  3. Off Topic
  4. Microcontroller
  5. Kegelstumpf Blockly in Berryscript Tasmota [gelöst]
    5.9k
Geplant Angeheftet Gesperrt Verschoben Microcontroller
6 Beiträge 3 Kommentatoren 816 Aufrufe 3 Beobachtet
    bishop
    schrieb am zuletzt editiert von bishop
    ich hätte gerne mein Blockly script auf den Esp32 ausgelagert.
      <variables>
        <variable id="`:H;H8V)NI74WMdws*,4">wert-23cm=0</variable>
        <variable id="*e!Qy+h)MO2flf!XL0It">hoehe_Tonne_bis_Sensor_in_cm</variable>
        <variable id="G-(dMY)T}f`7@c2malWY">Radius_oben_in_cm</variable>
        <variable id="HVLq_Zx{?_%{pb_NYC6.">Radius_unten_in_cm</variable>
        <variable type="timeout" id="timeout">timeout</variable>
        <variable id="kxN%n/_4vfYXY^W[9.VD">entfernung_invertiert</variable>
      </variables>
      <block type="comment" id="xbdQA]p:Rm0!77!u:Uzz" x="-63" y="424">
        <field name="COMMENT">Kegelstumpf Regentonne</field>
        <next>
          <block type="comment" id="|YNADPJ5k[^ORlh6KlBz">
            <field name="COMMENT">Sensor misst bis 23cm</field>
            <next>
              <block type="on" id="F~b*#|j@)ipdlQQopt$E">
                <field name="OID">sonoff.0.pool_61_regentonne.SR04_Distance</field>
                <statement name="STATEMENT">
                  <block type="variables_set" id="$?pcIQ[ZklduDkx|)]ok">
                    <field name="VAR" id="`:H;H8V)NI74WMdws*,4">wert-23cm=0</field>
                    <value name="VALUE">
                      <block type="math_arithmetic" id="zK|Ksu)dA:3N/uHX8.x`">
                        <value name="A">
                          <shadow type="math_number" id="(49.@XAbyvYM#sHmcwW9">
                            <field name="NUM">1</field>
                          </shadow>
                          <block type="on_source" id="~;N)F]CT5G1.sx{8mmm.">
                          </block>
                        </value>
                        <value name="B">
                          <shadow type="math_number" id="B9a9r.S{_=SEleC]:ct]">
                            <field name="NUM">22</field>
                          </shadow>
                          <block type="math_number" id="j!7zc`XzAv(o=e7#~!Z4">
                            <field name="NUM">23</field>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                      <block type="variables_set" id=".iH{PRMOti%`!9C:,$a7">
                        <field name="VAR" id="*e!Qy+h)MO2flf!XL0It">hoehe_Tonne_bis_Sensor_in_cm</field>
                          <block type="math_number" id="^?UsQbV8@;@=QeWE_kR#">
                            <field name="NUM">140</field>
                          </block>
                        </value>
                        <next>
                          <block type="variables_set" id="Wci|;:wXY~@J`VW6G?hL">
                            <field name="VAR" id="G-(dMY)T}f`7@c2malWY">Radius_oben_in_cm</field>
                              <block type="math_number" id="wZz#666*ftqLP4kfX-;k">
                                <field name="NUM">30</field>
                              </block>
                            </value>
                            <next>
                              <block type="variables_set" id="QyC*SpMyQA=D#ubNh6Dx">
                                <field name="VAR" id="HVLq_Zx{?_%{pb_NYC6.">Radius_unten_in_cm</field>
                                  <block type="math_number" id="*%:nMl~*~r3lZchceG`/">
                                    <field name="NUM">25</field>
                                  </block>
                                </value>
                                <next>
                                  <block type="timeouts_settimeout" id="Hx-?1TM^O.;}LVPXN#ho">
                                    <field name="DELAY">100</field>
                                    <field name="UNIT">ms</field>
                                      <block type="variables_set" id=":(iut~5QcavF29$`=1{L">
                                        <field name="VAR" id="kxN%n/_4vfYXY^W[9.VD">entfernung_invertiert</field>
                                          <block type="math_rndfixed" id="rQ`urI8G~mW*up[O}%a-">
                                            <field name="n">2</field>
                                            <value name="x">
                                              <shadow type="math_number" id="0TM5Vz5TwC3p%.E*NY4Q">
                                                <field name="NUM">3.1234</field>
                                              </shadow>
                                              <block type="math_arithmetic" id="1``s!BYJ{3S~_x^|TYH8">
                                                <value name="A">
                                                  <shadow type="math_number" id="v5PpsZu4PSyAx057^p^9">
                                                  </shadow>
                                                  <block type="variables_get" id="28jwSkT{!_W)Dw2AD:.z">
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  <shadow type="math_number" id="mj{c6)]{U{h|=8AoN-Y!">
                                                  </shadow>
                                                  <block type="variables_get" id="pR)8.rtSV}0RvZe2Q~U3">
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="update" id="}8URLV|N@HzOUvJ=dgWM">
                                            <field name="OID">javascript.0.Regentonne.entfernung_invertiert</field>
                                              <block type="variables_get" id="$;z][[YW!l]9Np}hH5Q*">
