  4. Problem mit Ring-Adapter
    6.7k
34 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • S Stefan341
    Ich versuche es nochmal, vielleicht hat ja jemand noch eine Idee:
    Sobald ich den Ring-Adapter starte, liefert er pausenlos Fehlermeldungen.
    2025-03-22 08:59:03.308 - info: ring.0 (3998066) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.ring, node: v20.19.0, js-controller: 7.0.6
    2025-03-22 08:59:03.321 - info: ring.0 (3998066) Initializing Api Client
    2025-03-22 08:59:06.715 - info: ring.0 (3998066) Received new Refresh Token. Will use the new one until the token in config gets changed
    2025-03-22 08:59:13.877 - info: ring.0 (3998066) Device 213497705 ("Haustür"): Create scheduled Job for HD Snapshot at "*/5 * * * * *"
    2025-03-22 08:59:13.918 - info: ring.0 (3998066) Device 384912755 ("Parkplatz"): Create scheduled Job for HD Snapshot at "*/5 * * * * *"
    2025-03-22 08:59:13.920 - info: ring.0 (3998066) Get sunset and sunrise
    2025-03-22 08:59:13.939 - info: ring.0 (3998066) Daily sun parameter calculation scheduled for 00:00:40
    2025-03-22 08:59:15.003 - info: ring.0 (3998066) Device 384912755 ("Parkplatz"): Cronjob Auto save HD Snapshot starts
    2025-03-22 08:59:15.004 - info: ring.0 (3998066) Device 213497705 ("Haustür"): Cronjob Auto save HD Snapshot starts
    2025-03-22 08:59:20.004 - warn: ring.0 (3998066) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:20.005 - warn: ring.0 (3998066) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:25.004 - warn: ring.0 (3998066) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:25.005 - warn: ring.0 (3998066) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:30.003 - warn: ring.0 (3998066) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:30.004 - warn: ring.0 (3998066) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:35.002 - warn: ring.0 (3998066) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:35.002 - warn: ring.0 (3998066) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:40.003 - warn: ring.0 (3998066) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    2025-03-22 08:59:40.004 - warn: ring.0 (3998066) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
    Hat vielleicht jemand noch eine Idee was da falsch läuft?
    haselchenH Offline
    haselchenH Offline
    haselchen
    @stefan341
    Nimm hier mal bei beiden Einträgen die 5sek raus
    S 2 Antworten Letzte Antwort
    • haselchenH haselchen
      @stefan341
      Stefan341
      @haselchen said in Problem mit Ring-Adapter:
      @stefan341
      Hab ich gemacht, danach den Adapter neu gestartet. Bringt nicht viel.
      2025-03-22 13:13:27.648 - info: host.ioB-Master stopInstance system.adapter.ring.0 (force=false, process=true)
      2025-03-22 13:13:27.654 - info: ring.0 (3998066) Got terminate signal TERMINATE_YOURSELF
      2025-03-22 13:13:27.655 - info: ring.0 (3998066) terminating
      2025-03-22 13:13:27.655 - info: ring.0 (3998066) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-03-22 13:13:27.781 - info: host.ioB-Master stopInstance system.adapter.ring.0 send kill signal
      2025-03-22 13:13:28.156 - info: ring.0 (3998066) terminating
      2025-03-22 13:13:28.782 - info: host.ioB-Master stopInstance timeout system.adapter.ring.0 killing pid 3998066
      2025-03-22 13:13:28.873 - warn: host.ioB-Master instance system.adapter.ring.0 terminated due to SIGKILL
      2025-03-22 13:13:28.873 - info: host.ioB-Master instance system.adapter.ring.0 terminated with code null ()
      2025-03-22 13:13:32.258 - info: host.ioB-Master instance system.adapter.ring.0 in version "6.3.0" started with pid 3998701
      2025-03-22 13:13:33.747 - info: ring.0 (3998701) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.ring, node: v20.19.0, js-controller: 7.0.6
      2025-03-22 13:13:33.760 - info: ring.0 (3998701) Initializing Api Client
      2025-03-22 13:13:37.168 - info: ring.0 (3998701) Received new Refresh Token. Will use the new one until the token in config gets changed
      2025-03-22 13:13:44.326 - info: ring.0 (3998701) Device 213497705 ("Haustür"): Create scheduled Job for HD Snapshot at "*/5 * * * * *"
      2025-03-22 13:13:44.361 - info: ring.0 (3998701) Device 384912755 ("Parkplatz"): Create scheduled Job for HD Snapshot at "*/5 * * * * *"
