  4. Awattar Adapter aktualisiert nicht mehr
16 Beiträge 2 Kommentatoren 3.3k Aufrufe 2 Beobachtet
  • B badsnoopy667
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker2023
             Icon name: computer-vm
               Chassis: vm
        Virtualization: kvm
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 5.10.0-20-amd64
          Architecture: x86-64
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     11:53:08 up 6 days, 11:27,  1 user,  load average: 0.54, 0.36, 0.27
    CPU threads: 16
    This system needs to be REBOOTED!
    *** Time and Time Zones ***
                   Local time: Wed 2023-11-22 11:53:09 CET
               Universal time: Wed 2023-11-22 10:53:09 UTC
                     RTC time: Wed 2023-11-22 10:53:10
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    iobroker
    /home/iobroker
    iobroker tty dialout cdrom floppy audio dip video plugdev netdev
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            3.8G        2.9G        461M        0.0K        478M        710M
    Swap:           974M        451M        523M
    Total:          4.8G        3.3G        984M
             3833 M total memory
             2894 M used memory
             1898 M active memory
             1208 M inactive memory
              460 M free memory
              159 M buffer memory
              319 M swap cache
              974 M total swap
              451 M used swap
              523 M free swap
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  1.9G     0  1.9G   0% /dev
    tmpfs          tmpfs     384M  492K  383M   1% /run
    /dev/sda1      ext4       47G  7.0G   37G  16% /
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    [sudo] password for iobroker:
    [Thu Nov 16 00:25:15 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Thu Nov 16 00:25:15 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.4G    /var/
    1.1G    /var/log
    1001M   /var/log/journal/6142cd24c64f4d70a507d7e820e723ce
    222M    /var/cache
    Archived and active journals take up 616.0M in the file system.
    /opt/iobroker/backups:
    362M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1001M   /opt/iobroker/iobroker-data/
    549M    /opt/iobroker/iobroker-data/history
    219M    /opt/iobroker/iobroker-data/files
    130M    /opt/iobroker/iobroker-data/backup-objects
    52M     /opt/iobroker/iobroker-data/files/javascript.admin
    35M     /opt/iobroker/iobroker-data/states.jsonl
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
    18M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.274a4d8d.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /home/iobroker/.diag.sh: line 277: nodejs: command not found
    /usr/bin/node           v16.20.2
    /usr/bin/npm            8.19.4
    /usr/bin/npx            8.19.4
    /usr/bin/corepack       0.17.0
    /home/iobroker/.diag.sh: line 288: nodejs: command not found
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.20.2-deb-1nodesource1
      Candidate: 16.20.2-deb-1nodesource1
      Version table:
     *** 16.20.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
    No problems detected
    Errors in npm tree:
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.12
    admin:          6.12.0
    javascript:     7.1.4
    Adapters from github:   4
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker2023                             -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.awattar.0                : awattar               : iobroker2023                             -  enabled, compact disabled
    + system.adapter.backitup.0               : backitup              : iobroker2023                             -  enabled, compact disabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker2023                             -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker2023                             -  enabled, compact disabled
    + system.adapter.denon.0                  : denon                 : iobroker2023                             -  enabled, compact disabled
      system.adapter.dwd.0                    : dwd                   : iobroker2023                             -  enabled, compact disabled
    + system.adapter.eusec.0                  : eusec                 : iobroker2023                             -  enabled, compact disabled
    + system.adapter.fiat.0                   : fiat                  : iobroker2023                             -  enabled, compact disabled
      system.adapter.flot.0                   : flot                  : iobroker2023                             -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker2023                             -  enabled, compact disabled
    + system.adapter.go-e.0                   : go-e                  : iobroker2023                             -  enabled, compact disabled
    + system.adapter.history.0                : history               : iobroker2023                             -  enabled, compact disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker2023                             -  enabled, compact disabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker2023                             -  enabled, compact disabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker2023                             -  enabled, compact disabled, port: 0
