  3. Einsteigerfragen
  4. Steuerung Gecko in Touch 2 per iob möglich? (Wellis)
    5.3k
210 Beiträge 9 Kommentatoren 48.3k Aufrufe 6 Beobachtet
  • Stefan-Berlin1S Stefan-Berlin1
    @rrov1
    Funktioniert Ping:
    PING 192.168.188.68 (192.168.188.68) 56(84) bytes of data.
    64 bytes from 192.168.188.68: icmp_seq=2 ttl=63 time=1.36 ms
    64 bytes from 192.168.188.68: icmp_seq=3 ttl=63 time=1.20 ms
    64 bytes from 192.168.188.68: icmp_seq=4 ttl=63 time=1.40 ms
    64 bytes from 192.168.188.68: icmp_seq=5 ttl=63 time=1.35 ms
    64 bytes from 192.168.188.68: icmp_seq=6 ttl=63 time=1.34 ms
    2te python3 from geckolip... geht auch findet er:
    Starting discovery process...Found 1 spas
    Connecting to spa `Kirschpool ??` at 192.168.188.68 ... connected!
    Heater: Temperature 36.0°C, SetPoint 36.0°C, Real SetPoint 24.9°C, Operation Cool
    ing
    Pump 1: OFF
    Pump 2: OFF
    Waterfall: OFF
    Lights: OFF
    WaterCare: Waiting...
    Smart Winter Mode:Risk: NO
    Circulating Pump: OFF
    Ozone: OFF
    Smart Winter Mode:Active: False
    Filter Status:Clean: False
    Filter Status:Purge: False
    Economy Mode: True
    Error Sensor: VSP1CommLost, VSP2CommLost
    Welcome to the Gecko shell. Type help or ? to list commands.
    Das letzte klappt nicht:
    root@buanet-iobroker-1:/opt/iobroker# python3 /SpaController/spa_config.py b7031c
    49-70a1-4f9b-917b-24df54c20973 http://172.17.0.4:8087 javascript.0.Datenpunkte.Sw
    imSpa
    /SpaController/spa_config.py Version: 0.2.4
    total arguments passed: 4
    Connect using client id: b7031c49-70a1-4f9b-917b-24df54c20973
    ioBroker Simple Rest API URL: http://172.17.0.4:8087
    Base path to datapoints: javascript.0.Datenpunkte.SwimSpa
    *** looking for spas on your network ...
    *** there were no spas found on your network.
    Stefan-Berlin1S Offline
    Stefan-Berlin1
    #153
    @stefan-berlin1
    Hat es was mit der Simple Api vielleicht zu tun und den Ports?
    rrov1R 1 Antwort Letzte Antwort
      @stefan-berlin1
      rrov1R Offline
      rrov1R Offline
      rrov1
      #154
      @stefan-berlin1 Hallo Stefan,
      leider nein. Das Skript spa_config.py ist recht simpel gestrickt:
      1. Parameteranzahl prüfen und Parameter in Variablen merken
      2. Verbindung zum SpaController herstellen (Zeile 34 die du angepasst hast)
      3. Diverse Werte vom SpaController abrufen und merken
      4. Werte aufbereiten und per HTTP-Request dem Simple API übergeben.
      Wenn bei Punkt 2 keine Verbindung aufgebaut werden kann endet das Skript an der Stelle (es hat ja sowieso nix was es dem Simple API übergeben könnte).
      Blöd ist, das es in meinem Testcontainer läuft und die beiden Tests die du ausgeführt hast sind klare Indikatoren dafür das es keine grundsätzlichen Probleme bei dir gibt.
      Ich habe leider heute und morgen keine Zeit mehr, am Wochenende bin ich unterwegs in den Urlaub. Ich baue, wenn ich Zeit habe nächst Woche das spa_config.py ordentlich um, so dass du da nicht mehr drin rumändern musst und melde mich noch mal.
      Stefan-Berlin1S 1 Antwort Letzte Antwort
      • rrov1R rrov1
        Stefan-Berlin1
        #155
        @rrov1
        Mach ganz ruhig, kommt ja nicht auf'n paar Tage an.
