  4. Meldungen beim/nach Upgrade
    2.2k
    4.1k
15 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    pi@iobroker-VM03:~$ cd /opt/iobroker
    pi@iobroker-VM03:/opt/iobroker$ npm ls buffer
    [sudo] Passwort für pi:
    iobroker.inst@3.0.0 /opt/iobroker
    ├─┬ iobroker.modbus@6.1.0
    │ └─┬ crc@4.3.2
    │ └── buffer@6.0.3
    ├─┬ iobroker.pollenflug@1.0.6
    │ └─┬ shelly-iot@1.1.2
    │ └─┬ coap@0.26.0
    │ └─┬ bl@5.0.0
    │ └── buffer@6.0.3 deduped
    └─┬ iobroker.rflink@2.1.6
    └─┬ serialport@8.0.8
    └─┬ @serialport/bindings@8.0.8
    └─┬ prebuild-install@5.3.6
    └─┬ tar-fs@2.1.1
    └─┬ tar-stream@2.2.0
    └─┬ bl@4.1.0
    └── buffer@5.7.1
      │ └─┬ crc@4.3.2
      │ └── buffer@6.0.3
      │ └─┬ coap@0.26.0
      │ └─┬ bl@5.0.0
      └─┬ tar-fs@2.1.1
      └─┬ bl@4.1.0
      └── buffer@5.7.1
      sieht jetzt besser aus
      │ └─┬ crc@4.3.2
      │   └── buffer@6.0.3
      │   └─┬ coap@0.26.0
      │     └─┬ bl@5.0.0
              └─┬ tar-fs@2.1.1
                  └─┬ bl@4.1.0
                    └── buffer@5.7.1
        │ └─┬ crc@4.3.2
        │   └── buffer@6.0.3
        │   └─┬ coap@0.26.0
        │     └─┬ bl@5.0.0
                └─┬ tar-fs@2.1.1
                    └─┬ bl@4.1.0
                      └── buffer@5.7.1
        die beiden module gelöscht und neu eingetragen
        i@iobroker-VM03:/opt/iobroker$ npm ls fs
        └─┬ iobroker.javascript@7.8.0
          └── fs@0.0.1-security
        pi@iobroker-VM03:/opt/iobroker$ npm ls dewpoint
          └── dewpoint@1.0.0
            └── dewpoint@1.0.0
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: iobroker-VM03
                   Icon name: computer-vm
                     Chassis: vm
              Virtualization: kvm
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 5.10.0-28-amd64
                Architecture: x86-64
          model name      : Common KVM processor
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : amd64
          Systemuptime and Load:
           17:20:13 up  3:01,  1 user,  load average: 0.07, 0.40, 0.71
          CPU threads: 8
          *** Time and Time Zones ***
                         Local time: Thu 2024-04-11 17:20:13 CEST
                     Universal time: Thu 2024-04-11 15:20:13 UTC
                           RTC time: Thu 2024-04-11 15:20:14
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi cdrom floppy sudo audio dip video plugdev netdev iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            5.9G        3.7G        1.4G        0.0K        831M        2.0G
          Swap:           974M        614M        360M
          Total:          6.9G        4.3G        1.8G
                   5928 M total memory
                   3654 M used memory
                   1166 M active memory
                   2926 M inactive memory
                   1443 M free memory
                    193 M buffer memory
                    638 M swap cache
                    974 M total swap
                    614 M used swap
                    360 M free swap
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  2.9G     0  2.9G   0% /dev
          tmpfs          tmpfs     593M  468K  593M   1% /run
          /dev/sda1      ext4       62G   54G  5.3G  92% /
          tmpfs          tmpfs     2.9G     0  2.9G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     593M     0  593M   0% /run/user/1000
          [Thu Apr 11 14:18:40 2024] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Apr 11 14:18:40 2024] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          2.7G    /var/
          2.3G    /var/log
          817M    /var/log/journal/14d81482e1a64d47a4613cdb6a71c2c7
          288M    /var/cache
          Archived and active journals take up 32.0M in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          47G     /opt/iobroker/iobroker-data/
          46G     /opt/iobroker/iobroker-data/history
          384M    /opt/iobroker/iobroker-data/files
          347M    /opt/iobroker/iobroker-data/backup-objects
          78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
          74M     /opt/iobroker/iobroker-data/states.jsonl
          36M     /opt/iobroker/iobroker-data/objects.jsonl
          25M     /opt/iobroker/iobroker-data/objects.json.migrated
          25M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          USB-Devices by-id:
          find: '/dev/serial/by-id/': No such file or directory
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v18.20.2
          /usr/bin/node           v18.20.2
          /usr/bin/npm            10.5.0
          /usr/bin/npx            10.5.0
          /usr/bin/corepack       0.25.2
          nodejs:
            Installed: 18.20.2-1nodesource1
            Candidate: 18.20.2-1nodesource1
            Version table:
           *** 18.20.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main amd64 Packages
                  500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller:  5.0.19
          admin:          6.13.16
          javascript:     7.8.0
          Adapters from github:   2
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker-VM03                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker-VM03                            -  enabled
            system.adapter.cloud.0                  : cloud                 : iobroker-VM03                            - disabled
            system.adapter.daikin.0                 : daikin                : iobroker-VM03                            - disabled
            system.adapter.daikin.1                 : daikin                : iobroker-VM03                            - disabled
            system.adapter.daikin.2                 : daikin                : iobroker-VM03                            - disabled
            system.adapter.daikin.3                 : daikin                : iobroker-VM03                            - disabled
