  3. Entwicklung
  4. [Neuer Adapter] Reolink Kamera
reolinkneuer adaptertestenkamera
1.1k Beiträge 166 Kommentatoren 679.5k Aufrufe 146 Beobachtet
  • skvarelS skvarel
    @michihorn sagte in [Neuer Adapter] Reolink Kamera:
    Hallo habe heute im ferienhaus eine E1 Outdoor installiert. Leider klappt es zu Hause nicht mit dem Adapter. Folgendes steht im Log:
    reolink.0
    2023-03-21 22:02:59.100	error	Error: connect EHOSTUNREACH 192.168.xxx.249:443: EHOSTUNREACH
    reolink.0
    2023-03-21 22:02:53.771	silly	States system redis pmessage system.adapter.reolink.0.logLevel/system.adapter.reolink.0.logLevel:{"val":"silly","ack":true,"ts":1679432573639,"q":0,"from":"system.adapter.reolink.0","lc":1679432506968}
    reolink.0
    2023-03-21 22:02:53.631	info	Current IP: 192.168.xxx.249
    reolink.0
    2023-03-21 22:02:53.626	info	Reolink adapter has started
    reolink.0
    2023-03-21 22:02:53.540	info	starting. Version 0.1.1 (non-npm: aendue/ioBroker.reolink#b78aab6744cdb81b360fd947a9c6e2fd6808bab1) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.12.0, js-controller: 4.0.24
    reolink.0
    2023-03-21 22:02:49.183	silly	statesDB connected
    reolink.0
    2023-03-21 22:02:49.181	debug	States connected to redis: 127.0.0.1:9000
    reolink.0
    2023-03-21 22:02:49.006	debug	States create User PubSub Client
    reolink.0
    2023-03-21 22:02:49.005	debug	States create System PubSub Client
    reolink.0
    2023-03-21 22:02:48.940	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    reolink.0
    2023-03-21 22:02:48.937	silly	objectDB connected
    reolink.0
    2023-03-21 22:02:48.931	silly	redis psubscribe cfg.o.enum.*
    reolink.0
    2023-03-21 22:02:48.842	silly	redis psubscribe cfg.o.system.user.*
    reolink.0
    2023-03-21 22:02:48.839	debug	Objects connected to redis: 127.0.0.1:9001
    reolink.0
    2023-03-21 22:02:48.830	debug	Objects client initialize lua scripts
    reolink.0
    2023-03-21 22:02:48.556	debug	Objects create User PubSub Client
    reolink.0
    2023-03-21 22:02:48.554	debug	Objects create System PubSub Client
    reolink.0
    2023-03-21 22:02:48.552	debug	Objects client ready ... initialize now
    reolink.0
    2023-03-21 22:02:48.427	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    Wo bin ich falsch abgebogen?
    Was muss ich bei Kanal eintragen?
    Gruß Michael
    .. alle Ports in der Browseransicht aktiviert?
    Die E1 Outdoor läuft auf jeden Fall mit dem Adapter
    Michael SchumannM Offline
    Michael Schumann
    #616
    @skvarel :
    Ist das eine normale E1 Outdoor bei dir oder eine E1 Outdoor Pro?
    Habe nun die E1 Zoom umgetauscht, da AudioAlarmPlay nicht verfügbar war und mir eine E1 Outdoor geholt in der Hoffnung, dass es dann im ioBroker bei mir genau so aussieht wie bei dir :) Leider nein, wie man in meinem letzten Eintrag sieht, alle Werte bei Settings sind (null).
    Wenn ich die API direkt anspreche (z.B. via Python) bekomme ich statt "not supportet" wie bei der E1 Zoom ein "[{'cmd': 'AudioAlarmPlay', 'code': 1, 'error': {'detail': 'ability error', 'rspCode': -26}}]" zurück gemeldet 😢
    Weiß jemand was ein ability error ist? Muss ich vllt. nur etwas umkonfigurieren?
    Oder hat hier noch jemand eine E1 Outdoor erfolgreich eingebunden, mit allen Settings?
