  4. [Neuer Adapter] EuSec
adaptercamerasdoorbelleufyeufycamsecurity
1.2k Beiträge 160 Kommentatoren 620.0k Aufrufe 147 Beobachtet
  • LongbowL Longbow
    @guitardoc
    ich bekomme leider nur Fehlermeldungen vom Iobroker wenn ich die neue Version (1.3.2) update:
    bei der Version 1.2.1 keine Fehlermeldung. An was liegt das bei mir, wenn bei Euch alles klappt ?
    web.0
    2024-09-13 10:41:55.906	info	http server listening on port 8082
    web.0
    2024-09-13 10:41:55.903	error	Cannot start extension "eusec.0": Error: Cannot find module 'iobroker.eusec/build/lib/web.js'Require stack:- /opt/iobroker/node_modules/iobroker.web/main.js
    web.0
    2024-09-13 10:41:55.902	info	socket.io server listening on port 8082
    web.0
    2024-09-13 10:41:55.694	info	starting. Version 6.2.5 in /opt/iobroker/node_modules/iobroker.web, node: v20.17.0, js-controller: 6.0.11
    host.iobroker-Final
    2024-09-13 10:41:54.310	info	Rebuild for adapter system.adapter.eusec.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: Node.js v20.17.0
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: }
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: requestPath: 'eufy-security-client'
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32) {
    host.iobroker-Final
    2024-09-13 10:41:54.310	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:36:35)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:771:18)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:487:19)
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: ^
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: throw err;
    host.iobroker-Final
    2024-09-13 10:41:54.309	error	Caught by controller[0]: node:internal/modules/cjs/loader:495
    host.iobroker-Final
    2024-09-13 10:41:53.781	info	instance system.adapter.eusec.0 in version "1.3.2" (non-npm: bropat/ioBroker.eusec#3fa381bf8ccb5eda3d13d201490ee4ee0207c1b0) started with pid 387373
    G Online
    G Online
    guitardoc
    #1050
    @longbow Hast du die alte Version vorher deinstalliert? Du musst erst den eusec-Adapter komplett deinstallieren und dann über die Katze die Git-Version installieren. Dann sollten keine Fehlermeldungen mehr kommen.,
    LongbowL 1 Antwort Letzte Antwort
    • G guitardoc
      LongbowL Offline
      LongbowL Offline
      Longbow
      #1051
      @guitardoc ja habe ich über die Mülltonne im iobroker... oder wie kann ich das anderes lösen
      G 1 Antwort Letzte Antwort
      • LongbowL Longbow
        G Online
        G Online
        guitardoc
        #1052
        @longbow Unter Adapter oder unter Instanzen? Du musst den Adapter löschen, nicht die Instanz. Dann den Adapter neu installieren und danach noch die Instanz erzeugen.
        • G guitardoc
          LongbowL Offline
          LongbowL Offline
          Longbow
          #1053
          @guitardoc hab ich auch so gemacht gerade erneut, die Fehlermeldungen bleiben. 2024-09-13 13_09_36-adapters - iobroker-Final.png
          • LongbowL Longbow
            G Online
            G Online
            guitardoc
            #1054
            @longbow und dann hierüber neu installiert:
            • G guitardoc
              LongbowL Offline
              LongbowL Offline
              Longbow
              schrieb am zuletzt editiert von Longbow
              #1055
              @guitardoc genau so habe ich und mache ich es auch.
              Kann nicht mal in dem Adapter die Daten Speichern, er geht zwar auf speichern, aber wenn ich erneut ins Instanz gehe, ist es leer
              host.iobroker-Final
              2024-09-13 14:06:53.380	info	iobroker npm-rebuild: Rebuilding native modules ...
              host.iobroker-Final
              2024-09-13 14:06:52.818	info	iobroker rebuild
              host.iobroker-Final
              2024-09-13 14:06:52.818	warn	adapter "eusec" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
              host.iobroker-Final
              2024-09-13 14:06:52.818	info	system.adapter.eusec.0 will be rebuilt
              host.iobroker-Final
              2024-09-13 14:06:52.818	info	Adapter system.adapter.eusec.0 needs rebuild and will be restarted afterwards.
