  3. Off Topic
  4. Pivccu E: Sub-process /usr/bin/dpkg
    6.0k
21 Beiträge 2 Kommentatoren 2.7k Aufrufe 2 Beobachtet
  • H Offline
    HerrFrodo
    @thomas-braun Jetzt hab ich richtig Mist :-(
    Ich hatte versucht InfluxDB zu installieren, doch das funktionierte nicht.
    Nun kommt folgendes:
    pi@raspberrypi:~ $ sudo apt update
    E: Conflicting values set for option Signed-By regarding source https://repos.influxdata.com/debian/ stable: /usr/share/keyrings/influxdata-archive_compat.gpg != /usr/share/keyrings/influxdb-archive-keyring.gpg
    E: The list of sources could not be read.
    Wo ein Wille ist, ist auch ein LAN!
    • H HerrFrodo
      @herrfrodo
      sudo rm /etc/apt/sources.list.d/infl*
      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      rm influxdata-archive_compat.key
      sudo apt update
      • H Offline
        HerrFrodo
        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/infl*
        pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
        pi@raspberrypi:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
        influxdata-archive_compat.key: OK
        pi@raspberrypi:~ $ echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
        pi@raspberrypi:~ $ rm influxdata-archive_compat.key
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fetched 48.4 kB in 2s (21.9 kB/s)
        Reading package lists... Done
        All packages are up to date.
        pi@raspberrypi:~ $ Sudo apt upgrade
        -bash: Sudo: command not found
        pi@raspberrypi:~ $ sudo apt upgrade
        Calculating upgrade... Done
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        1 not fully installed or removed.
        After this operation, 0 B of additional disk space will be used.
        Do you want to continue? [Y/n] y
        Setting up pivccu-modules-raspberrypi (2.0-19) ...
        sed: can't read /var/lib/piVCCU/dtb/config.txt: No such file or directory
        dpkg: error processing package pivccu-modules-raspberrypi (--configure):
         installed pivccu-modules-raspberrypi package post-installation script subprocess returned error exit status 2
        Errors were encountered while processing:
        E: Sub-process /usr/bin/dpkg returned an error code (1)
        pi@raspberrypi:~ $
        Super! Vielen Dank!
        Wie kann ich am sichersten influxdb und grafana installieren?
        • H HerrFrodo
          pi@raspberrypi:~ $
          Super! Vielen Dank!
          @herrfrodo sagte in Pivccu E: Sub-process /usr/bin/dpkg:
          sudo apt update
          sudo apt install grafana influxdb2
          H 1 Antwort Letzte Antwort
            sudo apt update
            HerrFrodo
            pi@raspberrypi:~ $ sudo apt install influxdb2
            The following additional packages will be installed:
              influxdb2-cli
            The following NEW packages will be installed:
              influxdb2 influxdb2-cli
            0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
            Need to get 56.1 MB of archives.
            After this operation, 128 MB of additional disk space will be used.
            Get:1 https://repos.influxdata.com/debian stable/main arm64 influxdb2 arm64 2.7.5-1 [45.4 MB]
            Get:2 https://repos.influxdata.com/debian stable/main arm64 influxdb2-cli arm64 2.7.3-1 [10.7 MB]
            Fetched 56.1 MB in 10s (5551 kB/s)
            Selecting previously unselected package influxdb2.
            (Reading database ... 91522 files and directories currently installed.)
            Preparing to unpack .../influxdb2_2.7.5-1_arm64.deb ...
            Unpacking influxdb2 (2.7.5-1) ...
            Selecting previously unselected package influxdb2-cli.
            Preparing to unpack .../influxdb2-cli_2.7.3-1_arm64.deb ...
            Unpacking influxdb2-cli (2.7.3-1) ...
            Setting up influxdb2 (2.7.5-1) ...
            ! Important 1.x to 2.x Upgrade Notice !
            Thank you for installing InfluxDB v2.  Due to significant changes between
            the v1 and v2 versions, upgrading to v2 requires additional steps.  If
            upgrading to v2 was not intended, simply re-install the v1 package now.
