  3. Einsteigerfragen
  4. *** nodejs is NOT correctly installed ***[gelöst]
    5.5k
12 Beiträge 4 Kommentatoren 559 Aufrufe 3 Beobachtet
  • DuffyD Offline
    DuffyD Offline
    Duffy
    schrieb am zuletzt editiert von Duffy
    Hallo an alle Experten,
    ich wollte soeben mein Zigbee Adapter von 1.9.5 auf 1.9.7 anheben.
    Dabei erschien folhgender Fehler:
    $ iobroker upgrade zigbee@1.9.7
    Update zigbee from @1.9.5 to @1.9.7
    host.raspberrypi Adapter "system.adapter.zigbee.0" is stopped.
    /bin/sh: 1: npm: not foundError trying to check npm version: Command failed: npm -v/bin/sh: 1: npm: not found!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Aborting install because the npm version could not be checked!Please check that npm is installed correctly.Use "npm install -g npm@8" or "npm install -g npm@latest" to install a supported version.You need to make sure to repeat this step after installing an update to NodeJS and/or npm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    ERROR: Process exited with code 30
    Aktuell habe ich npm 10.2.3 installiert.
    Eine Reparatur über: iob fix war nicht erfolgreich.
    Anbei der Auszug von iob diag: (*** nodejs is NOT correctly installed ***)
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.1.0-rpi6-rpi-v8
        Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : arm64
    Systemuptime and Load:
     12:43:07 up 53 days, 21:47,  2 users,  load average: 0.87, 1.57, 1.89
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2024-01-17 12:43:08 CET
               Universal time: Wed 2024-01-17 11:43:08 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.2G        2.5G        2.2G        1.2M        3.6G        5.7G
    Swap:           104M          0B        104M
    Total:          8.3G        2.5G        2.3G
             7810 M total memory
             2359 M used memory
             2912 M active memory
             2381 M inactive memory
             2104 M free memory
              191 M buffer memory
             3284 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
      UNIT            LOAD   ACTIVE SUB    DESCRIPTION
    * hciuart.service loaded failed failed Configure Bluetooth Modems connected by UART
    1 loaded units listed.
    *** FILESYSTEM ***
    Filesystem                                        Type      Size  Used Avail Use% Mounted on
    udev                                              devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs                                             tmpfs     782M  1.2M  780M   1% /run
    /dev/sda2                                         ext4       29G  6.1G   22G  23% /
    tmpfs                                             tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs                                             tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1                                         vfat      510M   61M  450M  12% /boot/firmware
    //192.168.178.1/fritz.nas/BACKUPS/iobroker-backup cifs       30G  1.3G   29G   5% /opt/iobroker/backups
    tmpfs                                             tmpfs     782M     0  782M   0% /run/user/1000
    TARGET                  SOURCE                                            FSTYPE OPTIONS
    /                       /dev/sda2                                         ext4   rw,noatime
    |-/opt/iobroker/backups //192.168.178.1/fritz.nas/BACKUPS/iobroker-backup cifs   rw,relatime,vers=3.1.1,cache=strict,username=iobroker,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
    `-/boot/firmware        /dev/sda1                                         vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1017M   /var/
    349M    /var/lib
    320M    /var/cache
    314M    /var/cache/apt
    248M    /var/log
    Archived and active journals take up 246.3M in the file system.
