  4. Neuer Adapter für Roborock-Staubsauger
    6.4k
1.1k Beiträge 155 Kommentatoren 475.3k Aufrufe 138 Beobachtet
  • T tritanium
    @copystring
    Okay, geht klar.... spiele eben die /dev neu ein....
    tritanium
    schrieb am zuletzt editiert von tritanium
    #469
    @copystring
    Habe extra gewartet :-)
    1h ist rum und et voila:
    2024-01-18 01:22:32.127 - info: jarvis.0 (20074) Found Backups for settings.
    2024-01-18 01:22:32.129 - info: jarvis.0 (20074) Found Backups for scripts.
    2024-01-18 01:22:32.130 - info: jarvis.0 (20074) Found Backups for styles.
    2024-01-18 01:22:32.164 - info: jarvis.0 (20074) Connection: WebSocket opened on port 8400 using http...
    2024-01-18 01:22:32.168 - info: jarvis.0 (20074) Found Backups for widgets.
    2024-01-18 01:22:32.191 - info: jarvis.0 (20074) Found Backups for devices.
    2024-01-18 01:22:34.905 - info: jarvis.0 (20074) Client with IP 192.168.50.49 connected.
    2024-01-18 01:22:41.406 - info: jarvis.0 (20074) Client with IP 192.168.50.49 disconnected.
    2024-01-18 01:22:42.255 - info: jarvis.0 (20074) Client with IP 192.168.50.49 connected.
    2024-01-18 01:22:51.308 - info: jarvis.0 (20074) Client with IP 192.168.50.49 disconnected.
    2024-01-18 01:22:52.201 - info: jarvis.0 (20074) Client with IP 192.168.50.49 connected.
    2024-01-18 01:24:27.498 - info: linux-control.0 (1880) getting data from ioBroker (192.168.50.5:22)
    2024-01-18 01:24:36.612 - info: linux-control.0 (1880) successful received data from ioBroker (192.168.50.5:22)
    2024-01-18 01:25:58.800 - warn: roborock.0 (6634) Reconnecting mqtt client!
    2024-01-18 01:25:58.840 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:25:58.842 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:25:58.996 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:25:59.996 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:26:00.102 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:26:01.102 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:26:01.203 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:26:02.203 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:26:02.314 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:26:03.315 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:26:03.418 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:26:04.419 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:26:04.522 - warn: roborock.0 (6634) MQTT connection close.
    2024-01-18 01:26:05.522 - warn: roborock.0 (6634) MQTT connection reconnect.
    2024-01-18 01:26:05.627 - warn: roborock.0 (6634) MQTT connection close.
    Aber ich gehe nun erst einmal in die Falle. Den Adapter lasse ich solange aus ;-)
    NACHTRAG:
    Wenn ich den Adapter beende kommt das hier nich im Log:
    host.iobroker
    	2024-01-18 01:47:36.327	info	instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    roborock.0
    	2024-01-18 01:47:36.138	error	DB closed
    roborock.0
    	2024-01-18 01:47:36.138	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
    roborock.0
    	2024-01-18 01:47:36.137	error	unhandled promise rejection: DB closed
    roborock.0
    	2024-01-18 01:47:36.137	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    	2024-01-18 01:47:36.133	error	DB closed
    roborock.0
    	2024-01-18 01:47:36.132	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
    roborock.0
    	2024-01-18 01:47:36.131	error	unhandled promise rejection: DB closed
    roborock.0
    	2024-01-18 01:47:36.131	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    	2024-01-18 01:47:36.068	error	DB closed
    roborock.0
    	2024-01-18 01:47:36.068	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:632:26) at Socket.emit (node:events:517:28) at Socket.emit (node:domain:489:12) at TCP.<anonymous> (node:net:350:12)
    roborock.0
    	2024-01-18 01:47:36.055	error	unhandled promise rejection: DB closed
    roborock.0
    	2024-01-18 01:47:36.054	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    roborock.0
    	2024-01-18 01:47:36.041	info	terminating
    So als Info noch :-) und nun Gute N8
    • copystringC copystring
      Bitte die neue dev von gerade eben installieren. Dort wurde der mqtt client aktualisiert.
      da_WoodyD Offline
      da_WoodyD Offline
      #470
      @copystring sagte in Neuer Adapter für Roborock-Staubsauger:
      hmpf, gerade eben...
      hab nach der vorigen dev um 23:25 den adapter angeworfen. wie du sagtest, um 00:26 gings los... 1 stunde.
