  4. Neuer Adapter für Roborock-Staubsauger
    6.4k
1.1k Beiträge 155 Kommentatoren 475.3k Aufrufe 138 Beobachtet
    tritanium
    #496
    @copystring
    Kurze Review nach dem Wochenende :-) :
    Adapter läuft stabil, ebenfalls die Funktionen dessen, lediglich das hier kommt jedesmal wenn unsere beiden unterwegs sind
    roborock.0
       2024-01-23 08:12:03.013	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447870 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:12:00.758	warn	Failed to execute get_clean_record_map on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with 447869 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:58.010	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447857 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:53.065	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447856 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:50.326	warn	Failed to execute get_clean_record_map on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with 447845 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:47.992	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447843 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:43.086	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447832 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:40.012	warn	Failed to execute get_clean_record_map on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with 447831 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:38.032	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447829 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:32.991	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447818 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:29.713	warn	Failed to execute get_clean_record_map on robot 5kt1jy0ATJPgji5k0hJAZg Error: Request with 447812 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:27.997	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447805 timed out after 10 seconds for response.301
    roborock.0
       2024-01-23 08:11:22.978	warn	Failed to execute get_map_v1 on robot 4Si5s3DNcsl0ATAl8e5UdI Error: Request with 447804 timed out after 10 seconds for response.301
    Kann man dort nochmal nachschauen und das in den Griff bekommen ??
    Was brauchst du dazu? Debugs ??
    grüße Micha
    • BanditFGB Offline
      BanditFGB Offline
      BanditFG
      #497
      könnte mir bitte mal jemand erklären wie ich in meiner Vis eine Karte von meinem Roborock Q Revo angezeigt bekomme?
      Ich habe die aktuelle Dev installiert.
      • BanditFGB BanditFG
        tritanium
        #498
        @banditfg
        in der Adapter Konfi steht ein Webserver Port angegeben ...(kannst du auch ändern):
        wenn du dann:
        http://ip_vom_iobroker:dann_den_port/map.html
        aufrufst, bekommst du "normalerweise" die Karte angezeigt.... also so in etwa:
        grüsse Micha
        • FlexerF Offline
          FlexerF Offline
          Flexer
          #499
          @copystring
          Kleine Anregung. Könntest du so nett sein und in deinem aller ersten Post oben den DEV Link platzieren? Ich muss den immer bei den 500 post hier suchen. Grüße
          Unterm Strich ist alles besser.
          Ja, voll geil hier!
          • FlexerF Flexer
            @copystring
            da_WoodyD Offline
            da_WoodyD Offline
            #500
            @flexer hehe, hab mir schon einen shortcut in den lesezeichen gemacht...
            https://github.com/copystring/ioBroker.roborock/tree/dev
            • T tritanium
              @banditfg
              wenn du dann:
              grüsse Micha
              TimoWald
              #501
              @tritanium da kommt bei mir....
              copystringC 1 Antwort Letzte Antwort
              • T TimoWald
                copystringC Offline
                copystringC Offline
                copystring
                #502
                @timowald damit das geht, muss die Kartenerstellung aktiviert sein.
                Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
                https://paypal.me/copystring
                • copystringC copystring
                  TimoWald
                  #503
                  @copystring der Haken Kartenerstellung ist aktiviert im Adapter.
                  • T TimoWald
                    copystringC Offline
                    copystringC Offline
                    copystring
                    #504
                    @timowald welches System? Ein Raspberry Pi?
                      TimoWald
                      #505
                      @copystring ioBroker im Container auf Proxmox.
                      • T TimoWald
                        copystringC Offline
                        copystringC Offline
                        copystring
                        #506
                        @timowald OK. Dann eröffne bitte ein Issue auf GitHub und lade ein Debuglog hoch.
                        T da_WoodyD 2 Antworten Letzte Antwort
                          TimoWald
                          #507
                          @copystring Sorry dafür fehlt mir die Erfahrung.
                            da_WoodyD Offline
                            da_WoodyD Offline
                            #508
                            @copystring öhhm, hab's im Browser noch nie probiert. In einer Visu sollte das trotzdem klappen.
