    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • MichaelFM MichaelF
    @tt-tom said in SONOFF NSPanel mit Lovelace UI:
    @michaelf
    Kannst du bitte mal im Script diese Funktion suchen und hinter if (result != undefined) {diese Zeile
    log(MQTT-PORT-Check Result + JSON.stringify(result)); einfügen, siehe unten Zeile 18. dann mal die Ausgabe posten, aber den Portcheck wieder einschalten.
    async function CheckMQTTPorts() {
        try {
            let instanceName: string = config.panelRecvTopic.substring(0, 6);
            if (isSetOptionActive) {
                await createStateAsync(NSPanel_Path + 'Config.MQTT.portCheck', true, { type: 'boolean', write: true });
                setObject(AliasPath + 'Config.MQTT.portCheck', { type: 'channel', common: { role: 'socket', name: 'mqttPortCheck' }, native: {} });
                await createAliasAsync(AliasPath + 'Config.MQTT.portCheck.ACTUAL', NSPanel_Path + 'Config.MQTT.portCheck', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'ACTUAL' });
                await createAliasAsync(AliasPath + 'Config.MQTT.portCheck.SET', NSPanel_Path + 'Config.MQTT.portCheck', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'SET' });
            if (getState(NSPanel_Path + 'Config.MQTT.portCheck').val) {
                let adapterArray: any = [];
                let portArray: any = [];
                exec('iob l i --port --enabled', async (error, result, stderr) => {
                    if (error == null) {
                            log(`MQTT-PORT-Check Result ` + JSON.stringify(result));
                            log('Start MQTT-Port-Check -------------------------------------', 'info');
                            let resultString1 = result.split('+');
                            for (let i: number = 1; i < resultString1.length - 1; i++) {
                                let resultString2: any = resultString1[i].split(':')
                                let adapterInstanceName: string = resultString2[0].substring(16);
                                let adapterInstancePort: string = resultString2[3].substring(1, 5);
                                log('-- ' + adapterInstanceName + ' - ' + adapterInstancePort, 'info');
                                adapterArray[i] = adapterInstanceName.trim();
                                portArray[i] = adapterInstancePort.trim();
    Der Log :
    javascript.0
    2024-05-05 11:48:51.835	error	at ChildProcess.emit (node:domain:489:12)
    javascript.0
    2024-05-05 11:48:51.835	error	at ChildProcess.emit (node:events:517:28)
    javascript.0
    2024-05-05 11:48:51.835	error	at ChildProcess.exithandler (node:child_process:414:7)
    javascript.0
    2024-05-05 11:48:51.834	error	at script.js.common.NsPanelWz:1276:100
    javascript.0
    2024-05-05 11:48:51.834	error	at __awaiter (script.js.common.NsPanelWz:4:12)
    javascript.0
    2024-05-05 11:48:51.834	error	at new Promise (<anonymous>)
    javascript.0
    2024-05-05 11:48:51.833	error	at script.js.common.NsPanelWz:8:71
    javascript.0
    2024-05-05 11:48:51.833	error	at Object.next (script.js.common.NsPanelWz:14:53)
    javascript.0
    2024-05-05 11:48:51.832	error	at step (script.js.common.NsPanelWz:33:23)
    javascript.0
    2024-05-05 11:48:51.832	error	at script.js.common.NsPanelWz:1287:84
    javascript.0
    2024-05-05 11:48:51.831	error	script.js.common.NsPanelWz: TypeError: Cannot read properties of undefined (reading 'substring')
    javascript.0
    2024-05-05 11:48:51.820	info	script.js.common.NsPanelWz: -- sonoff.0 - 1883
    javascript.0
    2024-05-05 11:48:51.820	info	script.js.common.NsPanelWz: -- simple-api.0 - 8087
    javascript.0
    2024-05-05 11:48:51.819	info	script.js.common.NsPanelWz: -- sainlogic.0 - 4500
    javascript.0
    2024-05-05 11:48:51.819	info	script.js.common.NsPanelWz: -- pioneer_sc_vsx.0 - 23
    javascript.0
    2024-05-05 11:48:51.818	info	script.js.common.NsPanelWz: -- mqtt.3 - 1886
    javascript.0
    2024-05-05 11:48:51.818	info	script.js.common.NsPanelWz: -- mqtt.1 - 1883
    javascript.0
    2024-05-05 11:48:51.818	info	script.js.common.NsPanelWz: -- mihome-vacuum.0 - 5432
    javascript.0
    2024-05-05 11:48:51.817	info	script.js.common.NsPanelWz: -- influxdb.1 - 8086
    javascript.0
    2024-05-05 11:48:51.817	info	script.js.common.NsPanelWz: -- influxdb.0 - 8086
