  5. Errormeldung Blockly Skript (compile failed: at)
    2.2k
    4.1k
9 Beiträge 3 Kommentatoren 941 Aufrufe 2 Beobachtet
  • NinjaTurtle85N Offline
    NinjaTurtle85
    Ich bekomme diese Error Meldungen nicht in den Griff:
    javascript.0
    	2023-12-16 07:20:39.802	error	at processImmediate (node:internal/timers:478:21)
    javascript.0
    	2023-12-16 07:20:39.802	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1671:17)
    javascript.0
    	2023-12-16 07:20:39.802	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2197:17
    javascript.0
    	2023-12-16 07:20:39.802	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2099:37)
    javascript.0
    	2023-12-16 07:20:39.802	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1846:21)
    javascript.0
    	2023-12-16 07:20:39.802	error	at new Script (node:vm:94:7)
    javascript.0
    	2023-12-16 07:20:39.802	error	SyntaxError: Unexpected token ')'
    javascript.0
    	2023-12-16 07:20:39.802	error	^
    javascript.0
    	2023-12-16 07:20:39.802	error	setState('javascript.0.zeiten.sonnenaufgang_minute' /* sonnenaufgang_minute */, ('' + getDateObject(getAstroDate('sunrise', undefined, 0)).getMinutes())));
    javascript.0
    	2023-12-16 07:20:39.802	error	script.js.common.Allgemein.RollladenZeit compile failed: at script.js.common.Allgemein.RollladenZeit:67
    Java Adater: V7.5.0
    Kann mir jemand Helfen?
    NinjaTurtle85N 1 Antwort Letzte Antwort
    • NinjaTurtle85N NinjaTurtle85
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Java Adater: V7.5.0
      NinjaTurtle85
      schrieb am zuletzt editiert von NinjaTurtle85
      Es lag an der Astrozeit abfrage.
        <block type="schedule" id="~.j87+foPnE#n)eT93rn" x="-1762" y="2063">
          <field name="SCHEDULE">5 */12 * * *</field>
          <statement name="STATEMENT">
            <block type="comment" id="[ExTzdI8@Eg{./04DsBY">
              <field name="COMMENT">Sonnenaufgang</field>
              <next>
                <block type="control" id="`Uk,BQ[wWYb#-0}{j`}!">
                  <field name="OID">javascript.0.zeiten.sonnenaufgang</field>
                  <value name="VALUE">
                    <block type="convert_tostring" id="U%F?0xBqF3XHitKMY|TV">
                        <block type="convert_from_date" id="B|lK0?j|-5%?m(HN{hl%">
                          <field name="OPTION">hh:mm</field>
                            <block type="time_astro" id=";)0;TglnL9egMLO*vC7)">
                              <field name="TYPE">sunrise</field>
                              <field name="OFFSET">0</field>
                            </block>
                          </value>
                        </block>
                      </value>
                    </block>
                  </value>
                  <next>
                    <block type="control" id="|:Vl-]3?9}!X}/`^`)y+">
                      <field name="OID">javascript.0.zeiten.sonnenaufgang_stunde</field>
                        <block type="convert_tostring" id="9vIr`eyxF9dePKZwv)2f">
                            <block type="convert_from_date" id="hji=xV`a)m=E`atGYY!|">
                              <field name="OPTION">h</field>
                                <block type="time_astro" id="8T:N1EK)%XW;;!|v;*:{">
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                      <next>
                        <block type="control" id=".z@;VfpW?SZ`d`!B4]Vd">
                          <field name="OID">javascript.0.zeiten.sonnenaufgang_minute</field>
                            <block type="convert_tostring" id="(O2/!Po?ho@(qOy1GwMh">
                                <block type="convert_from_date" id=")U.KaOF-=-xS0/dVKt.b">
                                  <field name="OPTION">m</field>
                                    <block type="time_astro" id="v%eiPa;4WFeOCft6E|((">
                                    </block>
                                  </value>
                                </block>
                              </value>
                            </block>
                          </value>
                          <next>
                            <block type="comment" id="dNle~;20WNfWoR2qv+JF">
                              <field name="COMMENT">Sonnenuntergang</field>
                              <next>
                                <block type="control" id="o,-P^2k,pO.XL5jRJU@{">
                                  <field name="OID">javascript.0.zeiten.sonnenuntergang</field>
                                    <block type="convert_tostring" id="oc+^#b,A.i[6cT;gC}3r">
                                        <block type="convert_from_date" id="1ZmHC7@@y21}ih5Glz@Z">
                                            <block type="time_astro" id="tbVuLpYX,jE^!!BGqP0-">
                                              <field name="TYPE">sunset</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </next>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </xml>
                <next>
                              </block>
                            </value>
                          </block>
                        </value>
                      </block>
                    </value>
                    <next>
                                  </block>
                                </value>
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                                <next>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
          </block>
        </xml>
        MartinPM Offline
        MartinPM Offline
        MartinP
        @ninjaturtle85 Ist das die korrigierte Version, oder die, die den Fehler erzeugt?
