  4. [Aufruf] ioBroker Jung/Gira eNet Adapter testen
111 Beiträge 16 Kommentatoren 26.0k Aufrufe 3 Beobachtet
    SchuetzeSchulz
    Bitte mal den gesamten Log-Inhalt nach Start des Adapters.
      stoffel67
      Sorry, den Anfang ganz unten hat's nicht mitkopiert…
      der obere Teil wiederholt sich dann immer wieder...( ich denke im 500ms Rhythmus)
      enet.0 2018-01-16 12:18:02.288 debug getGatewayStates: Array of subscribeable Channels: 16,17,18,19,38
      enet.0 2018-01-16 12:18:02.260 debug getGatewayStates: Starting to retrieve the current states from eNet gateway
      enet.0 2018-01-16 12:18:01.837 debug getGatewayStates: Setting state for channel: 38 to ioBroker objects DB Old Value: false new Value: UNDEFINED
      enet.0 2018-01-16 12:18:01.835 debug getGatewayStates: (channels.38.STATE) Channel: 38, Value: UNDEFINED, State: UNDEFINED, Setpoint: 255, Data for channel: {"NUMBER":"38","VALUE":"-1","STATE":"UNDEFINED","SETPOINT":"255"}
      enet.0 2018-01-16 12:18:01.832 debug getGatewayStates: (channels.19.LEVEL) Channel: 19, Value: 0, State: OFF, Setpoint: 255, Data for channel: {"NUMBER":"19","VALUE":"0","STATE":"OFF","SETPOINT":"255"}
      enet.0 2018-01-16 12:18:01.829 debug getGatewayStates: (channels.18.LEVEL) Channel: 18, Value: 0, State: OFF, Setpoint: 255, Data for channel: {"NUMBER":"18","VALUE":"0","STATE":"OFF","SETPOINT":"255"}
      enet.0 2018-01-16 12:18:01.825 debug getGatewayStates: (channels.17.LEVEL) Channel: 17, Value: 0, State: OFF, Setpoint: 255, Data for channel: {"NUMBER":"17","VALUE":"0","STATE":"OFF","SETPOINT":"255"}
      enet.0 2018-01-16 12:18:01.822 debug getGatewayStates: (channels.16.LEVEL) Channel: 16, Value: 0, State: OFF, Setpoint: 255, Data for channel: {"NUMBER":"16","VALUE":"0","STATE":"OFF","SETPOINT":"255"}
      enet.0 2018-01-16 12:18:01.760 debug getGatewayStates: Array of subscribeable Channels: 16,17,18,19,38
      enet.0 2018-01-16 12:18:01.748 debug getGatewayStates: Starting to retrieve the current states from eNet gateway
      enet.0 2018-01-16 12:18:01.401 info ioBroker Jung/Gira eNet Adapter. Gateway IP: 10.10.13.59, Gateway Firmware: 0.91, Gateway Hardware: 73355700, Protocol: 0.03, eNet: 45068305
      enet.0 2018-01-16 12:18:01.241 debug setupDevices: Channels for subscription: 16,17,18,19,38
      enet.0 2018-01-16 12:18:01.238 debug setupDevices: Added Device ID: 42, Name: MasterDimmen, Type: Binaer
      enet.0 2018-01-16 12:18:01.234 debug setupDevices: Added Device ID: 41, Name: Alles EIN/AUS, Type: Binaer
      enet.0 2018-01-16 12:18:01.231 debug setupDevices: Added Device ID: 38, Name: Kanal 23, Type: BINAER
      enet.0 2018-01-16 12:18:01.227 debug setupDevices: Added Device ID: 19, Name: Rolladen EZ <-, Type: Jalousie
      enet.0 2018-01-16 12:18:01.225 debug setupDevices: Added Device ID: 18, Name: Rolladen EZ ->, Type: Jalousie
      enet.0 2018-01-16 12:18:01.223 debug setupDevices: Added Device ID: 17, Name: Rolladen WZ ->, Type: Jalousie
      enet.0 2018-01-16 12:18:01.219 debug setupDevices: Added Device ID: 16, Name: Rolladen WZ <-, Type: Jalousie
      enet.0 2018-01-16 12:18:01.211 debug setupDevices: Reading Scenes/Channels/Devices...
      enet.0 2018-01-16 12:18:01.210 debug setupDevices: Got JSON device information from eNet gateway. Count of Devices: 42, Count of rooms: 20
      Mein Adapter: JUNG/GIRA eNet-Adapter
        SchuetzeSchulz
        Hmm, den Sonnenstandssensor scheint er gar nicht zu bekommen…
        Oder ist evtl. Kanal 38 in Deinem Gateway der Sensor?
