  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • Hant0rH Offline
    Hant0rH Offline
    Hant0r
    #2858
    Den Servererror habe ich auch
    vw-connect.0 2025-03-03 08:52:27.042	info	Server not available. For endpoint vehicle-maintenance/vehicles/report Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:25.880	info	Server not available. For endpoint vehicle-status/driving-range Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:24.883	info	Server not available. For endpoint maps/positions/vehicles/parking Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:21.220	info	Server not available. For endpoint vehicle-status Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:19.994	info	Server not available. For endpoint charging Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:18.934	info	Server not available. For endpoint air-conditioning/auxiliary-heating Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:17.835	info	Server not available. For endpoint air-conditioning/active-ventilation Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:17.271	info	Server not available. For endpoint air-conditioning Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:15.041	info	Server not available. For endpoint trip-statistics Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:14.110	info	Server not available. For endpoint trip-statistics Please try again later:"Internal server error"
    vw-connect.0 2025-03-03 08:52:13.185	info	Found 1 vehicles
    vw-connect.0 2025-03-03 08:52:12.578	info	Login successful
    vw-connect.0 0 25-03-03 08:52:11.108	info	Login in with skodae
    vw-connect.0 2025-03-03 08:52:10.541	info	starting. Version 0.7.7 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v20.18.2, js-controller: 7.0.6
    • W woupi
      @fuchs1978
      Heute morgen kommt in der App auch ein Hinweis darauf, dass ein Problem aufgetaucht ist und daran gearbeitet wird.
      Letzte Aktualisierung am 1.3.2025 19:43
      fuchs1978
      #2859
      @woupi ich habe wieder Werte in beiden Systemen
      W 1 Antwort Letzte Antwort
      • F fuchs1978
        W Offline
        W Offline
        woupi
        #2860
        @fuchs1978
        Danke für den Hinweis, bei mir leider noch nichts
        NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
        • W woupi
          @fuchs1978
          Ahnungsbefreit
          #2861
          @woupi Bei mir (VW e-up) ist auch seit >1 Tag kein Update mehr da (App+ioBroker).
          • J Offline
            JMA
            #2862
            Zuerst mal GROSSES LOB und BESTEN DANK für den Einsatz, damit der Adapter so zügig wieder upgedatet wurde!
            ich bin mittlerweile auch auf 0.7.7, funktioniert so weit auch mit Skoda.
            Mir fehlen aber noch zwei Werte die ich früher in Verwendung hatte:
            • Ölstand
            • Außentemperatur
            Gibt es eine Möglichkeit, die auch wieder zu bekommen?
            • J JMA
              • Ölstand
              • Außentemperatur
              TT-Tom
              #2863
              @jma sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
              Außentemperatur
              schau mal unter status.air-conditioning.outsideTemperature.temperatureValue
              Gruß Tom
              Public Transport
              NSPanel Adapter Wiki
              • A Ahnungsbefreit
                Ahnungsbefreit
                #2864
                @woupi jetzt geht beides wieder, App und Adapter.
                • A Ahnungsbefreit
                  W Offline
                  W Offline
                  woupi
                  #2865
                  @ahnungsbefreit
                  Jetzt gerade habe ich jede Menge Fehler von der app erhalten und bei beiden Fahrzeugen haben sich die Werte in der app aktualisiert.
                  Im Adapter komischerweise allerdings nur bei einem Fahrzeug, bei dem anderen musste ich erst den Adapter neu starten.
                  Werde gleich mal sehen wie es weiter geht.
                  • T TT-Tom
                    Außentemperatur
                    JMA
                    #2866
                    @tt-tom said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                    Außentemperatur
                    den Datenpunkt gibt es bei mir leider nicht.