    + system.adapter.hue.0                    : hue                   : iobroker2023                             -  enabled, compact disabled, port: 80
      system.adapter.ical.0                   : ical                  : iobroker2023                             -  enabled, compact disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker2023                             -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker2023                             -  enabled
      system.adapter.info.0                   : info                  : iobroker2023                             - disabled, compact disabled
    + system.adapter.javascript.0             : javascript            : iobroker2023                             -  enabled, compact disabled
      system.adapter.lovelace.0               : lovelace              : iobroker2023                             - disabled, compact disabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker2023                             -  enabled, compact disabled, port: 54321
      system.adapter.mqtt.0                   : mqtt                  : iobroker2023                             - disabled, compact disabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : iobroker2023                             -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.2                   : mqtt                  : iobroker2023                             - disabled, compact disabled, port: 1884, bind: 0.0.0.0
    + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobroker2023                             -  enabled, compact disabled, port: 16021
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker2023                             -  enabled, compact disabled
    + system.adapter.node-red.0               : node-red              : iobroker2023                             -  enabled, compact disabled, port: 1880, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : iobroker2023                             -  enabled, compact disabled
    + system.adapter.pvforecast.0             : pvforecast            : iobroker2023                             -  enabled, compact disabled
    + system.adapter.scenes.0                 : scenes                : iobroker2023                             -  enabled, compact disabled
    + system.adapter.shelly.0                 : shelly                : iobroker2023                             -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
      system.adapter.solarwetter.0            : solarwetter           : iobroker2023                             -  enabled, compact disabled
    + system.adapter.sonoff.1                 : sonoff                : iobroker2023                             -  enabled, compact disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker2023                             -  enabled, compact disabled
      system.adapter.spotify-premium.0        : spotify-premium       : iobroker2023                             - disabled, compact disabled
    + system.adapter.telegram.1               : telegram              : iobroker2023                             -  enabled, compact disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tesla-motors.0           : tesla-motors          : iobroker2023                             -  enabled, compact disabled
      system.adapter.text2command.0           : text2command          : iobroker2023                             - disabled, compact disabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker2023                             -  enabled, compact disabled
    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker2023                             -  enabled, compact disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker2023                             -  enabled
      system.adapter.vis.0                    : vis                   : iobroker2023                             -  enabled, compact disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker2023                             -  enabled, compact disabled
    + system.adapter.web.0                    : web                   : iobroker2023                             -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.yahka.0                  : yahka                 : iobroker2023                             -  enabled, compact disabled
      system.adapter.yr.0                     : yr                    : iobroker2023                             - disabled, compact disabled
    + instance is alive
    ioBroker-Repositories
    sources       : conf/sources-dist.json
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.12.0   , installed 6.12.0
    Adapter    "awattar"      : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
    Adapter    "denon"        : 1.15.4   , installed 1.15.4
    Adapter    "eusec"        : 1.2.1    , installed 1.1.2  [Updatable]
    Adapter    "fiat"         : 0.0.8    , installed 0.0.8
    Adapter    "fullybrowser" : 3.0.6    , installed 2.2.0  [Updatable]
    Adapter    "go-e"         : 1.0.27   , installed 1.0.27
    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
    Adapter    "hue"          : 3.10.1   , installed 3.10.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "info"         : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