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: Node.js v20.17.0
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: }
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: requestPath: 'eufy-security-client'
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1288:32) {
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1469:14)
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:36:35)
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
              host.iobroker-Final
              2024-09-13 14:06:52.818	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1311:19)
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1051:27)
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27)
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:771:18)
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:487:19)
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: ^
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: throw err;
              host.iobroker-Final
              2024-09-13 14:06:52.817	error	Caught by controller[0]: node:internal/modules/cjs/loader:495
              host.iobroker-Final
              2024-09-13 14:06:51.996	info	instance system.adapter.eusec.0 in version "1.3.2" started with pid 393588
              • LongbowL Longbow
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                host.iobroker-Final
                G Online
                G Online
                guitardoc
                #1056
                @longbow said in [Neuer Adapter] EuSec:
                Das sieht so aus, als ob da schon was installiert war. Mach mal unter ssh
                cd /opt/iobroker/
                npm ls
                • G guitardoc
                  cd /opt/iobroker/
                  npm ls
                  LongbowL Offline
                  LongbowL Offline
                  Longbow
                  #1057
                  @guitardoc sagte in [Neuer Adapter] EuSec:
                  npm ls
                  also gerade ausgeführt... was soll es zeigen?
                  Ok als ich es gepostet habe, gehen... es ist ein Eufy Security Client installiert, wieso und warum? Kann das der Grund sein, in den Adapter finde ich diesen nicht, wie lösche ich diesen?
                  iobroker.inst@3.0.0 /opt/iobroker
                  +-- @iobroker-javascript.0/chroma-js@npm:chroma-js@3.1.1
                  +-- @iobroker-javascript.0/mathjs@npm:mathjs@13.1.1
                  +-- @iobroker-javascript.0/moment-duration-format@npm:moment-duration-format@2.3.2
                  +-- @iobroker-javascript.0/moment-timezone@npm:moment-timezone@0.5.45
                  +-- @iobroker-javascript.0/moment@npm:moment@2.30.1
                  +-- @iobroker-javascript.0/night@npm:night@0.0.0
                  +-- eufy-security-client@3.1.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#27e7c87d67810667022cf6cabb0c46ab1b818654)
                  +-- iobroker.accuweather@1.5.0
                  +-- iobroker.admin@7.0.23
                  +-- iobroker.alarm@3.6.1
                  +-- iobroker.alias-manager@1.2.6
                  +-- iobroker.backitup@3.0.22
                  +-- iobroker.bidirectional-counter@2.1.3
                  +-- iobroker.chromecast@3.4.1
                  +-- iobroker.cloud@5.0.1
                  +-- iobroker.daswetter@3.1.16
                  +-- iobroker.device-watcher@2.12.1
                  +-- iobroker.discovery@4.5.0
                  +-- iobroker.doorbird@1.7.0
                  +-- iobroker.drag-indicator@2.2.0
                  +-- iobroker.dwd@2.8.5
                  +-- iobroker.energiefluss-erweitert@0.4.1
                  +-- iobroker.eventlist@2.0.1
                  +-- iobroker.fritzdect@2.5.11
                  +-- iobroker.fullcalendar@2.4.2
                  +-- iobroker.geofency@1.2.4
                  +-- iobroker.history@3.0.1
                  +-- iobroker.hm-rega@5.0.0
                  +-- iobroker.hm-rpc@1.17.0
                  +-- iobroker.homeconnect@1.4.1
                  +-- iobroker.hue@3.12.0
                  +-- iobroker.ical@1.15.0
                  +-- iobroker.icons-addictive-flavour-png@0.1.0
                  +-- iobroker.icons-freepic@1.0.0
                  +-- iobroker.icons-icons8@0.0.1
                  +-- iobroker.icons-material-png@0.1.0
                  +-- iobroker.icons-material-svg@0.1.0
                  +-- iobroker.icons-mfd-png@1.2.1
                  +-- iobroker.icons-mfd-svg@1.2.0
                  +-- iobroker.icons-open-icon-library-png@0.1.2
                  +-- iobroker.icons-smarthome@1.0.0
                  +-- iobroker.icons-ultimate-png@1.0.1
                  +-- iobroker.influxdb@4.0.2
                  +-- iobroker.info@2.0.0
                  +-- iobroker.iot@3.3.0
                  +-- iobroker.javascript@8.7.6
                  +-- iobroker.js-controller@6.0.11
                  +-- iobroker.klf200@1.2.0
                  +-- iobroker.lightcontrol@0.8.0
                  +-- iobroker.linkeddevices@1.5.5
                  +-- iobroker.modbus@6.2.3
                  +-- iobroker.mqtt@5.2.0
                  +-- iobroker.myenergi@0.0.3
                  +-- iobroker.net-tools@1.0.11
                  +-- iobroker.netatmo@3.1.0
                  +-- iobroker.nina@0.0.25
                  +-- iobroker.notification-manager@1.1.2
                  +-- iobroker.nuki-extended@2.7.0
                  +-- iobroker.onvif@1.1.4
                  +-- iobroker.openweathermap@1.1.2
                  +-- iobroker.operating-hours@1.1.0
                  +-- iobroker.ping@1.6.2
                  +-- iobroker.places@1.2.0
