  4. Neuer Adapter für Roborock-Staubsauger
    6.3k
1.1k Beiträge 155 Kommentatoren 475.2k Aufrufe 138 Beobachtet
  • da_WoodyD da_Woody
    @copystring so wars gemeint, nur halt nicht so schön beschrieben. ;)
    BamBam89
    #539
    bis vor einiger Zeit konnte ich den Sauger über meine VIS steuern.
    Seit kurzem jedoch nicht mehr. Stattdessen bekomme ich folgende Fehler:
    roborock.0
    2024-04-03 18:56:14.019	warn	Failed to execute get_water_box_custom_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 35 with method get_water_box_custom_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:56:13.957	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 34 with method get_status timed out after 10 seconds
    roborock.0
    2024-04-03 18:56:03.970	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 33 with method get_carpet_clean_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:53.967	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 32 with method get_carpet_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:43.964	warn	Failed to execute get_network_info on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 31 with method get_network_info timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:38.250	warn	Failed to execute get_map_v1 on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 30 with method get_room_mapping timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:33.962	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 28 with method get_consumable timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:23.959	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 27 with method get_status timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:14.020	warn	Failed to execute get_water_box_custom_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 26 with method get_water_box_custom_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:13.957	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 25 with method get_status timed out after 10 seconds
    roborock.0
    2024-04-03 18:55:03.972	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 24 with method get_carpet_clean_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:53.970	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 23 with method get_carpet_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:43.968	warn	Failed to execute get_network_info on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 22 with method get_network_info timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:39.761	warn	homedata failed to download
    roborock.0
    2024-04-03 18:54:33.964	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 21 with method get_consumable timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:23.960	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 20 with method get_status timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:14.015	warn	Failed to execute get_water_box_custom_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 19 with method get_water_box_custom_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:13.957	warn	Failed to execute get_status on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 18 with method get_status timed out after 10 seconds
    roborock.0
    2024-04-03 18:54:03.969	warn	Failed to execute get_carpet_clean_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 17 with method get_carpet_clean_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:53:53.967	warn	Failed to execute get_carpet_mode on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 16 with method get_carpet_mode timed out after 10 seconds
    roborock.0
    2024-04-03 18:53:43.965	warn	Failed to execute get_network_info on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 15 with method get_network_info timed out after 10 seconds
    roborock.0
    2024-04-03 18:53:33.962	warn	Failed to execute get_consumable on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 14 with method get_consumable timed out after 10 seconds
    roborock.0
    2024-04-03 18:53:23.960	warn	Failed to execute get_room_mapping on robot 4Pdmlh6A41cjZXBieYbjqk Error: Local request with id 13 with method get_status timed out after 10 seconds
    und unter meinen Objekten sind die Räume z.B. nicht mehr Sichtbar. Hat jemand eine Idee, was das sein könnte?
    Ich habe es schon mit einer älteren Version getestet, allerdings bekomme ich damit den Adapter gar nicht zum laufen.
    Danke euch
    • copystringC copystring
      @jahnbes said in Neuer Adapter für Roborock-Staubsauger:
      @nic-f
      Das interessiert mich! Siehst Du den hin- und herfahrenden Roborock und seine Spur?
      Viele Grüße, jahnbes.
      Nur nochmal als Erinnerung. Die Karte läuft deshalb nicht, da aus irgendeinem Grund nicht auf jedem Raspberry Pi die canvas Bibliothek richtig kompiliert wird. Wenn man sich damit etwas beschäftigt, kann man das natürlich noch nachholen. Vielleicht hat jemand Lust das zu tun und für andere Nutzer entsprechend zu dokumentieren.
      Dimi
      #540
      @copystring
      Hallo, also das die Kartendarstellung auf der pi4 funktioniert kann ich bestätigen. Früher hatte ich auch die Probleme, dass der Adpater auf Fehler lief. Dann hatte ich die 64 Bit Version von Buster genommen und es lief besser, aber nach kurzer Zeit wurde wegen häfigem Neustart des Adapters der Adpater durch den Host gestoppt. Seit gut 2 Monaten habe ich die 64 Bit Version von Bookworm auf der pi4 und da läuft es ohne Probleme mit der Version 0.5.4.
      Ich habe jedoch ein anderes Problem wenn ich auf die Version 0.6.1 update. Dann geht bei mir der Kamerastream nicht mehr. Gehe ich wieder auf 0.5.4 zurück geht es ohne Probleme. Hat sich da was geändert?
      copystringC 1 Antwort Letzte Antwort
      • D Dimi
        @copystring
        copystringC Offline
        copystringC Offline
        copystring
        #541
        @dimi Was genau geht denn am Kamerastream nicht? Wenn es kompliziert wird, öffnen doch bitte ein Issue auf Github.
        Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
        https://paypal.me/copystring
          Dimi
          #542
          @copystring
          Die ganze Webseite wird nicht mehr angezeigt. Da steht sowas wie Verbindung wird abgelehnt. Auch mit dem VLC Player bekomme ich keine Verbindung. Für mich sieht das so aus als ob das Tool was du verwendest um den Stream anzuzeigen nicht mehr läuft wenn die Version 0.6.1 läuft.
          • D Dimi
            @copystring
            copystringC Offline
            copystringC Offline
            copystring
            #543
            @dimi Wenn du den Ordner Camera löschst, wird der beim Neustart von 0.6.1 neu erstellt?
              Dimi
              #544
              @copystring
              Ja schon. Also ich habe auch versucht den Adapter zu deinstallieren und neu zu installieren so dass alle Objekte neu geschrieben werden. Der Camera Ordner wird erstellt und auch die Urls werden eingetragen.
              copystringC 2 Antworten Letzte Antwort
              • D Dimi
                @copystring
                copystringC Offline
                copystringC Offline
                copystring
                #545
                @dimi OK. Dann wird es etwas komplizierter. Ich gucke mir das an, würde mich aber freuen, wenn du ein entsprechendes Issue auf Github eröffnen würdest.
                • D Dimi
                  @copystring
                  copystringC Offline
                  copystringC Offline
                  copystring
                  #546
                  @dimi Müsste jetzt wieder laufen. Konnte es bei mir reproduzieren und beheben. Wenn du die dev eben testen würdest, mache ich daraus einen neuen release. https://github.com/copystring/ioBroker.roborock/tree/dev
                    Dimi
                    #547
                    @copystring
                    Funktioniert mit der dev. Jetzt wird auch das go2rtc geladen.
                    Kannst eine neue Version bauen.
                    • D Dimi
                      @copystring
                      copystringC Offline
                      copystringC Offline
                      copystring
                      #548
                      @dimi Danke, ist erledigt!
                        tritanium
                        #549
                        @copystring
                        Hallöle, ich mal wieder :-)
                        Habe gestern auf 0.6.2 upgedatet, und musste heute mal neu starten, seit dem kommen "warnings":
                        roborock.0
                           2024-04-06 23:25:20.967	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:17.542	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:17.541	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:17.540	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:17.539	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:03.669	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:00.937	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:00.936	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:00.933	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:25:00.932	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:48.539	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:44.646	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:44.645	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:44.590	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:44.589	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:38.759	warn	Failed to execute get_fw_features on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Local request with id 86 with method get_fw_features timed out after 10 seconds
                        roborock.0
                           2024-04-06 23:24:33.478	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:28.601	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:28.599	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:28.597	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:28.595	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:17.050	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:24:02.132	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:23:46.315	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:23:31.533	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:23:28.233	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.floors.multi_map_count" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:23:28.232	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.floors.max_bak_map" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:23:28.227	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.floors.max_multi_map" has no existing object, this might lead to an error in future versions
                        roborock.0
                           2024-04-06 23:23:27.653	warn	Failed to execute get_fw_features on robot 5kt1jy0ATJPgji5k0hJAZg Error: Local request with id 0 with method get_fw_features timed out after 10 seconds
                        roborock.0
                           2024-04-06 23:23:16.351	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                        Beide Robots funktionieren einwandfrei über den Adapter, allerdings bekam der Q8 Revo heute ein Firmware Update. Der Q7 Max+ wird aber auch angezählt, das Datenpunkt(e) fehlen...
                        Kannst du mal schauen :-) lg Micha
                        • T tritanium
                          @copystring
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          Batchman
                          #550
                          @tritanium Hallo, das ist bei mir auch so -> Roborock S6 MaxV
                          • FlexerF Offline
                            FlexerF Offline
                            Flexer
                            #551
                            Hallo @copystring ich habe das hier im Log. Kommt alle 2 Sekunden und hört nicht auf. Roboter ist gerade in der Station
                            Unterm Strich ist alles besser.
                            Ja, voll geil hier!
                            • B Batchman
                              tritanium
                              #552
                              @batchman
                              -> Meinen Adapter hatte ich nun eine Woche aus :-o
                              Habe ich jetzt grade mal wieder eingeschaltet & beobachte ....
                              • T tritanium
                                @batchman
                                tritanium
                                #553
                                Bring nix :-o
                                -> Alle 10-20 sek. folgende Meldungen:
                                   2024-04-21 20:36:02.352	warn	script.js.Steuerungen.Anwesenheit: Rolladen hinten | Gerät: | Kanal: Tag/Nacht | Wert: true
                                roborock.0
                                   2024-04-21 20:35:49.883	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:49.882	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:49.882	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:49.856	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:49.853	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:33.032	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:33.031	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:33.030	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:33.029	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:33.025	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:15.779	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:15.778	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:15.777	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:15.772	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:35:15.768	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:58.894	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:58.893	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:58.892	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:58.891	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:58.887	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:41.877	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:41.875	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:41.874	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:41.873	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:41.872	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:41.382	warn	Failed to execute get_network_info on robot 5kt1jy0ATJPgji5k0hJAZg Error: Local request with id 1470 with method get_network_info timed out after 10 seconds
                                roborock.0
                                   2024-04-21 20:34:24.884	warn	State "roborock.0.Devices.5kt1jy0ATJPgji5k0hJAZg.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:24.852	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.corner_clean_mode" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:24.851	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.rdt" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:24.850	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.camera_status" has no existing object, this might lead to an error in future versions
                                roborock.0
                                   2024-04-21 20:34:24.847	warn	State "roborock.0.Devices.4Si5s3DNcsl0ATAl8e5UdI.deviceStatus.distance_off" has no existing object, this might lead to an error in future versions
                                Insofern warte ich mal ab, auf GIT sind ja bereits etliche Issues dazu offen.