        Leider habe ich einen solchen Sensor nicht hier zum Testen :(
          stoffel67
          Ja, sag ich doch oben… die Sonnensensoren erkennt das Gateway nicht.
          Lt. Gira Hotline sollte es gehen, der MA wusste es aber nicht genau...
          Bei der Suche nach Geräten in der App, findet er nix...(trotz Sonnensensor im Programmiermodus..).
          ich hab' dann eine Szene (Sonnenschutz) definiert, aber da kann man nur einen Button definieren, der den/die Rolläden in eine zuvor eingestellte Stellung bringt, also nix mit Automation, ich will, daß die Rolläden bei Sonne alleine runtergehen...
          und ich nicht noch einen Button drücken muß.
          Kannst du dir das zweite Problem erklären... ich sehe die vier Aktoren, kann aber keine Werte ändern,
          d.h. keine Fahrbefehle ausführen...-> "LEVEL" ändern
            SchuetzeSchulz
            Kannst Du mal in den Objekten bei einem Aktor bei LEVEL das Stiftsymbol klicken und mir die Eigenschaften posten:
            Eigentlich sind die beschreibbar…
              stoffel67
              hier:
                SchuetzeSchulz
                Also beschreibbar ist der Wert.
                Werden denn die korrekten Werte zumindest aus dem Gateway ausgelesen?
                Also ändert sich der Wert in ioBroker, wenn Du ihn in der Gateway App änderst?
                  stoffel67
                  Ja, das funktioniert, wenn ich einen Rollladen mit der App auf 50% fahre, wird der Level direkt geändert…
                    SchuetzeSchulz
                    OK, dann habe ich eine Idee:
                    Ändere mal bitte in der Adapterkonfiguration den "Poll Intervall" testweise auf einen höheren Wert (z.B. 600000).
                    Danach den Adapter mal bitte neu starten und dann versuchen den Wert "LEVEL" zu ändern.
                    Tut sich dann was?
                      stoffel67
                      OK, hab ich gemacht,
                      jetzt kann ich den Wert ändern,(z.B. auf 50) er wird auch übernommen, unter Objekte enet.0.channels.17.level steht 50
                      aber der Rolladen bewegt sich nicht… nach ca. 60 sec steht wieder 100 drin...
                        stoffel67
                        hier noch der log:
                        enet.0 2018-01-16 18:51:55.056 debug getGatewayStates: (channels.38.STATE) Channel: 38, Value: UNDEFINED, State: UNDEFINED, Setpoint: 255, Data for channel: {"NUMBER":"38","VALUE":"-1","STATE":"UNDEFINED","SETPOINT":"255"}
                        enet.0 2018-01-16 18:51:55.056 debug getGatewayStates: (channels.19.LEVEL) Channel: 19, Value: 100, State: ON, Setpoint: 255, Data for channel: {"NUMBER":"19","VALUE":"100","STATE":"ON","SETPOINT":"255"}
                        enet.0 2018-01-16 18:51:55.055 debug getGatewayStates: (channels.18.LEVEL) Channel: 18, Value: 100, State: ON, Setpoint: 255, Data for channel: {"NUMBER":"18","VALUE":"100","STATE":"ON","SETPOINT":"255"}
                        enet.0 2018-01-16 18:51:55.055 debug getGatewayStates: Setting state for channel: 17 to ioBroker objects DB Old Value: 50 new Value: 100
                        enet.0 2018-01-16 18:51:55.054 debug getGatewayStates: (channels.17.LEVEL) Channel: 17, Value: 100, State: ON, Setpoint: 255, Data for channel: {"NUMBER":"17","VALUE":"100","STATE":"ON","SETPOINT":"255"}
                        enet.0 2018-01-16 18:51:55.052 debug getGatewayStates: (channels.16.LEVEL) Channel: 16, Value: 100, State: ON, Setpoint: 255, Data for channel: {"NUMBER":"16","VALUE":"100","STATE":"ON","SETPOINT":"255"}
                        enet.0 2018-01-16 18:51:54.767 debug getGatewayStates: Array of subscribeable Channels: 16,17,18,19,38
                        enet.0 2018-01-16 18:51:54.759 debug getGatewayStates: Starting to retrieve the current states from eNet gateway
                        noch eine Info:
                        habe vorhin mit der Gira-Hotline telefoniert, es ist definitiv so, daß mit dem Mobile Gateway keine Sonnensensoren erkannt und eingebunden werden können. Ich soll mir einen eNet-Server besorgen, damit ginge es…. :shock:
                          SchuetzeSchulz
                          Hmm, Mist.
                          Ich hatte leider keinen Rolladenaktor zum Testen hier :(
                          Schaltaktoren und Dimmer gehen aber…
                          Du hast nicht zufällig einen Rolladenaktor über den du mir zum Testen zur Verfügung stellen kannst?
                            stoffel67
                            Leider aktuell nein, sind alle verbaut…
                            ich hatte vor alle meine Rollläden damit auszustatten, wenn's denn funktioniert.. und ich auch "remote" drauf zugreifen kann
                            momentan habe ich überall die Jalousieaktoren mit Memory-funktion und Sensoreingang, mit jeweils einem kabelgebundenen Sonnensensor.
                            (Technik von vor 20 Jahren) :lol:
                            Das funktioniert eigentlich prima, nur muß man immer am Aktor selbst Zeiten für auf/zu einstellen, der Aktor wiederholt einfach alle 24 den rauf oder runter Befehl. Will man den Automatismus nicht muß man resetten und später wieder neu einstellen
                            bin am überlegen ob ich mir so einen eNet-Server besorge ( Preis allerdings: :o :shock: :oops: 😢 )
                              SchuetzeSchulz
                              Hast Du einen Windows Rechner zur Verfügung?
                                stoffel67
                                Hab hier zuhause nur einen I-Mac,
                                Laptop mit Windows ist im Büro
                                  SchuetzeSchulz
                                  Ok.
                                  Ich werd diese Woche nochmal was am Adapter ändern damit wir die Rolladenaktoren mal auslesen können.
                                    SchuetzeSchulz
                                    Ich entschuldige mich schon mal, das es leider alles nicht auf Anhieb klappt :(
                                    Kannst Du den Adapter mal deinstallieren und vom GitHub neu installieren?
                                    Nach Installation den Adapter-Modus direkt auf "Debug" stellen und starten.
                                    Dann das KOMPLETTE Log bitte per Copy & Paste hier posten:
                                    Dann werd ich mal die Daten die von Deinem eNet Gateway kommen analysieren und mir mal anschauen, wo es beim Rolladenaktor hakt.
                                      stoffel67
                                      Ohh, Respekt… da warst du aber lange aktiv...
                                      Ok, hab den Adapter gelöscht und von Github neu installiert...
                                      wie gewünscht, gestartet, anbei das LogFile ( hoffe, es ist OK so)
                                      habe dann mal den Level von Channel 17 auf 50 geändert, der Wert wurde dann auch übernommen, aber der Rolladen bewegt sich nicht..
                                      es werden jetzt auch Rooms und Szenen angezeigt, unter Szenen finde ich dann auch die Szene "Sonnenschutz", allerdings zweimal, einmal Status "true" und einmal "false", keine Ahnung ob und wie man die aktivieren könnte..
                                      4219_enet.log
                                        stoffel67
                                        hab mir mal deinen Code angesehen…. :idea:
                                        wenn ich es richtig verstehe, dann müßte ich mit "telnet 9050" folgenden Befehl schicken:
                                        {"CMD":"ITEM_VALUE_SET","PROTOCOL":"0.03","TIMESTAMP":"1410112233","VALUES"[{"STATE":"VALUE_BLINDS","VALUE":"50","NUMBER":"17"}]}
                                        zurück bekomme ich:
                                        {"PROTOCOL":"0.03","TIMESTAMP":"08154711","CMD":"INDICATION","STATE":-10}
                                        aber bewegen tut sich nix… :?
                                          SchuetzeSchulz
                                          Leider ist im Log die Zeile die ich brauche abgeschnitten :(
                                          Kannst Du mal bitte den Adapter neustarten und mir die LOGDATEI (aus dem IoBroker Log-Verzeichnis) schicken bzw. hier anhängen?
                                          Hast Du mal versucht den Wert per Telnet in prozent zu übermitteln? Also so:
                                          Bitte mal schauen ob 17 auch der Kanal Deines Rolladenaktors ist (müsstest Du in der App irgendwo sehen können).
