  4. Node-Red
  5. HUE Bewegungsmelder Roborock integr.
    6.4k
34 Beiträge 2 Kommentatoren 4.6k Aufrufe 2 Beobachtet
  • P peterfido
    @aphofis Der genaue Pfad wird in die Zwischenablage kopiert, wenn du da drauf klickst.
    AphofisA Offline
    AphofisA Offline
    Aphofis
    @peterfido
    Da kommt nur payload bei raus.
    Der BM kommt nicht über motion/false Node hinweg.
            "id": "4a7d49c9cec64387",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": "",
            "env": []
            "id": "5e77b709b7c1eae0",
            "type": "junction",
            "z": "4a7d49c9cec64387",
            "x": 220,
            "y": 160,
            "wires": [
                    "a779e45d3967bfb9"
            "id": "a779e45d3967bfb9",
            "type": "junction",
            "x": 520,
            "y": 160,
            "wires": [
                    "04fa302c2270ca4f"
            "id": "bfe42f33cfa9774d",
            "type": "junction",
            "x": 220,
            "y": 100,
            "wires": [
                    "140ae0a74c608f65"
            "id": "78e2ddead9cc1d0a",
            "type": "junction",
            "x": 500,
            "y": 180,
            "wires": [
                    "acb34561a25cb81b",
                    "98aed8cf2a3130df"
            "id": "8efbfa2bed5bc563",
            "type": "inject",
            "name": "Bewegung",
            "props": [
                    "p": "payload.motion",
                    "v": "true",
                    "vt": "bool"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "x": 80,
            "y": 160,
            "wires": [
                    "5e77b709b7c1eae0",
                    "bfe42f33cfa9774d",
                    "d7459276dc5863d1"
            "id": "393f87f05ba89b4d",
            "type": "debug",
            "name": "debug 17",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 1320,
            "y": 120,
            "wires": []
            "id": "140ae0a74c608f65",
            "type": "delay",
            "name": "verzög.1s",
            "pauseType": "delay",
            "timeout": "1",
            "timeoutUnits": "seconds",
            "rate": "1",
            "nbRateUnits": "1",
            "rateUnits": "second",
            "randomFirst": "1",
            "randomLast": "5",
            "randomUnits": "seconds",
            "drop": false,
            "allowrate": false,
            "outputs": 1,
            "x": 340,
            "y": 100,
            "wires": [
                    "43a8260bfdf05214"
            "id": "43a8260bfdf05214",
            "type": "change",
            "name": "motion/false",
            "rules": [
                    "t": "set",
                    "pt": "msg",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 490,
            "y": 100,
            "wires": [
                    "04fa302c2270ca4f"
            "id": "f5d7178472b12544",
            "type": "switch",
            "name": "",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "true"
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 830,
            "y": 100,
            "wires": [
                    "91e7c6e9005453c1"
            "id": "04fa302c2270ca4f",
            "type": "change",
            "name": "motion/payload",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "payload.motion",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 680,
            "y": 100,
            "wires": [
                    "f5d7178472b12544"
            "id": "464744eb1eb6f4bf",
            "type": "comment",
            "name": "Bewegungsmelder",
            "info": "",
            "x": 90,
            "y": 20,
            "wires": []
            "id": "d72b588f5ad0c3d1",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "1000",
            "payloadType": "num",
            "x": 290,
            "y": 200,
            "wires": [
                    "28b5fec6c9de7785"
            "id": "acb34561a25cb81b",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 630,
            "y": 180,
            "wires": [
                    "d2ebd9fe89d68291"
            "id": "28b5fec6c9de7785",
            "type": "switch",
            "name": "1000",
            "rules": [
                    "t": "eq",
                    "v": "1000",
                    "vt": "num"
                    "t": "eq",
                    "v": "",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 410,
            "y": 200,
            "wires": [
                    "78e2ddead9cc1d0a"
            "id": "932f55c48b111395",
            "type": "switch",
            "name": "",
            "property": "stopp",
            "propertyType": "flow",
            "rules": [
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 1070,
            "y": 80,
            "wires": [
                    "8a764bd3f71768b8"
            "id": "98aed8cf2a3130df",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "stopp",
                    "pt": "flow",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 620,
            "y": 240,
            "wires": [
                    "5858f0f89909dff4"
            "id": "7a91b9011434fb39",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "stopp",
                    "pt": "flow",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 1080,
            "y": 240,
            "wires": [
                    "25337f528e5f609e"
            "id": "924f5324f130bca6",
            "type": "switch",
            "name": "",
            "rules": [
                    "t": "eq",
                    "v": "1000",
                    "vt": "num"
                    "t": "eq",
                    "v": "",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 930,
            "y": 220,
            "wires": [
                    "7a91b9011434fb39"
            "id": "8a764bd3f71768b8",
            "type": "function",
            "name": "Ausgabe",
            "func": "node.status({ text: msg.payload });\n\nreturn msg;",
            "outputs": 1,
            "timeout": 0,
            "noerr": 0,
            "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);",
            "finalize": "",
            "libs": [],
            "x": 1180,
            "y": 180,
            "wires": [
                    "393f87f05ba89b4d",
                    "06974459414825ae"
            "id": "91e7c6e9005453c1",
            "type": "timeouttrigger",
            "OnTimeoutType": "bool",
            "OnTimeoutVal": "false",
            "duration": "3",
            "units": "s",
            "passthrough": true,
            "sendTimeoutValue": "once",
            "interval": "",
            "IntervalUnits": "s",
            "name": "",
            "x": 950,
            "y": 80,
            "wires": [
                    "932f55c48b111395"
            "id": "d2ebd9fe89d68291",
            "duration": "10",
            "units": "s",
            "interval": "",
            "name": "",
            "x": 790,
            "y": 180,
            "wires": [
                    "924f5324f130bca6",
                    "8a764bd3f71768b8"
            "id": "d2ef36de8a84d716",
            "type": "ioBroker in",
            "name": "KüMo",
            "attrname": "payload",
            "topic": "hue.0.Hue_GordonX.Küche_Motion_Sensor.presence",
            "payloadType": "value",
            "onlyack": "",
            "func": "rbe",
            "gap": "",
            "fireOnStart": "false",
            "outFormat": "MQTT",
            "x": 50,
            "y": 100,
            "wires": [
                    "5e77b709b7c1eae0",
                    "bfe42f33cfa9774d"
            "id": "25337f528e5f609e",
            "type": "debug",
            "name": "debug 6",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "x": 1320,
            "y": 300,
            "wires": []
            "id": "06974459414825ae",
            "type": "ioBroker out",
            "name": "Test Lampe",
            "topic": "0_userdata.0.GordonX-Home.0.Test_Gerät",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1330,
            "y": 240,
            "wires": []
            "id": "3aa4ad0593121ea0",
            "name": "Schalter Küche",
            "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
            "onlyack": "",
            "func": "all",
            "gap": "",
            "x": 260,
            "y": 240,
            "wires": [
                    "28b5fec6c9de7785"
            "id": "5858f0f89909dff4",
            "type": "debug",
            "name": "debug 18",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 780,
            "y": 240,
            "wires": []
            "id": "8de4ca9f0f0e9d4d",
            "type": "debug",
            "name": "debug 3",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "statusVal": "",
            "x": 740,
            "y": 300,
            "wires": []
            "id": "a87f289d766e582a",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "change",
                    "p": "payload",
                    "pt": "msg",
                    "from": "5",
                    "fromt": "str",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 560,
            "y": 300,
            "wires": [
                    "8de4ca9f0f0e9d4d"
            "id": "ac9990dcafb0f297",
            "type": "switch",
            "name": "Status5",
            "rules": [
                    "t": "neq",
                    "v": "5",
                    "vt": "str"
            "checkall": "true",
            "repair": false,
            "outputs": 1,
            "x": 380,
            "y": 300,
            "wires": [
                    "a87f289d766e582a"
            "id": "d7459276dc5863d1",
            "type": "ioBroker get",
            "name": "Status",
            "topic": "0_userdata.0.GordonX-Home.0.Test_Status_Robi",
            "errOnInvalidState": "nothing",
            "x": 230,
            "y": 300,
            "wires": [
                    "ac9990dcafb0f297"
    P 1 Antwort Letzte Antwort
    • AphofisA Aphofis
      @peterfido
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": "",
              "env": []
              "type": "junction",
              "x": 220,
              "y": 160,
              "wires": [
                      "a779e45d3967bfb9"
              "type": "junction",
              "x": 520,
              "y": 160,
              "wires": [
                      "04fa302c2270ca4f"
              "type": "junction",
              "x": 220,
              "y": 100,
              "wires": [
                      "140ae0a74c608f65"
              "type": "junction",
              "x": 500,
              "y": 180,
              "wires": [
                      "acb34561a25cb81b",
                      "98aed8cf2a3130df"
              "type": "inject",
              "name": "Bewegung",
              "props": [
                      "v": "true",
                      "vt": "bool"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "x": 80,
              "y": 160,
              "wires": [
                      "5e77b709b7c1eae0",
                      "bfe42f33cfa9774d",
                      "d7459276dc5863d1"
              "type": "debug",
              "name": "debug 17",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1320,
              "y": 120,
              "wires": []
              "type": "delay",
              "timeout": "1",
              "rate": "1",
              "nbRateUnits": "1",
              "randomFirst": "1",
              "randomLast": "5",
              "drop": false,
              "allowrate": false,
              "outputs": 1,
              "x": 340,
              "y": 100,
              "wires": [
                      "43a8260bfdf05214"
              "type": "change",
              "rules": [
                      "t": "set",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 490,
              "y": 100,
              "wires": [
                      "04fa302c2270ca4f"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 830,
              "y": 100,
              "wires": [
                      "91e7c6e9005453c1"
              "type": "change",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 680,
              "y": 100,
              "wires": [
                      "f5d7178472b12544"
              "type": "comment",
              "info": "",
              "x": 90,
              "y": 20,
              "wires": []
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "1000",
              "x": 290,
              "y": 200,
              "wires": [
                      "28b5fec6c9de7785"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 630,
              "y": 180,
              "wires": [
                      "d2ebd9fe89d68291"
              "type": "switch",
              "name": "1000",
              "rules": [
                      "t": "eq",
                      "v": "1000",
                      "vt": "num"
                      "t": "eq",
                      "v": "",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 410,
              "y": 200,
              "wires": [
                      "78e2ddead9cc1d0a"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 1070,
              "y": 80,
              "wires": [
                      "8a764bd3f71768b8"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "stopp",
                      "pt": "flow",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 620,
              "y": 240,
              "wires": [
                      "5858f0f89909dff4"
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "stopp",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1080,
              "y": 240,
              "wires": [
                      "25337f528e5f609e"
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "eq",
                      "v": "1000",
                      "vt": "num"
                      "t": "eq",
                      "v": "",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 930,
              "y": 220,
              "wires": [
                      "7a91b9011434fb39"
              "type": "function",
              "name": "Ausgabe",
              "outputs": 1,
              "timeout": 0,
              "noerr": 0,
              "finalize": "",
              "libs": [],
              "x": 1180,
              "y": 180,
              "wires": [
                      "393f87f05ba89b4d",
                      "06974459414825ae"
              "duration": "3",
              "units": "s",
              "interval": "",
              "name": "",
              "x": 950,
              "y": 80,
              "wires": [
                      "932f55c48b111395"
              "duration": "10",
              "units": "s",
              "interval": "",
              "name": "",
              "x": 790,
              "y": 180,
              "wires": [
                      "924f5324f130bca6",
                      "8a764bd3f71768b8"
              "name": "KüMo",
              "onlyack": "",
              "func": "rbe",
              "gap": "",
              "x": 50,
              "y": 100,
              "wires": [
                      "5e77b709b7c1eae0",
                      "bfe42f33cfa9774d"
              "type": "debug",
              "name": "debug 6",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 1320,
              "y": 300,
              "wires": []
              "ack": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1330,
              "y": 240,
              "wires": []
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 260,
              "y": 240,
              "wires": [
                      "28b5fec6c9de7785"
              "type": "debug",
              "name": "debug 18",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 780,
              "y": 240,
              "wires": []
              "type": "debug",
              "name": "debug 3",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 740,
              "y": 300,
              "wires": []
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "5",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 560,
              "y": 300,
              "wires": [
                      "8de4ca9f0f0e9d4d"
              "type": "switch",
              "name": "Status5",
              "rules": [
                      "t": "neq",
                      "v": "5",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 1,
              "x": 380,
              "y": 300,
              "wires": [
                      "a87f289d766e582a"
              "name": "Status",
              "x": 230,
              "y": 300,
              "wires": [
                      "ac9990dcafb0f297"
      peterfido
      @aphofis Ich gehe von Deinem Flow aus dem ersten Post aus. Den Wert aus "Motion" dann direkt ins Payload schieben und den Rest von meinem Entwurf damit füttern.
      Ich habe da nur versucht, den Hue Bewegungsmelder, bzw. dessen Ausgabe, nachzubauen. Ich habe da keinen, um das zuverlässig nachzubauen.
      Mein Beispiel läuft autark und blockiert den Bewegungsmelder eine Zeit lang, wenn die 1000 auf dem zweiten Pfad eintrudelt. In meinem Beispiel wird die Flow-Variable "stopp" dafür genutzt.
      Robi und Hue Bewegungungsmelder sind von dir zu ergänzen. Für den Robi könntest du z.B. eine zweite Flow-Variable nutzen.
      Peterfido
      • AphofisA Offline
        AphofisA Offline
        Aphofis
        schrieb am zuletzt editiert von Aphofis
        @peterfido sagte in HUE Bewegungsmelder Roborock integr.:
        Dazu fehlt mir wohl das wissen wie man das zusammen schustert.
        Ich weiß nicht wie man die Inject node durch eine Iobroker In Node ersetzt.
        Da anscheinend der true zustand der Inject und der Iob In node unteerschiedlich ist.
        und wo man nun den Sauger dran hängt verstehe ich auch nicht.
        Die wege sind mir noch nicht klar. Auch wenn ich überall eine Debug node dran hänge, verstehe ich den Weg noch nicht.
        Habe die Original Hue Node vom BM genommen dort kommt ja motion: ergebnis raus
        damit funktioniert es. nur wo ich nun den Roboter dran hänge das die Steuerung
        dann nur per Schalter ausgelöst werden kann und der BM bei nicht Roboter Status 5 deaktiviert ist.
        • AphofisA Aphofis
          peterfido
          schrieb am zuletzt editiert von peterfido
          @aphofis Einfach stattdessen, bzw. zum Testen von Werten, parallel.
          Einfach bissel probieren. Ich selbst sitze auf der Terrasse mit einem Tablet und gucke bissel durchs Forum.
          Der Robi schickt seinen Status, diesen in einer Flow Variable, welche idealerweise in einer Functionsnode unter Start initialisiert wird, speichern. (Status 5 = BWM true, sonst false). Inwieweit die 1000 mit dem Robi konkurrieren, bzw. welcher da gewinnt, ist mir nicht ganz klar.
          Meine Ausgabe-Function zeigt nur true, wenn die Lampe an ist, und false, wenn die aus ist. Da kann auch stattdessen eine ioBroker Out Node dran, parallel oder dahinter.
          Peterfido
          • AphofisA Offline
            AphofisA Offline
            Aphofis
            Wo ist den start !?
            Hatte ja jetzt die BWM Node von Hue eingebaut nur wo der Roboter dran gehängt wird verstehe ich noch nicht.
            Bin momentan so weit:
                    "type": "tab",
                    "label": "Flow 1",
                    "disabled": false,
                    "info": "",
                    "env": []
                    "type": "junction",
                    "x": 340,
                    "y": 240,
                    "wires": [
                            "a779e45d3967bfb9"
                    "type": "junction",
                    "x": 640,
                    "y": 240,
                    "wires": [
                            "04fa302c2270ca4f"
                    "type": "junction",
                    "x": 340,
                    "y": 180,
                    "wires": [
                            "140ae0a74c608f65"
                    "type": "junction",
                    "x": 300,
                    "y": 320,
                    "wires": [
                            "acb34561a25cb81b",
                            "98aed8cf2a3130df"
                    "id": "f2b50ddf46615123",
                    "type": "junction",
                    "x": 940,
                    "y": 280,
                    "wires": [
                            "8a764bd3f71768b8"
                    "id": "e83d1232da36de00",
                    "type": "junction",
                    "x": 640,
                    "y": 280,
                    "wires": [
                            "f2b50ddf46615123"
                    "type": "inject",
                    "name": "Bewegung",
                    "props": [
                            "v": "true",
                            "vt": "bool"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "x": 180,
                    "y": 240,
                    "wires": [
                            "5e77b709b7c1eae0",
                            "bfe42f33cfa9774d"
                    "type": "debug",
                    "name": "Ausgabe",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1220,
                    "y": 40,
                    "wires": []
                    "type": "delay",
                    "timeout": "1",
                    "rate": "1",
                    "nbRateUnits": "1",
                    "randomFirst": "1",
                    "randomLast": "5",
                    "drop": false,
                    "allowrate": false,
                    "outputs": 1,
                    "x": 420,
                    "y": 180,
                    "wires": [
                            "43a8260bfdf05214"
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "pt": "msg",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 570,
                    "y": 180,
                    "wires": [
                            "04fa302c2270ca4f"
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "true"
                            "t": "false"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 670,
                    "y": 100,
                    "wires": [
                            "91e7c6e9005453c1"
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "tot": "msg"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 780,
                    "y": 180,
                    "wires": [
                            "f5d7178472b12544"
                    "type": "comment",
                    "info": "",
                    "x": 110,
                    "y": 20,
                    "wires": []
                    "type": "inject",
                    "name": "",
                    "props": [
                            "p": "payload"
                            "p": "topic",
                            "vt": "str"
                    "repeat": "",
                    "crontab": "",
                    "once": false,
                    "onceDelay": 0.1,
                    "topic": "",
                    "payload": "1000",
                    "x": 110,
                    "y": 320,
                    "wires": [
                            "28b5fec6c9de7785"
                    "type": "change",
                    "name": "payload/true",
                    "rules": [
                            "t": "set",
                            "p": "payload",
                            "pt": "msg",
                            "to": "true",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 410,
                    "y": 320,
                    "wires": [
                            "d2ebd9fe89d68291"
                    "type": "switch",
                    "name": "1000",
                    "rules": [
                            "t": "eq",
                            "v": "1000",
                            "vt": "num"
                            "t": "eq",
                            "v": "",
                            "vt": "num"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 2,
                    "x": 230,
                    "y": 340,
                    "wires": [
                            "78e2ddead9cc1d0a"
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "false"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 1,
                    "x": 910,
                    "y": 80,
                    "wires": [
                            "8a764bd3f71768b8"
                    "type": "change",
                    "name": "payload/stop",
                    "rules": [
                            "t": "set",
                            "p": "stopp",
                            "pt": "flow",
                            "to": "true",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 410,
                    "y": 360,
                    "wires": [
                    "type": "change",
                    "rules": [
                            "t": "set",
                            "p": "stopp",
                            "pt": "flow",
                            "to": "false",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 830,
                    "y": 320,
                    "wires": [
                            "25337f528e5f609e"
                    "type": "switch",
                    "name": "",
                    "rules": [
                            "t": "eq",
                            "v": "1000",
                            "vt": "num"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 1,
                    "x": 690,
                    "y": 320,
                    "wires": [
                            "7a91b9011434fb39"
                    "type": "function",
                    "name": "Ausgabe",
                    "outputs": 1,
                    "timeout": 0,
                    "noerr": 0,
                    "finalize": "",
                    "libs": [],
                    "x": 1080,
                    "y": 60,
                    "wires": [
                            "393f87f05ba89b4d",
                            "06974459414825ae"
                    "duration": "3",
                    "units": "s",
                    "interval": "",
                    "name": "",
                    "x": 790,
                    "y": 80,
                    "wires": [
                            "932f55c48b111395"
                    "duration": "10",
                    "units": "s",
                    "interval": "",
                    "name": "",
                    "x": 550,
                    "y": 320,
                    "wires": [
                            "924f5324f130bca6",
                            "e83d1232da36de00"
                    "type": "debug",
                    "name": "Stop",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 970,
                    "y": 320,
                    "wires": []
                    "ack": "false",
                    "stateName": "",
                    "role": "",
                    "payloadType": "",
                    "readonly": "",
                    "stateUnit": "",
                    "stateMin": "",
                    "stateMax": "",
                    "x": 1230,
                    "y": 80,
                    "wires": []
                    "onlyack": "",
                    "func": "all",
                    "gap": "",
                    "x": 80,
                    "y": 360,
                    "wires": [
                            "28b5fec6c9de7785"
                    "type": "debug",
                    "name": "debug 3",
                    "active": true,
                    "tosidebar": true,
                    "console": false,
                    "tostatus": false,
                    "statusVal": "",
                    "x": 1040,
                    "y": 420,
                    "wires": []
                    "type": "change",
                    "name": "payload/5",
                    "rules": [
                            "t": "change",
                            "p": "payload",
                            "pt": "msg",
                            "from": "5",
                            "fromt": "str",
                            "to": "true",
                            "tot": "bool"
                    "action": "",
                    "property": "",
                    "from": "",
                    "to": "",
                    "reg": false,
                    "x": 880,
                    "y": 420,
                    "wires": [
                            "8de4ca9f0f0e9d4d"
                    "type": "switch",
                    "name": "Status nicht 5",
                    "rules": [
                            "t": "neq",
                            "v": "5",
                            "vt": "str"
                    "checkall": "true",
                    "repair": false,
                    "outputs": 1,
                    "x": 720,
                    "y": 420,
                    "wires": [
                            "a87f289d766e582a"
                    "name": "Status",
                    "x": 530,
                    "y": 420,
                    "wires": [
                            "ac9990dcafb0f297"
                    "id": "35902ac50003513b",
                    "type": "hue-bridge-node",
                    "name": "",
                    "bridge": "cbd54dbabf6f65be",
                    "autoupdates": true,
                    "skipglobalevents": false,
                    "initevents": false,
                    "x": 110,
                    "y": 60,
                    "wires": [
                            "3d01a93e7177b0f4"
                    "id": "3d01a93e7177b0f4",
                    "type": "hue-motion",
                    "name": "Küche Motion Sensor",
                    "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                    "skipevents": false,
                    "x": 160,
                    "y": 180,
                    "wires": [
                            "bfe42f33cfa9774d",
                            "5e77b709b7c1eae0"
                    "id": "cbd54dbabf6f65be",
                    "type": "hue-bridge",
                    "name": "Hue GordonX",
                    "bridge": "192.168.0.8",
                    "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                    "worker": "10",
                    "disableupdates": false
            Da hast du es aber gemütlich.
            Fehlt wohl nur noch ein Kaffee!
            • AphofisA Aphofis
              Wo ist den start !?