          + system.adapter.denon.0                  : denon                 : iobroker-VM03                            -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker-VM03                            -  enabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-VM03                            - disabled
          + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker-VM03                            -  enabled
          + system.adapter.energiefluss.0           : energiefluss          : iobroker-VM03                            -  enabled
            system.adapter.feiertage.0              : feiertage             : iobroker-VM03                            -  enabled
            system.adapter.flot.0                   : flot                  : iobroker-VM03                            - disabled
          + system.adapter.fritzbox.0               : fritzbox              : iobroker-VM03                            -  enabled
          + system.adapter.go-e.0                   : go-e                  : iobroker-VM03                            -  enabled
          + system.adapter.harmony.0                : harmony               : iobroker-VM03                            -  enabled
          + system.adapter.history.0                : history               : iobroker-VM03                            -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : iobroker-VM03                            -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-VM03                            -  enabled, port: 0
          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-VM03                            -  enabled, port: 0
          + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-VM03                            -  enabled, port: 0
            system.adapter.ical.0                   : ical                  : iobroker-VM03                            - disabled
            system.adapter.ical.1                   : ical                  : iobroker-VM03                            -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-VM03                            - disabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-VM03                            - disabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker-VM03                            - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker-VM03                            - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-VM03                            -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-VM03                            - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-VM03                            - disabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-VM03                            - disabled
            system.adapter.info.0                   : info                  : iobroker-VM03                            - disabled
          + system.adapter.javascript.0             : javascript            : iobroker-VM03                            -  enabled
          + system.adapter.javascript.1             : javascript            : iobroker-VM03                            -  enabled
            system.adapter.luftdaten.0              : luftdaten             : iobroker-VM03                            -  enabled
          + system.adapter.modbus.0                 : modbus                : tinkerboard                              -  enabled
          + system.adapter.modbus.1                 : modbus                : iobroker-VM03                            -  enabled
          + system.adapter.modbus.2                 : modbus                : tinkerboard                              -  enabled
            system.adapter.modbus.3                 : modbus                : tinkerboard                              - disabled
            system.adapter.modbus.4                 : modbus                : tinkerboard                              - disabled
          + system.adapter.mqtt.0                   : mqtt                  : tinkerboard                              -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.nut.0                    : nut                   : iobroker-VM03                            - disabled
            system.adapter.nut.1                    : nut                   : iobroker-VM03                            - disabled
            system.adapter.onkyo.0                  : onkyo                 : iobroker-VM03                            - disabled
          + system.adapter.opi.0                    : opi                   : tinkerboard                              -  enabled
          + system.adapter.parser.0                 : parser                : iobroker-VM03                            -  enabled
          + system.adapter.pollenflug.0             : pollenflug            : iobroker-VM03                            -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker-VM03                            -  enabled, port: 8006
            system.adapter.renault.0                : renault               : iobroker-VM03                            - disabled
            system.adapter.rflink.0                 : rflink                : iobroker-VM03                            - disabled
            system.adapter.sayit.0                  : sayit                 : iobroker-VM03                            - disabled, port: 0
            system.adapter.scenes.0                 : scenes                : iobroker-VM03                            - disabled
          + system.adapter.sensebox.0               : sensebox              : iobroker-VM03                            -  enabled
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker-VM03                            -  enabled
            system.adapter.simple-api.0             : simple-api            : iobroker-VM03                            - disabled, port: 8087, bind: 192.168.138.91, run as: admin
          + system.adapter.smartmeter.0             : smartmeter            : tinkerboard                              -  enabled