    /opt/iobroker/backups:
    1.1G    /opt/iobroker/backups/
    57M     /opt/iobroker/backups/05.11.23
    56M     /opt/iobroker/backups/05.11.23/influxDB_2023_11_05-10_32_44_iobroker-data_backupiobroker
    19M     /opt/iobroker/backups/04.11.23
    /opt/iobroker/iobroker-data:
    680M    /opt/iobroker/iobroker-data/
    551M    /opt/iobroker/iobroker-data/files
    138M    /opt/iobroker/iobroker-data/files/vis-2
    89M     /opt/iobroker/iobroker-data/files/echarts.admin
    84M     /opt/iobroker/iobroker-data/backup-objects
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    28M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /home/iobroker/.diag.sh: line 279: npm: command not found
    /home/iobroker/.diag.sh: line 280: npx: command not found
    /home/iobroker/.diag.sh: line 281: corepack: command not found
    /home/iobroker/.diag.sh: line 290: npm: command not found
    /home/iobroker/.diag.sh: line 291: npx: command not found
    nodejs:
      Installed: 18.19.0+dfsg-6~deb12u1
      Candidate: 18.19.0+dfsg-6~deb12u1
      Version table:
     *** 18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
         18.19.0-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
         18.18.2-1nodesource1 500
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
    No problems detected
    Errors in npm tree:
    /home/iobroker/.diag.sh: line 360: npm: command not found
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.12.0
    javascript:     7.1.6
    /home/iobroker/.diag.sh: line 375: npm: command not found
    Adapters from github:   0
    Adapter State
    + system.adapter.device-reminder.0        : device-reminder       : raspberrypi                              -  enabled
      system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
    + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : raspberrypi                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.mystrom.0                : mystrom               : raspberrypi                              -  enabled
      system.adapter.net-tools.0              : net-tools             : raspberrypi                              - disabled
    + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      system.adapter.smartcontrol.0           : smartcontrol          : raspberrypi                              - disabled
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
    + system.adapter.statistics.0             : statistics            : raspberrypi                              -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : raspberrypi                              -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
      system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
    Adapter    "device-reminder": 3.0.0  , installed 3.0.1
    Adapter    "discovery"    : 4.2.0    , installed 4.2.0
    Adapter    "echarts"      : 1.7.2    , installed 1.7.2
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.17   , installed 5.0.17
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "mystrom"      : 0.0.14   , installed 0.0.14
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
    Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis"          : 1.5.4    , installed 1.5.4
    Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "zigbee"       : 1.9.7    , installed 1.9.5  [Updatable]
    Objects and States
    Objects:        8810
    States:         8221
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://packages.grafana.com/oss/deb stable InRelease
    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       335128048  1749772/iobroker.js
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       335128055  1749772/iobroker.js
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       335131094  1749937/io.sonoff.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          106757407  1071493/sshd: /usr/
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       335130812  1749790/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       335134895  1750307/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        664        761/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        106752987  1071324/grafana
    tcp6       0      0 :::22                   :::*                    LISTEN      0          106757409  1071493/sshd: /usr/
    udp        0      0 0.0.0.0:54406           0.0.0.0:*                           104        560        549/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        558        549/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        559        549/avahi-daemon: r
    udp6       0      0 :::38177                :::*                                104        561        549/avahi-daemon: r
    2024-01-17 12:43:31.400  - error: host.raspberrypi Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-17 12:43:31.400  - error: host.raspberrypi Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]:     at node:internal/main/run_main_module:28:49
    2024-01-17 12:43:31.401  - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0
    2024-01-17 12:43:31.401  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-17 12:43:31.402  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
    2024-01-17 12:44:01.493  - info: host.raspberrypi instance system.adapter.info.0 started with pid 1750894
    2024-01-17 12:44:04.165  - error: host.raspberrypi Caught by controller[0]: /bin/sh: 1: npm: not found
    2024-01-17 12:44:04.165  - error: host.raspberrypi Caught by controller[1]: /opt/iobroker/node_modules/iobroker.info/main.js:89
    2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:             adapter.log.error("Could not check npm version: " + e);
    2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:                     ^
    2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'log')
    2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:     at getSystemVersions (/opt/iobroker/node_modules/iobroker.info/main.js:89:11)
    2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.info/main.js:58:18)
    2024-01-17 12:44:04.166  - error: host.raspberrypi Caught by controller[1]:     at Module._compile (node:internal/modules/cjs/loader:1356:14)
    2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
    2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Module.load (node:internal/modules/cjs/loader:1197:32)
    2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Module._load (node:internal/modules/cjs/loader:1013:12)
    2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
    2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]:     at node:internal/main/run_main_module:28:49
    2024-01-17 12:44:04.167  - error: host.raspberrypi Caught by controller[1]: Node.js v18.19.0
    2024-01-17 12:44:04.167  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2024-01-17 12:44:04.167  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
    Kann mit da bitte jemand weiter helfen?