                      "type": "tab",
                      "label": "Flow 1",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "type": "junction",
                      "x": 340,
                      "y": 240,
                      "wires": [
                              "a779e45d3967bfb9"
                      "type": "junction",
                      "x": 640,
                      "y": 240,
                      "wires": [
                              "04fa302c2270ca4f"
                      "type": "junction",
                      "x": 340,
                      "y": 180,
                      "wires": [
                              "140ae0a74c608f65"
                      "type": "junction",
                      "x": 300,
                      "y": 320,
                      "wires": [
                              "acb34561a25cb81b",
                              "98aed8cf2a3130df"
                      "type": "junction",
                      "x": 940,
                      "y": 280,
                      "wires": [
                              "8a764bd3f71768b8"
                      "type": "junction",
                      "x": 640,
                      "y": 280,
                      "wires": [
                              "f2b50ddf46615123"
                      "type": "inject",
                      "name": "Bewegung",
                      "props": [
                              "v": "true",
                              "vt": "bool"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "x": 180,
                      "y": 240,
                      "wires": [
                              "5e77b709b7c1eae0",
                              "bfe42f33cfa9774d"
                      "type": "debug",
                      "name": "Ausgabe",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1220,
                      "y": 40,
                      "wires": []
                      "type": "delay",
                      "timeout": "1",
                      "rate": "1",
                      "nbRateUnits": "1",
                      "randomFirst": "1",
                      "randomLast": "5",
                      "drop": false,
                      "allowrate": false,
                      "outputs": 1,
                      "x": 420,
                      "y": 180,
                      "wires": [
                              "43a8260bfdf05214"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 570,
                      "y": 180,
                      "wires": [
                              "04fa302c2270ca4f"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 670,
                      "y": 100,
                      "wires": [
                              "91e7c6e9005453c1"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 780,
                      "y": 180,
                      "wires": [
                              "f5d7178472b12544"
                      "type": "comment",
                      "info": "",
                      "x": 110,
                      "y": 20,
                      "wires": []
                      "type": "inject",
                      "name": "",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "1000",
                      "x": 110,
                      "y": 320,
                      "wires": [
                              "28b5fec6c9de7785"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 410,
                      "y": 320,
                      "wires": [
                              "d2ebd9fe89d68291"
                      "type": "switch",
                      "name": "1000",
                      "rules": [
                              "t": "eq",
                              "v": "1000",
                              "vt": "num"
                              "t": "eq",
                              "v": "",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 230,
                      "y": 340,
                      "wires": [
                              "78e2ddead9cc1d0a"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 1,
                      "x": 910,
                      "y": 80,
                      "wires": [
                              "8a764bd3f71768b8"
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 410,
                      "y": 360,
                      "wires": [
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 830,
                      "y": 320,
                      "wires": [
                              "25337f528e5f609e"
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "eq",
                              "v": "1000",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 1,
                      "x": 690,
                      "y": 320,
                      "wires": [
                              "7a91b9011434fb39"
                      "type": "function",
                      "name": "Ausgabe",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "finalize": "",
                      "libs": [],
                      "x": 1080,
                      "y": 60,
                      "wires": [
                              "393f87f05ba89b4d",
                              "06974459414825ae"
                      "duration": "3",
                      "units": "s",
                      "interval": "",
                      "name": "",
                      "x": 790,
                      "y": 80,
                      "wires": [
                              "932f55c48b111395"
                      "duration": "10",
                      "units": "s",
                      "interval": "",
                      "name": "",
                      "x": 550,
                      "y": 320,
                      "wires": [
                              "924f5324f130bca6",
                              "e83d1232da36de00"
                      "type": "debug",
                      "name": "Stop",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 970,
                      "y": 320,
                      "wires": []
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1230,
                      "y": 80,
                      "wires": []
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 80,
                      "y": 360,
                      "wires": [
                              "28b5fec6c9de7785"
                      "type": "debug",
                      "name": "debug 3",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1040,
                      "y": 420,
                      "wires": []
                      "type": "change",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "5",
                              "fromt": "str",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 880,
                      "y": 420,
                      "wires": [
                              "8de4ca9f0f0e9d4d"
                      "type": "switch",
                      "rules": [
                              "t": "neq",
                              "v": "5",
                              "vt": "str"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 1,
                      "x": 720,
                      "y": 420,
                      "wires": [
                              "a87f289d766e582a"
                      "name": "Status",
                      "x": 530,
                      "y": 420,
                      "wires": [
                              "ac9990dcafb0f297"
                      "name": "",
                      "x": 110,
                      "y": 60,
                      "wires": [
                              "3d01a93e7177b0f4"
                      "x": 160,
                      "y": 180,
                      "wires": [
                              "bfe42f33cfa9774d",
                              "5e77b709b7c1eae0"
                      "worker": "10",
              peterfido
              @aphofis Probier mal das:
                      "id": "a42b83181f07f8d0",
                      "type": "tab",
                      "label": "Flow 8",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "id": "1c8c0acba7c2bff2",
                      "type": "inject",
                      "z": "a42b83181f07f8d0",
                      "name": "Test Bewegung",
                      "props": [
                              "v": "true",
                              "vt": "bool"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "Bewegungsmelder",
                      "x": 120,
                      "y": 60,
                      "wires": [
                              "8bf1e5067a6f0ad2",
                              "b0410acfcad1b37e"
                      "id": "d1f2c8393ea7f683",
                      "type": "debug",
                      "name": "debug 3",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "complete": "true",
                      "targetType": "full",
                      "statusVal": "",
                      "x": 1560,
                      "y": 40,
                      "wires": []
                      "id": "8bf1e5067a6f0ad2",
                      "type": "delay",
                      "name": "",
                      "timeout": "1",
                      "rate": "1",
                      "nbRateUnits": "1",
                      "randomFirst": "1",
                      "randomLast": "5",
                      "drop": false,
                      "allowrate": false,
                      "outputs": 1,
                      "x": 120,
                      "y": 120,
                      "wires": [
                              "a9f9b30b4f8999d0"
                      "id": "a9f9b30b4f8999d0",
                      "type": "change",
                      "name": "motion:false",
                      "rules": [
                              "t": "set",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 170,
                      "y": 160,
                      "wires": [
                              "b0410acfcad1b37e"
                      "id": "7a509a8587332f14",
                      "type": "switch",
                      "name": "Schalter",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 820,
                      "y": 80,
                      "wires": [
                              "4d146d05efbc5d35"
                      "id": "c1952bc66da5a348",
                      "duration": "3",
                      "units": "s",
                      "interval": "",
                      "name": "",
                      "x": 1130,
                      "y": 60,
                      "wires": [
                              "550905a564f09176"
                      "id": "6adb99e531920623",
                      "type": "change",
                      "name": "Motion",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 500,
                      "y": 60,
                      "wires": [
                              "9f0c88dad82d8633"
                      "id": "9f83e7917ef2d8e2",
                      "type": "comment",
                      "name": "<< Bewegungsmelder |||||||||||||| Simulator  Beginn>>",
                      "info": "",
                      "x": 220,
                      "y": 20,
                      "wires": []
                      "id": "302a07cea50da337",
                      "duration": "45",
                      "units": "s",
                      "interval": "",
                      "name": "",
                      "x": 710,
                      "y": 180,
                      "wires": [
                              "2871643160dfcc7c",
                              "550905a564f09176"
                      "id": "0762e0ad3da83f0d",
                      "type": "inject",
                      "name": "Test 1000",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "Schalter_1000",
                      "payload": "1000",
                      "x": 120,
                      "y": 280,
                      "wires": [
                              "d1051390faa881a3"
                      "id": "bd795708de32c118",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 530,
                      "y": 240,
                      "wires": [
                              "302a07cea50da337"
                      "id": "d1051390faa881a3",
                      "type": "switch",
                      "name": "1000?",
                      "rules": [
                              "t": "eq",
                              "v": "1000",
                              "vt": "num"
                              "t": "eq",
                              "v": "",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 290,
                      "y": 300,
                      "wires": [
                              "bd795708de32c118",
                              "32b9213c2fe970b0"
                      "id": "4d146d05efbc5d35",
                      "type": "switch",
                      "name": "Robi",
                      "property": "BWM",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 950,
                      "y": 80,
                      "wires": [
                              "c1952bc66da5a348"
                      "id": "32b9213c2fe970b0",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 520,
                      "y": 280,
                      "wires": [
                      "id": "0439088d7ec73749",
                      "type": "change",
                      "name": "llöscheflow.stopp",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1030,
                      "y": 260,
                      "wires": [
                      "id": "2871643160dfcc7c",
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "eq",
                              "v": "1000",
                              "vt": "num"
                              "t": "eq",
                              "v": "",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 830,
                      "y": 260,
                      "wires": [
                              "0439088d7ec73749"
                      "id": "550905a564f09176",
                      "type": "function",
                      "name": "Variablen Ini + Ausgabe",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
                      "finalize": "",
                      "libs": [],
                      "x": 1330,
                      "y": 120,
                      "wires": [
                              "d1f2c8393ea7f683",
                              "e2721e4056e942e3"
                      "id": "d7bd1efc606cfcad",
                      "name": "ioB Robi",
                      "topic": "*",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 120,
                      "y": 560,
                      "wires": [
                              "b2f36db79c165583"
                      "id": "b0410acfcad1b37e",
                      "type": "function",
                      "name": "Ausgang BWM",
                      "func": "\nreturn msg;",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "initialize": "",
                      "finalize": "",
                      "libs": [],
                      "x": 320,
                      "y": 60,
                      "wires": [
                              "6adb99e531920623"
                      "id": "e2721e4056e942e3",
                      "name": "ioBroker Lampe",
                      "topic": "",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1640,
                      "y": 160,
                      "wires": []
                      "id": "7cfd7f7fba2e2d7a",
                      "name": "ioB Schalter",
                      "topic": "*",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 110,
                      "y": 340,
                      "wires": [
                              "d1051390faa881a3"
                      "id": "91ef09f531fcc27b",
                      "type": "inject",
                      "name": "Test Robi = 5",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "5",
                      "x": 130,
                      "y": 440,
                      "wires": [
                              "b2f36db79c165583"
                      "id": "6db2cc2617ad5707",
                      "type": "inject",
                      "name": "Test Robi <> 5",
                      "props": [
                              "p": "payload"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "topic": "",
                      "payload": "6",
                      "x": 130,
                      "y": 500,
                      "wires": [
                              "b2f36db79c165583"
                      "id": "b2f36db79c165583",
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "eq",
                              "v": "5",
                              "vt": "num"
                              "t": "neq",
                              "v": "5",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 310,
                      "y": 500,
                      "wires": [
                              "407e2e376c0ee370"
                              "5061312f43733426"
                      "id": "407e2e376c0ee370",
                      "type": "change",
                      "name": "setze Flow.BWM",
                      "rules": [
                              "t": "set",
                              "p": "BWM",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 500,
                      "y": 460,
                      "wires": [
                              "0650a4ab7aec40a1"
                      "id": "5061312f43733426",
                      "type": "change",
                      "name": "lösche Flow.BWM",
                      "rules": [
                              "t": "set",
                              "p": "BWM",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 490,
                      "y": 520,
                      "wires": [
                              "0650a4ab7aec40a1"
                      "id": "879b9060efcd163b",
                      "type": "comment",
                      "name": "evtl. gesperrt durch??",
                      "info": "",
                      "x": 880,
                      "y": 40,
                      "wires": []
                      "id": "9f0c88dad82d8633",
                      "type": "switch",
                      "name": "nur true",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 640,
                      "y": 80,
                      "wires": [
                              "7a509a8587332f14"
                      "id": "0650a4ab7aec40a1",
                      "type": "debug",
                      "name": "debug 4",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "complete": "true",
                      "statusVal": "",
                      "x": 720,
                      "y": 500,
                      "wires": []
                      "id": "f144b6f8b998c7f5",
                      "type": "comment",
                      "name": "<< Bewegungsmelder |||||||||||||| Simulator Ende >>",
                      "info": "",
                      "x": 220,
                      "y": 220,
                      "wires": []
              Edit: Die Verzögerung von einer Sekunde hinter dem BWM braucht es nicht unbedingt. Die setzt nur meinen simulierten BWM zurück.
              Peterfido
              AphofisA 1 Antwort Letzte Antwort
              • P peterfido
                        "type": "tab",
                        "label": "Flow 8",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "type": "inject",
                        "props": [
                                "v": "true",
                                "vt": "bool"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "x": 120,
                        "y": 60,
                        "wires": [
                                "8bf1e5067a6f0ad2",
                                "b0410acfcad1b37e"
                        "type": "debug",
                        "name": "debug 3",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "true",
                        "statusVal": "",
                        "x": 1560,
                        "y": 40,
                        "wires": []
                        "type": "delay",
                        "name": "",
                        "timeout": "1",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 120,
                        "y": 120,
                        "wires": [
                                "a9f9b30b4f8999d0"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "pt": "msg",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 170,
                        "y": 160,
                        "wires": [
                                "b0410acfcad1b37e"
                        "type": "switch",
                        "name": "Schalter",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 820,
                        "y": 80,
                        "wires": [
                                "4d146d05efbc5d35"
                        "duration": "3",
                        "units": "s",
                        "interval": "",
                        "name": "",
                        "x": 1130,
                        "y": 60,
                        "wires": [
                                "550905a564f09176"
                        "type": "change",
                        "name": "Motion",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 500,
                        "y": 60,
                        "wires": [
                                "9f0c88dad82d8633"
                        "type": "comment",
                        "info": "",
                        "x": 220,
                        "y": 20,
                        "wires": []
                        "duration": "45",
                        "units": "s",
                        "interval": "",
                        "name": "",
                        "x": 710,
                        "y": 180,
                        "wires": [
                                "2871643160dfcc7c",
                                "550905a564f09176"
                        "type": "inject",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "payload": "1000",
                        "x": 120,
                        "y": 280,
                        "wires": [
                                "d1051390faa881a3"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 530,
                        "y": 240,
                        "wires": [
                                "302a07cea50da337"
                        "type": "switch",
                        "name": "1000?",
                        "rules": [
                                "t": "eq",
                                "v": "1000",
                                "vt": "num"
                                "t": "eq",
                                "v": "",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 290,
                        "y": 300,
                        "wires": [
                                "bd795708de32c118",
                                "32b9213c2fe970b0"
                        "type": "switch",
                        "name": "Robi",
                        "property": "BWM",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 950,
                        "y": 80,
                        "wires": [
                                "c1952bc66da5a348"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "stopp",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 520,
                        "y": 280,
                        "wires": [
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "stopp",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 1030,
                        "y": 260,
                        "wires": [
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "eq",
                                "v": "1000",
                                "vt": "num"
                                "t": "eq",
                                "v": "",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 830,
                        "y": 260,
                        "wires": [
                                "0439088d7ec73749"
                        "type": "function",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "finalize": "",
                        "libs": [],
                        "x": 1330,
                        "y": 120,
                        "wires": [
                                "d1f2c8393ea7f683",
                                "e2721e4056e942e3"
                        "name": "ioB Robi",
                        "topic": "*",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 120,
                        "y": 560,
                        "wires": [
                                "b2f36db79c165583"
                        "type": "function",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 320,
                        "y": 60,
                        "wires": [
                                "6adb99e531920623"
                        "topic": "",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1640,
                        "y": 160,
                        "wires": []
                        "topic": "*",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 110,
                        "y": 340,
                        "wires": [
                                "d1051390faa881a3"
                        "type": "inject",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "5",
                        "x": 130,
                        "y": 440,
                        "wires": [
                                "b2f36db79c165583"
                        "type": "inject",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "6",
                        "x": 130,
                        "y": 500,
                        "wires": [
                                "b2f36db79c165583"
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "eq",
                                "v": "5",
                                "vt": "num"
                                "t": "neq",
                                "v": "5",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 310,
                        "y": 500,
                        "wires": [
                                "407e2e376c0ee370"
                                "5061312f43733426"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "BWM",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 500,
                        "y": 460,
                        "wires": [
                                "0650a4ab7aec40a1"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "BWM",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 490,
                        "y": 520,
                        "wires": [
                                "0650a4ab7aec40a1"
                        "type": "comment",
                        "info": "",
                        "x": 880,
                        "y": 40,
                        "wires": []
                        "type": "switch",
                        "name": "nur true",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 640,
                        "y": 80,
                        "wires": [
                                "7a509a8587332f14"
                        "type": "debug",
                        "name": "debug 4",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "true",
                        "statusVal": "",
                        "x": 720,
                        "y": 500,
                        "wires": []
                        "type": "comment",
                        "info": "",
                        "x": 220,
                        "y": 220,
                        "wires": []
                AphofisA Offline
                AphofisA Offline
                Aphofis
                @peterfido
                Das funktioniert.
                Habe da jetzt die normale Küchen Schaltung die es jetzt zu integrieren gilt.
                        "id": "f40fbc4eb5ac4f7a",
                        "type": "tab",
                        "label": "Küche",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "id": "a9a291ef92812c32",
                        "type": "junction",
                        "z": "f40fbc4eb5ac4f7a",
                        "x": 1160,
                        "y": 360,
                        "wires": [
                                "138c91dc2bbc1ae3",
                                "8d88b2a94c9ec76d",
                                "687c7e27683f7c5c",
                                "5f54b4987a5f8dd2",
                                "a54734800b81342e"
                        "id": "202c49953d235813",
                        "name": "Switch 2",
                        "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_2",
                        "x": 940,
                        "y": 460,
                        "wires": [
                                "5f856636064395a8"
                        "id": "5f856636064395a8",
                        "type": "change",
                        "name": "toggle",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "$not(payload)\t",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 1070,
                        "y": 460,
                        "wires": [
                                "167c3d9534071cfb",
                                "266f45298fe39781"
                        "id": "167c3d9534071cfb",
                        "name": "Virtuel Switch 2",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1320,
                        "y": 520,
                        "wires": []
                        "id": "f4b15ec716491f99",
                        "name": "Switch 3",
                        "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_3",
                        "x": 940,
                        "y": 580,
                        "wires": [
                                "5c2fda12ba92680a"
                        "id": "5c2fda12ba92680a",
                        "type": "change",
                        "name": "toggle",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 1070,
                        "y": 580,
                        "wires": [
                                "8be32882ca318f17",
                                "3e09ac32ae810712"
                        "id": "8be32882ca318f17",
                        "name": "Virtuel Switch 3",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1320,
                        "y": 640,
                        "wires": []
                        "id": "bffd16b00cfde14d",
                        "name": "Switch 1",
                        "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                        "x": 940,
                        "y": 360,
                        "wires": [
                                "c2ccf4efb123db4a"
                        "id": "c2ccf4efb123db4a",
                        "type": "change",
                        "name": "toggle",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 1070,
                        "y": 360,
                        "wires": [
                                "a9a291ef92812c32"
                        "id": "0d321e0ed699fec1",
                        "name": "U-rechts",
                        "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1430,
                        "y": 300,
                        "wires": []
                        "id": "589ac75a5e32f1d9",
                        "name": "Küche Decke",
                        "topic": "tuya.0.bfe4af976feb74d845vugp.1",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1430,
                        "y": 180,
                        "wires": []
                        "id": "492203889ad083cc",
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "eq",
                                "v": "1000",
                                "vt": "str"
                                "t": "eq",
                                "v": "2000",
                                "vt": "str"
                                "t": "eq",
                                "v": "3000",
                                "vt": "str"
                                "t": "eq",
                                "v": "4000",
                                "vt": "str"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 4,
                        "x": 590,
                        "y": 420,
                        "wires": [
                                "f17ddf70f0e3a462"
                                "18138896535a8b98"
                                "b060108e3005d932"
                                "26451af092a50c2a"
                        "id": "138c91dc2bbc1ae3",
                        "name": "Virtuel Switch 1",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1320,
                        "y": 240,
                        "wires": []
                        "id": "4efde19f0e9d494d",
                        "d": true,
                        "name": "Küche Schalter",
                        "onlyack": "",
                        "func": "rbe",
                        "gap": "",
                        "x": 360,
                        "y": 480,
                        "wires": [
                                "492203889ad083cc"
                        "id": "a258cc2e98284972",
                        "name": "Switch 4",
                        "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_4",
                        "x": 940,
                        "y": 700,
                        "wires": [
                                "7990f93a2f6d4246"
                        "id": "7990f93a2f6d4246",
                        "type": "change",
                        "name": "toggle",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 1070,
                        "y": 700,
                        "wires": [
                                "bf03dbcaedeac1bf",
                                "974fbea0a2bec958"
                        "id": "bf03dbcaedeac1bf",
                        "name": "VSwitch 4",
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1300,
                        "y": 760,
                        "wires": []
                        "id": "450a86229a268dec",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "true",
                        "payloadType": "str",
                        "x": 230,
                        "y": 420,
                        "wires": [
                                "708b9446e314ce9a"
                        "id": "ad88b1a4b3ec08b2",
                        "type": "link in",
                        "name": "Alexa Switch Küche",
                        "links": [
                            "ad266b7267edaa39"
                        "x": 185,
                        "y": 360,
                        "wires": [
                                "9bfe6974c0049dcc"
                        "id": "bacc098ce38ea437",
                        "type": "change",
                        "name": "on/off",
                        "rules": [
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "on",
                                "fromt": "str",
                                "to": "1002",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 430,
                        "y": 360,
                        "wires": [
                                "492203889ad083cc"
                        "id": "9bfe6974c0049dcc",
                        "type": "amazon-echo-device",
                        "name": "Alexa Küche",
                        "topic": "hue.0.Küche_Schalter.buttonevent",
                        "x": 290,
                        "y": 360,
                        "wires": [
                                "bacc098ce38ea437"
                        "id": "d5ac3ac0172cc081",
                        "name": "",
                        "x": 370,
                        "y": 540,
                        "wires": [
                                "492203889ad083cc"
                        "id": "98ee3d8530b8677f",
                        "type": "debug",
                        "name": "Küche",
                        "active": true,
                        "tosidebar": true,
                        "console": true,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1420,
                        "y": 420,
                        "wires": []
                        "id": "de121f3c399ed6d5",
                        "type": "hue-light",
                        "name": "Unterschr.Li",
                        "lightid": "9954a221-26e8-40ab-9732-ad33d14aeb5f",
                        "colornamer": false,
                        "x": 1450,
                        "y": 360,
                        "wires": [
                        "id": "708b9446e314ce9a",
                        "type": "trigger",
                        "name": "1000/1002",
                        "op1": "1000",
                        "op2": "1002",
                        "op1type": "str",
                        "op2type": "str",
                        "duration": "200",
                        "extend": false,
                        "overrideDelay": false,
                        "units": "ms",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 370,
                        "y": 420,
                        "wires": [
                                "492203889ad083cc"
                        "id": "974fbea0a2bec958",
                        "type": "hue-group",
                        "name": "Wohnzimmer",
                        "groupid": "fea8bacb-2692-4b22-9d97-295a32985af8",
                        "x": 1330,
                        "y": 700,
                        "wires": [
                        "id": "8d88b2a94c9ec76d",
                        "type": "delay",
                        "name": "230ms",
                        "timeout": "230",
                        "timeoutUnits": "milliseconds",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 1290,
                        "y": 360,
                        "wires": [
                                "de121f3c399ed6d5"
                        "id": "3e09ac32ae810712",
                        "type": "hue-scene",
                        "name": "Konzentrieren",
                        "sceneid": "1262fa36-0216-4e90-81f8-2c52082b2829",
                        "x": 1340,
                        "y": 580,
                        "wires": [
                        "id": "266f45298fe39781",
                        "name": "warmweiss",
                        "sceneid": "a48a039f-dc58-44ad-bb81-f6989dd30a2e",
                        "x": 1330,
                        "y": 460,
                        "wires": [
                        "id": "687c7e27683f7c5c",
                        "type": "delay",
                        "name": "230ms",
                        "timeout": "230",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 1290,
                        "y": 300,
                        "wires": [
                                "0d321e0ed699fec1"
                        "id": "5f54b4987a5f8dd2",
                        "type": "delay",
                        "name": "100ms",
                        "timeout": "100",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 1290,
                        "y": 180,
                        "wires": [
                                "589ac75a5e32f1d9"
                        "id": "f17ddf70f0e3a462",
                        "type": "delay",
                        "name": "100ms",
                        "timeout": "100",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 810,
                        "y": 360,
                        "wires": [
                                "bffd16b00cfde14d"
                        "id": "b060108e3005d932",
                        "type": "delay",
                        "name": "100ms",
                        "timeout": "100",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 810,
                        "y": 580,
                        "wires": [
                                "f4b15ec716491f99"
                        "id": "26451af092a50c2a",
                        "type": "delay",
                        "name": "100ms",
                        "timeout": "100",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 810,
                        "y": 700,
                        "wires": [
                                "a258cc2e98284972"
                        "id": "18138896535a8b98",
                        "type": "delay",
                        "name": "100ms",
                        "timeout": "100",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 810,
                        "y": 460,
                        "wires": [
                                "202c49953d235813"
                        "id": "a54734800b81342e",
                        "type": "change",
                        "name": "Küche",
                        "rules": [
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "1002",
                                "fromt": "str",
                                "to": "Küche",
                                "tot": "str"
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "true",
                                "fromt": "bool",
                                "to": "Küche eingeschaltet",
                                "tot": "str"
                                "t": "change",
                                "p": "payload",
                                "pt": "msg",
                                "from": "false",
                                "fromt": "bool",
                                "to": "Küche ausgeschaltet",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 1290,
                        "y": 420,
                        "wires": [
                                "98ee3d8530b8677f"
                        "id": "cc4b3f317dc6949d",
                        "type": "trigger",
                        "name": "2000/2002",
                        "op1": "2000",
                        "op2": "2002",
                        "op1type": "str",
                        "op2type": "str",
                        "duration": "200",
                        "extend": false,
                        "units": "ms",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 350,
                        "y": 680,
                        "wires": [
                                "492203889ad083cc"
                        "id": "58080c269d40839f",
                        "type": "trigger",
                        "name": "3000/3002",
                        "op1": "3000",
                        "op2": "3002",
                        "op1type": "str",
                        "op2type": "str",
                        "duration": "200",
                        "extend": false,
                        "units": "ms",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 350,
                        "y": 720,
                        "wires": [
                                "492203889ad083cc"
                        "id": "7dbf8e1e7cc0c58b",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "true",
                        "x": 210,
                        "y": 680,
                        "wires": [
                                "cc4b3f317dc6949d"
                        "id": "56783e9b03496a6b",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "true",
                        "x": 210,
                        "y": 720,
                        "wires": [
                                "58080c269d40839f"
                        "id": "e2b5712b17f86c31",
                        "type": "trigger",
                        "name": "4000/4002",
                        "op1": "4000",
                        "op2": "4002",
                        "op1type": "str",
                        "op2type": "str",
                        "duration": "200",
                        "extend": false,
                        "units": "ms",
                        "reset": "",
                        "bytopic": "all",
                        "topic": "topic",
                        "outputs": 1,
                        "x": 350,
                        "y": 760,
                        "wires": [
                                "492203889ad083cc"
                        "id": "60a4fa746191a149",
                        "type": "inject",
                        "name": "",
                        "props": [
                                "p": "payload"
                                "p": "topic",
                                "vt": "str"
                        "repeat": "",
                        "crontab": "",
                        "once": false,
                        "onceDelay": 0.1,
                        "topic": "",
                        "payload": "true",
                        "x": 210,
                        "y": 760,
                        "wires": [
                                "e2b5712b17f86c31"
                        "worker": "10",
                So funktioniert die Steuerung von dir prima nur muss diese in die standard schalter schaltung integriert werden.