          + system.adapter.snmp.0                   : snmp                  : iobroker-VM03                            -  enabled
            system.adapter.socketio.0               : socketio              : iobroker-VM03                            - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.sonos.0                  : sonos                 : iobroker-VM03                            - disabled
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-VM03                            -  enabled
          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-VM03                            -  enabled
          + system.adapter.tradfri.0                : tradfri               : iobroker-VM03                            -  enabled
            system.adapter.tradfri.1                : tradfri               : iobroker-VM03                            - disabled
          + system.adapter.trashschedule.0          : trashschedule         : iobroker-VM03                            -  enabled
            system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker-VM03                            -  enabled
            system.adapter.vedirect.0               : vedirect              : tinkerboard                              - disabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker-VM03                            - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-VM03                            - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-VM03                            - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-VM03                            - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-VM03                            -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker-VM03                            - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-VM03                            - disabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-VM03                            - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker-VM03                            - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker-VM03                            - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker-VM03                            - disabled
            system.adapter.vis-map.0                : vis-map               : iobroker-VM03                            - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker-VM03                            - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker-VM03                            - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker-VM03                            - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-VM03                            - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-VM03                            - disabled
            system.adapter.vis.0                    : vis                   : iobroker-VM03                            -  enabled
          + system.adapter.web.0                    : web                   : iobroker-VM03                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.wiffi-wz.0               : wiffi-wz              : iobroker-VM03                            -  enabled
            system.adapter.yr.0                     : yr                    : iobroker-VM03                            -  enabled
            system.adapter.zoe2.0                   : zoe2                  : iobroker-VM03                            -  enabled
          + instance is alive
          ioBroker-Repositories
          Beta          : http://download.iobroker.net/sources-dist-latest.json
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.13.16  , installed 6.13.16
          Adapter    "backitup"     : 2.10.11  , installed 2.10.11
          Adapter    "daikin"       : 1.4.2    , installed 1.4.2
          Adapter    "denon"        : 1.15.5   , installed 1.15.5
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "energiefluss-erweitert": 0.3.0, installed 0.3.0
          Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
          Adapter    "fritzbox"     : 0.5.0    , installed 0.5.0
          Adapter    "go-e"         : 1.0.29   , installed 1.0.29
          Adapter    "harmony"      : 1.3.0    , installed 1.3.0
          Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "ical"         : 1.14.3   , installed 1.14.3
          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
          Adapter    "javascript"   : 7.8.0    , installed 7.8.0
          Controller "js-controller": 5.0.19   , installed 5.0.19
          Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
          Adapter    "modbus"       : 6.1.0    , installed 6.1.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
          Adapter    "parser"       : 2.1.0    , installed 2.1.0
          Adapter    "pegelalarm"   : 1.3.3    , installed 1.3.3
          Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
          Adapter    "proxmox"      : 2.2.3    , installed 2.2.3
          Adapter    "renault"      : 0.0.15   , installed 0.0.15
          Adapter    "rflink"       : 2.1.6    , installed 2.1.6
          Adapter    "sayit"        : 3.0.5    , installed 3.0.5
          Adapter    "shuttercontrol": 1.7.0   , installed 1.7.0
          Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
          Adapter    "snmp"         : 3.1.0    , installed 3.1.0
          Adapter    "socketio"     : 6.6.1    , installed 6.6.1
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
          Adapter    "trashschedule": 3.2.0    , installed 3.2.0
          Adapter    "tvspielfilm"  : 2.0.5    , installed 2.0.5
          Adapter    "vis"          : 1.5.4    , installed 1.5.4
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.0.5    , installed 1.0.5
          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
          Adapter    "web"          : 6.2.5    , installed 6.2.5
          Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