      ok, werd updaten und das teil wieder anwerfen.
        da_WoodyD Offline
        da_WoodyD Offline
        #471
        @copystring schlechte nachrichten. nach ziemlich genau einer stunde wieder
        roborock.0
        2024-01-18 06:39:49.784	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:48.783	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:48.688	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:47.687	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:47.589	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:46.587	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:46.484	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:45.483	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:45.376	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:44.376	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:44.270	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:43.269	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:43.170	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:42.170	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:42.053	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
        roborock.0
        2024-01-18 06:39:42.009	warn	MQTT connection reconnect.
        roborock.0
        2024-01-18 06:39:42.009	warn	MQTT connection close.
        roborock.0
        2024-01-18 06:39:41.984	warn	Reconnecting mqtt client!
        roborock.0
        2024-01-18 06:38:42.030	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
        roborock.0
        2024-01-18 06:37:41.944	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
        roborock.0
        2024-01-18 06:36:41.919	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
        gestartet um
        roborock.0
        2024-01-18 05:39:42.337	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
        roborock.0
        2024-01-18 05:39:42.337	debug	All mapped rooms: []
        roborock.0
        2024-01-18 05:39:42.336	debug	Length of message queue: 0
        roborock.0
        2024-01-18 05:39:42.288	debug	Length of message queue: 1
        roborock.0
        2024-01-18 05:39:42.246	debug	Length of message queue: 1
        roborock.0
        2024-01-18 05:39:42.153	debug	Length of message queue: 0
        roborock.0
        2024-01-18 05:39:42.116	debug	Length of message queue: 1
        roborock.0
        2024-01-18 05:39:42.116	debug	Not clearing messageQueue. null - 64911
        roborock.0
        2024-01-18 05:39:42.116	debug	dps debug: {"id":3,"result":["ok"]}
        roborock.0
        2024-01-18 05:39:42.079	debug	Length of message queue: 1
        roborock.0
        2024-01-18 05:39:41.902	debug	getParameter for 5umEnoJEB0hmM5UmYlkumw: get_room_mapping
        roborock.0
        2024-01-18 05:39:41.900	debug	Length of message queue: 0
        roborock.0
        2024-01-18 05:39:41.827	debug	get_status: {"msg_ver":2,"msg_seq":191,"state":8,"battery":100,"clean_time":82,"clean_area":2185000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0}
        roborock.0
        2024-01-18 05:39:41.827	debug	Length of message queue: 0
        roborock.0
        2024-01-18 05:39:41.824	debug	getParameter for 5umEnoJEB0hmM5UmYlkumw: get_multi_maps_list
        roborock.0
        2024-01-18 05:39:41.823	debug	Length of message queue: 1
        roborock.0
        2024-01-18 05:39:41.756	debug	Firmware features request for 5umEnoJEB0hmM5UmYlkumw
        roborock.0
        2024-01-18 05:39:41.726	debug	System type: go2rtc_linux_amd64
        roborock.0
        2024-01-18 05:39:41.726	debug	platform: linux
        roborock.0
        2024-01-18 05:39:41.726	debug	arch: x64
        roborock.0
        2024-01-18 05:39:41.725	debug	Processing scene
        roborock.0
        2024-01-18 05:39:41.725	debug	Update map
        roborock.0
        2024-01-18 05:39:41.724	debug	getParameter for 5umEnoJEB0hmM5UmYlkumw: get_status
        roborock.0
        2024-01-18 05:39:41.724	debug	Latest data requested
        roborock.0
        2024-01-18 05:39:41.724	debug	getParameter for 5umEnoJEB0hmM5UmYlkumw: get_fw_features
        roborock.0
        2024-01-18 05:39:41.723	debug	5umEnoJEB0hmM5UmYlkumw online. Starting mainUpdateInterval.
        roborock.0
        2024-01-18 05:37:41.390	debug	MQTT connection connected {"cmd":"connack","retain":false,"qos":0,"dup":false,"length":2,"topic":null,"payload":null,"sessionPresent":false,"returnCode":0}.
        roborock.0
        2024-01-18 05:37:41.307	debug	tcp client for 5umEnoJEB0hmM5UmYlkumw connected
        roborock.0
        2024-01-18 05:37:40.939	debug	Robot key: roborock.vacuum.a08
        roborock.0
        2024-01-18 05:37:40.939	debug	RoomIDs debug: {"16510226":"Studio"}
        roborock.0
        2024-01-18 05:37:40.938	info	MQTT initialized
        roborock.0
        2024-01-18 05:37:40.909	debug	localDevices: {"5umEnoJEB0hmM5UmYlkumw":"192.168.1.15"}
        roborock.0
        2024-01-18 05:37:33.776	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
        roborock.0
        2024-01-18 05:37:33.764	info	starting. Version 0.5.1 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.19.0, js-controller: 5.0.17
        roborock.0
        2024-01-18 05:37:31.533	debug	Plugin sentry Initialize Plugin (enabled=true)
        das komplette log: iobroker.current.log.html
        • copystringC Offline
          copystringC Offline
          copystring
          #472
          Ich habe eine kleine Änderung in die dev geladen. Wer mag, kann das testen.
          Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
          https://paypal.me/copystring
            da_WoodyD Offline
            da_WoodyD Offline
            #473
            @copystring immerhin schon was...
            roborock.0
            	2024-01-19 07:37:59.872	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            roborock.0
            	2024-01-19 07:36:59.844	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            roborock.0
            	2024-01-19 07:35:59.878	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            roborock.0
            	2024-01-19 07:34:59.896	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            roborock.0
            	2024-01-19 07:34:59.608	warn	MQTT connection reconnect.
            roborock.0
            	2024-01-19 07:34:59.608	warn	MQTT connection close.
            roborock.0
            	2024-01-19 07:34:59.583	warn	Reconnecting mqtt client!
            roborock.0
            	2024-01-19 07:34:00.009	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            roborock.0
            	2024-01-19 07:32:59.919	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            roborock.0
            	2024-01-19 07:31:59.787	warn	Failed to map rooms. You need to name your rooms via the mobile app on your phone.
            also nach einer stunde nur ein reconnect.
            copystringC 1 Antwort Letzte Antwort
            • da_WoodyD da_Woody
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              roborock.0
              copystringC Offline
              copystringC Offline
              copystring
              #474
              @da_woody Ein reconnect in der Stunde ist normal. Beziehungsweise das war vorher alle drei Stunden. Müsste ich dann mal wieder zurückstellen.
                copystringC Offline
                copystring
                #475
                Die neue dev verbindet sich nun wieder wie gewohnt alle drei Stunden neu.
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #476
                  @copystring jau, war schlecht ausgedrückt. Klar, daß da hin und wieder ein reconnect kommt.
                  Werd später die neue dev draufklatschen.
                  Stört nur mehr das dauernde "failed to map"
                  Ich hab für den Robby halt nur einen Raum. Stiegen fahren kann er ja noch nicht... 🙄
                    tritanium
                    #477
                    Mooin :-D
                    Also JETZT nochmal die /dev installieren und dann sollte es normal laufen ??
                    • T tritanium
                      Mooin :-D
                      copystringC Offline
                      copystringC Offline
                      copystring
                      #478
                      @tritanium ja
                      T 2 Antworten Letzte Antwort
                        @tritanium ja
                        tritanium
                        #479
                        @copystring Sooooooo :-)
                        grade mal die /dev neu installiert.... Adapter startet...
                        roborock.0
                           2024-01-19 12:12:02.507	info	Starting adapter finished. Lets go!!!!!!!
                        linux-control.0
                           2024-01-19 12:10:03.589	info	successful received data from ioBroker (192.168.50.5:22)
                        linux-control.0
                           2024-01-19 12:09:54.047	info	getting data from ioBroker (192.168.50.5:22)
                        roborock.0
                           2024-01-19 12:08:15.080	warn	Failed to execute get_network_info on robot 5kt1jy0ATJPgji5k0hJAZg Error: Local request with id 10 with method get_network_info timed out after 10 seconds for response.102
                        roborock.0
                           2024-01-19 12:05:26.337	info	MQTT initialized
                        roborock.0
                           2024-01-19 12:05:20.027	info	Starting adapter. This might take a few minutes depending on your setup. Please wait.
                        roborock.0
                           2024-01-19 12:05:19.999	info	starting. Version 0.5.1 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.19.0, js-controller: 5.0.17
                        Dann warten wir mal ab ....
                          B0ck
                          #480
                          kann mir jemand erklären, wo ich den Datenpunkt zum entleeren des Staubbehälters finde? Ich habe mir den Objektbaum nun schon mehrfach angeschaut, finden kann ich den Datenpunkt allerdings nicht. Ich habe einen Roborock S7 Plus (mit Absaugstation)
                          Danke ung Gruß
                            @tritanium ja
                            tritanium
                            #481
                            @copystring
                            Hey Hey, 15:05 ... einmal disconnect, einmal reconnect... Zack fertig ... mehr nicht!