        Genieß den Urlaub. Ich teste mal nochmal paar Variation
          @rrov1
          rrov1R Offline
          rrov1R Offline
          rrov1
          #156
          ich habe jetzt die Skripte angepasst, so dass auch von meinem Docker Test Container aus SpaController erkannt werden. Es gibt jetzt einen Datenpunkt in dem du die IP-Adresse vom SpaController hinterlegen musst, damit dieser gefunden wird. Bitte wie folgt vorgehen:
          • im ioBroker anmelden, ins Verzeichnis SwimSpa wechseln und "git pull" aufrufen. Der git-Client sollte einige Skripte aktualisieren
          • Python Skripte aktualisieren: "cp ./Python/*.py /SpaController/"
          • Skript: SpaVariablen.js öffnen, Inhalt löschen und mit Inhalt von SpaVariablen.js ersetzen und 1x laufen lassen (Achtung: Aufruf in Zeile 4 ggf. anpassen), Am Ende sollte ein neuer Datenpunkt: javascript.0.Datenpunkte.SwimSpa.discoverIP vorhanden sein.
          • Jetzt die IP-Adresse des SpaController im neuen Datenpunkt: javascript.0.Datenpunkte.SwimSpa.discoverIP manuell eintragen.
          • Skript: SpaUpdateConfig.js öffnen, Inhalt löschen und mit dem aus git: SpaUpdateConfig.js ersetzen, speichern und ausführen.
          Das ist jetzt die spannende Stelle, wenn bei dir alles klappt, sollte der SpaController nun gefunden werden auf Basis seiner IP-Adresse. Es sollten Datenpunkte wie:
          • ID
          • IPAdresse
          • Name
          • U_ID
            unterhalb von javascript.0.Datenpunkte.SwimSpa.0 gesetzt sein.
          Schreibe mal ob das erfolgreich war.
          • rrov1R rrov1
            • ID
            • IPAdresse
            • Name
            • U_ID
            Stefan-Berlin1
            schrieb am zuletzt editiert von Stefan-Berlin1
            #157
            @rrov1
            Hallo hoffe Du hattest ein angenehmen Urlaub. Ich hab dies mal getestet und auch nochmal komplett neu gemacht.
            Im Datenpunkt taucht es auf. Wenn ich die Spa Update Config Starte kommt noch ein Fehler:
            javascript.0	01:58:42.668	info	Stopping script script.js.common.Spa.SpaUpdateConfig
            javascript.0	01:59:07.571	info	Stopping script script.js.common.Spa.SpaUpdateConfig
            javascript.0	01:59:13.261	info	Start JavaScript script.js.common.Spa.SpaUpdateConfig (Javascript/js)
            javascript.0	01:59:13.302	info	script.js.common.Spa.SpaUpdateConfig: start
            javascript.0	01:59:13.302	info	script.js.common.Spa.SpaUpdateConfig: registered 0 subscriptions, 1 schedule, 0 messages, 0 logs and 0 file subscriptions
            javascript.0	01:59:13.303	info	script.js.common.Spa.SpaUpdateConfig: *** IP(s) to disover: 192.168.188.68
            javascript.0	01:59:13.303	info	script.js.common.Spa.SpaUpdateConfig: resetting scriptRunning, because it's false since more than 5 minutes
            javascript.0	01:59:13.303	info	script.js.common.Spa.SpaUpdateConfig: *** discovering IP: 0 => 192.168.188.68
            javascript.0	01:59:13.304	info	script.js.common.Spa.SpaUpdateConfig: *** executing: python /SpaController/spa_config.py 4d9a30ec-aea3-4a77-af1a-01d1ea71c336 http://172.17.0.6:8087 javascript.0.Datenpunkte.SwimSpa 0 192.168.188.68
            javascript.0	01:59:13.313	info	script.js.common.Spa.SpaUpdateConfig: *** stderr: Error: Command failed: python /SpaController/spa_config.py 4d9a30ec-aea3-4a77-af1a-01d1ea71c336 http://172.17.0.6:8087 javascript.0.Datenpunkte.SwimSpa 0 192.168.188.68 /bin/sh: 1: python: not found
            javascript.0	01:59:13.313	info	script.js.common.Spa.SpaUpdateConfig: end
            Ich hab nochmal die befehle ausgeführt und er findet den Spa:
            python3
            from geckolib import GeckoShell
            GeckoShell.run(["logfile client.log", "discover 192.168.188.68"])
            Gruß Stefan
              @rrov1
              python3
              Gruß Stefan
              rrov1R Offline
              rrov1R Offline
              rrov1
              #158
              ja, der Urlaub war schon gut, nur das Wetter war dieses Jahr an der Costa Brava nicht so gut, ich musste die Tagesaktivitäten etwas aktiver gestalten ;-) .