          Adapter    "ws"           : 2.5.11   , installed 2.5.11
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Objects and States
          Objects:        19291
          States:         18826
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 192.168.138.91:8181     0.0.0.0:*               LISTEN      1001       41614      7463/io.wiffi-wz.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2631       438/sshd: /usr/sbin
          tcp        0      0 192.168.138.91:42010    0.0.0.0:*               LISTEN      1001       41243      7046/io.hm-rpc.1
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       40265      6820/iobroker.js-co
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       39878      6820/iobroker.js-co
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12373      1/init
          tcp        0      0 192.168.138.91:42000    0.0.0.0:*               LISTEN      1001       42281      7069/io.hm-rpc.2
          tcp        0      0 192.168.138.91:42001    0.0.0.0:*               LISTEN      1001       38493      7012/io.hm-rpc.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          2642       438/sshd: /usr/sbin
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       45057      7661/io.harmony.0
          tcp6       0      0 :::10123                :::*                    LISTEN      1001       40934      7584/io.energieflus
          tcp6       0      0 :::111                  :::*                    LISTEN      0          2301       1/init
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41111      6841/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       41568      7448/io.web.0
          udp        0      0 0.0.0.0:51460           0.0.0.0:*                           1001       38689      7292/io.snmp.0
          udp        0      0 0.0.0.0:43811           0.0.0.0:*                           1001       42740      7418/io.tradfri.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14333      340/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11341      1/init
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       45058      7661/io.harmony.0
          udp6       0      0 :::111                  :::*                                0          12378      1/init
          2024-04-11 17:15:53.729  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Lueftungsscript: Subscriptions angelegt: 36
          2024-04-11 17:15:54.139  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_co2: 81, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_temp: 20.9, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_feuchte: 57.7, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_taupunkt: 12.2, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_feuchte_abs: 10.5, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_baro: 1027.26, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_luftdrucktrend: stabil, common: [object Object]
          2024-04-11 17:15:54.140  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_lux: 2.5, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_motion_left: false, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_motion_right: false, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.: false, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_noise: false, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_elevation: 27.7, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_azimut: 247, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.wz_buzzer: false, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.MAC-Adresse: 4b:87:d:7f:cf:5c, common: [object Object]
          2024-04-11 17:15:54.141  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.ip_Homematic_CCU: 192.168.138.91, common: [object Object]
          2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.WLAN_ssid: Funkwelle, common: [object Object]
          2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.WLAN_Signal_dBm: -59, common: [object Object]
          2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.millis_seit_reset: 155063439, common: [object Object]
          2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.wiffizeit:  5 17:15, common: [object Object]
          2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: neuer Datenpunkt: WIFFI.Systeminfo.firmware: wiffi_wz_106, common: [object Object]
          2024-04-11 17:15:54.142  - info: javascript.1 (21563) script.js.Wetter_und_Klima.Wiffi: WIFFI Datenpunkte angelegt/aktualisiert
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 8
                          NTP service: active
                      RTC in local TZ: no
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
                     5928 M total memory
                     3654 M used memory
                     1443 M free memory
                      193 M buffer memory
                      638 M swap cache
                      974 M total swap
                      614 M used swap
                      360 M free swap
            *** FILESYSTEM ***
            /var:
            2.7G    /var/
            2.3G    /var/log
            288M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            10.5.0
            /usr/bin/npx            10.5.0
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.13.16
            javascript:     7.8.0
            Adapter State
            + instance is alive
            Objects and States
            Objects:        19291
            States:         18826
            Pending Updates: 0
            ich bekomme die Daten als User nicht auf den Pi5
            pi@ioBrokerpi5:~ $ groups
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            pi@ioBrokerpi5:~ $ ls -la /media/usbplatte/backups
            total 77732
            drwxr-xr-x 2 iobroker iobroker    4096 Apr 11 04:22 .
            drwxr-xr-x 4 root     root        4096 Dec 25 13:08 ..
            -rw-r--r-- 1 iobroker iobroker 4680106 Mar 16 01:36 homematic_2024_03_16-01_36_12_3.71.12_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Mar 19 01:36 homematic_2024_03_19-01_36_12_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Mar 22 01:36 homematic_2024_03_22-01_36_12_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Mar 25 01:36 homematic_2024_03_25-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Mar 28 01:36 homematic_2024_03_28-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Mar 31 01:36 homematic_2024_03_31-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Apr  1 01:36 homematic_2024_04_01-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Apr  4 01:36 homematic_2024_04_04-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Apr  7 01:36 homematic_2024_04_07-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 4813226 Apr 10 01:36 homematic_2024_04_10-01_36_11_3.73.9_backupiobroker.tar.sbk
            -rw-r--r-- 1 iobroker iobroker 3148949 Apr  2 04:22 iobroker_2024_04_02-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3154652 Apr  3 04:22 iobroker_2024_04_03-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3154705 Apr  4 04:22 iobroker_2024_04_04-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3155077 Apr  5 04:22 iobroker_2024_04_05-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3153078 Apr  6 04:22 iobroker_2024_04_06-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3152355 Apr  7 04:22 iobroker_2024_04_07-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3153662 Apr  8 04:22 iobroker_2024_04_08-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3153630 Apr  9 04:22 iobroker_2024_04_09-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3157581 Apr 10 04:22 iobroker_2024_04_10-04_22_10_backupiobroker.tar.gz
            -rw-r--r-- 1 iobroker iobroker 3157378 Apr 11 04:22 iobroker_2024_04_11-04_22_10_backupiobroker.tar.gz
            pi@ioBrokerpi5:~ $
            Thomas BraunT S 2 Antworten Letzte Antwort
              total 77732
              pi@ioBrokerpi5:~ $
              Verwendest du nicht den Backitup-Adapter?
              Der macht da eigentlich alles richtig.
                @thomas-braun sagte in Meldungen beim/nach Upgrade:
                doch, das funktioniert ja auch.
                jetzt will ich aber das Backup vom Nuc auf den pi5 bringen.
                wenn ich das dort via backitup hochlade landet es local und nicht in der gemounteten SSD
                  @homoran sagte in Meldungen beim/nach Upgrade:
                  Verstehe ich nicht.
                  zeigt doch ein gemountetes, externes Medium.
                    Verstehe ich nicht.
                    richtig!
                    aber wenn ich im backitup Reiter trotz aktivierter copy/nas option ein Backup hochlade landet es nur in /opt/iobroker/backups. nicht im mount
                    und wenn ich via filezilla auf /media/usbplatte/backups als user pi schieben will, bekomme ich einen permission error obwohl pi in der Gruppe iobroker ist.
                    die Rechte liegen nur auf 755, was wohl nicht das Screiben durch Gruppenmitglueder zulässt.
                      richtig!
                      Der User iobroker darf lesen und schreiben, die Gruppe ioboroker und der Rest darf nur lesen. Damit darf der user pi da nix schreiben.
                      Mit welchen Optionen mountest du denn?
                        ??Bahnhof??
                        das Laufwerk ist einfach mit sudo mount sda1 /media/usbplatte gemountet, ohne weitere Parameter.
                        davon hör ich gerade zum ersten mal 😳
                          ??Bahnhof??
                          Man kann/muss da noch Optionen mitgeben. Meine FritzNAS mounte ich (ist aber eine CIFS-Freigabe) z. B. so:
                          //fritz.nas/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups cifs credentials=/home/iobroker/.smbcredentials,users,noserverino,cache=loose,noauto,rw,uid=iobroker,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 0 0
                          Wichtig ist hier
                          uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777
                          Dateien werden also mit vollen Rechten (Lesen/Schreiben/Ausführen) für den user iobroker wie für die Gruppe iobroker gemountet. (Gut, das Ausführen-Bit könnte man auch weglassen, zumindest für Dateien)
                          Die Optionen unterscheiden sich je nach Dateisystem, das gemountet wird, die Rechte sind aber alle ähnlich zu vergeben.
                            Wichtig ist hier
                            Dann werde ich mir später mal diese Lektion anlernen.
                            im Moment schiebe ich die aktuellen Backups dann eben in lokal
                            die mountplatte kommt dann irgendwann
                            der Befehl wäre dann sudo mount /dev/sda1 /media/usbplatte,uid=iobroker gid=iobroker,file_mode=0775,dir_mode=0775?
                            in der fstab ist er eh noch nicht drin
                              Ich würde hier mal reinschauen:
                              https://wiki.ubuntuusers.de/mount/
                                @thomas-braun Danke!
                                dann wären das hier dchon ein paar Optionen
                                /dev/sda1 on /media/usbplatte type ext4 (rw,relatime) zuzüglich uid, gid und den modes