                            -> Daumen hoch :-D
                            Wenn das so bleibt... dann nix mehr ändern...
                            @jahnbes ...kannst dann auch testen ... ich habe die /dev um kurz vor 12 installiert und seit dem funktionierts wunderbar...
                            lg Micha
                            jahnbesJ 1 Antwort Letzte Antwort
                            • T tritanium
                              @copystring
                              -> Daumen hoch :-D
                              lg Micha
                              jahnbesJ Offline
                              jahnbesJ Offline
                              jahnbes
                              schrieb am zuletzt editiert von jahnbes
                              #482
                              @tritanium
                              Hoffnung!
                              13:31 Uhr neueste dev installiert und Instanz restartet
                              und nach über drei Stunden nun das:
                              2024-01-19 16:35:34.352	info	script.js.Test.roborock_log_dp: # Robi -> Find me [commands.find_me] = true -> false
                              2024-01-19 16:35:33.888	info	script.js.Test.roborock_log_dp: # Robi -> Find me [commands.find_me] = false -> true
                              roborock.0 2024-01-19 16:33:22.367	warn	MQTT connection reconnect.
                              roborock.0 2024-01-19 16:33:22.366	warn	MQTT connection close.
                              roborock.0 2024-01-19 16:33:22.333	warn	Reconnecting mqtt client!
                              Es läuft wieder! Kein endloses close-reconnect mehr. Klasse! 👍
                              Und trotzdem, wenn ändern notwendig ist, immer ran, immer weiterentwickeln!
                              Goethe, Faust: "Und sollt je ich mich auf ein Faulbett legen, sei es gleich um mich gescheh'n."
                              Gruß, jahnbes.
                              (Ich bin gespannt.)
                              • H hgerstung
                                Hi, und vielen Dank für den Adapter - grundsätzlich scheint bei mir (S7) alles zu funktionieren!
                                Eine Frage habe ich, gibt es eine Möglichkeit, über den Adapter einen Zeitplan des Robos zu deaktivieren/pausieren und wieder zu aktivieren? Unser Helferlein läuft nachts im EG und wenn wir Gäste haben, die da schlafen, dann wäre es super wenn man einen Befehl senden könnte, der den konfigurierten Zeitplan bis auf weiteres deaktiviert.
                                Falls jemand einen Tipp hat wäre ich dankbar!
                                hgerstung
                                #483
                                @hgerstung said in Neuer Adapter für Roborock-Staubsauger:
                                Hat keiner ne Idee? Schade, das wäre ne super praktische Funktion für mich ...
                                Heiko
                                I M 2 Antworten Letzte Antwort
                                • H hgerstung
                                  Heiko
                                  I Offline
                                  I Offline
                                  itwegner72
                                  #484
                                  @hgerstung
                                  Nimm den Zeitplan aus der App doch raus und lege einen in ioBroker an. Den könntest du den auch über einen eigenen Datenpunkt und sogar einen dementsprechenden Taster ein und ausschalten.
                                  H 1 Antwort Letzte Antwort
                                  • H hgerstung
                                    Heiko
                                    michael 1975
                                    #485
                                    @hgerstung Ich habe einen Datrenpunkt Besuch den Schalte ich an wenn besuch kommt damit werden manche Aktion nicht oder anders ausgeführt, der Robby läuft dann auch nicht allerdings starte ich meinen nicht nach zeitplan sondern wenn ich Abends Alexa Gute Nacht sage dann startet er nach einer Stunde.
                                    • jahnbesJ jahnbes
                                      @tritanium
                                      Hoffnung!
                                      Gruß, jahnbes.
                                      (Ich bin gespannt.)
                                      da_WoodyD Offline
                                      da_WoodyD Offline
                                      #486
                                      @jahnbes auch bei aller freude, bitte log in 32e649cc-2adc-48cb-8be4-007c05af15b5-grafik.png setzen... ;)
                                        jahnbesJ Offline
                                        jahnbesJ Offline
                                        jahnbes
                                        #487
                                        @da_woody
                                        Wenn Du mir sagst was, wo und warum? Ich hab trotz Suche nichts gefunden.
                                        Gruß jahnbes
                                        • jahnbesJ jahnbes
                                          @da_woody
                                          Gruß jahnbes
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          #488
                                          @jahnbes nuja, dei letztes posting.
                                          sollte so sein