              Die Shell sagt: /bin/sh: 1: python: not found
              Der Python Interpreter sollte auf den Namen "python3" hören (vgl. dein manueller Test). Bitte prüfe in SpaGlobal.js noch mal die Zeile 4, Variable: SPA_EXECUTEABLE, dort sollte "python3" drinnen stehen.
              • rrov1R rrov1
                Stefan-Berlin1
                #159
                @rrov1
                das ist ärgerlich das das Wetter so schlecht war. Dafür fährt man ja weg um dem Wetter hier zu entgehen.
                Es hat geklappt es sind Daten zu sehen 👍 huchu . Dann werde ich mal sehen wie ich die in meine Loxone wertvoll weiter verarbeiten kann.
                Bekomme in kürze dann auch noch eine Wellis Wärmepumpe mal schauen wie die funktioniert und wie man diese nun wieder einbindet.
                  @rrov1
                  rrov1R Offline
                  rrov1R Offline
                  rrov1
                  #160
                  schön zu hören, das es jetzt doch klappt :-) .
                  Ich habe hier auch eine Loxone Anlage. Ich habe die Integration über den Simple Rest API Adapter gelöst, sprich virtuelle Eingänge für z.B. die Temperaturen gleich über ein "getBulk" und virtuelle Ausgänge mit "set" auf Datenpunkte. Funktioniert einwandfrei.
                  Viel Erfolg noch.
                  Stefan-Berlin1S 2 Antworten Letzte Antwort
                  • rrov1R rrov1
                    Viel Erfolg noch.
                    Stefan-Berlin1
                    #161
                    @rrov1 danke, ja ich hole mir schon diverse Sachen rein in die loxone. Aber meist nur Status. Steuern muss ich mal schauen wie ich das mache.
                    Mal schauen wie sich die Wärmepumpe noch ansprechen lässt wenn Sie da ist
                    • rrov1R rrov1
                      Viel Erfolg noch.
                      Stefan-Berlin1
                      #162
                      @rrov1
                      Hab noch ein Problem.
                      Sagen wir mal 30 Grad ist aktuell. Ich Stelle die Temperatur auf 38 Grad (per App und auch vor Ort). Schau Zeit x später rein steht ne andere eingestellte Temperatur als hätte jemand wieder runter geregelt. 😔
                      Zur Info ich hab ein Wellis Life Atlas 2024 Modell.
                      Hat 2 Sprudler Pumpen und ein Zirkalations (Filter) Pumpe und ein Wasserfall der mit Pumpe 1 angeht automatisch (bzw.kann man den manuell über Drehknopf Mischer ausmachen)
                      1 Spa Controller
                      2 Pumpen
                      Datenpunkte:
                      P1 wäre Sprudel rechte Seite (Liegefläche) inklusive Wasserfall (Wasserfall kann man nur manuell mit Drehrad (Mischer) abstellen)
                      P2 ist Sprudler linke Seite (Sitze)
                      Beim Datenpunkt Waterfall reagiert er wenn Circulations Pumpe an geht. Da wird es angezeigt und auch unter Punkt Sensoren Circulations Pump
                      Kann ich den Datenpunkt (Waterfall) im SpaVariables einfach umbennen in CirculationPump?
                      oder gibts noch in anderen Phyton Scripts den Name Waterfall...?