                            Kann mir aber vorstellen, daß der Aufruf in Chrome nicht klappt. Sie Fehlermeldung Standard Browser..
                            • R Offline
                              Rushmed
                              #509
                              ich habe jetzt nich den ganzen Thread durchgelesen.
                              Nutze aktuell den mihome-vacuum Adapter und wollte eigentlich mal diesen hier testen.
                              Jetzt steht auf Github dass mit nem PI keine Kartenerstellung möglich ist.
                              Stimmt das? Ist das aktuell? Betrifft das nur das Zone Cleaning?
                              • R Rushmed
                                da_WoodyD Offline
                                da_WoodyD Offline
                                #510
                                @rushmed stimmt so nicht, da muss die karte nur anders aufgerufen werden. finde den link leider nicht...
                                hah, steht ja eh auf github... :D
                                http://iobrokerip:6824/map.html
                                so kannst du das aufrufen und auch in der visu einbauen...
                                sogar gleich mit steuerung
                                R 1 Antwort Letzte Antwort
                                • da_WoodyD da_Woody
                                  Rushmed
                                  #511
                                  @da_woody Danke, ich probier' das mal.
                                  • BanditFGB Offline
                                    BanditFGB Offline
                                    BanditFG
                                    #512
                                    hallo ich hätte noch paar Sachen. 😁
                                    kann man die Karte irgendwie anders in die Vis bekommen? Ich habe im Vis Edit einen Basic iFrame genutzt, damit ist die Karte leider sehr klein, auch wenn ich das Fenster größer ziehe.
                                    das Einstellungsmenü sieht bei mir sehr komisch aus, irgendwie abgeschnitten ist das normal??
                                    Und dann habe ich noch folgen Warnungen und Fehler!
                                    2024-01-24 12:28:43.371	warn	Failed to execute get_clean_record_map on robot 3EcEZGCAdEH696MqPr7iv1 Error: Request with id 71 with method get_clean_record_map timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:28:27.419	warn	Failed to execute get_clean_record_map on robot 3EcEZGCAdEH696MqPr7iv1 Error: Request with id 24 with method get_clean_record_map timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:28:23.756	warn	Failed to execute get_network_info on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 10 with method get_network_info timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:28:14.468	info	Starting adapter finished. Lets go!!!!!!!
                                    roborock.0
                                    2024-01-24 12:24:33.376	info	MQTT initialized
                                    roborock.0
                                    2024-01-24 12:24:27.531	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                                    roborock.0
                                    2024-01-24 12:24:27.487	info	starting. Version 0.5.1 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.18.2, js-controller: 5.0.17
                                    roborock.0
                                    2024-01-24 12:23:51.278	info	terminating
                                    roborock.0
                                    2024-01-24 12:23:50.772	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    roborock.0
                                    2024-01-24 12:23:50.768	info	terminating
                                    roborock.0
                                    2024-01-24 12:23:50.738	error	Exception-Code: ERR_OUT_OF_RANGE: The value of "offset" is out of range. It must be an integer. Received 317.5
                                    roborock.0
                                    2024-01-24 12:23:50.738	error	RangeError: The value of "offset" is out of range. It must be an integer. Received 317.5 at new NodeError (node:internal/errors:405:5) at boundsError (node:internal/buffer:82:11) at Buffer.readUInt32BE (node:internal/buffer:311:5) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:51:32) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at addChunk (node:internal/streams/readable:335:12) at readableAddChunk (node:internal/streams/readable:308:9) at Socket.Readable.push (node:internal/streams/readable:245:10) at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
                                    roborock.0
                                    2024-01-24 12:23:50.733	error	unhandled promise rejection: The value of "offset" is out of range. It must be an integer. Received 317.5
                                    roborock.0
                                    2024-01-24 12:23:50.730	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    roborock.0
                                    2024-01-24 12:21:30.677	warn	Failed to execute get_room_mapping on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 34707 with method get_room_mapping timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:20:29.944	warn	Failed to execute get_map_v1 on robot 3EcEZGCAdEH696MqPr7iv1 retry
                                    roborock.0
                                    2024-01-24 12:20:00.707	warn	Failed to execute get_room_mapping on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 34544 with method get_status timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:10:30.082	warn	Failed to execute get_map_v1 on robot 3EcEZGCAdEH696MqPr7iv1 retry
                                    roborock.0
                                    2024-01-24 12:06:49.567	warn	MQTT connection reconnect.
                                    roborock.0
                                    2024-01-24 12:06:49.567	warn	MQTT connection close.
                                    roborock.0
                                    2024-01-24 12:06:49.531	warn	Reconnecting mqtt client!
                                    roborock.0
                                    2024-01-24 12:04:01.098	warn	Failed to execute get_carpet_clean_mode on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 33025 with method get_carpet_clean_mode timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:03:31.107	warn	Failed to execute get_carpet_mode on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 32966 with method get_carpet_mode timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:03:01.139	warn	Failed to execute get_map_v1 on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 32914 with method get_room_mapping timed out after 10 seconds for response.102
                                    roborock.0
                                    2024-01-24 12:01:40.453	warn	Failed to execute get_map_v1 on robot 3EcEZGCAdEH696MqPr7iv1 retry
                                    roborock.0
                                    2024-01-24 12:00:01.239	warn	Failed to execute get_network_info on robot 3EcEZGCAdEH696MqPr7iv1 Error: Local request with id 32581 with method get_network_info timed out after 10 seconds for response.102
                                    • Karsten MüllerK Offline
                                      Karsten Müller
                                      schrieb am zuletzt editiert von Karsten Müller
                                      #513
                                      ich möchte gerne mit diesem Adapter meinen zum Black Friday erworbenen Roborock S8 Pro Ultra einbinden. Nach einem zunächst mühsamen, aber inzwischen erfolgreichen iobroker-Upgrade (docker image v5->v9) läuft der Adapter. Nun scheitere ich allerdings daran, dass im Adapter die Eingabe von User und Passwort gefordert wird - habe ich aber nicht, da ich in der Roborock-App die Anmeldung per Google nutze.
                                      Testweise habe ich einen neuen Account mit User / Passwort eingerichtet. Da ich die schon weit fortgeschrittene Einrichtung des Roborocks in der App nicht von vorne beginnen möchte, habe ich von meinem Google-Account aus den Roborock mit dem neuen Account geteilt.
                                      Nun wird er immerhin unter HomeData unter receivedDevices angezeigt:
                                      Allerdings scheint keine Steuerung solcher Freigaben möglich zu sein, jedenfalls ist roborock.0.Devices leer (und receivedDevices gibt es nicht als Knoten), und auch die Map sieht nicht gut aus:
                                      Hat jemand einen Tipp? Oder könnte man entweder Google-Authentifizierung oder die Steuerbarkeit geteilter Geräte mit in den Adapter einbauen?
                                      @copystring hältst du einer der beiden Punkte für umsetzbar?
                                      • da_WoodyD Offline
                                        da_WoodyD Offline
                                        #514
                                        @copystring hab gerade eine neu saugung gestartet. karte wird wieder nicht aktualisiert.
                                        mal flux in den objekten nachgelinst. leider nur foto.
                                        zeitstempel passt ja, nur zuletzt geändert wird nicht aktualisiert.
                                        somit denke ich, daß deswegen die karte nicht klappt.
                                        was meinst du dazu? falsche einstellung? fehler im system?
                                        auch nach neustart vom adapter bleibt der DP gleich.
                                        edit:
                                        spinn ich? ne halbe stunde später hab ich plötzlich was anderes im DP...
                                        • copystringC Offline
                                          copystringC Offline
                                          copystring
                                          #515
                                          Hallo zusammen. Ich möchte hier nochmal daran erinnern, dass Probleme oder wünsche bitte auf GitHub als Issue zu erstellen. Mein Zeit ist aktuell sehr begrenzt. Damit die begrenzte Zeit möglichst effektiv verwendet werden kann, tut mir bitte den Gefallen und erstellt bitte ein entsprechendes Issue. Danke.