    Controller "js-controller": 5.0.16   , installed 5.0.12 [Updatable]
    Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.0.0  [Updatable]
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
    Adapter    "node-red"     : 4.0.3    , installed 4.0.3
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
    Adapter    "solarwetter"  : 1.1.5    , installed 1.1.5
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "spotify-premium": 1.3.1  , installed 1.2.2  [Updatable]
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "tesla-motors" : 1.3.2    , installed 1.3.2
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis-justgage" : 2.0.0    , installed 1.0.2  [Updatable]
    Adapter    "weatherunderground": 3.6.0, installed 3.6.0
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        26205
    States:         20992
    W: GPG error: https://deb.nodesource.com/node_18.x nodistro InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 2F59B5F99B1BE0B4
    E: The repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' is not signed.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8555            0.0.0.0:*               LISTEN      1000       15813      1085/go2rtc
    tcp        0      0 127.0.0.1:41197         0.0.0.0:*               LISTEN      1000       9319209    128090/io.yahka.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14444      1/systemd
    tcp        0      0 192.168.0.47:2001       0.0.0.0:*               LISTEN      1000       11368013   182296/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          961490     24656/sshd: /usr/sb
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       14595      566/node-red
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       1376       762/io.sonoff.1
    tcp        0      0 192.168.0.47:2010       0.0.0.0:*               LISTEN      1000       1313       652/io.hm-rpc.1
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       17531      712/io.mqtt.1
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       1189       455/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       2267       455/iobroker.js-con
    tcp6       0      0 :::111                  :::*                    LISTEN      0          14317      1/systemd
    tcp6       0      0 :::36721                :::*                    LISTEN      1000       7216772    128090/io.yahka.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       2285       494/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       19555      1013/io.web.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          961492     24656/sshd: /usr/sb
    tcp6       0      0 :::1984                 :::*                    LISTEN      1000       15805      1085/go2rtc
    tcp6       0      0 :::8554                 :::*                    LISTEN      1000       15808      1085/go2rtc
    udp        0      0 0.0.0.0:41171           0.0.0.0:*                           1000       9244647    1060/io.eusec.0
    udp        0      0 0.0.0.0:8555            0.0.0.0:*                           1000       15809      1085/go2rtc
    udp        0      0 0.0.0.0:51580           0.0.0.0:*                           1000       9093577    1060/io.eusec.0
    udp        0      0 0.0.0.0:33154           0.0.0.0:*                           1000       9141736    1060/io.eusec.0
    udp        0      0 0.0.0.0:53682           0.0.0.0:*                           1000       6198537    1060/io.eusec.0
    udp        0      0 0.0.0.0:43451           0.0.0.0:*                           1000       9212411    1060/io.eusec.0
    udp        0      0 0.0.0.0:43490           0.0.0.0:*                           1000       9148607    1060/io.eusec.0
    udp        0      0 0.0.0.0:49674           0.0.0.0:*                           1000       9115814    1060/io.eusec.0
    udp        0      0 0.0.0.0:39505           0.0.0.0:*                           1000       9499560    1060/io.eusec.0
    udp        0      0 0.0.0.0:39535           0.0.0.0:*                           1000       9194434    1060/io.eusec.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       15680      825/io.broadlink2.0
    udp        0      0 0.0.0.0:39754           0.0.0.0:*                           1000       9461723    1060/io.eusec.0
    udp        0      0 0.0.0.0:48046           0.0.0.0:*                           1000       6198249    1060/io.eusec.0
    udp        0      0 0.0.0.0:48055           0.0.0.0:*                           1000       9364374    1060/io.eusec.0
    udp        0      0 0.0.0.0:35803           0.0.0.0:*                           1000       9073218    1060/io.eusec.0
    udp        0      0 0.0.0.0:37902           0.0.0.0:*                           1000       9214361    1060/io.eusec.0
    udp        0      0 0.0.0.0:35896           0.0.0.0:*                           1000       9071561    1060/io.eusec.0
    udp        0      0 0.0.0.0:52326           0.0.0.0:*                           1000       9380150    1060/io.eusec.0
    udp        0      0 0.0.0.0:52330           0.0.0.0:*                           1000       9504348    1060/io.eusec.0