    • MatzebhvM Offline
      MatzebhvM Offline
      Matzebhv
      schrieb am zuletzt editiert von Matzebhv
      #617
      Ich habe seit kurzem leider auch den Fehler "TypeError: Cannot read properties of undefined (reading 'DevInfo'): undefined". Der Adapter bleibt dabei auf gelb.
      Der Adapter hat davor klaglos funktioniert.
      Kamera: RLC-833A
      Matze
      Edit: die Version 0.1.2 läuft, die Versionen danach nicht mehr.
      oelisonO 1 Antwort Letzte Antwort
      • MatzebhvM Matzebhv
        Kamera: RLC-833A
        Matze
        oelisonO Offline
        oelisonO Offline
        oelison
        #618
        @matzebhv v1.0.2 sollte aber wieder gehen.
        I like Rust. ioBroker-Adapter: matrix, mediola-gateway, support for reolink
        MatzebhvM 1 Antwort Letzte Antwort
        • Michael SchumannM Michael Schumann
          @skvarel :
          bommel_030
          #619
          @michael-schumann
          Bin mir nicht sicher ob ich dir richtig folgen kann, aber alles unter Settings ist solange Null bis du es beschreibst.
          Der Adapter kann das was du in den jeweiligen Datenunkt schreibst senden, aber nicht den Status abholen. Das sieht die API so noch nicht vor.
          AudioAlarmPlay sagt mir nichts, wenn du damit playAlarm meinst, der steuert die Sirene. In den Datenpunkt kannst du eine Zahl schreiben. 0 = AUS, 1 = 1x Alarm, 2 = 2x Alarm abspielen usw. ob und welcher Wert das Maximum ist hab ich noch nicht probiert. Funktioniert hier sowohl mit einer E1 Zoom als auch mit einer E1 Outdoor POE.
          Michael SchumannM 1 Antwort Letzte Antwort
          • oelisonO oelison
            MatzebhvM Offline
            MatzebhvM Offline
            Matzebhv
            #620
            @oelison leider nein, grade nochmal probiert.
            reolink.0
            2023-12-22 15:02:24.131	error	TypeError: Cannot read properties of undefined (reading 'DevInfo'): undefined
            reolink.0
            2023-12-22 15:02:23.452	info	Current IP: 192.168.178.236
            reolink.0
            2023-12-22 15:02:23.451	info	Reolink adapter has started
            reolink.0
            2023-12-22 15:02:23.442	info	starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.reolink, node: v18.19.0, js-controller: 5.0.17
            oelisonO 2 Antworten Letzte Antwort
            • B bommel_030
              @michael-schumann
              Michael Schumann
              schrieb am zuletzt editiert von Michael Schumann
              #621
              @bommel_030
              Ah so funktioniert das! Super vielen Dank, hat geklappt!
              Allerdings nur bei meiner E1 Outdoor, nicht bei meiner E1 Zoom.
              Jetzt muss ich mal in den Code schauen wieso ich das nicht selbst via API hinbekommen habe.
              Gibt es auch irgendwo das Setting um "Bei Bewegungserkennung wird Sirene automatisch ausgelöst" zu aktiveren?
                dadsche
                #622
                Hallo Zusammen,
                ich habe meine RLC-833A mittlerweile eingebunden bekommen und nun wollte ich die Lampe über den IoBroker aktivieren, dies funktioniert aber nicht.
                Ich gehe doch recht in der Annahme, dass ich das Objekt "switchLed" auf "true" stellen muss, oder?
                Müssen noch andere Einstellungen getätigt werden?
                Version des Adapters ist 1.0.2.
                Wäre nett, wenn ihr mir einen Tipp geben könntet.
                  ArnoD
                  #623
                  Hallo in die Rund,
                  ich habe zu Weihnachten eine Reolink TrackMix PoE Kamera bekommen und habe diese über ein Javascript mithilfe der Reolink API Doku V8 eingebunden. Jetzt habe ich diesen Adapter entdeckt und wollte fragen, ob dieser noch weiter entwickelt wird?
                  Mir fehlt hier vor allem die Möglichkeit der PTZ Steuerung, um auf diesen Adapter umzusteigen.
                  VG Arno
                  • A ArnoD
                    Hallo in die Rund,
                    VG Arno
                    oelisonO Offline
                    oelisonO Offline
                    oelison
                    #624
                    @arnod Hi. Weiterentwickelt wird der. Und PTZ steuerung geht schon. Bitte mal die API Befehle senden, die funktionieren und im Adapter nicht.
                      reolink.0
                      reolink.0
                      reolink.0
                      reolink.0
                      oelisonO Offline
                      oelisonO Offline
                      oelison
                      #625
                      @matzebhv Bitte mal den Adapter in Debug umstellen. Es wäre mal interessant wie weit er kommt, befor er die Exeption schmeißt.
                        reolink.0
                        reolink.0
                        reolink.0
                        reolink.0
                        oelisonO Offline
                        oelisonO Offline
                        oelison
                        #626
                        @matzebhv Und das passwort neu setzen!
                        • oelisonO oelison
                          ArnoD
                          #627
                          @oelison
                          In meinem Script mache ich das über
                          [{"cmd":"PtzCtrl","param":{"channel":KameraKanal,"id":ID,"op":Richtung,"speed":Speed}}];
                          op: ist dabei die Richtung, also "Left" ,"Right", "Stop", "Up", "Down" , "LeftDown" .. usw.
                          Dafür habe ich eine eigene Objekt-ID angelegt und solange z.B. "Left" true ist, wird die Kamera nach links verfahren und bei false sende ich dann "Stop" sodass ich in Vis das über eine Tastenfunktion steuern kann.
                          Habe ich das im Adapter übersehen?
                          • A ArnoD
                            @oelison
                            oelisonO Offline
                            oelisonO Offline
                            oelison
                            #628
                            @arnod Das ist tatsächlich nicht drin. Nur die festen positionen. Das mit links, rechts, usw. kann ich bestimmt einbauen.
                            • oelisonO oelison
                              ArnoD
                              #629
                              @oelison
                              Das wäre super, :-) Danke schon mal für deine Arbeit.
                              Wenn es dir hilft, hier mein Script wie ich es umgesetzt habe:
                              'use strict';
                              //++++++++++++++++++++++++++++++++++++++++++  USER ANPASSUNGEN +++++++++++++++++++++++++++++++++++++++++
                              const instanz = '0_userdata.0';                                 // Instanz Script Charge-Control
                              let PfadEbene1 = 'Reolink';                                     // Pfad innerhalb der Instanz
                              let PfadEbene2 = ['UserDaten','PTZ','Settings'];                           // Pfad innerhalb PfadEbene1
                              const KameraKanal = 0;
                              //++++++++++++++++++++++++++++++++++++++++ ENDE USER ANPASSUNGEN +++++++++++++++++++++++++++++++++++++++
                              //**************************************** Deklaration Variablen ***************************************
                              // @ts-ignore
                              const axios = require("axios").default;
                              // @ts-ignore
                              const https = require("https");
                              let KameraIP,User,Passwort,reolinkBaseURL,ptzDescription;
                              ScriptStart()
                              // Alle nötigen Objekt ID's anlegen
                              async function CreateState(){
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[0]}.IP_Adresse`, {'def':'192.168.xxx.xxx', 'name':'Ip Adresse der Kamera' , 'type':'string', 'role':'value', 'desc':'IP Adresse Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[0]}.User`, {'def':'admin', 'name':'User Name' , 'type':'string', 'role':'value', 'desc':'User Name'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[0]}.Passwort`, {'def':'admin', 'name':'Passwort' , 'type':'string', 'role':'value', 'desc':'Passwort'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Stop`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Left`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Right`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Up`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Down`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.LeftUp`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.LeftDown`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.RightUp`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.RightDown`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.ZoomDec`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.ZoomInc`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Auto`, {'def':false, 'name':'Wenn = true wird Automatisch geschwenkt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.StartPatrol`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.StopPatrol`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.ToPos`, {'def':false, 'name':'Wir solange = true ausgeführt' , 'type':'boolean', 'role':'State', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Patrol_ID`, {'def':0, 'name':'Positions ID' , 'type':'number', 'role':'value', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Speed`, {'def':0, 'name':'Geschwindigkeit von 0-64' , 'type':'number', 'role':'value', 'desc':'PTZ Steuerung Reolink'});
                                  createStateAsync(`${instanz}.${PfadEbene1}.${PfadEbene2[2]}.SwitchLed`, {'def':false, 'name':'LED Ein/Aus-schalten' , 'type':'boolean', 'role':'State', 'desc':'LED Ein/Aus-schalten'});
                              const sID_IP_Adresse =`${instanz}.${PfadEbene1}.${PfadEbene2[0]}.IP_Adresse`;
                              const sID_User =`${instanz}.${PfadEbene1}.${PfadEbene2[0]}.User`;
                              const sID_Passwort =`${instanz}.${PfadEbene1}.${PfadEbene2[0]}.Passwort`;
                              const sID_Stopp =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Stop`;
                              const sID_Links =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Left`;
                              const sID_Rechts =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Right`;
                              const sID_Rauf =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Up`;
                              const sID_Runter =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Down`;
                              const sID_Links_Runter =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.LeftDown`;
                              const sID_Links_Rauf =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.LeftUp`;
                              const sID_Rechts_Runter =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.RightDown`;
                              const sID_Rechts_Rauf =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.RightUp`;
                              const sID_Zoom_in =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.ZoomDec`;
                              const sID_Zoom_out =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.ZoomInc`;
                              const sID_Auto =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Auto`;
                              const sID_StartPatrol =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.StartPatrol`;
                              const sID_StoppPatrol =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.StopPatrol`;
                              const sID_ToPos =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.ToPos`;
                              const sID_Patrol_ID =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Patrol_ID`;
                              const sID_Speed =`${instanz}.${PfadEbene1}.${PfadEbene2[1]}.Speed`;
                              const sID_SwitchLed =`${instanz}.${PfadEbene1}.${PfadEbene2[2]}.SwitchLed`;
                              const arrayID_Parameter1 = [sID_Stopp,sID_Links,sID_Rechts,sID_Rauf,sID_Runter,sID_Links_Runter,sID_Links_Rauf,sID_Rechts_Runter,sID_Rechts_Rauf,sID_Zoom_in,sID_Zoom_out]
                              async function ScriptStart(){
                                  await CreateState();
                                  log(`-==== alle Objekt ID\'s angelegt ====- `);
                                  KameraIP = (await getStateAsync(sID_IP_Adresse)).val;
                                  User = (await getStateAsync(sID_User)).val;
                                  Passwort = (await getStateAsync(sID_Passwort)).val;
                                  reolinkBaseURL = axios.create({baseURL: `https://${KameraIP}`,timeout: 5000,responseType: "json",responseEncoding: "binary",httpsAgent: new https.Agent({rejectUnauthorized: false,})});
                              async function postReolink(cmdObject) {
                              	try	{
                              		const antwort = await reolinkBaseURL.post(`/api.cgi?user=${User}&password=${Passwort}`, cmdObject);
                                      //log(JSON.stringify(antwort.data));
                                  } catch(error) {
                              		log(`Fehler = ${error}`,`warn`);
                              // Triggern wenn sich an Einstellung PTZ was ändert
                              on({id: arrayID_Parameter1, change: "ne"}, async function (obj) {
                                  if(obj.state.val){
                                      let ID = (await getStateAsync(sID_Patrol_ID)).val;
                                      let Speed = (await getStateAsync(sID_Speed)).val;
                                      let Richtung = obj.id.split('.')[4]
                                      ptzDescription = [{"cmd":"PtzCtrl","param":{"channel":KameraKanal,"id":ID,"op":Richtung,"speed":Speed}}];
                                      postReolink(ptzDescription);
                                  }else{
                                      ptzDescription = [{"cmd":"PtzCtrl","param":{"channel":KameraKanal,"op":'Stop'}}];
                              • D dadsche
                                Hallo Zusammen,
                                ArnoD
                                #630
                                @dadsche
                                Bei meiner Kamera habe ich festgestellt, dass man das Licht nur ein/ausschalten kann, wenn man als admin angemeldet ist.
                                Ansonsten ist deine Annahme richtig, dass nur "switchLed" auf "true" gesetzt werden muss.
                                • A ArnoD
                                  @dadsche
                                  dadsche
                                  #631
                                  @arnod Vielen Dank für den Hinweis! Jetzt funktioniert es.
                                  • M Online
                                    M Online
                                    michihorn
                                    schrieb am zuletzt editiert von michihorn
                                    #632
                                    Hallo habe gerade die neue 1.0.2 vom Git installiert.
                                    bekomme folgende Fehlermeldung:
                                    reolink.1
                                    2023-12-28 11:27:22.782	info	terminating
                                    reolink.1
                                    2023-12-28 11:27:33.136	info	starting. Version 1.0.2 (non-npm: aendue/ioBroker.reolink#d2e00f9aa8a64b4eff6048c1e47dbb07490e7a5a) in /opt/iobroker/node_modules/iobroker.reolink, node: v18.19.0, js-controller: 5.0.17
                                    reolink.1
                                    2023-12-28 11:27:33.186	info	Reolink adapter has started
                                    reolink.1
                                    2023-12-28 11:27:33.192	info	Current IP: 192.168.188.74
                                    reolink.1
                                    2023-12-28 11:27:36.735	error	TypeError: Cannot read properties of undefined (reading 'DevInfo'): undefined
                                    Passwort wurde neu gesetzt, jedoch ohne Erfolg.
                                    EDIT: Jetzt läufts, keine Ahnung was los war
                                    Michael
                                    • oelisonO oelison
                                      MatzebhvM Offline
                                      MatzebhvM Offline
                                      Matzebhv
                                      #633
                                      @oelison Hmm, update nochmal gemacht, Kennwort gesetzt, jetzt geht es. Das mit dem Kennwort hatte ich allerdings beim letzten mal auch schon probiert, das hatte ja jemand hier schon mal geschrieben.
                                      Aber egal, das Ergebnis zählt, Adapter läuft.
                                      Matze
                                        dan11hh
                                        #634
                                        Ich steh irgendwie auf dem Schlauch.
                                        Ich habe meine Reolink Kameras bisher über meine Synology Diskstation eingebunden. Nun sind es inzwischen ein paar mehr geworden und ich möchte diesen Umweg aus verschiedenen Gründen (u.a. Lizenzgebühren) nicht mehr gehen. Wie binde ich die Kameras über den Adapter in Lovelace ein. Dazu habe ich leider nichts gefunden. Steuern ist mir nicht wichtig. Nur Anzeige. Danke Euch!
                                        • M Online
                                          M Online
                                          michihorn
                                          #635
                                          Hallo
                                          ich habe eine E1 Outdoor, die Installation ist gelaufen PTZ geht, aber bei der Erkennung von Fahrzeugen oder Personen sehe ich in den Objekten keine Reaktion. Ich habe die entsprechenden DP's in einem Script eingebunden, selbst bei kurzfristiger Statusänderung müsste diese in meiner VIS gesichtet werden. Anbei das entsprechende Script.
                                          const id_detekt = "0_userdata.0.Events.Detekt"
                                          const id_mensch = "reolink.0.sensor.people.state"
                                          const id_car = "reolink.0.sensor.vehicle.state"
                                          setState(id_detekt, 0)
                                          const auslöser = [id_mensch, id_car];
                                          on({ id: auslöser, change: 'ne', val: true }, function (dp) {
                                              log("Auslöser Ankunft: " + dp.common.name)
                                              var name = dp.name;
                                              log(dp.name)
                                              switch (name) {
                                                  case 'Mensch':
                                                      setState(id_detekt, 1)
                                                      break;
                                                  case 'Auto':
                                                      setState(id_detekt, 2)
                                                      break;
                                          Muß ich evtl. noch irgendwas in der Reolink App berücksichtigen?
                                          Michael
