  3. Einsteigerfragen
  4. Modbus Finder 7M.38.8.400.0212 auslesen
    5.3k
87 Beiträge 8 Kommentatoren 15.9k Aufrufe 6 Beobachtet
    @sascha-hartmann und der USB-Port stimmt?
    wenn du dir nicht sicher bist, bitte doch die Langfassung von iob diag
    Sascha HartmannS Offline
    Sascha Hartmann
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: schopf
           Icon name: computer
              Kernel: Linux 6.6.51+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     06:51:06 up 14:40,  4 users,  load average: 0.77, 0.68, 0.51
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-07-09 06:51:07 CEST
               Universal time: Wed 2025-07-09 04:51:07 UTC
                     RTC time: Wed 2025-07-09 04:51:07
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    hartmann
    HOME=/home/hartmann
    GROUPS=hartmann adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        1.2G        4.3G         29M        3.1G        7.2G
    Swap:           209M          0B        209M
    Total:          8.7G        1.2G        4.5G
    Active iob-Instances:   6
             8052 M total memory
             1142 M used memory
             2935 M active memory
              703 M inactive memory
             4095 M free memory
              134 M buffer memory
             2805 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 06:51:07 up 14:40,  4 users,  load average: 0.77, 0.68, 0.51
    Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.3 total,   4095.1 free,   1142.4 used,   2940.0 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6909.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.8G     0  3.8G   0% /dev
    tmpfs          tmpfs     806M  6.7M  799M   1% /run
    /dev/mmcblk0p2 ext4      113G   12G   96G  11% /
    tmpfs          tmpfs     4.0G  368K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
    tmpfs          tmpfs     806M  192K  806M   1% /run/user/1000
    [Tue Jul  8 16:10:49 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe  smsc95xx.macaddr=2C:CF:67:9A:42:37 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a827d94a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Tue Jul  8 16:10:50 2025] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
    [Tue Jul  8 16:10:51 2025] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    5.1G    /var/
    4.0G    /var/log/journal/e60149e5b02640408b3f8e36879ec411
    4.0G    /var/log
    549M    /var/cache
    Archived and active journals take up 3.9G in the file system.
    /opt/iobroker/backups:
    1.8M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    145M    /opt/iobroker/iobroker-data/
    125M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
    5.5M    /opt/iobroker/iobroker-data/objects.jsonl
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_USB_Serial_Converter_FTB6SPL3-if00-port0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.3
    /usr/bin/node           v20.19.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
     *** 20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    schopf              schopf (version: 7.0.6, hostname: schopf        , alive, uptime: 151)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : schopf                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : schopf                                   -  enabled
    + system.adapter.discovery.0              : discovery             : schopf                                   -  enabled
    + system.adapter.javascript.0             : javascript            : schopf                                   -  enabled
    + system.adapter.modbus.0                 : modbus                : schopf                                   -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Objects and States
    Objects:        211
    States:         144
    W: GPG error: https://packages.twingate.com/apt  InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 5C363F09A9174A9E
    Hit:1 https://download.docker.com/linux/debian bookworm InRelease
    Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm InRelease
    Hit:5 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:6 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:7 https://apt.grafana.com stable InRelease
    Get:8 https://packages.twingate.com/apt  InRelease [2043 B]
    Hit:9 https://apt.grafana.com beta InRelease
    Ign:8 https://packages.twingate.com/apt  InRelease
    Fetched 2043 B in 1s (2594 B/s)
    Reading package lists...
    Pending Updates: 259
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7893       820/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7718783    1732282/iobroker.js
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7718778    1732282/iobroker.js
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          4133385    927897/cupsd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          4133384    927897/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7895       820/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        12242      1615/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7719701    1732335/io.admin.0
    udp        0      0 0.0.0.0:59557           0.0.0.0:*                           104        7850       633/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7848       633/avahi-daemon: r
    udp6       0      0 :::48959                :::*                                104        7851       633/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        7849       633/avahi-daemon: r
    2025-07-09 06:49:45.734  - debug: modbus.0 (1735032) Initialize Objects for coils: []
    2025-07-09 06:49:45.735  - debug: modbus.0 (1735032) Initialize Objects for inputRegs: []
    2025-07-09 06:49:45.735  - debug: modbus.0 (1735032) Initialize Objects for holdingRegs: [{"_address":"30025","name":"Kommunikation","description":"","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":30025,"deviceId":33,"id":"holdingRegisters._Kommunikation"}]
    2025-07-09 06:49:45.735  - debug: modbus.0 (1735032) Add holdingRegisters._Kommunikation: {"_id":"holdingRegisters._Kommunikation","type":"state","common":{"name":"","role":"value","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":30025,"deviceId":33,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    2025-07-09 06:49:45.835  - debug: modbus.0 (1735032) connect to serial /dev/ttyUSB0 with 19200
    2025-07-09 06:49:45.845  - info: modbus.0 (1735032) Connected to slave
    2025-07-09 06:49:45.846  - debug: modbus.0 (1735032) [DevID_33] Poll start ---------------------
    2025-07-09 06:49:45.846  - debug: modbus.0 (1735032) Initialization of scale factors done!
    2025-07-09 06:49:45.847  - debug: modbus.0 (1735032) [DevID_33/holdingRegs] Poll address 30025 - 1 registers
    2025-07-09 06:49:50.848  - warn: modbus.0 (1735032) Error: undefined
    2025-07-09 06:49:50.848  - error: modbus.0 (1735032) Request timed out.
    2025-07-09 06:49:50.848  - warn: modbus.0 (1735032) [DevID_33] Poll error count: 1 code: {"err":"timeout","timeout":5000}
    2025-07-09 06:49:51.850  - info: modbus.0 (1735032) Disconnected from slave
    2025-07-09 06:49:51.853  - debug: modbus.0 (1735032) Clearing timeout of the current request.
    2025-07-09 06:49:51.854  - debug: modbus.0 (1735032) Cleaning up request fifo.
    2025-07-09 06:50:51.851  - debug: modbus.0 (1735032) connect to serial /dev/ttyUSB0 with 19200
    2025-07-09 06:50:51.861  - info: modbus.0 (1735032) Connected to slave
    2025-07-09 06:50:51.861  - debug: modbus.0 (1735032) [DevID_33] Poll start ---------------------
    2025-07-09 06:50:51.861  - debug: modbus.0 (1735032) [DevID_33/holdingRegs] Poll address 30025 - 1 registers
    2025-07-09 06:50:56.861  - warn: modbus.0 (1735032) Error: undefined
    2025-07-09 06:50:56.862  - error: modbus.0 (1735032) Request timed out.
    2025-07-09 06:50:56.862  - warn: modbus.0 (1735032) [DevID_33] Poll error count: 2 code: {"err":"timeout","timeout":5000}
    2025-07-09 06:50:57.862  - info: modbus.0 (1735032) Disconnected from slave
    2025-07-09 06:50:57.866  - debug: modbus.0 (1735032) Clearing timeout of the current request.
    2025-07-09 06:50:57.866  - debug: modbus.0 (1735032) Cleaning up request fifo.
    iob diag has finished.
    wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
    • Sascha HartmannS Sascha Hartmann
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      hartmann
      HOME=/home/hartmann
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           209M          0B        209M
               8052 M total memory
               1142 M used memory
               4095 M free memory
                134 M buffer memory
               2805 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      *** FILESYSTEM ***
      /var:
      5.1G    /var/
      4.0G    /var/log
      549M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        211
      States:         144
      wendy2702W Offline
      wendy2702W Offline
      @sascha-hartmann ist das der USB Konverter den du benutzen willst um den Zähler auszulesen oder ein anderer:
      Das ist ein USB zu Seriel RS232 Konverter wenn man Google befragt. Du benötigst einen USB zu RS485 Konverter denke ich.
      Sascha HartmannS 1 Antwort Letzte Antwort
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        hartmann
        HOME=/home/hartmann
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 8052 M total memory
                 1142 M used memory
                 4095 M free memory
                  134 M buffer memory
                 2805 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        5.1G    /var/
        4.0G    /var/log
        549M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        211
        States:         144
        @sascha-hartmann sagte in Modbus Finder 7M.38.8.400.0212 auslesen:
        Hau die Updates drauf...
        • wendy2702W wendy2702
          Sascha Hartmann
          @wendy2702
          Hi Eigentlich dürfte das nicht sein
            Sascha Hartmann
            Hi System ist auf dem Aktuellen Stand
              @sascha-hartmann
              Da hängen über 200 Updates des Betriebssystems in der Pipeline.
                @sascha-hartmann
                Sascha Hartmann
                ok habs grad nochmal durchlaufen lassen
                Aktuell nur das offen aber die bekomm ich nicht geupdatet
                hartmann@schopf:~ $ apt list --upgradable
                Listing... Done
                lxinput/stable 0.3.5-1+rpt26 arm64 [upgradable from: 0.3.5-1+rpt25]
                raspberrypi-ui-mods/stable 1.20250506 arm64 [upgradable from: 1.20241107]
                wf-panel-pi/stable 0.102 arm64 [upgradable from: 0.91]
                wfplug-connect/stable 0.14 arm64 [upgradable from: 0.9]
                wfplug-squeek/stable 0.6 arm64 [upgradable from: 0.5]
                hartmann@schopf:~ $
                  Listing... Done
                  hartmann@schopf:~ $
                  Sascha Hartmann
                  @sascha-hartmann
                  Jetzt Ist alles Aktuell
                  hartmann@schopf:~ $ sudo apt upgrade
                  Reading package lists... Done
                  Calculating upgrade... Done
                  The following packages were automatically installed and are no longer required:
                    avahi-utils gir1.2-handy-1 gir1.2-polkit-1.0 lxplug-network
                  Use 'sudo apt autoremove' to remove them.
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  hartmann@schopf:~ $
                  Geht allerdings noch nicht
                  hier nochmal aktuelle Ausgabe von iob diag
                  ```bash
                  Script v.2025-03-08
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   09:24:40 up 17:13,  4 users,  load average: 0.14, 0.24, 0.56
                  CPU threads: 4
                  Current issues:
                                 Local time: Wed 2025-07-09 09:24:40 CEST
                             Universal time: Wed 2025-07-09 07:24:40 UTC
                                   RTC time: Wed 2025-07-09 07:24:40
                                NTP service: active
                            RTC in local TZ: no
                  hartmann
                  HOME=/home/hartmann
                  iobroker
                  HOME=/home/iobroker
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            8.4G        1.8G        408M         80M        6.5G        6.7G
                  Swap:           209M          0B        209M
                  Total:          8.7G        1.8G        618M
                           8052 M total memory
                           1678 M used memory
                           3801 M active memory
                           3296 M inactive memory
                            389 M free memory
                            176 M buffer memory
                           5981 M swap cache
                            199 M total swap
                              0 M used swap
                            199 M free swap
                  top - 09:24:40 up 17:13,  4 users,  load average: 0.14, 0.24, 0.56
                  Tasks: 235 total,   1 running, 234 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   8052.3 total,    389.0 free,   1678.6 used,   6158.3 buff/cache
                  MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6373.7 avail Mem
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * twingate.service loaded failed failed Twingate Remote Access Client
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     806M  6.5M  799M   1% /run
                  /dev/mmcblk0p2 ext4      113G   12G   96G  12% /
                  tmpfs          tmpfs     4.0G   16M  4.0G   1% /dev/shm
                  /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
                  tmpfs          tmpfs     806M  208K  806M   1% /run/user/1000
                  /var:
                  5.3G    /var/
                  4.1G    /var/log/journal/e60149e5b02640408b3f8e36879ec411
                  4.1G    /var/log
                  549M    /var/cache
                  Archived and active journals take up 4.0G in the file system.
                  153M    /opt/iobroker/iobroker-data/
                  11M     /opt/iobroker/iobroker-data/objects.jsonl
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  schopf              schopf (version: 7.0.6, hostname: schopf        , alive, uptime: 9376)
                  admin:          7.6.17
                  javascript:     8.9.2
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        211
                  States:         144
                  Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Fetched 2043 B in 1s (2868 B/s)
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8910608    2021856/sshd: /usr/
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          8910610    2021856/sshd: /usr/
                  tcp6       0      0 :::3000                 :::*                    LISTEN      112        8896994    2003890/grafana
                  2025-07-09 09:23:42.632  - debug: modbus.0 (2062978) Initialize Objects for coils: []
                  2025-07-09 09:23:42.632  - debug: modbus.0 (2062978) Initialize Objects for inputRegs: [{"_address":"30002","name":"ModelNummer","description":"ModellNr","unit":"","type":"string","len":8,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":30002,"deviceId":33,"id":"inputRegisters._ModelNummer"}]
                  2025-07-09 09:23:42.632  - debug: modbus.0 (2062978) Add inputRegisters._ModelNummer: {"_id":"inputRegisters._ModelNummer","type":"state","common":{"name":"ModellNr","role":"level","type":"string","read":true,"write":false,"def":"","unit":""},"native":{"regType":"inputRegs","address":30002,"deviceId":33,"type":"string","len":8,"offset":0,"factor":1}}
                  2025-07-09 09:23:42.632  - debug: modbus.0 (2062978) Initialize Objects for holdingRegs: []
                  2025-07-09 09:23:42.735  - debug: modbus.0 (2062978) connect to serial /dev/ttyUSB0 with 19200
                  2025-07-09 09:23:42.746  - info: modbus.0 (2062978) Connected to slave
                  2025-07-09 09:23:42.747  - debug: modbus.0 (2062978) [DevID_33] Poll start ---------------------
                  2025-07-09 09:23:42.748  - debug: modbus.0 (2062978) Initialization of scale factors done!
                  2025-07-09 09:23:42.749  - debug: modbus.0 (2062978) [DevID_33/inputRegs] Poll address 30002 - 8 registers
                  2025-07-09 09:23:47.750  - warn: modbus.0 (2062978) Error: undefined
                  2025-07-09 09:23:47.751  - error: modbus.0 (2062978) Request timed out.
                  2025-07-09 09:23:47.751  - warn: modbus.0 (2062978) [DevID_33] Poll error count: 1 code: {"err":"timeout","timeout":5000}
                  2025-07-09 09:23:48.751  - info: modbus.0 (2062978) Disconnected from slave
                  2025-07-09 09:23:48.754  - debug: modbus.0 (2062978) Clearing timeout of the current request.
                  2025-07-09 09:23:48.755  - debug: modbus.0 (2062978) Cleaning up request fifo.
                  2025-07-09 09:24:48.752  - debug: modbus.0 (2062978) connect to serial /dev/ttyUSB0 with 19200
                  2025-07-09 09:24:48.762  - info: modbus.0 (2062978) Connected to slave
                  2025-07-09 09:24:48.762  - debug: modbus.0 (2062978) [DevID_33] Poll start ---------------------
                  2025-07-09 09:24:48.762  - debug: modbus.0 (2062978) [DevID_33/inputRegs] Poll address 30002 - 8 registers
                  2025-07-09 09:24:53.763  - warn: modbus.0 (2062978) Error: undefined
                  2025-07-09 09:24:53.763  - error: modbus.0 (2062978) Request timed out.
                  2025-07-09 09:24:53.763  - warn: modbus.0 (2062978) [DevID_33] Poll error count: 2 code: {"err":"timeout","timeout":5000}
                  2025-07-09 09:24:54.763  - info: modbus.0 (2062978) Disconnected from slave
                  2025-07-09 09:24:54.766  - debug: modbus.0 (2062978) Clearing timeout of the current request.
                  2025-07-09 09:24:54.767  - debug: modbus.0 (2062978) Cleaning up request fifo.
                    @sascha-hartmann
                    hartmann@schopf:~ $
                    ```bash
                    Script v.2025-03-08
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                  NTP service: active
                              RTC in local TZ: no
                    hartmann
                    HOME=/home/hartmann
                    iobroker
                    HOME=/home/iobroker
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           209M          0B        209M
                             8052 M total memory
                             1678 M used memory
                              389 M free memory
                              176 M buffer memory
                             5981 M swap cache
                              199 M total swap
                                0 M used swap
                              199 M free swap
                    *** FILESYSTEM ***
                    /var:
                    5.3G    /var/
                    4.1G    /var/log
                    549M    /var/cache
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.6.17
                    javascript:     8.9.2
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        211
                    States:         144
                    Pending Updates: 0
                    wendy2702W Offline
                    wendy2702W Offline
                    @sascha-hartmann Hm,
                    Also wenn ich nach dem Chipsatz bzw. Der Bezeichnung “FTB6SPL3” suche lande ich immer bei RS232 Geräten.
                    Kannst du den mal in einen WIN PC Stecken ob der da anders erkannt wird, nicht das dein Ubuntu irgendetwas falsch interpretiert.
                    Kannst den auch mal abstecken, anstecken und im Anchluß die Ausgabe von
                    dmesg
                    Hier posten.
                    Sascha HartmannS 2 Antworten Letzte Antwort
                      dmesg
                      Hier posten.
                      Sascha Hartmann
                      @wendy2702
                      hartmann@schopf:~ $ dmesg
                      [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
                      [    0.000000] Linux version 6.12.34+rpt-rpi-2712 (serge@raspberrypi.com) (aarch64-linux-gnu-gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.12.34-1+rpt1~bookworm (2025-06-26)
                      [    0.000000] KASLR enabled
                      [    0.000000] random: crng init done
                      [    0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
                      [    0.000000] efi: UEFI not found.