        • MartinPM MartinP
          NinjaTurtle85
          @martinp Diese Erzeugt den Fehler.
          Ich habe den Block jetzt gelöscht da ich den Datenpunkt sowieso nicht mehr brauche.
            MartinPM Offline
            MartinPM Offline
            MartinP
            @ninjaturtle85 "Java Adapter 7.5"? Bist Du nicht im Stable Repository? Wenn man Adapter aus dem experimental Repository zieht, kann so etwas schon einmal passiereren. Wäre dann ggfs. einen Issue in Github wert ...
            ich bin in stable, und bei mir sieht das so aus:
            • MartinPM MartinP
              NinjaTurtle85
              @martinp das stimmt. Werde ich tun.
                MartinPM Offline
                MartinPM Offline
                MartinP
                @ninjaturtle85 Habe mal dein XML importiert - das erzeugte Javascript sieht unauffällig aus ...
                schedule("5 */12 * * *", async () => {
                  // Sonnenaufgang
                  setState('javascript.0.zeiten.sonnenaufgang', ('' + formatDate(getDateObject(getAstroDate('sunrise', undefined, 0)), "hh:mm")));
                  setState('javascript.0.zeiten.sonnenaufgang_stunde', ('' + getDateObject(getAstroDate('sunrise', undefined, 0)).getHours()));
                  setState('javascript.0.zeiten.sonnenaufgang_minute', ('' + (getDateObject(getAstroDate('sunrise', undefined, 0)).getMinutes())));
                  // Sonnenuntergang
                  setState('javascript.0.zeiten.sonnenuntergang', ('' + formatDate(getDateObject(getAstroDate('sunset', undefined, 0)), "hh:mm")));
                Edit, laut Fehlermeldung hat die Zeile 4 in Deiner Version des aus dem Blockly generierten Javascript-Quellcodes am Zeilenende eine schließende Klammer mehr.
                Da verhaspelt sich der Codegenerator des Blockly wohl ein wenig im experimental release ...
                Quatsch - habe mich verguckt, die Zeile sieht genauso aus ... in meinem Javascript Editor von 7.1.xx
                Quatsch2 da fehlt doch eine öffnende Klammer - hier die beiden Zeilen im Vergleich (oben fehlermeldung vs. unten bei mir erzeugter Code) :
                setState('javascript.0.zeiten.sonnenaufgang_minute', ('' + getDateObject(getAstroDate('sunrise', undefined, 0)).getMinutes())));
                • MartinPM MartinP
                    // Sonnenaufgang
                    // Sonnenuntergang
                  ticaki
                  @martinp
                  Bitte Issue eröffnen, wegen der fehlenden Klammer. bzw. die schließende scheint zu viel.
                  Spenden
                  • T ticaki
                    @martinp
                    MartinPM Offline
                    MartinPM Offline
                    MartinP
                    @ticaki Erledigt https://github.com/ioBroker/ioBroker.javascript/issues/1463 - vielleicht kann @NinjaTurtle85 auch noch etwas ausfüllen - Die Umgebung zur Reproduktion des Fehlers kenne ich nicht ...