                    • T tombox
                      @wszene vw-connect.0.XXXXX.remote.auxiliaryheating kannst du mit einer Sekunden Anzahl starten
                      WszeneW Offline
                      WszeneW Offline
                      Wszene
                      #2867
                      @tombox sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                      OK ja den DP habe ich jetzt
                      Das werde ich mal testen
                      Aber früher hatte ich einen DP der hat mir die noch verbleibenden Minuten angezeigt
                      Also wenn ich die Klima z.B. automatisch gestartet habe oder per App dann hat der DP die Restlaufzeit in Minuten angezeigt
                      So etwas wäre schön wenn das noch da wäre
                      Danke im Voraus
                      Marcel
                      Meine Hard- & Software:
                      • CC2652P Zigbee Stick
                      • Lichtschalter mit Tasmota
                      • IKEA TRÅDFRI Glühbirnen
                      • Aqara Sensoren
                      • WszeneW Wszene
                        Danke im Voraus
                        Marcel
                        tombox
                        #2868
                        @wszene vw-connect.0.XXXXX.status.auxiliary-heating
                        • tiga3110T Offline
                          tiga3110T Offline
                          tiga3110
                          schrieb am zuletzt editiert von tiga3110
                          #2869
                          habt ihr aktuell bei myseat für einen cupra-leon den Datenpunkt Außentemperatur sowie (car)ismoving?
                          die fehlen doch in der version 0.7.7, oder?
                          Danke für die Rückmeldung
                          C 1 Antwort Letzte Antwort
                          • tiga3110T tiga3110
                            citruskraft
                            #2870
                            @tiga3110
                            Habe auch myseat (und einen Seat). Bei mir gibts die Datenpunkte auch nicht.. Den Ordner status.air-conditioning, in dem manche (Skodafahrer?) den Temperatur DP gefunden haben, gibts ebenfalls nicht ( 0.7.7)
                            • C citruskraft
                              @tiga3110
                              tourer4778
                              schrieb am zuletzt editiert von tourer4778
                              #2871
                              Ich habe im Adapter von Skoda Alt auf MySkoda gestellt. Nun ist er Online, allerdings kommen keine Daten mehr rüber.
                              Hat sich erledigt, die Baumstrucktur hat sich geändert.
                              • F Offline
                                fuchs1978
                                #2872
                                Bei Myseat lässt die Zuverlässigkeit aktuell auch sehr zu wünschen übrig.
                                • O Online
                                  O Online
                                  oxident
                                  #2873
                                  Sorry wg. OT, aber gibt es eigentlich Empfehlungen zu Autobauern bei denen der API etwas mehr "Liebe" geschenkt wird?
                                  VW & Co. fallen ja wirklich extrem negativ auf.
                                  amg_666A F 2 Antworten Letzte Antwort
                                  • O oxident
                                    amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    #2874
                                    @oxident sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                    Ich war mit BMW / dem BMW Adapter bislang sehr zufrieden, allerdings würde ich eine Kaufentscheidung nicht maßgeblich von der API abhängig machen ;-)
                                    O 1 Antwort Letzte Antwort
                                    • amg_666A amg_666
                                      O Online
                                      O Online
                                      oxident
                                      #2875
                                      @amg_666 said in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                      Ja, ich weiß, was Du meinst. Aber mal abgesehen vom (mega wichtigen) PV-Überschussladen gibt es aber so ein paar Dinge, die ich schon gerne verlässlich im Smarthome hätte: Standheizung via Alexa (oder was auch immer), Verriegelung prüfen, Standort für Geofence, Wartungsintervalle ... gibt da schon einiges.
                                      Aber BMW werd ich mir mal anschauen, danke!
                                      • O oxident
                                        fuchs1978
                                        #2876
                                        @oxident bei unserem EQV sind die Werte auch zuverlässiger.
                                        • O oxident
                                          tombox
                                          #2877
                                          @oxident BMW hat leider eine Quota für Abrufe was eine aktualisierung von 15min erlaubt und Probleme beim ausführen von Kommandos mache
                                          Mercedes aktualisiert die Werte in Echtzeit aber hat auch ein Abrufelimit eingeführt
                                          Skoda müsste jetzt die Werte auch in Echtzeit aktualisiere und hat bisher keine hartes Abrufelimit
                                          O JB_SullivanJ 2 Antworten Letzte Antwort
