  4. Vis2 RSSfeed Widgets nicht mehr in der Palette vorhanden
    5.8k
20 Beiträge 2 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • OliverIOO OliverIO
    @worxweis
    gibt es fehlermeldungen in der browserkonsole mit F12?
    W Offline
    W Offline
    worxweis
    @oliverio
    Das ist die Konsole:
    iobroker.vis-2@2.9.64 using theme "colored"
    Runtime.jsx:89
    Runtime.jsx:89 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
    Runtime.jsx:89 Help us to create open source project with reactJS!
    Runtime.jsx:89 See you :)
    Editor.jsx:1778 Translate: null
    VM1670:140 Version vis-canvas-gauges: 0.1.5
    VM1671:78 Version vis-colorpicker: 2.0.3
    VM1673:75 Version vis-history: 1.0.0
    VM1675:113 Version vis-jqui-mfd: 1.0.12
    VM1677:45 Version vis-map: 1.1.2
    VM1678:645 Metro version: "1.2.0"
    VM1679:97 Version vis-plumb: 1.0.0
    VM1683:1269 Version vis-weather: 2.5.6
    justgage.js:112 Version justgage: 2.1.7
    trashschedule.js:176 Version trashschedule: 3.3.0
    lib.min.js:43 Download the Vue Devtools extension for a better development experience:
    https://github.com/vuejs/vue-devtools
    lib.min.js:43 You are running Vue in development mode.
    Make sure to turn on production mode when deploying for production.
    See more tips at https://vuejs.org/guide/deployment.html
    keyboard.js:25 Version iobroker.vis-keyboard: 0.0.2
    time-switch.js:38 Version time-switch: 2.2.2
    materialdesign.js:33 Version vis-materialdesign: 0.5.9
    hub.ts:494 Uncaught (in promise) TypeError: Ut(...).isOlderThan is not a function
        at qt (hub.ts:494:65)
        at sdk.ts:19:15
        at t.init (sdk.ts:91:3)
        at Object._initializeSentry (widgets.min.js:1:20151)
        at Object.initializeSentry (widgets.min.js:1:19863)
    qt @ hub.ts:494
    (anonym) @ sdk.ts:19
    t.init @ sdk.ts:91
    _initializeSentry @ widgets.min.js:1
    await in initializeSentry
    (anonym) @ materialdesign.js:35
    (anonym) @ widgets.min.js:1
    (anonym) @ visEngine.jsx:1199
    Promise.then
    emit @ visEngine.jsx:1199
    getObject @ widgets.min.js:1
    getVersion @ widgets.min.js:1
    (anonym) @ materialdesign.js:32
    setTimeout
    waitForVisConnected @ widgets.min.js:1
    showVersion @ materialdesign.js:31
    (anonym) @ widgets.min.js:1Fehler nachvollziehenAI
    vis-material-advanced.js:183 Version vis-material-advanced: 1.7.3
    visLoadWidgets.tsx:125
               GET http://10.0.0.20:8082/vis-2/widgets/vis-2-widgets-rssfeed/customWidgets.js net::ERR_ABORTED 404 (Not Found)
    (anonym) @ visLoadWidgets.tsx:125
    (anonym) @ visLoadWidgets.tsx:49
    (anonym) @ visLoadWidgets.tsx:142
    (anonym) @ visLoadWidgets.tsx:298
    (anonym) @ visLoadWidgets.tsx:254
    Promise.then
    r @ visLoadWidgets.tsx:225
    (anonym) @ visWidgetsCatalog.tsx:302
    setTimeout
    (anonym) @ visWidgetsCatalog.tsx:301
    collectRxInformation @ visWidgetsCatalog.tsx:300
    onWidgetsLoaded @ Runtime.jsx:813
    onLoaded @ Runtime.jsx:1028
    loadWidgets @ visEngine.jsx:1529
    await in loadWidgets
    (anonym) @ visEngine.jsx:208
    Promise.then
    Mt @ visEngine.jsx:196
    cs @ react-dom.production.min.js:184
    Vs @ react-dom.production.min.js:197
    Hi @ react-dom.production.min.js:291
    Ml @ react-dom.production.min.js:279
    gl @ react-dom.production.min.js:279
    fl @ react-dom.production.min.js:279
    rl @ react-dom.production.min.js:267
    S @ scheduler.production.min.js:13