                  +-- iobroker.pollenflug@2.0.0
                  +-- iobroker.proxmox@2.3.0
                  +-- iobroker.pushover@3.0.6
                  +-- iobroker.reolink@1.1.1
                  +-- iobroker.robonect@1.3.6
                  +-- iobroker.roborock@0.6.11 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#801511a70e1eeb3ae66f2608f9d6c86b8933e515)
                  +-- iobroker.samsung_tizen@1.1.0
                  +-- iobroker.scenes@3.2.1
                  +-- iobroker.shelly@7.0.0
                  +-- iobroker.simple-api@2.8.0
                  +-- iobroker.smartgarden@2.0.1
                  +-- iobroker.smartthings@0.0.4
                  +-- iobroker.socketio@6.7.1
                  +-- iobroker.solaredge@1.4.1
                  +-- iobroker.sonos@3.0.0
                  +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
                  +-- iobroker.sql@3.0.1
                  +-- iobroker.statistics@2.4.0
                  +-- iobroker.systeminfo@1.2.0
                  +-- iobroker.tankerkoenig@3.4.0
                  +-- iobroker.tr-064@4.3.0
                  +-- iobroker.trashschedule@3.3.0
                  +-- iobroker.tuya@3.16.0
                  +-- iobroker.unifi@0.7.0
                  +-- iobroker.upnp@1.0.21
                  +-- iobroker.virtualpowermeter@1.4.6
                  +-- iobroker.vis-bars@0.1.4
                  +-- iobroker.vis-canvas-gauges@1.0.1
                  +-- iobroker.vis-colorpicker@2.0.3
                  +-- iobroker.vis-fancyswitch@1.1.0
                  +-- iobroker.vis-google-fonts@1.0.4
                  +-- iobroker.vis-history@1.0.0
                  +-- iobroker.vis-hqwidgets@1.5.1
                  +-- iobroker.vis-icontwo@1.5.0
                  +-- iobroker.vis-inventwo@3.3.4
                  +-- iobroker.vis-jqui-mfd@1.1.1
                  +-- iobroker.vis-justgage@2.1.7
                  +-- iobroker.vis-map@1.1.2
                  +-- iobroker.vis-material-advanced@1.7.4
                  +-- iobroker.vis-material@0.1.3
                  +-- iobroker.vis-materialdesign@0.5.9
                  +-- iobroker.vis-metro@1.2.0
                  +-- iobroker.vis-plumb@1.0.2
                  +-- iobroker.vis-rgraph@0.0.2
                  +-- iobroker.vis-timeandweather@1.2.2
                  +-- iobroker.vis-weather@2.5.9
                  +-- iobroker.vis@1.5.6
                  +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
                  +-- iobroker.weather-warnings@0.6.7
                  +-- iobroker.weatherunderground@3.7.0
                  +-- iobroker.web@6.2.5
                  +-- iobroker.welcome@0.3.0
                  +-- iobroker.wolf-smartset@1.2.3
                  +-- iobroker.wolf@1.7.0
                  +-- iobroker.ws@2.6.2
                  +-- iobroker.yr@5.3.0
                  `-- npm@10.3.0
                  • LongbowL Longbow
                    npm ls
                    `-- npm@10.3.0
                    Adnim
                    #1058
                    @longbow
                    also da nix von Hand löschen würde ich sagen.
                    Ich glaube du hast da nen Update Stau im System; hau mal nen IOB Diag raus...
                    • LongbowL Offline
                      LongbowL Offline
                      Longbow
                      #1059
                      @adnim
                      Mhh kann so was passieren...
                      Skript v.2024-05-22
                      *** BASE SYSTEM ***
                       Static hostname: iobroker-Final
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 6.2.16-3-pve
                          Architecture: x86-64
                      model name      : Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
                      CPU threads: 4
                      *** Time and Time Zones ***
                                     Local time: Sat 2024-09-14 17:18:05 CEST
                                 Universal time: Sat 2024-09-14 15:18:05 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      longbow
                      HOME=/home/longbow
                      GROUPS=longbow sudo users iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      *** Display-Server-Setup ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:             12G        5.5G        4.3G         90K        3.0G        7.4G
                      Swap:           8.6G        126K        8.6G
                      Total:           21G        5.5G         12G
                      Active iob-Instances:   64
                              12288 M total memory
                               5271 M used memory
                               1878 M active memory
                               5748 M inactive memory
                               4145 M free memory
                                  0 M buffer memory
                               2871 M swap cache
                               8191 M total swap
                                  0 M used swap
                               8191 M free swap
                      top - 17:18:05 up 14 days,  3:39,  3 users,  load average: 1.25, 1.22, 1.12
                      Tasks:  93 total,   2 running,  91 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :  12288.0 total,   4142.8 free,   5273.9 used,   2871.3 buff/cache
                      MiB Swap:   8192.0 total,   8191.9 free,      0.1 used.   7014.1 avail Mem
                      *** FAILED SERVICES ***
                        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                      1 loaded units listed.
