  4. BLE Startet nicht
    1.0k
    6.1k
BLE Startet nicht
21 Beiträge 4 Kommentatoren 3.4k Aufrufe 5 Beobachtet
    @larryxxl
    Bitte CodeTags verwenden und das Logfile aus
    iob logs --watch
    nehmen. Das ist dann auch chronologisch richtig.
    LarryXXL
    pi@iobrokerII:~$ iob logs --watch
    2024-11-30 15:46:50.275  - error: radar2.0 (15194) adapter disabled
    2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIGFOUND): Without reason
    2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
    • L LarryXXL
      haselchenH Offline
      haselchenH Offline
      haselchen
      @larryxxl
      Hast du die anderen beiden Befehle eingegeben?
      L 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @larryxxl
        LarryXXL
        @haselchen ja beide Befehle wurden ausgeführt.
        2024-11-30 15:51:22.881  - info: radar2.0 (15292) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v20.18.1, js-controller: 7.0.3
        2024-11-30 15:51:22.927  - info: radar2.0 (15292) radar2 initialization started...
        2024-11-30 15:51:22.932  - info: radar2.0 (15292) Will use l2Ping for BT scans.
        2024-11-30 15:51:22.951  - info: radar2.0 (15292) found and will use '@abandonware/noble'
        2024-11-30 15:51:22.961  - info: radar2.0 (15292) debug: radar2 set to flag items away if they are not seen for 3 minutes
        2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known BT list: [ '01:12:23:34:45:56' ]
        2024-11-30 15:51:22.963  - info: radar2.0 (15292) debug: use known IP list: [ '192.168.178.10', '192.168.178.10' ]
        2024-11-30 15:51:22.964  - info: radar2.0 (15292) arp-scan will use the following interfaces: [ 'ens18' ]
        2024-11-30 15:51:22.970  - info: radar2.0 (15292) Connected with '0.0.0.0' for DHCP Scan
        2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: radar2 set to scan every 30 seconds and printers every 720 minutes.
        2024-11-30 15:51:22.985  - info: radar2.0 (15292) debug: Will 'not save' unknown BT devices and will 'save' unknown IP devices!
        2024-11-30 15:51:22.995  - info: radar2.0 (15292) Will try to scan BT devices: hci0    78:8A:86:1F:0B:8B
        2024-11-30 15:51:23.010  - warn: radar2.0 (15292) Uncaught Exception: spawn ping ENOENT
        2024-11-30 15:51:23.010  - error: radar2.0 (15292) uncaught exception: spawn ping ENOENT
        2024-11-30 15:51:23.011  - error: radar2.0 (15292) Error: spawn ping ENOENT
            at ChildProcess._handle.onexit (node:internal/child_process:285:19)
            at onErrorNT (node:internal/child_process:483:16)
            at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
        2024-11-30 15:51:23.011  - error: radar2.0 (15292) Exception-Code: ENOENT: spawn ping ENOENT
        2024-11-30 15:51:23.016  - info: radar2.0 (15292) Unload adapter now with null
        2024-11-30 15:51:23.017  - info: radar2.0 (15292) Adapter disconnected and stopped with dostop(null) and callback(true)
        2024-11-30 15:51:23.017  - info: radar2.0 (15292) terminating
        2024-11-30 15:51:23.017  - warn: radar2.0 (15292) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-11-30 15:51:23.018  - info: radar2.0 (15292) terminating
        2024-11-30 15:51:23.067  - info: radar2.0 (15292) debug: created State radar2.0.info.connection
        2024-11-30 15:51:23.385  - debug: ble.0 (15303) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-11-30 15:51:23.403  - debug: ble.0 (15303) Objects client ready ... initialize now
        2024-11-30 15:51:23.405  - debug: ble.0 (15303) Objects create System PubSub Client
