  5. Szenen Anlegen und durchschalten. Geht es eleganter?
    6.6k
5 Beiträge 4 Kommentatoren 564 Aufrufe 2 Beobachtet
    Dave83
    so schalten wir das Schlafzimmer durch. Wir haben Szenen angelegt, die durchgeschaltet werden.
      <variables>
        <variable id="S4kqSec@m|:m3,KQJX0k">modus</variable>
      </variables>
      <block type="procedures_defnoreturn" id="H7~5opJ.fFEf+|1?oqh[" x="887" y="-38">
        <field name="NAME">M1_WenigLicht</field>
        <statement name="STACK">
          <block type="control" id="!{zq*DaXMo1jesH#OI$-">
            <field name="OID">zigbee.0.group_3.color</field>
            <value name="VALUE">
              <block type="text" id="`Y@9ee);an[+Z,1_1C)D">
                <field name="TEXT">DB7C1D</field>
              </block>
            </value>
            <next>
              <block type="control" id="dTEnmr,$41FzplC:OA$t">
                <field name="OID">zigbee.0.group_3.brightness</field>
                  <block type="math_number" id="*IhhH-pS,3xq?X/a6TBw">
                    <field name="NUM">100</field>
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="variables_set" id="aoWjk9vkp.FAAxHh;A]C" x="37" y="13">
        <field name="VAR" id="S4kqSec@m|:m3,KQJX0k">modus</field>
          <block type="math_number" id="k%s)28N{GAWlD;I5nEHh">
            <field name="NUM">0</field>
          </block>
        </value>
        <next>
          <block type="on_ext" id="Y?TE!26NflqB|sW[L-pr">
            <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
            <value name="OID0">
              <shadow type="field_oid" id=",#Gi/@A2eTU{2AX6Tlqt">
                <field name="oid">zigbee.0.8c6fb9fffe642632.on</field>
              </shadow>
            </value>
            <value name="OID1">
              <shadow type="field_oid" id="l;V%/ICM9F]f^;QO=}oG">
                <field name="oid">zigbee.0.8c6fb9fffe642632.off</field>
              </shadow>
            </value>
            <statement name="STATEMENT">
              <block type="control" id="gzeW8j(2RT-i|A~zBe*D">
                <field name="OID">zigbee.0.group_3.transition_time</field>
                  <block type="math_number" id="IAp!99NK1fr7|S+`}|L,">
                    <field name="NUM">1</field>
                  </block>
                </value>
                <next>
                  <block type="controls_if" id="yM:N=,x%}@_~ICl%haSM">
                    <value name="IF0">
                      <block type="get_value" id="iBO.Gw|zgN(.W753)X#U">
                        <field name="OID">zigbee.0.8c6fb9fffe642632.on</field>
                      </block>
                    </value>
                    <statement name="DO0">
                      <block type="math_change" id=",tI3YBDmtMH=~b@WG/BC">
                        <value name="DELTA">
                          <shadow type="math_number" id=";T8y[qx#ac.@gioE/HZm">
                          </shadow>
                        </value>
                        <next>
                          <block type="procedures_callnoreturn" id="oWgO/sN68p|v_b5H.kln">
                            <mutation name="ModusEinstellen"></mutation>
                          </block>
                        </next>
                      </block>
                    </statement>
                    <next>
                      <block type="controls_if" id="K_xM{BUwEQ.J|J/*fw0R">
                        <value name="IF0">
                          <block type="get_value" id="5e1)Nm{@JjX;A@vinqo[">
                            <field name="OID">zigbee.0.8c6fb9fffe642632.off</field>
                          </block>
                        </value>
                          <block type="procedures_callnoreturn" id="W%/~1vX?vKm8}0]a?KxK">
                            <mutation name="LangsamLichtAUS"></mutation>
                            <next>
                              <block type="variables_set" id="6Fu}PsdA=SO-I;}Z_f]m">
                                  <block type="math_number" id="bqjf3bE!yUcGsJFcx*:H">
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </statement>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </next>
      </block>
      <block type="procedures_defnoreturn" id="yKO9Xd)*nf=O4_*J2^[6" x="487" y="13">
        <field name="NAME">ModusEinstellen</field>
          <block type="controls_if" id="uE$cBA@,.4#x/MkFKf|V">
            <mutation elseif="4"></mutation>
            <value name="IF0">
              <block type="logic_compare" id="(1`Eq7=,xhF@v)M.TdMB">
                <field name="OP">LTE</field>
                <value name="A">
                  <block type="variables_get" id="c(*uu2,|T%!7klAC:]UQ">
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="jDgkn{.$5XY+B4)J8kss">
                  </block>
                </value>
              </block>
            </value>
              <block type="variables_set" id="MdwD}RKu}dd9*P+bhWKE">
                  <block type="math_number" id="[M50^?7;o%[kq3Y|.90H">