                      *** FILESYSTEM ***
                      Filesystem                       Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--240--disk--0 ext4       94G   14G   76G  16% /
                      none                             tmpfs     492K  4.0K  488K   1% /dev
                      udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
                      tmpfs                            tmpfs     3.2G  136K  3.2G   1% /run
                      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                      tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                      dmesg: read kernel buffer failed: Operation not permitted
                      Show mounted filesystems:
                      TARGET                                                  SOURCE                           FSTYPE     OPTIONS
                      /                                                       /dev/mapper/pve-vm--240--disk--0 ext4       rw,relatime,stripe=16
                      |-/run                                                  tmpfs                            tmpfs      rw,nosuid,nodev,size=3251320k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
                      | |-/run/user/1000                                      tmpfs                            tmpfs      rw,nosuid,nodev,relatime,size=1625656k,nr_inodes=406414,mode=700,uid=101000,gid=101000,inode64
                      | |-/run/lock                                           tmpfs                            tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
                      | |-/run/credentials/systemd-tmpfiles-setup-dev.service ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-tmpfiles-setup.service     ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                      | |-/run/credentials/systemd-sysctl.service             ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                      | `-/run/credentials/systemd-sysusers.service           ramfs                            ramfs      ro,nosuid,nodev,noexec,relatime,mode=700
                      |-/dev                                                  none                             tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                      | |-/dev/shm                                            tmpfs                            tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
                      | |-/dev/mqueue                                         mqueue                           mqueue     rw,nosuid,nodev,noexec,relatime
                      | |-/dev/.lxc/proc                                      proc                             proc       rw,relatime
                      | |-/dev/.lxc/sys                                       sys                              sysfs      rw,relatime
                      | |-/dev/full                                           udev[/full]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                      | |-/dev/null                                           udev[/null]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                      | |-/dev/random                                         udev[/random]                    devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                      | |-/dev/tty                                            udev[/tty]                       devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                      | |-/dev/urandom                                        udev[/urandom]                   devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                      | |-/dev/zero                                           udev[/zero]                      devtmpfs   rw,nosuid,relatime,size=8093780k,nr_inodes=2023445,mode=755,inode64
                      | |-/dev/pts                                            devpts                           devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | |-/dev/ptmx                                           devpts[/ptmx]                    devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | |-/dev/console                                        devpts[/0]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | |-/dev/tty1                                           devpts[/1]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      | `-/dev/tty2                                           devpts[/2]                       devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
                      |-/proc                                                 proc                             proc       rw,nosuid,nodev,noexec,relatime
                      | |-/proc/sys                                           proc[/sys]                       proc       ro,relatime
                      | | |-/proc/sys/net                                     proc[/sys/net]                   proc       rw,nosuid,nodev,noexec,relatime
                      | | `-/proc/sys/kernel/random/boot_id                   none[/.lxc-boot-id]              tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
                      | |-/proc/sysrq-trigger                                 proc[/sysrq-trigger]             proc       ro,relatime
                      | |-/proc/cpuinfo                                       lxcfs[/proc/cpuinfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/diskstats                                     lxcfs[/proc/diskstats]           fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/loadavg                                       lxcfs[/proc/loadavg]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/meminfo                                       lxcfs[/proc/meminfo]             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/slabinfo                                      lxcfs[/proc/slabinfo]            fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/stat                                          lxcfs[/proc/stat]                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | |-/proc/swaps                                         lxcfs[/proc/swaps]               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      | `-/proc/uptime                                        lxcfs[/proc/uptime]              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      `-/sys                                                  sysfs                            sysfs      ro,nosuid,nodev,noexec,relatime
                        |-/sys/fs/fuse/connections                            fusectl                          fusectl    rw,nosuid,nodev,noexec,relatime
                        |-/sys/devices/virtual/net                            sysfs[/devices/virtual/net]      sysfs      rw,nosuid,nodev,noexec,relatime
                        |-/sys/fs/cgroup                                      none                             cgroup2    rw,nosuid,nodev,noexec,relatime
                        `-/sys/devices/system/cpu                             lxcfs[/sys/devices/system/cpu]   fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
                      /var:
                      4.3G    /var/
                      3.5G    /var/log/journal/4482dacb35484bddab24b914a301d279
                      3.5G    /var/log
                      712M    /var/cache
                      Archived and active journals take up 19.3M in the file system.
