  4. Tuya Adapter V 3.16.0 Instanz bleibt rot
    6.6k
13 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • F Offline
    FS1567
    Mein io-Broker läuft als Docker in einer Synology Nas.
    Der installierte Tuya Adapter zeigt folgendes:
    danach ein Login zum Cloud geht jetzt erstmalig:
    Dbug Log:
    tuya.0
    	2025-08-15 17:47:41.337	info	bf10c708588fe2f665pgtk: Connect locally to device
    tuya.0
    	2025-08-15 17:47:41.294	info	bf8009fd481520527b87z0: Connect locally to device
    tuya.0
    	2025-08-15 17:47:40.384	info	bf609dad6ee86ab803yfhc: Connect locally to device
    tuya.0
    	2025-08-15 17:47:39.965	info	IOT Cloud ID/Secret not configured, disabling real time State updates from Cloud MQTT
    tuya.0
    	2025-08-15 17:47:39.739	info	Listen for encrypted local Tuya devices on port 6667
    tuya.0
    	2025-08-15 17:47:39.738	info	Listen for local Tuya devices on port 6666
    tuya.0
    	2025-08-15 17:47:39.532	info	Try to sync devices from Cloud using stored cloud credentials
    tuya.0
    	2025-08-15 17:47:39.529	info	Existing devices initialized
    tuya.0
    	2025-08-15 17:47:39.528	info	bf609dad6ee86ab803yfhc: Connect locally to device
    tuya.0
    	2025-08-15 17:47:39.527	info	bf10c708588fe2f665pgtk: Connect locally to device
    tuya.0
    	2025-08-15 17:47:39.487	info	bf8009fd481520527b87z0: Connect locally to device
    tuya.0
    	2025-08-15 17:47:38.552	info	starting. Version 3.16.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v22.18.0, js-controller: 7.0.6
    host.buanet-iobroker
    	2025-08-15 17:47:36.414	info	instance system.adapter.tuya.0 in version "3.16.0" started with pid 11037
    	2025-08-15 17:47:28.621	info	instance system.adapter.tuya.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    tuya.0
    	2025-08-15 17:47:28.080	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    tuya.0
    	2025-08-15 17:47:28.079	info	terminating
    	2025-08-15 17:47:25.114	info	stopInstance system.adapter.tuya.0 send kill signal
    tuya.0
    	2025-08-15 17:47:25.076	info	Got terminate signal TERMINATE_YOURSELF
    	2025-08-15 17:47:25.073	info	stopInstance system.adapter.tuya.0 (force=false, process=true)
    tuya.0
    	2025-08-15 17:47:25.064	info	Set data for tuya.0 to appDeviceId=hwihbsdshylho8a4qt0dtjhfvi555113rux8psesml61 / sid=eu175033N2830543eq4dzkm3ddf409efd1973b2032d1820836b12d0b. Restart adapter now!
    tuya.0
    	2025-08-15 17:47:25.064	info	Cloud login successful. Adapter restarts in 5s
    tuya.0
    	2025-08-15 17:47:22.142	info	Listen for encrypted local Tuya devices on port 6667
    tuya.0
    	2025-08-15 17:47:22.141	info	Listen for local Tuya devices on port 6666
    tuya.0
    	2025-08-15 17:47:21.942	info	Try to sync devices from Cloud using stored cloud credentials
    tuya.0
    	2025-08-15 17:47:21.939	info	Existing devices initialized
    tuya.0
    	2025-08-15 17:47:21.938	info	bf609dad6ee86ab803yfhc: Connect locally to device
    tuya.0
    	2025-08-15 17:47:21.933	info	bf10c708588fe2f665pgtk: Connect locally to device
    tuya.0
    	2025-08-15 17:47:21.888	info	bf8009fd481520527b87z0: Connect locally to device
    tuya.0
    	2025-08-15 17:47:21.013	info	starting. Version 3.16.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v22.18.0, js-controller: 7.0.6
    die Daten werden im Objekt-bereich angezeigt:
    Frage:
    wie bekomm ich verbunden mit Gerät auf Grün, wenn doch Objekte angezeigt werden und lokal alles Verbunden ist?
    Was mach ich falsch??
    Mod-Edit
    Bitte Code-Tags </> benutzen!
    Thomas BraunT C 2 Antworten Letzte Antwort
    • F FS1567
      Dbug Log:
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      tuya.0
      Frage:
      Mod-Edit
      @fs1567
      Dürfte damit zusammen hängen:
      tuya.0
      F 1 Antwort Letzte Antwort
      • F FS1567
        Dbug Log:
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        tuya.0
        Frage:
        Mod-Edit
        CatShape
        schrieb am zuletzt editiert von CatShape
        @fs1567
        Ich würde Dir empfehlen, das zu machen, was in den Adapter-Instanzeinstellungen steht:
        Ich vermute, dass der Adapter den jeweiligen "localKey" Deiner Geräte nicht kennt, oder einen veralteten/ungültigen gespeichert hat. Um die aktuellen "localKeys" zu erhalten, musst Du eben in den Instanz-Einstellungen die Geräte einmalig mit der Cloud synchronisieren.