                      [    0.000000] Reserved memory: created CMA memory pool at 0x000000003a000000, size 64 MiB
                      [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
                      [    0.000000] OF: reserved mem: 0x000000003a000000..0x000000003dffffff (65536 KiB) map reusable linux,cma
                      [    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
                      [    0.000000] OF: reserved mem: 0x000000003fd165c0..0x000000003fd165f7 (0 KiB) nomap non-reusable nvram@0
                      [    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000001ffffffff]
                      [    0.000000] Faking node 0 at [mem 0x0000000000000000-0x000000003fffffff] (1024MB)
                      [    0.000000] Faking node 1 at [mem 0x0000000040000000-0x000000007fffffff] (1024MB)
                      [    0.000000] Faking node 2 at [mem 0x0000000080000000-0x00000000bfffffff] (1024MB)
                      [    0.000000] Faking node 3 at [mem 0x00000000c0000000-0x00000000ffffffff] (1024MB)
                      [    0.000000] Faking node 4 at [mem 0x0000000100000000-0x000000013fffffff] (1024MB)
                      [    0.000000] Faking node 5 at [mem 0x0000000140000000-0x000000017fffffff] (1024MB)
                      [    0.000000] Faking node 6 at [mem 0x0000000180000000-0x00000001bfffffff] (1024MB)
                      [    0.000000] Faking node 7 at [mem 0x00000001c0000000-0x00000001ffffffff] (1024MB)
                      [    0.000000] NUMA: Initialized distance table, cnt=8
                      [    0.000000] NODE_DATA(0) allocated [mem 0x3fbfd200-0x3fbfffff]
                      [    0.000000] NODE_DATA(1) allocated [mem 0x7fffd200-0x7fffffff]
                      [    0.000000] NODE_DATA(2) allocated [mem 0xbfffd200-0xbfffffff]
                      [    0.000000] NODE_DATA(3) allocated [mem 0xffffd200-0xffffffff]
                      [    0.000000] NODE_DATA(4) allocated [mem 0x13fffd200-0x13fffffff]
                      [    0.000000] NODE_DATA(5) allocated [mem 0x17fffd200-0x17fffffff]
                      [    0.000000] NODE_DATA(6) allocated [mem 0x1bfffd200-0x1bfffffff]
                      [    0.000000] NODE_DATA(7) allocated [mem 0x1ffb9c6c0-0x1ffb9f4bf]
                      [    0.000000] Zone ranges:
                      [    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
                      [    0.000000]   DMA32    empty
                      [    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
                      [    0.000000] Movable zone start for each node
                      [    0.000000] Early memory node ranges
                      [    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
                      [    0.000000]   node   0: [mem 0x0000000000080000-0x000000003fbfffff]
                      [    0.000000]   node   1: [mem 0x0000000040000000-0x000000007fffffff]
                      [    0.000000]   node   2: [mem 0x0000000080000000-0x00000000bfffffff]
                      [    0.000000]   node   3: [mem 0x00000000c0000000-0x00000000ffffffff]
                      [    0.000000]   node   4: [mem 0x0000000100000000-0x000000013fffffff]
                      [    0.000000]   node   5: [mem 0x0000000140000000-0x000000017fffffff]
                      [    0.000000]   node   6: [mem 0x0000000180000000-0x00000001bfffffff]
                      [    0.000000]   node   7: [mem 0x00000001c0000000-0x00000001ffffffff]
                      [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003fbfffff]
                      [    0.000000] Initmem setup node 1 [mem 0x0000000040000000-0x000000007fffffff]
                      [    0.000000] Initmem setup node 2 [mem 0x0000000080000000-0x00000000bfffffff]
                      [    0.000000] Initmem setup node 3 [mem 0x00000000c0000000-0x00000000ffffffff]
                      [    0.000000] Initmem setup node 4 [mem 0x0000000100000000-0x000000013fffffff]
                      [    0.000000] Initmem setup node 5 [mem 0x0000000140000000-0x000000017fffffff]
                      [    0.000000] Initmem setup node 6 [mem 0x0000000180000000-0x00000001bfffffff]
                      [    0.000000] Initmem setup node 7 [mem 0x00000001c0000000-0x00000001ffffffff]
                      [    0.000000] On node 1, zone DMA: 256 pages in unavailable ranges
                      [    0.000000] psci: probing for conduit method from DT.
                      [    0.000000] psci: PSCIv1.1 detected in firmware.
                      [    0.000000] psci: Using standard PSCI v0.2 function IDs
                      [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
                      [    0.000000] psci: SMC Calling Convention v1.2
                      [    0.000000] percpu: Embedded 15 pages/cpu s193368 r8192 d44200 u245760
                      [    0.000000] pcpu-alloc: s193368 r8192 d44200 u245760 alloc=15*16384
                      [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                      [    0.000000] Detected PIPT I-cache on CPU0
                      [    0.000000] CPU features: detected: Virtualization Host Extensions
                      [    0.000000] CPU features: detected: Spectre-v4
                      [    0.000000] CPU features: detected: Spectre-BHB
                      [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
                      [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
                      [    0.000000] CPU features: detected: SSBS not fully self-synchronizing
                      [    0.000000] alternatives: applying boot alternatives
                      [    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:9A:42:37 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a827d94a-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
                      [    0.000000] cgroup: Disabling memory control group subsystem
                      [    0.000000] mempolicy: NUMA default policy overridden to 'interleave:0-7'
                      [    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
                      [    0.000000] Fallback order for Node 0: 0 1 2 3 4 5 6 7
                      [    0.000000] Fallback order for Node 1: 1 2 3 4 5 6 7 0
                      [    0.000000] Fallback order for Node 2: 2 3 4 5 6 7 0 1
                      [    0.000000] Fallback order for Node 3: 3 4 5 6 7 0 1 2
                      [    0.000000] Fallback order for Node 4: 4 5 6 7 0 1 2 3
                      [    0.000000] Fallback order for Node 5: 5 6 7 0 1 2 3 4
                      [    0.000000] Fallback order for Node 6: 6 7 0 1 2 3 4 5
                      [    0.000000] Fallback order for Node 7: 7 0 1 2 3 4 5 6
                      [    0.000000] Built 8 zonelists, mobility grouping on.  Total pages: 524032
                      [    0.000000] Policy zone: Normal
                      [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
                      [    0.000000] software IO TLB: area num 4.
                      [    0.000000] software IO TLB: mapped [mem 0x00000000fbffc000-0x00000000ffffc000] (64MB)
                      [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=8
                      [    0.000000] ftrace: allocating 45269 entries in 45 pages
                      [    0.000000] ftrace: allocated 45 pages with 4 groups
                      [    0.000000] rcu: Preemptible hierarchical RCU implementation.
                      [    0.000000] rcu:     RCU event tracing is enabled.
                      [    0.000000]  Trampoline variant of Tasks RCU enabled.
                      [    0.000000]  Rude variant of Tasks RCU enabled.
                      [    0.000000]  Tracing variant of Tasks RCU enabled.
                      [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
                      [    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                      [    0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                      [    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
                      [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
                      [    0.000000] Root IRQ handler: gic_handle_irq
                      [    0.000000] GIC: Using split EOI/Deactivate mode
                      [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
                      [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
                      [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
                      [    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
                      [    0.000091] Console: colour dummy device 80x25
                      [    0.000096] printk: legacy console [tty1] enabled
                      [    0.000166] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
                      [    0.000170] pid_max: default: 32768 minimum: 301
                      [    0.000262] LSM: initializing lsm=capability
                      [    0.001783] Dentry cache hash table entries: 1048576 (order: 9, 8388608 bytes, vmalloc)
                      [    0.002518] Inode-cache hash table entries: 524288 (order: 8, 4194304 bytes, vmalloc)
                      [    0.002563] Mount-cache hash table entries: 16384 (order: 3, 131072 bytes, vmalloc)
                      [    0.002583] Mountpoint-cache hash table entries: 16384 (order: 3, 131072 bytes, vmalloc)
                      [    0.003315] rcu: Hierarchical SRCU implementation.
                      [    0.003322] rcu:     Max phase no-delay instances is 1000.
                      [    0.003364] Timer migration: 1 hierarchy levels; 8 children per group; 0 crossnode level
                      [    0.003706] EFI services will not be available.
                      [    0.003774] smp: Bringing up secondary CPUs ...
                      [    0.003959] Detected PIPT I-cache on CPU1
                      [    0.004019] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
                      [    0.004231] Detected PIPT I-cache on CPU2
                      [    0.004257] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
                      [    0.004454] Detected PIPT I-cache on CPU3
                      [    0.004474] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
                      [    0.004499] smp: Brought up 8 nodes, 4 CPUs
                      [    0.004507] SMP: Total of 4 processors activated.
                      [    0.004508] CPU: All CPU(s) started at EL2
                      [    0.004510] CPU features: detected: 32-bit EL0 Support
                      [    0.004512] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
                      [    0.004514] CPU features: detected: Common not Private translations
                      [    0.004515] CPU features: detected: CRC32 instructions
                      [    0.004518] CPU features: detected: RCpc load-acquire (LDAPR)
                      [    0.004520] CPU features: detected: LSE atomic instructions
                      [    0.004521] CPU features: detected: Privileged Access Never
                      [    0.004522] CPU features: detected: RAS Extension Support
                      [    0.004524] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
                      [    0.004549] alternatives: applying system-wide alternatives
                      [    0.005986] CPU features: detected: Hardware dirty bit management on CPU0-3
                      [    0.006156] Memory: 8141360K/8384512K available (14208K kernel code, 2418K rwdata, 4928K rodata, 5696K init, 647K bss, 151088K reserved, 65536K cma-reserved)
                      [    0.006327] devtmpfs: initialized
                      [    0.008209] Enabled cp15_barrier support
                      [    0.008214] Enabled setend support
                      [    0.008253] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
                      [    0.008259] futex hash table entries: 1024 (order: 2, 65536 bytes, vmalloc)
                      [    0.008374] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
                      [    0.008376] 0 pages in range for non-PLT usage
                      [    0.008377] 129308 pages in range for PLT usage
                      [    0.008463] pinctrl core: initialized pinctrl subsystem
                      [    0.008583] DMI not present or invalid.