        2024-11-30 15:51:23.406  - debug: ble.0 (15303) Objects create User PubSub Client
        2024-11-30 15:51:23.428  - debug: ble.0 (15303) Objects client initialize lua scripts
        2024-11-30 15:51:23.434  - debug: ble.0 (15303) Objects connected to redis: 127.0.0.1:9001
        2024-11-30 15:51:23.449  - debug: ble.0 (15303) Redis States: Use Redis connection: 127.0.0.1:9000
        2024-11-30 15:51:23.457  - debug: ble.0 (15303) States create System PubSub Client
        2024-11-30 15:51:23.458  - debug: ble.0 (15303) States create User PubSub Client
        2024-11-30 15:51:23.512  - debug: ble.0 (15303) States connected to redis: 127.0.0.1:9000
        2024-11-30 15:51:23.515  - info: radar2.0 (15292) terminating
        2024-11-30 15:51:23.552  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-11-30 15:51:23.610  - info: ble.0 (15303) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
        2024-11-30 15:51:23.671  - info: ble.0 (15303) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
        2024-11-30 15:51:23.672  - info: ble.0 (15303) enabled plugins: _default
        2024-11-30 15:51:23.672  - info: ble.0 (15303) monitored services:
        2024-11-30 15:51:23.721  - info: ble.0 (15303) starting scanner process...
        ^[[A^[[A^[[A^[[A^[[A^[[A^[[A^Cpi@iobrokerII:~$
        pi@iobrokerII:~$
        pi@iobrokerII:~$
        2024-11-30 15:46:50.363  - warn: radar2.0 (15194) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
        2024-11-30 15:46:50.896  - error: host.iobrokerII instance system.adapter.radar2.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
        • L LarryXXL
          pi@iobrokerII:~$
          pi@iobrokerII:~$
          @larryxxl
          sudo hcitool lescan
          sagt?
            @larryxxl
            sudo hcitool lescan
            sagt?
            LarryXXL
            @thomas-braun said in BLE Startet nicht:
            sudo hcitool lescan
            pi@iobrokerII:~$ sudo hcitool lescan
            [sudo] Passwort für pi:
            LE Scan ...
            C4:7C:8D:67:4D:75 (unknown)
            32:37:48:71:31:42 (unknown)
            5C:85:7E:13:24:5D (unknown)
            5C:85:7E:13:24:5D Flower care
            D8:D6:68:9E:43:9B (unknown)
            D8:D6:68:9E:43:9B TY
            6B:67:61:43:6C:36 (unknown)
            5C:85:7E:B1:25:58 (unknown)
            5C:85:7E:B1:25:58 Flower care
            08:A6:F7:3A:4C:96 (unknown)
            C4:7C:8D:67:4D:75 Flower care
            6B:67:61:43:6C:36 EL_B2kgaCl6
            08:A6:F7:3A:4C:96 IPSTube_3A4C96
            C4:7C:8D:67:4E:78 (unknown)
            C4:7C:8D:67:4E:78 Flower care
            5C:85:7E:13:24:29 (unknown)
            5C:85:7E:13:24:29 Flower care
            54:EF:44:2B:0D:7A (unknown)
            4A:63:26:56:43:FD (unknown)
            5C:85:7E:13:26:95 (unknown)
            • L LarryXXL
              pi@iobrokerII:~$
              pi@iobrokerII:~$
              @larryxxl sagte in BLE Startet nicht:
              Du wirst da noch plugins aktivieren müssen, wenn du die Flower care Dinger sehen willst.
              haselchenH L 2 Antworten Letzte Antwort
              • L LarryXXL
                sudo hcitool lescan
                LE Scan ...
                haselchenH Offline
                haselchenH Offline
                haselchen
                @larryxxl
                BLE funktioniert doch?!
                Ich sehe da keine Fehler im Log.
                Wie sehen deine Radar Einstellungen aus?
                Edit:
                Was soll das _default in den Plugins?