        Ich glaube der "localKey" von einem Tuya-Gerät ist nur solange gültig bis Du das Gerät resettest und/oder neu in die Tuya-App einbindest. Beim ausführen einer solchen Aktion bekommt das Gerät einen neuen "localKey". Und deshalb muss sich der Adapter nach einer solchen Aktion diesen neuen "localKey" auch erstmal wieder aus der Cloud besorgen.
        Raspberry Pi 5 8GB; Raspberry Pi OS; ioBroker; ecoflow_catshape, shelly-http-cs, tuya-cs
        • C CatShape
          @fs1567
          FS1567
          @catshape
          Danke für die Antwort
          hab ich gemacht, mit Erfolg, aber keine Wirkung auf die Instanz!
            @fs1567
            tuya.0
            FS1567
            Hallo Thomas, das ist auch meine Befürchtung, aber
            • wo
            • wie
            kann ich den IOT Coud ITSecret "configurieren"
            Die Smart Live App zeigt mir die Geräte an und ich kann sie damit bedienen
            Die Zugangsdaten hab ich im Tya Adapter eingegeben und er ruft die Daten auch von dort ab.
            Also was ist das?
            Habe gestern nochmals den Adapter deinstalliert und neu installiert, gleicher Fehler wieder.
            Bin für jede Hilfe dankbar
            • F FS1567
              • wo
              • wie
              Also was ist das?
              @fs1567
              Mal in die ReadMe geschaut?
              https://www.iobroker.net/#en/adapters/adapterref/iobroker.tuya/README.md
                @fs1567
                FS1567
                Danke für den Link, hab ich schon 4 mal gelesen.
                Also ich habe aktuell installiert (zur Probe) bevor ich alles anschließe:
                1. Wi-Fi IR + FR Remote Controller 1 x
                2. Tuya Smart Plug WiFi Steckdose 16A mit Power Messung 1 x
                weitere 6 liegen hier zum Anschließen wenn es denn geht.
                so hier die Objekt-Daten des smartPlugin Netzsteckers:
                Local connect flase ist richtig, da ich die Ports im Docker nicht freigegeben habe. --> hilft das?
                Zeigt er mir dehalb keine IP-Adresse an?
                • F FS1567
                  @fs1567
                  Zu Docker sag ich nichts...
                  Da sind die Netzwerkeinstellungen ggfls. ganz anders als in 'richtigen' Systemen.
                    @fs1567
                    FS1567
                    Sorry,
                    die Frage war ob ich local Ports wirklich freigeben muss?
                    Bei meinen HomeMatic IP Geräten von der Markise funzt alles und die läuft im gleichen Docker auf der NAS
                    hab nen Neustart gemacht und bei Tuya bleibt alles beim alten:
                    • F Offline
                      FS1567
                      so ich kann euch die Lösung nennen:
                      Für Tyua zusätzlich die Ports 6666 / 6667 TCP/UDP freigeben
                      Achtung : es müssen beide Ports sein und auch UDP
                      Danach logischerweise auch noch die Firewall des Gerätes dafür freischalten
                      Leidr kann ich gerade kein Bild hochladen
                      Danke für die Anregungen
                      • F FS1567
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @fs1567
                        Du hast also eine Bridge Installation …. Gut zu wissen
                        • haselchenH haselchen
                          @fs1567
                          FS1567
                          @haselchen
                          Gut erkannt,
                          möchte es auf MC-VLAN umstellen, ist aber komplex,
                          der NAS hat 4 Netzanschlüsse als Bond, den Bond stelle ich gerade um auf BOND mit 8 VLAN über die Console; auf dem NAS laufen auch 4 Docker Container, also Netztrennung auf dem NAS
                          also wenn du mir ein gutes Tutorial für MC-VLAN bei der Konstellation hast bin ich dankbar (sind noch 4 Cisco Switche und 3 weiter NAS im Netz)
                          • F FS1567
                            @haselchen
                            Gut erkannt,
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @fs1567 sagte in Tuya Adapter V 3.16.0 Instanz bleibt rot:
                            Bei dem Vorhaben können Dir bestimmt andere eingefleischte Dockerfans helfen.
                            Aber aus reiner Neugier, wenn ich das richtig gelesen habe , hast Du 4 Container und betreibst einen Aufwand , als wenn Du ein Unternehmen führst .
                            Worin liegt der Ansporn?
                            Wenn das alles Bridge Installationen sind, musste Du manuell bei jedem Container die Ports freigeben.
                            Edit: bestes Beispiel dieser Thread hier von Dir