    javascript.0
    2024-05-05 11:48:51.816	info	script.js.common.NsPanelWz: -- hm-rpc.3 - 0
    javascript.0
    2024-05-05 11:48:51.816	info	script.js.common.NsPanelWz: -- hm-rpc.2 - 0
    javascript.0
    2024-05-05 11:48:51.816	info	script.js.common.NsPanelWz: -- hm-rpc.1 - 0
    javascript.0
    2024-05-05 11:48:51.815	info	script.js.common.NsPanelWz: -- hm-rpc.0 - 0
    javascript.0
    2024-05-05 11:48:51.814	info	script.js.common.NsPanelWz: -- admin.0 - 8081
    javascript.0
    2024-05-05 11:48:51.814	info	script.js.common.NsPanelWz: Start MQTT-Port-Check -------------------------------------
    javascript.0
    2024-05-05 11:48:51.813	info	script.js.common.NsPanelWz: MQTT-PORT-Check Result "+ system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin\n+ system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0\n+ system.adapter.hm-rpc.1 : hm-rpc : iobroker - enabled, port: 0\n+ system.adapter.hm-rpc.2 : hm-rpc : iobroker - enabled, port: 0\n+ system.adapter.hm-rpc.3 : hm-rpc : iobroker - enabled, port: 0\n+ system.adapter.influxdb.0 : influxdb : iobroker - enabled, port: 8086\n+ system.adapter.influxdb.1 : influxdb : iobroker - enabled, port: 8086\n+ system.adapter.mihome-vacuum.0 : mihome-vacuum : IoBroker64Bit - enabled, port: 54321\n+ system.adapter.mqtt.1 : mqtt : iobroker - enabled, port: 1883, bind: 0.0.0.0\n+ system.adapter.mqtt.3 : mqtt : iobroker - enabled, port: 1886, bind: 192.168.178.69\n+ system.adapter.pioneer_sc_vsx.0 : pioneer_sc_vsx : iobroker - enabled, port: 23\n+ system.adapter.sainlogic.0 : sainlogic : iobroker - enabled, port: 45000, bind: 192.168.178.69\n+ system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin\n+ system.adapter.sonoff.0 : sonoff : IoBroker64Bit - enabled, port: 1883, bind: 0.0.0.0\n+ system.adapter.sql.0 : sql : iobroker - enabled\n+ system.adapter.synology.0 : synology : iobroker - enabled, port: 5000\n+ system.adapter.synology.1 : synology : iobroker - enabled, port: 5000\n+ system.adapter.telegram.0 : telegram : iobroker - enabled, port: 8443, bind: 0.0.0.0\n+ system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin\n\n+ instance is alive\n"
    javascript.0
    2024-05-05 11:48:45.347	info	script.js.common.NsPanelWz: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-05 11:48:45.346	info	script.js.common.NsPanelWz: Desired TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-05 11:48:45.332	info	script.js.common.NsPanelWz: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-05 11:48:45.331	info	script.js.common.NsPanelWz: Desired TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-05 11:48:43.925	info	script.js.common.NsPanelWz: Debug mode disabled
    javascript.0
    2024-05-05 11:48:43.577	info	script.js.common.NsPanelWz: Installed TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-05 11:48:43.576	info	script.js.common.NsPanelWz: Desired TFT Firmware: 53 / v4.3.3
    javascript.0
    2024-05-05 11:48:42.445	info	script.js.common.NsPanelWz: No Updates for NSPanel available
    javascript.0
    2024-05-05 11:48:42.437	info	script.js.common.NsPanelWz: registered 32 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2024-05-05 11:48:42.436	info	script.js.common.NsPanelWz: No Updates for NSPanel available
    javascript.0
    2024-05-05 11:48:42.416	info	script.js.common.NsPanelWz: weather alias for accuweather.0. already exists
    javascript.0
    2024-05-05 11:48:42.411	info	script.js.common.NsPanelWz: setObjects enabled - create Alias Channels possible
    javascript.0
    2024-05-05 11:48:42.114	info	script.js.common.NsPanelWz: source code did not change, using cached compilation result...
    javascript.0
    2024-05-05 11:48:40.470	info	script.js.common.NsPanelWz: compiling TypeScript source...
    admin.0
    2024-05-05 11:48:40.046	info	<== Disconnect system.user.admin from ::ffff:192.168.178.52 javascript
    javascript.0
    2024-05-05 11:48:38.935	info	Stop script script.js.common.NsPanelWz
    TT-Tom
    #5690
    @michaelf
    der SQL liefert kein Port, darum läuft die Abfrage auf einen Fehler. Werde mal deine Daten nutzen für ein Fix. aktuell hilft da nur den check ausschalten, wir melden uns wenn der fix verfügbar ist.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    MichaelFM 1 Antwort Letzte Antwort
    • L lustig29
      @tt-tom So???