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  Sind aktiviert
                  ble.0
                  2024-11-30 15:20:14.111 info loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                    LarryXXL
                    Plugins xiaomi, mi-flora
                    aber Adapter bleibt Gelb. nicht verbunden mit Gerät oder Dienst.
                      @larryxxl
                      Edit:
                      LarryXXL
                      @haselchen
                      Radar 2 läuft ebenfalls nicht. auch nicht mit Noble.
                        Sind aktiviert
                        ble.0
                        LarryXXL
                        @haselchen
                        BLE plugins sind Xiaomi, mi-flora im Log stehen noch andere Plugins.
                        ble.0
                        2024-11-30 16:12:35.326	info	starting scanner process...
                        ble.0
                        2024-11-30 16:12:35.276	info	monitored services: fe95
                        ble.0
                        2024-11-30 16:12:35.276	info	enabled plugins: Xiaomi, mi-flora, _default
                        ble.0
                        2024-11-30 16:12:35.275	info	loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                        ble.0
                        2024-11-30 16:12:35.212	info	starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                        ble.0
                        2024-11-30 16:12:35.136	debug	States connected to redis: 127.0.0.1:9000
                        ble.0
                        2024-11-30 16:12:35.080	debug	States create User PubSub Client
                        ble.0
                        2024-11-30 16:12:35.079	debug	States create System PubSub Client
                        ble.0
                        2024-11-30 16:12:35.073	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                        ble.0
                        2024-11-30 16:12:35.059	debug	Objects connected to redis: 127.0.0.1:9001
                        ble.0
                        2024-11-30 16:12:35.056	debug	Objects client initialize lua scripts
                        ble.0
                        2024-11-30 16:12:35.037	debug	Objects create User PubSub Client
                        ble.0
                        2024-11-30 16:12:35.036	debug	Objects create System PubSub Client
                        ble.0
                        2024-11-30 16:12:35.035	debug	Objects client ready ... initialize now
                        ble.0
                        2024-11-30 16:12:35.019	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                        ble.0
                        2024-11-30 16:12:33.069	info	terminating
                        ble.0
                        2024-11-30 16:12:32.568	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        ble.0
                        2024-11-30 16:12:32.568	info	terminating
                        ble.0
                        2024-11-30 16:12:32.566	info	Got terminate signal TERMINATE_YOURSELF
                        F 1 Antwort Letzte Antwort
                        • L LarryXXL
                          @haselchen
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          ble.0
                          funky4t
                          Ich würd mich gern hier "anhängen"... Habe den Broker als VM in Proxmox laufen und der BLE lief bis dahin okay. Ich musste aus einem anderen Grunde heute ein Proxmox Backup einspielen, lief alles reibungslos bis ich merkte, dass meine BLE devices (Xiaomi Temp/Humidtiy) sich angeblich seit 7 Tagen (Date vom letzten Backup) nicht aktualisiert haben. Hab den BLE Adapter gecheckt, der DriverState steht auf unknown und die Objects werden nicht upgedatet. Ich hab die States gelöscht, danach wurden sie auch nach BLE Neustart nicht neu geschrieben. Adapter gelöscht, neu installiert, leider erfolglos.
                          Hab mit ChatGPT ebenfalls einiges getestet, leider erfolglos. Komisch war da, dass
                          sudo hcitool lescan
                          auf der Broker wie hier diverse BLE Geräte anzeigte, die aber im BLE Adapter nicht angelegt wurden.
