  3. Einsteigerfragen
  4. bekomme USB Stick nicht gemountet für backup
    5.4k
48 Beiträge 4 Kommentatoren 4.9k Aufrufe 3 Beobachtet
  • F final
    sorry, durch das kopieren aus der Konsole gehen die Zeilenumbrüche verloren :(
    Geht das anders? Ich markiere und mache dann strg-shift-C
    raspberrypi:/ $ mount | sort        binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)                              bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)                                                  cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)                configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)                                          debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)                                             /dev/mmcblk0p1 on /boot/firmware type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)        /dev/mmcblk0p2 on / type ext4 (rw,noatime,commit=600)        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)                                  /dev/sda1 on /mnt/usbstick type ext4 (rw,relatime)        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)                                      mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)                                                     proc on /proc type proc (rw,relatime)        pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)                                                  ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)                  ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)                ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)      ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)          securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)                                    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)                                                              systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)     tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)                                              tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=94304k,mode=755)                                         tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=94304k,nr_inodes=23576,mode=700,uid=1000,gid=1000)    tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)                                           udev on /dev type devtmpfs (rw,nosuid,relatime,size=334764k,nr_inodes=83691,mode=755)
    @final sagte in bekomme USB Stick nicht gemountet für backup:
    Welches Terminal verwendest du denn?
    Hier geht das nämlich ohne Hantier:
    [thomas@roamer ~]$ mount | sort
    /dev/nvme0n1p1 on /efi type vfat (rw,relatime,fmask=0137,dmask=0027,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
    /dev/nvme0n1p2 on /home type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=257,subvol=/@home)
    /dev/nvme0n1p2 on / type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=256,subvol=/@)
    /dev/nvme0n1p2 on /var/cache type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=258,subvol=/@cache)
    /dev/nvme0n1p2 on /var/log type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=259,subvol=/@log)
    devtmpfs on /dev type devtmpfs (rw,nosuid,size=4096k,nr_inodes=2008343,mode=755,inode64)
    efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
    hugetlbfs on /dev/hugepages type hugetlbfs (rw,nosuid,nodev,relatime,pagesize=2M)
    portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=5713)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
    tmpfs on /run/credentials/systemd-journald.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run/credentials/systemd-sysctl.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run/credentials/systemd-tmpfiles-setup-dev-early.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run/credentials/systemd-tmpfiles-setup-dev.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run/credentials/systemd-tmpfiles-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run/credentials/systemd-udev-load-credentials.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run/credentials/systemd-vconsole-setup.service type tmpfs (ro,nosuid,nodev,noexec,relatime,nosymfollow,size=1024k,nr_inodes=1024,mode=700,inode64,noswap)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,size=3219116k,nr_inodes=819200,mode=755,inode64)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1609556k,nr_inodes=402389,mode=700,uid=1000,gid=1000,inode64)
    tmpfs on /tmp type tmpfs (rw,noatime,inode64)
    [thomas@roamer ~]$
    F 1 Antwort Letzte Antwort
      [thomas@roamer ~]$
      final
      Powershell unter Windows
      • F final
        @final
        Die hab ich auch unter Windows verwendet. Hatte ich nie Probleme mit.
          @final
          final
          Hm, keine Ahnung, vielleicht kopiere ich ja falsch. Naja.
          Hab ich das jetzt verstanden - weil nur root Schreibrechte hat, klappt es nicht?
          • F final
            Dann füg die Zeilenumbrüche von Hand ein. So werde ich das jedenfalls nicht lesen.
              final
              Klar, hab es per Hand angepasst.
              raspberrypi:/ $ mount |sort
              • F final
                @final
                Was hast du eigentlich für einen seltsamen Prompt?
                  @final
                  final
                  ich hab nur den namen vor dem @raspberrypi rausgeschnitten
                  • F final
                    @final
                    Und der hat kein Home?
                    Veränder an der Ausgabe nichts.
                      @final
                      final
                      Doch, wieso.
                      Achso - ich bin anscheinend irgendwann mal mit cd .. aus home raus, wenn du das meinst?
                      Hab bewusst nix verändert.
                      @raspberrypi:/ $ ls -f
                      lost+found  mnt  srv  dev  tmp  bin  etc  media  boot  .  lib  usr  sbin  home  ..  var  root  proc  sys  run  opt
                      • F final
                        Doch, wieso.
                        Doch, wieso.
                        Weil es u. U. wichtig ist, mit welchem user du in welchem Verzeichnis stehst, deswegen.
                        Stell dich wieder in dein home.
                        Die /etc/fstab schaut wie aus?
                        • F final
                          Doch, wieso.
                          @raspberrypi
                          und da vorne steht wirklich nichts davor?
                            @raspberrypi
                            final
                            @homoran said in bekomme USB Stick nicht gemountet für backup:
                            doch, der username (nicht root).
                            • F final
                              @final
                              Text nie als Screenshot, immer in Textform in CodeTags hier rein
                                @final
                                final
                                sorry, war ablenkt :(
                                • F final
                                  final
                                  @Thomas-Braun
                                  Nabend.
                                  Schon eine Idee woran es liegen könnte? Muss ich dem Ordner /mnt/usbstick andere Rechte geben, damit der iob drauf schreiben kann?
                                  • F final
                                    @Thomas-Braun
                                    Nabend.
                                    Text? Dann in Textform hier rein. Wie gesagt, Screenshots schau ich mir nicht an.
                                      final
                                      proc	/proc	proc	defaults	0	0
                                      PARTUUID=d2bed0db-01	/boot/firmware	vfat	defaults	0	2
                                      PARTUUID=d2bed0db-02	/				ext4	defaults,noatime,commit=600 0	1
                                      UUID=9e950934-a656-4909-ac5e-b658ee72204e	/mnt/usbstick	ext4	defaults	0	2
                                      #/dev/sda1	/mnt/usbstick	ext4	defaults	0	2
                                      • F final
                                        Trag da mal
                                        UUID=9e950934-a656-4909-ac5e-b658ee72204e	/mnt/usbstick	ext4	defaults,noauto,users	0	2
                                        ein.
                                        In den Optionen von Backitup dann den Haken bei 'Als root mounten' entfernen und die Kiste neustarten.
                                          Trag da mal
                                          ein.
                                          final
                                          mach ich - sobald ich das System wieder zum laufen bekomme. Aus irgendeinem Grund startet der Raspi nicht mehr richtig, schon mehrfach versucht. Hab ein ungutes Gefühl...
                                          Ein RPi5 kommt heute, den muss ich aber dann erstmal neu aufsetzen.
                                          Allerdings kommt ja dann da das gleiche Thema zum Tragen - werde also dann die fstab wie vorgeschlagen befüllen und dann Rückmeldung geben.
                                          Eine Info könnte ich aber gut gebrauchen: wenn ich jetzt nicht mehr auf den alten Raspi komme - wie kann ich auf die SD Karte zugreifen und mir die letzte Sicherung runter kopieren? Damit das gerade nicht passiert war ja eigentlich der USB Stick gedacht...
