  4. Gelöst: Datenpunkte addieren
    5.2k
44 Beiträge 5 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • C cbrocker
    @mickym
    hey mickym,
    ich versuche mich schon geraume Zeit an dem Flow für die Summe von Datenpunkten.
    Könntest du mir sagen, welche Eigenschaften die nodes haben. Ich komme da nicht weiter.
    vielen Dank.
    https://forum.iobroker.net/assets/uploads/files/1708891083341-838bc0d0-fbe3-456b-abb9-d9bfa831bf5d-image.png
    mickymM Offline
    mickymM Offline
    mickym
    @cbrocker Du liest mit einer list Node einfach mit Wildcard alle untergeordneten Objekte/Datenpunkte mit den Werten.
    Anschließend bildest Du einfach die Summe aus den Werten
    Hier der Flow zum Import:
    [{"id":"7d1e245379d70cc0","type":"inject","z":"289f539dcc33814e","name":"","props":[{"p":"trigger","v":"true","vt":"bool"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":5160,"wires":[["c1364b291413b43e"]]},{"id":"c1364b291413b43e","type":"ioBroker list","z":"289f539dcc33814e","name":"","topic":"0_userdata.0.Test.FritzBox7590.Zähler.*","objType":"state","regex":"","asArray":"true","onlyIDs":"true","withValues":"true","x":380,"y":5160,"wires":[["7ae6b190062293fb","83565c11b43f8064"]]},{"id":"83565c11b43f8064","type":"debug","z":"289f539dcc33814e","name":"Array","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":650,"y":5120,"wires":[]},{"id":"7ae6b190062293fb","type":"change","z":"289f539dcc33814e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(payload.val)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":5160,"wires":[["23d459549a7c4a1e"]]},{"id":"23d459549a7c4a1e","type":"debug","z":"289f539dcc33814e","name":"Summe","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":860,"y":5160,"wires":[]}]
    C 1 Antwort Letzte Antwort
    • mickymM mickym
      cbrocker
      @mickym Hey mickym, danke für die schnelle Reaktion. Cool, daß du gerade auch zufällig vorm PC sitzt :-)
      Ich habe den Flow importiert und angepasst. Funktioniert sehr gut :-)
      Warum ist da aber jetzt ein Array dabei. Bei dem o.g. Beispiel hattest du auch kein Array gezeigt.
      Danke für die prompte Hilfe
      Proxmox Cluster mit ioBroker, Wireguard, HomeAssistant (Testsystem), paperlessNGX, MariaDB, PiHole, Grafana, InfluxDB, 1 x BKW 600 Wp, 2 x BKW 400 Wp, 2 x SolarFlow 800 Pro mit 11,52 kWh Akku und 3,48 kWp, OpenDTU, AhoyDTU, HmIP, Shellys, AVM LAN/WLAN
      • C cbrocker
        mickymM Offline
        mickymM Offline
        mickym
        @cbrocker Die Debug Node dient ja nur zur Veranschaulichung. Das funktioniert natürlich mit einem Array - aber das musst ja nicht ausgeben. Da unten funktioniert das natürlich auch mit einem Array.
        Also wenn du die Debug Node weglässt - siehst das Array gar nicht.
        • mickymM mickym
          cbrocker
          @mickym
          ah, danke.
          Muß mich mal in Node-red reinknien.
          Bisher hatte ich nur 2 Flows, aber diese nur durch Anleitungen angelegt.
          Super, nochmals vielen Dank. Jetzt kann ich da weiter auto-didaktisch rumexperimentieren.
          Schönen Sonntag
          • C cbrocker
            mickymM Offline
            mickymM Offline
            mickym
            @cbrocker Das ist halt die Macht der coolen JSONATA Bibliothek. ;)
            Zum einen dass Du aus einem Array von Objekten easy Arrays beliebiger Eigenschaften extrahieren kannst und diese dann mit einer der Aggregatfunktion aufsummieren kannst.
            https://docs.jsonata.org/aggregation-functions
            • mickymM mickym
              cbrocker
              @mickym
              ja, den großen Nutzen habe ich schon gecheckt, echt der Hammer, was da möglich ist.
              Ist ja mit JS-Blockly viel umständlicher.
              Da kann ich mir nun die Nächte mit Node-Red um die Ohren schlagen :-)
              • C cbrocker
                @mickym
                mickymM Offline
                mickymM Offline
                mickym
                @cbrocker sagte in Gelöst: Datenpunkte addieren:
                @mickym
                Na ja dann gehörst Du zum auserwählten Kreis derjenigen, die das erkannt haben. :) Die Mehrheit puzzelt lieber.
                Und wenn Du Hilfe bei NodeRed brauchst, stehe ich gerne weiter zur Verfügung - auch wenn es sich nur um Verständnisfragen handelt.
                C 2 Antworten Letzte Antwort
                • mickymM mickym
                  @mickym
                  cbrocker
                  @mickym said in Gelöst: Datenpunkte addieren:
                  @mickym
                  Definitiv habe ich das erkannt.
                  Schon bei diesem Beispiel des TE mit einer Summe von mehreren DPs ist das recht schnell erkennbar, was das für ein mächtiges Tool ist.
                  Ich komme gerne auf dein Angebot zurück, vielen Dank.
                  • mickymM mickym
                    @mickym
                    cbrocker
                    @mickym
                    hey, schon eine weitere Frage.
                    Kann man in einem Flow-Blatt mehrere Nodes-Reihen laufen lassen?
                    • C cbrocker
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @cbrocker Klar - soviele Du willst. Flows dienen nur der thematischen Untergliederung, aber gibt keine Restriktionen.
