  4. Metro Widget + Tankerkönig = Kein Name
    5.1k
15 Beiträge 5 Kommentatoren 1.8k Aufrufe 1 Beobachtet
  • E Offline
    eBBeL
    Hi Rainer,
    danke für deine Rückmeldung und für das nette Willkommen :D
    Anbei der Screen:
    ~~![](</s><URL url=)<link_text text="http://forum.iobroker.net/download/file ... e1e95818a5">http://forum.iobroker.net/download/file.php?mode=view&id=18124&sid=9d0d9bd289b90d6fcfa3a7e1e95818a5</link_text>" />
    und nochmal als Code
    [{"tpl":"tplMetroTileString","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"bg_class_false":"bg-crimson","bg_class_true":"bg-cyan","icon_class_false":"","icon_class_true":"","badge_bg_class_false":"","badge_bg_class_true":"","icon_badge_false":"","icon_badge_true":"","brand_bg_class_false":"","brand_bg_class_true":"","badge_top":"0","badge_left":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"content_prepend":"","content_oid":"tankerkoenig.0.stations.0.diesel.combined","state_oid":"tankerkoenig.0.stations.0.status","hover":true,"select_on_true":false,"label_prepend":"","label_id":"tankerkoenig.0.stations.0.name","content_append":"","icon_false":"/icons-mfd-svg/audio_fade.svg","icon_true":"/icons-mfd-svg/scene_gas_station.svg","icon_width":"68","icon_height":"68","icon_top":"38","icon_left":"37","label_append":"","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"690px","top":"60px","font-weight":"bold","font-family":"Verdana, Geneva, sans-serif","font-style":"normal","font-variant":"small-caps","text-align":"left","width":"130px","height":"130px","z-index":"4"},"widgetSet":"metro"}]
    ioB: RPi 4B 4GB (Proxmox in progress)
    Raspberrymatic 1 (Wohnung): RPi 4B 4GB HM-MOD-RPI
    Raspberrymatic 2 (Haus): RPi 3B+ HM-MOD-RPI
    • eric2905E Offline
      eric2905E Offline
      eric2905
      ich habe es eben mal bei mir nachgestellt - alle Daten werden angezeigt.
      Poste bitte auch mal einen Screenshot von der Objektstruktur Tankerkönig.0.stations.xxx mit allen Unterordners aufgeklappt.
      Gruß,
      Eric
      • E Offline
        eBBeL
        @eric2905:
        Poste bitte auch mal einen Screenshot von der Objektstruktur Tankerkönig.0.stations.xxx mit allen Unterordners aufgeklappt. `
        Hi Eric, danke dir! Screenshots siehe Anhang :-)
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Hm, bei Station 3 ist der Name leer, bei den anderen nicht.
          Laut Screenshot willst Du ja die Station 0 anzeigen … seltsam.
          Gruß,
          Eric
          Von unterwegs getippert
            Ich glaube bei der Staion 0 war irgendwo ein Leerzeichen zu viel.
            Sollte aber hier nichts machen, störte nur beim filtern
            Gruß Rainer
            • BluefoxB Offline
              BluefoxB Offline
              Es war ein bug drin und nur in diesem Widget. Habe ich gefixt. Bitte 1.1.2 ausprobieren.
              • E Offline
                eBBeL
                @Bluefox:
                Es war ein bug drin und nur in diesem Widget. Habe ich gefixt. Bitte 1.1.2 ausprobieren. `
                Ouha das ging schnell. Danke erstmal :shock:
                Leider hat es keinen Erfolg gehabt, zumindest bei mir nicht. Habe die neue Version über iobroker.admin via "installieren aus eigener URL" und dann vom Github installiert. Sollte auch drin sein, siehe Screenshot.
                Ich muss gestehen: Ich verwende die Node.js 9.2.0 auf meinem Server. Ist das evtl. ein Problem? :oops:
                • BluefoxB Offline
                  BluefoxB Offline
                  @eBBeL:
                  @Bluefox:
                  Ich muss gestehen: Ich verwende die Node.js 9.2.0 auf meinem Server. Ist das evtl. ein Problem? :oops: `
                  Attributsname würde geändert. Man muss da ein Wert erneut eintragen
                  • E Offline
                    eBBeL
                    @Bluefox:
                    Attributsname würde geändert. Man muss da ein Wert erneut eintragen `
                    Ich steh auf dem Schlauch. Wo genau?
                    • BluefoxB Offline
                      BluefoxB Offline
                      hier
                      48_2017-12-18_22_27_46-iobroker.s7__d__pwork_node_modules_iobroker.s7__-_d__pwork_iobroker.repositories.png
                      • E Offline
                        eBBeL
                        Hi bluefox.
                        Danke für den Screenshot, macht aber leider keinen Unterschied.
                        Habe den Wert entfernt und per Explorer dann den Wert vom Tankerkönig nochmal neu ausgewählt.
                        Auch ein neues Widget anlegen bringt leider nix.
                        Viele Grüße
                        • eric2905E Offline
                          eric2905E Offline
                          eric2905
                          Du hast eine PN.
                          Gruß,
                          Eric
                          • eric2905E eric2905
                            Du hast eine PN.
                            Gruß,
                            Eric
                            thomke67
                            @eric2905 Hi, bin neu im Forum und möchte mich zuerst bei allen Aktiven bedanken!
                            Ich fand die Lösung auf dem Screenshot super und wollte das nachbauen, aber mein Problem ist genau das gleiche. Bekomme auch "null" angezeigt. Kann ich auch eine Nachricht haben, wie man das ändern kann?
                            Thomas
                            Gruß,
                            Thomas