                  </block>
                </value>
              </block>
            </statement>
            <value name="IF1">
              <block type="logic_compare" id="A/IeSw1,+mB[p8];x`Nh">
                <field name="OP">EQ</field>
                <value name="A">
                  <block type="variables_get" id="1=BSHd_Y~2MwH;6j`.Ut">
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="WsWS]+R-YP[!{Qg]x)3p">
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO1">
              <block type="procedures_callnoreturn" id="IH]h19Hj7X%/8:JzED8t">
                <mutation name="M1_WenigLicht"></mutation>
              </block>
            </statement>
            <value name="IF2">
              <block type="logic_compare" id="F3Uq((n#67j}.K2DlFly">
                <value name="A">
                  <block type="variables_get" id="^2fuvs2G*pPE@msWMdv2">
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="13fpqtLA8WfLOgOdt4#s">
                    <field name="NUM">2</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO2">
              <block type="procedures_callnoreturn" id="xQB3*E1|4lE]$)P{d/]U">
                <mutation name="M2_Liebe"></mutation>
              </block>
            </statement>
            <value name="IF3">
              <block type="logic_compare" id="`8dTADnsr7pnGy5wT^j{">
                <value name="A">
                  <block type="variables_get" id="/8{uCsMF_2q#d*|i:X25">
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="TF(02?:mmg,RFOb3Y.BI">
                    <field name="NUM">3</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO3">
              <block type="procedures_callnoreturn" id="J8JP~/DJ)x}W$AR^h;6(">
                <mutation name="M3_Blau"></mutation>
              </block>
            </statement>
            <value name="IF4">
              <block type="logic_compare" id="9~;:%EjD:V8/a3Fzhk[O">
                <field name="OP">GTE</field>
                <value name="A">
                  <block type="variables_get" id="#s-:dBPkP@zqW:iYXX[Z">
                  </block>
                </value>
                <value name="B">
                  <block type="math_number" id="GkiuIa:BqHRHh;ucycX9">
                    <field name="NUM">4</field>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO4">
              <block type="procedures_callnoreturn" id="%p,fz[.8`z~usi%ZG/Jn">
                <mutation name="M4_AllesHell"></mutation>
                <next>
                  <block type="variables_set" id="([m^s1?a!/JiJ#rBQFR3">
                      <block type="math_number" id="Kr^d)uT}k~~}oP]|%.W8">
                      </block>
                    </value>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="X/XiXKl%9N+Kt`6*g(/I" x="887" y="112">
        <field name="NAME">M2_Liebe</field>
          <block type="control" id="FOerTwC:bt`_v1]1==_/">
              <block type="text" id="VJT9C!BnydQ57R!d%-;S">
                <field name="TEXT">681111</field>
              </block>
            </value>
            <next>
              <block type="control" id="A_ztr+bbtev%r9?3Pb$E">
                  <block type="math_number" id="3Se`fPP3]xJU7c_5um^u">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="Gich}IWXj|!34glpse)i" x="887" y="263">
        <field name="NAME">M3_Blau</field>
          <block type="control" id="g=LuHy11mUel3fA9GrL:">
              <block type="text" id="a|z=Whoyi#ei{b5nLxVN">
                <field name="TEXT">0000FF</field>
              </block>
            </value>
            <next>
              <block type="control" id="cF#={+C9/%Co[UOoSHGb">
                  <block type="math_number" id="S0WQPD1FZDo89_Mq6}wl">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id="RA^UN-hKl,(30|=[`WQ?" x="887" y="413">
        <field name="NAME">M4_AllesHell</field>
          <block type="control" id="?*_XFWb(COZ*sU68IHzE">
              <block type="text" id="aQqT`RmeGk-ibKJw6Kx=">
                <field name="TEXT">FFFFFF</field>
              </block>
            </value>
            <next>
              <block type="control" id=";9X?`Lx{j?wSg)8r9b[p">
                  <block type="math_number" id="1Fp/0Gf6~Mz;cI5g?DIh">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
      <block type="procedures_defnoreturn" id=":vVG]N(##0|D3Xdd|aQd" x="887" y="562">
        <field name="NAME">LangsamLichtAUS</field>
          <block type="control" id="Dk61F+HgZ*_,BsKo/4K5">
              <block type="math_number" id="QuefmaBxxU]i?x;eDK~B">
              </block>
            </value>
            <next>
              <block type="control" id="d*)FRdyb{G;-=31GO(xk">
                  <block type="text" id=")FTvZ0%EPi._|1k1FdC5">
                  </block>
                </value>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    Frage
    Geht das Ganze eleganter? Weil das jedes mal ganz schön viel Arbeit ist, dass so anzulegen. Wie mach ihr das?
