  4. Wolf Smart Set
    6.7k
Wolf Smart Set
30 Beiträge 8 Kommentatoren 4.0k Aufrufe 7 Beobachtet
  • W Wch
    @oxident thx, ich check das mal. 👍
    manrum1
    @wch Gibts es jemand, der ismmqtt zusammen mit iobroker am Laufen hat. Ich schaffe es nicht, MQTT ans Laufen zubringen, folgendes ist mein Aufruf:
    pi@iob1:/opt/ism7mqtt $ ./ism7mqtt -i ism7  -p PASSWORT -m iob1 --mqttuser=mqtt --mqttpass=mqttPASSWORT --mqttport:1886  --parameter=/opt/ism7mqtt/parameter.json
    #System.Net.Sockets.SocketException (0xFFFDFFFF): Name or service not known
       at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError, CancellationToken)
       at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16)
       at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|285_0(AwaitableSocketAsyncEventArgs, ValueTask, CancellationToken)
       at System.Net.Sockets.TcpClient.CompleteConnectAsync(ValueTask)
       at ism7mqtt.Ism7Client.ConnectAsync(CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client.cs:line 63
       at ism7mqtt.Ism7Client.RunAsync(String password, CancellationToken cancellationToken) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/ISM7/Ism7Client.cs:line 50
       at ism7mqtt.Program.Main(String[] args) in /home/runner/work/ism7mqtt/ism7mqtt/src/ism7mqtt/Program.cs:line 144
    Unhandled exception. System.Net.Sockets.SocketException (0xFFFDFFFF): Name or service not known
    code_text
    Abgebrochen
    Das Log am iobroker schaut so aus:
    mqtt.0
    	2025-05-19 17:51:40.266	info	Client [Wolf_ism7 ] connection closed: closed
    mqtt.0
    	2025-05-19 17:51:36.689	info	Client [Wolf_ism7 ] publishOnSubscribe send all known states
    mqtt.0
    	2025-05-19 17:51:36.629	info	Client [Wolf_ism7 ] publishOnSubscribe send all known states
    mqtt.0
    	2025-05-19 17:51:36.489	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set/#" with regex /^mqtt\.0\.Wolf\.ism7_\.[^.]*\.set\..*/
    mqtt.0
    	2025-05-19 17:51:36.488	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set/#" with regex /^Wolf\.ism7_\.[^.]*\.set\..*/
    mqtt.0
    	2025-05-19 17:51:36.429	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set" with regex /mqtt\.0\.Wolf\.ism7_\.[^.]*\.set/
    mqtt.0
    	2025-05-19 17:51:36.428	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set" with regex /Wolf\.ism7_\.[^.]*\.set/
    mqtt.0
    	2025-05-19 17:51:36.258	info	Client [Wolf_ism7 ] connected with secret 1747669896030_308
    • M manrum1
      code_text
      Abgebrochen
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      mqtt.0
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      @manrum1 sagte in Wolf Smart Set:
      • es müsste "--mqttport=1886" heißen
      • stelle sicher, dass "ism7" und "iob1" DNS-seitig auflösbar sind (z.B. mit ping ism7), oder nutze die IP-Adresse
      • Marc BergM Marc Berg
        manrum1
        schrieb am zuletzt editiert von manrum1
        @marc-berg Danke für die Antwort, hatte ich schon bemerkt und korrigiert:
        pi@iob1:/opt/ism7mqtt $ ./ism7mqtt -i ism7  -p PASSWORT -m localhost --mqttuser=mqtt --mqttpass=PASSWORT --mqttport=1886
           at ism7mqtt.Program.<Main>(String[] args)
        Abgebrochen
        Er authentifiziert sich auch, so schaut das Log am iobroker aus
        mqtt.0
        	2025-05-20 10:25:30.634	info	Client [Wolf_ism7 ] connection closed: closed
        mqtt.0
        	2025-05-20 10:25:26.768	info	Client [Wolf_ism7 ] publishOnSubscribe send all known states
        mqtt.0
        	2025-05-20 10:25:26.716	info	Client [Wolf_ism7 ] publishOnSubscribe send all known states
        mqtt.0
        	2025-05-20 10:25:26.567	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set/#" with regex /^mqtt\.0\.Wolf\.ism7_\.[^.]*\.set\..*/
        mqtt.0
        	2025-05-20 10:25:26.567	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set/#" with regex /^Wolf\.ism7_\.[^.]*\.set\..*/
