  4. Adapter vollständig deinstallieren...
27 Beiträge 3 Kommentatoren 2.9k Aufrufe 2 Beobachtet
  • G guitardoc
    iobroker.inst@3.0.0 /opt/iobroker
    +-- eufy-security-client@3.0.0 (git+ssh://git@github.com/bropat/eufy-security-client.git#2c376bc8889b1f92961289b96a7bc667deda8609)
    +-- iobroker.admin@6.13.16
    +-- iobroker.alias-manager@1.2.6
    +-- iobroker.backitup@2.11.0
    +-- iobroker.cloud@5.0.1
    +-- iobroker.discovery@4.4.0
    +-- iobroker.echarts@1.7.2
    +-- iobroker.eusec@1.2.1
    +-- iobroker.feiertage@1.2.0
    +-- iobroker.followthesun@0.5.0
    +-- iobroker.homeconnect@1.3.0
    +-- iobroker.hydrawise@1.0.0
    +-- iobroker.javascript@8.0.3 (git+ssh://git@github.com/ioBroker/ioBroker.javascript.git#34769285d99d2b547c039b27e7522d02fac6434e)
    +-- iobroker.js-controller@5.0.19
    +-- iobroker.logparser@2.2.2
    +-- iobroker.modbus@6.1.0
    +-- iobroker.mqtt@5.2.0
    +-- iobroker.pvforecast@2.9.1
    +-- iobroker.shelly@6.9.0
    +-- iobroker.shuttercontrol@1.7.0
    +-- iobroker.socketio@6.7.0
    +-- iobroker.solaredge@1.3.0
    +-- iobroker.sonoff@3.0.3
    +-- iobroker.sql@2.2.0
    +-- iobroker.telegram@3.2.1
    +-- iobroker.tuya@3.15.0
    +-- iobroker.viessmannapi@2.3.0
    +-- iobroker.vis-map@1.0.5
    +-- iobroker.vis-materialdesign@0.5.9
    +-- iobroker.vis@1.5.4
    +-- iobroker.vw-connect@0.6.0 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#1bea7002b834d672f998717c2232223d4d1d13af)
    +-- iobroker.weatherunderground@3.7.0
    +-- iobroker.web@6.2.5
    +-- iobroker.ws@2.6.1
    +-- iobroker.yahka@1.0.3
    `-- iobroker.zigbee@1.10.3
    @guitardoc
    Der hat auf der Ebene nix verloren.
    npm uninstall eufy-security-client
    G 1 Antwort Letzte Antwort
      @guitardoc
      guitardoc
      @thomas-braun said in Adapter vollständig deinstallieren...:
      OK, da war er weg. Dann noch mal neu die Installation versuchen?
      • G guitardoc
        @guitardoc
        Starte den eigentlichen Adapter mal neu. Meldungen aus dem log dann hier rein.
        iob logs --watch
          @guitardoc
          iob logs --watch
          guitardoc
          schrieb am zuletzt editiert von guitardoc
          2024-05-12 08:47:25.761  - info: eusec.0 (25157) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
          2024-05-12 08:47:27.894  - info: eusec.0 (25157) Connected to station T8010P2320100018 on host 192.168.188.100 and port 21399
          2024-05-12 08:47:27.910  - info: eusec.0 (25157) Connected to station T8010N2320201304 on host 192.168.188.103 and port 21025
          2024-05-12 08:47:28.410  - error: eusec.0 (25157) Station: T8010N2320201304 command CMD_SDINFO_EX failed with error: undefined (-148)
          2024-05-12 08:47:28.417  - error: eusec.0 (25157) Station: T8010P2320100018 command CMD_SDINFO_EX failed with error: undefined (-148)
          2024-05-12 08:47:28.885  - error: eusec.0 (25157) onStationDatabaseQueryLatest Error [{"error":{"message":"DeviceNotFoundError: Device doesn't exists","context":{"device":"T8114P02195250D1"},"stacktrace":"DeviceNotFoundError: Device doesn't exists\n    at EufySecurity.getDevice (/opt/iobroker/node_modules/iobroker.eusec/node_modules/eufy-security-client/build/eufysecurity.js:372:15)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)"},"stationSN":"T8010P2320100018","returnCode":0}]
          2024-05-12 08:47:28.961  - info: eusec.0 (25157) go2rtc started: 08:47:28.961 INF go2rtc version 1.8.5 linux/amd64
          2024-05-12 08:47:28.961  - info: eusec.0 (25157) go2rtc started: 08:47:28.961 INF [api] listen addr=:1984
          2024-05-12 08:47:28.962  - info: eusec.0 (25157) go2rtc started: 08:47:28.962 INF [rtsp] listen addr=:8554
          2024-05-12 08:47:28.962  - info: eusec.0 (25157) go2rtc started: 08:47:28.962 INF [webrtc] listen addr=:8555
          2024-05-12 08:47:29.701  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0219521BCE.recording_clip_length" has value "0" less than min "5"
          2024-05-12 08:47:29.702  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0219521D94.recording_clip_length" has value "0" less than min "5"
          2024-05-12 08:47:29.703  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010P2320100018.cameras.T8114P0220032A09.recording_clip_length" has value "0" less than min "5"
          2024-05-12 08:47:29.703  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010N2320201304.cameras.T8114P0219522104.recording_clip_length" has value "0" less than min "5"
          2024-05-12 08:47:29.704  - warn: eusec.0 (25157) State value to set for "eusec.0.T8010N2320201304.cameras.T8114P0219524FBF.recording_clip_length" has value "0" less than min "5"
          2024-05-12 08:47:45.315  - info: eusec.0 (25157) Push notification connection successfully established
          Das ist das Protokoll nach dem Neustart des Adapters in der offiziellen Version 1.2.1. Der Fehler
          kommt dann in unregelmäßigen Abständen immer wieder, deswegen war die Empfehlung, die Version 1.3.0 aus dem Developer Branch zu installieren. Das hab ich jetzt mal getan, und dann kommen die folgenden Fehler:
          2024-05-12 09:30:26.409  - info: eusec.0 (25536) starting. Version 1.3.0 (non-npm: bropat/ioBroker.eusec#develop) in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
          2024-05-12 09:30:26.822  - info: eusec.0 (25536) Got terminate signal TERMINATE_YOURSELF
          2024-05-12 09:30:26.827  - warn: web.0 (25521) Terminated (-100): Without reason
          2024-05-12 09:30:26.827  - warn: eusec.0 (25536) Required fix to use livestreaming with this version of Node.js (CVE-2023-46809) applied. Restart of the adapter initiated to activate the fix.
          2024-05-12 09:30:26.827  - warn: eusec.0 (25536) Restart initiated
          2024-05-12 09:30:26.887  - info: eusec.0 (25536) terminating
          2024-05-12 09:30:26.887  - info: eusec.0 (25536) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-05-12 09:30:27.323  - info: eusec.0 (25536) terminating
          2024-05-12 09:30:27.331  - warn: web.0 (25521) setTimeout called, but adapter is shutting down
          2024-05-12 09:30:29.126  - error: web.0 (25551) Cannot start extension "eusec.0": Error: Cannot find module 'iobroker.eusec/build/lib/web.js'
          Require stack:
          - /opt/iobroker/node_modules/iobroker.web/main.js
          2024-05-12 09:30:30.642  - info: eusec.0 (25566) starting. Version 1.3.0 (non-npm: bropat/ioBroker.eusec#develop) in /opt/iobroker/node_modules/iobroker.eusec, node: v18.20.2, js-controller: 5.0.19
          2024-05-12 09:30:31.056  - warn: eusec.0 (25566) Migrated configuration files to new location (needs restart). Restart of the adapter initiated.
          2024-05-12 09:30:31.056  - warn: eusec.0 (25566) Restart initiated
          2024-05-12 09:30:31.063  - info: eusec.0 (25566) terminating
          2024-05-12 09:30:31.064  - info: eusec.0 (25566) Terminated (NO_ERROR): Without reason
          2024-05-12 09:30:31.559  - info: eusec.0 (25566) terminating
          Ich bekomme die Version nicht zum Laufen...
          Edit: Ich werd verrückt. Hab den Adapter in Version 1.3.0 noch mal neu gestartet und jetzt läuft er. Hurra!!!!
          • G guitardoc
            Require stack:
            @guitardoc
            Insgesamt scheinst du aber falsch zu installieren.
            GitHub/'die Katze' ist keine reguläre Installationsweise. Pick den vw-connect und den javascript-Adapter aus dem Beta-Repository, wenn du testen willst. Ansonsten ist das stable-Repo dein erster Anlaufpunkt.
              @guitardoc
              guitardoc
              Was ist da genau der Unterschied? Hab mir da nie groß Gedanken drüber gemacht... Von der Katze ging es immer schneller, beim Beta-Repo muss man immer erst aufwändig die Repos umstellen, oder gibt es da eine Abkürzung?
              • G guitardoc
                @guitardoc sagte in Adapter vollständig deinstallieren...:
                Der Unterschied ist, dass die räudige Katze immer 'irgendeinen' Code anschleppt. Was halt so gerade im GitHub herumliegt. Über das Beta-Repo sind zumindest rudimentäre Tests gelaufen und es sind dann definierte Versionsstände.
                • G guitardoc
                  @guitardoc
                  'Abkürzung':
                  Den Reiter 'npm' benutzen:
                    guitardoc
                    @thomas-braun Wenn ich Beta als Repo auswähle
                    dann erhalte ich sogar noch geringere Versionsstände als bei Stable? Oder hab ich nicht das richtige Verzeichnis?
                    • G guitardoc
                      @guitardoc
                      iob update
                      iob repo list
                        @guitardoc
                        iob update
                        iob repo list
                        guitardoc
                        iob repo list
                        mn@iobroker:~$ iob update
                        Used repository: stable
                        Adapter    "admin"        : 6.13.16  , installed 6.13.16
                        Adapter    "alias-manager": 1.2.6    , installed 1.2.6
                        Adapter    "backitup"     : 2.11.0   , installed 2.11.0
                        Adapter    "discovery"    : 4.4.0    , installed 4.4.0
                        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
                        Adapter    "eusec"        : 1.2.1    , installed 1.3.0
                        Adapter    "feiertage"    : 1.2.0    , installed 1.2.0
                        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                        Adapter    "hydrawise"    : 1.0.0    , installed 1.0.0
                        Adapter    "javascript"   : 7.8.0    , installed 8.0.3
                        Controller "js-controller": 5.0.19   , installed 5.0.19
                        Adapter    "logparser"    : 2.2.2    , installed 2.2.2
                        Adapter    "modbus"       : 6.1.0    , installed 6.1.0
                        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
                        Adapter    "shelly"       : 6.9.0    , installed 6.9.0
                        Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
                        Adapter    "socketio"     : 6.7.0    , installed 6.7.0
                        Adapter    "solaredge"    : 1.3.0    , installed 1.3.0
                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                        Adapter    "telegram"     : 3.2.1    , installed 3.2.1
                        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                        Adapter    "vis"          : 1.5.4    , installed 1.5.4
                        Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Adapter    "web"          : 6.2.5    , installed 6.2.5
                        Adapter    "ws"           : 2.6.1    , installed 2.6.1
                        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                        Adapter    "zigbee"       : 1.10.3   , installed 1.10.3
                        mn@iobroker:~$ iob repo list
                        stable        : https://download.iobroker.net/sources-dist.json