    udp        0      0 0.0.0.0:33904           0.0.0.0:*                           1000       9247721    1060/io.eusec.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       7216773    128090/io.yahka.0
    udp        0      0 192.168.0.47:5353       0.0.0.0:*                           1000       2811       779/io.tr-064.0
    udp        0      0 0.0.0.0:38122           0.0.0.0:*                           1000       15683      825/io.broadlink2.0
    udp        0      0 0.0.0.0:52465           0.0.0.0:*                           1000       9164734    1060/io.eusec.0
    udp        0      0 0.0.0.0:50435           0.0.0.0:*                           1000       9073664    1060/io.eusec.0
    udp        0      0 0.0.0.0:60725           0.0.0.0:*                           1000       9195841    1060/io.eusec.0
    udp        0      0 0.0.0.0:34182           0.0.0.0:*                           1000       1344062    1060/io.eusec.0
    udp        0      0 0.0.0.0:54746           0.0.0.0:*                           1000       9399886    1060/io.eusec.0
    udp        0      0 0.0.0.0:56809           0.0.0.0:*                           1000       9171515    1060/io.eusec.0
    udp        0      0 0.0.0.0:34318           0.0.0.0:*                           1000       9205124    1060/io.eusec.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       14677      744/io.shelly.0
    udp        0      0 0.0.0.0:48741           0.0.0.0:*                           1000       9215704    1060/io.eusec.0
    udp        0      0 0.0.0.0:46801           0.0.0.0:*                           1000       9142226    1060/io.eusec.0
    udp        0      0 0.0.0.0:50913           0.0.0.0:*                           1000       9172805    1060/io.eusec.0
    udp        0      0 0.0.0.0:34562           0.0.0.0:*                           1000       9272032    1060/io.eusec.0
    udp        0      0 0.0.0.0:42823           0.0.0.0:*                           1000       9077126    1060/io.eusec.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       1461       918/io.nanoleaf-lig
    udp        0      0 0.0.0.0:36820           0.0.0.0:*                           1000       9375936    1060/io.eusec.0
    udp        0      0 0.0.0.0:59380           0.0.0.0:*                           1000       20635      1060/io.eusec.0
    udp        0      0 0.0.0.0:45060           0.0.0.0:*                           1000       18446      825/io.broadlink2.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          2209       371/dhclient
    udp        0      0 0.0.0.0:36943           0.0.0.0:*                           1000       6608309    1060/io.eusec.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2092       1/systemd
    udp        0      0 0.0.0.0:45185           0.0.0.0:*                           1000       9214612    1060/io.eusec.0
    udp        0      0 0.0.0.0:45203           0.0.0.0:*                           1000       9057374    1060/io.eusec.0
    udp        0      0 0.0.0.0:47273           0.0.0.0:*                           1000       20630      1060/io.eusec.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       625        697/io.mihome-vacuu
    udp        0      0 0.0.0.0:59587           0.0.0.0:*                           1000       9461475    1060/io.eusec.0
    udp6       0      0 :::8443                 :::*                                1000       15814      1085/go2rtc
    udp6       0      0 :::111                  :::*                                0          4410       1/systemd
    2023-11-22 11:47:00.316  - info: javascript.0 (148538) script.js.Eigene_Scripte.Wetter.sonne_scheint: Sonne scheint (ungepuffert) = unwahr
    2023-11-22 11:47:04.519  - debug: fullybrowser.0 (885) get Information
    2023-11-22 11:48:00.016  - info: host.iobroker2023 instance system.adapter.weatherunderground.0 started with pid 188074
    2023-11-22 11:48:00.056  - debug: fullybrowser.0 (885) stateID fullybrowser.0.192_168_0_21.Commands.textToSpeech changed:   (ack = false)
    2023-11-22 11:48:00.057  - debug: fullybrowser.0 (885) Send http://192.168.0.21:2323/?cmd=textToSpeech&text=%20&password=1234
    2023-11-22 11:48:01.088  - info: weatherunderground.0 (188074) starting. Version 3.6.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.20.2, js-controller: 5.0.12
    2023-11-22 11:48:04.520  - debug: fullybrowser.0 (885) get Information
    2023-11-22 11:48:24.640  - info: weatherunderground.0 (188074) Terminated (NO_ERROR): Without reason
    2023-11-22 11:48:25.149  - info: host.iobroker2023 instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2023-11-22 11:48:30.110  - debug: fullybrowser.0 (885) stateID fullybrowser.0.192_168_0_21.Commands.setAudioVolume changed: 80 (ack = false)
    2023-11-22 11:48:30.110  - debug: fullybrowser.0 (885) Send http://192.168.0.21:2323/?cmd=setAudioVolume&level=80&stream=3&password=1234
    2023-11-22 11:49:04.520  - debug: fullybrowser.0 (885) get Information
    2023-11-22 11:49:24.604  - info: javascript.0 (148538) script.js.Eigene_Scripte.Wetter.es_regnet_setzen: Es regnet nicht mehr
    2023-11-22 11:50:04.520  - debug: fullybrowser.0 (885) get Information
    2023-11-22 11:51:04.521  - debug: fullybrowser.0 (885) get Information
    2023-11-22 11:51:10.261  - info: daikin-cloud.0 (148466) Daikin-Cloud tokens updated ...
