  3. Cloud Dienste
  4. IOT Adapter
    6.4k
IOT Adapter
24 Beiträge 7 Kommentatoren 5.4k Aufrufe 5 Beobachtet
    @babba79
    cd /opt/iobroker
    sudo -H -u iobroker npm install iobroker.js-controller
    babba79
    @thomas-braun vielen Dank. Probiere ich gleich mal aus. Nur auf dem Master, oder?
    Thomas BraunT B 2 Antworten Letzte Antwort
    • B babba79
      @babba79
      Auf der Kiste mit der Fehlermeldung. Wenn du die vollständige Ausgabe inkl. der Eingabezeile posten würdest wäre es klarer.
      • B babba79
        babba79
        pi@Jarvis1:~ $ cd /opt/iobroker
        pi@Jarvis1:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN skipping integrity check for git dependency ssh://git@github.com/Jey-Cee/ioBroker.net-tools.git
        npm WARN skipping integrity check for git dependency ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
        npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN cleanup Failed to remove some directories [
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/node-dht-sensor',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/node-dht-sensor'] {
        npm WARN cleanup       errno: -39,
        npm WARN cleanup       code: 'ENOTEMPTY',
        npm WARN cleanup       syscall: 'rmdir',
        npm WARN cleanup       path: '/opt/iobroker/node_modules/node-dht-sensor'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/iobroker.js-controller',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/iobroker.js-controller'] {
        npm WARN cleanup       path: '/opt/iobroker/node_modules/iobroker.js-controller'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     '/opt/iobroker/node_modules/cpu-features',
        npm WARN cleanup     [Error: ENOTEMPTY: directory not empty, rmdir '/opt/iobroker/node_modules/cpu-features/build/Release'] {
        npm WARN cleanup       path: '/opt/iobroker/node_modules/cpu-features/build/Release'
        npm WARN cleanup     }
        npm WARN cleanup   ],
        npm WARN cleanup   [
        npm WARN cleanup     }
        npm WARN cleanup   ]
        npm WARN cleanup ]
        npm ERR! code 1
        npm ERR! path /opt/iobroker/node_modules/iobroker.js-controller
        npm ERR! command failed
        npm ERR! command sh -c node iobroker.js setup first
        npm ERR! No connection to objects 127.0.0.1:6379[redis]
        npm ERR! /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
        npm ERR!         throw e;
        npm ERR!         ^
        npm ERR!
        npm ERR! Error: Connection is closed.
        npm ERR!     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        npm ERR!     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        npm ERR!     at Object.onceWrapper (node:events:632:26)
        npm ERR!     at Socket.emit (node:events:517:28)
        npm ERR!     at TCP.<anonymous> (node:net:350:12)
        npm ERR! Emitted 'error' event on ScanStream instance at:
        npm ERR!     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        npm ERR!     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        npm ERR!     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        npm ERR!     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        npm ERR!
        npm ERR! Node.js v18.19.1
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-19T14_03_05_090Z-debug-0.log
        Als Rest bleiben im "node_modules" Ordner 3 versteckte Ordner mit . vorne.
        • B babba79
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ],
          npm WARN cleanup   [
          npm WARN cleanup     }
          npm WARN cleanup   ]
          npm WARN cleanup ]
          npm ERR! code 1
          npm ERR!         throw e;
          npm ERR!         ^
          npm ERR!
          npm ERR!
          @babba79
          iob stop
          iob fix
          iob start
          Dann ggfls. nochmal installieren.
            @babba79
            iob stop
            iob fix
            iob start
            babba79
            pi@Jarvis1:/opt/iobroker $ iob start
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ],
            npm WARN cleanup   [
            npm WARN cleanup     }
            npm WARN cleanup   ]
            npm WARN cleanup ]
            npm ERR! code 1
            npm ERR!         throw e;
            npm ERR!         ^
            npm ERR!
            npm ERR!
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-03-19T14_51_02_406Z-debug-0.log
            Gleicher Fehler. 😞
            • B babba79
              npm WARN cleanup   [
              npm WARN cleanup     }
              npm WARN cleanup   ],
              npm WARN cleanup   [
              npm WARN cleanup     }
              npm WARN cleanup   ],
              npm WARN cleanup   [
              npm WARN cleanup     }
              npm WARN cleanup   ],
              npm WARN cleanup   [
              npm WARN cleanup     }
              npm WARN cleanup   ]
              npm WARN cleanup ]
              npm ERR! code 1
              npm ERR!         throw e;
              npm ERR!         ^
              npm ERR!
              npm ERR!
              Gleicher Fehler. 😞
              @babba79 sagte in IOT Adapter:
              rm -rf /opt/iobroker/node_modules/node-dht-sensor
              rm -rf /opt/iobroker/node_modules/iobroker.js-controller
                babba79
                das ganze hab ich 2x wiederholt und die Fehler Ordner ebenfalls gelöscht. Jetzt hat es funktioniert.
                added 25 packages, removed 82 packages, and changed 1013 packages in 4m
                86 packages are looking for funding
                  run `npm fund` for details
                Du bist mein Held. Ich danke dir für deine Unterstützung. iob läuft wieder.....👍 🤸 🤝 Als nächstes nehm ich mir mal dein Tutorial Bullseye -> Bookworm vor, aber zuerst muss ich noch vom Buster weg, oder kann ich von Buster auch direkt zu Bookworm upgraden?
                • B babba79
                  Das würde ich auf einem RaspberryPi gar nicht machen. Die Änderungen insbesondere von Bullseye auf Bookworm sind zu groß. Mach eine Neuinstallation.
                  Und bleib da am Ball, der 'Buster' ist schon länger abgekündigt.
                    babba79
                    OK dann werd ich es so machen. Dann kommen meine 2x RPi 5 auch mal zum Einsatz für die Neuinstallation.
                    • B babba79
                      @babba79
                      Auf RPi5 ohnehin neuinstallieren, da wird eh ein anderer Kernel verwendet, weil da ein anderer Chipsatz läuft.
                        @babba79
                        babba79
                        OK ich habe verstanden. Ich warte noch auf meine POE Hats für die 5er und dann mach ich mich mit meinem gefährlichen Halbwissen ans Werk. Nochmals vielen Dank für deine Unterstützung.
                          @babba79
                          babba79
                          schrieb am zuletzt editiert von babba79
                          Ich habe die Hardware nun alles zusammen 2x RPI 5 mit POE-Hats und M.2 SSD Bottom. Bookworm auf beiden installiert, iobroker mit Redis drauf.....und läuft.
                          Leider klappt iot und Alexa immer noch nicht. Bekomme in der Alexa-App beim aktivieren des iobroker.iot Skills immer noch die Meldung "User does not exist".
                          Hat jemand noch irgendwelche Ansätze, wie ich das lösen kann?
                          Nochmal kurz meine Zusammenfassung, da der letze Versuch im März war mit der alten Buster Installation.
                          Ich habe ein iobroker.pro Abo "Assistent.year" das bis Feb. 2025 läuft. Passwörter wurden alle neu gemacht und der Login funktioniert auch. Bei Amazon habe ich die 2FA aktiviert.
                          IOT Adapter läuft und ist grün. Der Haken ist nur bei Alexa gesetzt (nicht bei alexa v3 (Beta)).
                          Ich gehe dann in die Alexa App unter Skills und suche den iobroker.iot Skill und betätige den Button "Zur Verwendung aktivieren" und gebe die Zugangsdaten des iobroker.pro Account ein und dann bekomme ich immer die Meldung in ROT "User does not exist". Ich bin echt am verzweifeln.
                          Ich weiß nicht , ob es relevant ist , aber der alexa2 Adapter läuft auf dem Slave und der iot Adapter auf dem Master.
                          Grüße aus Karlsruhe
                          Edit:
                          Ich habe nun nochmal jede Anleitung zu iobroker.pro, iot Adapter Wort für Wort durchgelesen. Ich habe den Anmeldedaten neu erstellen Button im iot Adapter schon bestimmt 30 mal bei den einzelnen Versuchen gedrückt und es hat nie funktioniert.
                          Das habe ich vorher nochmals probiert und jetzt hat es geklappt. Halleluja 🤦
                          Schön, dass es jetzt funktioniert, aber ärgerlich das ich nicht weiß woran es gelegen hat.
                          Danke für eure Hilfe, Unterstützung und Geduld.
                          LongbowL 1 Antwort Letzte Antwort
                          • B babba79
                            Grüße aus Karlsruhe
                            Edit:
                            LongbowL Offline
                            LongbowL Offline
                            Longbow
                            also meine Pro Verbindung ging bis jetzt immer sehr gut.. nur jetzt auf einmal nicht.
                            Alles ist grün, startet man den VIS Editor auf der Startseite kommt beim VIS Editor nach kurzem Laden folgenden Fehlermeldung. An was liegt das Problem?
                            • LongbowL Longbow
                              LongbowL Offline
                              LongbowL Offline
                              Longbow
                              Keine eine Idee?
                                David16
                                Dieser Beitrag wurde gelöscht!