                      [    0.012680] NET: Registered PF_NETLINK/PF_ROUTE protocol family
                      [    0.013050] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
                      [    0.013078] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
                      [    0.013107] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
                      [    0.013120] audit: initializing netlink subsys (disabled)
                      [    0.013165] audit: type=2000 audit(0.012:1): state=initialized audit_enabled=0 res=1
                      [    0.013262] thermal_sys: Registered thermal governor 'step_wise'
                      [    0.013271] cpuidle: using governor menu
                      [    0.013327] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
                      [    0.013347] ASID allocator initialised with 32768 entries
                      [    0.013568] Serial: AMBA PL011 UART driver
                      [    0.014274] /soc@107c000000/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /soc@107c000000/interrupt-controller@7fff9000
                      [    0.014431] bcm2835-mbox 107c013880.mailbox: mailbox enabled
                      [    0.014550] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 16, base_baud = 0) is a PL011 rev3
                      [    0.014559] printk: legacy console [ttyAMA10] enabled
                      [    0.020036] raspberrypi-firmware soc@107c000000:firmware: Attached to firmware from 2025-05-08T14:13:17, variant start_cd
                      [    0.024031] raspberrypi-firmware soc@107c000000:firmware: Firmware hash is 6947117700000000000000000000000000000000
                      [    0.032546] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
                      [    0.032798] iommu: Default domain type: Translated
                      [    0.032800] iommu: DMA domain TLB invalidation policy: strict mode
                      [    0.033094] SCSI subsystem initialized
                      [    0.033130] usbcore: registered new interface driver usbfs
                      [    0.033136] usbcore: registered new interface driver hub
                      [    0.033143] usbcore: registered new device driver usb
                      [    0.033211] pps_core: LinuxPPS API ver. 1 registered
                      [    0.033212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
                      [    0.033215] PTP clock support registered
                      [    0.033456] vgaarb: loaded
                      [    0.033543] clocksource: Switched to clocksource arch_sys_counter
                      [    0.033663] VFS: Disk quotas dquot_6.6.0
                      [    0.033670] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
                      [    0.036814] NET: Registered PF_INET protocol family
                      [    0.036975] IP idents hash table entries: 131072 (order: 6, 1048576 bytes, vmalloc)
                      [    0.038513] tcp_listen_portaddr_hash hash table entries: 4096 (order: 2, 65536 bytes, vmalloc)
                      [    0.038549] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, vmalloc)
                      [    0.038555] TCP established hash table entries: 65536 (order: 5, 524288 bytes, vmalloc)
                      [    0.038746] TCP bind hash table entries: 65536 (order: 7, 2097152 bytes, vmalloc)
                      [    0.039432] TCP: Hash tables configured (established 65536 bind 65536)
                      [    0.039534] MPTCP token hash table entries: 8192 (order: 3, 196608 bytes, vmalloc)
                      [    0.039586] UDP hash table entries: 4096 (order: 3, 131072 bytes, vmalloc)
                      [    0.039649] UDP-Lite hash table entries: 4096 (order: 3, 131072 bytes, vmalloc)
                      [    0.039747] NET: Registered PF_UNIX/PF_LOCAL protocol family
                      [    0.039875] RPC: Registered named UNIX socket transport module.
                      [    0.039877] RPC: Registered udp transport module.
                      [    0.039878] RPC: Registered tcp transport module.
                      [    0.039879] RPC: Registered tcp-with-tls transport module.
                      [    0.039880] RPC: Registered tcp NFSv4.1 backchannel transport module.
                      [    0.039883] PCI: CLS 0 bytes, default 64
                      [    0.039970] Trying to unpack rootfs image as initramfs...
                      [    0.046585] kvm [1]: nv: 554 coarse grained trap handlers
                      [    0.046691] kvm [1]: IPA Size Limit: 40 bits
                      [    0.046714] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
                      [    0.046760] kvm [1]: vgic interrupt IRQ9
                      [    0.046772] kvm [1]: VHE mode initialized successfully
                      [    0.196714] Freeing initrd memory: 17584K
                      [    0.243371] Initialise system trusted keyrings
                      [    0.243649] workingset: timestamp_bits=42 max_order=19 bucket_order=0
                      [    0.244008] NFS: Registering the id_resolver key type
                      [    0.244015] Key type id_resolver registered
                      [    0.244016] Key type id_legacy registered
                      [    0.244026] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                      [    0.244028] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
                      [    0.244211] Key type asymmetric registered
                      [    0.244213] Asymmetric key parser 'x509' registered
                      [    0.244234] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
                      [    0.244268] io scheduler mq-deadline registered
                      [    0.244270] io scheduler kyber registered
                      [    0.244283] io scheduler bfq registered
                      [    0.244604] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/interrupt-controller@7d510600, parent irq: 27)
                      [    0.244636] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/interrupt-controller@7c502000, parent irq: 28)
                      [    0.244663] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d508380, parent irq: 29)
                      [    0.244697] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d508400, parent irq: 30)
                      [    0.244723] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d503000, parent irq: 31)
                      [    0.245632] ledtrig-cpu: registered to indicate activity on CPUs
                      [    0.275463] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
                      [    0.275753] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
                      [    0.275792] serial serial0: tty port ttyS0 registered
                      [    0.276047] iproc-rng200 107d208000.rng: hwrng registered
                      [    0.276080] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
                      [    0.276260] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
                      [    0.277556] brd: module loaded
                      [    0.278435] loop: module loaded
                      [    0.278522] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
                      [    0.278621] Loading iSCSI transport class v2.0-870.
                      [    0.279297] usbcore: registered new interface driver lan78xx
                      [    0.279305] usbcore: registered new interface driver smsc95xx
                      [    0.279350] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                      [    0.279364] dwc_otg: FIQ enabled
                      [    0.279365] dwc_otg: NAK holdoff enabled
                      [    0.279366] dwc_otg: FIQ split-transaction FSM enabled
                      [    0.279368] Module dwc_common_port init
                      [    0.279559] usbcore: registered new interface driver uas
                      [    0.279569] usbcore: registered new interface driver usb-storage
                      [    0.279634] mousedev: PS/2 mouse device common for all mice
                      [    0.287096] rpi-rtc soc@107c000000:rpi_rtc: registered as rtc0
                      [    0.288469] rpi-rtc soc@107c000000:rpi_rtc: setting system clock to 2025-07-09T07:28:38 UTC (1752046118)
                      [    0.288753] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
                      [    0.288756] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
                      [    0.290743] sdhci: Secure Digital Host Controller Interface driver
                      [    0.290745] sdhci: Copyright(c) Pierre Ossman
                      [    0.290772] sdhci-pltfm: SDHCI platform and OF driver helper
                      [    0.290834] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
                      [    0.290842] hid: raw HID events driver (C) Jiri Kosina
                      [    0.290861] usbcore: registered new interface driver usbhid
                      [    0.290862] usbhid: USB HID core driver
                      [    0.291130] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available
                      [    0.291338] NET: Registered PF_PACKET protocol family
                      [    0.291359] Key type dns_resolver registered
                      [    0.294762] registered taskstats version 1
                      [    0.294822] Loading compiled-in X.509 certificates
                      [    0.296227] Demotion targets for Node 0: null
                      [    0.296230] Demotion targets for Node 1: null
                      [    0.296231] Demotion targets for Node 2: null
                      [    0.296232] Demotion targets for Node 3: null
                      [    0.296233] Demotion targets for Node 4: null
                      [    0.296234] Demotion targets for Node 5: null
                      [    0.296235] Demotion targets for Node 6: null
                      [    0.296236] Demotion targets for Node 7: null
                      [    0.296385] Key type .fscrypt registered
                      [    0.296387] Key type fscrypt-provisioning registered
                      [    0.297195] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@1000120000 ranges:
                      [    0.297200] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@1000120000, using [bus 00-ff]
                      [    0.297207] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
                      [    0.297211] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
                      [    0.297217] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
                      [    0.297221] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
                      [    0.297225] brcm-pcie 1000120000.pcie:   IB MEM 0x1000130000..0x1000130fff -> 0xfffffff000
                      [    0.298544] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0002:00
                      [    0.298549] pci_bus 0002:00: root bus resource [bus 00-ff]
                      [    0.298552] pci_bus 0002:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
                      [    0.298554] pci_bus 0002:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
                      [    0.298565] pci 0002:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
                      [    0.298571] pci 0002:00:00.0: PCI bridge to [bus 00]
                      [    0.298573] pci 0002:00:00.0:   bridge window [mem 0x1f80000000-0x1fbfffffff]
                      [    0.298590] pci 0002:00:00.0: PME# supported from D0 D3hot
                      [    0.299191] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
                      [    0.401545] brcm-pcie 1000120000.pcie: clkreq-mode set to default
                      [    0.401548] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
                      [    0.401570] pci 0002:01:00.0: [1de4:0001] type 00 class 0x020000 PCIe Endpoint
                      [    0.401583] pci 0002:01:00.0: BAR 0 [mem 0xffffc000-0xffffffff]
