  2. English
  3. Scripting / Logic
  4. JavaScript
  5. JavaScript adapter wont detect modbus-serial
18 Beiträge 3 Kommentatoren 3.5k Aufrufe 3 Beobachtet
    @jack-3 sagte in JavaScript adapter wont detect modbus-serial:
    where do I need to download it to?
    nowhere!
    you just have to add it in the config.
    save and exit, the instance should restart and load it itself.
    Jack 3J
    Jack 3J
    Jack 3
    @homoran Im still getting this error even after adding modbus-serial to the instance, are there perhaps other steps I can take to troubleshoot this?
    • Jack 3J Jack 3
      I think so, but I cannot tell which ones.
      maybe that @thomas-braun may help to find the issue if something went wrong by your installation method and is blocking the built in method
      oooh!
      is there a whitespace too much at the end? before the closing '
      • Jack 3J Jack 3
        I am trying to use the modbus-serial library so that I can automate the creation of new instances in iobroker when it detects a new TCP signal. However, for some reason it does not recognize that I have downloaded this module already. I have attached a screenshot for clarification. 7de54df8-6aa1-4254-8e0f-6df2af3913fe-image.png
        I am doing this in the JavaScript adapter.
        Any help would be greatly appreciated, thanks in advance.
        F
        F
        fastfoot
        @jack-3 do something with ModbusRTU, the error might only be visually(because of some restriction the sandbox has). Only if yo get additional errors when using the module you can tell the module is not loaded
        Jack 3J 1 Antwort Letzte Antwort
        • F fastfoot
          Jack 3J
          Jack 3J
          Jack 3
          @fastfoot I tried this code which I copied and edited from the modbus serial documentation and I am getting these errors 48aac906-bd54-4c26-8cd4-eb3e6a7f5078-image.png
          F 1 Antwort Letzte Antwort
          • Jack 3J Jack 3
            F
            F
            fastfoot
            @jack-3 ok, thats a real error. Which version of JS-Adapter do you have? I think there is a bug in the newest Beta not installing modules that were entered in the instance config. Remove these lines, leave the config and enter them again. After leaving the config then have a look to the Log Tab, you schould see the that module(s) are getting installed.
            Workaround on the cli:
            • cd /opt/iobroker
            • npm i modbus-serial
            • js-adapter should recognize the module now, though the red underline might still be there
            let us know, there should be no need to install module in /opt/iobroker/node_modules/iobroker.javascript instead of /opt/iobroker
            • F fastfoot
              • cd /opt/iobroker
              Jack 3J
              Jack 3J
              Jack 3
              @fastfoot Thats the thing, I do not have an /opt/iobroker directory, it does not exist is what the terminal tells me
              • Jack 3J Jack 3
                F
                F
                fastfoot
                @jack-3 what system are you running iobroker, windows? There it schould be C:\iobroker. All Linux Systems use /opt/iobroker. Though not sure where tis is on a Mac
                Jack 3J 2 Antworten Letzte Antwort
                • F fastfoot
                  Jack 3J
                  Jack 3J
                  Jack 3
                  @fastfoot I use windows
                  • F fastfoot
                    Jack 3J
                    Jack 3J
                    Jack 3
                    @fastfoot I ran the command again using the directory you said and Im still getting the same errors, I can even see in the node_modules directory that I do have Modbus-serial installed
                    • Jack 3J Jack 3
                      F
                      F
                      fastfoot
                      @jack-3 the try cd C:\iobroker and then npm i modbus-serial
                      • F fastfoot
                        F
                        F
                        fastfoot
                        @fastfoot please log the error instead of the data, works fine here though i have no modbus hardware
                        • Jack 3J
                          Jack 3J
                          Jack 3
                          schrieb am zuletzt editiert von Jack 3
                          @fastfoot
                          2024-07-09 09:07:46.559 - error: modbus.0 (604) Socket Error
                          2024-07-09 09:07:46.564 - error: modbus.0 (604) Client in error state.
                          2024-07-09 09:07:46.564 - warn: modbus.0 (604) On error: {"errno":-4039,"code":"ETIMEDOUT","syscall":"connect","address":"131.246.75.233","port":5020}
                          2024-07-09 09:07:46.592 - error: modbus.1 (12848) Socket Error
                          2024-07-09 09:07:46.601 - error: modbus.1 (12848) Client in error state.
                          2024-07-09 09:07:46.601 - warn: modbus.1 (12848) On error: {"errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                          2024-07-09 09:08:47.615 - error: modbus.1 (12848) Socket Error
                          2024-07-09 09:08:47.615 - error: modbus.1 (12848) Client in error state.
                          2024-07-09 09:08:47.615 - warn: modbus.1 (12848) On error: {"errno":-4078,"code":"ECONNREFUSED","syscall":"connect","address":"127.0.0.1","port":502}
                          2024-07-09 09:09:08.775 - error: modbus.0 (604) Socket Error
                          2024-07-09 09:09:08.775 - error: modbus.0 (604) Client in error state.
                          2024-07-09 09:09:08.775 - warn: modbus.0 (604) On error: {"errno":-4039,"code":"ETIMEDOUT","syscall":"connect","address":"131.246.75.233","port":5020}
                          2024-07-09 09:09:12.133 - info: admin.0 (5516) ==> Connected system.user.admin from ::1
                          2024-07-09 09:09:12.221 - error: host.PCRT49 cannot call visUtils: Not exists
                          2024-07-09 09:09:18.930 - info: admin.0 (5516) ==> Connected system.user.admin from ::1
                          2024-07-09 09:09:21.197 - info: javascript.0 (12652) Start JavaScript script.js.Test (Javascript/js)
                          2024-07-09 09:09:21.206 - error: javascript.0 (12652) script.js.Test compile failed:
                          at script.js.Test:4
                          is that what you mean?
                          83.8k