            An upgrade helper script is available that should be reviewed and executed
            prior to starting the influxdb systemd service.  In order to start the v2
            upgrade, execute the following:
            sudo /usr/share/influxdb/influxdb2-upgrade.sh
            Visit our website for complete details on the v1 to v2 upgrade process:
            https://docs.influxdata.com/influxdb/latest/upgrade/v1-to-v2/
            For new or upgrade installations, please review the getting started guide:
            https://docs.influxdata.com/influxdb/latest/get-started/
            Setting up influxdb2-cli (2.7.3-1) ...
            pi@raspberrypi:~ $ sudo apt install grafana
            E: Unable to locate package grafana
            pi@raspberrypi:~ $
            • H HerrFrodo
                influxdb2-cli
              pi@raspberrypi:~ $
              @herrfrodo
              Das Grafana-Repo muss zuvor angelegt werden:
              wget -qO- http://phoscon.de/apt/deconz.pub.key | sudo gpg --dearmor -o /usr/share/keyrings/deconz.gpg > /dev/null
              sudo sh -c "echo 'deb [signed-by=/usr/share/keyrings/deconz.gpg] http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
              sudo apt update
                @herrfrodo
                sudo apt update
                HerrFrodo
                pi@raspberrypi:~ $ wget -qO- http://phoscon.de/apt/deconz.pub.key | sudo gpg --dearmor -o /usr/share/keyrings/deconz.gpg > /dev/null
                pi@raspberrypi:~ $ sudo sh -c "echo 'deb [signed-by=/usr/share/keyrings/deconz.gpg] http://phoscon.de/apt/deconz $(lsb_release -cs) main' > /etc/apt/sources.list.d/deconz.list"
                Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
                Hit:5 http://security.debian.org/debian-security bullseye-security InRelease
                Get:6 http://phoscon.de/apt/deconz bullseye InRelease [4327 B]
                Hit:7 https://repos.influxdata.com/debian stable InRelease
                Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
                Get:9 http://phoscon.de/apt/deconz bullseye/main arm64 Packages [549 B]
                Get:10 http://phoscon.de/apt/deconz bullseye/main armhf Packages [545 B]
                Fetched 49.5 kB in 2s (22.2 kB/s)
                pi@raspberrypi:~ $
                • H HerrFrodo
                  pi@raspberrypi:~ $
                  @herrfrodo
                  OOOOOH, SORRY!
                  Hab in die falsche Schublade gegriffen!
                  sudo rm /etc/apt/sources.list.d/deconz.list
                  sudo rm /usr/share/keyrings/deconz.gpg
                  sudo apt-get install -y apt-transport-https
                  sudo apt-get install -y software-properties-common wget
                  sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                  echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                  sudo apt update
                    @herrfrodo
                    OOOOOH, SORRY!
                    sudo apt update
                    HerrFrodo
                    pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/deconz.list
                    pi@raspberrypi:~ $ sudo rm /usr/share/keyrings/deconz.gpg
                    pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
                      apt-transport-https
                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 160 kB of archives.
                    After this operation, 166 kB of additional disk space will be used.
                    Get:1 http://deb.debian.org/debian bullseye/main arm64 apt-transport-https all 2.2.4 [160 kB]
                    Fetched 160 kB in 0s (1646 kB/s)
                    Selecting previously unselected package apt-transport-https.
                    (Reading database ... 91537 files and directories currently installed.)
                    Preparing to unpack .../apt-transport-https_2.2.4_all.deb ...
                    Unpacking apt-transport-https (2.2.4) ...
                    Setting up apt-transport-https (2.2.4) ...
                    pi@raspberrypi:~ $ sudo apt-get install -y software-properties-common wget
                    wget is already the newest version (1.21-1+deb11u1).
                    wget set to manually installed.
                      gir1.2-packagekitglib-1.0 libappstream4 libpackagekit-glib2-18 libstemmer0d
                      packagekit packagekit-tools python3-dbus python3-distro-info python3-gi
                      python3-pycurl python3-software-properties unattended-upgrades
                    Suggested packages:
                      appstream python-dbus-doc python3-dbus-dbg libcurl4-gnutls-dev
                      python-pycurl-doc python3-pycurl-dbg bsd-mailx default-mta
                      | mail-transport-agent needrestart powermgmt-base
                      python3-pycurl python3-software-properties software-properties-common
                      unattended-upgrades
                    0 upgraded, 13 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 1667 kB of archives.
                    After this operation, 7404 kB of additional disk space will be used.
                    Get:1 http://deb.debian.org/debian bullseye/main arm64 libpackagekit-glib2-18 arm64 1.2.2-2 [113 kB]
                    Get:2 http://deb.debian.org/debian bullseye/main arm64 gir1.2-packagekitglib-1.0 arm64 1.2.2-2 [36.8 kB]
                    Get:3 http://deb.debian.org/debian bullseye/main arm64 libstemmer0d arm64 2.1.0-1 [113 kB]
                    Get:4 http://deb.debian.org/debian bullseye/main arm64 libappstream4 arm64 0.14.4-1 [160 kB]
                    Get:5 http://deb.debian.org/debian bullseye/main arm64 packagekit arm64 1.2.2-2 [575 kB]
                    Get:6 http://deb.debian.org/debian bullseye/main arm64 packagekit-tools arm64 1.2.2-2 [39.9 kB]
                    Get:7 http://deb.debian.org/debian bullseye/main arm64 python3-dbus arm64 1.2.16-5 [105 kB]
                    Get:8 http://deb.debian.org/debian bullseye/main arm64 python3-distro-info all 1.0+deb11u1 [8860 B]
                    Get:9 http://deb.debian.org/debian bullseye/main arm64 python3-gi arm64 3.38.0-2 [226 kB]
                    Get:10 http://deb.debian.org/debian bullseye/main arm64 python3-pycurl arm64 7.43.0.6-5 [67.9 kB]
                    Get:11 http://deb.debian.org/debian bullseye/main arm64 python3-software-properties all 0.96.20.2-2.1 [49.7 kB]
                    Get:12 http://deb.debian.org/debian bullseye/main arm64 software-properties-common all 0.96.20.2-2.1 [83.4 kB]
                    Get:13 http://deb.debian.org/debian bullseye/main arm64 unattended-upgrades all 2.8 [88.6 kB]
                    Fetched 1667 kB in 0s (5420 kB/s)
                    Preconfiguring packages ...
                    Selecting previously unselected package libpackagekit-glib2-18:arm64.
                    (Reading database ... 91541 files and directories currently installed.)
                    Preparing to unpack .../00-libpackagekit-glib2-18_1.2.2-2_arm64.deb ...
                    Unpacking libpackagekit-glib2-18:arm64 (1.2.2-2) ...
                    Selecting previously unselected package gir1.2-packagekitglib-1.0.
                    Preparing to unpack .../01-gir1.2-packagekitglib-1.0_1.2.2-2_arm64.deb ...
                    Unpacking gir1.2-packagekitglib-1.0 (1.2.2-2) ...
                    Selecting previously unselected package libstemmer0d:arm64.
                    Preparing to unpack .../02-libstemmer0d_2.1.0-1_arm64.deb ...
                    Unpacking libstemmer0d:arm64 (2.1.0-1) ...
                    Selecting previously unselected package libappstream4:arm64.
                    Preparing to unpack .../03-libappstream4_0.14.4-1_arm64.deb ...
                    Unpacking libappstream4:arm64 (0.14.4-1) ...
                    Selecting previously unselected package packagekit.
                    Preparing to unpack .../04-packagekit_1.2.2-2_arm64.deb ...
                    Unpacking packagekit (1.2.2-2) ...
                    Selecting previously unselected package packagekit-tools.
                    Preparing to unpack .../05-packagekit-tools_1.2.2-2_arm64.deb ...
                    Unpacking packagekit-tools (1.2.2-2) ...
                    Selecting previously unselected package python3-dbus.
                    Preparing to unpack .../06-python3-dbus_1.2.16-5_arm64.deb ...
                    Unpacking python3-dbus (1.2.16-5) ...
                    Selecting previously unselected package python3-distro-info.
                    Preparing to unpack .../07-python3-distro-info_1.0+deb11u1_all.deb ...
                    Unpacking python3-distro-info (1.0+deb11u1) ...
                    Selecting previously unselected package python3-gi.
                    Preparing to unpack .../08-python3-gi_3.38.0-2_arm64.deb ...
                    Unpacking python3-gi (3.38.0-2) ...
                    Selecting previously unselected package python3-pycurl.
                    Preparing to unpack .../09-python3-pycurl_7.43.0.6-5_arm64.deb ...
                    Unpacking python3-pycurl (7.43.0.6-5) ...
                    Selecting previously unselected package python3-software-properties.
                    Preparing to unpack .../10-python3-software-properties_0.96.20.2-2.1_all.deb ...
                    Unpacking python3-software-properties (0.96.20.2-2.1) ...
                    Selecting previously unselected package software-properties-common.
                    Preparing to unpack .../11-software-properties-common_0.96.20.2-2.1_all.deb ...
                    Unpacking software-properties-common (0.96.20.2-2.1) ...
                    Selecting previously unselected package unattended-upgrades.
                    Preparing to unpack .../12-unattended-upgrades_2.8_all.deb ...
                    Unpacking unattended-upgrades (2.8) ...
                    Setting up python3-dbus (1.2.16-5) ...