    VG Duffy
    Nix besonderes; iob auf Respberry pi 4 (8GB) mit 32 GB SSD
    Node.js: v22.23.1
    NPM: 10.9.4
    js-controller 7.1.2
    Linux: Trixie
    DJMarc75D Thomas BraunT 2 Antworten Letzte Antwort
    • DuffyD Duffy
      Skript v.2023-10-10
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : arm64
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           104M          0B        104M
               7810 M total memory
               2359 M used memory
               2104 M free memory
                191 M buffer memory
               3284 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      1017M   /var/
      349M    /var/lib
      320M    /var/cache
      314M    /var/cache/apt
      248M    /var/log
      USB-Devices by-id:
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.0
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8810
      States:         8221
      Pending Updates: 0
      VG Duffy
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @duffy
      https://forum.iobroker.net/topic/71478/plötzliche-probleme-durch-nodejs-dfsg-version-npm-fehlt
      Lehrling seit 1975 !!!
      DuffyD 1 Antwort Letzte Antwort
      • DJMarc75D DJMarc75
        @duffy
        DuffyD Offline
        DuffyD Offline
        Duffy
        @djmarc75
        Vielen Dank für den Link, den hatte ich in meiner Unruhe nicht gefunden.
        Läuft wieder, dachte schon ich muss mir Betablocker in der Apotheke holen 😧
        Gruß Duffy
        Node.js: v22.23.1
        NPM: 10.9.4
        js-controller 7.1.2
        Linux: Trixie
        • DuffyD Duffy
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Docker          : false
          Kernel          : aarch64
          Userland        : arm64
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           104M          0B        104M
                   7810 M total memory
                   2359 M used memory
                   2104 M free memory
                    191 M buffer memory
                   3284 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FILESYSTEM ***
          /var:
          1017M   /var/
          349M    /var/lib
          320M    /var/cache
          314M    /var/cache/apt
          248M    /var/log
          USB-Devices by-id:
          nodejs:
            Version table:
               18.13.0+dfsg1-1 500
          Errors in npm tree:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.6
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8810
          States:         8221
          Pending Updates: 0
          VG Duffy
          @duffy
          Und ich würde auch mal schauen, ob deine Backups wirklich vollständig geschrieben und gelesen werden können.
          Deine derzeitigen Mount-Optionen sind eigentlich für das FritzNAS falsch.
          • DuffyD Duffy
            @djmarc75
            Gruß Duffy
            @duffy sagte in *** nodejs is NOT correctly installed ***[gelöst]:
            ist extra oben angepinnt um den Blutdruck nicht allzuhoch zu treiben
            bei dir war
            der entscheidende Hinweis im iob diag
              @duffy
              DuffyD Offline
              DuffyD Offline
              Duffy
              Danke für den Hinweis.
              Ich habe soeben noch mal ein Backup angestoßen und es wurde auf die Nas der FB geschrieben und auch in die Dropbox.
              Started iobroker ...
              [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobroker,password=****,noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.1/fritz.nas/BACKUPS/iobroker-backup /opt/iobroker/backups"
              [DEBUG] [mount] - mount successfully completed
              [DEBUG] [mount] - done
              [DEBUG] [iobroker] - host.raspberrypi 8202 states saved
              [DEBUG] [iobroker] - host.raspberrypi 8818 objects saved
              [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_01_17-13_15_50_Smarthome_backupiobroker.tar.gz
              [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
              [DEBUG] [iobroker] - done
              [DEBUG] [influxDB] - InfluxDB-Backup for iobroker-data is started ...
              [DEBUG] [influxDB] - Start InfluxDB Backup ...
              [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
              [DEBUG] [influxDB] - Packed 8MB so far...
              [DEBUG] [influxDB] - Packed 45MB so far...
              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker.tar.gz
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker"
              [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker" successfully deleted
              [DEBUG] [influxDB] - InfluxDB-Backup for iobroker-data is finish
              [DEBUG] [influxDB] - InfluxDB-Backup for IOB-Kurzzeit-1Jahr is started ...
              [DEBUG] [influxDB] - Packed 16MB so far...