        mqtt.0
        	2025-05-20 10:25:26.515	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set" with regex /mqtt\.0\.Wolf\.ism7_\.[^.]*\.set/
        mqtt.0
        	2025-05-20 10:25:26.514	info	Client [Wolf_ism7 ] subscribes on "Wolf/ism7 /+/set" with regex /Wolf\.ism7_\.[^.]*\.set/
        mqtt.0
        	2025-05-20 10:25:26.334	info	Client [Wolf_ism7 ] connected with secret 1747729526126_8073
        Das ist alles was ich unter Objects sehe
        Dann weiß ich nicht was ich noch faslch mache 😞
        • M manrum1
          Abgebrochen
          mqtt.0
          mqtt.0
          mqtt.0
          mqtt.0
          mqtt.0
          mqtt.0
          mqtt.0
          mqtt.0
          Marc BergM Offline
          Marc BergM Offline
          Marc Berg
          Hast du das geprüft?
            manrum1
            @marc-berg Ja habe ich, bekomme ja auch eine Verbindung. Gleicher Aufruf mit IP-Adressen führt zum gleichen Ergebnis.
            • M manrum1
              Marc BergM Offline
              Marc BergM Offline
              Marc Berg
              @manrum1
              Wenn ism7mqtt bereits als service läuft, bekommst du über die Kommandozeile keine zweite Verbindung hin. Was sagt:
              sudo systemctl status ism7mqtt.service
              Ist die parameter.json korrekt gepflegt?
                @manrum1
                manrum1
                @marc-berg said in Wolf Smart Set:
                Ich habe noch keinen Service eingerichtet. Das Parameter-File konnte ich mit ism7config ohne Probleme erzeugen. Ich hängs mal an:
                parameter.json
                Eine Instanz im iobroker läuft, die liest die Daten vom WOlf Portatl (smartset). Stört das vielleicht?
                U 1 Antwort Letzte Antwort
                • M manrum1
                  parameter.json
                  U Offline
                  U Offline
                  UlliJ
                  @manrum1
                  Zeitgleich Portal und ism7mqtt funktioniert nicht. Entweder oder…
                  Proxmox auf iNuc, lxc für IoB, InfluxDB2, Grafana, u.a. *** Homematic & Homematic IP, Shellies, Zigbee etc
                  • U UlliJ
                    @manrum1
                    manrum1
                    @ullij Aha, das ist der Grund. Dann verzichten also alle auf die APP?
                    Danke für dei Info, dann hat sich das eh erledigt.
                    O 1 Antwort Letzte Antwort
                    • M manrum1
                      O Online
                      O Online
                      oxident
                      @manrum1 Hmm. also bei mir läuft auch beides parallel und teilweise sogar noch der Wolf-Adapter. Ist vielleicht nicht optimal, funktioniert aber...
                      • O oxident
                        manrum1
                        @oxident Hallo, danke für deine Antwort. Könntest Du mir vielleicht helfen und mir veraten, was ich falsch mache. Siehe oben....
                        • M manrum1
                          O Online
                          O Online
                          oxident
                          @manrum1 Sehe irgendwie noch keinen Fehler bei Dir. Hast Du mal versucht, ob Fu via Handy oder Tablet direkten Zugriff (ohne Cloud) bekommen kannst?
                          Nicht, dass es doch irgendein Firmware-Update braucht...
                          • O oxident
                            manrum1
                            @oxident Wie meinst Du das mit dem direkten Zugriff? Wie soll ich das per Handy/Tablet machen?
                            • M manrum1
                              O Online
                              O Online
                              oxident
                              @manrum1 Du kannst in der Smartset-App beim Einloggen unten rechts auf "Nutzung ohne Internet" klicken. Wenn das funktioniert, dann sind die Voraussetzungen für ism7mqtt gegeben:
