  4. nach nodeJs update auf 20.16.0 keine Skrpt seite mehr
    1.0k
    6.1k
54 Beiträge 5 Kommentatoren 7.1k Aufrufe 3 Beobachtet
  • S stoffel67
    iob upload all. hat geholfen, Seite wird wieder angezeigt, aber jetzt - wie gesagt es hagelt Fehler:
    host.raspberrypi
    2024-08-02 18:53:34.382	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-08-02 18:53:34.382	error	Caught by controller[0]: Node.js v20.16.0
    host.raspberrypi
    2024-08-02 18:53:34.381	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:53:34.381	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-08-02 18:53:34.380	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspberrypi
    2024-08-02 18:53:34.380	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/index.js:12:18)
    host.raspberrypi
    2024-08-02 18:53:34.379	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspberrypi
    2024-08-02 18:53:34.379	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspberrypi
    2024-08-02 18:53:34.378	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspberrypi
    2024-08-02 18:53:34.377	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:53:34.377	error	Caught by controller[0]: at Module._extensions..json (node:internal/modules/cjs/loader:1434:39)
    host.raspberrypi
    2024-08-02 18:53:34.376	error	Caught by controller[0]: at parse (<anonymous>)
    host.raspberrypi
    2024-08-02 18:53:34.375	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/db.json: Expected property name or '}' in JSON at position 111104
    host.raspberrypi
    2024-08-02 18:53:34.375	error	Caught by controller[0]: ^
    host.raspberrypi
    2024-08-02 18:53:34.374	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2024-08-02 18:53:34.373	error	Caught by controller[0]: node:internal/modules/cjs/loader:1437
    host.raspberrypi
    2024-08-02 18:53:01.965	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-08-02 18:53:01.964	error	Caught by controller[0]: Node.js v20.16.0
    host.raspberrypi
    2024-08-02 18:53:01.964	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:53:01.963	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-08-02 18:53:01.962	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspberrypi
    2024-08-02 18:53:01.962	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/index.js:12:18)
    host.raspberrypi
    2024-08-02 18:53:01.961	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspberrypi
    2024-08-02 18:53:01.961	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspberrypi
    2024-08-02 18:53:01.960	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspberrypi
    2024-08-02 18:53:01.960	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:53:01.959	error	Caught by controller[0]: at Module._extensions..json (node:internal/modules/cjs/loader:1434:39)
    host.raspberrypi
    2024-08-02 18:53:01.958	error	Caught by controller[0]: at parse (<anonymous>)
    host.raspberrypi
    2024-08-02 18:53:01.957	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/db.json: Expected property name or '}' in JSON at position 111104
    host.raspberrypi
    2024-08-02 18:53:01.957	error	Caught by controller[0]: ^
    host.raspberrypi
    2024-08-02 18:53:01.956	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2024-08-02 18:53:01.954	error	Caught by controller[0]: node:internal/modules/cjs/loader:1437
    host.raspberrypi
    2024-08-02 18:52:29.474	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-08-02 18:52:29.473	error	Caught by controller[0]: Node.js v20.16.0
    host.raspberrypi
    2024-08-02 18:52:29.472	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:52:29.472	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-08-02 18:52:29.471	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspberrypi
    2024-08-02 18:52:29.471	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/index.js:12:18)
    host.raspberrypi
    2024-08-02 18:52:29.470	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspberrypi
    2024-08-02 18:52:29.469	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspberrypi
    2024-08-02 18:52:29.469	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspberrypi
    2024-08-02 18:52:29.468	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:52:29.467	error	Caught by controller[0]: at Module._extensions..json (node:internal/modules/cjs/loader:1434:39)
    host.raspberrypi
    2024-08-02 18:52:29.466	error	Caught by controller[0]: at parse (<anonymous>)
    host.raspberrypi
    2024-08-02 18:52:29.466	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/db.json: Expected property name or '}' in JSON at position 111104
    host.raspberrypi
    2024-08-02 18:52:29.465	error	Caught by controller[0]: ^
    host.raspberrypi
    2024-08-02 18:52:29.464	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2024-08-02 18:52:29.462	error	Caught by controller[0]: node:internal/modules/cjs/loader:1437
    host.raspberrypi
    2024-08-02 18:51:57.028	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-08-02 18:51:57.027	error	Caught by controller[0]: Node.js v20.16.0
    host.raspberrypi
    2024-08-02 18:51:57.027	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:51:57.025	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-08-02 18:51:57.024	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspberrypi
    2024-08-02 18:51:57.023	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/index.js:12:18)
    host.raspberrypi
    2024-08-02 18:51:57.022	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspberrypi
    2024-08-02 18:51:57.021	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspberrypi
    2024-08-02 18:51:57.020	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspberrypi
    2024-08-02 18:51:57.020	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:51:57.019	error	Caught by controller[0]: at Module._extensions..json (node:internal/modules/cjs/loader:1434:39)
    host.raspberrypi
    2024-08-02 18:51:57.018	error	Caught by controller[0]: at parse (<anonymous>)
    host.raspberrypi
    2024-08-02 18:51:57.017	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/db.json: Expected property name or '}' in JSON at position 111104
    host.raspberrypi
    2024-08-02 18:51:57.017	error	Caught by controller[0]: ^
    host.raspberrypi
    2024-08-02 18:51:57.016	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2024-08-02 18:51:57.014	error	Caught by controller[0]: node:internal/modules/cjs/loader:1437
    host.raspberrypi
    2024-08-02 18:51:24.618	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-08-02 18:51:24.617	error	Caught by controller[0]: Node.js v20.16.0
    host.raspberrypi
    2024-08-02 18:51:24.616	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:51:24.616	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
    host.raspberrypi
    2024-08-02 18:51:24.615	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1358:14)
    host.raspberrypi
    2024-08-02 18:51:24.614	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/index.js:12:18)
    host.raspberrypi
    2024-08-02 18:51:24.614	error	Caught by controller[0]: at require (node:internal/modules/helpers:179:18)
    host.raspberrypi
    2024-08-02 18:51:24.613	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1233:19)
    host.raspberrypi
    2024-08-02 18:51:24.612	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1024:12)
    host.raspberrypi
    2024-08-02 18:51:24.612	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1208:32)
    host.raspberrypi
    2024-08-02 18:51:24.611	error	Caught by controller[0]: at Module._extensions..json (node:internal/modules/cjs/loader:1434:39)
    host.raspberrypi
    2024-08-02 18:51:24.610	error	Caught by controller[0]: at parse (<anonymous>)
    host.raspberrypi
    2024-08-02 18:51:24.610	error	Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/db.json: Expected property name or '}' in JSON at position 111104
    host.raspberrypi
    2024-08-02 18:51:24.609	error	Caught by controller[0]: ^
    host.raspberrypi
    2024-08-02 18:51:24.608	error	Caught by controller[0]: throw err;
    host.raspberrypi
    2024-08-02 18:51:24.606	error	Caught by controller[0]: node:internal/modules/cjs/loader:1437
    host.raspberrypi
    2024-08-02 18:50:52.155	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi
    2024-08-02 18:50:52.154	error	Caught by controller[1]: Node.js v20.16.0
    @stoffel67
    Schau dir die Langfassung von
    iob diag
    an.
      @stoffel67
      iob diag
      an.
      stoffel67
      im iob diag kommt folgendes:
      kannst du damiot was anfangen?
      2024-08-02 18:57:55.252  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
      2024-08-02 18:57:55.253  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      2024-08-02 18:57:55.253  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
      2024-08-02 18:57:55.254  - error: host.raspberrypi Caught by controller[0]: Node.js v20.16.0
      2024-08-02 18:57:55.254  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-08-02 18:57:55.255  - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      2024-08-02 18:58:25.676  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 9442
      2024-08-02 18:58:27.858  - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1437
      2024-08-02 18:58:27.859  - error: host.raspberrypi Caught by controller[0]:     throw err;
      2024-08-02 18:58:27.860  - error: host.raspberrypi Caught by controller[0]:     ^
      2024-08-02 18:58:27.861  - error: host.raspberrypi Caught by controller[0]: SyntaxError: /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/db.json: Expected property name or '}' in JSON at position 111104
      2024-08-02 18:58:27.862  - error: host.raspberrypi Caught by controller[0]:     at parse (<anonymous>)
      2024-08-02 18:58:27.863  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..json (node:internal/modules/cjs/loader:1434:39)
      2024-08-02 18:58:27.863  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
      2024-08-02 18:58:27.864  - error: host.raspberrypi Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1024:12)
      2024-08-02 18:58:27.866  - error: host.raspberrypi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1233:19)
      2024-08-02 18:58:27.867  - error: host.raspberrypi Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
      2024-08-02 18:58:27.868  - error: host.raspberrypi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db/index.js:12:18)
      2024-08-02 18:58:27.869  - error: host.raspberrypi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1358:14)
      2024-08-02 18:58:27.869  - error: host.raspberrypi Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1416:10)
      2024-08-02 18:58:27.870  - error: host.raspberrypi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1208:32)
      2024-08-02 18:58:27.871  - error: host.raspberrypi Caught by controller[0]: Node.js v20.16.0
      2024-08-02 18:58:27.872  - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-08-02 18:58:27.873  - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
      2024-08-02 18:58:59.452  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 9752
      Mein Adapter: JUNG/GIRA eNet-Adapter
      • S stoffel67
        @stoffel67 sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
        nee, das ist nur der letzte Teil des iob logs
          stoffel67
          das ist aber viel!
          Skript v.2024-05-22
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v7+
                Architecture: arm
          Model           : Raspberry Pi 2 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : 32 bit
          Systemuptime and Load:
           18:56:45 up  1:26,  3 users,  load average: 0.93, 1.63, 2.29
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Fri 2024-08-02 18:56:46 CEST
                     Universal time: Fri 2024-08-02 16:56:46 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** Display-Server-Setup ***
          Display-Server: true
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            921M        379M        219M        7.0M        322M        475M
          Swap:            99M         99M        0.0K
          Total:          1.0G        479M        219M
          Active iob-Instances:   7
                    921 M total memory
                    379 M used memory
                    229 M active memory
                    382 M inactive memory
                    219 M free memory
                     48 M buffer memory
                    274 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          top - 18:56:46 up  1:26,  3 users,  load average: 0.93, 1.63, 2.29
          Tasks: 172 total,   1 running, 171 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  7.2 sy,  0.0 ni, 92.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :    922.0 total,    219.9 free,    378.7 used,    323.4 buff/cache
          MiB Swap:    100.0 total,      0.0 free,    100.0 used.    476.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          /dev/root      ext4       30G   11G   18G  37% /
          devtmpfs       devtmpfs  333M     0  333M   0% /dev
          tmpfs          tmpfs     461M     0  461M   0% /dev/shm
          tmpfs          tmpfs     185M  1.1M  184M   1% /run
          /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
          tmpfs          tmpfs      93M   20K   93M   1% /run/user/1000
          [Fri Aug  2 17:30:43 2024] Kernel command line: coherent_pool=1M snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1280x1024M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=53c09ba6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Fri Aug  2 17:30:46 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Fri Aug  2 17:30:46 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Fri Aug  2 17:30:49 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET                       SOURCE         FSTYPE          OPTIONS
          /                            /dev/mmcblk0p2 ext4            rw,noatime,commit=600
          |-/dev                       devtmpfs       devtmpfs        rw,relatime,size=340464k,nr_inodes=85116,mode=755
          | |-/dev/shm                 tmpfs          tmpfs           rw,nosuid,nodev
          | |-/dev/pts                 devpts         devpts          rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000