                        "type": "tab",
                        "label": "Flow 8",
                        "disabled": false,
                        "info": "",
                        "env": []
                        "type": "debug",
                        "name": "debug 3",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "true",
                        "statusVal": "",
                        "x": 1160,
                        "y": 520,
                        "wires": []
                        "type": "delay",
                        "name": "verz. 1s",
                        "timeout": "1",
                        "rate": "1",
                        "nbRateUnits": "1",
                        "randomFirst": "1",
                        "randomLast": "5",
                        "drop": false,
                        "allowrate": false,
                        "outputs": 1,
                        "x": 360,
                        "y": 480,
                        "wires": [
                                "a9f9b30b4f8999d0"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "pt": "msg",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 510,
                        "y": 480,
                        "wires": [
                                "b0410acfcad1b37e"
                        "type": "switch",
                        "name": "Schalter",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 1060,
                        "y": 440,
                        "wires": [
                                "4d146d05efbc5d35"
                        "duration": "3",
                        "units": "s",
                        "interval": "",
                        "name": "",
                        "x": 1310,
                        "y": 440,
                        "wires": [
                                "550905a564f09176"
                        "type": "change",
                        "name": "Motion",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 790,
                        "y": 440,
                        "wires": [
                                "9f0c88dad82d8633"
                        "type": "comment",
                        "name": "<< Bewegungsmelder Simulator  Beginn>>",
                        "info": "",
                        "x": 180,
                        "y": 380,
                        "wires": []
                        "duration": "45",
                        "units": "s",
                        "interval": "",
                        "name": "",
                        "x": 550,
                        "y": 600,
                        "wires": [
                                "2871643160dfcc7c",
                                "550905a564f09176"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 390,
                        "y": 600,
                        "wires": [
                                "302a07cea50da337"
                        "type": "switch",
                        "name": "1000?",
                        "rules": [
                                "t": "eq",
                                "v": "1000",
                                "vt": "num"
                                "t": "eq",
                                "v": "",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 210,
                        "y": 620,
                        "wires": [
                                "bd795708de32c118",
                                "32b9213c2fe970b0"
                        "type": "switch",
                        "name": "Robi",
                        "property": "BWM",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 1190,
                        "y": 440,
                        "wires": [
                                "c1952bc66da5a348"
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "stopp",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 380,
                        "y": 640,
                        "wires": [
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "stopp",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 830,
                        "y": 640,
                        "wires": [
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "eq",
                                "v": "1000",
                                "vt": "num"
                                "t": "eq",
                                "v": "",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 670,
                        "y": 620,
                        "wires": [
                                "0439088d7ec73749"
                        "type": "function",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "finalize": "",
                        "libs": [],
                        "x": 910,
                        "y": 560,
                        "wires": [
                                "d1f2c8393ea7f683",
                                "e2721e4056e942e3"
                        "name": "Robi",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 90,
                        "y": 720,
                        "wires": [
                                "b2f36db79c165583"
                        "type": "function",
                        "name": "Out BWM",
                        "outputs": 1,
                        "timeout": 0,
                        "noerr": 0,
                        "initialize": "",
                        "finalize": "",
                        "libs": [],
                        "x": 660,
                        "y": 440,
                        "wires": [
                                "6adb99e531920623"
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1160,
                        "y": 560,
                        "wires": []
                        "name": "KüSchalter",
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 80,
                        "y": 620,
                        "wires": [
                                "d1051390faa881a3"
                        "type": "switch",
                        "name": "",
                        "rules": [
                                "t": "eq",
                                "v": "5",
                                "vt": "num"
                                "t": "neq",
                                "v": "5",
                                "vt": "num"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 290,
                        "y": 720,
                        "wires": [
                                "407e2e376c0ee370"
                                "5061312f43733426"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "BWM",
                                "pt": "flow",
                                "to": "true",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 470,
                        "y": 700,
                        "wires": [
                                "0650a4ab7aec40a1"
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "BWM",
                                "pt": "flow",
                                "to": "false",
                                "tot": "bool"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 470,
                        "y": 740,
                        "wires": [
                                "0650a4ab7aec40a1"
                        "type": "comment",
                        "info": "",
                        "x": 900,
                        "y": 380,
                        "wires": []
                        "type": "switch",
                        "name": "nur true",
                        "rules": [
                                "t": "true"
                                "t": "false"
                        "checkall": "true",
                        "repair": false,
                        "outputs": 2,
                        "x": 920,
                        "y": 440,
                        "wires": [
                                "7a509a8587332f14"
                        "type": "debug",
                        "name": "debug 4",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "complete": "true",
                        "statusVal": "",
                        "x": 640,
                        "y": 720,
                        "wires": []
                        "type": "comment",
                        "name": "<< Bewegungsmelder Simulator Ende >>",
                        "info": "",
                        "x": 180,
                        "y": 560,
                        "wires": []
                        "id": "f74d0c3a0bc11bfd",
                        "name": "Hue",
                        "x": 90,
                        "y": 440,
                        "wires": [
                                "b6564cd395bbd771"
                        "id": "b6564cd395bbd771",
                        "name": "KüMo",
                        "x": 230,
                        "y": 440,
                        "wires": [
                                "b0410acfcad1b37e",
                                "8bf1e5067a6f0ad2"
                        "worker": "10",
                Da der HUE Schalter nur befehle sendet wie auf Kanal 1 für die Küche
                1000 und 100ms später 1002 muss die Steuerung nun die virtuellen schalter haben um mit einem klick das Licht ein und mit einem weiteren klick die lampen wieder ausschaltet. damit muss dann auch die 45 Sekunden (45min.) Schaltung deaktiviert werden.
                Wenn ich das integriere läuft der 45sek. Timer weiter.
                P 2 Antworten Letzte Antwort
                • AphofisA Aphofis
                  @peterfido
                  Das funktioniert.
                          "type": "tab",
                          "label": "Küche",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "junction",
                          "x": 1160,
                          "y": 360,
                          "wires": [
                                  "138c91dc2bbc1ae3",
                                  "8d88b2a94c9ec76d",
                                  "687c7e27683f7c5c",
                                  "5f54b4987a5f8dd2",
                                  "a54734800b81342e"
                          "name": "Switch 2",
                          "x": 940,
                          "y": 460,
                          "wires": [
                                  "5f856636064395a8"
                          "type": "change",
                          "name": "toggle",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 1070,
                          "y": 460,
                          "wires": [
                                  "167c3d9534071cfb",
                                  "266f45298fe39781"
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1320,
                          "y": 520,
                          "wires": []
                          "name": "Switch 3",
                          "x": 940,
                          "y": 580,
                          "wires": [
                                  "5c2fda12ba92680a"
                          "type": "change",
                          "name": "toggle",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 1070,
                          "y": 580,
                          "wires": [
                                  "8be32882ca318f17",
                                  "3e09ac32ae810712"
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1320,
                          "y": 640,
                          "wires": []
                          "name": "Switch 1",
                          "x": 940,
                          "y": 360,
                          "wires": [
                                  "c2ccf4efb123db4a"
                          "type": "change",
                          "name": "toggle",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 1070,
                          "y": 360,
                          "wires": [
                                  "a9a291ef92812c32"
                          "name": "U-rechts",
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1430,
                          "y": 300,
                          "wires": []
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1430,
                          "y": 180,
                          "wires": []
                          "type": "switch",
                          "name": "",
                          "rules": [
                                  "t": "eq",
                                  "v": "1000",
                                  "vt": "str"
                                  "t": "eq",
                                  "v": "2000",
                                  "vt": "str"
                                  "t": "eq",
                                  "v": "3000",
                                  "vt": "str"
                                  "t": "eq",
                                  "v": "4000",
                                  "vt": "str"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 4,
                          "x": 590,
                          "y": 420,
                          "wires": [
                                  "f17ddf70f0e3a462"
                                  "18138896535a8b98"
                                  "b060108e3005d932"
                                  "26451af092a50c2a"
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1320,
                          "y": 240,
                          "wires": []
                          "d": true,
                          "onlyack": "",
                          "func": "rbe",
                          "gap": "",
                          "x": 360,
                          "y": 480,
                          "wires": [
                                  "492203889ad083cc"
                          "name": "Switch 4",
                          "x": 940,
                          "y": 700,
                          "wires": [
                                  "7990f93a2f6d4246"
                          "type": "change",
                          "name": "toggle",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "jsonata"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 1070,
                          "y": 700,
                          "wires": [
                                  "bf03dbcaedeac1bf",
                                  "974fbea0a2bec958"
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1300,
                          "y": 760,
                          "wires": []
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "true",
                          "x": 230,
                          "y": 420,
                          "wires": [
                                  "708b9446e314ce9a"
                          "type": "link in",
                          "links": [
                              "ad266b7267edaa39"
                          "x": 185,
                          "y": 360,
                          "wires": [
                                  "9bfe6974c0049dcc"
                          "type": "change",
                          "name": "on/off",
                          "rules": [
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "on",
                                  "fromt": "str",
                                  "to": "1002",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 430,
                          "y": 360,
                          "wires": [
                                  "492203889ad083cc"
                          "x": 290,
                          "y": 360,
                          "wires": [
                                  "bacc098ce38ea437"
                          "name": "",
                          "x": 370,
                          "y": 540,
                          "wires": [
                                  "492203889ad083cc"
                          "type": "debug",
                          "name": "Küche",
                          "active": true,
                          "tosidebar": true,
                          "console": true,
                          "tostatus": false,
                          "statusVal": "",
                          "x": 1420,
                          "y": 420,
                          "wires": []
                          "x": 1450,
                          "y": 360,
                          "wires": [
                          "type": "trigger",
                          "op1": "1000",
                          "op2": "1002",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "200",
                          "extend": false,
                          "units": "ms",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 370,
                          "y": 420,
                          "wires": [
                                  "492203889ad083cc"
                          "x": 1330,
                          "y": 700,
                          "wires": [
                          "type": "delay",
                          "name": "230ms",
                          "timeout": "230",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 1290,
                          "y": 360,
                          "wires": [
                                  "de121f3c399ed6d5"
                          "x": 1340,
                          "y": 580,
                          "wires": [
                          "x": 1330,
                          "y": 460,
                          "wires": [
                          "type": "delay",
                          "name": "230ms",
                          "timeout": "230",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 1290,
                          "y": 300,
                          "wires": [
                                  "0d321e0ed699fec1"
                          "type": "delay",
                          "name": "100ms",
                          "timeout": "100",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 1290,
                          "y": 180,
                          "wires": [
                                  "589ac75a5e32f1d9"
                          "type": "delay",
                          "name": "100ms",
                          "timeout": "100",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 810,
                          "y": 360,
                          "wires": [
                                  "bffd16b00cfde14d"
                          "type": "delay",
                          "name": "100ms",
                          "timeout": "100",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 810,
                          "y": 580,
                          "wires": [
                                  "f4b15ec716491f99"
                          "type": "delay",
                          "name": "100ms",
                          "timeout": "100",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 810,
                          "y": 700,
                          "wires": [
                                  "a258cc2e98284972"
                          "type": "delay",
                          "name": "100ms",
                          "timeout": "100",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 810,
                          "y": 460,
                          "wires": [
                                  "202c49953d235813"
                          "type": "change",
                          "name": "Küche",
                          "rules": [
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "1002",
                                  "fromt": "str",
                                  "to": "Küche",
                                  "tot": "str"
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "true",
                                  "fromt": "bool",
                                  "tot": "str"
                                  "t": "change",
                                  "p": "payload",
                                  "pt": "msg",
                                  "from": "false",
                                  "fromt": "bool",
                                  "tot": "str"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 1290,
                          "y": 420,
                          "wires": [
                                  "98ee3d8530b8677f"
                          "type": "trigger",
                          "op1": "2000",
                          "op2": "2002",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "200",
                          "extend": false,
                          "units": "ms",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 350,
                          "y": 680,
                          "wires": [
                                  "492203889ad083cc"
                          "type": "trigger",
                          "op1": "3000",
                          "op2": "3002",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "200",
                          "extend": false,
                          "units": "ms",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 350,
                          "y": 720,
                          "wires": [
                                  "492203889ad083cc"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "true",
                          "x": 210,
                          "y": 680,
                          "wires": [
                                  "cc4b3f317dc6949d"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "true",
                          "x": 210,
                          "y": 720,
                          "wires": [
                                  "58080c269d40839f"
                          "type": "trigger",
                          "op1": "4000",
                          "op2": "4002",
                          "op1type": "str",
                          "op2type": "str",
                          "duration": "200",
                          "extend": false,
                          "units": "ms",
                          "reset": "",
                          "bytopic": "all",
                          "topic": "topic",
                          "outputs": 1,
                          "x": 350,
                          "y": 760,
                          "wires": [
                                  "492203889ad083cc"
                          "type": "inject",
                          "name": "",
                          "props": [
                                  "p": "payload"
                                  "p": "topic",
                                  "vt": "str"
                          "repeat": "",
                          "crontab": "",
                          "once": false,
                          "onceDelay": 0.1,
                          "topic": "",
                          "payload": "true",
                          "x": 210,
                          "y": 760,
                          "wires": [
                                  "e2b5712b17f86c31"
                          "worker": "10",
                          "type": "tab",
                          "label": "Flow 8",
                          "disabled": false,
                          "info": "",
                          "env": []
                          "type": "debug",
                          "name": "debug 3",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "complete": "true",
                          "statusVal": "",
                          "x": 1160,
                          "y": 520,
                          "wires": []
                          "type": "delay",
                          "name": "verz. 1s",
                          "timeout": "1",
                          "rate": "1",
                          "nbRateUnits": "1",
                          "randomFirst": "1",
                          "randomLast": "5",
                          "drop": false,
                          "allowrate": false,
                          "outputs": 1,
                          "x": 360,
                          "y": 480,
                          "wires": [
                                  "a9f9b30b4f8999d0"
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "pt": "msg",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 510,
                          "y": 480,
                          "wires": [
                                  "b0410acfcad1b37e"
                          "type": "switch",
                          "name": "Schalter",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 1060,
                          "y": 440,
                          "wires": [
                                  "4d146d05efbc5d35"
                          "duration": "3",
                          "units": "s",
                          "interval": "",
                          "name": "",
                          "x": 1310,
                          "y": 440,
                          "wires": [
                                  "550905a564f09176"
                          "type": "change",
                          "name": "Motion",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "tot": "msg"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 790,
                          "y": 440,
                          "wires": [
                                  "9f0c88dad82d8633"
                          "type": "comment",
                          "info": "",
                          "x": 180,
                          "y": 380,
                          "wires": []
                          "duration": "45",
                          "units": "s",
                          "interval": "",
                          "name": "",
                          "x": 550,
                          "y": 600,
                          "wires": [
                                  "2871643160dfcc7c",
                                  "550905a564f09176"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "payload",
                                  "pt": "msg",
                                  "to": "true",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 390,
                          "y": 600,
                          "wires": [
                                  "302a07cea50da337"
                          "type": "switch",
                          "name": "1000?",
                          "rules": [
                                  "t": "eq",
                                  "v": "1000",
                                  "vt": "num"
                                  "t": "eq",
                                  "v": "",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 210,
                          "y": 620,
                          "wires": [
                                  "bd795708de32c118",
                                  "32b9213c2fe970b0"
                          "type": "switch",
                          "name": "Robi",
                          "property": "BWM",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 1190,
                          "y": 440,
                          "wires": [
                                  "c1952bc66da5a348"
                          "type": "change",
                          "name": "",
                          "rules": [
                                  "t": "set",
                                  "p": "stopp",
                                  "pt": "flow",
                                  "to": "true",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 380,
                          "y": 640,
                          "wires": [
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "stopp",
                                  "pt": "flow",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 830,
                          "y": 640,
                          "wires": [
                          "type": "switch",
                          "name": "",
                          "property": "payload",
                          "propertyType": "msg",
                          "rules": [
                                  "t": "eq",
                                  "v": "1000",
                                  "vt": "num"
                                  "t": "eq",
                                  "v": "",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 670,
                          "y": 620,
                          "wires": [
                                  "0439088d7ec73749"
                          "type": "function",
                          "outputs": 1,
                          "timeout": 0,
                          "noerr": 0,
                          "finalize": "",
                          "libs": [],
                          "x": 910,
                          "y": 560,
                          "wires": [
                                  "d1f2c8393ea7f683",
                                  "e2721e4056e942e3"
                          "name": "Robi",
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 90,
                          "y": 720,
                          "wires": [
                                  "b2f36db79c165583"
                          "type": "function",
                          "name": "Out BWM",
                          "outputs": 1,
                          "timeout": 0,
                          "noerr": 0,
                          "initialize": "",
                          "finalize": "",
                          "libs": [],
                          "x": 660,
                          "y": 440,
                          "wires": [
                                  "6adb99e531920623"
                          "ack": "false",
                          "stateName": "",
                          "role": "",
                          "payloadType": "",
                          "readonly": "",
                          "stateUnit": "",
                          "stateMin": "",
                          "stateMax": "",
                          "x": 1160,
                          "y": 560,
                          "wires": []
                          "onlyack": "",
                          "func": "all",
                          "gap": "",
                          "x": 80,
                          "y": 620,
                          "wires": [
                                  "d1051390faa881a3"
                          "type": "switch",
                          "name": "",
                          "rules": [
                                  "t": "eq",
                                  "v": "5",
                                  "vt": "num"
                                  "t": "neq",
                                  "v": "5",
                                  "vt": "num"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 290,
                          "y": 720,
                          "wires": [
                                  "407e2e376c0ee370"
                                  "5061312f43733426"
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "BWM",
                                  "pt": "flow",
                                  "to": "true",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 470,
                          "y": 700,
                          "wires": [
                                  "0650a4ab7aec40a1"
                          "type": "change",
                          "rules": [
                                  "t": "set",
                                  "p": "BWM",
                                  "pt": "flow",
                                  "to": "false",
                                  "tot": "bool"
                          "action": "",
                          "property": "",
                          "from": "",
                          "to": "",
                          "reg": false,
                          "x": 470,
                          "y": 740,
                          "wires": [
                                  "0650a4ab7aec40a1"
                          "type": "comment",
                          "info": "",
                          "x": 900,
                          "y": 380,
                          "wires": []
                          "type": "switch",
                          "name": "nur true",
                          "rules": [
                                  "t": "true"
                                  "t": "false"
                          "checkall": "true",
                          "repair": false,
                          "outputs": 2,
                          "x": 920,
                          "y": 440,
                          "wires": [
                                  "7a509a8587332f14"
                          "type": "debug",
                          "name": "debug 4",
                          "active": true,
                          "tosidebar": true,
                          "console": false,
                          "tostatus": false,
                          "complete": "true",
                          "statusVal": "",
                          "statusType": "auto",
                          "x": 640,
                          "y": 720,
                          "wires": []
                          "type": "comment",
                          "info": "",
                          "x": 180,
                          "y": 560,
                          "wires": []
                          "name": "Hue",
                          "x": 90,
                          "y": 440,
                          "wires": [
                                  "b6564cd395bbd771"
                          "name": "KüMo",
                          "x": 230,
                          "y": 440,
                          "wires": [
                                  "b0410acfcad1b37e",
                                  "8bf1e5067a6f0ad2"
                          "worker": "10",
                  peterfido
                  @aphofis Das ist ein wichtige Info, die am Anfang der Aufgabenstellung gut gewesen wäre. Dann muss der Timeout Baustein gegen einen, welcher sich zurücksetzen lässt, ersetzt werden. z.B. myTimeout.
                  Edit: Die 45 Minuten sind jetzt wofür?
                  Peterfido
                  • AphofisA Aphofis
                    @peterfido
                    Das funktioniert.