    T @ scheduler.production.min.js:14Fehler nachvollziehenAI
    visLoadWidgets.tsx:312 Cannot load i18n "vis2rssfeedWidgets": Error: Cannot load vis2rssfeedWidgets from ./widgets/vis-2-widgets-rssfeed/customWidgets.js
    visLoadWidgets.tsx:197 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: Error: Cannot load vis2rssfeedWidgets from ./widgets/vis-2-widgets-rssfeed/customWidgets.js
    (anonym) @ visLoadWidgets.tsx:197
    Promise.catch
    (anonym) @ visLoadWidgets.tsx:196
    n @ visLoadWidgets.tsx:173
    (anonym) @ visLoadWidgets.tsx:326
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    visLoadWidgets.tsx:198 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {}
    (anonym) @ visLoadWidgets.tsx:198
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    Promise.catch
    Promise.then
    Promise.then
    setTimeout
    Promise.then
    JQuiWriteState.tsx:209 Translate: Write state
    index.tsx:642 Translate: bars
    index.tsx:642 Translate: canvas-gauges
    index.tsx:642 Translate: colorpicker
    index.tsx:642 Translate: fancyswitch
    index.tsx:642 Translate: history
    index.tsx:642 Translate: hqwidgets
    index.tsx:642 Translate: jqplot
    index.tsx:642 Translate: jqui-mfd
    index.tsx:642 Translate: justgage
    index.tsx:642 Translate: keyboard
    index.tsx:642 Translate: map
    index.tsx:642 Translate: materialdesign
    index.tsx:642 Translate: metro
    index.tsx:642 Translate: plumb
    index.tsx:642 Translate: rgraph
    index.tsx:642 Translate: swipe
    index.tsx:642 Translate: time-switch
    index.tsx:642 Translate: timeandweather
    index.tsx:642 Translate: trashschedule
    index.tsx:642 Translate: vis-inventwo
    index.tsx:642 Translate: vis-material-advanced
    index.tsx:642 Translate: weather
    visEngine.jsx:1824 [2025-02-16T18:49:16.059Z] +SUBSCRIBE: javascript.0.Automatisierung.Infomeldung
    visEngine.jsx:1824 [2025-02-16T18:49:16.080Z] +SUBSCRIBE: mqtt.0.SHRDZM.4C7525362326.4C7525362326.sensor.1.7.0
    visEngine.jsx:1824 [2025-02-16T18:49:16.084Z] +SUBSCRIBE: mqtt.0.SHRDZM.4C7525362326.4C7525362326.sensor.2.7.0
    visEngine.jsx:1824 [2025-02-16T18:49:16.085Z] +SUBSCRIBE: javascript.0.PV.Gesamtleistung_PV_in_W
    visEngine.jsx:1824 [2025-02-16T18:49:16.086Z] +SUBSCRIBE: javascript.0.Energie.Verbrauch
    visEngine.jsx:1824 [2025-02-16T18:49:16.088Z] +SUBSCRIBE: javascript.0.PV.Speicher_Entladen
    visEngine.jsx:1824 [2025-02-16T18:49:16.089Z] +SUBSCRIBE: javascript.0.PV.Speicher_Laden
    visEngine.jsx:1824 [2025-02-16T18:49:16.090Z] +SUBSCRIBE: alias.0.Pool_Pumpe.Power
    visEngine.jsx:1824 [2025-02-16T18:49:16.090Z] +SUBSCRIBE: javascript.0.Diverse_Hilfsdatenpunkte.Pool_Winter_Ein
    visEngine.jsx:1824 [2025-02-16T18:49:16.091Z] +SUBSCRIBE: ds18b20.0.sensors.28-3ce1e380f524
    visEngine.jsx:1824 [2025-02-16T18:49:16.094Z] +SUBSCRIBE: modbus.0.holdingRegisters.1544_battery_soc
    visEngine.jsx:1824 [2025-02-16T18:49:16.096Z] +SUBSCRIBE: javascript.0.HoroskopKrebsLiebe
    visEngine.jsx:1824 [2025-02-16T18:49:16.097Z] +SUBSCRIBE: javascript.0.HoroskopWassermann
    visEngine.jsx:1824 [2025-02-16T18:49:16.098Z] +SUBSCRIBE: javascript.0.HoroskopLoewe
    visEngine.jsx:1824 [2025-02-16T18:49:16.102Z] +SUBSCRIBE: trashschedule.0.type.altpapier.nextDateFormat
    visEngine.jsx:1824 [2025-02-16T18:49:16.104Z] +SUBSCRIBE: trashschedule.0.type.altpapier.daysLeft
    visEngine.jsx:1824 [2025-02-16T18:49:16.106Z] +SUBSCRIBE: trashschedule.0.type.restmüll.nextDateFormat