          | `-/dev/mqueue              mqueue         mqueue          rw,nosuid,nodev,noexec,relatime
          |-/proc                      proc           proc            rw,relatime
          | `-/proc/sys/fs/binfmt_misc systemd-1      autofs          rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct
          |-/sys                       sysfs          sysfs           rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/security     securityfs     securityfs      rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/cgroup           cgroup2        cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot
          | |-/sys/fs/pstore           pstore         pstore          rw,nosuid,nodev,noexec,relatime
          | |-/sys/fs/bpf              bpf            bpf             rw,nosuid,nodev,noexec,relatime,mode=700
          | |-/sys/kernel/tracing      tracefs        tracefs         rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/debug        debugfs        debugfs         rw,nosuid,nodev,noexec,relatime
          | |-/sys/kernel/config       configfs       configfs        rw,nosuid,nodev,noexec,relatime
          | `-/sys/fs/fuse/connections fusectl        fusectl         rw,nosuid,nodev,noexec,relatime
          |-/run                       tmpfs          tmpfs           rw,nosuid,nodev,size=188820k,nr_inodes=819200,mode=755
          | |-/run/lock                tmpfs          tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k
          | |-/run/rpc_pipefs          sunrpc         rpc_pipefs      rw,relatime
          | `-/run/user/1000           tmpfs          tmpfs           rw,nosuid,nodev,relatime,size=94408k,nr_inodes=23602,mode=700,uid=1000,gid=1000
          |   `-/run/user/1000/gvfs    gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot                      /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.0G    /var/
          2.3G    /var/log
          2.2G    /var/log/journal/4261c72918d647a8ac632ffea859fbd4
          469M    /var/cache
          Archived and active journals take up 2.1G in the file system.
          /opt/iobroker/backups:
          66M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          731M    /opt/iobroker/iobroker-data/
          637M    /opt/iobroker/iobroker-data/files
          441M    /opt/iobroker/iobroker-data/files/javascript.admin
          409M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          408M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
          12M     /opt/iobroker/iobroker-data/objects.jsonl
          8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
          8.8M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.16.0
          /usr/bin/node           v20.16.0
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          /usr/bin/corepack       0.28.2
          nodejs:
            Installed: 20.16.0-1nodesource1
            Candidate: 20.16.0-1nodesource1
            Version table:
           *** 20.16.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
          Temp directories causing npm8 problem: 1
          Some problems detected, please run iob fix
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.12
          admin:          7.0.22
          javascript:     8.7.6
          nodejs modules from github:     1
          +-- iobroker.enet@1.0.1 (git+ssh://git@github.com/SebastianSchultz/ioBroker.enet.git#9f24d2f36cb4ce2c9c99546fa9ab3c31ebcf358f)
          Adapter State
            system.adapter.ble.0                    : ble                   : raspberrypi                              - disabled
            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
            system.adapter.ds18b20.0                : ds18b20               : raspberrypi                              - disabled
            system.adapter.enet.0                   : enet                  : raspberrypi                              - disabled
            system.adapter.enet.1                   : enet                  : raspberrypi                              - disabled
            system.adapter.info.0                   : info                  : raspberrypi                              - disabled
            system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
            system.adapter.modbus.0                 : modbus                : raspberrypi                              - disabled
            system.adapter.node-red.0               : node-red              : raspberrypi                              - disabled, port: 1880, bind: 0.0.0.0
            system.adapter.proxy.0                  : proxy                 : raspberrypi                              - disabled
          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
            system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              - disabled
            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
            system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              - disabled
            system.adapter.withings.0               : withings              : raspberrypi                              - disabled
          + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.0.22   , installed 7.0.22
          Adapter    "backitup"     : 2.11.0   , installed 2.11.0
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "discovery"    : 4.5.0    , installed 4.5.0
          Adapter    "ds18b20"      : 2.0.5    , installed 2.0.5
          Adapter    "enet"         : 1.0.1    , installed 1.0.1
          Adapter    "javascript"   : 8.7.6    , installed 8.7.6
          Controller "js-controller": 6.0.9    , installed 5.0.12 [Updatable]
          Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