                            "type": "tab",
                            "label": "Küche",
                            "disabled": false,
                            "info": "",
                            "env": []
                            "type": "junction",
                            "x": 1160,
                            "y": 360,
                            "wires": [
                                    "138c91dc2bbc1ae3",
                                    "8d88b2a94c9ec76d",
                                    "687c7e27683f7c5c",
                                    "5f54b4987a5f8dd2",
                                    "a54734800b81342e"
                            "name": "Switch 2",
                            "attrname": "payload",
                            "payloadType": "value",
                            "x": 940,
                            "y": 460,
                            "wires": [
                                    "5f856636064395a8"
                            "type": "change",
                            "name": "toggle",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1070,
                            "y": 460,
                            "wires": [
                                    "167c3d9534071cfb",
                                    "266f45298fe39781"
                            "type": "ioBroker out",
                            "ack": "false",
                            "autoCreate": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1320,
                            "y": 520,
                            "wires": []
                            "name": "Switch 3",
                            "x": 940,
                            "y": 580,
                            "wires": [
                                    "5c2fda12ba92680a"
                            "type": "change",
                            "name": "toggle",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1070,
                            "y": 580,
                            "wires": [
                                    "8be32882ca318f17",
                                    "3e09ac32ae810712"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1320,
                            "y": 640,
                            "wires": []
                            "name": "Switch 1",
                            "x": 940,
                            "y": 360,
                            "wires": [
                                    "c2ccf4efb123db4a"
                            "type": "change",
                            "name": "toggle",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1070,
                            "y": 360,
                            "wires": [
                                    "a9a291ef92812c32"
                            "name": "U-rechts",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1430,
                            "y": 300,
                            "wires": []
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1430,
                            "y": 180,
                            "wires": []
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "eq",
                                    "v": "1000",
                                    "vt": "str"
                                    "t": "eq",
                                    "v": "2000",
                                    "vt": "str"
                                    "t": "eq",
                                    "v": "3000",
                                    "vt": "str"
                                    "t": "eq",
                                    "v": "4000",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 4,
                            "x": 590,
                            "y": 420,
                            "wires": [
                                    "f17ddf70f0e3a462"
                                    "18138896535a8b98"
                                    "b060108e3005d932"
                                    "26451af092a50c2a"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1320,
                            "y": 240,
                            "wires": []
                            "type": "ioBroker in",
                            "d": true,
                            "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
                            "onlyack": "",
                            "func": "rbe",
                            "gap": "",
                            "fireOnStart": "false",
                            "outFormat": "MQTT",
                            "x": 360,
                            "y": 480,
                            "wires": [
                                    "492203889ad083cc"
                            "type": "ioBroker get",
                            "name": "Switch 4",
                            "errOnInvalidState": "nothing",
                            "x": 940,
                            "y": 700,
                            "wires": [
                                    "7990f93a2f6d4246"
                            "type": "change",
                            "name": "toggle",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "jsonata"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1070,
                            "y": 700,
                            "wires": [
                                    "bf03dbcaedeac1bf",
                                    "974fbea0a2bec958"
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1300,
                            "y": 760,
                            "wires": []
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "true",
                            "x": 230,
                            "y": 420,
                            "wires": [
                                    "708b9446e314ce9a"
                            "type": "link in",
                            "links": [
                                "ad266b7267edaa39"
                            "x": 185,
                            "y": 360,
                            "wires": [
                                    "9bfe6974c0049dcc"
                            "type": "change",
                            "name": "on/off",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "on",
                                    "fromt": "str",
                                    "to": "1002",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 430,
                            "y": 360,
                            "wires": [
                                    "492203889ad083cc"
                            "x": 290,
                            "y": 360,
                            "wires": [
                                    "bacc098ce38ea437"
                            "name": "",
                            "x": 370,
                            "y": 540,
                            "wires": [
                                    "492203889ad083cc"
                            "type": "debug",
                            "name": "Küche",
                            "active": true,
                            "tosidebar": true,
                            "console": true,
                            "tostatus": false,
                            "complete": "payload",
                            "targetType": "msg",
                            "statusVal": "",
                            "x": 1420,
                            "y": 420,
                            "wires": []
                            "x": 1450,
                            "y": 360,
                            "wires": [
                            "type": "trigger",
                            "op1": "1000",
                            "op2": "1002",
                            "op1type": "str",
                            "op2type": "str",
                            "duration": "200",
                            "extend": false,
                            "units": "ms",
                            "reset": "",
                            "bytopic": "all",
                            "topic": "topic",
                            "outputs": 1,
                            "x": 370,
                            "y": 420,
                            "wires": [
                                    "492203889ad083cc"
                            "x": 1330,
                            "y": 700,
                            "wires": [
                            "type": "delay",
                            "name": "230ms",
                            "pauseType": "delay",
                            "timeout": "230",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "rateUnits": "second",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "randomUnits": "seconds",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 1290,
                            "y": 360,
                            "wires": [
                                    "de121f3c399ed6d5"
                            "x": 1340,
                            "y": 580,
                            "wires": [
                            "x": 1330,
                            "y": 460,
                            "wires": [
                            "type": "delay",
                            "name": "230ms",
                            "timeout": "230",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 1290,
                            "y": 300,
                            "wires": [
                                    "0d321e0ed699fec1"
                            "type": "delay",
                            "name": "100ms",
                            "timeout": "100",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 1290,
                            "y": 180,
                            "wires": [
                                    "589ac75a5e32f1d9"
                            "type": "delay",
                            "name": "100ms",
                            "timeout": "100",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 810,
                            "y": 360,
                            "wires": [
                                    "bffd16b00cfde14d"
                            "type": "delay",
                            "name": "100ms",
                            "timeout": "100",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 810,
                            "y": 580,
                            "wires": [
                                    "f4b15ec716491f99"
                            "type": "delay",
                            "name": "100ms",
                            "timeout": "100",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 810,
                            "y": 700,
                            "wires": [
                                    "a258cc2e98284972"
                            "type": "delay",
                            "name": "100ms",
                            "timeout": "100",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 810,
                            "y": 460,
                            "wires": [
                                    "202c49953d235813"
                            "type": "change",
                            "name": "Küche",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "1002",
                                    "fromt": "str",
                                    "to": "Küche",
                                    "tot": "str"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "true",
                                    "fromt": "bool",
                                    "tot": "str"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "false",
                                    "fromt": "bool",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1290,
                            "y": 420,
                            "wires": [
                                    "98ee3d8530b8677f"
                            "type": "trigger",
                            "op1": "2000",
                            "op2": "2002",
                            "op1type": "str",
                            "op2type": "str",
                            "duration": "200",
                            "extend": false,
                            "units": "ms",
                            "reset": "",
                            "bytopic": "all",
                            "topic": "topic",
                            "outputs": 1,
                            "x": 350,
                            "y": 680,
                            "wires": [
                                    "492203889ad083cc"
                            "type": "trigger",
                            "op1": "3000",
                            "op2": "3002",
                            "op1type": "str",
                            "op2type": "str",
                            "duration": "200",
                            "extend": false,
                            "units": "ms",
                            "reset": "",
                            "bytopic": "all",
                            "topic": "topic",
                            "outputs": 1,
                            "x": 350,
                            "y": 720,
                            "wires": [
                                    "492203889ad083cc"
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "true",
                            "x": 210,
                            "y": 680,
                            "wires": [
                                    "cc4b3f317dc6949d"
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "true",
                            "x": 210,
                            "y": 720,
                            "wires": [
                                    "58080c269d40839f"
                            "type": "trigger",
                            "op1": "4000",
                            "op2": "4002",
                            "op1type": "str",
                            "op2type": "str",
                            "duration": "200",
                            "extend": false,
                            "units": "ms",
                            "reset": "",
                            "bytopic": "all",
                            "topic": "topic",
                            "outputs": 1,
                            "x": 350,
                            "y": 760,
                            "wires": [
                                    "492203889ad083cc"
                            "type": "inject",
                            "name": "",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "true",
                            "x": 210,
                            "y": 760,
                            "wires": [
                                    "e2b5712b17f86c31"
                            "worker": "10",
                            "type": "tab",
                            "label": "Flow 8",
                            "disabled": false,
                            "info": "",
                            "env": []
                            "type": "debug",
                            "name": "debug 3",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "true",
                            "statusVal": "",
                            "x": 1160,
                            "y": 520,
                            "wires": []
                            "type": "delay",
                            "name": "verz. 1s",
                            "timeout": "1",
                            "timeoutUnits": "seconds",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 360,
                            "y": 480,
                            "wires": [
                                    "a9f9b30b4f8999d0"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "payload.motion",
                                    "pt": "msg",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 510,
                            "y": 480,
                            "wires": [
                                    "b0410acfcad1b37e"
                            "type": "switch",
                            "name": "Schalter",
                            "property": "stopp",
                            "propertyType": "flow",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 1060,
                            "y": 440,
                            "wires": [
                                    "4d146d05efbc5d35"
                            "type": "timeouttrigger",
                            "OnTimeoutType": "bool",
                            "OnTimeoutVal": "false",
                            "duration": "3",
                            "units": "s",
                            "passthrough": true,
                            "sendTimeoutValue": "once",
                            "interval": "",
                            "IntervalUnits": "s",
                            "name": "",
                            "x": 1310,
                            "y": 440,
                            "wires": [
                                    "550905a564f09176"
                            "type": "change",
                            "name": "Motion",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "payload.motion",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 790,
                            "y": 440,
                            "wires": [
                                    "9f0c88dad82d8633"
                            "type": "comment",
                            "info": "",
                            "x": 180,
                            "y": 380,
                            "wires": []
                            "duration": "45",
                            "units": "s",
                            "interval": "",
                            "name": "",
                            "x": 550,
                            "y": 600,
                            "wires": [
                                    "2871643160dfcc7c",
                                    "550905a564f09176"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 390,
                            "y": 600,
                            "wires": [
                                    "302a07cea50da337"
                            "type": "switch",
                            "name": "1000?",
                            "rules": [
                                    "t": "eq",
                                    "v": "1000",
                                    "vt": "num"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 210,
                            "y": 620,
                            "wires": [
                                    "bd795708de32c118",
                                    "32b9213c2fe970b0"
                            "type": "switch",
                            "name": "Robi",
                            "property": "BWM",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 1190,
                            "y": 440,
                            "wires": [
                                    "c1952bc66da5a348"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "stopp",
                                    "pt": "flow",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 380,
                            "y": 640,
                            "wires": [
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "stopp",
                                    "pt": "flow",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 830,
                            "y": 640,
                            "wires": [
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "eq",
                                    "v": "1000",
                                    "vt": "num"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 670,
                            "y": 620,
                            "wires": [
                                    "0439088d7ec73749"
                            "type": "function",
                            "func": "node.status({ text: msg.payload });\n\nreturn msg;",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "finalize": "",
                            "libs": [],
                            "x": 910,
                            "y": 560,
                            "wires": [
                                    "d1f2c8393ea7f683",
                                    "e2721e4056e942e3"
                            "name": "Robi",
                            "topic": "0_userdata.0.GordonX-Home.0.Test_Status_Robi",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 90,
                            "y": 720,
                            "wires": [
                                    "b2f36db79c165583"
                            "type": "function",
                            "name": "Out BWM",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "initialize": "",
                            "finalize": "",
                            "libs": [],
                            "x": 660,
                            "y": 440,
                            "wires": [
                                    "6adb99e531920623"
                            "topic": "0_userdata.0.GordonX-Home.0.Test_Gerät",
                            "ack": "false",
                            "stateName": "",
                            "role": "",
                            "payloadType": "",
                            "readonly": "",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1160,
                            "y": 560,
                            "wires": []
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 80,
                            "y": 620,
                            "wires": [
                                    "d1051390faa881a3"
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "eq",
                                    "v": "5",
                                    "vt": "num"
                                    "t": "neq",
                                    "v": "5",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 290,
                            "y": 720,
                            "wires": [
                                    "407e2e376c0ee370"
                                    "5061312f43733426"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "BWM",
                                    "pt": "flow",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 470,
                            "y": 700,
                            "wires": [
                                    "0650a4ab7aec40a1"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "BWM",
                                    "pt": "flow",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 470,
                            "y": 740,
                            "wires": [
                                    "0650a4ab7aec40a1"
                            "type": "comment",
                            "info": "",
                            "x": 900,
                            "y": 380,
                            "wires": []
                            "type": "switch",
                            "name": "nur true",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 920,
                            "y": 440,
                            "wires": [
                                    "7a509a8587332f14"
                            "type": "debug",
                            "name": "debug 4",
                            "active": true,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "true",
                            "statusVal": "",
                            "x": 640,
                            "y": 720,
                            "wires": []
                            "type": "comment",
                            "info": "",
                            "x": 180,
                            "y": 560,
                            "wires": []
                            "name": "Hue",
                            "x": 90,
                            "y": 440,
                            "wires": [
                                    "b6564cd395bbd771"
                            "name": "KüMo",
                            "x": 230,
                            "y": 440,
                            "wires": [
                                    "b0410acfcad1b37e",
                                    "8bf1e5067a6f0ad2"
                            "worker": "10",
                    peterfido
                    @aphofis mit myTimeout könnte das so aussehen.
                    Mehr mag ich auf dem Mäusekino nicht probieren, zumal Samsung oder Google die Stiftbedienung seit einigen Updates vermurkst haben.
                            "type": "tab",
                            "label": "Flow 8",
                            "disabled": false,
                            "info": "",
                            "env": []
                            "type": "inject",
                            "props": [
                                    "v": "true",
                                    "vt": "bool"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "x": 120,
                            "y": 60,
                            "wires": [
                                    "8bf1e5067a6f0ad2",
                                    "b0410acfcad1b37e"
                            "type": "debug",
                            "name": "debug 3",
                            "active": false,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "true",
                            "statusVal": "",
                            "x": 1640,
                            "y": 180,
                            "wires": []
                            "type": "delay",
                            "name": "",
                            "timeout": "1",
                            "rate": "1",
                            "nbRateUnits": "1",
                            "randomFirst": "1",
                            "randomLast": "5",
                            "drop": false,
                            "allowrate": false,
                            "outputs": 1,
                            "x": 120,
                            "y": 120,
                            "wires": [
                                    "a9f9b30b4f8999d0"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "pt": "msg",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 170,
                            "y": 160,
                            "wires": [
                                    "b0410acfcad1b37e"
                            "type": "switch",
                            "name": "Schalter",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 820,
                            "y": 80,
                            "wires": [
                                    "4d146d05efbc5d35"
                            "type": "change",
                            "name": "Motion",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "tot": "msg"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 500,
                            "y": 60,
                            "wires": [
                                    "9f0c88dad82d8633"
                            "type": "comment",
                            "info": "",
                            "x": 220,
                            "y": 20,
                            "wires": []
                            "type": "inject",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "payload": "1000",
                            "payloadType": "num",
                            "x": 120,
                            "y": 280,
                            "wires": [
                                    "d1051390faa881a3"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "on",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 570,
                            "y": 200,
                            "wires": [
                                    "a6a847c390a23b20"
                            "type": "switch",
                            "name": "1000?",
                            "rules": [
                                    "t": "eq",
                                    "v": "1000",
                                    "vt": "num"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 290,
                            "y": 300,
                            "wires": [
                                    "91fb51e7bf3d65f7"
                            "type": "switch",
                            "name": "Robi",
                            "property": "BWM",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 950,
                            "y": 80,
                            "wires": [
                                    "9cf97a8724bea369"
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "stopp",
                                    "pt": "flow",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 820,
                            "y": 300,
                            "wires": [
                            "type": "change",
                            "name": "löscheflow.stopp",
                            "rules": [
                                    "t": "set",
                                    "p": "stopp",
                                    "pt": "flow",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1330,
                            "y": 340,
                            "wires": [
                            "type": "function",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "finalize": "",
                            "libs": [],
                            "x": 1490,
                            "y": 260,
                            "wires": [
                                    "d1f2c8393ea7f683",
                                    "e2721e4056e942e3"
                            "name": "ioB Robi",
                            "topic": "*",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 120,
                            "y": 560,
                            "wires": [
                                    "b2f36db79c165583"
                            "type": "function",
                            "outputs": 1,
                            "timeout": 0,
                            "noerr": 0,
                            "initialize": "",
                            "finalize": "",
                            "libs": [],
                            "x": 320,
                            "y": 60,
                            "wires": [
                                    "6adb99e531920623"
                            "topic": "0_userdata.0.tests.Lampekueche",
                            "ack": "false",
                            "autoCreate": "true",
                            "stateName": "Lampe_Kueche",
                            "role": "light",
                            "payloadType": "boolean",
                            "readonly": "false",
                            "stateUnit": "",
                            "stateMin": "",
                            "stateMax": "",
                            "x": 1720,
                            "y": 300,
                            "wires": []
                            "topic": "*",
                            "onlyack": "",
                            "func": "all",
                            "gap": "",
                            "x": 110,
                            "y": 320,
                            "wires": [
                                    "d1051390faa881a3"
                            "type": "inject",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "5",
                            "x": 130,
                            "y": 440,
                            "wires": [
                                    "b2f36db79c165583"
                            "type": "inject",
                            "props": [
                                    "p": "payload"
                                    "p": "topic",
                                    "vt": "str"
                            "repeat": "",
                            "crontab": "",
                            "once": false,
                            "onceDelay": 0.1,
                            "topic": "",
                            "payload": "6",
                            "x": 130,
                            "y": 500,
                            "wires": [
                                    "b2f36db79c165583"
                            "type": "switch",
                            "name": "5?",
                            "rules": [
                                    "t": "eq",
                                    "v": "5",
                                    "vt": "num"
                                    "t": "neq",
                                    "v": "5",
                                    "vt": "num"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 310,
                            "y": 500,
                            "wires": [
                                    "407e2e376c0ee370"
                                    "5061312f43733426"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "BWM",
                                    "pt": "flow",
                                    "to": "true",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 680,
                            "y": 480,
                            "wires": [
                                    "0650a4ab7aec40a1"
                            "type": "change",
                            "rules": [
                                    "t": "set",
                                    "p": "BWM",
                                    "pt": "flow",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 690,
                            "y": 520,
                            "wires": [
                                    "0650a4ab7aec40a1"
                            "type": "comment",
                            "info": "",
                            "x": 880,
                            "y": 40,
                            "wires": []
                            "type": "switch",
                            "name": "nur true",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 640,
                            "y": 80,
                            "wires": [
                                    "7a509a8587332f14"
                            "type": "debug",
                            "name": "debug 4",
                            "active": false,
                            "tosidebar": true,
                            "console": false,
                            "tostatus": false,
                            "complete": "true",
                            "statusVal": "",
                            "x": 900,
                            "y": 500,
                            "wires": []
                            "type": "comment",
                            "info": "",
                            "x": 220,
                            "y": 220,
                            "wires": []
                            "id": "a6a847c390a23b20",
                            "type": "mytimeout",
                            "name": "45 sec",
                            "outtopic": "",
                            "outsafe": "on",
                            "outwarning": "Warning",
                            "outunsafe": "off",
                            "warning": "5",
                            "timer": "45",
                            "debug": false,
                            "ndebug": false,
                            "ignoreCase": false,
                            "repeat": false,
                            "again": false,
                            "x": 730,
                            "y": 180,
                            "wires": [
                                    "25e12cdd5eeefe18"
                            "id": "442af76f7b9f1d0a",
                            "name": "3 sec",
                            "outtopic": "",
                            "outsafe": "on",
                            "outunsafe": "off",
                            "warning": "1",
                            "timer": "3",
                            "debug": false,
                            "ndebug": false,
                            "repeat": false,
                            "again": false,
                            "x": 1290,
                            "y": 120,
                            "wires": [
                                    "01e10f79b058e94d"
                            "id": "25e12cdd5eeefe18",
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "on",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "off",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 890,
                            "y": 180,
                            "wires": [
                                    "d5e9baf2e985c341"
                            "id": "d5e9baf2e985c341",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 3,
                            "x": 1150,
                            "y": 260,
                            "wires": [
                                    "550905a564f09176"
                                    "550905a564f09176",
                                    "0439088d7ec73749"
                            "id": "d7c7e0bfb963466c",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "true"
                                    "t": "false"
                                    "t": "eq",
                                    "v": "",
                                    "vt": "str"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 3,
                            "x": 1550,
                            "y": 40,
                            "wires": [
                                    "550905a564f09176"
                                    "550905a564f09176"
                            "id": "01e10f79b058e94d",
                            "type": "change",
                            "name": "",
                            "rules": [
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "on",
                                    "fromt": "str",
                                    "to": "true",
                                    "tot": "bool"
                                    "t": "change",
                                    "p": "payload",
                                    "pt": "msg",
                                    "from": "off",
                                    "fromt": "str",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1370,
                            "y": 40,
                            "wires": [
                                    "d7c7e0bfb963466c"
                            "id": "9cf97a8724bea369",
                            "type": "change",
                            "z": "a42b83181f07f8d0",
                            "name": "",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "on",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 1130,
                            "y": 80,
                            "wires": [
                                    "442af76f7b9f1d0a"
                            "id": "91fb51e7bf3d65f7",
                            "name": "Lampe ist?",
                            "x": 430,
                            "y": 300,
                            "wires": [
                                    "e1bc32d82926ab1a"
                            "id": "e1bc32d82926ab1a",
                            "type": "switch",
                            "name": "",
                            "rules": [
                                    "t": "false"
                                    "t": "true"
                            "checkall": "true",
                            "repair": false,
                            "outputs": 2,
                            "x": 570,
                            "y": 360,
                            "wires": [
                                    "32b9213c2fe970b0",
                                    "bd795708de32c118"
                                    "407e2e376c0ee370",
                                    "0439088d7ec73749",
                                    "f8efa184517f5926",
                                    "5ff36fd59f9b86a7"
                            "id": "f8efa184517f5926",
                            "type": "change",
                            "name": "Alles auf Anfang",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "false",
                                    "tot": "bool"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 880,
                            "y": 420,
                            "wires": [
                                    "550905a564f09176"
                            "id": "5ff36fd59f9b86a7",
                            "type": "change",
                            "name": "stop",
                            "rules": [
                                    "t": "set",
                                    "p": "payload",
                                    "pt": "msg",
                                    "to": "stop",
                                    "tot": "str"
                            "action": "",
                            "property": "",
                            "from": "",
                            "to": "",
                            "reg": false,
                            "x": 650,
                            "y": 260,
                            "wires": [
                                    "a6a847c390a23b20",
                                    "442af76f7b9f1d0a"
                    Daher bitte selbst probieren und tüfteln, falls was nicht so läuft, wie gewollt.
                    Peterfido
                    AphofisA 2 Antworten Letzte Antwort
                    • P peterfido
                      AphofisA Offline
                      AphofisA Offline
                      Aphofis
                      @peterfido
                      Also vielleicht mal die ganze Steuerung
                      Philips Hue Schalter schaltet nur 1000/2000/3000/4000
                      Dieses wird per virtuellen Schaltern realisiert
                      Damit das überhaupt klappt mit an aus mit einem Befehl
                      Sprich Schalter hat nicht true/false sondern nur 1000
                      Wobei der Wert nach 200ms ca umschaltet auf 1002 was aber ignoriert wird.
                      Die anderen drei Button werden für andere hue Lampen genutzt.
                      Die Bewegungsmelder sollen die küchenbeleuchtung einschalten und nach 3 min. Ausschalten ist der Roboter unterwegs sprich nicht auf der ladestation sollen die BWM abgeschaltet werden. Wenn ich den Lichtschalter betätige soll dieser nach 45 min. Abgeschaltet werden sollte ich das Licht mal vergessen.
                      Ist schon im Bad passiert und ist ja unnötig Strom Verbrauch. Weil wenn ich den Lichtschalter benutze soll das Licht schon an bleiben. Wäre nicht nötig wenn der BWM bei Wiederbewegung funktionieren würde
                      Dazu muss denke ich aber die True/false Schaltung
                      Träge gemacht werden. Dann würde die 45 min. Schaltung unnötig
                      • P peterfido
                                "id": "a42b83181f07f8d0",
                                "type": "tab",
                                "label": "Flow 8",
                                "disabled": false,
                                "info": "",
                                "env": []
                                "id": "1c8c0acba7c2bff2",
                                "type": "inject",
                                "name": "Test Bewegung",
                                "props": [
                                        "v": "true",
                                        "vt": "bool"
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "Bewegungsmelder",
                                "x": 120,
                                "y": 60,
                                "wires": [
                                        "8bf1e5067a6f0ad2",
                                        "b0410acfcad1b37e"
                                "id": "d1f2c8393ea7f683",
                                "type": "debug",
                                "name": "debug 3",
                                "active": false,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "targetType": "full",
                                "statusVal": "",
                                "x": 1640,
                                "y": 180,
                                "wires": []
                                "id": "8bf1e5067a6f0ad2",
                                "type": "delay",
                                "name": "",
                                "timeout": "1",
                                "rate": "1",
                                "nbRateUnits": "1",
                                "randomFirst": "1",
                                "randomLast": "5",
                                "drop": false,
                                "allowrate": false,
                                "outputs": 1,
                                "x": 120,
                                "y": 120,
                                "wires": [
                                        "a9f9b30b4f8999d0"
                                "id": "a9f9b30b4f8999d0",
                                "type": "change",
                                "name": "motion:false",
                                "rules": [
                                        "t": "set",
                                        "pt": "msg",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 170,
                                "y": 160,
                                "wires": [
                                        "b0410acfcad1b37e"
                                "id": "7a509a8587332f14",
                                "type": "switch",
                                "name": "Schalter",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 820,
                                "y": 80,
                                "wires": [
                                        "4d146d05efbc5d35"
                                "id": "6adb99e531920623",
                                "type": "change",
                                "name": "Motion",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "tot": "msg"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 500,
                                "y": 60,
                                "wires": [
                                        "9f0c88dad82d8633"
                                "id": "9f83e7917ef2d8e2",
                                "type": "comment",
                                "name": "<< Bewegungsmelder |||||||||||||| Simulator  Beginn>>",
                                "info": "",
                                "x": 220,
                                "y": 20,
                                "wires": []
                                "id": "0762e0ad3da83f0d",
                                "type": "inject",
                                "name": "Test 1000",
                                "props": [
                                        "p": "payload"
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "Schalter_1000",
                                "payload": "1000",
                                "x": 120,
                                "y": 280,
                                "wires": [
                                        "d1051390faa881a3"
                                "id": "bd795708de32c118",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "on",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 570,
                                "y": 200,
                                "wires": [
                                        "a6a847c390a23b20"
                                "id": "d1051390faa881a3",
                                "type": "switch",
                                "name": "1000?",
                                "rules": [
                                        "t": "eq",
                                        "v": "1000",
                                        "vt": "num"
                                        "t": "eq",
                                        "v": "",
                                        "vt": "num"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 290,
                                "y": 300,
                                "wires": [
                                        "91fb51e7bf3d65f7"
                                "id": "4d146d05efbc5d35",
                                "type": "switch",
                                "name": "Robi",
                                "property": "BWM",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 950,
                                "y": 80,
                                "wires": [
                                        "9cf97a8724bea369"
                                "id": "32b9213c2fe970b0",
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "stopp",
                                        "pt": "flow",
                                        "to": "true",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 820,
                                "y": 300,
                                "wires": [
                                "id": "0439088d7ec73749",
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "p": "stopp",
                                        "pt": "flow",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 1330,
                                "y": 340,
                                "wires": [
                                "id": "550905a564f09176",
                                "type": "function",
                                "name": "Variablen Ini + Ausgabe",
                                "outputs": 1,
                                "timeout": 0,
                                "noerr": 0,
                                "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
                                "finalize": "",
                                "libs": [],
                                "x": 1490,
                                "y": 260,
                                "wires": [
                                        "d1f2c8393ea7f683",
                                        "e2721e4056e942e3"
                                "id": "d7bd1efc606cfcad",
                                "name": "ioB Robi",
                                "topic": "*",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 120,
                                "y": 560,
                                "wires": [
                                        "b2f36db79c165583"
                                "id": "b0410acfcad1b37e",
                                "type": "function",
                                "name": "Ausgang BWM",
                                "func": "\nreturn msg;",
                                "outputs": 1,
                                "timeout": 0,
                                "noerr": 0,
                                "initialize": "",
                                "finalize": "",
                                "libs": [],
                                "x": 320,
                                "y": 60,
                                "wires": [
                                        "6adb99e531920623"
                                "id": "e2721e4056e942e3",
                                "name": "ioBroker Lampe",
                                "ack": "false",
                                "role": "light",
                                "stateUnit": "",
                                "stateMin": "",
                                "stateMax": "",
                                "x": 1720,
                                "y": 300,
                                "wires": []
                                "id": "7cfd7f7fba2e2d7a",
                                "name": "ioB Schalter",
                                "topic": "*",
                                "onlyack": "",
                                "func": "all",
                                "gap": "",
                                "x": 110,
                                "y": 320,
                                "wires": [
                                        "d1051390faa881a3"
                                "id": "91ef09f531fcc27b",
                                "type": "inject",
                                "name": "Test Robi = 5",
                                "props": [