              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker.tar.gz
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker"
              [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker" successfully deleted
              [DEBUG] [influxDB] - InfluxDB-Backup for IOB-Kurzzeit-1Jahr is finish
              [DEBUG] [influxDB] - InfluxDB-Backup for iob-14-Tage is started ...
              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker.tar.gz
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker"
              [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker" successfully deleted
              [DEBUG] [influxDB] - InfluxDB-Backup for iob-14-Tage is finish
              [DEBUG] [influxDB] - InfluxDB-Backup for Keller is started ...
              [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2024_01_17-13_19_05_Keller_backupiobroker.tar.gz
              [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2024_01_17-13_19_05_Keller_backupiobroker"
              [DEBUG] [influxDB] - InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2024_01_17-13_19_05_Keller_backupiobroker" successfully deleted
              [DEBUG] [influxDB] - InfluxDB-Backup for Keller is finish
              [DEBUG] [influxDB] - done
              [DEBUG] [historyDB] - compress from historyDB started ...
              [DEBUG] [historyDB] - Backup created: /opt/iobroker/backups/historyDB_2024_01_17-13_19_09_Smarthome_backupiobroker.tar.gz
              [DEBUG] [historyDB] - done
              [DEBUG] [zigbee] - found zigbee database: zigbee.0
              [DEBUG] [zigbee] - done
              [DEBUG] [grafana] - Start Grafana Backup ...
              [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
              [DEBUG] [grafana] - Created dashboard directory
              [DEBUG] [grafana] - Created dashboards_manually_restore directory
              [DEBUG] [grafana] - Created datasource directory
              [DEBUG] [grafana] - start Grafana request ...
              [DEBUG] [grafana] - Grafana is available ... Status: 200
              [DEBUG] [grafana] - found Dashboard: haus
              [DEBUG] [grafana] - found Dashboard: terrasse-garten
              [DEBUG] [grafana] - found Dashboard: temperatur-gefriere
              [DEBUG] [grafana] - found Dashboard: temperaturen-haus
              [DEBUG] [grafana] - found Dashboard: maschinen
              [DEBUG] [grafana] - found Dashboard: temp-pi
              [DEBUG] [grafana] - found Dashboard: stromzahler
              [DEBUG] [grafana] - found Dashboard: pv-ueberwachung
              [DEBUG] [grafana] - found Dashboard: stromverbrauch-haus-brutto
              [DEBUG] [grafana] - found Dashboard: stromverbrauch-tag
              [DEBUG] [grafana] - found Dashboard: signale-thermometer
              [DEBUG] [grafana] - found Dashboard: signale-bwm-licht-briefkasten-erschuetterung
              [DEBUG] [grafana] - found Dashboard: pv-mit-stromverbrauch
              [DEBUG] [grafana] - found Dashboard: signale-steckdose-birnen-relais
              [DEBUG] [grafana] - found Dashboard: keller
              [DEBUG] [grafana] - found Dashboard: alle-zigbee
              [DEBUG] [grafana] - found Dashboard: gasverbrauch-tag
              [DEBUG] [grafana] - found Dashboard: hobby
              [DEBUG] [grafana] - found Dashboard: mini-pv
              [DEBUG] [grafana] - found Dashboard: spuehlmaschine
              [DEBUG] [grafana] - found Dashboard: system-ueberwachung
              [DEBUG] [grafana] - found Dashboard: waschmaschine-2
              [DEBUG] [grafana] - found Dashboard: mini-pv-mit-luftentfeuchter
              [DEBUG] [grafana] - start Grafana backup compress ...