                    Setting up libpackagekit-glib2-18:arm64 (1.2.2-2) ...
                    Setting up gir1.2-packagekitglib-1.0 (1.2.2-2) ...
                    Setting up python3-pycurl (7.43.0.6-5) ...
                    Setting up python3-software-properties (0.96.20.2-2.1) ...
                    Setting up python3-gi (3.38.0-2) ...
                    Setting up libstemmer0d:arm64 (2.1.0-1) ...
                    Setting up python3-distro-info (1.0+deb11u1) ...
                    Setting up libappstream4:arm64 (0.14.4-1) ...
                    Setting up software-properties-common (0.96.20.2-2.1) ...
                    Setting up unattended-upgrades (2.8) ...
                    Creating config file /etc/apt/apt.conf.d/20auto-upgrades with new version
                    Creating config file /etc/apt/apt.conf.d/50unattended-upgrades with new version
                    Created symlink /etc/systemd/system/multi-user.target.wants/unattended-upgrades.service → /lib/systemd/system/unattended-upgrades.service.
                    Synchronizing state of unattended-upgrades.service with SysV service script with /lib/systemd/systemd-sysv-install.
                    Executing: /lib/systemd/systemd-sysv-install enable unattended-upgrades
                    Setting up packagekit (1.2.2-2) ...
                    Created symlink /etc/systemd/user/sockets.target.wants/pk-debconf-helper.socket → /usr/lib/systemd/user/pk-debconf-helper.socket.
                    Setting up packagekit-tools (1.2.2-2) ...
                    Processing triggers for man-db (2.9.4-2) ...
                    Processing triggers for dbus (1.12.28-0+deb11u1) ...
                    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
                    pi@raspberrypi:~ $ sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                    pi@raspberrypi:~ $ echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Get:5 https://apt.grafana.com stable InRelease [5984 B]
                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                    Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
                    Get:9 https://apt.grafana.com stable/main arm64 Packages [163 kB]
                    Get:10 https://apt.grafana.com stable/main armhf Packages [129 kB]
                    Fetched 298 kB in 3s (118 kB/s)
                      musl
                      grafana musl
                    Need to get 103 MB of archives.
                    After this operation, 391 MB of additional disk space will be used.
                    Get:1 http://deb.debian.org/debian bullseye/main arm64 musl arm64 1.2.2-1 [399 kB]
                    Get:2 https://apt.grafana.com stable/main arm64 grafana arm64 10.3.3 [103 MB]
                    Fetched 103 MB in 15s (7053 kB/s)
                    Selecting previously unselected package musl:arm64.
                    (Reading database ... 91931 files and directories currently installed.)
                    Preparing to unpack .../musl_1.2.2-1_arm64.deb ...
                    Unpacking musl:arm64 (1.2.2-1) ...
                    Selecting previously unselected package grafana.
                    Preparing to unpack .../grafana_10.3.3_arm64.deb ...
                    Unpacking grafana (10.3.3) ...
                    Setting up musl:arm64 (1.2.2-1) ...
                    Setting up grafana (10.3.3) ...
                    Adding system user `grafana' (UID 111) ...
                    Adding new user `grafana' (UID 111) with group `grafana' ...
                    Not creating home directory `/usr/share/grafana'.
                    ### NOT starting on installation, please execute the following statements to configure grafana to start automatically using systemd
                     sudo /bin/systemctl daemon-reload
                     sudo /bin/systemctl enable grafana-server
                    ### You can start grafana-server by executing
                     sudo /bin/systemctl start grafana-server
                    pi@raspberrypi:~ $
                    Kein Problem! Trotzdem vielen Dank! :-)
                    Bis auf Pivccu scheint ja alles zu funktionieren.
                    WIe muss ich influxdb und grafana jetzt einrichten?
                    • H HerrFrodo
                        apt-transport-https
                      Suggested packages:
                        unattended-upgrades
                        musl
                        grafana musl
                      pi@raspberrypi:~ $
                      Anleitungen lesen?
                        Anleitungen lesen?
                        HerrFrodo
                        YouTube Videos schauen?
                        Nach der Influxdb2 Installation, gelangt man im Browser über Port 8086 auf die landing page.
                        Im ioBroker muss man den Influx-Adapter installieren und die zuvor festgelegten influxdb2-Konfigurationsdaten dort eingeben.
                        Wenn dann alles funzt, dann kann man in den Objekten am rechten Rand die Datenbank aktivieren.
                        • H HerrFrodo
                          Dann aber die richtigen. Die wenigsten sind gut.