                      /opt/iobroker/backups:
                      518M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      1.9G    /opt/iobroker/iobroker-data/
                      1.3G    /opt/iobroker/iobroker-data/files
                      441M    /opt/iobroker/iobroker-data/files/javascript.admin
                      409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      130M    /opt/iobroker/iobroker-data/states.jsonl
                      55M     /opt/iobroker/iobroker-data/objects.jsonl
                      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v20.17.0
                      /usr/bin/node           v20.17.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.29.3
                      nodejs:
                        Installed: 20.17.0-1nodesource1
                        Candidate: 20.17.0-1nodesource1
                        Version table:
                       *** 20.17.0-1nodesource1 600
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.16.0-1nodesource1 600
                           20.15.1-1nodesource1 600
                           20.15.0-1nodesource1 600
                           20.14.0-1nodesource1 600
                           20.13.1-1nodesource1 600
                           20.13.0-1nodesource1 600
                           20.12.2-1nodesource1 600
                           20.12.1-1nodesource1 600
                           20.12.0-1nodesource1 600
                           20.11.1-1nodesource1 600
                           20.11.0-1nodesource1 600
                           20.10.0-1nodesource1 600
                           20.9.0-1nodesource1 600
                           20.8.1-1nodesource1 600
                           20.8.0-1nodesource1 600
                           20.7.0-1nodesource1 600
                           20.6.1-1nodesource1 600
                           20.6.0-1nodesource1 600
                           20.5.1-1nodesource1 600
                           20.5.0-1nodesource1 600
                           20.4.0-1nodesource1 600
                           20.3.1-1nodesource1 600
                           20.3.0-1nodesource1 600
                           20.2.0-1nodesource1 600
                           20.1.0-1nodesource1 600
                           20.0.0-1nodesource1 600
                           18.19.0+dfsg-6~deb12u2 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                           18.19.0+dfsg-6~deb12u1 500
                              500 http://security.debian.org bookworm-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Core adapters versions
                      admin:          7.0.23
                      javascript:     8.7.6
                      nodejs modules from github:     4
                      Adapter State
                      + system.adapter.accuweather.0            : accuweather           : iobroker-Final                           -  enabled
                      + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alarm.0                  : alarm                 : iobroker-Final                           -  enabled
                        system.adapter.alias-manager.0          : alias-manager         : iobroker-Final                           - disabled
                      + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
                        system.adapter.bidirectional-counter.0  : bidirectional-counter : iobroker-Final                           - disabled
                        system.adapter.chromecast.0             : chromecast            : iobroker-Final                           - disabled
                      + system.adapter.cloud.0                  : cloud                 : iobroker-Final                           -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
                      + system.adapter.device-watcher.0         : device-watcher        : iobroker-Final                           -  enabled
                      + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
                      + system.adapter.doorbird.0               : doorbird              : iobroker-Final                           -  enabled
                        system.adapter.drag-indicator.0         : drag-indicator        : iobroker-Final                           - disabled
                        system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-Final                           -  enabled
                        system.adapter.eventlist.0              : eventlist             : iobroker-Final                           - disabled
                      + system.adapter.fritzdect.0              : fritzdect             : iobroker-Final                           -  enabled
                        system.adapter.fullcalendar.0           : fullcalendar          : iobroker-Final                           - disabled
                      + system.adapter.geofency.0               : geofency              : iobroker-Final                           -  enabled, port: 7999, bind: 0.0.0.0
                      + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
                        system.adapter.hm-rega.1                : hm-rega               : iobroker-Final                           - disabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 18701
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Final                           -  enabled, port: 12001
                        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Final                           - disabled, port: 12001
                      + system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
                      + system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
                        system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           - disabled
                        system.adapter.icons-freepic.0          : icons-freepic         : iobroker-Final                           - disabled
                        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           - disabled
                        system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           - disabled
                        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           - disabled
                        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           - disabled
                        system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker-Final                           - disabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           - disabled
                      + system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
                      + system.adapter.info.0                   : info                  : iobroker-Final                           -  enabled
                      + system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
                      + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                      + system.adapter.klf200.0                 : klf200                : iobroker-Final                           -  enabled
                        system.adapter.lightcontrol.0           : lightcontrol          : iobroker-Final                           - disabled
                        system.adapter.linkeddevices.0          : linkeddevices         : iobroker-Final                           - disabled
                      + system.adapter.modbus.0                 : modbus                : iobroker-Final                           -  enabled
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker-Final                           -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
                      + system.adapter.net-tools.0              : net-tools             : iobroker-Final                           -  enabled
                      + system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
                      + system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
                      + system.adapter.notification-manager.0   : notification-manager  : iobroker-Final                           -  enabled
                      + system.adapter.nuki-extended.0          : nuki-extended         : iobroker-Final                           -  enabled
                      + system.adapter.onvif.0                  : onvif                 : iobroker-Final                           -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899, 888
                        system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
                      + system.adapter.operating-hours.0        : operating-hours       : iobroker-Final                           -  enabled