                      [    0.401590] pci 0002:01:00.0: BAR 1 [mem 0xffc00000-0xffffffff]
                      [    0.401596] pci 0002:01:00.0: BAR 2 [mem 0xffff0000-0xffffffff]
                      [    0.401661] pci 0002:01:00.0: supports D1
                      [    0.401663] pci 0002:01:00.0: PME# supported from D0 D1 D3hot D3cold
                      [    0.409551] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
                      [    0.409560] pci 0002:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]: assigned
                      [    0.409563] pci 0002:01:00.0: BAR 1 [mem 0x1f00000000-0x1f003fffff]: assigned
                      [    0.409567] pci 0002:01:00.0: BAR 2 [mem 0x1f00400000-0x1f0040ffff]: assigned
                      [    0.409570] pci 0002:01:00.0: BAR 0 [mem 0x1f00410000-0x1f00413fff]: assigned
                      [    0.409575] pci 0002:00:00.0: PCI bridge to [bus 01]
                      [    0.409577] pci 0002:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
                      [    0.409580] pci_bus 0002:00: resource 4 [mem 0x1f00000000-0x1ffffffffb]
                      [    0.409582] pci_bus 0002:00: resource 5 [mem 0x1c00000000-0x1effffffff pref]
                      [    0.409584] pci_bus 0002:01: resource 1 [mem 0x1f00000000-0x1f005fffff]
                      [    0.409587] pci 0002:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
                      [    0.409594] pci 0002:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
                      [    0.409654] pcieport 0002:00:00.0: enabling device (0000 -> 0002)
                      [    0.409679] pcieport 0002:00:00.0: PME: Signaling with IRQ 38
                      [    0.409719] pcieport 0002:00:00.0: AER: enabled with IRQ 38
                      [    0.409775] rp1 0002:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
                      [    0.409778] rp1 0002:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
                      [    0.409789] rp1 0002:01:00.0: enabling device (0000 -> 0002)
                      [    0.410390] rp1 0002:01:00.0: chip_id 0x20001927
                      [    0.414347] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 100
                      [    0.429119] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 106 (2c:cf:67:9a:42:37)
                      [    0.429897] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
                      [    0.430124] xhci-hcd xhci-hcd.0: xHCI Host Controller
                      [    0.430129] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
                      [    0.430564] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000808000000810
                      [    0.430572] xhci-hcd xhci-hcd.0: irq 131, io mem 0x1f00200000
                      [    0.430626] xhci-hcd xhci-hcd.0: xHCI Host Controller
                      [    0.430628] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
                      [    0.430631] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
                      [    0.430668] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
                      [    0.430671] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [    0.430673] usb usb1: Product: xHCI Host Controller
                      [    0.430674] usb usb1: Manufacturer: Linux 6.12.34+rpt-rpi-2712 xhci-hcd
                      [    0.430676] usb usb1: SerialNumber: xhci-hcd.0
                      [    0.430770] hub 1-0:1.0: USB hub found
                      [    0.430782] hub 1-0:1.0: 2 ports detected
                      [    0.430873] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
                      [    0.430875] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [    0.430877] usb usb2: Product: xHCI Host Controller
                      [    0.430879] usb usb2: Manufacturer: Linux 6.12.34+rpt-rpi-2712 xhci-hcd
                      [    0.430880] usb usb2: SerialNumber: xhci-hcd.0
                      [    0.430939] hub 2-0:1.0: USB hub found
                      [    0.430949] hub 2-0:1.0: 1 port detected
                      [    0.431169] xhci-hcd xhci-hcd.1: xHCI Host Controller
                      [    0.431172] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
                      [    0.431595] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000808000000810
                      [    0.431602] xhci-hcd xhci-hcd.1: irq 136, io mem 0x1f00300000
                      [    0.431655] xhci-hcd xhci-hcd.1: xHCI Host Controller
                      [    0.431657] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
                      [    0.431659] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
                      [    0.431682] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
                      [    0.431685] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [    0.431687] usb usb3: Product: xHCI Host Controller
                      [    0.431688] usb usb3: Manufacturer: Linux 6.12.34+rpt-rpi-2712 xhci-hcd
                      [    0.431690] usb usb3: SerialNumber: xhci-hcd.1
                      [    0.431753] hub 3-0:1.0: USB hub found
                      [    0.431763] hub 3-0:1.0: 2 ports detected
                      [    0.431837] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
                      [    0.431839] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
                      [    0.431841] usb usb4: Product: xHCI Host Controller
                      [    0.431842] usb usb4: Manufacturer: Linux 6.12.34+rpt-rpi-2712 xhci-hcd
                      [    0.431844] usb usb4: SerialNumber: xhci-hcd.1
                      [    0.431904] hub 4-0:1.0: USB hub found
                      [    0.431913] hub 4-0:1.0: 1 port detected
                      [    0.432668] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
                      [    0.433073] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
                      [    0.433516] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
                      [    0.433938] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
                      [    0.434361] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
                      [    0.434771] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
                      [    0.434984] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
                      [    0.435068] mmc0: CQHCI version 5.10
                      [    0.435315] mmc1: CQHCI version 5.10
                      [    0.436446] of_cfs_init
                      [    0.436478] of_cfs_init: OK
                      [    0.437202] clk: Disabling unused clocks
                      [    0.445787] PM: genpd: Disabling unused power domains
                      [    0.473240] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
                      [    0.582794] mmc0: new ultra high speed SDR104 SDXC card at address 0001
                      [    0.582963] mmcblk0: mmc0:0001 SD 115 GiB
                      [    0.583842]  mmcblk0: p1 p2
                      [    0.583923] mmcblk0: mmc0:0001 SD 115 GiB
                      [    0.624079] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
                      [    0.626949] Freeing unused kernel memory: 5696K
                      [    0.627042] Run /init as init process
                      [    0.627044]   with arguments:
                      [    0.627045]     /init
                      [    0.627046]     splash
                      [    0.627047]   with environment:
                      [    0.627049]     HOME=/
                      [    0.627049]     TERM=linux
                      [    0.658298] mmc1: new ultra high speed DDR50 SDIO card at address 0001
                      [    0.677562] usb 1-1: new full-speed USB device number 2 using xhci-hcd
                      [    0.699072] input: pwr_button as /devices/platform/pwr_button/input/input0
                      [    0.712615] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
                      [    0.712730] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
                      [    0.734258] v3d 1002000000.v3d: [drm] Transparent Hugepage support is recommended for optimal performance on this platform!
                      [    0.735155] [drm] Initialized v3d 1.0.0 for 1002000000.v3d on minor 0
                      [    0.747163] vc4_hvs 107c580000.hvs: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
                      [    0.747172] vc4_hvs 107c580000.hvs: bcm2712_iommu_probe_device: MMU 1000005200.iommu
                      [    0.747178] vc4_hvs 107c580000.hvs: bcm2712_iommu_device_group: MMU 1000005200.iommu
                      [    0.747184] vc4_hvs 107c580000.hvs: Adding to iommu group 1
                      [    0.747188] vc4_hvs 107c580000.hvs: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
                      [    0.749870] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
                      [    0.749877] vc4-drm axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
                      [    0.749888] vc4-drm axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
                      [    0.749893] vc4-drm axi:gpu: Adding to iommu group 1
                      [    0.749895] vc4-drm axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
                      [    0.752121] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
                      [    0.753243] Registered IR keymap rc-cec
                      [    0.753283] rc rc0: vc4-hdmi-0 as /devices/platform/soc@107c000000/107c701400.hdmi/rc/rc0
                      [    0.753323] input: vc4-hdmi-0 as /devices/platform/soc@107c000000/107c701400.hdmi/rc/rc0/input1
                      [    0.753911] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc@107c000000/107c701400.hdmi/sound/card0/input2
                      [    0.754825] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
                      [    0.755975] Registered IR keymap rc-cec
                      [    0.756004] rc rc1: vc4-hdmi-1 as /devices/platform/soc@107c000000/107c706400.hdmi/rc/rc1
                      [    0.756042] input: vc4-hdmi-1 as /devices/platform/soc@107c000000/107c706400.hdmi/rc/rc1/input3
                      [    0.756621] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc@107c000000/107c706400.hdmi/sound/card1/input4
                      [    0.757537] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
                      [    0.757837] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
                      [    0.757883] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
                      [    0.757923] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [    0.757959] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
                      [    0.758714] [drm] Initialized vc4 0.0.0 for axi:gpu on minor 1
                      [    0.761317] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
                      [    0.765042] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
                      [    0.768481] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
                      [    0.849688] usb 1-1: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
                      [    0.849693] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                      [    0.849695] usb 1-1: Product: USB Serial Converter
                      [    0.849697] usb 1-1: Manufacturer: FTDI
                      [    0.849698] usb 1-1: SerialNumber: FTB6SPL3
                      [    1.012636] EXT4-fs (mmcblk0p2): mounted filesystem 5170097f-f1f6-42d8-a2ff-8938cbdfa7be ro with ordered data mode. Quota mode: none.
                      [    1.321245] NET: Registered PF_INET6 protocol family
                      [    1.321571] Segment Routing with IPv6
                      [    1.321578] In-situ OAM (IOAM) with IPv6
                      [    1.348946] systemd[1]: systemd 252.38-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
                      [    1.348957] systemd[1]: Detected architecture arm64.