      const jsonEventName1: string = 'Graue Tonne'; // Vergleichstring für Schwarze Tonne
      const customEventName1: string = 'Graue Tonne';        // benutzerdefinierter Text für schwarze Tonne
      const jsonEventName2: string = 'Gelbe Tonne'; // Vergleichstring für Gelbe Tonne / Sack
      const customEventName2: string = 'Gelbe Tonne';        // benutzerdefinierter Text für gelbe Tonne
      const jsonEventName3: string = 'Altpapier';    // Vergleichstring für Blaue Tonne
      const customEventName3: string = 'Altpapier';       // benutzerdefinierter Text für blaue Tonne
      const jsonEventName4: string = 'Grüne Tonne';   // Vergleichstring für Braune Tonne
      const customEventName4: string = 'Grüne Tonne';        // benutzerdefinierter Text für braune Tonne
      const jsonEventName5: string = 'Treppe';   // Vergleichstring für Event 5
      const customEventName5: string = 'Besen schwingen';        // benutzerdefinierter Text für Event 5
      const jsonEventName6: string = '';   // Vergleichstring für Event 6
      const customEventName6: string = '';        // benutzerdefinierter Text für Event 6
      TT-Tom
      #5691
      @lustig29
      nein, du musst die jsonEventNameX Parameter anpassen.
      const jsonEventName1: string = 'Restmüll';
      Die customEventNameX sind alternativ Texte für die Anzeige auf dem Panel, siehe Event5. Dort wird nach Treppe im Kalender gesucht und auf dem Panel Besen schwingen angezeigt.
      Gruß Tom
      Public Transport
      L 1 Antwort Letzte Antwort
      • T TT-Tom
        @michaelf
        MichaelFM Online
        MichaelFM Online
        MichaelF
        #5692
        @michaelf
        Super danke.
        • T TT-Tom
          @lustig29
          lustig29
          #5693
          @tt-tom Super, danke. Das war es
          • L Offline
            lustig29
            #5694
            Ich möchte gerne mein Nuki Türschloss in diese Card intigrieren. Kann mir jemand dabei helfen?
            let Garage: PageType =
                'type': 'cardGrid',
                'heading': 'Übersicht',
                'useColor': true,
                'subPage': false,
                'items': [
                    { id: 'alias.0.Garagentor', icon: 'garage', icon2: 'garage-open', offColor: MSRed, onColor: MSGreen, name: 'Garagentor'},
                    { id: 'alias.0.Alias_Geräte.Alle_Rollos', icon: 'roller-shade', icon2: 'roller-shade-closed', offColor: MSRed, onColor: MSGreen, name: 'Alle Rollos'},
              "type": "state",
              "common": {
                "name": "Tür auf-/abschließen",
                "type": "boolean",
                "write": true,
                "role": "switch.lock.door"
              "native": {},
              "from": "system.adapter.nuki.0",
              "user": "system.user.admin",
              "ts": 1714916320263,
              "_id": "nuki.0.607002684.actions.lockAction",
              "acl": {
                "object": 1636,
                "state": 1636,
                "owner": "system.user.admin",
            • L lustig29
                  'type': 'cardGrid',
                  'useColor': true,
                  'subPage': false,
                  'items': [
                "type": "state",
                "common": {
                  "type": "boolean",
                  "write": true,
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636,
              TT-Tom
              #5695
              @lustig29
              Hast du schon einen Alias für den Nuki angelegt.
              Hier kannst du nachschauen. https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#verschluss-channel-lock
              Gruß Tom
              Public Transport
                @michaelf
                Super danke.
                TT-Tom
                #5696
                @michaelf
                probiere bitte mal den Fix der DEV Version, danke.
                https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.ts
                Gruß Tom
                Public Transport
                MichaelFM 2 Antworten Letzte Antwort
                • T TT-Tom
                  @lustig29
                  lustig29
                  #5697
                  @tt-tom Danke. Hat schon mal soweit super geklappt. Schloss schließt und öffnet über das Ns Panel. Jetzt muss ich nur noch den Status (Offen/Geschlossen) im Alias irgendwie angeben.
                  Kannst du mir da bitte nochmal kurz helfen?
                  Das ist der Datenpunkt vom Nuki.
                    "type": "state",
                    "common": {
                      "name": "Aktion",
                      "type": "number",
                      "states": {
                        "0": "",
                        "1": "unlock",
                        "2": "lock",
                        "3": "unlatch",
                        "4": "lock‘n’go",
                        "5": "lock‘n’go with unlatch"
                      "role": "value"
                    "native": {},
                    "_id": "nuki.0.607002684.actions.action",
                    "acl": {
                      "object": 1636,
                      "state": 1636,
                    bakerman23
                    #5698
                    Sorry schonmal. Mein Problem kam sicherlich schon tausend mal.