                                              </block>
                                            </value>
                                            <next>
                                              <block type="update" id="w=,FAsa)^dq!2`9Z|UZX">
                                                <field name="OID">javascript.0.Regentonne.Wasserinhalt</field>
                                                  <block type="math_round" id="n:4L(^03@L;)WKDGKE?d">
                                                    <field name="OP">ROUND</field>
                                                    <value name="NUM">
                                                      <shadow type="math_number" id="5F8D1VUX]8%@[!I+U`KP">
                                                        <field name="NUM">3.1</field>
                                                      </shadow>
                                                      <block type="math_arithmetic" id="G:9I3$=qQ`lixEy`L#)8">
                                                        <field name="OP">DIVIDE</field>
                                                        <value name="A">
                                                          <shadow type="math_number" id="8RB]xuYu[)(Hxz9T,h#]">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="(8lz8X_0Yd/HYLs[*iI?" inline="false">
                                                            <field name="OP">MULTIPLY</field>
                                                            <value name="A">
                                                              <shadow type="math_number" id="q#+V35)]KK#{%)Hy(}K^">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="cQMs/PeTI:.u)RI.!4LG">
        <value name="A">
        <shadow type="math_number" id="`^E[57|rmC4$kCp6;T7l">
        </shadow>
        <block type="math_arithmetic" id="RO_U/wVMG{$3R-[Z(9R@">
        <value name="A">
        <shadow type="math_number" id="z5MVmXmfh($[f+YQ8X)0">
        </shadow>
        <block type="math_arithmetic" id="an)b`B$+-7oWrHKG2nV{">
        <value name="A">
        <shadow type="math_number" id="{x2%9pm8MD#oH!RmvkTS">
        <field name="NUM">150</field>
        </shadow>
        <block type="variables_get" id="hIZn|]q?sSq06mfMXh2(">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="/{4m/d]]]d62w}G,vF0o">
        </shadow>
        <block type="on_source" id="akt?UxuSJ$Tzttd4;.de">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="8TSK#8[Y^%/D|xoGin8W">
        </shadow>
        <block type="math_constant" id="YAHz2L/9o?rW]S:!~9tG">
        <field name="CONSTANT">PI</field>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id=":fdAXjfwZJ-YfHA)x.`H">
        <field name="NUM">3</field>
        </shadow>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="dRp/LRm-wBuL~BJ/X[Hl">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="Axp!Zaz1YfHZO3c_%qq[" inline="false">
        <field name="OP">ADD</field>
        <value name="A">
        <shadow type="math_number" id="1:D(5[Ncv0U~Cn%1`D`t">
        </shadow>
        <block type="math_arithmetic" id="=9UZ5%r4Nm@d|/{CTU(z" inline="false">
        <value name="A">
        <shadow type="math_number" id="z1J+Pb1N`=0zR.C%n],*">
        </shadow>
        <block type="math_arithmetic" id="_h)Wn3vLrXP-E8WqfoGC">
        <value name="A">
        <shadow type="math_number" id="%1=s}F,x_Q9dUaQ+Im#r">
        </shadow>
        <block type="variables_get" id="j/U;7F@C4#K_$ic_A7h-">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="B6aH,xuq-QHsC?}92,K$">
        </shadow>
        <block type="variables_get" id="_H$0AsSI7#d*ziJfHZBa">
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="fABi#19`C|Q-}F7d,+pH">
        </shadow>
        <block type="math_arithmetic" id="fm$KD-n9|AU,Dn;Bdaof">
        <value name="A">
        <shadow type="math_number" id="Q#cQ_AM7#1XN61%/]oyV">
        </shadow>
        <block type="variables_get" id="?-k51TG8Woy5}c/oo`yp">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="E0ow|#WNDvI%Y3%?0-KJ">
        </shadow>
        <block type="variables_get" id="myVd3]C~JZK`?.I9r6Ac">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="V9JScxR=lN`K~1rn$[$y">
        </shadow>
        <block type="math_arithmetic" id="nkEjUwifV:_jvgF0%Yga">
        <value name="A">
        <shadow type="math_number" id="J9I-31pLT_CR8~r**__k">
        </shadow>
        <block type="variables_get" id=")-Aru@@Rw}6,DkD^-G7a">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="/UQ-JAZ5+Uu_hg+Ww2wI">
        </shadow>
        <block type="variables_get" id="P2LR1`~mR)#HlZ[zX)|8">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          <shadow type="math_number" id="qVyeSl:Gu)Q7dFJekEdn">
                                                            <field name="NUM">1000</field>
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                <next>
                                                  <block type="update" id="0B,m$6sq^-u!78mgYaR+">
                                                    <field name="OID">javascript.0.Regentonne.Füllmenge_in_Prozent</field>
                                                      <block type="math_round" id="D)#U]4czaPL0subb+wTA">
                                                        <value name="NUM">
                                                          <shadow type="math_number" id="x-:C@bh`WB+NYy~{k|VC">
                                                          </shadow>
                                                          <block type="math_arithmetic" id="~C7?buZDPnWI,?O)IA1@">
