  4. [Javascript] Midas (Aquatemp) Poolheizung
    6.3k
359 Beiträge 25 Kommentatoren 103.9k Aufrufe 25 Beobachtet
  • S sunnylaila
    @michael-roling
    habe es gerade neu installiert aber leider noch kein erfolg siehe log
    midas-aquatemp.0
    2024-07-17 18:38:47.258	error	Response: {"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[],"isReusltSuc":true}
    midas-aquatemp.0
    2024-07-17 18:38:47.258	error	Error in updateDeviceID(): No device code found
    midas-aquatemp.0
    2024-07-17 18:38:47.092	info	Login ok! Token: TVhfM4yFTdnqTRMIchl7Rt+ILOZsLixeSOXBNvoowdNppxVNabU6Mj1mYkyWloTMXPFacEkw0HogOrNnmbsXTw==
    midas-aquatemp.0
    2024-07-17 18:38:46.550	info	Request token
    midas-aquatemp.0
    2024-07-17 18:38:46.546	info	Objects created
    midas-aquatemp.0
    2024-07-17 18:38:46.539	info	Create object: midas-aquatemp.0.rawJSON
    midas-aquatemp.0
    2024-07-17 18:38:46.521	info	Create object: midas-aquatemp.0.DeviceCode
    midas-aquatemp.0
    2024-07-17 18:38:46.514	info	Create object: midas-aquatemp.0.ProductCode
    midas-aquatemp.0
    2024-07-17 18:38:46.506	info	Create object: midas-aquatemp.0.exhaust
    midas-aquatemp.0
    2024-07-17 18:38:46.501	info	Create object: midas-aquatemp.0.coilTemp
    midas-aquatemp.0
    2024-07-17 18:38:46.497	info	Create object: midas-aquatemp.0.suctionTemp
    midas-aquatemp.0
    2024-07-17 18:38:46.493	info	Create object: midas-aquatemp.0.tempSet
    midas-aquatemp.0
    2024-07-17 18:38:46.488	info	Create object: midas-aquatemp.0.tempOut
    midas-aquatemp.0
    2024-07-17 18:38:46.483	info	Create object: midas-aquatemp.0.tempIn
    midas-aquatemp.0
    2024-07-17 18:38:46.478	info	Create object: midas-aquatemp.0.state
    midas-aquatemp.0
    2024-07-17 18:38:46.473	info	Create object: midas-aquatemp.0.silent
    midas-aquatemp.0
    2024-07-17 18:38:46.468	info	Create object: midas-aquatemp.0.rotor
    midas-aquatemp.0
    2024-07-17 18:38:46.463	info	Create object: midas-aquatemp.0.mode
    midas-aquatemp.0
    2024-07-17 18:38:46.459	info	Create object: midas-aquatemp.0.errorMessage
    midas-aquatemp.0
    2024-07-17 18:38:46.454	info	Create object: midas-aquatemp.0.errorLevel
    midas-aquatemp.0
    2024-07-17 18:38:46.447	info	Create object: midas-aquatemp.0.errorCode
    midas-aquatemp.0
    2024-07-17 18:38:46.438	info	Create object: midas-aquatemp.0.error
    midas-aquatemp.0
    2024-07-17 18:38:46.423	info	Create object: midas-aquatemp.0.consumption
    midas-aquatemp.0
    2024-07-17 18:38:46.415	info	Create object: midas-aquatemp.0.info.connection
    midas-aquatemp.0
    2024-07-17 18:38:46.358	info	Create object: midas-aquatemp.0.ambient
    midas-aquatemp.0
    2024-07-17 18:38:46.312	info	starting. Version 0.0.1 (non-npm: MiRo1310/ioBroker.midas-aquatemp#fe2980f6c63f14269805862155e182f5f2bed22b) in /opt/iobroker/node_modules/iobroker.midas-aquatemp, node: v20.15.1, js-controller: 5.0.19
    Michael RolingM Offline
    Michael Roling
    #285
    @sunnylaila sorry. Ich muss dann noch mal schauen.
    • S sunnylaila
      @michael-roling
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      midas-aquatemp.0
      O Online
      O Online
      oxident
      #286
      @sunnylaila Das ist echt tricky ... hat aber mit den SSL-Sachen nix zu tun. Ich schaue parallel auch nochmal!
      Michael RolingM 2 Antworten Letzte Antwort
      • O oxident
        Michael Roling
        schrieb am zuletzt editiert von Michael Roling
        #287
        @oxident Hast du schon was in Erfahrung bringen können? Mir scheint es so als ob er das Device nicht erkennt, und daher kann der ganze Code nicht laufen. Der Error der kommt, ist von mir so eingebaut. Das Login klappt ja, nur halt bekommt er keine weiteren Daten.
        Dann ist die Frage von wo kommt der ProduktId? In meiner App steht eine ganz andere Id als wie im Adapter ausgelesen.
        Ich nehme das mit dem ssl zertifikat erstmal wieder raus, denn das ist ja sonst eine mögliche Sicherheitslücke.
        Kann das was mit dem Api-Level zu tun haben?
        @sunnylaila Hast du das mal versucht ob es mit einem anderen geht?
        • Michael RolingM Michael Roling
          sunnylaila
          #288
          @michael-roling
          Was meinst du mit einem anderen?
          Kann ich eventuell euch aus der App etwas auslesen in den Parameter Einstellung ?