                      Kannst Du mir noch ein Tipp geben wie ich die Pumpen an und ausschalten kann muss ich den Modi oder Switch ansteuern per Loxone Virtuellen Ausgang?
                      LG
                        @rrov1
                        1 Spa Controller
                        2 Pumpen
                        Datenpunkte:
                        LG
                        rrov1R Offline
                        rrov1R Offline
                        rrov1
                        #163
                        1. Hast du das Script: SpaMoveTargetTemp.js aktiv? Das wäre dafür verantwortlich die Temperatur nachzuregeln. Bitte den Datenpunkt: javascript.0.Datenpunkte.SwimSpa.automaticTargetTemp mal auf "false" setzen, damit wird diese automatische Temperaturnachführung deaktiviert.
                        2. Du kannst im Protokoll vom ioBroker mal nach "spa_setTargetTemp.py" suchen, dann findest du die Aufrufe zum setzen der Zieltemperatur.
                        Der "Waterfall" ist noch eher eine Baustelle, da ich sowas nicht habe und bisher nichts testen konnte. Es gibt aktuell auch keine Skripte die auf die Änderung des Datenpunktes reagieren bzw. auch kein Python Skript das die Reaktion an den SpaController weitergibt. Er ist erst mal nur da, weil die geckolib ihn kennt. Den Datenpunkt: javascript.0.Datenpunkte.SwimSpa.0.Pumpen.Waterfall umzubenennen, wäre mir nicht so lieb, weil der Pfad bei einem Update wieder angelegt werden würde und dann evtl. zu Verwirrung führt. Was wäre das Ziel hinter der Umbenennung, die Pfade tauchen in den GUI's ja nicht auf. Zur Not vielleicht lieber einen Alias anlegen?
                        Um die Pumpen einzuschalten nimmst du den Datenpunkte mit dem Namen "Switch", die anderen beiden Datenpunkte sind für dich Read Only (zu erkennen am Schloss im Icon vor dem Namen des Datenpunkts). Wichtig noch zu wissen, die geckolib kennt pro Pumpe 3 Status:
                        • OFF = AUS (logisch)
                        • LO oder LOW = kleine Stufe (funktioniert nur, wenn es deine Pumpe unterstützt, meine z.B. nicht)
                        • HI oder HIGH = große Stufe
                        • rrov1R rrov1
                          Stefan-Berlin1
                          #164
                          @rrov1
                          Danke,
                          so Waterfall / Zirkulations Pumpe sind das gleiche in meinem Fall.
                          ok SpaMoveTargetTemp.js den Datenpunkt hab ich auf false gesetzt.
                          Ich hab mal beobachtet bei OZON Status wird auch immer off angezeigt. Setzt er den nicht ein zur Reinigung wenn Zirkulationspumpe an ist und Filterdurchlauf läuft?
                          Dann noch eine Sache zu Wasserpflege Modi,
                          dort steht auch immer " Away from home" . Bei Wasserpflege Switch hab ich nun mal auf Standart (1) gesetzt manuell. Der ist immer aktiv (APP). Sollte sich dann aber nicht auch Der Modi Name ändern?
                            @rrov1
                            Danke,
                            rrov1R Offline
                            rrov1R Offline
                            rrov1
                            #165
                            OZON Status immer OFF: Das habe ich auch schon beobachtet. Das war bei mir noch nie ON. Ich vermute die zugrundeliegende geckolib liefert den Wert nicht. Der Entwickler hat aber leider nur ganz wenig Zeit.
                            WasserpflegeModi: Der Status ändert sich nicht, das ist eine Liste der verfügbaren Wasserpflegestatusnamen, bei mir: ['Away From Home', 'Standard', 'Energy Saving', 'Super Energy Saving', 'Weekender']. Das ist vorgesehen, falls das jemand zur Visualisierung braucht.