                      [    1.354317] systemd[1]: Hostname set to <schopf>.
                      [    1.673612] systemd[1]: Queued start job for default target multi-user.target.
                      [    1.694212] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
                      [    1.694493] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
                      [    1.694732] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
                      [    1.694966] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
                      [    1.695125] systemd[1]: Created slice user.slice - User and Session Slice.
                      [    1.695177] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
                      [    1.695318] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
                      [    1.695337] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-a827d94a\x2d01.device - /dev/disk/by-partuuid/a827d94a-01...
                      [    1.695346] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
                      [    1.695370] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
                      [    1.695412] systemd[1]: Reached target slices.target - Slice Units.
                      [    1.695430] systemd[1]: Reached target swap.target - Swaps.
                      [    1.695449] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
                      [    1.695558] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
                      [    1.695617] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
                      [    1.695803] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
                      [    1.695885] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
                      [    1.695973] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
                      [    1.696603] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
                      [    1.696674] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
                      [    1.696782] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
                      [    1.697384] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
                      [    1.698121] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
                      [    1.698896] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
                      [    1.699012] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
                      [    1.701024] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
                      [    1.702939] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
                      [    1.703844] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
                      [    1.704805] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
                      [    1.706040] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
                      [    1.707203] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
                      [    1.708724] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
                      [    1.709970] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
                      [    1.711270] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
                      [    1.711413] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
                      [    1.713217] systemd[1]: Starting systemd-journald.service - Journal Service...
                      [    1.722898] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
                      [    1.723804] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
                      [    1.724682] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
                      [    1.725941] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
                      [    1.726150] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
                      [    1.726289] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
                      [    1.726538] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
                      [    1.726864] systemd[1]: modprobe@configfs.service: Deactivated successfully.
                      [    1.726947] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
                      [    1.727110] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
                      [    1.727180] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
                      [    1.727343] systemd[1]: modprobe@loop.service: Deactivated successfully.
                      [    1.727417] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
                      [    1.728490] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
                      [    1.730669] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
                      [    1.734541] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
                      [    1.735012] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
                      [    1.735121] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
                      [    1.735262] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
                      [    1.738268] fuse: init (API version 7.41)
                      [    1.738742] systemd[1]: modprobe@fuse.service: Deactivated successfully.
                      [    1.738829] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
                      [    1.739658] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
                      [    1.745832] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
                      [    1.750252] systemd[1]: modprobe@drm.service: Deactivated successfully.
                      [    1.750403] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
                      [    1.767455] systemd[1]: Started systemd-journald.service - Journal Service.
                      [    1.769871] i2c_dev: i2c /dev entries driver
                      [    1.776086] EXT4-fs (mmcblk0p2): re-mounted 5170097f-f1f6-42d8-a2ff-8938cbdfa7be r/w.
                      [    1.813778] systemd-journald[328]: Received client request to flush runtime journal.
                      [    2.374803] rp1-firmware rp1_firmware: RP1 Firmware version eb39cfd516f8c90628aa9d91f52370aade5d0a55
                      [    2.375248] rp1-pio 1f00178000.pio: Created instance as pio0
                      [    2.383091] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
                      [    2.383199] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
                      [    2.383235] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
                      [    2.383280] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
                      [    2.383301] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
                      [    2.383328] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
                      [    2.383344] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
                      [    2.383369] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
                      [    2.383455] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
                      [    2.383487] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
                      [    2.438498] mc: Linux media interface: v0.10
                      [    2.486511] videodev: Linux video capture interface: v2.00
                      [    2.583752] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
                      [    2.583764] pispbe 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
                      [    2.583774] pispbe 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
                      [    2.583781] pispbe 1000880000.pisp_be: Adding to iommu group 0
                      [    2.583785] pispbe 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
                      [    2.586366] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
                      [    2.586373] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
                      [    2.586380] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
                      [    2.586386] rpi-hevc-dec 1000800000.codec: Adding to iommu group 0
                      [    2.586388] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
                      [    2.589608] rpi-hevc-dec 1000800000.codec: Device registered as /dev/video19
                      [    2.600563] usbcore: registered new interface driver usbserial_generic
                      [    2.600579] usbserial: USB Serial support registered for generic
                      [    2.611668] usbcore: registered new interface driver ftdi_sio
                      [    2.611684] usbserial: USB Serial support registered for FTDI USB Serial Device
                      [    2.611723] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
                      [    2.611757] usb 1-1: Detected FT232R
                      [    2.612875] ftdi_sio ttyUSB0: Unable to read latency timer: -32
                      [    2.618676] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
                      [    2.639166] cfg80211: Loading compiled-in X.509 certificates for regulatory database
                      [    2.648439] Bluetooth: Core ver 2.22
                      [    2.649403] NET: Registered PF_BLUETOOTH protocol family
                      [    2.649410] Bluetooth: HCI device and connection manager initialized
                      [    2.649417] Bluetooth: HCI socket layer initialized
                      [    2.649420] Bluetooth: L2CAP socket layer initialized
                      [    2.649426] Bluetooth: SCO socket layer initialized
                      [    2.649885] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
                      [    2.650102] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
                      [    2.650410] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
                      [    2.651961] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
                      [    2.661210] Bluetooth: HCI UART driver ver 2.3
                      [    2.661217] Bluetooth: HCI UART protocol H4 registered
                      [    2.661238] Bluetooth: HCI UART protocol Three-wire (H5) registered
                      [    2.661366] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
                      [    2.661408] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
                      [    2.661446] Bluetooth: HCI UART protocol Broadcom registered
                      [    2.684268] brcmfmac: F1 signature read @0x18000000=0x15264345
                      [    2.685872] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                      [    2.686065] usbcore: registered new interface driver brcmfmac
                      [    2.905579] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
                      [    2.905816] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
                      [    3.021982] Bluetooth: hci0: BCM: chip id 107
                      [    3.022204] Bluetooth: hci0: BCM: features 0x2f
                      [    3.023271] Bluetooth: hci0: BCM4345C0
                      [    3.023276] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
                      [    3.029832] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
                      [    3.295723] Adding 204784k swap on /var/swap.  Priority:-2 extents:7 across:2080768k SS
                      [    3.419238] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                      [    3.419245] Bluetooth: BNEP filters: protocol multicast
                      [    3.419251] Bluetooth: BNEP socket layer initialized
                      [    3.722156] Bluetooth: hci0: BCM: features 0x2f
                      [    3.723483] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
                      [    3.723488] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
                      [    3.723797] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
                      [    3.741344] Bluetooth: MGMT ver 1.23
                      [    3.747306] NET: Registered PF_ALG protocol family
                      [    4.289410] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
                      [    4.289418] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
                      [    4.292295] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
                      [    4.300993] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                      [    8.383469] macb 1f00100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
                      [   13.590201] tun: Universal TUN/TAP device driver, 1.6
                      [   13.622041] warning: `twingated' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
                      [   16.249999] Initializing XFRM netlink socket
                      [   16.510579] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
                      [   17.354088] docker0: port 1(vethd076c47) entered blocking state
                      [   17.354100] docker0: port 1(vethd076c47) entered disabled state
                      [   17.354117] vethd076c47: entered allmulticast mode
                      [   17.354245] vethd076c47: entered promiscuous mode
                      [   17.382223] docker0: port 2(vethdf159e9) entered blocking state
                      [   17.382237] docker0: port 2(vethdf159e9) entered disabled state
                      [   17.382259] vethdf159e9: entered allmulticast mode
                      [   17.382352] vethdf159e9: entered promiscuous mode
                      [   17.393871] eth0: renamed from veth86388a6
                      [   17.395332] docker0: port 1(vethd076c47) entered blocking state
                      [   17.395341] docker0: port 1(vethd076c47) entered forwarding state
                      [   17.420303] eth0: renamed from vethacb440a
                      [   17.420925] docker0: port 2(vethdf159e9) entered blocking state
                      [   17.420933] docker0: port 2(vethdf159e9) entered forwarding state
                      [   20.344066] Bluetooth: RFCOMM TTY layer initialized
                      [   20.344080] Bluetooth: RFCOMM socket layer initialized
                      [   20.344089] Bluetooth: RFCOMM ver 1.11
                      [   67.076115] ieee80211 phy0: brcmf_p2p_send_action_frame: Unknown Frame: category 0xa, action 0x8
                      [  578.695839] usb 1-1: USB disconnect, device number 2
                      [  578.712423] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
                      [  578.712457] ftdi_sio 1-1:1.0: device disconnected
                      [  583.440362] usb 3-2: new full-speed USB device number 2 using xhci-hcd
                      [  583.612643] usb 3-2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
                      [  583.612651] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                      [  583.612654] usb 3-2: Product: USB Serial Converter
                      [  583.612657] usb 3-2: Manufacturer: FTDI
                      [  583.612659] usb 3-2: SerialNumber: FTB6SPL3
                      [  583.622709] ftdi_sio 3-2:1.0: FTDI USB Serial Device converter detected
                      [  583.622749] usb 3-2: Detected FT232R
                      [  583.624803] ftdi_sio ttyUSB0: Unable to read latency timer: -32
                      [  583.628829] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB0
                      hartmann@schopf:~ $
                        dmesg
                        Hier posten.