      2025-03-22 13:13:44.362 - info: ring.0 (3998701) Get sunset and sunrise
      2025-03-22 13:13:44.376 - info: ring.0 (3998701) Daily sun parameter calculation scheduled for 00:00:29
      2025-03-22 13:13:45.002 - info: ring.0 (3998701) Device 384912755 ("Parkplatz"): Cronjob Auto save HD Snapshot starts
      2025-03-22 13:13:45.004 - info: ring.0 (3998701) Device 213497705 ("Haustür"): Cronjob Auto save HD Snapshot starts
      2025-03-22 13:13:45.448 - info: host.ioB-Master stopInstance system.adapter.ring.0 (force=false, process=true)
      2025-03-22 13:13:45.450 - info: ring.0 (3998701) Got terminate signal TERMINATE_YOURSELF
      2025-03-22 13:13:45.452 - info: ring.0 (3998701) terminating
      2025-03-22 13:13:45.452 - info: ring.0 (3998701) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-03-22 13:13:45.503 - info: host.ioB-Master stopInstance system.adapter.ring.0 send kill signal
      2025-03-22 13:13:45.953 - info: ring.0 (3998701) terminating
      2025-03-22 13:13:46.502 - info: host.ioB-Master stopInstance timeout system.adapter.ring.0 killing pid 3998701
      2025-03-22 13:13:46.567 - warn: host.ioB-Master instance system.adapter.ring.0 terminated due to SIGKILL
      2025-03-22 13:13:46.567 - info: host.ioB-Master instance system.adapter.ring.0 terminated with code null ()
      2025-03-22 13:13:49.955 - info: host.ioB-Master instance system.adapter.ring.0 in version "6.3.0" started with pid 3998716
      2025-03-22 13:13:51.428 - info: ring.0 (3998716) starting. Version 6.3.0 in /opt/iobroker/node_modules/iobroker.ring, node: v20.19.0, js-controller: 7.0.6
      2025-03-22 13:13:51.453 - info: ring.0 (3998716) Initializing Api Client
      2025-03-22 13:13:54.913 - info: ring.0 (3998716) Received new Refresh Token. Will use the new one until the token in config gets changed
      2025-03-22 13:14:02.024 - info: ring.0 (3998716) Device 213497705 ("Haustür"): Create scheduled Job for HD Snapshot at "*/5 * * * * *"
      2025-03-22 13:14:02.055 - info: ring.0 (3998716) Device 384912755 ("Parkplatz"): Create scheduled Job for HD Snapshot at "*/5 * * * * *"
      2025-03-22 13:14:02.058 - info: ring.0 (3998716) Get sunset and sunrise
      2025-03-22 13:14:02.074 - info: ring.0 (3998716) Daily sun parameter calculation scheduled for 00:00:28
      2025-03-22 13:14:05.004 - info: ring.0 (3998716) Device 384912755 ("Parkplatz"): Cronjob Auto save HD Snapshot starts
      2025-03-22 13:14:05.006 - info: ring.0 (3998716) Device 213497705 ("Haustür"): Cronjob Auto save HD Snapshot starts
      2025-03-22 13:14:10.003 - warn: ring.0 (3998716) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:10.004 - warn: ring.0 (3998716) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:15.005 - warn: ring.0 (3998716) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:15.006 - warn: ring.0 (3998716) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:20.004 - warn: ring.0 (3998716) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:20.006 - warn: ring.0 (3998716) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:25.003 - warn: ring.0 (3998716) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:25.003 - warn: ring.0 (3998716) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:30.002 - warn: ring.0 (3998716) Device 213497705 ("Haustür"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      2025-03-22 13:14:30.003 - warn: ring.0 (3998716) Device 384912755 ("Parkplatz"): Cronjob HD Snapshot not executed because another job is already running. Please adapt timer and/or duration time!
      Da wird alle 5Min was ausgeführt oder? Könnte das damit zu tun haben?
      • S Stefan341
        @stefan341
        haselchenH Offline
        haselchenH Offline
        haselchen
        @stefan341
        Alle 5 sek
        Und das würde zu der Einstellung passen, die ich vorhin gepostet habe
        Edit: woher kommt der Cronjob aus dem 2.Log?
          @stefan341
          Stefan341
          schrieb am zuletzt editiert von Stefan341
          @stefan341
          Das habe ich gemacht. Sieht jetzt genauso aus wie auf deinem Screenshot.
          @stefan341
          Alle 5 sek
          Ob es ein Cronjob ist, keine Ahnung. Es wird ausgeführt wenn ich den Adapter starte. Es ist in dem ersten Log auch enthalten, ich habe es im zweiten Log nur nochmal separiert.