                                                            <value name="A">
                                                              <shadow type="math_number" id="mjU9uL)vyWKthB4*vFzB">
                                                              </shadow>
                                                              <block type="math_arithmetic" id="Qh?#1$X7kEM673SB,}XJ">
        <value name="A">
        <shadow type="math_number" id="_hf9SH]1@k[{BEL)8cU%">
        <field name="NUM">100</field>
        </shadow>
        </value>
        <value name="B">
        <shadow type="math_number" id=")qi:Vc9rY.t^HEE~$|jp">
        </shadow>
        <block type="variables_get" id="hY?MRbdqy=zO[s*JU|%f">
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <value name="B">
                                                              <shadow type="math_number" id="3^^./Y-?5C?f??#8rz)o">
                                                              </shadow>
                                                              <block type="variables_get" id="P{o2a}m+eae19f{A,SrZ">
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    mit Blockly bekomme ich das hin aber dann hört es auchschon auf :)
    Kann mir jemand helfen das Blockly in Berry Script umzuwandeln?
    • B bishop
        <variables>
        </variables>
          <next>
              <next>
                          <value name="A">
                            </shadow>
                            </block>
                          </value>
                          <value name="B">
                            </shadow>
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                            </block>
                          </value>
                          <next>
                                </block>
                              </value>
                              <next>
                                    </block>
                                  </value>
                                  <next>
                                              <value name="x">
                                                </shadow>
                                                  <value name="A">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    </shadow>
                                                    </block>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <next>
                                                </block>
                                              </value>
                                              <next>
                                                      <value name="NUM">
                                                        </shadow>
                                                          <value name="A">
                                                            </shadow>
                                                              <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                          <value name="B">
                                                            </shadow>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <next>
                                                          <value name="NUM">
                                                            </shadow>
                                                              <value name="A">
        </shadow>
        <value name="A">
        </shadow>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
                                                              </value>
                                                              <value name="B">
        </shadow>
        </block>
                                                              </value>
                                                            </block>
                                                          </value>
                                                        </block>
                                                      </value>
                                                    </block>
                                                  </next>
                                                </block>
                                              </next>
                                            </block>
                                          </next>
                                        </block>
                                      </statement>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </statement>
                </block>
              </next>
            </block>
          </next>
        </block>
      </xml>
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @bishop sagte in Kegelstumpf Blockly in Berryscript Tasmota:
      Umwandeln kann ich dir das nicht, da ich BerryScript nicht kenne. Allerdings kannst Du dir den JS Code des Blockly's anzeigen lassen. ggf. gibt es dafür saubere Umsetzungsanleitungen. Zur Anzeige des JS diesen Button benutzen:
      Aufpassen musst du natürlich bei den ioBroker spezifischen Blöcken (Trigger, Timeout, Datenpunkte setzen, Datenpunkte löschen)
      A.
      • AsgothianA Asgothian
        A.
        bishop
        @asgothian
        danke für den Tip, hab aber leider nicht wirklich was gefunden um es um zu schreiben.
        Hier gibt es ein Script. Funktioniert auch nur wird da alles in inch und gallonen umgerechnet.
        P 1 Antwort Letzte Antwort
        • B bishop
          @asgothian
          peterfido
          @bishop Da sind mehrere Skripte hinterlegt. Das geeignete nehmen und umrechnen sollte gehen. 1 Inch sind 2,54 cm. 1 Gallone 4,55 Liter.