                        beta          : https://download.iobroker.net/sources-dist-latest.json
                        live-stable   : http://iobroker.live/repo/sources-dist.json
                        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
                        Active repo(s): stable
                        • G guitardoc
                          iob repo list
                            guitardoc
                            @thomas-braun Ja, ich hatte wieder umgestellt. Nach dem ioB Update unter Beta zeigt er die richtigen Versionsstände:
                            Used repository: beta
                            Adapter    "admin"        : 6.17.6   , installed 6.13.16 [Updatable]
                            Adapter    "discovery"    : 4.5.0    , installed 4.4.0  [Updatable]
                            Adapter    "homeconnect"  : 1.4.0    , installed 1.3.0  [Updatable]
                            Adapter    "javascript"   : 8.3.0    , installed 8.0.3  [Updatable]
                            Adapter    "modbus"       : 6.2.2    , installed 6.1.0  [Updatable]
                            Adapter    "shelly"       : 7.0.0    , installed 6.9.0  [Updatable]
                            Adapter    "solaredge"    : 1.4.1    , installed 1.3.0  [Updatable]
                            Adapter    "viessmannapi" : 2.4.0    , installed 2.3.0  [Updatable]
                            Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
                            Adapter    "vis-map"      : 1.1.0    , installed 1.0.5  [Updatable]
                            Adapter    "vw-connect"   : 0.6.0    , installed 0.6.0
                            Active repo(s): beta
                            mn@iobroker:~$
                            Das ist aber verwirrend, dass man da erst ein ioB update ausführen muss nach der Umstellung der Repos...
                            • G guitardoc
                              mn@iobroker:~$
                              Nee, das ist normal, weil ein 'iob update' halt den Inhalt der Repos aktualisiert und synchronisert und nicht die Adapter, falls du das meinen solltest.
                                guitardoc
                                @thomas-braun Aber müssten nach der Umstellung des Repos von Stable auf Beta nicht gleich die Beta-Versionsnummern der Adapter angezeigt werden? Ohne ioB update waren die bei mir in Beta ja viel niedriger als in Stable (siehe Screenshots oben).
                                • G guitardoc
                                  Nein, nach der Umstellung muss zwingend das Repo aktualisiert werden. Halt per iob update
                                    guitardoc
                                    @thomas-braun OK, vielleicht könnte man das als Hinweis mit in die repository-Seite aufnehmen? Viele Anwender werden das nicht wissen und ich hab das in drei Monaten bestimmt auch wieder vergessen... :-)
                                    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                                    • G guitardoc
                                      @guitardoc
                                      Ist halt Basis-Wissen. Das Update deines Linux-Systems funktioniert ja genauso.
                                      sudo apt update aktualisiert das Inhaltsverzeichnis, sudo apt upgrade aktualisiert die Softwarepakete.
                                      • G guitardoc
                                        Ist aber auch wurscht, weil du das Repo am besten eh auf stable setzt und von beta oder gar alpha-Versionen besser die Finger lässt. Und wenn es schon was unstabiles sein muss, dann pick eine Beta-Version über den Reiter 'npm'.
                                          @guitardoc
                                          guitardoc
                                          @thomas-braun Najaaaaa, der Vergleich passt nicht ganz. sudo apt update aktualisiert das Inhaltsverzeichnis, sudo apt upgrade aktualisiert die Pakete.
                                          Hier stellt aber Repo auf beta erst mal nur das Repo um, iob update aktualisiert dann erst mal nur die Versionsstände in der Adapterliste und erst beim Klick auf den Pfeil wird der Adapter tatsächlich aktualisiert. Sind also drei Schritte notwendig. Mir hat sich das nicht gleich erschlossen, dass ich das so machen muss, aber ich bin auch kein Linux-Insider, nur "normaler" Anwender des ioB... Ich vermute, dass das vielen anderen Anwendern auch so gehen könnte.