                                  m0skit0
                                  #554
                                  Hallo liebes Forum
                                  ich habe ein Problem mit meinem Roborock S7.
                                  Ich habe die neuste Version 0.6.2 installiert, aber leider startet der Roborock keine Raumreinigung über den Sprachbefehl Alexa Raum ..... saugen.
                                  Wenn ich in den Objekten floor schaue dann geht der Wert beim Sprachbefehl auf true, aber der Sauger läuft nicht.
                                  Ich hatte vorher die Version 0.4.4 installiert dort geht es.
                                  Habe den Ordner 0 im Roborock Verzeinis gelöscht und den Adapter neu installiert.
                                  Wenn ich jetzt auf die Version 0.4.4 zurück wechsle funktioniert der Sprachbefehl sofort.
                                  Könnt ihr mir helfen und sagen was ich da falsch mache ?
                                  Mein System:
                                  Node.js
                                  v18.20.2
                                  NPM
                                  10.5.0
                                  Ich wäre für jede Hilfe dankbar
                                  lg
                                  m0skit0
                                  F 1 Antwort Letzte Antwort
                                  • M m0skit0
                                    Hallo liebes Forum
                                    Mein System:
                                    Node.js
                                    v18.20.2
                                    NPM
                                    10.5.0
                                    lg
                                    m0skit0
                                    frankyboy73
                                    #555
                                    @m0skit0 Hi, eigentlich reicht es nicht nur den Raum der gereinigt werden soll auf true zu setzen, zusätzlich muss auch noch der Datenpunkt roborock.0.Devices.XXXXXXXXXXXXXX.commands.app_segment_clean (Beginnen Sie mit der Zimmerreinigung) auf true gesetzt werden, war bei der Version 0.4.4 aber auch schon so.
                                    Schöne Grüße Frank
                                    • F frankyboy73
                                      m0skit0
                                      #556
                                      @frankyboy73
                                      vielen dank für deine Antwort
                                      Wenn ich den Sprachbefehlt mit 0.4.4 zum saugen des Raumes gebe, dann bekomme ich die Bestätigung mit ok und die
                                      Werte werden auf true gesetzt und der Roborock fährt.
                                      Wenn ich die 0.6.2 installiert habe bekomme ich auch die Bestätigung und die Werte werden auf true gesetzt, aber der Roborock fährt nicht los.
                                      Leider bin ich da überfragt, was das sein kann weil die Werte ja aktualisiert werden so wie bei der 0.4.4.
                                      Vielelicht hat ja noch jemand eine Idee
                                      • VumerV Offline
                                        VumerV Offline
                                        Vumer
                                        schrieb am zuletzt editiert von Vumer
                                        #557
                                        es geht um meinem Roborock Q7 Max und Adapter roborock v0.6.2, aber auch v0.5.4
                                        js-controller v5.0.17; Admin v6.13.16; Nodejs v18.17.1; NPM 9.6.7;
                                        NUC 4 x Intel(R) Core(TM) i5-4250U CPU @ 1.30GHz; Proxmox 6.4-15; Debian 10 (buster)
                                        iob LXC Privilegierte Container Debian 11 (bullseye); SSD; RAM 3.5 GB;
                                        anormale CPU-Auslastung 🙄
                                        mit rot gezeichnet ist der Zeitpunkt als ich dem Adapter ausgeschaltet habe.
                                        Die Auslastung ist alle 5 min, obwohl 4 min eingestellt sind.
                                        Aufgefallen ist mir das als der Lüfter am NUC sehr laut war und die CPU-Auslastung zwischen 30 und 80%. Nach dem ich alles, auch dem Q7, neu gestartet habe sieht die CPU-Auslastung so aus wie am Bild
                                        Das ist die Auslastung ohne roborock Adapter
                                        Thomas BraunT VumerV 2 Antworten Letzte Antwort
                                        • VumerV Vumer
                                          #558
                                          @vumer sagte in Neuer Adapter für Roborock-Staubsauger:
                                          Bring das auf Stand.
                                          iob stop
                                          iob fix
                                          iob nodejs-update
                                          und Debian 10 (buster) ist tot. Installier da ein lebendes Release.
                                          VumerV 1 Antwort Letzte Antwort