    black.falcon87B paul53P 2 Antworten Letzte Antwort
    • D Dave83
        <variables>
        </variables>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
            </block>
          </value>
          <next>
              <value name="OID0">
                </shadow>
              </value>
              <value name="OID1">
                </shadow>
              </value>
                    </block>
                  </value>
                  <next>
                      <value name="IF0">
                        </block>
                      </value>
                            </shadow>
                          </value>
                          <next>
                            </block>
                          </next>
                        </block>
                      </statement>
                      <next>
                          <value name="IF0">
                            </block>
                          </value>
                              <next>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </next>
        </block>
              <value name="IF0">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                </block>
              </statement>
              <value name="IF1">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                </block>
              </statement>
              <value name="IF2">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                </block>
              </statement>
              <value name="IF3">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                </block>
              </statement>
              <value name="IF4">
                  <value name="A">
                    </block>
                  </value>
                  <value name="B">
                    </block>
                  </value>
                </block>
              </value>
                  <next>
                        </block>
                      </value>
                    </block>
                  </next>
                </block>
              </statement>
            </block>
          </statement>
        </block>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
                </block>
              </value>
              <next>
                    </block>
                  </value>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </xml>
      Frage
      black.falcon87B Offline
      black.falcon87
      @dave83
      Du könntest dir mal den Szenen Adapter anschauen?
      Dort kreiert man Szenen die aus einer Ansammlung von Datenpunkten und Werten bestehen. Die kann man im Blockly dann einfach aktivieren oder deaktivieren.
      https://github.com/ioBroker/ioBroker.scenes
        Dave83
        @black-falcon87 Wie installiert man das von dir verlinkte?
        Oder gibt es hier im Forum dazu einenAnleitung und erste Beispiele?
        • D Dave83
          @dave83 sagte in Szenen Anlegen und durchschalten. Geht es eleganter?:
          ganz normal wie jeden Adapter über den Admin
          • D Dave83
              <variables>
              </variables>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
                  </block>
                </value>
                <next>
                    <value name="OID0">
                      </shadow>
                    </value>
                    <value name="OID1">
                      </shadow>
                    </value>
                          </block>
                        </value>
                        <next>
                            <value name="IF0">
                              </block>
                            </value>
                                  </shadow>
                                </value>
                                <next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                            <next>
                                <value name="IF0">
                                  </block>
                                </value>
                                    <next>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
                    <value name="IF0">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                          </block>
                        </value>
                      </block>
                    </statement>
                    <value name="IF1">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                      </block>
                    </statement>
                    <value name="IF2">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                      </block>
                    </statement>
                    <value name="IF3">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                      </block>
                    </statement>
                    <value name="IF4">
                        <value name="A">
                          </block>
                        </value>
                        <value name="B">
                          </block>
                        </value>
                      </block>
                    </value>
                        <next>
                              </block>
                            </value>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
                      </block>
                    </value>
                    <next>
                          </block>
                        </value>
                      </block>
                    </next>
                  </block>
                </statement>
              </block>
            </xml>
            Frage
            @dave83 sagte: Geht das Ganze eleganter?
            Ohne Funktionen und mit einzelnen Triggern:
