  4. Neuer Adapter für Roborock-Staubsauger
    6.3k
1.1k Beiträge 155 Kommentatoren 475.0k Aufrufe 138 Beobachtet
  • Jey CeeJ Jey Cee
    @rissn Meld dich mal in der App neu an, die hatte ein Update.
    Danach gehts wieder.
    breaksrmine
    schrieb am zuletzt editiert von breaksrmine
    #691
    @jey-cee danke geht wieder !
    • C Offline
      chuck2941
      #692
      Hallo, jedesmal wenn der S8 in Aktion ist wird mir der Log mit Warnungen vollgeschrieben, weiß jemand was das ist?
      In den Objekten gibt es keine Einträge dazu.
      24-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:00.628 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.0.map.mapData" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.432 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.begin" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.433 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.end" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.duration" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.434 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.area" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.435 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.error" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.complete" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.436 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.start_type" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.437 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.clean_type" has no existing object, this might lead to an error in future versions
      2024-11-26 08:09:04.438 - warn: roborock.0 (525) State "roborock.0.Devices.5JcrRUnxVs84yiX2hSJUkJ.cleaningInfo.records.21.finish_reason" has no existing object, this might lead to an error in future versions
      T E 2 Antworten Letzte Antwort
      • MatzebhvM Offline
        MatzebhvM Offline
        Matzebhv
        #693
        Moin,
        ich habe seit heute den S8 MaxV Ultra.
        Hier kann anscheinend die Karte nicht mehr gezogen werden, das Log läuft über mit:
        Failed to execute get_map_v1 on robot xxxxxxxxxxT0dDsc9ju (roborock.vacuum.a97): Error: Failed to convert JavaScript value `Undefined` into rust type `String` at /opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:647:29 at Array.forEach (<anonymous>) at MapCreator.canvasMap (/opt/iobroker/node_modules/iobroker.roborock/lib/mapCreator.js:624:30) at vacuum.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:84:46)
        Wird das bei dem Modell noch nicht unterstützt?
        Bei dem Vorgänger S6MaxV Ultra hatte ich das Problem nicht.
        Habe die Karte jetzt erstmal deaktiviert.
        Matze
        • H Offline
          hansano
          #694
          Bekomme seit ein paa Tage folgende Fehlermeldung:
          roborock.0
          2024-11-30 11:31:54.304	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
          roborock.0
          2024-11-30 11:12:54.298	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
          roborock.0
          2024-11-30 10:59:54.296	error	Failed to update updateHomeData with error: Error: getaddrinfo ENOTFOUND api-eu.roborock.com
          roborock.0
          roborock.0
          Hat noch jemand das Problem und eventuell eine Lösung?
          • H hansano
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            roborock.0
            D Online
            D Online
            docsnyder7
            #695
            bei mir schauts seit dem Update auf js 7.0.3 so aus
            roborock.0
            	2024-11-30 13:45:33.234	error	Login returned empty userdata.
            roborock.0
            	2024-11-30 13:45:33.233	error	Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:85:20)
            roborock.0
            	2024-11-30 13:45:33.228	error	unhandled promise rejection: Login returned empty userdata.
            roborock.0
            	2024-11-30 13:45:33.228	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            roborock.0
            	2024-11-30 13:45:33.202	error	Error in getUserData: Login returned empty userdata.
            roborock.0
            	2024-11-30 13:45:32.838	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
            roborock.0
            	2024-11-30 13:45:32.814	info	starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.3
            userdaten stehen im Adapter und sind auch korrekt
            JackDanielJ 1 Antwort Letzte Antwort
            • C chuck2941
              Tom_W
              #696
              @chuck2941
              Hallo Chuck2941,
              das ist bei mir genau das selbe. Hast du schon rausgefunden was dagegen hilft?
              • T Tom_W
                @chuck2941
                Hallo Chuck2941,
                TimoWald
                schrieb am zuletzt editiert von TimoWald
                #697
                Hallo habe aktuell diese Fehlermeldung. Diese kommt aber nur wenn ich Kartenerstellung aktiviere.
                Was kann ich dagegen tun?
                2024-12-07 13:00:18.752 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:20.373 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:21.787 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:24.444 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:26.375 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:28.423 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:30.431 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:32.502 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:34.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:36.428 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:38.402 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:40.751 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:42.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:44.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:46.411 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:48.468 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:49.028 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.1.16" started with pid 240048
                2024-12-07 13:00:50.514 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:50.963 - info: daswetter.0 (240048) starting. Version 3.1.16 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.0, js-controller: 7.0.3
                2024-12-07 13:00:51.008 - info: daswetter.0 (240048) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                2024-12-07 13:00:51.522 - info: daswetter.0 (240048) cleaned everything up...
                2024-12-07 13:00:51.537 - info: host.iobroker instance system.adapter.daswetter.0 having pid 240048 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2024-12-07 13:00:52.441 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:54.501 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:56.543 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:00:58.377 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:00.558 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:02.519 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:04.407 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:04.646 - info: solax.0 (70086) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
                2024-12-07 13:01:06.664 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:08.438 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:10.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:12.451 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:14.367 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:16.430 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:18.613 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:20.397 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:22.422 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:24.477 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:26.365 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:28.442 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:30.598 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:32.440 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                2024-12-07 13:01:34.439 - error: roborock.0 (COMPACT) Error writing map file Error: EACCES: permission denied, open './test.rrmap.gz'
                • D docsnyder7
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  JackDanielJ Offline
                  JackDanielJ Offline
                  JackDaniel
                  #698
                  @docsnyder7 sagte in Neuer Adapter für Roborock-Staubsauger:
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  bei mir auch, somit ist der adapter im moment tot
                  Carpe diem
                  Ro75R 1 Antwort Letzte Antwort
                  • JackDanielJ JackDaniel
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    Ro75R Offline
                    Ro75R Offline
                    Ro75
                    #699
                    @jackdaniel was passiert wenn du auf die vorherige 6.x Version vom js-controler gehst? Bei mir läuft der Adapter so wie er soll.
                    Ro75
                    • JackDanielJ Offline
                      JackDanielJ Offline
                      JackDaniel
                      schrieb am zuletzt editiert von JackDaniel
                      #700
                      er lief ja schon unter 7.x ohne probleme, es sieht für mich so aus als ob roborock da etwas serverseitig geändert hat (bei der anmeldung)
                      Carpe diem
                      • copystringC Offline
                        copystringC Offline
                        copystring
                        #701
                        Mal die App auf dem Handy öffnen. Eventuell müssen neue AGB angenommen werden.
                        Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                        https://paypal.me/copystring
                          JackDanielJ Offline
                          JackDaniel
                          #702
                          das war auch mein erster gedanke
                          hab mich sogar ab und wieder angemeldet, brachte aber auch nichts
                          Carpe diem
                            copystringC Offline
                            copystring
                            #703
                            Manchmal wird man gebannt, wenn zu viele Anfragen verschickt werden. Mal den Router neu starten, sodass man eine neue IP bekommt. Dann sollte es laufen.
                              JackDanielJ Offline
                              JackDaniel
                              #704
                              hmm ich hab aber eine statische ib...
                              Carpe diem
                                copystringC Offline
                                copystring
                                #705
                                Okay. So eine Sperre geht soweit ich weiß maximal 24 Stunden aus meiner Erfahrung heraus. Vielleicht mal den Adapter für einen Tag abschalten.
                                Ansonsten kann ich leider nicht so viel tun. Ich kann mir gerne mal ein Debuglog angucken, aber ich hatte schon einige solche Fälle und bisher noch keine Lösung außer sich eine neue IP zu holen.
                                  JackDanielJ Offline
                                  JackDaniel
                                  #706
                                  ok dann ist der adapter für mich leider geschichte :(
                                  neu ip gibt es nicht da statisch, und adapter ist schon seit sonntag deaktiviert (und beim start jetzt kam sofort der crash)
                                  und das ich nun nach jahren mit der ip gepannt wurde, ist für mich nicht ganz nachvollziehbar, da ich ja an der nutzung nichts geändert habe
                                  Carpe diem
                                    copystringC Offline
                                    copystring
                                    #707
                                    Ach so. Okay. Könnte natürlich auch ein anderer Fehler sein. Magst du mir ein Debuglog schicken?
                                      JackDanielJ Offline
                                      JackDaniel
                                      #708
                                      kommt auch nicht wirklich viel, die aktuelle dev auf debug gestellt beim start
                                      roborock.0
                                      2024-12-11 13:17:21.875	error	Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
                                      roborock.0
                                      2024-12-11 13:17:21.680	error	Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
                                      roborock.0
                                      2024-12-11 13:17:21.659	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
                                      roborock.0
                                      2024-12-11 13:17:21.402	debug	initializeRoborockApi
                                      roborock.0
                                      2024-12-11 13:17:21.377	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                      roborock.0
                                      2024-12-11 13:17:21.367	info	starting. Version 0.6.17 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v20.18.1, js-controller: 7.0.5
                                      roborock.0
                                      2024-12-11 13:17:21.212	debug	Plugin sentry Initialize Plugin (enabled=true)
                                      roborock.0
                                      2024-12-11 13:17:21.190	debug	States connected to redis: 127.0.0.1:6379
                                      roborock.0
                                      2024-12-11 13:17:21.185	debug	States create User PubSub Client
                                      roborock.0
                                      2024-12-11 13:17:21.185	debug	States create System PubSub Client
                                      roborock.0
                                      2024-12-11 13:17:21.182	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                                      roborock.0
                                      2024-12-11 13:17:21.173	debug	Objects connected to redis: 127.0.0.1:6379
                                      roborock.0
                                      2024-12-11 13:17:21.171	debug	Objects client initialize lua scripts
                                      roborock.0
                                      2024-12-11 13:17:21.036	debug	Objects create User PubSub Client
                                      roborock.0
                                      2024-12-11 13:17:21.036	debug	Objects create System PubSub Client
                                      roborock.0
                                      2024-12-11 13:17:21.035	debug	Objects client ready ... initialize now
                                      roborock.0
                                      2024-12-11 13:17:21.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                                      Carpe diem
                                      • T TimoWald
                                        TimoWald
                                        #709
                                        @timowald Keiner eine Lösung für mich?
                                        IOB läuft auf Proxmox.
                                        • T TimoWald
                                          Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          #710
                                          @timowald Compact mode aktiv? Für die map wird doch ein Port benötigt.
                                          Ro75
                                          T mcm1957M 2 Antworten Letzte Antwort