                        system.adapter.ping.0                   : ping                  : iobroker-Final                           - disabled
                        system.adapter.places.0                 : places                : iobroker-Final                           - disabled
                      + system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
                      + system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
                      + system.adapter.pushover.0               : pushover              : iobroker-Final                           -  enabled
                      + system.adapter.reolink.0                : reolink               : iobroker-Final                           -  enabled
                      + system.adapter.reolink.1                : reolink               : iobroker-Final                           -  enabled
                      + system.adapter.reolink.2                : reolink               : iobroker-Final                           -  enabled
                        system.adapter.robonect.0               : robonect              : iobroker-Final                           - disabled
                      + system.adapter.roborock.0               : roborock              : iobroker-Final                           -  enabled
                        system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker-Final                           - disabled, port: 8002
                      + system.adapter.scenes.0                 : scenes                : iobroker-Final                           -  enabled
                      + system.adapter.shelly.0                 : shelly                : iobroker-Final                           -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.simple-api.0             : simple-api            : iobroker-Final                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
                        system.adapter.smartthings.0            : smartthings           : iobroker-Final                           - disabled
                        system.adapter.solaredge.0              : solaredge             : iobroker-Final                           -  enabled
                        system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
                      + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-Final                           -  enabled
                      + system.adapter.sql.0                    : sql                   : iobroker-Final                           -  enabled
                      + system.adapter.statistics.0             : statistics            : iobroker-Final                           -  enabled
                      + system.adapter.systeminfo.0             : systeminfo            : iobroker-Final                           -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
                      + system.adapter.tr-064.0                 : tr-064                : iobroker-Final                           -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
                      + system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
                      + system.adapter.tuya.1                   : tuya                  : iobroker-Final                           -  enabled
                      + system.adapter.tuya.2                   : tuya                  : iobroker-Final                           -  enabled
                      + system.adapter.unifi.0                  : unifi                 : iobroker-Final                           -  enabled
                      + system.adapter.upnp.0                   : upnp                  : iobroker-Final                           -  enabled
                        system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-Final                           - disabled
                        system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           - disabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Final                           - disabled
                        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Final                           -  enabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
                        system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           - disabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Final                           - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Final                           - disabled
                        system.adapter.vis-map.0                : vis-map               : iobroker-Final                           - disabled
                        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           - disabled
                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-Final                           -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : iobroker-Final                           - disabled
                        system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Final                           -  enabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           - disabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker-Final                           - disabled
                        system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
                      + system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
                      + system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           -  enabled
                      + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-Final                           -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           -  enabled
                      + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.welcome.0                : welcome               : iobroker-Final                           -  enabled, port: 80, bind: 0.0.0.0, run as: admin
                      + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
                      + system.adapter.wolf.0                   : wolf                  : iobroker-Final                           -  enabled, port: 12004, bind: 0.0.0.0
                        system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Upgrade policy: none
                      Installed ioBroker-Instances
                      Used repository: stable
                      Adapter    "accuweather"  : 1.5.0    , installed 1.5.0
                      Adapter    "admin"        : 7.0.23   , installed 7.0.23
                      Adapter    "alarm"        : 3.6.1    , installed 3.6.1
                      Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                      Adapter    "backitup"     : 3.0.22   , installed 3.0.22
                      Adapter    "bidirectional-counter": 2.2.0, installed 2.2.0
                      Adapter    "chromecast"   : 3.4.1    , installed 3.4.1
                      Adapter    "daswetter"    : 3.1.16   , installed 3.1.16
                      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                      Adapter    "discovery"    : 4.5.0    , installed 4.5.0
                      Adapter    "doorbird"     : 1.7.0    , installed 1.7.0
                      Adapter    "drag-indicator": 2.2.0   , installed 2.2.0
                      Adapter    "energiefluss-erweitert": 0.4.1, installed 0.4.1
                      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
                      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                      Adapter    "fullcalendar" : 2.4.2    , installed 2.4.2
                      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                      Adapter    "hm-rega"      : 5.0.0    , installed 5.0.0
                      Adapter    "hm-rpc"       : 1.17.0   , installed 1.17.0
                      Adapter    "homeconnect"  : 1.4.1    , installed 1.4.1
                      Adapter    "hue"          : 3.12.0   , installed 3.12.0
                      Adapter    "ical"         : 1.15.0   , installed 1.15.0
                      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
                      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
                      Adapter    "iot"          : 3.3.0    , installed 3.3.0
                      Adapter    "javascript"   : 8.7.6    , installed 8.7.6
                      Controller "js-controller": 6.0.11   , installed 6.0.11
                      Adapter    "klf200"       : 1.2.0    , installed 1.2.0
                      Adapter    "lightcontrol" : 0.8.0    , installed 0.8.0
                      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
                      Adapter    "modbus"       : 6.2.3    , installed 6.2.3