                                        "p": "payload"
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "",
                                "payload": "5",
                                "x": 130,
                                "y": 440,
                                "wires": [
                                        "b2f36db79c165583"
                                "id": "6db2cc2617ad5707",
                                "type": "inject",
                                "name": "Test Robi <> 5",
                                "props": [
                                        "p": "payload"
                                        "p": "topic",
                                        "vt": "str"
                                "repeat": "",
                                "crontab": "",
                                "once": false,
                                "onceDelay": 0.1,
                                "topic": "",
                                "payload": "6",
                                "x": 130,
                                "y": 500,
                                "wires": [
                                        "b2f36db79c165583"
                                "id": "b2f36db79c165583",
                                "type": "switch",
                                "name": "5?",
                                "rules": [
                                        "t": "eq",
                                        "v": "5",
                                        "vt": "num"
                                        "t": "neq",
                                        "v": "5",
                                        "vt": "num"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 310,
                                "y": 500,
                                "wires": [
                                        "407e2e376c0ee370"
                                        "5061312f43733426"
                                "id": "407e2e376c0ee370",
                                "type": "change",
                                "name": "setze Flow.BWM",
                                "rules": [
                                        "t": "set",
                                        "p": "BWM",
                                        "pt": "flow",
                                        "to": "true",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 680,
                                "y": 480,
                                "wires": [
                                        "0650a4ab7aec40a1"
                                "id": "5061312f43733426",
                                "type": "change",
                                "name": "lösche Flow.BWM",
                                "rules": [
                                        "t": "set",
                                        "p": "BWM",
                                        "pt": "flow",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 690,
                                "y": 520,
                                "wires": [
                                        "0650a4ab7aec40a1"
                                "id": "879b9060efcd163b",
                                "type": "comment",
                                "name": "evtl. gesperrt durch??",
                                "info": "",
                                "x": 880,
                                "y": 40,
                                "wires": []
                                "id": "9f0c88dad82d8633",
                                "type": "switch",
                                "name": "nur true",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 640,
                                "y": 80,
                                "wires": [
                                        "7a509a8587332f14"
                                "id": "0650a4ab7aec40a1",
                                "type": "debug",
                                "name": "debug 4",
                                "active": false,
                                "tosidebar": true,
                                "console": false,
                                "tostatus": false,
                                "complete": "true",
                                "statusVal": "",
                                "x": 900,
                                "y": 500,
                                "wires": []
                                "id": "f144b6f8b998c7f5",
                                "type": "comment",
                                "name": "<< Bewegungsmelder |||||||||||||| Simulator Ende >>",
                                "info": "",
                                "x": 220,
                                "y": 220,
                                "wires": []
                                "name": "45 sec",
                                "outtopic": "",
                                "outsafe": "on",
                                "outunsafe": "off",
                                "warning": "5",
                                "timer": "45",
                                "debug": false,
                                "ndebug": false,
                                "repeat": false,
                                "again": false,
                                "x": 730,
                                "y": 180,
                                "wires": [
                                        "25e12cdd5eeefe18"
                                "name": "3 sec",
                                "outtopic": "",
                                "outsafe": "on",
                                "outunsafe": "off",
                                "warning": "1",
                                "timer": "3",
                                "debug": false,
                                "ndebug": false,
                                "repeat": false,
                                "again": false,
                                "x": 1290,
                                "y": 120,
                                "wires": [
                                        "01e10f79b058e94d"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "on",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "off",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 890,
                                "y": 180,
                                "wires": [
                                        "d5e9baf2e985c341"
                                "type": "switch",
                                "name": "",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                        "t": "eq",
                                        "v": "",
                                        "vt": "str"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 3,
                                "x": 1150,
                                "y": 260,
                                "wires": [
                                        "550905a564f09176"
                                        "550905a564f09176",
                                        "0439088d7ec73749"
                                "type": "switch",
                                "name": "",
                                "rules": [
                                        "t": "true"
                                        "t": "false"
                                        "t": "eq",
                                        "v": "",
                                        "vt": "str"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 3,
                                "x": 1550,
                                "y": 40,
                                "wires": [
                                        "550905a564f09176"
                                        "550905a564f09176"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "on",
                                        "fromt": "str",
                                        "to": "true",
                                        "tot": "bool"
                                        "t": "change",
                                        "p": "payload",
                                        "pt": "msg",
                                        "from": "off",
                                        "fromt": "str",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 1370,
                                "y": 40,
                                "wires": [
                                        "d7c7e0bfb963466c"
                                "type": "change",
                                "name": "",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "on",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 1130,
                                "y": 80,
                                "wires": [
                                        "442af76f7b9f1d0a"
                                "x": 430,
                                "y": 300,
                                "wires": [
                                        "e1bc32d82926ab1a"
                                "type": "switch",
                                "name": "",
                                "rules": [
                                        "t": "false"
                                        "t": "true"
                                "checkall": "true",
                                "repair": false,
                                "outputs": 2,
                                "x": 570,
                                "y": 360,
                                "wires": [
                                        "32b9213c2fe970b0",
                                        "bd795708de32c118"
                                        "407e2e376c0ee370",
                                        "0439088d7ec73749",
                                        "f8efa184517f5926",
                                        "5ff36fd59f9b86a7"
                                "type": "change",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "false",
                                        "tot": "bool"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 880,
                                "y": 420,
                                "wires": [
                                        "550905a564f09176"
                                "type": "change",
                                "name": "stop",
                                "rules": [
                                        "t": "set",
                                        "p": "payload",
                                        "pt": "msg",
                                        "to": "stop",
                                        "tot": "str"
                                "action": "",
                                "property": "",
                                "from": "",
                                "to": "",
                                "reg": false,
                                "x": 650,
                                "y": 260,
                                "wires": [
                                        "a6a847c390a23b20",
                                        "442af76f7b9f1d0a"
                        AphofisA Offline
                        AphofisA Offline
                        Aphofis
                        @peterfido
                        Ich werde tüfteln
                        • P peterfido
                                  "type": "tab",
                                  "label": "Flow 8",
                                  "disabled": false,
                                  "info": "",
                                  "env": []
                                  "type": "inject",
                                  "props": [
                                          "v": "true",
                                          "vt": "bool"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "x": 120,
                                  "y": 60,
                                  "wires": [
                                          "8bf1e5067a6f0ad2",
                                          "b0410acfcad1b37e"
                                  "type": "debug",
                                  "name": "debug 3",
                                  "active": false,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 1640,
                                  "y": 180,
                                  "wires": []
                                  "type": "delay",
                                  "name": "",
                                  "timeout": "1",
                                  "rate": "1",
                                  "nbRateUnits": "1",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "drop": false,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 120,
                                  "y": 120,
                                  "wires": [
                                          "a9f9b30b4f8999d0"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 170,
                                  "y": 160,
                                  "wires": [
                                          "b0410acfcad1b37e"
                                  "type": "switch",
                                  "name": "Schalter",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 820,
                                  "y": 80,
                                  "wires": [
                                          "4d146d05efbc5d35"
                                  "type": "change",
                                  "name": "Motion",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 500,
                                  "y": 60,
                                  "wires": [
                                          "9f0c88dad82d8633"
                                  "type": "comment",
                                  "info": "",
                                  "x": 220,
                                  "y": 20,
                                  "wires": []
                                  "type": "inject",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "payload": "1000",
                                  "x": 120,
                                  "y": 280,
                                  "wires": [
                                          "d1051390faa881a3"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "on",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 570,
                                  "y": 200,
                                  "wires": [
                                          "a6a847c390a23b20"
                                  "type": "switch",
                                  "name": "1000?",
                                  "rules": [
                                          "t": "eq",
                                          "v": "1000",
                                          "vt": "num"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "num"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 290,
                                  "y": 300,
                                  "wires": [
                                          "91fb51e7bf3d65f7"
                                  "type": "switch",
                                  "name": "Robi",
                                  "property": "BWM",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 950,
                                  "y": 80,
                                  "wires": [
                                          "9cf97a8724bea369"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "stopp",
                                          "pt": "flow",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 820,
                                  "y": 300,
                                  "wires": [
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "stopp",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1330,
                                  "y": 340,
                                  "wires": [
                                  "type": "function",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "finalize": "",
                                  "libs": [],
                                  "x": 1490,
                                  "y": 260,
                                  "wires": [
                                          "d1f2c8393ea7f683",
                                          "e2721e4056e942e3"
                                  "name": "ioB Robi",
                                  "topic": "*",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 120,
                                  "y": 560,
                                  "wires": [
                                          "b2f36db79c165583"
                                  "type": "function",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 320,
                                  "y": 60,
                                  "wires": [
                                          "6adb99e531920623"
                                  "ack": "false",
                                  "role": "light",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1720,
                                  "y": 300,
                                  "wires": []
                                  "topic": "*",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 110,
                                  "y": 320,
                                  "wires": [
                                          "d1051390faa881a3"
                                  "type": "inject",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "payload": "5",
                                  "x": 130,
                                  "y": 440,
                                  "wires": [
                                          "b2f36db79c165583"
                                  "type": "inject",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "payload": "6",
                                  "x": 130,
                                  "y": 500,
                                  "wires": [
                                          "b2f36db79c165583"
                                  "type": "switch",
                                  "name": "5?",
                                  "rules": [
                                          "t": "eq",
                                          "v": "5",
                                          "vt": "num"
                                          "t": "neq",
                                          "v": "5",
                                          "vt": "num"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 310,
                                  "y": 500,
                                  "wires": [
                                          "407e2e376c0ee370"
                                          "5061312f43733426"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "BWM",
                                          "pt": "flow",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 680,
                                  "y": 480,
                                  "wires": [
                                          "0650a4ab7aec40a1"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "BWM",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 690,
                                  "y": 520,
                                  "wires": [
                                          "0650a4ab7aec40a1"
                                  "type": "comment",
                                  "info": "",
                                  "x": 880,
                                  "y": 40,
                                  "wires": []
                                  "type": "switch",
                                  "name": "nur true",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 640,
                                  "y": 80,
                                  "wires": [
                                          "7a509a8587332f14"
                                  "type": "debug",
                                  "name": "debug 4",
                                  "active": false,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 900,
                                  "y": 500,
                                  "wires": []
                                  "type": "comment",
                                  "info": "",
                                  "x": 220,
                                  "y": 220,
                                  "wires": []
                                  "name": "45 sec",
                                  "outtopic": "",
                                  "outsafe": "on",
                                  "outunsafe": "off",
                                  "warning": "5",
                                  "timer": "45",
                                  "debug": false,
                                  "ndebug": false,
                                  "repeat": false,
                                  "again": false,
                                  "x": 730,
                                  "y": 180,
                                  "wires": [
                                          "25e12cdd5eeefe18"
                                  "name": "3 sec",
                                  "outtopic": "",
                                  "outsafe": "on",
                                  "outunsafe": "off",
                                  "warning": "1",
                                  "timer": "3",
                                  "debug": false,
                                  "ndebug": false,
                                  "repeat": false,
                                  "again": false,
                                  "x": 1290,
                                  "y": 120,
                                  "wires": [
                                          "01e10f79b058e94d"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "on",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "off",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 890,
                                  "y": 180,
                                  "wires": [
                                          "d5e9baf2e985c341"
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 3,
                                  "x": 1150,
                                  "y": 260,
                                  "wires": [
                                          "550905a564f09176"
                                          "550905a564f09176",
                                          "0439088d7ec73749"
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 3,
                                  "x": 1550,
                                  "y": 40,
                                  "wires": [
                                          "550905a564f09176"
                                          "550905a564f09176"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "on",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "off",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1370,
                                  "y": 40,
                                  "wires": [
                                          "d7c7e0bfb963466c"
                                  "type": "change",
                                  "name": "",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "on",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1130,
                                  "y": 80,
                                  "wires": [
                                          "442af76f7b9f1d0a"
                                  "x": 430,
                                  "y": 300,
                                  "wires": [
                                          "e1bc32d82926ab1a"
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "false"
                                          "t": "true"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 570,
                                  "y": 360,
                                  "wires": [
                                          "32b9213c2fe970b0",
                                          "bd795708de32c118"
                                          "407e2e376c0ee370",
                                          "0439088d7ec73749",
                                          "f8efa184517f5926",
                                          "5ff36fd59f9b86a7"
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 880,
                                  "y": 420,
                                  "wires": [
                                          "550905a564f09176"
                                  "type": "change",
                                  "name": "stop",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "stop",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 650,
                                  "y": 260,
                                  "wires": [
                                          "a6a847c390a23b20",
                                          "442af76f7b9f1d0a"
                          AphofisA Offline
                          AphofisA Offline
                          Aphofis
                          @peterfido
                          Scheint alles zu funktionieren. Nur Wiederbewegung hatte ich noch nicht getestet ob das Licht dann an bleibt oder erstmal aus geht und dann wieder eingeschaltet wird.
                          Aber an sich tolle Steuerung. Wie und wo kann man sowas bloß lernen und dann auch noch auf einem Mäusekino. Ich sage mal Vielen vielen Dank.
                          AphofisA 1 Antwort Letzte Antwort
                          • AphofisA Aphofis
                            @peterfido
                            AphofisA Offline
                            AphofisA Offline
                            Aphofis
                            schrieb am zuletzt editiert von Aphofis
                            So siehts jetzt aus und scheint zu laufen.
                            Wie gesagt bis auf die wiederbewegung klappt nicht.
                            Ganz ehrlich gesagt, ich wüsste nicht mal wo ich da ansetzen soll um die schaltung träge zu machen damit nicht beim BWM auf jedes false zwischen den true reagiert wird sondern wenn keine Ahnung wenn wirklich 10 sek zB. false ist das dann erst ein false gesendet wird
                            Hab jetzt die Steuerung in Küche und Bad integriert und bin so auch erstmal zufrieden. nur die Wiederbewegung ist halt etwas doof das dass nicht klappt. Ist aber in Öffentlichen Toiletten und Restaurants auch so das bei einer Sitzung das Licht einmal aus geht und erst wenn man sich bewegt das Licht wieder an geht. Ganz schlecht ist es nur wenn nicht jedes Klo einen BWM hat und man mit Handy Taschenlampe die Sitzung beenden muss. Da ist es so zumindest schon mal ein Anfang.
                                    "id": "b802892eed83e90f",
                                    "type": "tab",
                                    "label": "Flow 8",
                                    "disabled": false,
                                    "info": "",
                                    "env": []
                                    "id": "f00e20abd94ff43d",
                                    "type": "junction",
                                    "z": "b802892eed83e90f",
                                    "x": 960,
                                    "y": 320,
                                    "wires": [
                                            "141a052859674836",
                                            "574a9f7ddc4f663b"
                                    "id": "423ea0f1dc0e4d31",
                                    "type": "junction",
                                    "x": 1440,
                                    "y": 300,
                                    "wires": [
                                            "ff32f89078260f0e",
                                            "67e2e01a1266d1c3",
                                            "e98816534075b0f5",
                                            "21f36ea2695afe19",
                                            "a695276a00fe8f61"
                                    "id": "a2104cdffd7ca75f",
                                    "type": "inject",
                                    "props": [
                                            "v": "true",
                                            "vt": "bool"
                                            "p": "topic",
                                            "vt": "str"
                                    "repeat": "",
                                    "crontab": "",
                                    "once": false,
                                    "onceDelay": 0.1,
                                    "x": 120,
                                    "y": 60,
                                    "wires": [
                                            "a919a4c30d900c39",
                                            "0150c15cf7b51170"
                                    "id": "ed06e85de97289c8",
                                    "type": "debug",
                                    "name": "debug 3",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1620,
                                    "y": 140,
                                    "wires": []
                                    "id": "a919a4c30d900c39",
                                    "type": "delay",
                                    "name": "",
                                    "timeout": "1",
                                    "rate": "1",
                                    "nbRateUnits": "1",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": false,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 380,
                                    "y": 140,
                                    "wires": [
                                            "bee64eb116d76ed1"
                                    "id": "bee64eb116d76ed1",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "pt": "msg",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 390,
                                    "y": 100,
                                    "wires": [
                                            "0150c15cf7b51170"
                                    "id": "ab41883686b27cc0",
                                    "type": "switch",
                                    "name": "Schalter",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 860,
                                    "y": 80,
                                    "wires": [
                                            "01fea99b98c641a3"
                                    "id": "0395e4bbb7c67e21",
                                    "type": "change",
                                    "name": "Motion",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "tot": "msg"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 590,
                                    "y": 80,
                                    "wires": [
                                            "d24a5429e472b18a"
                                    "id": "59792b228df9eb30",
                                    "type": "comment",
                                    "info": "",
                                    "x": 220,
                                    "y": 20,
                                    "wires": []
                                    "id": "93f0d4c85ab42e59",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "on",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 590,
                                    "y": 160,
                                    "wires": [
                                            "ed2607cafe826532"
                                    "id": "e22b60db6265e908",
                                    "type": "switch",
                                    "name": "1000?",
                                    "rules": [
                                            "t": "eq",
                                            "v": "1000",
                                            "vt": "num"
                                            "t": "eq",
                                            "v": "",
                                            "vt": "num"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 210,
                                    "y": 320,
                                    "wires": [
                                            "6ae2e0e61f81faeb"
                                    "id": "01fea99b98c641a3",
                                    "type": "switch",
                                    "name": "Robi",
                                    "property": "BWM",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 990,
                                    "y": 80,
                                    "wires": [
                                            "ba0aea0ff71ebc3d"
                                    "id": "7eea52e80cbe51f0",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "stopp",
                                            "pt": "flow",
                                            "to": "true",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 680,
                                    "y": 220,
                                    "wires": [
                                    "id": "574a9f7ddc4f663b",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "stopp",
                                            "pt": "flow",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1280,
                                    "y": 300,
                                    "wires": [
                                    "id": "331a07cfba2d7df1",
                                    "type": "function",
                                    "outputs": 1,
                                    "timeout": 0,
                                    "noerr": 0,
                                    "finalize": "",
                                    "libs": [],
                                    "x": 1410,
                                    "y": 180,
                                    "wires": [
                                            "ed06e85de97289c8",
                                            "423ea0f1dc0e4d31"
                                    "id": "b9692c9131fb2ef5",
                                    "name": "Robi",
                                    "topic": "mihome-vacuum.0.info.state",
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 50,
                                    "y": 380,
                                    "wires": [
                                            "6b214a0a59b5e04a"
                                    "id": "0150c15cf7b51170",
                                    "type": "function",
                                    "outputs": 1,
                                    "timeout": 0,
                                    "noerr": 0,
                                    "initialize": "",
                                    "finalize": "",
                                    "libs": [],
                                    "x": 440,
                                    "y": 60,
                                    "wires": [
                                            "0395e4bbb7c67e21"
                                    "id": "b6b4c157c31e3701",
                                    "onlyack": "",
                                    "func": "all",
                                    "gap": "",
                                    "x": 60,
                                    "y": 320,
                                    "wires": [
                                            "e22b60db6265e908"
                                    "id": "6b214a0a59b5e04a",
                                    "type": "switch",
                                    "name": "8?",
                                    "rules": [
                                            "t": "eq",
                                            "v": "8",
                                            "vt": "num"
                                            "t": "neq",
                                            "v": "8",
                                            "vt": "num"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 650,
                                    "y": 380,
                                    "wires": [
                                            "7b9c0fa6e795af2d"
                                            "ccadbb1ee1de29e6"
                                    "id": "7b9c0fa6e795af2d",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "BWM",
                                            "pt": "flow",
                                            "to": "true",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 810,
                                    "y": 360,
                                    "wires": [
                                            "b117dac109d51b34"
                                    "id": "ccadbb1ee1de29e6",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "BWM",
                                            "pt": "flow",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 810,
                                    "y": 400,
                                    "wires": [
                                            "b117dac109d51b34"
                                    "id": "558db419c5c37cca",
                                    "type": "comment",
                                    "info": "",
                                    "x": 860,
                                    "y": 40,
                                    "wires": []
                                    "id": "d24a5429e472b18a",
                                    "type": "switch",
                                    "name": "nur true",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 720,
                                    "y": 80,
                                    "wires": [
                                            "ab41883686b27cc0"
                                    "id": "b117dac109d51b34",
                                    "type": "debug",
                                    "name": "debug 4",
                                    "active": false,
                                    "tosidebar": true,
                                    "console": false,
                                    "tostatus": false,
                                    "complete": "true",
                                    "statusVal": "",
                                    "x": 1100,
                                    "y": 380,
                                    "wires": []
                                    "id": "d64f728f4f574f51",
                                    "type": "comment",
                                    "info": "",
                                    "x": 190,
                                    "y": 280,
                                    "wires": []
                                    "id": "91febc7692f9b822",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "on",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "off",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 930,
                                    "y": 140,
                                    "wires": [
                                            "d303b6e1817d8b77"
                                    "id": "d303b6e1817d8b77",
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                            "t": "eq",
                                            "v": "",
                                            "vt": "str"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 3,
                                    "x": 1090,
                                    "y": 120,
                                    "wires": [
                                            "331a07cfba2d7df1"
                                            "331a07cfba2d7df1",
                                            "574a9f7ddc4f663b"
                                    "id": "b4e55cb04c30244e",
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "true"
                                            "t": "false"
                                            "t": "eq",
                                            "v": "",
                                            "vt": "str"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 3,
                                    "x": 1630,
                                    "y": 60,
                                    "wires": [
                                            "331a07cfba2d7df1"
                                            "331a07cfba2d7df1"
                                    "id": "90c9685b4a5344dc",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "on",
                                            "fromt": "str",
                                            "to": "true",
                                            "tot": "bool"
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "off",
                                            "fromt": "str",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1470,
                                    "y": 60,
                                    "wires": [
                                            "b4e55cb04c30244e"
                                    "id": "ba0aea0ff71ebc3d",
                                    "type": "change",
                                    "name": "",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "on",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1150,
                                    "y": 60,
                                    "wires": [
                                            "fa5f2b5bcd258a98"
                                    "id": "6ae2e0e61f81faeb",
                                    "name": "Virtuelle Lampe",
                                    "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                                    "x": 460,
                                    "y": 320,
                                    "wires": [
                                            "cf3016a536d38a8d"
                                    "id": "cf3016a536d38a8d",
                                    "type": "switch",
                                    "name": "",
                                    "rules": [
                                            "t": "false"
                                            "t": "true"
                                    "checkall": "true",
                                    "repair": false,
                                    "outputs": 2,
                                    "x": 650,
                                    "y": 320,
                                    "wires": [
                                            "7eea52e80cbe51f0",
                                            "93f0d4c85ab42e59"
                                            "7b9c0fa6e795af2d",
                                            "87ec46662c49de4e",
                                            "f00e20abd94ff43d"
                                    "id": "141a052859674836",
                                    "type": "change",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "false",
                                            "tot": "bool"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1280,
                                    "y": 340,
                                    "wires": [
                                            "331a07cfba2d7df1"
                                    "id": "87ec46662c49de4e",
                                    "type": "change",
                                    "name": "stop",
                                    "rules": [
                                            "t": "set",
                                            "p": "payload",
                                            "pt": "msg",
                                            "to": "stop",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 930,
                                    "y": 280,
                                    "wires": [
                                            "ed2607cafe826532",
                                            "fa5f2b5bcd258a98"
                                    "id": "ed2607cafe826532",
                                    "name": "45min.",
                                    "outtopic": "",
                                    "outsafe": "on",
                                    "outunsafe": "off",
                                    "warning": "10",
                                    "timer": "2700",
                                    "debug": false,
                                    "ndebug": false,
                                    "repeat": false,
                                    "again": false,
                                    "x": 770,
                                    "y": 160,
                                    "wires": [
                                            "91febc7692f9b822"
                                    "id": "fa5f2b5bcd258a98",
                                    "name": "3Min.",
                                    "outtopic": "",
                                    "outsafe": "on",
                                    "outunsafe": "off",
                                    "warning": "10",
                                    "timer": "180",
                                    "debug": false,
                                    "ndebug": false,
                                    "repeat": false,
                                    "again": false,
                                    "x": 1310,
                                    "y": 100,
                                    "wires": [
                                            "90c9685b4a5344dc"
                                    "id": "802770af38c8534e",
                                    "type": "hue-bridge-node",
                                    "name": "Hue",
                                    "bridge": "cbd54dbabf6f65be",
                                    "autoupdates": true,
                                    "skipglobalevents": false,
                                    "initevents": false,
                                    "x": 90,
                                    "y": 220,
                                    "wires": [
                                            "2e0c2a67486c0ac7"
                                    "id": "2e0c2a67486c0ac7",
                                    "type": "hue-motion",
                                    "name": "Küche Motion Sensor",
                                    "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                                    "skipevents": false,
                                    "initevents": true,
                                    "x": 140,
                                    "y": 140,
                                    "wires": [
                                            "a919a4c30d900c39",
                                            "0150c15cf7b51170"
                                    "id": "21f36ea2695afe19",
                                    "name": "U-rechts",
                                    "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1600,
                                    "y": 360,
                                    "wires": []
                                    "id": "084e7114b7ed1c61",
                                    "name": "Küche Decke",
                                    "topic": "tuya.0.bfe4af976feb74d845vugp.1",
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1730,
                                    "y": 240,
                                    "wires": []
                                    "id": "ff32f89078260f0e",
                                    "name": "Virtuel Switch 1",
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1620,
                                    "y": 300,
                                    "wires": []
                                    "id": "442c2ef743d9599f",
                                    "type": "debug",
                                    "name": "Küche",
                                    "active": true,
                                    "tosidebar": true,
                                    "console": true,
                                    "tostatus": false,
                                    "statusVal": "",
                                    "x": 1620,
                                    "y": 520,
                                    "wires": []
                                    "id": "67e2e01a1266d1c3",
                                    "type": "delay",
                                    "name": "100ms",
                                    "timeout": "100",
                                    "timeoutUnits": "milliseconds",
                                    "rate": "1",
                                    "nbRateUnits": "1",
                                    "randomFirst": "1",
                                    "randomLast": "5",
                                    "drop": false,
                                    "allowrate": false,
                                    "outputs": 1,
                                    "x": 1590,
                                    "y": 240,
                                    "wires": [
                                            "084e7114b7ed1c61"
                                    "id": "e98816534075b0f5",
                                    "type": "change",
                                    "name": "Küche",
                                    "rules": [
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "1000",
                                            "fromt": "str",
                                            "to": "Küche",
                                            "tot": "str"
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "true",
                                            "fromt": "bool",
                                            "to": "Küche eingeschaltet",
                                            "tot": "str"
                                            "t": "change",
                                            "p": "payload",
                                            "pt": "msg",
                                            "from": "false",
                                            "fromt": "bool",
                                            "to": "Küche ausgeschaltet",
                                            "tot": "str"
                                    "action": "",
                                    "property": "",
                                    "from": "",
                                    "to": "",
                                    "reg": false,
                                    "x": 1490,
                                    "y": 520,
                                    "wires": [
                                            "442c2ef743d9599f"
                                    "id": "a695276a00fe8f61",
                                    "name": "U-links",
                                    "topic": "hue.0.Hue_GordonX.Küche_Unterschr_Links.on",
                                    "ack": "false",
                                    "stateName": "",
                                    "role": "",
                                    "payloadType": "",
                                    "readonly": "",
                                    "stateUnit": "",
                                    "stateMin": "",
                                    "stateMax": "",
                                    "x": 1590,
                                    "y": 440,
                                    "wires": []
                                    "id": "cbd54dbabf6f65be",
                                    "type": "hue-bridge",
                                    "name": "Hue GordonX",
                                    "bridge": "192.168.0.8",
                                    "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                                    "worker": "10",
                                    "disableupdates": false
                            • P Offline
                              peterfido
                              @aphofis Wenn Du die Laufzeit des Bewegungsmelders mit berücksichtigen möchtest, dann muss diese zyklisch abgefragt werden, und kommt dann zu der Laufzeit von drei Minuten dazu.