          Adapter    "modbus"       : 6.2.3    , installed 6.1.0  [Updatable]
          Adapter    "node-red"     : 5.2.1    , installed 5.2.1
          Adapter    "proxy"        : 1.3.2    , installed 1.3.2
          Adapter    "radar2"       : 2.2.0    , installed 2.1.0  [Updatable]
          Adapter    "shelly"       : 7.0.0    , installed 7.0.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "socketio"     : 6.7.0    , installed 6.7.0
          Adapter    "sonoff"       : 3.1.0    , installed 3.0.3  [Updatable]
          Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Adapter    "withings"     : 0.0.13   , installed 0.0.13
          Adapter    "ws"           : 2.6.1    , installed 2.6.1
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Objects and States
          Objects:        11542
          States:         7722
          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13733      431/cupsd
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          1742       458/vncserver-x11-c
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13724      484/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       58839      8457/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       59887      8457/iobroker.js-co
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       59966      8481/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       59089      8542/io.web.0
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          1741       458/vncserver-x11-c
          tcp6       0      0 :::38147                :::*                    LISTEN      1001       60033      8541/io.yahka.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13732      431/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          13726      484/sshd: /usr/sbin
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13746      489/cups-browsed
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1531       312/avahi-daemon: r
          udp        0      0 0.0.0.0:35225           0.0.0.0:*                           108        1533       312/avahi-daemon: r
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13677      440/dhcpcd
          udp6       0      0 :::5353                 :::*                                108        1532       312/avahi-daemon: r
          udp6       0      0 :::32773                :::*                                108        1534       312/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          13756      440/dhcpcd
          iob diag has finished.
          Press any key for a summary
          Copy text starting here:
                                  v.2024-05-22
                   Icon name: computer
                Architecture: arm
          Kernel:                 armv7l
          Userland:               32 bit
          User-ID:                1000
          Pending OS-Updates:     0
          Pending iob updates:    5
          Nodejs-Installation:
          /usr/bin/npm            10.8.1
          /usr/bin/npx            10.8.1
          Recommended versions are nodejs 20.16.0 and npm 10.8.1
          MEMORY:
          Mem:            921M        393M         99M        7.0M        428M        456M
          Swap:            99M         99M        0.0K
          Total:          1.0G        493M         99M
                  ^[[1;2AActive repo(s): stable
          ioBroker Core:          js-controller           5.0.12
                                  admin                   7.0.22
          Objects type: jsonl
          States  type: jsonl
          Objects:                11542
          States:                 7722
          Size of iob-Database:
          2.4M    /opt/iobroker/iobroker-data/states.jsonl
          Some problems detected, please run iob fix and try to have them fixed
          HomoranH T Thomas BraunT 3 Antworten Letzte Antwort
          • S stoffel67
            das ist aber viel!
            Skript v.2024-05-22
            *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm
            Docker          : false
            Kernel          : armv7l
            Userland        : 32 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M         99M        0.0K
                      921 M total memory
                      379 M used memory
                      229 M active memory
                      219 M free memory
                       48 M buffer memory
                      274 M swap cache
                       99 M total swap
                       99 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            /var:
            3.0G    /var/
            2.3G    /var/log
            469M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          7.0.22
            javascript:     8.7.6
            Adapter State
            + instance is alive
            Objects and States
            Objects:        11542
            States:         7722
            Pending Updates: 0
                                    v.2024-05-22
                     Icon name: computer
                  Architecture: arm
            Kernel:                 armv7l
            Userland:               32 bit
            User-ID:                1000
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            MEMORY:
            Swap:            99M         99M        0.0K
                                    admin                   7.0.22
            Objects type: jsonl
            States  type: jsonl
            Objects:                11542
            States:                 7722
            ernsthaft?
            mit nur 1GB RAM?
            und vollkommen verbrauchtem SWAP
            Swap: 99M 99M 0.0K
            wird zwar nicht mehr viel reißen können, aber musst du mal machen!