          • S Stefan341
            @stefan341
            @stefan341
            Alle 5 sek
            Stefan341
            Ich hole das Thema nochmal hoch. Vielleicht hat noch jemand eine Idee?
            • S Stefan341
              Stefan341
              Ich hole das Thema nochmal hoch. Folgendes hat sich ergeben bzw ich denke das ich den Fehler gefunden habe, benötige aber trotzdem noch etwas Hilfe:
              In den Datenpunkten des Ring-Adapters finde ich den Datenpunkt history_url. wenn ich den Link aus dem DP in meinen DP einfüge den meine VIS ausliest, wird das Bild angezeigt und alles funktioniert wie es soll.
              Das habe ich jetzt versucht zu automatisieren:
              Als Trigger erschien mit der DP des Adapters sinnvoll, wo das Datum und die Uhrzeit der letzten Aktion rein geschrieben wird.
              Wenn ich das so laufen lasse, bekomme ich folgende Logeinträge
              ring.0
              3748	2025-05-29 21:30:58.747	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              ring.0
              3748	2025-05-29 21:30:58.747	error	unhandled promise rejection: Parameter "filename" needs to be of type "string" but type "undefined" has been passed
              ring.0
              3748	2025-05-29 21:30:58.748	error	Error: Parameter "filename" needs to be of type "string" but type "undefined" has been passed at Validator.assertString (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:166:13) at RingAdapter.writeFile (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4398:32) at /opt/iobroker/node_modules/iobroker.ring/build/lib/services/file-service.js:103:21 at new Promise (<anonymous>) at FileService.writeFile (/opt/iobroker/node_modules/iobroker.ring/build/lib/services/file-service.js:89:16) at OwnRingCamera.takeSnapshot (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:319:42) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async OwnRingCamera.notifyRecording (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:841:51)
              ring.0
              3748	2025-05-29 21:30:58.749	error	Parameter "filename" needs to be of type "string" but type "undefined" has been passed
              host.ioB-Master
              2025-05-29 21:30:59.320	error	instance system.adapter.ring.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
              host.ioB-Slave
              2025-05-29 21:31:42.253	error	instance system.adapter.daswetter.0 having pid 9609 terminated with code 15 (UNKNOWN_ERROR)
              Und jetzt komme ich nicht weiter... der Datenpunkt in den geschrieben wird mit dem Script ist vom Typ String.
              • haselchenH Offline
                haselchenH Offline
                haselchen
                @stefan341
                Soweit ich weiss, muss man die Bilder mit dem writeFile Befehl in einen bestimmten Ordner schreiben , damit sie von der VIS akzeptiert werden (tmp Ordner z.B.)
                Schon nen paar Jahre alt, aber sollte noch so stimmen (Beispielskript)
                var fs = require('fs');
                exec('wget --output-document /tmp/alarm5.jpg \'http://192.168.8.95:8765/picture/1/current/?_username=xxxx&_signature=ba8317b8fc071dadb725d4d0d9dbf7e606acbf1e\'');
                const bild = fs.readFileSync('/tmp/alarm5.jpg');
                writeFile('vis.0','alarm5.jpg', bild);
                Edit: gibt mit Sicherheit aktuell galantere Lösungen. So habe und praktiziere ich es aktuell.
                  @stefan341
                  Stefan341
                  Die VIS akzeptiert das Video und spielt es in Dauerschleife, so wie es sein soll. Ich kann nur die URL vom Ring-Adater nicht in meinen Datenpunkt schreiben den die VIS ausliest. Schreibe ich die URL manuell in den DP, geht es.
                  Es müsste jetzt nur wenn sich im Adapter der DP mit Datum und Uhrzeit ändert, die URL des aktuellen Videos aus dem DP des Adapters in den DP, den meine VIS ausliest übergeben werden.
                  Von welchem Typ muss der DP sein in den eine URL geschrieben wird? Bei mir ist es String. Das scheint aber ja lt. den Logs nicht ok zu sein.
                  • S Stefan341
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @stefan341
                    In Deinem letzten Thread war die Rede von einem Bild….
                      @stefan341
                      Stefan341
                      @stefan341
                      Ich könnte jetzt antworten mit "Videos bestehen doch auch aus Bildern..." aber ok, ich habe das etwas undeutlich formuliert. Also gemeint ist das Video vom letzten Ereignis, dass dann in der Vis in Dauerschleife läuft, bis zum nächsten Ereignis.