    visEngine.jsx:1824 [2025-02-16T18:49:16.107Z] +SUBSCRIBE: trashschedule.0.type.restmüll.daysLeft
    visEngine.jsx:1824 [2025-02-16T18:49:16.111Z] +SUBSCRIBE: trashschedule.0.type.kunststoff.nextDateFormat
    visEngine.jsx:1824 [2025-02-16T18:49:16.112Z] +SUBSCRIBE: trashschedule.0.type.kunststoff.daysLeft
    visEngine.jsx:1824 [2025-02-16T18:49:16.113Z] +SUBSCRIBE: 0
    visEngine.jsx:1824 [2025-02-16T18:49:16.114Z] +SUBSCRIBE: 9500
    visEngine.jsx:1824 [2025-02-16T18:49:16.114Z] +SUBSCRIBE: 350
    visEngine.jsx:1824 [2025-02-16T18:49:16.116Z] +SUBSCRIBE: 8000
    visEngine.jsx:1824 [2025-02-16T18:49:16.116Z] +SUBSCRIBE: 4000
    visEngine.jsx:1824 [2025-02-16T18:49:16.117Z] +SUBSCRIBE: 4050
    visEngine.jsx:1824 [2025-02-16T18:49:16.117Z] +SUBSCRIBE: 2000
    W OliverIOO 2 Antworten Letzte Antwort
    • W worxweis
      @oliverio
      Runtime.jsx:89
          at sdk.ts:19:15
      qt @ hub.ts:494
      t.init @ sdk.ts:91
      Promise.then
      setTimeout
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      Promise.catch
      Promise.then
      Promise.then
      setTimeout
      Promise.then
      W Offline
      W Offline
      worxweis
      @OliverIO
      Er kann offensichtlich das Widget nicht laden. Nur warum nicht? Der Adapter ist installiert!
      • W worxweis
        @oliverio
        Runtime.jsx:89
            at sdk.ts:19:15
        qt @ hub.ts:494
        t.init @ sdk.ts:91
        Promise.then
        setTimeout
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        Promise.catch
        Promise.then
        Promise.then
        setTimeout
        Promise.then
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @worxweis
        ok irgendwo im forderen bereich steht ein 404 fehler.
        zeile 58
        das bedeutet, das die datei nicht vorhanden ist.
        bei vis2 muss man auch beachten, das sobald vis2 erkennt, das sich da was verändert, es automatisch alles löscht und wieder neu aufbaut. das keine einige zeit dauern. bei mir in der entwicklungsumgebung durchaus auch mal 1 Minute mit kaum installierten adaptern.
        das sind dann folgefehler, die mehrfach auftreten
        also am besten dir vis2 rss widgets nochmal ordentlich deinstallieren
        dann wieder installieren und dann ein weilchen warten.
        dann nochmal schauen
        Meine Adapter und Widgets
        Links im Profil
        W 1 Antwort Letzte Antwort
          @worxweis
          zeile 58
          W Offline
          W Offline
          worxweis
          @oliverio
          ich habe sie bereits mehrfach deinstalliert und wieder installiert. Jedoch immer über die Adapterseite von iobroker.
          Sind jetzt bestimmt schon mind. 20min installiert und funktionieren immer noch nicht.
          Wie deinstalliere und installiere ich die sauber über die konsole?
          • W worxweis
            @oliverio
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @worxweis
            browser cache löschen?
            iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
            evtl auch mal den upload knopf betätigen, sichtbar im expertenmodus
            weiß aber nicht ob es bei vis2 eine auswirkung hat, schadet aber auch nicht
            Links im Profil
              @worxweis
              W Offline
              W Offline
              worxweis
              @oliverio
              Okay, ich werde das morgen mal testen.
              Vielen Dank einstweilen!