          Michael RolingM 1 Antwort Letzte Antwort
          • S sunnylaila
            @michael-roling
            Michael Roling
            #289
            @sunnylaila ich meinte anderen api Level in den settings
            • Z znyde
              sorry für den Spam,
              hier eine Lösung die bei mir geholfen hat
              einfach diese Abfrage hinzufügen:
              body: {product_ids: ["1442284873216843776"]},
              function updateDeviceID() {
                  if(token!="") {
                      var optionsDev = {
                          url: cloudURL + '/app/device/deviceList.json',
                          headers: { "x-token": token},
                          method: 'POST',
                          json: true,
                          rejectUnauthorized: false
              sunnylaila
              #290
              @znyde said in [Javascript] Midas (Aquatemp) Poolheizung:
              sorry für den Spam,
                  if(token!="") {
                      var optionsDev = {
                          method: 'POST',
                          json: true,
              hier hat zynde noch etwas im Javascript hinzugefügt für die product id
              " body: {product_ids: ["1442284873216843776"]}, "
              vielleicht hilft das ja etwas
                sunnylaila
                #291
                @michael-roling
                api level hatte ich alle drei ausprobiert hat aber nichts geändert
                • S sunnylaila
                  @michael-roling
                  Michael Roling
                  #292
                  @sunnylaila die productId ist bereits enthalten
                  • O oxident
                    Michael Roling
                    #293
                    @oxident Sag mal hatte das einen Grund warum man die Werte nur ändern darf wenn die Wärmepumpe an ist? Ich habe das mal raus genommen, es sei denn du hast da noch einen Einwand zu.
                    O 1 Antwort Letzte Antwort
                    • S sunnylaila
                      @michael-roling
                      Michael Roling
                      #294
                      @sunnylaila Ich habe noch mal ein paar kleine Änderungen vor genommen. Also noch einmal bitte testen
                        O Online
                        O Online
                        oxident
                        #295
                        @michael-roling Also früher hat der Server sämtliche Änderungen (bis auf on/off) mit einem Fehler quittiert wenn die WP aus war. Ist das jetzt nicht mehr so?
                        Also bei @sunnylaila stehe ich auch gerade auf dem Schlauch. Eine Paketmitschnitt aus der App wäre cool, aber das ist ja sicherlich nicht ganz so leicht...
                        Eventuell könnte es an der ProductID liegen. Die habe ich vom Github-Projekt übernommen.
                        • O oxident
                          Michael Roling
                          #296
                          @oxident ja das geht jetzt.
                            sunnylaila
                            #297
                            @michael-roling
                            habe es jetzt nochmal neu installiert mit dem selben Fehler
                            	2024-07-20 08:02:46.517	error	Response: {"sessionid":null,"error_code":"0","error_msg":"Success","error_msg_code":"","totalSize":null,"totalPage":null,"nextPage":null,"objectResult":[],"isReusltSuc":true}
                            midas-aquatemp.0
                            2024-07-20 08:02:46.516	error	Error in updateDeviceID(): No device code found
                            wobei mir jetzt gerade in der app die Poolheizung auch als Offline angezeigt wird.
                            Probiere heute Nachmittag nochmal wenn die Poolheizung wieder als Online angezeigt wird und guck dann mal in den Parametereinstellungen ob ich da etwas mit Product ID sehe.
                            • S sunnylaila
                              @michael-roling
                              midas-aquatemp.0
                              Michael Roling
                              #298
                              @sunnylaila unter diesem Benutzer ist auch definitiv eine pumpe registriert? Schau mal zusätzlich in der App was du für eine Product id hast
                                sunnylaila
                                #299
                                @michael-roling
                                jetzt ist die Poolheizung in der App wieder online ist aber im log immer noch gleich
                                habe in der App mal Screenshots gemacht vielleicht hilft das ja
                                IMG_8835.png IMG_8836.png IMG_8837.png IMG_8838.png IMG_8839.png IMG_8840.png IMG_8841.png IMG_8842.png IMG_8843.png IMG_8844.png IMG_8845.png IMG_8846.png
                                • S sunnylaila
                                  @michael-roling
                                  Michael Roling
                                  #300
                                  @sunnylaila du hast aber 2 Accounts? Einen für die App und einen für den Adapter?
                                  Und was mir noch aufgefallen ist, die zieltemperatur ist viel zu niedrig 🤣🤣🤣🤣
                                  Ich habe für heute die auf 33 grad stehen. 😋
                                    sunnylaila
                                    #301
                                    @michael-roling
                                    hi, ja habe 2 Accounts, die Zieltemperatur von dir gefällt mir auch besser, aber meiner Regierung nicht 😊
                                    • S sunnylaila
                                      @michael-roling
                                      Michael Roling
                                      #302
                                      @sunnylaila und du benutzt auch wirklich nicht den gleichen Account trotz das du 2 hast.
                                      Mein Plan ist je nach Überschuss vom Strom die Temperatur zu steuern. Mindestens aber 30 grad.
                                        sunnylaila
                                        #303
                                        @michael-roling
                                        nein habe ich kontrolliert in der app ist es ein anderer Account wie im iobroker
                                        off Topic meine Frau mag lieber eine Erfrischung mir wäre Wärmer auch lieber da ja die PV auch immer genug Strom liefert
                                          sunnylaila
                                          #304
                                          @michael-roling
                                          Hilft den die Geräte -ID dir bei mir in der app steht eventuell weiter?
                                          1640627152468598784