                                     "type": "tab",
                                     "label": "Flow 8",
                                     "disabled": false,
                                     "info": "",
                                     "env": []
                                     "type": "junction",
                                     "x": 1120,
                                     "y": 660,
                                     "wires": [
                                             "141a052859674836",
                                             "574a9f7ddc4f663b",
                                             "b6322a40cf4557b3"
                                     "type": "junction",
                                     "x": 1960,
                                     "y": 460,
                                     "wires": [
                                             "ff32f89078260f0e",
                                             "67e2e01a1266d1c3",
                                             "e98816534075b0f5",
                                             "21f36ea2695afe19",
                                             "a695276a00fe8f61"
                                     "id": "ae8ceff406113f11",
                                     "type": "junction",
                                     "x": 1140,
                                     "y": 260,
                                     "wires": [
                                             "ba0aea0ff71ebc3d"
                                     "id": "256e4df028333ee3",
                                     "type": "junction",
                                     "x": 580,
                                     "y": 60,
                                     "wires": [
                                             "6ae2e0e61f81faeb"
                                     "id": "9c7c62ee37b6b12c",
                                     "type": "junction",
                                     "x": 540,
                                     "y": 120,
                                     "wires": [
                                             "d24a5429e472b18a"
                                     "id": "d96f128a59bdfbb4",
                                     "type": "junction",
                                     "x": 900,
                                     "y": 440,
                                     "wires": [
                                             "84bd4ea1d044fea4",
                                             "ed2607cafe826532"
                                     "id": "84bd4ea1d044fea4",
                                     "type": "junction",
                                     "x": 980,
                                     "y": 360,
                                     "wires": [
                                             "be66da991b562e24"
                                     "id": "be66da991b562e24",
                                     "type": "junction",
                                     "x": 1280,
                                     "y": 360,
                                     "wires": [
                                             "fa5f2b5bcd258a98"
                                     "type": "inject",
                                     "props": [
                                             "v": "true",
                                             "vt": "bool"
                                             "p": "topic",
                                             "vt": "str"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "x": 140,
                                     "y": 380,
                                     "wires": [
                                             "a919a4c30d900c39",
                                             "0150c15cf7b51170"
                                     "type": "debug",
                                     "name": "debug 3",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "complete": "true",
                                     "statusVal": "",
                                     "x": 2000,
                                     "y": 360,
                                     "wires": []
                                     "type": "delay",
                                     "name": "",
                                     "timeout": "10",
                                     "rate": "1",
                                     "nbRateUnits": "1",
                                     "randomFirst": "1",
                                     "randomLast": "5",
                                     "drop": false,
                                     "allowrate": false,
                                     "outputs": 1,
                                     "x": 150,
                                     "y": 460,
                                     "wires": [
                                             "bee64eb116d76ed1"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "pt": "msg",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 350,
                                     "y": 460,
                                     "wires": [
                                             "0150c15cf7b51170"
                                     "type": "switch",
                                     "name": "Schalter",
                                     "rules": [
                                             "t": "true"
                                             "t": "false"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 920,
                                     "y": 260,
                                     "wires": [
                                             "01fea99b98c641a3"
                                     "type": "change",
                                     "name": "Motion",
                                     "rules": [
                                             "t": "set",
                                             "p": "bewegung",
                                             "pt": "flow",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 670,
                                     "y": 320,
                                     "wires": [
                                     "type": "comment",
                                     "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Beginn>>",
                                     "info": "",
                                     "x": 270,
                                     "y": 300,
                                     "wires": []
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "on",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 710,
                                     "y": 400,
                                     "wires": [
                                             "ed2607cafe826532"
                                     "type": "switch",
                                     "name": "1000?",
                                     "rules": [
                                             "t": "eq",
                                             "v": "1000",
                                             "vt": "num"
                                             "t": "eq",
                                             "v": "",
                                             "vt": "num"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 250,
                                     "y": 660,
                                     "wires": [
                                             "35f7a8f381fdb099"
                                     "type": "switch",
                                     "name": "Robi",
                                     "property": "BWM",
                                     "rules": [
                                             "t": "true"
                                             "t": "false"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 1050,
                                     "y": 260,
                                     "wires": [
                                             "ae8ceff406113f11"
                                     "type": "change",
                                     "name": "setze stopp",
                                     "rules": [
                                             "t": "set",
                                             "p": "stopp",
                                             "pt": "flow",
                                             "to": "true",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 890,
                                     "y": 600,
                                     "wires": [
                                     "type": "change",
                                     "name": "lösche stopp",
                                     "rules": [
                                             "t": "set",
                                             "p": "stopp",
                                             "pt": "flow",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1370,
                                     "y": 600,
                                     "wires": [
                                     "type": "function",
                                     "func": "node.status({ text: msg.payload });\n\n// Für Tests Beginn\nflow.set(\"lampe_ist\", msg.payload); // Zeile für Normalbetrieb auskommentieren\n// Für Tests Ende\n\nreturn msg;",
                                     "outputs": 1,
                                     "timeout": 0,
                                     "noerr": 0,
                                     "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\nflow.set(\"lampe_ist\", false);\n",
                                     "finalize": "",
                                     "libs": [],
                                     "x": 1770,
                                     "y": 380,
                                     "wires": [
                                             "ed06e85de97289c8",
                                             "423ea0f1dc0e4d31"
                                     "name": "Robi",
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 90,
                                     "y": 780,
                                     "wires": [
                                             "6b214a0a59b5e04a"
                                     "type": "function",
                                     "outputs": 1,
                                     "timeout": 0,
                                     "noerr": 0,
                                     "initialize": "",
                                     "finalize": "",
                                     "libs": [],
                                     "x": 360,
                                     "y": 360,
                                     "wires": [
                                             "0395e4bbb7c67e21"
                                     "name": "KüSchalter",
                                     "onlyack": "",
                                     "func": "all",
                                     "gap": "",
                                     "x": 100,
                                     "y": 680,
                                     "wires": [
                                             "e22b60db6265e908"
                                     "type": "switch",
                                     "name": "8?",
                                     "rules": [
                                             "t": "eq",
                                             "v": "8",
                                             "vt": "num"
                                             "t": "neq",
                                             "v": "8",
                                             "vt": "num"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 630,
                                     "y": 780,
                                     "wires": [
                                             "7b9c0fa6e795af2d"
                                             "ccadbb1ee1de29e6"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "BWM",
                                             "pt": "flow",
                                             "to": "true",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 850,
                                     "y": 760,
                                     "wires": [
                                             "b117dac109d51b34"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "BWM",
                                             "pt": "flow",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 850,
                                     "y": 800,
                                     "wires": [
                                             "b117dac109d51b34"
                                     "type": "comment",
                                     "name": "evtl. gesperrt durch?? Beginn",
                                     "info": "",
                                     "x": 980,
                                     "y": 220,
                                     "wires": []
                                     "type": "switch",
                                     "name": "nur true",
                                     "rules": [
                                             "t": "true"
                                             "t": "false"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 740,
                                     "y": 240,
                                     "wires": [
                                             "ab41883686b27cc0"
                                     "type": "debug",
                                     "name": "debug 4",
                                     "active": false,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "complete": "true",
                                     "statusVal": "",
                                     "x": 1040,
                                     "y": 760,
                                     "wires": []
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "on",
                                             "fromt": "str",
                                             "to": "true",
                                             "tot": "bool"
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "off",
                                             "fromt": "str",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1290,
                                     "y": 400,
                                     "wires": [
                                             "d303b6e1817d8b77"
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "true"
                                             "t": "false"
                                             "t": "eq",
                                             "v": "",
                                             "vt": "str"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 3,
                                     "x": 1470,
                                     "y": 400,
                                     "wires": [
                                             "331a07cfba2d7df1"
                                             "331a07cfba2d7df1",
                                             "574a9f7ddc4f663b"
                                     "type": "switch",
                                     "name": "",
                                     "rules": [
                                             "t": "true"
                                             "t": "false"
                                             "t": "eq",
                                             "v": "",
                                             "vt": "str"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 3,
                                     "x": 1770,
                                     "y": 260,
                                     "wires": [
                                             "331a07cfba2d7df1"
                                             "331a07cfba2d7df1"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "on",
                                             "fromt": "str",
                                             "to": "true",
                                             "tot": "bool"
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "off",
                                             "fromt": "str",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1610,
                                     "y": 260,
                                     "wires": [
                                             "b4e55cb04c30244e"
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "on",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1250,
                                     "y": 260,
                                     "wires": [
                                             "fa5f2b5bcd258a98"
                                     "x": 760,
                                     "y": 100,
                                     "wires": [
                                             "dc4b3ed2e3d1a857"
                                     "type": "switch",
                                     "name": "true false",
                                     "property": "payload",
                                     "propertyType": "msg",
                                     "rules": [
                                             "t": "false"
                                             "t": "true"
                                     "checkall": "true",
                                     "repair": false,
                                     "outputs": 2,
                                     "x": 680,
                                     "y": 660,
                                     "wires": [
                                             "7eea52e80cbe51f0",
                                             "93f0d4c85ab42e59"
                                             "7b9c0fa6e795af2d",
                                             "87ec46662c49de4e",
                                             "f00e20abd94ff43d"
                                     "type": "change",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1380,
                                     "y": 640,
                                     "wires": [
                                             "331a07cfba2d7df1"
                                     "type": "change",
                                     "name": "stop",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "stop",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1010,
                                     "y": 640,
                                     "wires": [
                                             "d96f128a59bdfbb4"
                                     "name": "45sek",
                                     "outtopic": "",
                                     "outsafe": "on",
                                     "outunsafe": "off",
                                     "warning": "10",
                                     "timer": "45",
                                     "debug": false,
                                     "ndebug": false,
                                     "repeat": false,
                                     "again": false,
                                     "x": 1090,
                                     "y": 400,
                                     "wires": [
                                             "91febc7692f9b822"
                                     "name": "10Sek",
                                     "outtopic": "",
                                     "outsafe": "on",
                                     "outunsafe": "off",
                                     "warning": "10",
                                     "timer": "10",
                                     "debug": false,
                                     "ndebug": false,
                                     "repeat": false,
                                     "again": false,
                                     "x": 1430,
                                     "y": 260,
                                     "wires": [
                                             "90c9685b4a5344dc"
                                     "name": "U-rechts",
                                     "ack": "false",
                                     "stateName": "",
                                     "role": "",
                                     "payloadType": "",
                                     "readonly": "",
                                     "stateUnit": "",
                                     "stateMin": "",
                                     "stateMax": "",
                                     "x": 2140,
                                     "y": 600,
                                     "wires": []
                                     "ack": "false",
                                     "stateName": "",
                                     "role": "",
                                     "payloadType": "",
                                     "readonly": "",
                                     "stateUnit": "",
                                     "stateMin": "",
                                     "stateMax": "",
                                     "x": 2210,
                                     "y": 460,
                                     "wires": []
                                     "ack": "false",
                                     "stateName": "",
                                     "role": "",
                                     "payloadType": "",
                                     "readonly": "",
                                     "stateUnit": "",
                                     "stateMin": "",
                                     "stateMax": "",
                                     "x": 2160,
                                     "y": 540,
                                     "wires": []
                                     "type": "debug",
                                     "name": "Küche",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": true,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "statusType": "auto",
                                     "x": 2160,
                                     "y": 760,
                                     "wires": []
                                     "type": "delay",
                                     "name": "100ms",
                                     "timeout": "100",
                                     "rate": "1",
                                     "nbRateUnits": "1",
                                     "randomFirst": "1",
                                     "randomLast": "5",
                                     "drop": false,
                                     "allowrate": false,
                                     "outputs": 1,
                                     "x": 2070,
                                     "y": 460,
                                     "wires": [
                                             "084e7114b7ed1c61"
                                     "type": "change",
                                     "name": "Küche",
                                     "rules": [
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "1000",
                                             "fromt": "str",
                                             "to": "Küche",
                                             "tot": "str"
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "true",
                                             "fromt": "bool",
                                             "tot": "str"
                                             "t": "change",
                                             "p": "payload",
                                             "pt": "msg",
                                             "from": "false",
                                             "fromt": "bool",
                                             "tot": "str"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 2030,
                                     "y": 760,
                                     "wires": [
                                             "442c2ef743d9599f"
                                     "name": "U-links",
                                     "ack": "false",
                                     "stateName": "",
                                     "role": "",
                                     "payloadType": "",
                                     "readonly": "",
                                     "stateUnit": "",
                                     "stateMin": "",
                                     "stateMax": "",
                                     "x": 2130,
                                     "y": 680,
                                     "wires": []
                                     "name": "Hue",
                                     "x": 130,
                                     "y": 160,
                                     "wires": [
                                             "2e0c2a67486c0ac7"
                                     "initevents": true,
                                     "x": 360,
                                     "y": 160,
                                     "wires": [
                                             "0395e4bbb7c67e21"
                                     "id": "83e1205cab7afd75",
                                     "type": "inject",
                                     "name": "Takt",
                                     "props": [
                                             "p": "payload"
                                             "p": "topic",
                                             "vt": "str"
                                     "repeat": "1",
                                     "crontab": "",
                                     "once": true,
                                     "onceDelay": 0.1,
                                     "topic": "Takt",
                                     "payload": "true",
                                     "payloadType": "bool",
                                     "x": 130,
                                     "y": 60,
                                     "wires": [
                                             "26a06677287b879b",
                                             "256e4df028333ee3"
                                     "id": "26a06677287b879b",
                                     "type": "change",
                                     "name": "",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "bewegung",
                                             "tot": "flow"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 350,
                                     "y": 120,
                                     "wires": [
                                             "9c7c62ee37b6b12c"
                                     "id": "c8bd53de95a27a58",
                                     "type": "inject",
                                     "name": "Test Schalter",
                                     "props": [
                                             "p": "payload"
                                             "p": "topic",
                                             "vt": "str"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "1000",
                                     "x": 130,
                                     "y": 600,
                                     "wires": [
                                             "e22b60db6265e908"
                                     "id": "b6322a40cf4557b3",
                                     "type": "change",
                                     "name": "lösche bewegung",
                                     "rules": [
                                             "t": "set",
                                             "p": "bewegung",
                                             "pt": "flow",
                                             "to": "false",
                                             "tot": "bool"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 1390,
                                     "y": 680,
                                     "wires": [
                                     "id": "35f7a8f381fdb099",
                                     "type": "change",
                                     "name": "lichtan?",
                                     "rules": [
                                             "t": "set",
                                             "p": "payload",
                                             "pt": "msg",
                                             "to": "lampe_ist",
                                             "tot": "flow"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 460,
                                     "y": 660,
                                     "wires": [
                                             "cf3016a536d38a8d"
                                     "id": "dc4b3ed2e3d1a857",
                                     "type": "change",
                                     "name": "Motion",
                                     "rules": [
                                             "t": "set",
                                             "p": "lampe_ist",
                                             "pt": "flow",
                                             "to": "payload",
                                             "tot": "msg"
                                     "action": "",
                                     "property": "",
                                     "from": "",
                                     "to": "",
                                     "reg": false,
                                     "x": 910,
                                     "y": 100,
                                     "wires": [
                                     "id": "704f9134130a0c13",
                                     "type": "comment",
                                     "name": "Nötig für Simulation, da kein Tuya Ende",
                                     "info": "",
                                     "x": 830,
                                     "y": 160,
                                     "wires": []
                                     "id": "105d29d40a2b08f3",
                                     "type": "comment",
                                     "name": "Nötig für Simulation, da kein Tuya Beginn",
                                     "info": "",
                                     "x": 840,
                                     "y": 40,
                                     "wires": []
                                     "id": "2e246cc32c852ec4",
                                     "type": "comment",
                                     "name": "Nötig für Simulation, da kein Tuya",
                                     "info": "",
                                     "x": 470,
                                     "y": 620,
                                     "wires": []
                                     "id": "5d18e186acebf108",
                                     "type": "comment",
                                     "info": "",
                                     "x": 470,
                                     "y": 720,
                                     "wires": []
                                     "id": "4208dd4576daa563",
                                     "type": "comment",
                                     "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Ende>>",
                                     "info": "",
                                     "x": 260,
                                     "y": 520,
                                     "wires": []
                                     "id": "f6fea6b16f9005b0",
                                     "type": "comment",
                                     "name": "evtl. gesperrt durch?? Ende",
                                     "info": "",
                                     "x": 980,
                                     "y": 320,
                                     "wires": []
                                     "worker": "10",
                              Peterfido
                              • P peterfido
                                       "type": "tab",
                                       "label": "Flow 8",
                                       "disabled": false,
                                       "info": "",
                                       "env": []
                                       "type": "junction",
                                       "x": 1120,
                                       "y": 660,
                                       "wires": [
                                               "141a052859674836",
                                               "574a9f7ddc4f663b",
                                               "b6322a40cf4557b3"
                                       "type": "junction",
                                       "x": 1960,
                                       "y": 460,
                                       "wires": [
                                               "ff32f89078260f0e",
                                               "67e2e01a1266d1c3",
                                               "e98816534075b0f5",
                                               "21f36ea2695afe19",
                                               "a695276a00fe8f61"
                                       "type": "junction",
                                       "x": 1140,
                                       "y": 260,
                                       "wires": [
                                               "ba0aea0ff71ebc3d"
                                       "type": "junction",
                                       "x": 580,
                                       "y": 60,
                                       "wires": [
                                               "6ae2e0e61f81faeb"
                                       "type": "junction",
                                       "x": 540,
                                       "y": 120,
                                       "wires": [
                                               "d24a5429e472b18a"
                                       "type": "junction",
                                       "x": 900,
                                       "y": 440,
                                       "wires": [
                                               "84bd4ea1d044fea4",
                                               "ed2607cafe826532"
                                       "type": "junction",
                                       "x": 980,
                                       "y": 360,
                                       "wires": [
                                               "be66da991b562e24"
                                       "type": "junction",
                                       "x": 1280,
                                       "y": 360,
                                       "wires": [
                                               "fa5f2b5bcd258a98"
                                       "type": "inject",
                                       "props": [
                                               "v": "true",
                                               "vt": "bool"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "x": 140,
                                       "y": 380,
                                       "wires": [
                                               "a919a4c30d900c39",
                                               "0150c15cf7b51170"
                                       "type": "debug",
                                       "name": "debug 3",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 2000,
                                       "y": 360,
                                       "wires": []
                                       "type": "delay",
                                       "name": "",
                                       "timeout": "10",
                                       "rate": "1",
                                       "nbRateUnits": "1",
                                       "randomFirst": "1",
                                       "randomLast": "5",
                                       "drop": false,
                                       "allowrate": false,
                                       "outputs": 1,
                                       "x": 150,
                                       "y": 460,
                                       "wires": [
                                               "bee64eb116d76ed1"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "pt": "msg",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 350,
                                       "y": 460,
                                       "wires": [
                                               "0150c15cf7b51170"
                                       "type": "switch",
                                       "name": "Schalter",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 920,
                                       "y": 260,
                                       "wires": [
                                               "01fea99b98c641a3"
                                       "type": "change",
                                       "name": "Motion",
                                       "rules": [
                                               "t": "set",
                                               "p": "bewegung",
                                               "pt": "flow",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 670,
                                       "y": 320,
                                       "wires": [
                                       "type": "comment",
                                       "info": "",
                                       "x": 270,
                                       "y": 300,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "on",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 710,
                                       "y": 400,
                                       "wires": [
                                               "ed2607cafe826532"
                                       "type": "switch",
                                       "name": "1000?",
                                       "rules": [
                                               "t": "eq",
                                               "v": "1000",
                                               "vt": "num"
                                               "t": "eq",
                                               "v": "",
                                               "vt": "num"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 250,
                                       "y": 660,
                                       "wires": [
                                               "35f7a8f381fdb099"
                                       "type": "switch",
                                       "name": "Robi",
                                       "property": "BWM",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 1050,
                                       "y": 260,
                                       "wires": [
                                               "ae8ceff406113f11"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "stopp",
                                               "pt": "flow",
                                               "to": "true",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 890,
                                       "y": 600,
                                       "wires": [
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "stopp",
                                               "pt": "flow",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1370,
                                       "y": 600,
                                       "wires": [
                                       "type": "function",
                                       "outputs": 1,
                                       "timeout": 0,
                                       "noerr": 0,
                                       "finalize": "",
                                       "libs": [],
                                       "x": 1770,
                                       "y": 380,
                                       "wires": [
                                               "ed06e85de97289c8",
                                               "423ea0f1dc0e4d31"
                                       "type": "ioBroker in",
                                       "name": "Robi",
                                       "attrname": "payload",
                                       "payloadType": "value",
                                       "onlyack": "",
                                       "func": "all",
                                       "gap": "",
                                       "fireOnStart": "false",
                                       "outFormat": "MQTT",
                                       "x": 90,
                                       "y": 780,
                                       "wires": [
                                               "6b214a0a59b5e04a"
                                       "type": "function",
                                       "outputs": 1,
                                       "timeout": 0,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 360,
                                       "y": 360,
                                       "wires": [
                                               "0395e4bbb7c67e21"
                                       "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
                                       "onlyack": "",
                                       "func": "all",
                                       "gap": "",
                                       "x": 100,
                                       "y": 680,
                                       "wires": [
                                               "e22b60db6265e908"
                                       "type": "switch",
                                       "name": "8?",
                                       "rules": [
                                               "t": "eq",
                                               "v": "8",
                                               "vt": "num"
                                               "t": "neq",
                                               "v": "8",
                                               "vt": "num"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 630,
                                       "y": 780,
                                       "wires": [
                                               "7b9c0fa6e795af2d"
                                               "ccadbb1ee1de29e6"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "BWM",
                                               "pt": "flow",
                                               "to": "true",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 850,
                                       "y": 760,
                                       "wires": [
                                               "b117dac109d51b34"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "BWM",
                                               "pt": "flow",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 850,
                                       "y": 800,
                                       "wires": [
                                               "b117dac109d51b34"
                                       "type": "comment",
                                       "info": "",
                                       "x": 980,
                                       "y": 220,
                                       "wires": []
                                       "type": "switch",
                                       "name": "nur true",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 740,
                                       "y": 240,
                                       "wires": [
                                               "ab41883686b27cc0"
                                       "type": "debug",
                                       "name": "debug 4",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 1040,
                                       "y": 760,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "on",
                                               "fromt": "str",
                                               "to": "true",
                                               "tot": "bool"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "off",
                                               "fromt": "str",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1290,
                                       "y": 400,
                                       "wires": [
                                               "d303b6e1817d8b77"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                               "t": "eq",
                                               "v": "",
                                               "vt": "str"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 3,
                                       "x": 1470,
                                       "y": 400,
                                       "wires": [
                                               "331a07cfba2d7df1"
                                               "331a07cfba2d7df1",
                                               "574a9f7ddc4f663b"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                               "t": "eq",
                                               "v": "",
                                               "vt": "str"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 3,
                                       "x": 1770,
                                       "y": 260,
                                       "wires": [
                                               "331a07cfba2d7df1"
                                               "331a07cfba2d7df1"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "on",
                                               "fromt": "str",
                                               "to": "true",
                                               "tot": "bool"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "off",
                                               "fromt": "str",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1610,
                                       "y": 260,
                                       "wires": [
                                               "b4e55cb04c30244e"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "on",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1250,
                                       "y": 260,
                                       "wires": [
                                               "fa5f2b5bcd258a98"
                                       "type": "ioBroker get",
                                       "errOnInvalidState": "nothing",
                                       "x": 760,
                                       "y": 100,
                                       "wires": [
                                               "dc4b3ed2e3d1a857"
                                       "type": "switch",
                                       "rules": [
                                               "t": "false"
                                               "t": "true"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 680,
                                       "y": 660,
                                       "wires": [
                                               "7eea52e80cbe51f0",
                                               "93f0d4c85ab42e59"
                                               "7b9c0fa6e795af2d",
                                               "87ec46662c49de4e",
                                               "f00e20abd94ff43d"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1380,
                                       "y": 640,
                                       "wires": [
                                               "331a07cfba2d7df1"
                                       "type": "change",
                                       "name": "stop",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "stop",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1010,
                                       "y": 640,
                                       "wires": [
                                               "d96f128a59bdfbb4"
                                       "name": "45sek",
                                       "outtopic": "",
                                       "outsafe": "on",
                                       "outunsafe": "off",
                                       "warning": "10",
                                       "timer": "45",
                                       "debug": false,
                                       "ndebug": false,
                                       "repeat": false,
                                       "again": false,
                                       "x": 1090,
                                       "y": 400,
                                       "wires": [
                                               "91febc7692f9b822"
                                       "name": "10Sek",
                                       "outtopic": "",
                                       "outsafe": "on",
                                       "outunsafe": "off",
                                       "warning": "10",
                                       "timer": "10",
                                       "debug": false,
                                       "ndebug": false,
                                       "repeat": false,
                                       "again": false,
                                       "x": 1430,
                                       "y": 260,
                                       "wires": [
                                               "90c9685b4a5344dc"
                                       "type": "ioBroker out",
                                       "name": "U-rechts",
                                       "ack": "false",
                                       "autoCreate": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2140,
                                       "y": 600,
                                       "wires": []
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2210,
                                       "y": 460,
                                       "wires": []
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2160,
                                       "y": 540,
                                       "wires": []
                                       "type": "debug",
                                       "name": "Küche",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": true,
                                       "tostatus": false,
                                       "complete": "payload",
                                       "targetType": "msg",
                                       "statusVal": "",
                                       "x": 2160,
                                       "y": 760,
                                       "wires": []
                                       "type": "delay",
                                       "name": "100ms",
                                       "pauseType": "delay",
                                       "timeout": "100",
                                       "rate": "1",
                                       "nbRateUnits": "1",
                                       "rateUnits": "second",
                                       "randomFirst": "1",
                                       "randomLast": "5",
                                       "randomUnits": "seconds",
                                       "drop": false,
                                       "allowrate": false,
                                       "outputs": 1,
                                       "x": 2070,
                                       "y": 460,
                                       "wires": [
                                               "084e7114b7ed1c61"
                                       "type": "change",
                                       "name": "Küche",
                                       "rules": [
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "1000",
                                               "fromt": "str",
                                               "to": "Küche",
                                               "tot": "str"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "true",
                                               "fromt": "bool",
                                               "tot": "str"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "false",
                                               "fromt": "bool",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 2030,
                                       "y": 760,
                                       "wires": [
                                               "442c2ef743d9599f"
                                       "name": "U-links",
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2130,
                                       "y": 680,
                                       "wires": []
                                       "name": "Hue",
                                       "x": 130,
                                       "y": 160,
                                       "wires": [
                                               "2e0c2a67486c0ac7"
                                       "initevents": true,
                                       "x": 360,
                                       "y": 160,
                                       "wires": [
                                               "0395e4bbb7c67e21"
                                       "type": "inject",
                                       "name": "Takt",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "1",
                                       "crontab": "",
                                       "once": true,
                                       "onceDelay": 0.1,
                                       "topic": "Takt",
                                       "payload": "true",
                                       "x": 130,
                                       "y": 60,
                                       "wires": [
                                               "26a06677287b879b",
                                               "256e4df028333ee3"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "bewegung",
                                               "tot": "flow"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 350,
                                       "y": 120,
                                       "wires": [
                                               "9c7c62ee37b6b12c"
                                       "type": "inject",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "1000",
                                       "x": 130,
                                       "y": 600,
                                       "wires": [
                                               "e22b60db6265e908"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "bewegung",
                                               "pt": "flow",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1390,
                                       "y": 680,
                                       "wires": [
                                       "type": "change",
                                       "name": "lichtan?",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "lampe_ist",
                                               "tot": "flow"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 460,
                                       "y": 660,
                                       "wires": [
                                               "cf3016a536d38a8d"
                                       "type": "change",
                                       "name": "Motion",
                                       "rules": [
                                               "t": "set",
                                               "p": "lampe_ist",
                                               "pt": "flow",
                                               "to": "payload",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 910,
                                       "y": 100,
                                       "wires": [
                                       "type": "comment",
                                       "info": "",
                                       "x": 830,
                                       "y": 160,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 840,
                                       "y": 40,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 470,
                                       "y": 620,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 470,
                                       "y": 720,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 260,
                                       "y": 520,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 980,
                                       "y": 320,
                                       "wires": []
                                       "worker": "10",
                                AphofisA Offline
                                AphofisA Offline
                                Aphofis
                                @peterfido
                                Mit der neuen Schaltung kann man per HUE schalter einmal zweimal klick nicht das licht ein und ausschalten es geht nur einschalten einschalten.
