  4. Parser Regex
Parser Regex
11 Beiträge 3 Kommentatoren 990 Aufrufe 3 Beobachtet
    MCU
    @Wuffi26
    Mit javascript?
    let dpInhalt = {
        "val": "{\"InverterStatus\":5,\"InputPower\":270,\"PV1Voltage\":362.9,\"PV1InputCurrent\":0.7,\"PV1InputPower\":257.9,\"PV2Voltage\":288.4,\"PV2InputCurrent\":0,\"PV2InputPower\":20.9,\"OutputPower\":496.7,\"GridFrequency\":49.98,\"L1ThreePhaseGridVoltage\":241.5,\"L1ThreePhaseGridOutputCurrent\":2.3,\"L1ThreePhaseGridOutputPower\":492.9,\"L2ThreePhaseGridVoltage\":0,\"L2ThreePhaseGridOutputCurrent\":0,\"L2ThreePhaseGridOutputPower\":0,\"L3ThreePhaseGridVoltage\":0,\"L3ThreePhaseGridOutputCurrent\":0,\"L3ThreePhaseGridOutputPower\":0,\"TodayGenerateEnergy\":27.9,\"TotalGenerateEnergy\":6828.3,\"TWorkTimeTotal\":5.903158e7,\"PV1EnergyToday\":12.3,\"PV1EnergyTotal\":3153.6,\"PV2EnergyToday\":17.1,\"PV2EnergyTotal\":3378.2,\"PVEnergyTotal\":6554.4,\"InverterTemperature\":36,\"TemperatureInsideIPM\":33.3,\"BoostTemperature\":35.9,\"DischargePower\":0,\"ChargePower\":0,\"BatteryVoltage\":53.3,\"SOC\":100,\"ACPowerToUser\":0,\"ACPowerToUserTotal\":0,\"ACPowerToGrid\":81,\"ACPowerToGridTotal\":81,\"INVPowerToLocalLoad\":200,\"INVPowerToLocalLoadTotal\":200,\"BatteryTemperature\":26,\"BatteryState\":5,\"EnergyToUserToday\":1.2,\"EnergyToUserTotal\":8244.3,\"EnergyToGridToday\":0.8,\"EnergyToGridTotal\":217.9,\"DischargeEnergyToday\":8.8,\"DischargeEnergyTotal\":3086.6,\"ChargeEnergyToday\":10.8,\"ChargeEnergyTotal\":3092.5,\"LocalLoadEnergyToday\":27.8,\"LocalLoadEnergyTotal\":14574.9,\"ACChargeEnergyToday\":0.4,\"ACChargeEnergyTotal\":840.4,\"Mac\":\"48:55:19:68:30:C9\",\"Cnt\":100808}",
        "ack": true,
        "ts": 1719331820944,
        "q": 0,
        "from": "system.adapter.mqtt.0",
        "user": "system.user.admin",
        "lc": 1719331820944,
        "_id": "mqtt.0.SPH4600",
        "common": { "name": "SPH4600", "write": true, "read": true, "role": "variable", "desc": "mqtt server variable", "type": "string" },
        "native": { "topic": "SPH4600" },
        "type": "state",
        "acl": { "object": 1636, "state": 1636, "owner": "system.user.dressman79", "ownerGroup": "system.group.user" }
    let val = dpInhalt.val
    let parsedVal = JSON.parse(val)
    log(parsedVal.SOC)
    log(parsedVal.Cnt)
    DP holen
    let val = getState('mqtt.0.SPH4600').val
    log(parsedVal.SOC)
    log(parsedVal.Cnt)
    • W Offline
      W Offline
      Wuffi26
      Danke für die schnelle, aber mit JS habe ich keinen Plan. In der Parser Instanz kann man eine Regex eingeben, da der string sich immer wieder aktualisiert, wolle eigentlich diesen Weg nehmen. Wie könnte man das noch realisieren?
      M OliverIOO 2 Antworten Letzte Antwort
      • W Wuffi26
        MCU
        @wuffi26 Keine Ahnung ob es funktioniert
        Regex
        \"SOC\":(\d+(\.\d+)?)
        /\"SOC\":(\d+(\.\d+)?)/
        • W Offline
          W Offline
          Wuffi26
          OK danke werde es gleich mal probieren.
          • W Offline
            W Offline
            Wuffi26
            @mcu said in Parser Regex:
            /"SOC":(\d+(.\d+)?)/
            Leider keine Ergebnisse.
            • W Offline
              W Offline
              Wuffi26
              Wenn ich nur SOC eingebe findet er logischerweise Nur das Wort.
              • W Wuffi26
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @wuffi26
                oder so
                \\\"SOC\\\":([\d\.\,]+),
                das regex brücksichtigt auch, das die zahl auch mal punkt und komma enthält
                snsonsten reicht auch
                \\\"SOC\\\":([\d]+),
                Meine Adapter und Widgets
                Links im Profil
                • W Offline
                  W Offline
                  Wuffi26
                  @oliverio said in Parser Regex:
                  \"SOC\":([\d.,]+),
                  Ein Regex Experte, es fontioniert. Ich werde daraus einfach nicht schlau. Vielen Dank.
                  • W Wuffi26
                    \"SOC\":([\d.,]+),
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @wuffi26
                    ja regex ist hart.
                    habe auch mehrere anläufe über die jahre gebraucht bis ich es kapiert habe
                    die folgende seite hilft da enorm.
                    da habe ich genau deinen fall mal gespeichert.
                    oben rechts steht die beschreibung welche zeichen da was genau was matcht.
                    die größte schwierigkeit besteht ein stop zeichen zu finden, da regex als greedy gilt und lieber mehr zeichen anzeiht als zu wenig.
                    aber hier haben wir das , nach der zahl
                    https://regex101.com/r/WiCynN/1
                    Links im Profil
                    • W Offline
                      W Offline
                      Wuffi26
                      Ok vielen Dank für Deine Hilfe.
