  4. Fully Browser verbinden sich nicht mehr *gelöst*
    2.4k
    2.7k
    1.5k
7 Beiträge 6 Kommentatoren 664 Aufrufe 5 Beobachtet
  • G Offline
    gluecksmann
    schrieb am zuletzt editiert von gluecksmann
    Hallo, meine 3 Tablets verbinden sich nicht mehr mit dem FullyBrowser. Bin mir keiner Schuld bewusst was geändert zu haben. System sollte aktuell sein.
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.20+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     08:26:32 up  5:26,  4 users,  load average: 0.60, 0.42, 0.44
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-07-06 08:26:32 CEST
               Universal time: Sun 2025-07-06 06:26:32 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.2G        3.2G        3.6G         20M        1.7G        5.0G
    Swap:           209M          0B        209M
    Total:          8.4G        3.2G        3.8G
    Active iob-Instances:   36
             7809 M total memory
             3016 M used memory
             3301 M active memory
              778 M inactive memory
             3406 M free memory
              141 M buffer memory
             1434 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 08:26:33 up  5:26,  4 users,  load average: 0.60, 0.42, 0.44
    Tasks: 254 total,   4 running, 250 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7809.4 total,   3405.9 free,   3015.9 used,   1577.1 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4793.5 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     781M  1.3M  780M   1% /run
    /dev/mmcblk0p2 ext4       58G   13G   43G  22% /
    tmpfs          tmpfs     3.9G  140K  3.9G   1% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   77M  434M  16% /boot/firmware
    tmpfs          tmpfs     781M   48K  781M   1% /run/user/1000
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.3G    /var/
    1.1G    /var/log/journal/4577005cbad945408993919bfbab79bf
    1.1G    /var/log
    777M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    667M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    573M    /opt/iobroker/iobroker-data/
    359M    /opt/iobroker/iobroker-data/files
    90M     /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
    80M     /opt/iobroker/iobroker-data/influxdata.json
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/states.jsonl
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
         20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
     *** 20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 4264)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.17
    javascript:     8.9.2
    nodejs modules from github:     1
    +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
    + system.adapter.ankersolix2.0            : ankersolix2           : raspberrypi                              -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
    + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
      system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
    + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
    + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
      system.adapter.history.0                : history               : raspberrypi                              - disabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
    + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
    + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
    + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
    + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
    + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
    + system.adapter.signifylights.0          : signifylights         : raspberrypi                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.6.17   , installed 7.6.17
    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "ankersolix2"  : 2.1.2    , installed 2.1.2
    Adapter    "awtrix-light" : 1.7.0    , installed 1.7.0
    Adapter    "backitup"     : 3.2.2    , installed 3.2.2
    Adapter    "ble"          : 0.14.0   , installed 0.14.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "daswetter"    : 3.2.3    , installed 3.1.16 [Updatable]
    Adapter    "devices"      : 1.1.5    , installed 1.1.5
    Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hue"          : 3.16.1   , installed 3.16.1
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
    Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
    Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.0.0   , installed 10.0.0
    Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
    Adapter    "signifylights": 1.0.0    , installed 1.0.0
    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
    Objects and States
    Objects:        12220
    States:         10030
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 216
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       484961     570378/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8337       789/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7620       777/cupsd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       485424     570043/iobroker.js-
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       485419     570043/iobroker.js-
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7619       777/cupsd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8339       789/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        8934       1107/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       485011     570447/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       486430     570061/io.admin.0
    tcp6       0      0 :::3500                 :::*                    LISTEN      1001       486518     570151/io.sonos.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      112        12501      1267/grafana
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6564       576/avahi-daemon: r
    udp        0      0 0.0.0.0:34045           0.0.0.0:*                           104        6566       576/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       484191     570307/io.shelly.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       486689     570318/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       486690     570318/io.tuya.0
    udp        0      0 0.0.0.0:60626           0.0.0.0:*                           1001       484860     570258/io.philips-a
    udp        0      0 0.0.0.0:36461           0.0.0.0:*                           1001       484160     570273/io.philips-a
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       487606     570626/io.musiccast
    udp6       0      0 fe80::a6e1:3ab9:3bf:546 :::*                                0          8633       712/NetworkManager
    udp6       0      0 fe80::e996:6ae8:1bc:546 :::*                                0          6959       712/NetworkManager
    udp6       0      0 :::37802                :::*                                104        6567       576/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        6565       576/avahi-daemon: r