                        Sascha HartmannS Offline
                        Sascha Hartmann
                        @wendy2702
                        so wird er im Windows erkannt
                        Das Gerät FTDIBUS\VID_0403+PID_6001+FTB6SPL3A\0000 wurde konfiguriert.
                        Treibername: null
                        Klassen-GUID: {00000000-0000-0000-0000-000000000000}
                        Treiberdatum:
                        Treiberversion:
                        Treiberanbieter:
                        Treiberabschnitt:
                        Treiberrang: 0x0
                        Passende Geräte-ID:
                        Treiber mit niedrigerem Rang:
                        Gerät wurde aktualisiert: false
                        Übergeordnetes Gerät: USB\VID_0403&PID_6001\FTB6SPL3
                          @wendy2702
                          Treibername: null
                          Treiberdatum:
                          Treiberversion:
                          Treiberanbieter:
                          Treiberabschnitt:
                          Treiberrang: 0x0
                          Passende Geräte-ID:
                          wendy2702W Offline
                          wendy2702W Offline
                          @sascha-hartmann um den ioBroker auszuschließen kannst du mal mit einem Modbus Programm auf deinem WIN PC Testen ob du etwas bekommst.
                            Sascha Hartmann
                            #66
                            @wendy2702
                            Ok Das Versuch ich heute mittag mal
                            Was mich echt wundert mit dem Stick habe ich erst vor Kurzem eine PV Battery geupdatet und das war auch RS485
                            wendy2702W HomoranH 2 Antworten Letzte Antwort
                              @wendy2702
                              wendy2702W Offline
                              wendy2702W Offline
                              #67
                              @sascha-hartmann dann sollte er wohl auch RS485 können. Ich habe ja nur nach der Bezeichnung gesucht und auf anhieb nichts gefunden mit RS485
                                Sascha Hartmann
                                #68
                                @wendy2702
                                denk ich auch ich versuchs nacher mal mit Windows und gebe nochmal rückinfo :)
                                  @wendy2702
                                  Sascha Hartmann
                                  #69
                                  @sascha-hartmann Scheint am Stick zu liegen auch im Windows geht nichts mit Testprogramm
                                  hab jetzt mal en Anderen Bestellt werde nochmals Berichten
                                  Danke Vorab an Alle
                                    @wendy2702
                                    #70
                                    sicher?
                                    das geht bei mir via RS232
                                    • P Offline
                                      peterfido
                                      schrieb am zuletzt editiert von peterfido
                                      #71
                                      @sascha-hartmann Wenn Du da eine PV Batterie erfolgreich mit genutzt hast, passt evtl. die Verdrahtung oder die Parameter nicht.
                                      Verdrahtung könnte man mal A / B auf einer Seite tauschen. Endwiderstände nicht vergessen, wenn keine im Gerät verbaut sind. (120 Ohm). Parameter abgleichen (meist 9600 Baud)
                                      RS 485 Treiber kann man hinter RS 232 Chips schalten. Evtl. ist sowas in Deinem Stick gemacht worden.
                                      RS 485 gibt es einmal als Modbus, wo man mit Adressen arbeiten muss, aber auch als Punkt zu Punkt - Verbindung. Dann haben die Geräte keine Adresse (angegeben). Da wird RS 485 nur wegen der möglichen 1200 Meter Kabelstrecke genutzt, verhält sich aber in der Kommunikation wie RS 232.
                                      Peterfido
                                        Sascha Hartmann
                                        #72
                                        @wendy2702
                                        Also hab nun einen Neuen Konverter
                                        wird aber am Pi nicht richtig erkannt meines Erachtens
                                        Zeile 151
                                        lsusb -v
                                        Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                        Couldn't open device, some information will be missing
                                        Device Descriptor:
                                          bLength                18
                                          bDescriptorType         1
                                          bcdUSB               3.00
                                          bDeviceClass            9 Hub
                                          bDeviceSubClass         0
                                          bDeviceProtocol         3
                                          bMaxPacketSize0         9
                                          idVendor           0x1d6b Linux Foundation
                                          idProduct          0x0003 3.0 root hub
                                          bcdDevice            6.12
                                          iManufacturer           3 Linux 6.12.34+rpt-rpi-2712 xhci-hcd
                                          iProduct                2 xHCI Host Controller
                                          iSerial                 1 xhci-hcd.1
                                          bNumConfigurations      1
                                          Configuration Descriptor:
                                            bLength                 9
                                            bDescriptorType         2
                                            wTotalLength       0x001f
                                            bNumInterfaces          1
                                            bConfigurationValue     1
                                            iConfiguration          0
                                            bmAttributes         0xe0
                                              Self Powered
                                              Remote Wakeup
                                            MaxPower                0mA
                                            Interface Descriptor:
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        0
                                              bAlternateSetting       0
                                              bNumEndpoints           1
                                              bInterfaceClass         9 Hub
                                              bInterfaceSubClass      0
                                              bInterfaceProtocol      0 Full speed (or root) hub
                                              iInterface              0
                                              Endpoint Descriptor:
                                                bLength                 7
                                                bDescriptorType         5
                                                bEndpointAddress     0x81  EP 1 IN
                                                bmAttributes            3
                                                  Transfer Type            Interrupt
                                                  Synch Type               None
                                                  Usage Type               Data
                                                wMaxPacketSize     0x0004  1x 4 bytes
                                                bInterval              12
                                                bMaxBurst               0
                                        Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                                        Device Descriptor:
                                          bLength                18
                                          bDescriptorType         1
                                          bcdUSB               2.00
                                          bDeviceClass            9 Hub
                                          bDeviceSubClass         0
                                          bDeviceProtocol         1 Single TT
                                          bMaxPacketSize0        64
                                          idProduct          0x0002 2.0 root hub
                                          bcdDevice            6.12
                                            bLength                 9
                                            bDescriptorType         2
                                            wTotalLength       0x0019
                                            bNumInterfaces          1
                                            iConfiguration          0
                                            bmAttributes         0xe0
                                              Self Powered
                                              Remote Wakeup
                                            MaxPower                0mA
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        0
                                              bAlternateSetting       0
                                              bNumEndpoints           1
                                              iInterface              0
                                                bLength                 7
                                                bDescriptorType         5
                                                bmAttributes            3
                                                  Synch Type               None
                                                  Usage Type               Data
                                                bInterval              12
                                        Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                                        Device Descriptor:
                                          bLength                18
                                          bDescriptorType         1
                                          bcdUSB               3.00
                                          bDeviceClass            9 Hub
                                          bDeviceSubClass         0
                                          bDeviceProtocol         3
                                          bMaxPacketSize0         9
                                          bcdDevice            6.12
                                          iSerial                 1 xhci-hcd.0
                                            bLength                 9
                                            bDescriptorType         2
                                            wTotalLength       0x001f
                                            bNumInterfaces          1
                                            iConfiguration          0
                                            bmAttributes         0xe0
                                              Self Powered
                                              Remote Wakeup
                                            MaxPower                0mA
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        0
                                              bAlternateSetting       0
                                              bNumEndpoints           1
                                              iInterface              0
                                                bLength                 7
                                                bDescriptorType         5
                                                bmAttributes            3
                                                  Synch Type               None
                                                  Usage Type               Data
                                                bInterval              12
                                                bMaxBurst               0
                                        Bus 001 Device 004: ID 1a86:55d3 QinHeng Electronics USB Single Serial
                                        Device Descriptor:
                                          bLength                18
                                          bDescriptorType         1
                                          bcdUSB               1.10
                                          bDeviceClass            2 Communications
                                          bDeviceSubClass         0
                                          bDeviceProtocol         0
                                          bMaxPacketSize0         8
                                          idVendor           0x1a86 QinHeng Electronics
                                          idProduct          0x55d3
                                          bcdDevice            4.45
                                          iManufacturer           0
                                          iProduct                2 USB Single Serial
                                          iSerial                 3 586D005887
                                            bLength                 9
                                            bDescriptorType         2
                                            wTotalLength       0x0043
                                            bNumInterfaces          2
                                            iConfiguration          0
                                            bmAttributes         0x80
                                              (Bus Powered)
                                            MaxPower              138mA
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        0
                                              bAlternateSetting       0
                                              bNumEndpoints           1
                                              bInterfaceClass         2 Communications
                                              bInterfaceSubClass      2 Abstract (modem)
                                              bInterfaceProtocol      1 AT-commands (v.25ter)
                                              iInterface              0
                                              CDC Header:
                                                bcdCDC               1.10
                                              CDC Call Management:
                                                bmCapabilities       0x00
                                                bDataInterface          1
                                              CDC ACM:
                                                bmCapabilities       0x02
                                                  line coding and serial state
                                              CDC Union:
                                                bMasterInterface        0
                                                bSlaveInterface         1
                                                bLength                 7
                                                bDescriptorType         5
                                                bEndpointAddress     0x83  EP 3 IN
                                                bmAttributes            3
                                                  Synch Type               None
                                                  Usage Type               Data
                                                wMaxPacketSize     0x0010  1x 16 bytes
                                                bInterval               1
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        1
                                              bAlternateSetting       0
                                              bNumEndpoints           2
                                              bInterfaceClass        10 CDC Data
                                              iInterface              0
                                                bLength                 7
                                                bDescriptorType         5
                                                bEndpointAddress     0x02  EP 2 OUT
                                                bmAttributes            2
                                                  Transfer Type            Bulk
                                                  Synch Type               None
                                                  Usage Type               Data
                                                wMaxPacketSize     0x0020  1x 32 bytes
                                                bInterval               0
                                                bLength                 7
                                                bDescriptorType         5
                                                bEndpointAddress     0x82  EP 2 IN
                                                bmAttributes            2
                                                  Transfer Type            Bulk
                                                  Synch Type               None
                                                  Usage Type               Data
                                                wMaxPacketSize     0x0040  1x 64 bytes
                                                bInterval               0
                                        Bus 001 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
                                        Device Descriptor:
                                          bLength                18
                                          bDescriptorType         1
                                          bcdUSB               2.00
                                          bDeviceClass            0
                                          bDeviceSubClass         0
                                          bDeviceProtocol         0