                      Ansonsten gibt es im Kontext halt Variablen, die entweder für function Nodes, Flows oder global gültig sind.
                      Beispiel:
                      Hier laufen zum Beispiele alle Flows - die Alarmzustände melden.
                      • mickymM mickym
                        Beispiel:
                        cbrocker
                        @mickym ah, verstehe. ist ja cool, mit den globalen Variablen. Danke.
                        Wow, du hast ja echt alles mit Flows laufen. Ist ja der Hammer.
                        Ich habe bisher viel mit Blocklys gemacht, ca. 20-30. Also im Prinzip könnte ich
                        nun alle Blocklys mit Flows machen?
                        • C cbrocker
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @cbrocker Du kannst Flows auch gruppieren um sie als Einheit zu verschieben und mit einer Box zur Markieren und zu beschriften und farblich zu markieren:
                          • C cbrocker
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @cbrocker Ja Du kannst 99% aller Blockies sicher umschreiben. Ist auch eine gute Übung und man sieht beides im Vergleich.
                            Es gibt ein paar Einschränkungen bzgl. wenn Du mit den Aufzählungen (Räumen und Funktionen) arbeitest. Das ist in den iobroker Nodes im Node Red Adapter nicht so gut umgesetzt.
                            Rudimentär kann auch auf die Aufzählungen über die List Node zugreifen, aber man kann zum Beispiel nicht über die Aufzählungen triggern lassen.
                            Inzwischen mit den Wildcards, den Filtermöglichkeiten in den iobroker- In Nodes etc. hast Du aber keine Nachteile mehr.
                            Im Gegenteil zum Beispiel um Objekte in einzelne Datenpunkte zu erstellen, geht viel besser mit NodeRed.
                            Die NodeRed Community ist ja viel größer, als die Blockly Fraktion und wird ja in vielen Iot Systemen oder sogar Stand-alone eingesetzt.
                            Du hast damit auch einen kleinen Webserver mit dem NodeRed Adapter etc.
                            • mickymM mickym
                              cbrocker
                              @mickym
                              ich sitze hier auf der Couch mit offenem Mund 😊
                              echt beeindruckend, was da alles möglich ist.
                              Das ganze SmartHome Universum (ioBroker, HA, usw.) mit all den Aktoren usw. ist so geil,
                              was man da alles machen kann.
                              • C cbrocker
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @cbrocker Ja mit HA habe ich mich auch bissi beschäftigt - aber der iobroker hat mit seiner Objektestruktur, der Datenbank eine einzigartige Stellung.
                                Deswegen finde ich die Kombination von iobroker mit NodeRed auch die gelungenste Kombi. (solange die iobroker Jungs das nicht immer weiter einschränken).
                                Ich habe mich bissi mit HA beschäftigt, das ist OK wenn man vorgefertigte Automationen nutzen will - ansonsten ist das aber alles ziemlich fummelig.
                                • mickymM mickym
                                  cbrocker
                                  @mickym
                                  HA habe ich auch testweise auf dem proxmox laufen zum Rumspielen.
                                  Aber ich habe mich auf ioBroker eingeschossen, da bleibe ich nun dabei.
                                  Ja, die Architektur und Struktur von ioBroker ist schon gut durchdacht.
                                  • C cbrocker
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @cbrocker Als NodeRed Anfänger kannst Du natürlich im Bedarfsfall auch alles mit JS programmieren - wirst Du auch viel im Netz finden. Ich rate Dir aber davon ab, wenn Du die Vorteile von NodeRed der grafischen Programmierung nutzen willst. Du wirst sehen - gerade beim Debuggen oder auch wenn es mal mit der Logik hapert bist du dann unfassbar schnell. Also lass am Anfang Function Nodes mit JS Code erst mal weg - und versuche das immer mit anderen Nodes umzusetzen
                                    Meine Bereitschaft 300 Zeilen Javascript Code durchzuackern ist inzwischen SEHR GERING. Das ist mir alles viel zu umständlich.
                                    In Node Red zerschneidest ein Kabel - machst mal eine Debug Node da und dort hin, kannst mit Inject Nodes Deine Logik prüfen ohne dass Du Deine Hardware quälen musst etc.
                                    • C cbrocker
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @cbrocker Schau Dir mal ein paar meiner Threads an, was mit NodeRed und iobroker in der Kombi möglich ist:
                                      • Hier mal so was ähnliches um Zählerstände zu erfassen: https://forum.iobroker.net/post/1148031
                                      • Sehr beliebte Threads sind die Datum- und Uhrzeitverarbeitung im Vergleich zwischen NodeRed und Blockly:
                                        https://forum.iobroker.net/topic/50086/datum-und-zeitverarbeitung-mit-nodered
                                      • Wetter-APIs direkt zu nutzen: https://forum.iobroker.net/topic/44684/wetter-api-s-mit-nodered-abrufen
                                      • oder auch sehr beliebt für alle die LEIDER sich nicht mit Objekten beschäftigen wollen, wie man automatisiert Objekte in einzelne Datenpunkte zerlegt: https://forum.iobroker.net/topic/43856/json-oder-javascript-objekt-in-iobroker-datenpunkte-zerlegen
                                      • mickymM mickym
                                        cbrocker
                                        @mickym
                                        ich danke dir für die vielen Tipps und Infos.
                                        Die Links schaue ich mir gerne an. Da habe ich jetzt Lust auf mehr. Das macht so viel Spaß, auch wenn man viel rumbasteln/rumprobieren muß. Aber das sind dann alles Erfahrungen.