              [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2024_01_17-13_19_12_Smarthome_backupiobroker.tar.gz
              [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
              [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
              [DEBUG] [grafana] - done
              [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
              [DEBUG] [javascripts] - found Script: Alexa_Musik2
              [DEBUG] [javascripts] - found Script: Guten_Morgen_Alexa
              [DEBUG] [javascripts] - found Script: Licht_Arbeitszimmer
              [DEBUG] [javascripts] - found Script: Alexa_Aussentemperatur
              [DEBUG] [javascripts] - found Script: Alexa_Musik1
              [DEBUG] [javascripts] - found Script: Alexa_Musik_mit_Feiertagskalender
              [DEBUG] [javascripts] - found Script: Licht_Bad_OG
              [DEBUG] [javascripts] - found Script: Licht_Bad_OG_Feriertage
              [DEBUG] [javascripts] - found Script: Astro_Funktion
              [DEBUG] [javascripts] - found Script: Briefkasten
              [DEBUG] [javascripts] - found Script: Briefkasten_mit_BWM
              [DEBUG] [javascripts] - found Script: Esszimmer
              [DEBUG] [javascripts] - found Script: Gaszaehler
              [DEBUG] [javascripts] - found Script: Gaszaehler_Test_Runden
              [DEBUG] [javascripts] - found Script: Offene_Fenster
              [DEBUG] [javascripts] - found Script: Skript_1
              [DEBUG] [javascripts] - found Script: Vergleiche
              [DEBUG] [javascripts] - found Script: Video_1
              [DEBUG] [javascripts] - found Script: eCharts
              [DEBUG] [javascripts] - found Script: eCharts1
              [DEBUG] [javascripts] - found Script: Luftentfeuchter
              [DEBUG] [javascripts] - found Script: Licht_Arbeitsplatte
              [DEBUG] [javascripts] - found Script: Licht_Arbeitsplatte_2_BWM
              [DEBUG] [javascripts] - found Script: Alexa_Stromproduktion
              [DEBUG] [javascripts] - found Script: PV_Ertrag___Einspeisung
              [DEBUG] [javascripts] - found Script: PV_Gesamtertrag___Tag
              [DEBUG] [javascripts] - found Script: PV_Stromproduktion_aktuell
              [DEBUG] [javascripts] - found Script: Stromverbrauch_Haus
              [DEBUG] [javascripts] - found Script: 0_Einspeisung_An___Aus
              [DEBUG] [javascripts] - found Script: PV_Nulleinseisung
              [DEBUG] [javascripts] - found Script: PV_Nulleinseisung_(Backup)
              [DEBUG] [javascripts] - found Script: Tigger66
              [DEBUG] [javascripts] - found Script: Regenmelder_Echo_SZ
              [DEBUG] [javascripts] - found Script: Regenmelder_Echo_SZ_WZ
              [DEBUG] [javascripts] - found Script: Dimmer_Schlafzimmerlicht
              [DEBUG] [javascripts] - found Script: Dimmer_Schlafzimmerlicht__vereinfacht_
              [DEBUG] [javascripts] - found Script: Adapter_Updates
              [DEBUG] [javascripts] - found Script: Batterie_Sensor_Warnung
              [DEBUG] [javascripts] - found Script: Geraetestatus
              [DEBUG] [javascripts] - found Script: influxDB_Migration
              [DEBUG] [javascripts] - found Script: Timer_Steckdose_Carport
              [DEBUG] [javascripts] - found Script: Timer_Steckdose_Carport1
              [DEBUG] [javascripts] - found Script: Toilette_mit_BWM
              [DEBUG] [javascripts] - found Script: Toilette_mit_Erschüttertung
              [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Fritz
              [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Gosund
              [DEBUG] [javascripts] - found Script: Telegram_Test
              [DEBUG] [javascripts] - found Script: Test_Whatsapp
              [DEBUG] [javascripts] - found Script: Filament_Temperaturüberwachung
              [DEBUG] [javascripts] - found Script: Drucker_Abschaltung
              [DEBUG] [javascripts] - found Script: Filament_Temperaturüberwachung2
              [DEBUG] [javascripts] - found Script: Timer_Heizlüfter
              [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Tasmota
              [DEBUG] [javascripts] - found Script: Wohnzimmerbeleuchtung_Tasmota_fehlersuche
              [DEBUG] [javascripts] - found Script: Kaffeemaschine
              [DEBUG] [javascripts] - found Script: Waschmaschine_DECT
              [DEBUG] [javascripts] - found Script: Waschmaschine_Tasmota
              [DEBUG] [javascripts] - found Script: Waschmaschine_Tasmota1_Test_skript
              [DEBUG] [javascripts] - found Script: Gefriere_Temperaturüberwachung
              [DEBUG] [javascripts] - found Script: Gefriere_Paul_53
              [DEBUG] [javascripts] - found Script: Kühlschrank_Temperaturüberwachung
              [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
              [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
              [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2024_01_17-13_19_20_Smarthome_backupiobroker.tar.gz
              [DEBUG] [javascripts] - done
              [DEBUG] [cifs] - used copy path: /fritz.nas/BACKUPS/iobroker-backup
              [DEBUG] [cifs] - done
              [DEBUG] [dropbox] - Dropbox: Copy iobroker_2024_01_17-13_15_50_Smarthome_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_16_09_iobroker-data_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_17_59_IOB-Kurzzeit-1Jahr_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_18_54_iob-14-Tage_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy influxDB_2024_01_17-13_19_05_Keller_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy historyDB_2024_01_17-13_19_09_Smarthome_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy zigbee.0_2024_01_17-13_19_09_Smarthome_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy grafana_2024_01_17-13_19_12_Smarthome_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - Dropbox: Copy javascripts_2024_01_17-13_19_20_Smarthome_backupiobroker.tar.gz...