            • S stoffel67
              das ist aber viel!
              Skript v.2024-05-22
              *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm
              Docker          : false
              Kernel          : armv7l
              Userland        : 32 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M         99M        0.0K
                        921 M total memory
                        379 M used memory
                        229 M active memory
                        219 M free memory
                         48 M buffer memory
                        274 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              3.0G    /var/
              2.3G    /var/log
              469M    /var/cache
              USB-Devices by-id:
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              nodejs:
                Version table:
              Errors in npm tree:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          7.0.22
              javascript:     8.7.6
              Adapter State
              + instance is alive
              Objects and States
              Objects:        11542
              States:         7722
              Pending Updates: 0
                                      v.2024-05-22
                       Icon name: computer
                    Architecture: arm
              Kernel:                 armv7l
              Userland:               32 bit
              User-ID:                1000
              /usr/bin/npm            10.8.1
              /usr/bin/npx            10.8.1
              MEMORY:
              Swap:            99M         99M        0.0K
                                      admin                   7.0.22
              Objects type: jsonl
              States  type: jsonl
              Objects:                11542
              States:                 7722
              TT-Tom
              @stoffel67
              Den JS-Controller sollte auch auf Version 6.0.9 angepasst werden.
              Gruß Tom
              Public Transport
              NSPanel Adapter Wiki
              • S stoffel67
                das ist aber viel!
                Skript v.2024-05-22
                *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm
                Docker          : false
                Kernel          : armv7l
                Userland        : 32 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:            99M         99M        0.0K
                          921 M total memory
                          379 M used memory
                          229 M active memory
                          219 M free memory
                           48 M buffer memory
                          274 M swap cache
                           99 M total swap
                           99 M used swap
                            0 M free swap
                *** FILESYSTEM ***
                /var:
                3.0G    /var/
                2.3G    /var/log
                469M    /var/cache
                USB-Devices by-id:
                /usr/bin/npm            10.8.1
                /usr/bin/npx            10.8.1
                nodejs:
                  Version table:
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          7.0.22
                javascript:     8.7.6
                Adapter State
                + instance is alive
                Objects and States
                Objects:        11542
                States:         7722
                Pending Updates: 0
                                        v.2024-05-22
                         Icon name: computer
                      Architecture: arm
                Kernel:                 armv7l
                Userland:               32 bit
                User-ID:                1000
                /usr/bin/npm            10.8.1
                /usr/bin/npx            10.8.1
                MEMORY:
                Swap:            99M         99M        0.0K
                                        admin                   7.0.22
                Objects type: jsonl
                States  type: jsonl
                Objects:                11542
                States:                 7722
                Boot Target: graphical.target
                Schalt den Desktop aus... (Inkl. VNC-Server und Drucker-Server und so einem Quark...)
                sudo systemctl set-default multi-user.target
                iob stop
                iob fix
                Schmeiß das Modul mime-db mal aus dem javascript-Adapter raus. Wozu wird das benötigt?
                Dann die
                auf 0 bringen.
                • T TT-Tom
                  @stoffel67
                  stoffel67
                  @tt-tom
                  js-controller auf 6.0.9 … was muss ich da eingeben, ist dan npm install…
                    iob stop
                    iob fix
                    Dann die
                    auf 0 bringen.
                    stoffel67
                    mime-db ist doch da garnicht drin…
                    • S stoffel67
                      @stoffel67
                      Ich würde sagen, das Ding spukt da herum.
                      cd /opt/iobroker
                      npm ls mime-db
                      sagt?