                    Ich habe das NSPanel jetzt soweit eingerichtet, daß ich eine eigene Seite erstellen kann.
                    Egal, was ich aus der Beispielseite unter
                    //-- Start for your own pages -- some self-defined aliases required ----------------
                    eintrage, nach dem Starten des Scipts erscheint auf dem NSPanel immer nur die Serviceseite.
                    Das Script läuft ohne Fehler durch.
                    • B bakerman23
                      Marc BergM Online
                      Marc BergM Online
                      Marc Berg
                      #5699
                      @bakerman23 sagte in SONOFF NSPanel mit Lovelace UI:
                      Ja, hier z.B.:
                      https://forum.iobroker.net/post/1153993
                      • Marc BergM Marc Berg
                        Ja, hier z.B.:
                        bakerman23
                        #5700
                        @marc-berg oh Gott. So dumm. Jetzt geht es.
                        Ich bin allerdings auch der Meinung, das es nicht im Wiki steht.
                        H T 2 Antworten Letzte Antwort
                        • B bakerman23
                          H Nicht stören
                          H Nicht stören
                          Hansi1234
                          #5701
                          @bakerman23 said in SONOFF NSPanel mit Lovelace UI:
                          Jep, daran hing ich auch ewig
                          • B bakerman23
                            TT-Tom
                            #5702
                            @bakerman23
                            Doch hier im letzten Absatz. Vielleicht etwas versteckt. @Kuckuckmann kann da bestimmt, noch ein Beispiel einfügen. 😉
                            Gruß Tom
                            Public Transport
                            • L lustig29
                                "type": "state",
                                "common": {
                                  "name": "Aktion",
                                  "type": "number",
                                  "states": {
                                    "0": "",
                                    "1": "unlock",
                                    "2": "lock",
                                    "3": "unlatch",
                                    "4": "lock‘n’go",
                                  "role": "value"
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636,
                              TT-Tom
                              #5703
                              @lustig29 wie sieht dein Alias Datenpunkt jetzt aus??
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                lustig29
                                #5704
                                @tt-tom
                                  "_id": "alias.0.Alias_Geräte.Nuki_Garagentür.ACTUAL",
                                  "native": {},
                                  "type": "state",
                                  "common": {
                                    "alias": {
                                      "id": "nuki.0.607002684.actions.action"
                                    "name": "ACTUAL",
                                    "role": "state",
                                    "write": false,
                                    "type": "number"
                                  "acl": {
                                    "object": 1636,
                                    "state": 1636,
                                  "ts": 1715084132432
                                • L lustig29
                                  @tt-tom
                                    "native": {},
                                    "type": "state",
                                    "common": {
                                      "alias": {
                                      "name": "ACTUAL",
                                      "role": "state",
                                      "write": false,
                                      "type": "number"
                                    "acl": {
                                      "object": 1636,
                                      "state": 1636,
                                    "ts": 1715084132432
                                  TT-Tom
                                  #5705
                                  @lustig29
                                  versuche mal das im alias
                                  und setzte den Typ auf boolean
                                  Gruß Tom
                                  Public Transport
                                  • T TT-Tom
                                    @lustig29
                                    lustig29
                                    #5706
                                    @tt-tom Jetzt bekomme ich nur den Status "geöffnete Tür" angezeigt. Vorhin war es andersrum.
                                    • T TT-Tom
                                      @michaelf
                                      MichaelFM Online
                                      MichaelFM Online
                                      MichaelF
                                      #5707
                                      @michaelf
                                      Hi, das ging ja schnell. Kann ich erst am we testen bin leider unterwegs.
                                      Grüsse
                                        @michaelf
                                        Grüsse
                                        lustig29
                                        #5708
                                        Da ich jetzt doch schon einiges mit dem Ns Panel auch mit Hilfe des Boards realisiert habe, möchte ich gerne meinen Frage nach dem Shelly Dimmer 2 aufgreifen.
                                        Kann mir jemand dabei helfen, bzw. hat jemand zwischenzeitlich sowas schon realisiert?
                                        Das Ns Panel soll hinter einem Shelly Dimmer 2 angeschlossen werden.
                                        • L lustig29
                                          TT-Tom
                                          #5709
                                          @lustig29
                                          Was für Werte stehen denn im Actual, wenn du keine Konvertierung drin hast. Bitte mal zeigen von beiden Stati.
                                          Gruß Tom
                                          Public Transport
