  4. Problem mit nodejs. Fehlermeldung (Node-red)
13 Beiträge 4 Kommentatoren 694 Aufrufe 3 Beobachtet
  • G gerrit1
    @homoran habe nun schon ne Neuinstallation versucht.
    curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh
    sagt:
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
        at Module._load (node:internal/modules/cjs/loader:981:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
        at node:internal/main/run_main_module:28:49 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    Node.js v18.20.6
    Pending iob updates: 	0
    Nodejs-Installation:
    /usr/bin/nodejs 	v18.20.6
    node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by node)
    /home/pi/.nvm/versions/node/v20.18.3/bin/node
    /home/pi/.nvm/versions/node/v20.18.3/bin/npm
    /home/pi/.nvm/versions/node/v20.18.3/bin/npx
    /home/pi/.nvm/versions/node/v20.18.3/bin/corepack
    Recommended versions are nodejs  and npm
    *** nodejs is NOT correctly installed ***
    Wrong installation path detected. This needs to be fixed.
    Please execute
    iob nodejs-update
    to fix these errors.
    MEMORY:
    Mem:           3.8G         69M        3.0G         24M        762M        3.6G
    Swap:           99M          0B         99M
    Total:         3.9G         69M        3.1G
    Active iob-Instances: 	0
    node:internal/modules/cjs/loader:1143
      throw err;
      requireStack: []
    Node.js v18.20.6
      throw err;
      requireStack: []
    Node.js v18.20.6
    ioBroker Core: 		js-controller
      throw err;
      requireStack: []
    Node.js v18.20.6
    			admin
      throw err;
      requireStack: []
    Node.js v18.20.6
    ioBroker Status:
    Objects: 		0
    States: 		0
    Size of iob-Database:
    find: '/opt/iobroker/iobroker-data': No such file or directory
    Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW!
    für mich wäre es mittlerweile wohl am besten, node red neuzuinstallieren, allerdings gerne übers Terminal und nicht hart über die sd karte. So müsste ich nicht alles neu machen
    @gerrit1 sagte in Problem mit nodejs. Fehlermeldung (Node-red):
    buster
    ist so was von tot!
    Dafür gibt es keinerlei updates mehr, auch nicht für node.
    G 1 Antwort Letzte Antwort
      buster
      ist so was von tot!
      gerrit1
      was genau ist tot?
      ich vermute ich habe mir irgendwas "altes" raufgezogen. Habe aktuell keinen Zugang mehr zu Node-red.
      • G gerrit1
        was genau ist tot?
        was genau ist tot?
        Buster!
        das Betriebssystem
        • G gerrit1
          Moin zusammen,
          zunächst weiß ich gar nicht ob ich hier genau richtig bin:
          Leider komme ich nicht mehr weiter. Ursprünglich wollte ich nur eine Palette in Node-red updaten, allerdings ging es anscheinend nicht, da nodejs. auf einem alten Stand war.
          Nun habe ich mir vermutlich recht viel verhagelt. Bin kurz davor, den ganzen RaspberryPi zu reseten.
          Node-red kann ich auch nicht mehr deinstallieren. Folgende Meldung kommt bei jeglicher Eingabe:
          node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by node)
          node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by node)
          Hat jemand eine Idee?
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @gerrit1
          Du hast Node aktualisiert was durch dein altes Betriebssystem nicht mehr supportet wird
          Entweder du aktualisierst dein Betriebssystem (bevorzugt) oder
          Machst wieder ein downgrade von node um das andere in Ruhe vorzubereiten (Backup vom IoBroker und so)
          Glib ist eine der zentralen Bibliotheken die benötigt wird für alle Programme
          Die mit dem gnu c compiler kompiliert worden sind.
          Bei raspberry, dank den preiswerten sd Karten machst du am besten auf einer neuen sd Karte eine komplett neuinstallation
          Meine Adapter und Widgets
          Links im Profil
          • OliverIOO OliverIO
            @gerrit1
            @oliverio sagte in Problem mit nodejs. Fehlermeldung (Node-red):
            klingt nach RasPi.
            Da geht nur Neuinstallation mit Restore des ketzten Backups.
            Voraussetzung ist, dass nicht auch der js-controller zu alt ist.
            • G gerrit1
              sagt:
                requireStack: []
              Node.js v18.20.6
              Please execute
              iob nodejs-update
              MEMORY:
              Swap:           99M          0B         99M
                throw err;
                requireStack: []
              Node.js v18.20.6
                throw err;
                requireStack: []
              Node.js v18.20.6
                throw err;
                requireStack: []
              Node.js v18.20.6
              			admin
                throw err;
                requireStack: []
              Node.js v18.20.6
              ioBroker Status:
              Objects: 		0
              States: 		0
              @gerrit1
              Versuch es mal mit
              iob stop
              iob fix
              iob nodejs-update 18
              Und lass die Finger von so einem Kram wie nvm!!!
              Das zerschießt dir die Installation. Wenn der ioBroker wieder laufen sollte ziehst du ein Backup und ziehst damit auf ein von Grund auf NEUINSTALLIERTES Raspberry OS 12 'Bookworm' um.
                @gerrit1
                Versuch es mal mit
                iob stop
                iob fix
                gerrit1
                Danke für eure Hilfe,
                habe es irgendwie geschafft, Node-red neuzinstallieren. Musste hierfür aber keine komplette Neuinstallation vom Raspberry machen.
                • G gerrit1
                  @gerrit1
                  Doch, musst du. Dein buster ist nämlich tot.
                  Und ein 'in-line-Upgrade' auf ein aktuelles Release ist nicht möglich.
                  Zeig mal die Langfassung von
                  iob diag
                  nun
                    @gerrit1
                    iob diag
                    nun
                    gerrit1
                    Da steht tatsächlich:
                    *** LIFE CYCLE STATUS ***
                    Wobei jetzt das neueste Node-Red läuft
                    Kann ich denn ein Backup von Node-Red machen und anschließend auf das neue Betriebssystem wieder schieben? Oder wie sollte ich da am sinnvollsten vorgehen?
                    • G gerrit1
                      @gerrit1
                      Wenn es 'da steht' wird es wohl auch wahr sein.
                      Warum sollte ich dich anlügen?
                      Mittels
                      distro-info --unsupported -yeol -c
                      steht da sogar, wie lange (in Tagen) das schon tot ist.
                      Klar, jetzt ist ja auch nodejs senkrecht installiert.
                      Kiste inkl. ioBroker auf den letzen Stand bringen, Backup mittels Backitup-Adapter ziehen, neues Betriebssystem komplett neuinstallieren, ioBroker 'leer' installieren, Backup einspielen.
                      Ob für node-red da noch weitere Dinge zu berücksichtigen sind weiß ich allerdings nicht, ich verwende kein node-red.