                                          bMaxPacketSize0         8
                                          idVendor           0x0403 Future Technology Devices International, Ltd
                                          idProduct          0x6001 FT232 Serial (UART) IC
                                          bcdDevice            6.00
                                          iManufacturer           1 FTDI
                                          iProduct                2 USB Serial Converter
                                          iSerial                 3 FTB6SPL3
                                            bLength                 9
                                            bDescriptorType         2
                                            wTotalLength       0x0020
                                            bNumInterfaces          1
                                            iConfiguration          0
                                            bmAttributes         0xa0
                                              (Bus Powered)
                                              Remote Wakeup
                                            MaxPower               44mA
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        0
                                              bAlternateSetting       0
                                              bNumEndpoints           2
                                              bInterfaceClass       255 Vendor Specific Class
                                              bInterfaceSubClass    255 Vendor Specific Subclass
                                              bInterfaceProtocol    255 Vendor Specific Protocol
                                              iInterface              2 USB Serial Converter
                                                bLength                 7
                                                bDescriptorType         5
                                                bmAttributes            2
                                                  Transfer Type            Bulk
                                                  Synch Type               None
                                                  Usage Type               Data
                                                bInterval               0
                                                bLength                 7
                                                bDescriptorType         5
                                                bmAttributes            2
                                                  Transfer Type            Bulk
                                                  Synch Type               None
                                                  Usage Type               Data
                                                bInterval               0
                                        Device Status:     0x0000
                                          (Bus Powered)
                                        Device Descriptor:
                                          bLength                18
                                          bDescriptorType         1
                                          bcdUSB               2.00
                                          bDeviceClass            9 Hub
                                          bDeviceSubClass         0
                                          bMaxPacketSize0        64
                                          bcdDevice            6.12
                                            bLength                 9
                                            bDescriptorType         2
                                            wTotalLength       0x0019
                                            bNumInterfaces          1
                                            iConfiguration          0
                                            bmAttributes         0xe0
                                              Self Powered
                                              Remote Wakeup
                                            MaxPower                0mA
                                              bLength                 9
                                              bDescriptorType         4
                                              bInterfaceNumber        0
                                              bAlternateSetting       0
                                              bNumEndpoints           1
                                              iInterface              0
                                                bLength                 7
                                                bDescriptorType         5
                                                bmAttributes            3
                                                  Synch Type               None
                                                  Usage Type               Data
                                                bInterval              12
                                        • Sascha HartmannS Sascha Hartmann
                                          @wendy2702
                                          Zeile 151
                                          lsusb -v
                                          Device Descriptor:
                                            bLength                18
                                            bDescriptorType         1
                                            bcdUSB               3.00
                                            bDeviceClass            9 Hub
                                            bDeviceSubClass         0
                                            bDeviceProtocol         3
                                            bMaxPacketSize0         9
                                            bcdDevice            6.12
                                              bLength                 9
                                              bDescriptorType         2
                                              wTotalLength       0x001f
                                              bNumInterfaces          1
                                              iConfiguration          0
                                              bmAttributes         0xe0
                                                Self Powered
                                                Remote Wakeup
                                              MaxPower                0mA
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        0
                                                bAlternateSetting       0
                                                bNumEndpoints           1
                                                iInterface              0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            3
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval              12
                                                  bMaxBurst               0
                                          Device Descriptor:
                                            bLength                18
                                            bDescriptorType         1
                                            bcdUSB               2.00
                                            bDeviceClass            9 Hub
                                            bDeviceSubClass         0
                                            bMaxPacketSize0        64
                                            bcdDevice            6.12
                                              bLength                 9
                                              bDescriptorType         2
                                              wTotalLength       0x0019
                                              bNumInterfaces          1
                                              iConfiguration          0
                                              bmAttributes         0xe0
                                                Self Powered
                                                Remote Wakeup
                                              MaxPower                0mA
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        0
                                                bAlternateSetting       0
                                                bNumEndpoints           1
                                                iInterface              0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            3
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval              12
                                          Device Descriptor:
                                            bLength                18
                                            bDescriptorType         1
                                            bcdUSB               3.00
                                            bDeviceClass            9 Hub
                                            bDeviceSubClass         0
                                            bDeviceProtocol         3
                                            bMaxPacketSize0         9
                                            bcdDevice            6.12
                                              bLength                 9
                                              bDescriptorType         2
                                              wTotalLength       0x001f
                                              bNumInterfaces          1
                                              iConfiguration          0
                                              bmAttributes         0xe0
                                                Self Powered
                                                Remote Wakeup
                                              MaxPower                0mA
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        0
                                                bAlternateSetting       0
                                                bNumEndpoints           1
                                                iInterface              0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            3
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval              12
                                                  bMaxBurst               0
                                          Device Descriptor:
                                            bLength                18
                                            bDescriptorType         1
                                            bcdUSB               1.10
                                            bDeviceSubClass         0
                                            bDeviceProtocol         0
                                            bMaxPacketSize0         8
                                            idProduct          0x55d3
                                            bcdDevice            4.45
                                            iManufacturer           0
                                              bLength                 9
                                              bDescriptorType         2
                                              wTotalLength       0x0043
                                              bNumInterfaces          2
                                              iConfiguration          0
                                              bmAttributes         0x80
                                                (Bus Powered)
                                              MaxPower              138mA
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        0
                                                bAlternateSetting       0
                                                bNumEndpoints           1
                                                iInterface              0
                                                CDC Header:
                                                  bcdCDC               1.10
                                                  bmCapabilities       0x00
                                                  bDataInterface          1
                                                CDC ACM:
                                                  bmCapabilities       0x02
                                                CDC Union:
                                                  bMasterInterface        0
                                                  bSlaveInterface         1
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            3
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval               1
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        1
                                                bAlternateSetting       0
                                                bNumEndpoints           2
                                                iInterface              0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            2
                                                    Transfer Type            Bulk
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval               0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            2
                                                    Transfer Type            Bulk
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval               0
                                          Device Descriptor:
                                            bLength                18
                                            bDescriptorType         1
                                            bcdUSB               2.00
                                            bDeviceClass            0
                                            bDeviceSubClass         0
                                            bDeviceProtocol         0
                                            bMaxPacketSize0         8
                                            bcdDevice            6.00
                                            iSerial                 3 FTB6SPL3
                                              bLength                 9
                                              bDescriptorType         2
                                              wTotalLength       0x0020
                                              bNumInterfaces          1
                                              iConfiguration          0
                                              bmAttributes         0xa0
                                                (Bus Powered)
                                                Remote Wakeup
                                              MaxPower               44mA
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        0
                                                bAlternateSetting       0
                                                bNumEndpoints           2
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            2
                                                    Transfer Type            Bulk
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval               0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            2
                                                    Transfer Type            Bulk
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval               0
                                            (Bus Powered)
                                          Device Descriptor:
                                            bLength                18
                                            bDescriptorType         1
                                            bcdUSB               2.00
                                            bDeviceClass            9 Hub
                                            bDeviceSubClass         0
                                            bMaxPacketSize0        64
                                            bcdDevice            6.12
                                              bLength                 9
                                              bDescriptorType         2
                                              wTotalLength       0x0019
                                              bNumInterfaces          1
                                              iConfiguration          0
                                              bmAttributes         0xe0
                                                Self Powered
                                                Remote Wakeup
                                              MaxPower                0mA
                                                bLength                 9
                                                bDescriptorType         4
                                                bInterfaceNumber        0
                                                bAlternateSetting       0
                                                bNumEndpoints           1
                                                iInterface              0
                                                  bLength                 7
                                                  bDescriptorType         5
                                                  bmAttributes            3
                                                    Synch Type               None
                                                    Usage Type               Data
                                                  bInterval              12
                                          M Online
                                          M Online
                                          Matis
                                          #73
                                          @sascha-hartmann Mein Erfahrung ist:
                                          die USB-Adapter sind schwierig einzubinden, machen Zicken, fallen immer wieder aus und kosten viel zu viel Zeit.
                                          Kauf Dir einen tcp-LAN-Adapter, funktioniert immer zuverlässig und ist zudem räumlich unabhängig, dann hast du Ruhe.
                                          Sascha HartmannS HomoranH 2 Antworten Letzte Antwort