    2025-07-06 08:27:19.111  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.timerMinutes" has to be type "number" but received type "string"
    2025-07-06 08:27:19.167  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.preFilterCleanInHours" has to be type "number" but received type "string"
    2025-07-06 08:27:19.215  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2025-07-06 08:27:19.268  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2025-07-06 08:27:23.496  - warn: fullybrowser.0 (577073) [REST] 192.168.2.176: Sending command get axiosGetDevicesInfo  failed: No response
    2025-07-06 08:27:23.849  - error: govee.0 (570544) AxiosError: Request failed with status code 429
    2025-07-06 08:27:25.500  - warn: fullybrowser.0 (577073) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
    2025-07-06 08:27:25.546  - error: fullybrowser.0 (577073) [REST] 192.168.2.206: Sending command first Login  failed: Error: Please login
    2025-07-06 08:27:28.849  - error: govee.0 (570544) AxiosError: Request failed with status code 429
    2025-07-06 08:27:32.895  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.lightBrightness" has to be type "number" but received type "string"
    2025-07-06 08:27:32.944  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.airQualityNotificationThreshold" has to be type "number" but received type "string"
    2025-07-06 08:27:33.001  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.allergenIndex" has to be type "number" but received type "string"
    2025-07-06 08:27:33.048  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.childLock" has to be type "boolean" but received type "string"
    2025-07-06 08:27:33.146  - info: philips-air.1 (570273) State value to set for "philips-air.1.device.uptime" has to be type "number" but received type "string"
    2025-07-06 08:27:33.208  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.pm25" has to be type "number" but received type "string"
    2025-07-06 08:27:33.273  - info: philips-air.1 (570273) State value to set for "philips-air.1.control.timerHours" has to be type "number" but received type "string"
    2025-07-06 08:27:33.321  - info: philips-air.1 (570273) State value to set for "philips-air.1.status.timerMinutes" has to be type "number" but received type "string"
    2025-07-06 08:27:33.383  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.preFilterCleanInHours" has to be type "number" but received type "string"
    2025-07-06 08:27:33.433  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.hepaFilterReplaceInHours" has to be type "number" but received type "string"
    2025-07-06 08:27:33.480  - info: philips-air.1 (570273) State value to set for "philips-air.1.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
    2025-07-06 08:27:33.496  - warn: fullybrowser.0 (577073) [REST] 192.168.2.176: Sending command get axiosGetDevicesInfo  failed: No response
    2025-07-06 08:27:33.851  - error: govee.0 (570544) AxiosError: Request failed with status code 429
    2025-07-06 08:27:35.500  - warn: fullybrowser.0 (577073) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
    2025-07-06 08:27:35.583  - error: fullybrowser.0 (577073) [REST] 192.168.2.206: Sending command first Login  failed: Error: Please login
    2025-07-06 08:27:38.849  - error: govee.0 (570544) AxiosError: Request failed with status code 429
    iob diag has finished.
    Thomas BraunT Z BananaJoeB 3 Antworten Letzte Antwort
    • wendy2702W Online
      wendy2702W Online
      Sind die Tablets denn unter den IP Adressen vom iobroker aus per Ping erreichbar?
      • G gluecksmann
        Script v.2025-03-08
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 7809 M total memory
                 3016 M used memory
                 3406 M free memory
                  141 M buffer memory
                 1434 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        2.3G    /var/
        1.1G    /var/log
        777M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.17
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12220
        States:         10030
        @gluecksmann sagte in Fully Browser verbinden sich nicht mehr:
        HUST
        Updates fahren.
        Solltest du auch umstellen:
        vis läuft nicht.
        • G gluecksmann
          Script v.2025-03-08
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           209M          0B        209M
                   7809 M total memory
                   3016 M used memory
                   3406 M free memory
                    141 M buffer memory
                   1434 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          *** FILESYSTEM ***
          /var:
          2.3G    /var/
          1.1G    /var/log
          777M    /var/cache
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.17
          javascript:     8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        12220
          States:         10030
          Z Abwesend
          Z Abwesend
          zahnheinrich
          @gluecksmann
          Schuss ins blaue:
          Mqtt Einstellungen im iobroker und/oder auf den tablets falsch
          MfG Ulrich
          • G gluecksmann
            Script v.2025-03-08
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           209M          0B        209M
                     7809 M total memory
                     3016 M used memory
                     3406 M free memory
                      141 M buffer memory
                     1434 M swap cache
                      199 M total swap
                        0 M used swap
                      199 M free swap
            *** FILESYSTEM ***
            /var:
            2.3G    /var/
            1.1G    /var/log
            777M    /var/cache
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.6.17
            javascript:     8.9.2
            Adapter State
            + instance is alive
            Objects and States
            Objects:        12220
            States:         10030
            BananaJoeB Online
            BananaJoeB Online
            BananaJoe
            @gluecksmann Testen ob du die 3 Tablets denn auch über deren IP-Adresse und Port 2323 erreichen kannst,
            dann ob bei denen MQTT eingestellt ist.
            Und dann ob die Adapter Einstellungen passen (MQTT oder http mode etc.)
            Eventuell hast du ja auch noch etwas anderes gemacht und die 3 Tablets haben jetzt neue IP-Adressen per DHCP bekommen
            • G Offline
              gluecksmann
              @bananajoe
              Hallo, habe Updates gefahren. Neu gestartet, Passwörter neu gesetzt ect. Irgendwas hat geholfen. Ich danke für die Unterstützung.
              • G gluecksmann
                @bananajoe
                @gluecksmann sagte in Fully Browser verbinden sich nicht mehr *gelöst*:
                @thomas-braun sagte in Fully Browser verbinden sich nicht mehr *gelöst*:
                vis läuft nicht.
                wird jetzt wohl laufen
                83.2k