                      Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
                      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                      Adapter    "nina"         : 0.0.25   , installed 0.0.25
                      Adapter    "notification-manager": 1.1.2, installed 1.1.2
                      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                      Adapter    "operating-hours": 1.1.0  , installed 1.1.0
                      Adapter    "places"       : 1.2.0    , installed 1.2.0
                      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                      Adapter    "proxmox"      : 2.3.0    , installed 2.3.0
                      Adapter    "pushover"     : 4.1.0    , installed 3.0.6  [Updatable]
                      Adapter    "reolink"      : 1.1.1    , installed 1.1.1
                      Adapter    "robonect"     : 1.3.6    , installed 1.3.6
                      Adapter    "roborock"     : 0.6.4    , installed 0.6.11
                      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                      Adapter    "scenes"       : 3.2.1    , installed 3.2.1
                      Adapter    "shelly"       : 7.0.0    , installed 7.0.0
                      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                      Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
                      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                      Adapter    "sql"          : 3.0.1    , installed 3.0.1
                      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
                      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                      Adapter    "vis-icontwo"  : 1.5.0    , installed 1.5.0
                      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                      Adapter    "vis-material" : 0.1.3    , installed 0.1.3
                      Adapter    "vis-weather"  : 2.5.9    , installed 2.5.9
                      Adapter    "weather-warnings": 0.6.7 , installed 0.6.7
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "web"          : 6.2.5    , installed 6.2.5
                      Adapter    "welcome"      : 0.3.0    , installed 0.3.0
                      Adapter    "wolf"         : 1.7.0    , installed 1.7.0
                      Adapter    "wolf-smartset": 1.2.3    , installed 1.2.3
                      Adapter    "yr"           : 5.3.0    , installed 5.3.0
                      Objects and States
                      Objects:        58506
                      States:         46276
                      Hit:1 http://security.debian.org bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 192.168.178.240:18701   0.0.0.0:*               LISTEN      1001       512516892  381431/io.hm-rpc.0
                      tcp        0      0 192.168.178.240:12001   0.0.0.0:*               LISTEN      1001       512517743  381442/io.hm-rpc.1
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          419981791  294/master
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       512511819  381099/iobroker.js-
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       512511824  381099/iobroker.js-
                      tcp        0      0 0.0.0.0:8100            0.0.0.0:*               LISTEN      1001       512527792  382060/io.doorbird.
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       512521923  381635/io.shelly.0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          419979059  1/systemd
                      tcp        0      0 0.0.0.0:12004           0.0.0.0:*               LISTEN      1001       512526179  381961/io.wolf.0
                      tcp6       0      0 :::7906                 :::*                    LISTEN      1001       512521448  381244/io.roborock.
                      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       512547557  382879/io.upnp.0
                      tcp6       0      0 :::7999                 :::*                    LISTEN      1001       512516041  381395/io.geofency.
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       513254766  387362/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       512512795  381117/io.admin.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       512539420  382911/io.simple-ap
                      tcp6       0      0 :::8095                 :::*                    LISTEN      1001       512534319  382574/io.onvif.0
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          419981792  294/master
                      tcp6       0      0 :::6824                 :::*                    LISTEN      1001       512521447  381244/io.roborock.
                      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       512520456  381571/go2rtc_linux
                      tcp6       0      0 :::80                   :::*                    LISTEN      1001       512537054  382784/io.welcome.0
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          419979061  1/systemd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          419980077  1/systemd
                      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       512518925  381571/go2rtc_linux
                      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       512518926  381571/go2rtc_linux
                      tcp6       0      0 :::51989                :::*                    LISTEN      1001       512525054  382028/io.nuki-exte
                      udp        0      0 192.168.178.240:5353    0.0.0.0:*                           1001       512521215  381756/io.tr-064.0
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       512522784  381868/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       512522785  381868/io.tuya.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          419979060  1/systemd
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       512542779  382879/io.upnp.0
                      udp        0      0 0.0.0.0:35611           0.0.0.0:*                           1001       512537584  382879/io.upnp.0
                      udp6       0      0 :::111                  :::*                                0          419979062  1/systemd
                      udp6       0      0 :::8555                 :::*                                1001       512560717  383682/go2rtc
                      2024-09-14 17:15:26.014  - info: host.iobroker-Final instance system.adapter.daswetter.0 in version "3.1.16" started with pid 428529
                      2024-09-14 17:15:26.657  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
                      2024-09-14 17:15:26.677  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
                      2024-09-14 17:15:26.688  - info: web.0 (387362) ==> Connected system.user.admin from ::ffff:192.168.178.38
                      2024-09-14 17:15:26.884  - info: web.0 (387362) <== Disconnect system.user.admin from ::ffff:192.168.178.38
                      Copy text starting here:
                                              v.2024-05-22
                        Virtualization: lxc
                      Installation:           lxc
                      Kernel:                 x86_64
                      Userland:               64 bit
                      User-ID:                1000
                      Pending OS-Updates:     0
                      Pending iob updates:    1
                      Nodejs-Installation:
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      Recommended versions are nodejs 20.17.0 and npm 10.8.2
                      MEMORY:
                      Mem:             12G        5.5G        4.4G         90K        3.0G        7.4G
                      Total:           21G        5.5G         12G
                      ioBroker Core:          js-controller           6.0.11
                                              admin                   7.0.23
                      Objects type: jsonl
                      States  type: jsonl
                      Objects:                58506
                      States:                 46276
                      Size of iob-Database:
                      59M     /opt/iobroker/iobroker-data/objects.jsonl
                      132M    /opt/iobroker/iobroker-data/states.jsonl
                      === Mark text until here for copying ===
                      longbow@iobroker-Final:~$
                      • LongbowL Offline
                        LongbowL Offline
                        Longbow
                        #1060
                        Kann mir keiner einen Tipp geben oder behilflich sein ?