          Peterfido
          • P peterfido
            bishop
            @peterfido
            Ja machts auch nur wie ändere ich das ab
            Inch weg und gal in cm3
            EDIT:
            habs mal umgebaut so gut ich es kann!
            Vielleicht kann es ja jemand gebrauchen.
            class FOTank : Driver
                var tank_data
                #build an global array-->list to store sensor for filtering
                static buf = []
                # this table is from the manufacturer datasheet, showing total gallons in inches, 44 entries plus a zero-entry.
                static Tank275 =[0.38,0.76,1.16,1.55,1.96,2.36,2.77,3.19,3.61,4.04,4.47,4.91,5.35,5.8,6.25,6.71,7.17,7.64,8.11,8.59,9.07,9.56,10.06,10.56,11.07,11.58,12.09,12.62,13.14,13.68,14.22,14.76,15.31,15.87,16.43,17,17.57,18.15,18.74,19.33,19.93,20.53,21.14,21.76,22.38,23.01,23.64,24.28,24.93,25.58,26.24,26.91,27.58,28.26,28.94,29.63,30.33,31.03]
               def tank()
                var TableLength =   self.Tank275.size()         # 59
                var TableTop = TableLength -1
                var tank_offset = -3                           # offset from SR04t to top of tank (dead zone...)
                var MaxBuf = 180                                # filtering buffer size
                #print ("\n")
                # Read Sensor data
                import json
                var sensors=json.load(tasmota.read_sensors())
                if !(sensors.contains('SR04')) return end
                var d = sensors['SR04']['Distance']
                #print("Dist: ", d)
                if (self.buf.size() >= MaxBuf) self.buf.pop(0) end      # remove old entry
                self.buf.push(d)                                        # add new sensor reading to list
                #print (self.buf)
                #print ("Size: :", self.buf.size())
                d = 0
                for i : 0 .. (self.buf.size()-1 )               # let's sum all of the entrys
                #print ("I: ",i)
                d = d + self.buf.item (i)
                end
                #print("Buf: ", self.buf)
                d = d / self.buf.size()                         # average the sensor data
                #print("Dist-avd: ", d)
                d = d + tank_offset                             # adjust for sensor to tank offset (dead zone)
                #  Convert from CM to inch and round up
                var d1 = d + 0.5                              # 2.54 cm to one inch
                d1 = int(d1)                                    # we want an integer here for table lookup
                if (d1 > TableTop) d1 = TableTop end            # do a bounds check, 0 --> 44
                if (d1 <= 0) d1 = 0 end
                #print("Cm: ",d1)
                var d2 = self.Tank275.item(TableTop - d1)       # do table lookup, from end of table
                d2 = int(d2)                                    # make sure its an integer
                #print ("Liter: ",d2)
                var d3 = (real(d2) / self.Tank275.item(TableTop)) * 100    # calculate percent of full
                d3 = int (d3)
                #print ("Prozent:", d3)
                self.tank_data = [int (d), d1, d2, d3]          # return the data
                return self.tank_data
              end
              def every_second()
            	if !self.tank return nil end
            	self.tank()
              end
              def web_sensor()
                import string
                if !self.tank_data return nil end               #- exit if not initialized -#
                var msg = string.format(
                          "{s}Distanz{m}%.f cm{e}"..
                          "{s}Volumen{m}%.f Liter{e}"..
                          "{s}Prozent Voll{m}%.f %%{e}",
                          self.tank_data[0],self.tank_data[1],self.tank_data[2],self.tank_data[3])
                tasmota.web_send_decimal(msg)
              end
              def json_append()
            	import string
            	var msg = string.format(",\"Tank\":{\"Distanz cm\":%.f,\"Distanz cm\":%.f,\"Volumen\":%.f,\"Prozent Voll\":%.f}",
                tasmota.response_append(msg)
              end
            end
            FOTank = FOTank()
            tasmota.add_driver(FOTank)
            #- ************ The Very End ************* -#
            • B bishop
              @peterfido
              EDIT:
                  var tank_data
                  static buf = []
                 def tank()
                  #print ("\n")
                  # Read Sensor data
                  import json
                  #print("Dist: ", d)
                  #print (self.buf)
                  d = 0
                  #print ("I: ",i)
                  end
                  #print("Cm: ",d1)
                  d3 = int (d3)
                end
                def every_second()
              	self.tank()
                end
                def web_sensor()
                  import string
                end
                def json_append()
              	import string
                end
              end
              FOTank = FOTank()
              peterfido
              @bishop Danke fürs teilen.
              Peterfido