              • W Offline
                W Offline
                worxweis
                @OliverIO
                @oliverio
                Ich habe jetzt den Chache gelöscht, Adapter deinstalliert, Adapter neu installiert.
                Das ist das Log von der Installation:
                $ iobroker add vis-2-widgets-rssfeed auto --host iobroker --debug
                NPM version: 10.8.2
                Installing iobroker.vis-2-widgets-rssfeed@0.3.6... (System call)
                added 1 package in 3s
                360 packages are looking for funding run `npm fund` for details
                host.iobroker install adapter vis-2-widgets-rssfeed
                upload [0] vis-2-widgets-rssfeed.admin /opt/iobroker/node_modules/iobroker.vis-2-widgets-rssfeed/admin/vis-2-widgets-rssfeed.png vis-2-widgets-rssfeed.png image/png
                Adapter "system.adapter.vis-2.0" restarted.
                host.iobroker object system.adapter.vis-2-widgets-rssfeed created/updated
                Updating objects from io-package.json for adapter "vis-2-widgets-rssfeed" with version "0.3.6"
                host.iobroker create instance vis-2-widgets-rssfeed
                host.iobroker object system.adapter.vis-2-widgets-rssfeed.0 created
                Process exited with code 0
                im Ordner /opt/iobroker/node_modules/iobroker.vis-2-widgets-rssfeed/widgets/vis-2-widgets-rssfeed$ sind folgende Dateien vorhanden:
                customWidgets.js  customWidgets.js.map  i18n  img  static
                • W worxweis
                  @OliverIO
                  @oliverio
                  NPM version: 10.8.2
                  W Offline
                  W Offline
                  worxweis
                  @OliverIO
                  Hast du noch eine Idee für mich?
                  • W worxweis
                    @OliverIO
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @worxweis
                    Nicht wirklich.
                    Irgendwas scheint bei dir am vis-2 Adapter kaputt zu sein.
                    Normalerweise sollten die Dateien durch vis bereitgestellt worden sein
                    Auch wenn die Dateien im Adapter enthalten sind,
                    Muss vis die sozusagen noch mal hochladen, so dass sie für den Browser verfügbar sind.
                    Das scheint bei dir nicht richtig zu funktionieren.
                    Hast du das Problem auch mit anderen Widgets?
                    Links im Profil
                      @worxweis
                      Nicht wirklich.
                      W Offline
                      W Offline
                      worxweis
                      @oliverio
                      Das wäre mir jetzt noch nicht aufgefallen.
                      Kann ich Vis 2 neu installieren, ohne dass mein Projekt gelöscht wird? Oder muss ich das vorher irgendwie exportieren?
                      • W worxweis
                        @oliverio
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @worxweis
                        Besser ist zum einen ein komplettes Backup zu machen
                        Auch kann man in vis2 zumindest seitenweise exportieren.
                        Komplettes Projekt auf einmal exportieren hab ich nicht gefunden.
                        Links im Profil
                          @worxweis
                          W Offline
                          W Offline
                          worxweis
                          @oliverio
                          Okay, danke!
                          Werde das probieren.
                          Sicher täglich auf Proxmox, da kann ich ja eh alles wiederherstellen"
                          Werde dann Berichten wie es gelaufen ist!
                          • W worxweis
                            @oliverio
                            Okay, danke!
                            W Offline
                            W Offline
                            worxweis
                            @OliverIO
                            So, hab nun vis2 de- und wieder neu installiert. Dann alle VIS2 Widgetsadapter nachinstalliert! nun ist auch rss wieder vorhanden.
                            Alles andere muss ich erst testen.
                            Man kann übrigens ein Komplettes Projekt exportieren und wieder importieren!
                            Danke!
                            • W worxweis
                              @OliverIO
                              Danke!
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @worxweis sagte in Vis2 RSSfeed Widgets nicht mehr in der Palette vorhanden:
                              wo/wie geht das? hab nix gefunden
                              Links im Profil
                                W Offline
                                W Offline
                                worxweis
                                @oliverio
                                Unter Projekte
                                • W worxweis
                                  @oliverio
                                  Unter Projekte
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  @worxweis
                                  Danke, wird bei mir nur als Burger Menü dargestellt.
                                  Aber hab's gefunden
                                  Links im Profil