                                Das war in der vorherigen Schaltung korrekt da war jeder klick auf den schalter ein aus ein aus schalten.
                                P 1 Antwort Letzte Antwort
                                • AphofisA Aphofis
                                  @peterfido
                                  peterfido
                                  @aphofis Guck Dir mal die Function genauer an. Da ist ein Bemerkungstext drin, dass eine Zeile auskommentiert werden soll, wenn es produktiv genutzt wird. Evtl. war es das dann schon. Ich habe die Hardware nicht da, und habe daher die Lampe mit der Function simuliert.
                                  Es ist nicht einfach, da was zu "testen", was man nicht hat.
                                  Peterfido
                                  • AphofisA Offline
                                    AphofisA Offline
                                    Aphofis
                                    @peterfido
                                    Du meinst in der Variable !?
                                    flow.set("lampe_ist", msg.payload);
                                    Hatte ich auskommentiert, geht dann aber trotzdem nicht.
                                    • AphofisA Aphofis
                                      @peterfido
                                      peterfido
                                      @aphofis Da kommt dann die Fehlersuche. Also ein Node, z.B. den vom Bewegungsmelder deaktivieren, und schauen, ob es dann in der Simulation läuft. Man kann auch das Topic setzen und am Ende auswerten, wer die Lampe eingeschaltet hat.
                                      Die Abfrage der Lampe_ist kann auch von oben wieder weg und nach unten als Ersatz für den von mir mit "kein Tuya" 'eingerahmten' Block.
                                      Peterfido
                                      • P peterfido
                                        AphofisA Offline
                                        AphofisA Offline
                                        Aphofis
                                        @peterfido
                                        Also es funktioniert soweit, doch wenn der Roboter status 5 hat und man in den BWM läuft geht trotzdem das Licht an und wenn man es dann per Schalter ausschalten will, muss man das 3-4 mal machen bis das licht aus bleibt. Wie man jetzt herausfindet wer nun das licht schaltet weiß ich nicht.
                                                "id": "a4c8574588c0de3c",
                                                "type": "change",
                                                "z": "f40fbc4eb5ac4f7a",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload.motion",
                                                        "pt": "msg",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 450,
                                                "y": 540,
                                                "wires": [
                                                        "169c9cd74337485f"
                                                "id": "f6bc1b429099ca57",
                                                "type": "switch",
                                                "name": "Schalter",
                                                "property": "stopp",
                                                "propertyType": "flow",
                                                "rules": [
                                                        "t": "true"
                                                        "t": "false"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 800,
                                                "y": 500,
                                                "wires": [
                                                        "ee120a8678492945"
                                                "id": "f2bfa3e6a90d48ed",
                                                "type": "change",
                                                "name": "Motion",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "payload.motion",
                                                        "tot": "msg"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 610,
                                                "y": 500,
                                                "wires": [
                                                        "a7c05960eac63d95"
                                                "id": "8803280db34eb22b",
                                                "type": "comment",
                                                "name": "Bewegungsmelder Simulator  Beginn",
                                                "info": "",
                                                "x": 160,
                                                "y": 420,
                                                "wires": []
                                                "id": "5925b1db569c695b",
                                                "type": "change",
                                                "name": "payload",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "on",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 620,
                                                "y": 540,
                                                "wires": [
                                                        "5f9435538ec534ed"
                                                "id": "95fda7a91b84c03f",
                                                "type": "switch",
                                                "name": "1000?",
                                                "rules": [
                                                        "t": "eq",
                                                        "v": "1000",
                                                        "vt": "num"
                                                        "t": "eq",
                                                        "v": "",
                                                        "vt": "num"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 250,
                                                "y": 600,
                                                "wires": [
                                                        "ee5a65e2896d189b"
                                                "id": "ee120a8678492945",
                                                "type": "switch",
                                                "name": "Robi",
                                                "property": "BWM",
                                                "rules": [
                                                        "t": "true"
                                                        "t": "false"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 810,
                                                "y": 460,
                                                "wires": [
                                                        "8f4fcec5a545127f"
                                                "id": "3648551e97ec2cab",
                                                "type": "change",
                                                "name": "flow/stop",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "stopp",
                                                        "pt": "flow",
                                                        "to": "true",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 620,
                                                "y": 580,
                                                "wires": [
                                                "id": "a8b609cc983f0b37",
                                                "type": "change",
                                                "name": "löscheflow.stopp",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "stopp",
                                                        "pt": "flow",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 1220,
                                                "y": 520,
                                                "wires": [
                                                "id": "0e43213215238d27",
                                                "type": "function",
                                                "name": "Variab.Ini + Ausg.",
                                                "func": "node.status({ text: msg.payload });\n\nreturn msg;",
                                                "outputs": 1,
                                                "timeout": 0,
                                                "noerr": 0,
                                                "finalize": "",
                                                "libs": [],
                                                "x": 1430,
                                                "y": 460,
                                                "wires": [
                                                        "f1be18a24ca143f6"
                                                "id": "6500453922363ac9",
                                                "name": "Robi",
                                                "onlyack": "",
                                                "func": "all",
                                                "gap": "",
                                                "x": 370,
                                                "y": 700,
                                                "wires": [
                                                        "81fd4c871d668d04"
                                                "id": "169c9cd74337485f",
                                                "type": "function",
                                                "name": "Ausg.BWM",
                                                "outputs": 1,
                                                "timeout": 0,
                                                "noerr": 0,
                                                "initialize": "",
                                                "finalize": "",
                                                "libs": [],
                                                "x": 450,
                                                "y": 500,
                                                "wires": [
                                                        "f2bfa3e6a90d48ed"
                                                "id": "c6d6a47028727285",
                                                "onlyack": "",
                                                "func": "all",
                                                "gap": "",
                                                "x": 80,
                                                "y": 600,
                                                "wires": [
                                                        "95fda7a91b84c03f"
                                                "id": "81fd4c871d668d04",
                                                "type": "switch",
                                                "name": "8?",
                                                "rules": [
                                                        "t": "eq",
                                                        "v": "8",
                                                        "vt": "num"
                                                        "t": "neq",
                                                        "v": "8",
                                                        "vt": "num"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 490,
                                                "y": 680,
                                                "wires": [
                                                        "638dc14da90f5eb4"
                                                        "542b940ecfefa127"
                                                "id": "638dc14da90f5eb4",
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "BWM",
                                                        "pt": "flow",
                                                        "to": "true",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 650,
                                                "y": 660,
                                                "wires": [
                                                        "3803f5607daeb485"
                                                "id": "542b940ecfefa127",
                                                "type": "change",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "BWM",
                                                        "pt": "flow",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 650,
                                                "y": 700,
                                                "wires": [
                                                        "3803f5607daeb485"
                                                "id": "2bb3725204a30905",
                                                "type": "comment",
                                                "info": "",
                                                "x": 800,
                                                "y": 380,
                                                "wires": []
                                                "id": "a7c05960eac63d95",
                                                "type": "switch",
                                                "name": "nur true",
                                                "rules": [
                                                        "t": "true"
                                                        "t": "false"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 640,
                                                "y": 460,
                                                "wires": [
                                                        "f6bc1b429099ca57"
                                                "id": "3803f5607daeb485",
                                                "type": "debug",
                                                "name": "debug 9",
                                                "active": false,
                                                "tosidebar": true,
                                                "console": false,
                                                "tostatus": false,
                                                "complete": "true",
                                                "statusVal": "",
                                                "x": 820,
                                                "y": 680,
                                                "wires": []
                                                "id": "86ed2879e6ab1742",
                                                "type": "comment",
                                                "name": "Bewegungsmelder Simulator Ende",
                                                "info": "",
                                                "x": 160,
                                                "y": 560,
                                                "wires": []
                                                "id": "4deb5666bac8cf44",
                                                "type": "change",
                                                "name": "on/off",
                                                "rules": [
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "on",
                                                        "fromt": "str",
                                                        "to": "true",
                                                        "tot": "bool"
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "off",
                                                        "fromt": "str",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 890,
                                                "y": 560,
                                                "wires": [
                                                        "d2eeea8c88021d24"
                                                "id": "d2eeea8c88021d24",
                                                "type": "switch",
                                                "name": "",
                                                "rules": [
                                                        "t": "true"
                                                        "t": "false"
                                                        "t": "eq",
                                                        "v": "",
                                                        "vt": "str"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 3,
                                                "x": 1010,
                                                "y": 560,
                                                "wires": [
                                                        "1584a54e77837dbd"
                                                        "a8b609cc983f0b37",
                                                        "1584a54e77837dbd"
                                                "id": "774f8f940a2c4c96",
                                                "type": "switch",
                                                "name": "",
                                                "rules": [
                                                        "t": "true"
                                                        "t": "false"
                                                        "t": "eq",
                                                        "v": "",
                                                        "vt": "str"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 3,
                                                "x": 1190,
                                                "y": 460,
                                                "wires": [
                                                        "0e43213215238d27"
                                                        "0e43213215238d27"
                                                "id": "bcc31acbfde45d97",
                                                "type": "change",
                                                "name": "on/off",
                                                "rules": [
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "on",
                                                        "fromt": "str",
                                                        "to": "true",
                                                        "tot": "bool"
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "off",
                                                        "fromt": "str",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 990,
                                                "y": 460,
                                                "wires": [
                                                        "774f8f940a2c4c96"
                                                "id": "8f4fcec5a545127f",
                                                "type": "change",
                                                "name": "on",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "on",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 810,
                                                "y": 420,
                                                "wires": [
                                                        "e8865a546b6ee97f"
                                                "id": "ee5a65e2896d189b",
                                                "x": 340,
                                                "y": 640,
                                                "wires": [
                                                        "661eb84a02820976"
                                                "id": "661eb84a02820976",
                                                "type": "switch",
                                                "name": "",
                                                "rules": [
                                                        "t": "false"
                                                        "t": "true"
                                                "checkall": "true",
                                                "repair": false,
                                                "outputs": 2,
                                                "x": 430,
                                                "y": 580,
                                                "wires": [
                                                        "a8a0cb4a1682f9f2",
                                                        "3bd2c8cd8fbc4e0d"
                                                        "638dc14da90f5eb4",
                                                        "d5b7b0bf08213264",
                                                        "8791ca72f579691c"
                                                "id": "3c6f79231d0fc04b",
                                                "type": "change",
                                                "name": "Alles auf Anfang",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 1220,
                                                "y": 560,
                                                "wires": [
                                                        "0e43213215238d27"
                                                "id": "d5b7b0bf08213264",
                                                "type": "change",
                                                "name": "stop",
                                                "rules": [
                                                        "t": "set",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "to": "stop",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 610,
                                                "y": 620,
                                                "wires": [
                                                        "5f9435538ec534ed",
                                                        "9b6cc9d834347e2b"
                                                "id": "5f9435538ec534ed",
                                                "type": "mytimeout",
                                                "name": "10min.",
                                                "outtopic": "",
                                                "outsafe": "on",
                                                "outwarning": "Warning",
                                                "outunsafe": "off",
                                                "warning": "10",
                                                "timer": "600",
                                                "debug": false,
                                                "ndebug": false,
                                                "ignoreCase": false,
                                                "repeat": false,
                                                "again": false,
                                                "x": 770,
                                                "y": 560,
                                                "wires": [
                                                        "4deb5666bac8cf44"
                                                "id": "e8865a546b6ee97f",
                                                "name": "3Min.",
                                                "outtopic": "",
                                                "outsafe": "on",
                                                "outunsafe": "off",
                                                "warning": "10",
                                                "timer": "180",
                                                "debug": false,
                                                "ndebug": false,
                                                "repeat": false,
                                                "again": false,
                                                "x": 990,
                                                "y": 500,
                                                "wires": [
                                                        "bcc31acbfde45d97"
                                                "id": "166ff2a331d49e9e",
                                                "name": "Hue",
                                                "x": 130,
                                                "y": 500,
                                                "wires": [
                                                        "d500eca26ab86278"
                                                "id": "d500eca26ab86278",
                                                "name": "KüMo",
                                                "initevents": true,
                                                "x": 270,
                                                "y": 500,
                                                "wires": [
                                                        "169c9cd74337485f",
                                                        "a4c8574588c0de3c"
                                                "id": "631201f88292c2d6",
                                                "name": "U-rechts",
                                                "ack": "false",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "readonly": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1320,
                                                "y": 740,
                                                "wires": []
                                                "id": "400b88291d913b81",
                                                "ack": "false",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "readonly": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1330,
                                                "y": 620,
                                                "wires": []
                                                "id": "ce64922d78c18bb2",
                                                "ack": "false",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "readonly": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1340,
                                                "y": 680,
                                                "wires": []
                                                "id": "b16aaa4000874ffd",
                                                "type": "debug",
                                                "name": "Küche",
                                                "active": true,
                                                "tosidebar": true,
                                                "console": true,
                                                "tostatus": false,
                                                "statusVal": "",
                                                "x": 1440,
                                                "y": 860,
                                                "wires": []
                                                "id": "f5195df37114b7de",
                                                "type": "change",
                                                "name": "Küche",
                                                "rules": [
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "1000",
                                                        "fromt": "str",
                                                        "to": "Küche",
                                                        "tot": "str"
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "true",
                                                        "fromt": "bool",
                                                        "tot": "str"
                                                        "t": "change",
                                                        "p": "payload",
                                                        "pt": "msg",
                                                        "from": "false",
                                                        "fromt": "bool",
                                                        "tot": "str"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 1310,
                                                "y": 860,
                                                "wires": [
                                                        "b16aaa4000874ffd"
                                                "id": "08276b1f6580fc56",
                                                "name": "U-links",
                                                "ack": "false",
                                                "stateName": "",
                                                "role": "",
                                                "payloadType": "",
                                                "readonly": "",
                                                "stateUnit": "",
                                                "stateMin": "",
                                                "stateMax": "",
                                                "x": 1430,
                                                "y": 800,
                                                "wires": []
                                                "id": "587e1a24a2250226",
                                                "type": "inject",
                                                "name": "",
                                                "props": [
                                                        "p": "payload"
                                                        "p": "topic",
                                                        "vt": "str"
                                                "repeat": "",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "",
                                                "payload": "1000",
                                                "payloadType": "str",
                                                "x": 90,
                                                "y": 720,
                                                "wires": [
                                                        "95fda7a91b84c03f"
                                                "id": "f3e6cb95fd339887",
                                                "name": "VIS-Küche",
                                                "topic": "0_userdata.0.GordonX-Home.0.Küche.VIS-Küche",
                                                "onlyack": "",
                                                "func": "all",
                                                "gap": "",
                                                "x": 80,
                                                "y": 660,
                                                "wires": [
                                                        "95fda7a91b84c03f"
                                                "id": "3c0717cd3d6e108e",
                                                "type": "delay",
                                                "name": "100ms",
                                                "timeout": "100",
                                                "rate": "1",
                                                "nbRateUnits": "1",
                                                "randomFirst": "1",
                                                "randomLast": "5",
                                                "drop": false,
                                                "allowrate": false,
                                                "outputs": 1,
                                                "x": 1310,
                                                "y": 800,
                                                "wires": [
                                                        "08276b1f6580fc56"
                                                "id": "805251b70f5d5a93",
                                                "type": "inject",
                                                "name": "Test Bewegung",
                                                "props": [
                                                        "v": "true",
                                                        "vt": "bool"
                                                        "p": "topic",
                                                        "vt": "str"
                                                "repeat": "",
                                                "crontab": "",
                                                "once": false,
                                                "onceDelay": 0.1,
                                                "topic": "Bewegungsmelder",
                                                "x": 240,
                                                "y": 460,
                                                "wires": [
                                                        "169c9cd74337485f",
                                                        "e1f5f49327a29a8a"
                                                "id": "e1f5f49327a29a8a",
                                                "type": "change",
                                                "name": "motion:false",
                                                "rules": [
                                                        "t": "set",
                                                        "pt": "msg",
                                                        "to": "false",
                                                        "tot": "bool"
                                                "action": "",
                                                "property": "",
                                                "from": "",
                                                "to": "",
                                                "reg": false,
                                                "x": 450,
                                                "y": 460,
                                                "wires": [
                                                        "169c9cd74337485f"
                                                "id": "90f844739a331c64",
                                                "type": "junction",
                                                "x": 1060,
                                                "y": 600,
                                                "wires": [
                                                        "3c6f79231d0fc04b",
                                                        "a8b609cc983f0b37"
                                                "id": "f1be18a24ca143f6",
                                                "type": "junction",
                                                "x": 1160,
                                                "y": 680,
                                                "wires": [
                                                        "ce64922d78c18bb2",
                                                        "f5195df37114b7de",
                                                        "631201f88292c2d6",
                                                        "400b88291d913b81",
                                                        "3c0717cd3d6e108e"
                                                "id": "1584a54e77837dbd",
                                                "type": "junction",
                                                "x": 1100,
                                                "y": 480,
                                                "wires": [
                                                        "612158a90f7d1a23"
                                                "id": "e9a12ac84d11dd0e",
                                                "type": "junction",
                                                "x": 980,
                                                "y": 640,
                                                "wires": [
                                                        "90f844739a331c64"
                                                "id": "a8a0cb4a1682f9f2",
                                                "type": "junction",
                                                "x": 540,
                                                "y": 560,
                                                "wires": [
                                                        "5925b1db569c695b"
                                                "id": "3bd2c8cd8fbc4e0d",
                                                "type": "junction",
                                                "x": 540,
                                                "y": 580,
                                                "wires": [
                                                        "3648551e97ec2cab"
                                                "id": "9b6cc9d834347e2b",
                                                "type": "junction",
                                                "x": 880,
                                                "y": 620,
                                                "wires": [
                                                        "e8865a546b6ee97f"
                                                "id": "612158a90f7d1a23",
                                                "type": "junction",
                                                "x": 1260,
                                                "y": 480,
                                                "wires": [
                                                        "0e43213215238d27"
                                                "id": "8791ca72f579691c",
                                                "type": "junction",
                                                "x": 560,
                                                "y": 640,
                                                "wires": [
                                                        "e9a12ac84d11dd0e"
                                                "worker": "10",
                                        • AphofisA Aphofis
                                          @peterfido
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "pt": "msg",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 450,
                                                  "y": 540,
                                                  "wires": [
                                                          "169c9cd74337485f"
                                                  "type": "switch",
                                                  "name": "Schalter",
                                                  "rules": [
                                                          "t": "true"
                                                          "t": "false"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 2,
                                                  "x": 800,
                                                  "y": 500,
                                                  "wires": [
                                                          "ee120a8678492945"
                                                  "type": "change",
                                                  "name": "Motion",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "tot": "msg"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 610,
                                                  "y": 500,
                                                  "wires": [
                                                          "a7c05960eac63d95"
                                                  "type": "comment",
                                                  "info": "",
                                                  "x": 160,
                                                  "y": 420,
                                                  "wires": []
                                                  "type": "change",
                                                  "name": "payload",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "on",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 620,
                                                  "y": 540,
                                                  "wires": [
                                                          "5f9435538ec534ed"
                                                  "type": "switch",
                                                  "name": "1000?",
                                                  "rules": [
                                                          "t": "eq",
                                                          "v": "1000",
                                                          "vt": "num"
                                                          "t": "eq",
                                                          "v": "",
                                                          "vt": "num"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 2,
                                                  "x": 250,
                                                  "y": 600,
                                                  "wires": [
                                                          "ee5a65e2896d189b"
                                                  "type": "switch",
                                                  "name": "Robi",
                                                  "property": "BWM",
                                                  "rules": [
                                                          "t": "true"
                                                          "t": "false"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 2,
                                                  "x": 810,
                                                  "y": 460,
                                                  "wires": [
                                                          "8f4fcec5a545127f"
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "stopp",
                                                          "pt": "flow",
                                                          "to": "true",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 620,
                                                  "y": 580,
                                                  "wires": [
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "stopp",
                                                          "pt": "flow",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 1220,
                                                  "y": 520,
                                                  "wires": [
                                                  "type": "function",
                                                  "outputs": 1,
                                                  "timeout": 0,
                                                  "noerr": 0,
                                                  "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
                                                  "finalize": "",
                                                  "libs": [],
                                                  "x": 1430,
                                                  "y": 460,
                                                  "wires": [
                                                          "f1be18a24ca143f6"
                                                  "name": "Robi",
                                                  "onlyack": "",
                                                  "func": "all",
                                                  "gap": "",
                                                  "x": 370,
                                                  "y": 700,
                                                  "wires": [
                                                          "81fd4c871d668d04"
                                                  "type": "function",
                                                  "name": "Ausg.BWM",
                                                  "func": "\nreturn msg;",
                                                  "outputs": 1,
                                                  "timeout": 0,
                                                  "noerr": 0,
                                                  "initialize": "",
                                                  "finalize": "",
                                                  "libs": [],
                                                  "x": 450,
                                                  "y": 500,
                                                  "wires": [
                                                          "f2bfa3e6a90d48ed"
                                                  "onlyack": "",
                                                  "func": "all",
                                                  "gap": "",
                                                  "x": 80,
                                                  "y": 600,
                                                  "wires": [
                                                          "95fda7a91b84c03f"
                                                  "type": "switch",
                                                  "name": "8?",
                                                  "rules": [
                                                          "t": "eq",
                                                          "v": "8",
                                                          "vt": "num"
                                                          "t": "neq",
                                                          "v": "8",
                                                          "vt": "num"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 2,
                                                  "x": 490,
                                                  "y": 680,
                                                  "wires": [
                                                          "638dc14da90f5eb4"
                                                          "542b940ecfefa127"
                                                  "type": "change",
                                                  "name": "setze Flow.BWM",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "BWM",
                                                          "pt": "flow",
                                                          "to": "true",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 650,
                                                  "y": 660,
                                                  "wires": [
                                                          "3803f5607daeb485"
                                                  "type": "change",
                                                  "name": "lösche Flow.BWM",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "BWM",
                                                          "pt": "flow",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 650,
                                                  "y": 700,
                                                  "wires": [
                                                          "3803f5607daeb485"
                                                  "type": "comment",
                                                  "name": "evtl. gesperrt durch??",
                                                  "info": "",
                                                  "x": 800,
                                                  "y": 380,
                                                  "wires": []
                                                  "type": "switch",
                                                  "name": "nur true",
                                                  "rules": [
                                                          "t": "true"
                                                          "t": "false"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 2,
                                                  "x": 640,
                                                  "y": 460,
                                                  "wires": [
                                                          "f6bc1b429099ca57"
                                                  "type": "debug",
                                                  "name": "debug 9",
                                                  "active": false,
                                                  "tosidebar": true,
                                                  "console": false,
                                                  "tostatus": false,
                                                  "complete": "true",
                                                  "targetType": "full",
                                                  "statusVal": "",
                                                  "x": 820,
                                                  "y": 680,
                                                  "wires": []
                                                  "type": "comment",
                                                  "info": "",
                                                  "x": 160,
                                                  "y": 560,
                                                  "wires": []
                                                  "type": "change",
                                                  "name": "on/off",
                                                  "rules": [
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "on",
                                                          "fromt": "str",
                                                          "to": "true",
                                                          "tot": "bool"
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "off",
                                                          "fromt": "str",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 890,
                                                  "y": 560,
                                                  "wires": [
                                                          "d2eeea8c88021d24"
                                                  "type": "switch",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "true"
                                                          "t": "false"
                                                          "t": "eq",
                                                          "v": "",
                                                          "vt": "str"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 3,
                                                  "x": 1010,
                                                  "y": 560,
                                                  "wires": [
                                                          "1584a54e77837dbd"
                                                          "a8b609cc983f0b37",
                                                          "1584a54e77837dbd"
                                                  "type": "switch",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "true"
                                                          "t": "false"
                                                          "t": "eq",
                                                          "v": "",
                                                          "vt": "str"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 3,
                                                  "x": 1190,
                                                  "y": 460,
                                                  "wires": [
                                                          "0e43213215238d27"
                                                          "0e43213215238d27"
                                                  "type": "change",
                                                  "name": "on/off",
                                                  "rules": [
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "on",
                                                          "fromt": "str",
                                                          "to": "true",
                                                          "tot": "bool"
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "off",
                                                          "fromt": "str",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 990,