                        • LongbowL Longbow
                          G Online
                          G Online
                          guitardoc
                          #1061
                          @longbow Der Security Client muss raus, den hast du dir bei irgendeinem Installationsversuch eingefangen:
                          npm uninstall eufy-security-client
                          • LongbowL Offline
                            LongbowL Offline
                            Longbow
                            #1062
                            @guitardoc Danke, hat geklappt... der Adapter könnte installiert werden, nur leider werden meinen Cam, die Bilder angezeigt... spricht wie binde ich nun diese ein?
                            G G 2 Antworten Letzte Antwort
                            • LongbowL Longbow
                              G Online
                              G Online
                              guitardoc
                              #1063
                              @longbow Da kann ich dir leider nicht helfen, ich nutze den Adapter nur, um den Modus in Abhängigkeit von Anwesenheit und Tageszeit zu steuern.
                              • LongbowL Longbow
                                GMJ
                                schrieb am zuletzt editiert von GMJ
                                #1064
                                @longbow
                                So gehts -> http://IP_BROKER:PORT_BROKER_VIS/eusec.0/T8030P0815/last_event/T8213P0815.jpg
                                In Vis in ein "Basic Image" in die URL
                                astuermerA 1 Antwort Letzte Antwort
                                • LongbowL Offline
                                  LongbowL Offline
                                  Longbow
                                  #1065
                                  @gmj Danke, das geht sehr gut.
                                  Wie kann man das Live einfügen? Also aufrufen, bekommen?
                                  • LongbowL Longbow
                                    GMJ
                                    #1066
                                    @longbow
                                    Kein Live Bild so einfach "da"
                                    Nutze ich nicht.... denn man muss so wie ich das verstanden haben das Livebild starten (per datenpunkt triggern) dann gibt es einen Stream den man dann irgend wie einbinden könnte .... und danach den Stream wieder beenden. Sonst refresh Bild im widget in x ms einstellbar dann gibt es auktuelles wenn da.
                                    • G GMJ
                                      @longbow
                                      astuermerA Offline
                                      astuermerA Offline
                                      astuermer
                                      schrieb am zuletzt editiert von astuermer
                                      #1067
                                      @gmj sagte in [Neuer Adapter] EuSec:
                                      @longbow
                                      Da kommt bei mir leider nur das:
                                      404
                                      Oops! The page you're looking for can't be found. 😔
                                      File /eusec.0/hier Pfad mit Dateiname.jpg not found
                                      Update: Hat sich erledigt mit einem neuen Update. Was nachwievor nicht läuft, dass der Akkustand sich automatisch aktualisiert. Ich muss dazu jedesmal den Adapter neu starten.
                                      • astuermerA Offline
                                        astuermerA Offline
                                        astuermer
                                        #1068
                                        Was von Vorteil wäre: Timestamp pro Kamera.
                                        Klar man kann es in der eufy App ins Bild integrieren, aber bei Tageslicht ist das nicht lesbar. Das wäre als Value pro Kamera toll 👍🏻
                                        • G Online
                                          G Online
                                          guitardoc
                                          schrieb am zuletzt editiert von guitardoc
                                          #1069
                                          @astuermer Bei mir liefert der eusec Adapter leider keine geänderten Werte in den Datenpunkten für motion_detected und person_detected. Die Datenpunkte stehen permanent auf false. Ich habe die Werte mal in SQL protokolliert - keine Änderung. Motion_detection steht aber auf true, Bewegungen werden in der app auch erkannt.
                                          Hat jemand das gleiche Problem?
                                          FabioF 1 Antwort Letzte Antwort