                          iob logs --watch
                          ergibt folgendes:
                          2024-12-07 21:12:38.011  - info: host.debianbroker stopInstance system.adapter.ble.0 (force=false, process=true)
                          2024-12-07 21:12:38.014  - info: ble.0 (8139) Got terminate signal TERMINATE_YOURSELF
                          2024-12-07 21:12:38.015  - info: ble.0 (8139) terminating
                          2024-12-07 21:12:38.015  - info: ble.0 (8139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2024-12-07 21:12:38.106  - info: host.debianbroker stopInstance system.adapter.ble.0 send kill signal
                          2024-12-07 21:12:38.516  - info: ble.0 (8139) terminating
                          2024-12-07 21:12:38.558  - info: host.debianbroker instance system.adapter.ble.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2024-12-07 21:12:41.677  - info: host.debianbroker instance system.adapter.ble.0 in version "0.14.0" started with pid 10359
                          2024-12-07 21:12:41.954  - debug: ble.0 (10359) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2024-12-07 21:12:41.978  - debug: ble.0 (10359) Objects client ready ... initialize now
                          2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create System PubSub Client
                          2024-12-07 21:12:41.979  - debug: ble.0 (10359) Objects create User PubSub Client
                          2024-12-07 21:12:42.034  - debug: ble.0 (10359) Objects client initialize lua scripts
                          2024-12-07 21:12:42.036  - debug: ble.0 (10359) Objects connected to redis: 127.0.0.1:9001
                          2024-12-07 21:12:42.116  - debug: ble.0 (10359) Redis States: Use Redis connection: 127.0.0.1:9000
                          2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create System PubSub Client
                          2024-12-07 21:12:42.182  - debug: ble.0 (10359) States create User PubSub Client
                          2024-12-07 21:12:42.258  - debug: ble.0 (10359) States connected to redis: 127.0.0.1:9000
                          2024-12-07 21:12:42.334  - info: ble.0 (10359) starting. Version 0.14.0 in /opt/iobroker/node_modules/iobroker.ble, node: v20.18.1, js-controller: 7.0.3
                          2024-12-07 21:12:42.398  - info: ble.0 (10359) loaded plugins: Xiaomi, mi-flora, ruuvi-tag, BTHome, _default
                          2024-12-07 21:12:42.398  - info: ble.0 (10359) enabled plugins: Xiaomi, _default
                          2024-12-07 21:12:42.398  - info: ble.0 (10359) monitored services: fe95
                          2024-12-07 21:12:42.448  - info: ble.0 (10359) starting scanner process...
                          In der Vergangenheit hab ich die BLE Themen immer mit Google oder ChatGPT hinbekommen, aber heute stoße ich an meine Grenzen.
                          Falls ich hier völlig falsch bin seht es mir bitte nach, der Broker ist für mich Hobby und ich sehe ich eher als User. Aber wenn ich helfen kann einen Bug einzukreisen unterstütze ich gern. Falls der Bug vorm Bildschirm ist, lern ich gern dazu! ;)
                          Ergebnis von
                          iob diag
                          findet ihr hier: iobdiag.rtf
                          Was ich noch versucht habe sind
                          iob fix
                          ohne Fehlermeldung durchgelaufen
                          sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                          ohne Effekt, hat sonst immer funktioniert.
                          Ich werde morgen mal eine neue VM mit IOB und nur dem BLE aufsetzen und dann schauen, wie sich der BT Stick darin verhält....
                          • F funky4t
                            sudo hcitool lescan
                            iob logs --watch
                            ergibt folgendes:
                            Ergebnis von
                            iob diag
                            iob fix
                            @funky4t
                            Ja, der ble-Adapter ist gerade kaputt.
                            Gibt auch schon Issues dazu.
                            Und bitte die Ausgabe von iob diag nicht als rtf oder word-Dokument oder sowas hier rein klatschen, das kann ich mit meinem Editor nicht gut lesen.
                            Die reine Ausgabe in CodeTags eingebettet hier rein, mehr braucht es nicht.
                              @funky4t
                              funky4t
                              Herzlichen Dank @thomas-braun für deine Info zum Adapter und dem DIAG, dann muss ich vorläufig nicht weiter probieren.👍
                              • F funky4t
                                @funky4t
                                Genauer:
                                https://github.com/AlCalzone/ioBroker.ble/issues/871
                                Evtl. muss die alternative verwendet werden:
                                https://github.com/AlCalzone/ioBroker.ble/issues/870