                            • rrov1R rrov1
                              Stefan-Berlin1
                              #166
                              Kannst Du mir irgendwie ein Rat geben für die Loxone Bausteine
                              Wenn PV Überschuss dann stell die temperatur auf z.b 38 Grad
                              Wenn kein Überschuss ist stell die Temeratur auf 25 Grad.
                                rrov1R Offline
                                rrov1R Offline
                                rrov1
                                #167
                                @stefan-berlin1
                                Hallo Stefan,
                                das habe ich tatsächlich nicht mit Loxone geregelt sondern mit einem Script oder besser mit 2 Scripten.
                                Script 1: SpaMoveTargetTemp.js (im Repo enthalten), das führt die Zieltemperatur immer 5 Grad höher als die aktuelle Temperatur nach und zwar zwischen der Minimaltemperatur von 12 Grad (Konstante im Script) und einer gewünschten Maximaltemperatur wie z.B. 38 Grad). Das Script läuft einfach aller 20 Minuten. Wenn du das einsetzt, dann schau in die schedule-Funktion, Zeilen 5 & 6, das ist für meine 2 Spa's du brauchst nur Zeile 5, Zieltemperatur natürlich anpassen nach Wunsch.
                                Script 2: Ist nicht im Repo enthalten. Das Script ist spezifisch für meine Solaranlage und Schaltet den Wasserpflegemodus ein, wenn meine Batterie in den letzten 10 Minuten über 70% gefüllt ist und genug Überschuss da ist. Natürlich schaltet das dann den Wasserpflegemodus auch wieder aus.
                                Vieleicht reicht dir aber schon das Script mit der Zieltemperatur.
                                rrov1
                                • rrov1R rrov1
                                  @stefan-berlin1
                                  Hallo Stefan,
                                  rrov1
                                  Stefan-Berlin1
                                  #168
                                  @rrov1
                                  danke Dir, ich hab das schon relativ hinbekommen.
                                  Ich habe irgendwie jedoch im io ne Fehlermeldung:
                                  script.js.common.Spa.SpaUpdateValues: *** stderr: Error: Command failed: python3 /SpaController/spa_updateBulk.py 54657**********a2d3-7b6acda379a4 http://172.17.0.4:8087 SPA80:********:2c 192.168.188.68 javascript.0.Datenpunkte.SwimSpa 2025-07-09 21:48:42,362> ERROR Cannot get full struct, protocol retry count exceeded 2025-07-09 21:49:30,203> ERROR Exception during spa connection Traceback (most recent call last): File "/usr/lib/python3.11/asyncio/runners.py", line 190, in run return runner.run(main) ^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/asyncio/runners.py", line 118, in run return self._loop.run_until_complete(task) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/asyncio/base_events.py", line 640, in run_until_complete self.run_forever() File "/usr/lib/python3.11/asyncio/base_events.py", line 607, in run_forever self._run_once() File "/usr/lib/python3.11/asyncio/base_events.py", line 1884, in _run_once event_list = self._selector.select(timeout) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/selectors.py", line 468, in select fd_event_list = self._selector.poll(timeout, max_ev) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/SpaController/spa_updateBulk.py", line 52, in alarm raise SystemExit("Timed out: Maximum script runtime reached.") SystemExit: Timed out: Maximum script runtime reached. During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.11/dist-packages/geckolib/async_spa.py", line 367, in connect await self._connect() File "/usr/local/lib/python3.11/dist-packages/geckolib/async_spa.py", line 239, in _connect config_file_handler = await self._protocol.get( ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.11/dist-packages/geckolib/driver/async_udp_protocol.py", line 146, in get await config_sleep(GeckoConfig.PAUSE_BETWEEN_RETRIES_IN_SECONDS) File "/usr/local/lib/python3.11/dist-packages/geckolib/config.py", line 105, in config_sleep await asyncio.wait([ConfigChange], timeout=delay) File "/usr/lib/python3.11/asyncio/tasks.py", line 418, in wait return await _wait(fs, timeout, return_when, loop) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/asyncio/tasks.py", line 525, in _wait await waiter asyncio.exceptions.CancelledError Timed out: Maximum script runtime reached.