    2023-11-22 11:51:11.791  - info: daikin-cloud.0 (148466) Daikin-Cloud tokens updated ...
    2023-11-22 11:51:34.598  - info: javascript.0 (148538) script.js.Eigene_Scripte.Wetter.es_regnet_setzen: Es regnet nicht mehr
    2023-11-22 11:51:34.600  - info: javascript.0 (148538) script.js.Eigene_Scripte.Wetter.sonne_scheint: Sonne scheint (ungepuffert) = unwahr
    2023-11-22 11:51:40.085  - info: web.0 (1013) <== Disconnect system.user.admin from ::ffff:192.168.0.21 flot
    2023-11-22 11:51:40.111  - info: web.0 (1013) <== Disconnect system.user.admin from ::ffff:192.168.0.21 vis.0
    2023-11-22 11:51:44.153  - info: web.0 (1013) ==> Connected system.user.admin from ::ffff:192.168.0.21
    2023-11-22 11:51:50.143  - info: web.0 (1013) ==> Connected system.user.admin from ::ffff:192.168.0.21
    2023-11-22 11:52:04.521  - debug: fullybrowser.0 (885) get Information
    2023-11-22 11:53:04.521  - debug: fullybrowser.0 (885) get Information
    Ich sehe schon, irgendwas stimmt mit nodejs schon wieder nicht...
    @badsnoopy667 sagte in Awattar Adapter aktualisiert nicht mehr:
    Setz den user iobroker (übrigens ein unglücklicher username) in die Gruppe adm.
    Bring nodejs auf Version 18.
    iobroker nodejs-update
    Bring die Adapter auf Stand.
      badsnoopy667
      @thomas-braun said in Awattar Adapter aktualisiert nicht mehr:
      Reboot: Erledigt
      User verschieben: Erledigt
      iobroker nodejs-update --> will er nicht, er gibt mir nur die Auswahl aller iobroker Befehle zurück.
      Hatte vor ein paar Tagen schonmal versucht nodejs auf 18 zu bringen und dafür die aktuelle Anleitung aus dem Forum hier befolgt. Bin aber daran gescheitert, dass er irgendwann gemeckert hat, dass das von mir eingetragene Repository nicht verifiziert wäre (oder so ähnlich). Dann bin ich nicht weitergekommen.
      • B badsnoopy667
        Reboot: Erledigt
        @badsnoopy667
        iob stop
        iob fix
        iob nodejs-update
          @badsnoopy667
          iob stop
          iob fix
          iob nodejs-update
          badsnoopy667
          Vielen Dank für Deine Hilfe! Das hat jetzt (anscheinend) funktioniert!
          iob diag:
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                     Chassis: vm
              Virtualization: kvm
                      Kernel: Linux 5.10.0-26-amd64
          Docker          : false
          Kernel          : x86_64
          Userland        : amd64
           12:24:21 up 21 min,  1 user,  load average: 0.11, 0.09, 0.12
          CPU threads: 16
                         Local time: Wed 2023-11-22 12:24:21 CET
                     Universal time: Wed 2023-11-22 11:24:21 UTC
                           RTC time: Wed 2023-11-22 11:24:22
                        NTP service: active
                    RTC in local TZ: no
          iobroker
          /home/iobroker
          iobroker adm tty dialout cdrom floppy audio dip video plugdev netdev
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        103M        2.7G        0.0K        1.0G        3.4G
          Swap:           974M          0B        974M
          Total:          4.8G        103M        3.7G
                   3821 M total memory
                    103 M used memory
                    396 M active memory
                    450 M inactive memory
                   2694 M free memory
                    159 M buffer memory
                    865 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
            UNIT             LOAD   ACTIVE SUB    DESCRIPTION
          * iobroker.service loaded failed failed ioBroker Server
          1 loaded units listed.
          *** FILESYSTEM ***
          tmpfs          tmpfs     383M  484K  382M   1% /run
          tmpfs          tmpfs     383M     0  383M   0% /run/user/1000
          [Wed Nov 22 12:02:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
          [Wed Nov 22 12:02:34 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
          /var:
          1.5G    /var/
          1.1G    /var/log/journal/6142cd24c64f4d70a507d7e820e723ce
          1.1G    /var/log
          250M    /var/cache
          Archived and active journals take up 1.0G in the file system.
          968M    /opt/iobroker/iobroker-data/
          550M    /opt/iobroker/iobroker-data/history
          25M     /opt/iobroker/iobroker-data/objects.jsonl
          9.3M    /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /usr/bin/nodejs         v18.18.2
          /usr/bin/node           v18.18.2
          /usr/bin/npm            9.8.1
          /usr/bin/npx            9.8.1
          /usr/bin/corepack       0.19.0
          nodejs:
            Installed: 18.18.2-1nodesource1
            Candidate: 18.18.2-1nodesource1
            Version table:
           *** 18.18.2-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          Errors in npm tree:
          ioBroker Status
          iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
          admin:          6.12.0
          javascript:     7.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        26205
          States:         20991
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13305      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17317      477/sshd: /usr/sbin
          tcp6       0      0 :::111                  :::*                    LISTEN      0          3132       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17319      477/sshd: /usr/sbin
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          17540      362/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16503      1/init
          udp6       0      0 :::111                  :::*                                0          37         1/init
          2023-11-22 12:10:41.768  - info: host.iobroker2023 instance system.adapter.shelly.0 terminated with code 0 (NO_ERROR)
          2023-11-22 12:10:42.199  - warn: host.iobroker2023 instance system.adapter.javascript.0 terminated due to SIGTERM
          2023-11-22 12:10:42.200  - info: host.iobroker2023 instance system.adapter.javascript.0 terminated with code null ()
          2023-11-22 12:10:42.214  - warn: host.iobroker2023 instance system.adapter.telegram.1 terminated due to SIGTERM
          2023-11-22 12:10:42.215  - info: host.iobroker2023 instance system.adapter.telegram.1 terminated with code null ()
          2023-11-22 12:10:42.228  - warn: host.iobroker2023 instance system.adapter.hm-rega.0 terminated due to SIGTERM
          2023-11-22 12:10:42.228  - info: host.iobroker2023 instance system.adapter.hm-rega.0 terminated with code null ()