              [DEBUG] [dropbox] - done
              [DEBUG] [clean] - No older backup files are deleted, because this backup was started manually
              [DEBUG] [clean] - done
              [DEBUG] [telegram] - done
              [DEBUG] [historyHTML] - new history html values created
              [DEBUG] [historyHTML] - done
              [DEBUG] [historyJSON] - new history json values created
              [DEBUG] [historyJSON] - done
              [DEBUG] [umount] - mount activ, umount is started ...
              [DEBUG] [umount] - umount successfully completed
              [DEBUG] [umount] - done
              [EXIT] 0
              Kannst du mir bitte noch sagen wo du den Fehler vermustest so das ich dir von meinen Einstellungen noch einen Sc´reenshot zukommen lassen kann?
              Node.js: v22.23.1
              NPM: 10.9.4
              js-controller 7.1.2
              Linux: Trixie
              • DuffyD Duffy
                [EXIT] 0
                @duffy
                Bei meinem FritzNAS müssen die Optionen 'noserverino' und 'cache=loose' gesetzt sein. Sonst werden da korrupte (zu kleine) Dateien geschrieben.
                  @duffy
                  DuffyD Offline
                  DuffyD Offline
                  Duffy
                  die sind bei mir auch drin.
                  Node.js: v22.23.1
                  NPM: 10.9.4
                  js-controller 7.1.2
                  Linux: Trixie
                  • DuffyD Duffy
                    @duffy
                    Da ist es aber anders:
                    Ist das über die ```fstab`` gemountet?
                      @duffy
                      DuffyD Offline
                      DuffyD Offline
                      Duffy
                      @thomas-braun sagte in *** nodejs is NOT correctly installed ***[gelöst]:
                      Leider weis ich nicht was das ist.
                      Wenn du mir sagst was ich tun muss schaue ich gerne danach.
                      Wills ja richtig haben!
                      Node.js: v22.23.1
                      NPM: 10.9.4
                      js-controller 7.1.2
                      Linux: Trixie
                      • DuffyD Duffy
                        @duffy
                        cat /etc/fstab
                          @duffy
                          cat /etc/fstab
                          DuffyD Offline
                          DuffyD Offline
                          Duffy
                          cat /etc/fstab
                          Das schaut so aus:
                          pi@raspberrypi:~ $ cat /etc/fstab
                          proc            /proc           proc    defaults          0       0
                          PARTUUID=dd528ea5-01  /boot/firmware  vfat    defaults          0       2
                          PARTUUID=dd528ea5-02  /               ext4    defaults,noatime  0       1
                          # a swapfile is not a swap partition, no line here
                          #   use  dphys-swapfile swap[on|off]  for that
                          pi@raspberrypi:~ $
                          Will es halt nicht rikieren ein Backup wiederherzustellen wenns nicht nötig ist.
                          Sagen wir mal so, es hat schon mal funktioniert ist aber auch schon wieder ne Weile her.
                          Node.js: v22.23.1
                          NPM: 10.9.4
                          js-controller 7.1.2
                          Linux: Trixie