                                  Kannst Du damit zufällig was anfangen?
                                    @rrov1
                                    rrov1R Offline
                                    rrov1R Offline
                                    rrov1
                                    #169
                                    @stefan-berlin1 Hallo, "Timed out: Maximum script runtime reached." ist eine Sicherheitsmaßnahme in den Python-Skripten. Es gibt Situationen wo die geckolib nicht mit dem SpaController kommunizieren kann und dann "hängen bleibt". Da die Scripte aller 30 Sekunden aufgerufen werden, wäre das wie das Märchen vom süßen Brei. Es würden schnell, immer mehr Python-Prozesse gestartet die nie beendet werden, die irgendwann den ioBroker-Host vollstopfen. Um das zu verhindern, ist der Timeout nach 90 Sekunden eingebaut.
                                    Jetzt wäre meine Frage, wie oft tritt der Fehler auf? 1-10x am Tag -> ignorieren. Häufiger -> da müssen wir die Ursache ermitteln.
                                    rrov1
                                    • rrov1R rrov1
                                      rrov1
                                      Stefan-Berlin1
                                      #170
                                      @rrov1
                                      Sorry, hatte ich nicht gesehen das Du geantwortet hast. Ich war etwas beschäftigt, jetzt wollte ich nachdem ich die Daten Abfrage auch steuern. Die Pumpen kann ich anschalten, sowie Licht.
                                      Sag mal ich hab echtes Problem die Temperatur anzusteuern.
                                      Ich versuche es erstmal über den Browser:
                                      http://iobroker:****/set/javascript.0.Datenpunkte.SwimSpa.0.ZielTemperatur?value=37,5&ack=true
                                      Ich mache sogar bestätigen - trotzdem nimmt er es nur kurz an im IO Brocker Objekt. Trägt es ein es steht grün da und kurz danach geht es auf rot und ist wieder zurück geändert....
                                      Der Punkt: javascript.0.Datenpunkte.SwimSpa.0.EchteZielTemperatur
                                      dieser ist ja schreibgeschützt.
                                      funkt da das script rein?
                                      Hab alles an bis auf das script : AutomatictargetTemp
                                      Was mache ich falsch?
                                      LG Stefan
                                        @rrov1
                                        LG Stefan
                                        rrov1R Offline
                                        rrov1R Offline
                                        rrov1
                                        #171
                                        @stefan-berlin1 said in Steuerung Gecko in Touch 2 per iob möglich? (Wellis):
                                        Hallo Stefan,
                                        bitte auf keinen Fall ack=true verwenden. In der Entwicklerdoku steht:
                                        ack - Flag indicating that the value has been acknowledged by the target system
                                        d.h. nur meine Scripte nutzen ack=true, wenn ich sicher bin, dass der SpaController den Wert übernommen hat. Meine Scripte reagieren auch nicht, wenn ack=true, auch VIS-Controls setzen den Wert ausschließlich mit ack=false.
                                        Als nächste ändere mal die Zieltemperatur und prüfe danach das ioBroker-Log. Filter setzen:
                                        • Adapter: javascript und
                                        • Message: TargetTemp
                                        Es müssten dann 3 Einträge zu sehen sein:
                                        Ist dem so?
                                        • rrov1R rrov1
                                          Hallo Stefan,
                                          Ist dem so?
                                          Stefan-Berlin1
                                          #172
                                          @rrov1
                                          OK dann schaue ich mal ob das im Log kommt.
                                          Muss target temp Script dann an sein?
                                          Ja ich versucht mit ack weil er es zwar eingetragen hat aber es ist nie drin geblieben.
                                          Aber der Datenpunkt ist richtig zur Setzung der Temperatur ja?
                                          Ich teste es heute Abend mal.
                                          Für die PV überschuss programmierung hatte ich auch alles fertig. Ist quasi nur noch der heiz Befehl offen bzw. Die Temperatur Anhebung.