          2023-11-22 12:10:42.246  - warn: host.iobroker2023 instance system.adapter.hm-rpc.1 terminated due to SIGTERM
          2023-11-22 12:10:42.246  - info: host.iobroker2023 instance system.adapter.hm-rpc.1 terminated with code null ()
          2023-11-22 12:10:42.277  - warn: host.iobroker2023 instance system.adapter.ping.0 terminated due to SIGTERM
          2023-11-22 12:10:42.277  - info: host.iobroker2023 instance system.adapter.ping.0 terminated with code null ()
          2023-11-22 12:10:42.277  - warn: host.iobroker2023 instance system.adapter.sonoff.1 terminated due to SIGTERM
          2023-11-22 12:10:42.277  - info: host.iobroker2023 instance system.adapter.sonoff.1 terminated with code null ()
          2023-11-22 12:10:42.295  - warn: host.iobroker2023 instance system.adapter.tesla-motors.0 terminated due to SIGTERM
          2023-11-22 12:10:42.295  - info: host.iobroker2023 instance system.adapter.tesla-motors.0 terminated with code null ()
          2023-11-22 12:10:42.314  - warn: host.iobroker2023 instance system.adapter.virtualpowermeter.0 terminated due to SIGTERM
          2023-11-22 12:10:42.314  - info: host.iobroker2023 instance system.adapter.virtualpowermeter.0 terminated with code null ()
          2023-11-22 12:10:42.329  - warn: host.iobroker2023 instance system.adapter.web.0 terminated due to SIGTERM
          2023-11-22 12:10:42.329  - info: host.iobroker2023 instance system.adapter.web.0 terminated with code null ()
          2023-11-22 12:10:42.399  - warn: host.iobroker2023 instance system.adapter.eusec.0 terminated due to SIGTERM
          2023-11-22 12:10:42.399  - info: host.iobroker2023 instance system.adapter.eusec.0 terminated with code null ()
          2023-11-22 12:10:42.400  - info: host.iobroker2023 instance system.adapter.node-red.0 terminated with code 0 (NO_ERROR)
          2023-11-22 12:10:42.451  - info: host.iobroker2023 instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
          2023-11-22 12:10:42.451  - info: host.iobroker2023 All instances are stopped.
          2023-11-22 12:10:42.629  - info: host.iobroker2023 terminated
          • B badsnoopy667
            iob diag:
            Skript v.2023-10-10
            *** BASE SYSTEM ***
                       Chassis: vm
                Virtualization: kvm
            Docker          : false
            Kernel          : x86_64
            Userland        : amd64
            CPU threads: 16
                          NTP service: active
                      RTC in local TZ: no
            iobroker
            /home/iobroker
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:           974M          0B        974M
                     3821 M total memory
                      103 M used memory
                      396 M active memory
                     2694 M free memory
                      159 M buffer memory
                      865 M swap cache
                      974 M total swap
                        0 M used swap
                      974 M free swap
            *** FILESYSTEM ***
            /var:
            1.5G    /var/
            1.1G    /var/log
            250M    /var/cache
            USB-Devices by-id:
            /usr/bin/npm            9.8.1
            /usr/bin/npx            9.8.1
            nodejs:
              Version table:
            Errors in npm tree:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.12.0
            javascript:     7.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        26205
            States:         20991
            Pending Updates: 0
            • iobroker.service loaded failed failed ioBroker Server
            Was klemmt denn da?
            iob restart
            Deine iob-Repos sind auch komisch.
            iob repo del sources
            iob repo del online
            Den ioBroker auf Stand halten:
            iob update
            iob upgrade all
            iob stop
            iob upgrade self
            iob start
              Was klemmt denn da?
              iob restart
              iob repo del online
              iob update
              iob upgrade all
              iob stop
              iob upgrade self
              iob start
              badsnoopy667
              schrieb am zuletzt editiert von badsnoopy667
              So, habe ich gemacht. Läuft auch alles, nur der fullybrowser Adapter bleibt gelb. Gut, das ist vermutlich ein anderes Thema jetzt.
              Meinst Du, ich könnte jetzt versuchen auf Debian Bookworm upzudaten? Das schiebe ich nämlich noch vor mit her und wollte vorher erstmal nodejs auf Stand bringen. Das hat ja jetzt anscheinend geklappt.