                                                  "y": 460,
                                                  "wires": [
                                                          "774f8f940a2c4c96"
                                                  "type": "change",
                                                  "name": "on",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "on",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 810,
                                                  "y": 420,
                                                  "wires": [
                                                          "e8865a546b6ee97f"
                                                  "x": 340,
                                                  "y": 640,
                                                  "wires": [
                                                          "661eb84a02820976"
                                                  "type": "switch",
                                                  "name": "",
                                                  "rules": [
                                                          "t": "false"
                                                          "t": "true"
                                                  "checkall": "true",
                                                  "repair": false,
                                                  "outputs": 2,
                                                  "x": 430,
                                                  "y": 580,
                                                  "wires": [
                                                          "a8a0cb4a1682f9f2",
                                                          "3bd2c8cd8fbc4e0d"
                                                          "638dc14da90f5eb4",
                                                          "d5b7b0bf08213264",
                                                          "8791ca72f579691c"
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 1220,
                                                  "y": 560,
                                                  "wires": [
                                                          "0e43213215238d27"
                                                  "type": "change",
                                                  "name": "stop",
                                                  "rules": [
                                                          "t": "set",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "to": "stop",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 610,
                                                  "y": 620,
                                                  "wires": [
                                                          "5f9435538ec534ed",
                                                          "9b6cc9d834347e2b"
                                                  "name": "10min.",
                                                  "outtopic": "",
                                                  "outsafe": "on",
                                                  "outunsafe": "off",
                                                  "warning": "10",
                                                  "timer": "600",
                                                  "debug": false,
                                                  "ndebug": false,
                                                  "repeat": false,
                                                  "again": false,
                                                  "x": 770,
                                                  "y": 560,
                                                  "wires": [
                                                          "4deb5666bac8cf44"
                                                  "name": "3Min.",
                                                  "outtopic": "",
                                                  "outsafe": "on",
                                                  "outunsafe": "off",
                                                  "warning": "10",
                                                  "timer": "180",
                                                  "debug": false,
                                                  "ndebug": false,
                                                  "repeat": false,
                                                  "again": false,
                                                  "x": 990,
                                                  "y": 500,
                                                  "wires": [
                                                          "bcc31acbfde45d97"
                                                  "name": "Hue",
                                                  "x": 130,
                                                  "y": 500,
                                                  "wires": [
                                                          "d500eca26ab86278"
                                                  "name": "KüMo",
                                                  "initevents": true,
                                                  "x": 270,
                                                  "y": 500,
                                                  "wires": [
                                                          "169c9cd74337485f",
                                                          "a4c8574588c0de3c"
                                                  "name": "U-rechts",
                                                  "ack": "false",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "readonly": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 1320,
                                                  "y": 740,
                                                  "wires": []
                                                  "ack": "false",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "readonly": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 1330,
                                                  "y": 620,
                                                  "wires": []
                                                  "ack": "false",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "readonly": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 1340,
                                                  "y": 680,
                                                  "wires": []
                                                  "type": "debug",
                                                  "name": "Küche",
                                                  "active": true,
                                                  "tosidebar": true,
                                                  "console": true,
                                                  "tostatus": false,
                                                  "statusVal": "",
                                                  "x": 1440,
                                                  "y": 860,
                                                  "wires": []
                                                  "type": "change",
                                                  "name": "Küche",
                                                  "rules": [
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "1000",
                                                          "fromt": "str",
                                                          "to": "Küche",
                                                          "tot": "str"
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "true",
                                                          "fromt": "bool",
                                                          "tot": "str"
                                                          "t": "change",
                                                          "p": "payload",
                                                          "pt": "msg",
                                                          "from": "false",
                                                          "fromt": "bool",
                                                          "tot": "str"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 1310,
                                                  "y": 860,
                                                  "wires": [
                                                          "b16aaa4000874ffd"
                                                  "name": "U-links",
                                                  "ack": "false",
                                                  "stateName": "",
                                                  "role": "",
                                                  "payloadType": "",
                                                  "readonly": "",
                                                  "stateUnit": "",
                                                  "stateMin": "",
                                                  "stateMax": "",
                                                  "x": 1430,
                                                  "y": 800,
                                                  "wires": []
                                                  "type": "inject",
                                                  "name": "",
                                                  "props": [
                                                          "p": "payload"
                                                          "p": "topic",
                                                          "vt": "str"
                                                  "repeat": "",
                                                  "crontab": "",
                                                  "once": false,
                                                  "onceDelay": 0.1,
                                                  "topic": "",
                                                  "payload": "1000",
                                                  "x": 90,
                                                  "y": 720,
                                                  "wires": [
                                                          "95fda7a91b84c03f"
                                                  "onlyack": "",
                                                  "func": "all",
                                                  "gap": "",
                                                  "x": 80,
                                                  "y": 660,
                                                  "wires": [
                                                          "95fda7a91b84c03f"
                                                  "type": "delay",
                                                  "name": "100ms",
                                                  "timeout": "100",
                                                  "rate": "1",
                                                  "nbRateUnits": "1",
                                                  "randomFirst": "1",
                                                  "randomLast": "5",
                                                  "drop": false,
                                                  "allowrate": false,
                                                  "outputs": 1,
                                                  "x": 1310,
                                                  "y": 800,
                                                  "wires": [
                                                          "08276b1f6580fc56"
                                                  "type": "inject",
                                                  "props": [
                                                          "v": "true",
                                                          "vt": "bool"
                                                          "p": "topic",
                                                          "vt": "str"
                                                  "repeat": "",
                                                  "crontab": "",
                                                  "once": false,
                                                  "onceDelay": 0.1,
                                                  "x": 240,
                                                  "y": 460,
                                                  "wires": [
                                                          "169c9cd74337485f",
                                                          "e1f5f49327a29a8a"
                                                  "type": "change",
                                                  "rules": [
                                                          "t": "set",
                                                          "pt": "msg",
                                                          "to": "false",
                                                          "tot": "bool"
                                                  "action": "",
                                                  "property": "",
                                                  "from": "",
                                                  "to": "",
                                                  "reg": false,
                                                  "x": 450,
                                                  "y": 460,
                                                  "wires": [
                                                          "169c9cd74337485f"
                                                  "type": "junction",
                                                  "x": 1060,
                                                  "y": 600,
                                                  "wires": [
                                                          "3c6f79231d0fc04b",
                                                          "a8b609cc983f0b37"
                                                  "type": "junction",
                                                  "x": 1160,
                                                  "y": 680,
                                                  "wires": [
                                                          "ce64922d78c18bb2",
                                                          "f5195df37114b7de",
                                                          "631201f88292c2d6",
                                                          "400b88291d913b81",
                                                          "3c0717cd3d6e108e"
                                                  "type": "junction",
                                                  "x": 1100,
                                                  "y": 480,
                                                  "wires": [
                                                          "612158a90f7d1a23"
                                                  "type": "junction",
                                                  "x": 980,
                                                  "y": 640,
                                                  "wires": [
                                                          "90f844739a331c64"
                                                  "type": "junction",
                                                  "x": 540,
                                                  "y": 560,
                                                  "wires": [
                                                          "5925b1db569c695b"
                                                  "type": "junction",
                                                  "x": 540,
                                                  "y": 580,
                                                  "wires": [
                                                          "3648551e97ec2cab"
                                                  "type": "junction",
                                                  "x": 880,
                                                  "y": 620,
                                                  "wires": [
                                                          "e8865a546b6ee97f"
                                                  "type": "junction",
                                                  "x": 1260,
                                                  "y": 480,
                                                  "wires": [
                                                          "0e43213215238d27"
                                                  "type": "junction",
                                                  "x": 560,
                                                  "y": 640,
                                                  "wires": [
                                                          "e9a12ac84d11dd0e"
                                                  "worker": "10",
                                          peterfido
                                          @aphofis Das ist eine neue Variante. Meine "Simulation" des HUE Bewegungsmelders hast Du noch nicht verinnerlicht. Die ist rein für Tests, oder, wenn man wie ich keinen HUE BWM hat. Das ist nur für die Simulation zum Testen, und dann auch erst nach einer Zeit x vorgesehen. Jetzt wird zeitgleich payload.motion auf false gesetzt, auch wenn der HUE BWM meldet.
                                          Ich habe es jetzt nicht importiert / ausprobiert.
                                          Eine Idee:
                                          Der HUE Bewegungsmelder geht seine eigenen Wege. Wenn das Licht nicht aus, bzw. gleich wieder an geht, könnte einer erkannten, oder noch anstehenden Bewegung geschuldet sein. Da könnte man eine Sperrvarable setzen, bzw. nur Änderungen durchlassen. Zumindest lief die von mir zuletzt gepostete Variante in meiner Testumgebung. Möglich, dass Dein BWM / Taster / Schalter da was unerwartetes losschickt.
                                          Hier mein aufgeräumter Flow.
                                                 "type": "tab",
                                                 "label": "Flow 8",
                                                 "disabled": false,
                                                 "info": "",
                                                 "env": []
                                                 "type": "junction",
                                                 "x": 1120,
                                                 "y": 660,
                                                 "wires": [
                                                         "141a052859674836",
                                                         "574a9f7ddc4f663b",
                                                         "b6322a40cf4557b3"
                                                 "type": "junction",
                                                 "x": 1960,
                                                 "y": 460,
                                                 "wires": [
                                                         "ff32f89078260f0e",
                                                         "67e2e01a1266d1c3",
                                                         "e98816534075b0f5",
                                                         "21f36ea2695afe19",
                                                         "a695276a00fe8f61"
                                                 "type": "junction",
                                                 "x": 1140,
                                                 "y": 260,
                                                 "wires": [
                                                         "ba0aea0ff71ebc3d"
                                                 "type": "junction",
                                                 "x": 520,
                                                 "y": 60,
                                                 "wires": [
                                                         "d24a5429e472b18a"
                                                 "type": "junction",
                                                 "x": 900,
                                                 "y": 440,
                                                 "wires": [
                                                         "84bd4ea1d044fea4",
                                                         "ed2607cafe826532"
                                                 "type": "junction",
                                                 "x": 980,
                                                 "y": 360,
                                                 "wires": [
                                                         "be66da991b562e24"
                                                 "type": "junction",
                                                 "x": 1280,
                                                 "y": 360,
                                                 "wires": [
                                                         "fa5f2b5bcd258a98"
                                                 "id": "8355cf791b8a8b1b",
                                                 "type": "junction",
                                                 "x": 580,
                                                 "y": 560,
                                                 "wires": [
                                                         "e22b60db6265e908"
                                                 "id": "1ee1fe89c1628b34",
                                                 "type": "junction",
                                                 "x": 580,
                                                 "y": 560,
                                                 "wires": [
                                                         "e22b60db6265e908"
                                                 "id": "f3921b2658b5916c",
                                                 "type": "junction",
                                                 "x": 240,
                                                 "y": 560,
                                                 "wires": [
                                                         "1ee1fe89c1628b34"
                                                 "type": "inject",
                                                 "props": [
                                                         "v": "true",
                                                         "vt": "bool"
                                                         "p": "topic",
                                                         "vt": "str"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "x": 140,
                                                 "y": 380,
                                                 "wires": [
                                                         "a919a4c30d900c39",
                                                         "0150c15cf7b51170"
                                                 "type": "debug",
                                                 "name": "debug 3",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "complete": "true",
                                                 "statusVal": "",
                                                 "x": 2000,
                                                 "y": 360,
                                                 "wires": []
                                                 "type": "delay",
                                                 "name": "",
                                                 "timeout": "30",
                                                 "timeoutUnits": "seconds",
                                                 "rate": "1",
                                                 "nbRateUnits": "1",
                                                 "randomFirst": "1",
                                                 "randomLast": "5",
                                                 "drop": false,
                                                 "allowrate": false,
                                                 "outputs": 1,
                                                 "x": 150,
                                                 "y": 460,
                                                 "wires": [
                                                         "bee64eb116d76ed1"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "pt": "msg",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 350,
                                                 "y": 460,
                                                 "wires": [
                                                         "0150c15cf7b51170"
                                                 "type": "switch",
                                                 "name": "Schalter",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 920,
                                                 "y": 260,
                                                 "wires": [
                                                         "01fea99b98c641a3"
                                                 "type": "change",
                                                 "name": "Motion",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "bewegung",
                                                         "pt": "flow",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 670,
                                                 "y": 320,
                                                 "wires": [
                                                 "type": "comment",
                                                 "name": "Beginn << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                                                 "info": "",
                                                 "x": 280,
                                                 "y": 300,
                                                 "wires": []
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "on",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 710,
                                                 "y": 400,
                                                 "wires": [
                                                         "ed2607cafe826532"
                                                 "type": "switch",
                                                 "name": "1000?",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "1000",
                                                         "vt": "num"
                                                         "t": "eq",
                                                         "v": "",
                                                         "vt": "num"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 310,
                                                 "y": 660,
                                                 "wires": [
                                                         "6ae2e0e61f81faeb"
                                                 "type": "switch",
                                                 "name": "Robi",
                                                 "property": "BWM",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 1050,
                                                 "y": 260,
                                                 "wires": [
                                                         "ae8ceff406113f11"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "stopp",
                                                         "pt": "flow",
                                                         "to": "true",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 890,
                                                 "y": 600,
                                                 "wires": [
                                                 "type": "change",
                                                 "z": "b802892eed83e90f",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "stopp",
                                                         "pt": "flow",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1370,
                                                 "y": 600,
                                                 "wires": [
                                                 "type": "function",
                                                 "name": "Variablen Ini + Ausgabe",
                                                 "outputs": 1,
                                                 "timeout": 0,
                                                 "noerr": 0,
                                                 "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\n",
                                                 "finalize": "",
                                                 "libs": [],
                                                 "x": 1770,
                                                 "y": 380,
                                                 "wires": [
                                                         "ed06e85de97289c8",
                                                         "423ea0f1dc0e4d31"
                                                 "name": "Robi",
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 90,
                                                 "y": 780,
                                                 "wires": [
                                                         "6b214a0a59b5e04a"
                                                 "type": "function",
                                                 "name": "Ausgang BWM",
                                                 "outputs": 1,
                                                 "timeout": 0,
                                                 "noerr": 0,
                                                 "initialize": "",
                                                 "finalize": "",
                                                 "libs": [],
                                                 "x": 360,
                                                 "y": 360,
                                                 "wires": [
                                                         "0395e4bbb7c67e21"
                                                 "onlyack": "",
                                                 "func": "all",
                                                 "gap": "",
                                                 "x": 100,
                                                 "y": 680,
                                                 "wires": [
                                                         "e22b60db6265e908"
                                                 "type": "switch",
                                                 "name": "8?",
                                                 "rules": [
                                                         "t": "eq",
                                                         "v": "8",
                                                         "vt": "num"
                                                         "t": "neq",
                                                         "v": "8",
                                                         "vt": "num"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 630,
                                                 "y": 780,
                                                 "wires": [
                                                         "7b9c0fa6e795af2d"
                                                         "ccadbb1ee1de29e6"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "BWM",
                                                         "pt": "flow",
                                                         "to": "true",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 850,
                                                 "y": 760,
                                                 "wires": [
                                                         "b117dac109d51b34"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "BWM",
                                                         "pt": "flow",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 850,
                                                 "y": 800,
                                                 "wires": [
                                                         "b117dac109d51b34"
                                                 "type": "comment",
                                                 "info": "",
                                                 "x": 980,
                                                 "y": 220,
                                                 "wires": []
                                                 "type": "switch",
                                                 "name": "nur true",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 740,
                                                 "y": 240,
                                                 "wires": [
                                                         "ab41883686b27cc0"
                                                 "type": "debug",
                                                 "name": "debug 4",
                                                 "active": false,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "complete": "true",
                                                 "statusVal": "",
                                                 "x": 1040,
                                                 "y": 760,
                                                 "wires": []
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "on",
                                                         "fromt": "str",
                                                         "to": "true",
                                                         "tot": "bool"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "off",
                                                         "fromt": "str",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1290,
                                                 "y": 400,
                                                 "wires": [
                                                         "d303b6e1817d8b77"
                                                 "type": "switch",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                         "t": "eq",
                                                         "v": "",
                                                         "vt": "str"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 3,
                                                 "x": 1470,
                                                 "y": 400,
                                                 "wires": [
                                                         "331a07cfba2d7df1"
                                                         "331a07cfba2d7df1",
                                                         "574a9f7ddc4f663b"
                                                 "type": "switch",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "true"
                                                         "t": "false"
                                                         "t": "eq",
                                                         "v": "",
                                                         "vt": "str"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 3,
                                                 "x": 1770,
                                                 "y": 260,
                                                 "wires": [
                                                         "331a07cfba2d7df1"
                                                         "331a07cfba2d7df1"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "on",
                                                         "fromt": "str",
                                                         "to": "true",
                                                         "tot": "bool"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "off",
                                                         "fromt": "str",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1610,
                                                 "y": 260,
                                                 "wires": [
                                                         "b4e55cb04c30244e"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "on",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1250,
                                                 "y": 260,
                                                 "wires": [
                                                         "fa5f2b5bcd258a98"
                                                 "x": 500,
                                                 "y": 660,
                                                 "wires": [
                                                         "cf3016a536d38a8d"
                                                 "type": "switch",
                                                 "rules": [
                                                         "t": "false"
                                                         "t": "true"
                                                 "checkall": "true",
                                                 "repair": false,
                                                 "outputs": 2,
                                                 "x": 680,
                                                 "y": 660,
                                                 "wires": [
                                                         "7eea52e80cbe51f0",
                                                         "93f0d4c85ab42e59"
                                                         "7b9c0fa6e795af2d",
                                                         "87ec46662c49de4e",
                                                         "f00e20abd94ff43d"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1380,
                                                 "y": 640,
                                                 "wires": [
                                                         "331a07cfba2d7df1"
                                                 "type": "change",
                                                 "name": "stop",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "stop",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1010,
                                                 "y": 640,
                                                 "wires": [
                                                         "d96f128a59bdfbb4"
                                                 "name": "45sek",
                                                 "outtopic": "",
                                                 "outsafe": "on",
                                                 "outunsafe": "off",
                                                 "warning": "10",
                                                 "timer": "60",
                                                 "debug": false,
                                                 "ndebug": false,
                                                 "repeat": false,
                                                 "again": false,
                                                 "x": 1090,
                                                 "y": 400,
                                                 "wires": [
                                                         "91febc7692f9b822"
                                                 "name": "10Sek",
                                                 "outtopic": "",
                                                 "outsafe": "on",
                                                 "outunsafe": "off",
                                                 "warning": "10",
                                                 "timer": "30",
                                                 "debug": false,
                                                 "ndebug": false,
                                                 "repeat": false,
                                                 "again": false,
                                                 "x": 1430,
                                                 "y": 260,
                                                 "wires": [
                                                         "90c9685b4a5344dc"
                                                 "name": "U-rechts",
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 2140,
                                                 "y": 600,
                                                 "wires": []
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 2210,
                                                 "y": 460,
                                                 "wires": []
                                                 "ack": "false",
                                                 "autoCreate": "true",
                                                 "stateName": "Simlulierte Lampe",
                                                 "role": "value",
                                                 "payloadType": "boolean",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 2160,
                                                 "y": 540,
                                                 "wires": []
                                                 "type": "debug",
                                                 "name": "Küche",
                                                 "active": false,
                                                 "tosidebar": true,
                                                 "console": true,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 2160,
                                                 "y": 760,
                                                 "wires": []
                                                 "type": "delay",
                                                 "name": "100ms",
                                                 "timeout": "100",
                                                 "rate": "1",
                                                 "nbRateUnits": "1",
                                                 "randomFirst": "1",
                                                 "randomLast": "5",
                                                 "drop": false,
                                                 "allowrate": false,
                                                 "outputs": 1,
                                                 "x": 2070,
                                                 "y": 460,
                                                 "wires": [
                                                         "084e7114b7ed1c61"
                                                 "type": "change",
                                                 "name": "Küche",
                                                 "rules": [
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "1000",
                                                         "fromt": "str",
                                                         "to": "Küche",
                                                         "tot": "str"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "true",
                                                         "fromt": "bool",
                                                         "tot": "str"
                                                         "t": "change",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "from": "false",
                                                         "fromt": "bool",
                                                         "tot": "str"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 2030,
                                                 "y": 760,
                                                 "wires": [
                                                         "442c2ef743d9599f"
                                                 "name": "U-links",
                                                 "ack": "false",
                                                 "stateName": "",
                                                 "role": "",
                                                 "payloadType": "",
                                                 "readonly": "",
                                                 "stateUnit": "",
                                                 "stateMin": "",
                                                 "stateMax": "",
                                                 "x": 2130,
                                                 "y": 680,
                                                 "wires": []
                                                 "name": "Hue",
                                                 "x": 130,
                                                 "y": 160,
                                                 "wires": [
                                                         "2e0c2a67486c0ac7"
                                                 "initevents": true,
                                                 "x": 360,
                                                 "y": 160,
                                                 "wires": [
                                                         "0395e4bbb7c67e21"
                                                 "type": "inject",
                                                 "name": "Takt",
                                                 "props": [
                                                         "p": "payload"
                                                         "p": "topic",
                                                         "vt": "str"
                                                 "repeat": "1",
                                                 "crontab": "",
                                                 "once": true,
                                                 "onceDelay": 0.1,
                                                 "topic": "Takt",
                                                 "payload": "true",
                                                 "x": 130,
                                                 "y": 60,
                                                 "wires": [
                                                         "26a06677287b879b"
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "bewegung",
                                                         "tot": "flow"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 370,
                                                 "y": 60,
                                                 "wires": [
                                                         "9c7c62ee37b6b12c"
                                                 "type": "inject",
                                                 "props": [
                                                         "p": "payload"
                                                         "p": "topic",
                                                         "vt": "str"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "1000",
                                                 "payloadType": "num",
                                                 "x": 130,
                                                 "y": 520,
                                                 "wires": [
                                                         "64bf8df5efc25d40",
                                                         "f3921b2658b5916c"
                                                 "type": "change",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "bewegung",
                                                         "pt": "flow",
                                                         "to": "false",
                                                         "tot": "bool"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1390,
                                                 "y": 680,
                                                 "wires": [
                                                 "type": "comment",
                                                 "name": "Ende << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                                                 "info": "",
                                                 "x": 270,
                                                 "y": 580,
                                                 "wires": []
                                                 "type": "comment",
                                                 "info": "",
                                                 "x": 980,
                                                 "y": 320,
                                                 "wires": []
                                                 "id": "64bf8df5efc25d40",
                                                 "type": "delay",
                                                 "name": "200 ms",
                                                 "timeout": "200",
                                                 "rate": "1",
                                                 "nbRateUnits": "1",
                                                 "randomFirst": "1",
                                                 "randomLast": "5",
                                                 "drop": false,
                                                 "allowrate": false,
                                                 "outputs": 1,
                                                 "x": 300,
                                                 "y": 520,
                                                 "wires": [
                                                         "d628f1137cfb08c1"
                                                 "id": "d628f1137cfb08c1",
                                                 "type": "change",
                                                 "name": "1002",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "to": "1002",
                                                         "tot": "num"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 430,
                                                 "y": 520,
                                                 "wires": [
                                                         "8355cf791b8a8b1b"
                                                 "id": "9a70fab410cfbdae",
                                                 "type": "inject",
                                                 "name": "Test Robi 8",
                                                 "props": [
                                                         "p": "payload"
                                                         "p": "topic",
                                                         "vt": "str"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "8",
                                                 "x": 120,
                                                 "y": 840,
                                                 "wires": [
                                                         "6b214a0a59b5e04a"
                                                 "id": "10a3703ea5e9c5fd",
                                                 "type": "inject",
                                                 "name": "Test Robi 5",
                                                 "props": [
                                                         "p": "payload"
                                                         "p": "topic",
                                                         "vt": "str"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "payload": "5",
                                                 "x": 120,
                                                 "y": 900,
                                                 "wires": [
                                                         "6b214a0a59b5e04a"
                                                 "worker": "10",
                                                 "autoupdates": true,
                                          Peterfido
                                          AphofisA 1 Antwort Letzte Antwort