                        @stoffel67
                        cd /opt/iobroker
                        npm ls mime-db
                        sagt?
                        stoffel67
                        pi@ /home/pi
                        └── (empty)
                        • S stoffel67
                          pi@ /home/pi
                          └── (empty)
                          @stoffel67
                          Du sollst ja auch zuvor in das richtige Verzeichnis wechseln...
                          Deswegen gebe ich das sogar an.
                            @stoffel67
                            stoffel67
                            schrieb am zuletzt editiert von stoffel67
                            sorry, hab ich übersehen…
                            pi@raspberrypi:~ $ cd /opt/iobroker/
                            pi@raspberrypi:/opt/iobroker $ npm ls mime-db
                            iobroker.inst@3.0.0 /opt/iobroker
                            ├─┬ iobroker.admin@7.0.22
                            │ └─┬ compression@1.7.4
                            │   └─┬ compressible@2.0.18
                            │     └── mime-db@1.52.0 deduped
                            ├─┬ iobroker.javascript@8.7.6
                            │ └─┬ axios@1.7.2
                            │   └─┬ form-data@4.0.0
                            │     └─┬ mime-types@2.1.35
                            │       └── mime-db@ invalid: "1.52.0" from node_modules/iobroker.javascript/node_modules/mime-types
                            └─┬ iobroker.web@6.2.5
                                └── mime-db@1.52.0
                            npm error code ELSPROBLEMS
                            npm error invalid: mime-db@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime-db
                            npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_22_41_904Z-debug-0.log
                            die mime-types werden soweitz ich weiß für ein SH1106 Display gebraucht
                            • S stoffel67
                              Was ist denn drin?
                              HomoranH S 2 Antworten Letzte Antwort
                                Was ist denn drin?
                                @thomas-braun sagte in nach nodeJs update auf 20.16.0 keine Skrpt seite mehr:
                                Was ist denn drin?
                                lass mich raten...
                                mime-types
                                  Was ist denn drin?
                                  stoffel67
                                  ich versteh’s aktuell nicht so richtig…
                                  im javascript adapter habe ich zusätzlich npm module
                                  „modbus-seriell,i2c-bus,oled-font-5x7,ms5611,basic-ftp“
                                    TT-Tom
                                    @stoffel67
                                    Nix mit npm install machen, sondern über
                                    iob upgrade self
                                    Gruß Tom
                                    Public Transport
                                    • T TT-Tom
                                      @stoffel67
                                      iob upgrade self
                                      stoffel67
                                      @tt-tom
                                      OK werden den JS-controller updaten
                                      S Thomas BraunT T 3 Antworten Letzte Antwort
                                      • S stoffel67
                                        @tt-tom
                                        stoffel67
                                        @stoffel67
                                        pi@raspberrypi:/opt/iobroker $ iob stop
                                        pi@raspberrypi:/opt/iobroker $ iob upgrade self
                                        Update js-controller from @5.0.12 to @6.0.9
                                        Stopped Objects DB
                                        Stopped States DB
                                        NPM version: 10.8.1
                                        Installing iobroker.js-controller@6.0.9... (System call)
                                        Try to solve ENOTEMPTY error automatically
                                        Could not handle ENOTEMPTY, because no deletable files were found
                                        npm error code ENOTEMPTY
                                        npm error syscall rename
                                        npm error path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types
                                        npm error dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue
                                        npm error errno -39
                                        npm error ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/types' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/.types-YI5CT0ue'
                                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-08-02T18_32_43_299Z-debug-0.log
                                        host.raspberrypi Cannot install iobroker.js-controller@6.0.9: 217
                                        • S stoffel67
                                          @tt-tom
                                          @stoffel67
                                          Hau den javascript-Adapter nochmal drüber.