              2023-11-22 13:37:49.806  - info: host.iobroker2023 "system.adapter.fullybrowser.0" disabled
              2023-11-22 13:37:49.807  - info: host.iobroker2023 stopInstance system.adapter.fullybrowser.0 (force=false, process=true)
              2023-11-22 13:37:49.810  - info: fullybrowser.0 (7258) Got terminate signal TERMINATE_YOURSELF
              2023-11-22 13:37:49.812  - info: fullybrowser.0 (7258) [MQTT] Disconnect all clients and close server
              2023-11-22 13:37:49.813  - info: fullybrowser.0 (7258) terminating
              2023-11-22 13:37:49.813  - info: fullybrowser.0 (7258) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2023-11-22 13:37:49.814  - debug: fullybrowser.0 (7258) [MQTT] aedes.close() succeeded
              2023-11-22 13:37:49.814  - debug: fullybrowser.0 (7258) [MQTT] server.close() succeeded
              2023-11-22 13:37:49.858  - info: host.iobroker2023 stopInstance system.adapter.fullybrowser.0 send kill signal
              2023-11-22 13:37:50.311  - info: fullybrowser.0 (7258) terminating
              2023-11-22 13:37:50.379  - info: host.iobroker2023 instance system.adapter.fullybrowser.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2023-11-22 13:37:51.010  - info: host.iobroker2023 "system.adapter.fullybrowser.0" enabled
              2023-11-22 13:37:51.255  - info: host.iobroker2023 instance system.adapter.fullybrowser.0 started with pid 7505
              2023-11-22 13:37:51.727  - debug: fullybrowser.0 (7505) Redis Objects: Use Redis connection: 127.0.0.1:9001
              2023-11-22 13:37:51.759  - debug: fullybrowser.0 (7505) Objects client ready ... initialize now
              2023-11-22 13:37:51.760  - debug: fullybrowser.0 (7505) Objects create System PubSub Client
              2023-11-22 13:37:51.761  - debug: fullybrowser.0 (7505) Objects create User PubSub Client
              2023-11-22 13:37:51.827  - debug: fullybrowser.0 (7505) Objects client initialize lua scripts
              2023-11-22 13:37:51.829  - debug: fullybrowser.0 (7505) Objects connected to redis: 127.0.0.1:9001
              2023-11-22 13:37:51.860  - debug: fullybrowser.0 (7505) Redis States: Use Redis connection: 127.0.0.1:9000
              2023-11-22 13:37:51.878  - debug: fullybrowser.0 (7505) States create System PubSub Client
              2023-11-22 13:37:51.879  - debug: fullybrowser.0 (7505) States create User PubSub Client
              2023-11-22 13:37:51.952  - debug: fullybrowser.0 (7505) States connected to redis: 127.0.0.1:9000
              2023-11-22 13:37:52.017  - info: fullybrowser.0 (7505) starting. Version 3.0.6 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v18.18.2, js-controller: 5.0.16
              2023-11-22 13:37:52.031  - debug: fullybrowser.0 (7505) Final Config: {"name":"192.168.0.21","id":"LenovoTabletFlur","ip":"192.168.0.21","enabled":true,"mqttInfoObjectsCreated":false,"mqttInfoKeys":[],"restProtocol":"http","restPort":2323,"restPassword":"(hidden)","lastSeen":0,"isAlive":false,"apiType":"mqtt"}
              2023-11-22 13:37:52.032  - info: fullybrowser.0 (7505) 🗸 192.168.0.21 (192.168.0.21): Config successfully verified.
              2023-11-22 13:37:52.032  - debug: fullybrowser.0 (7505) Adapter settings successfully verified and initialized.
              2023-11-22 13:37:52.109  - info: fullybrowser.0 (7505) 🚀 Start RESTApi request intervall
              2023-11-22 13:37:52.109  - info: fullybrowser.0 (7505) 🚀 MQTT Server started and is listening on port 3000.
              Edit: Fullybrowser geht wieder, da war der MQTT Pfad falsch gesetzt.
              • B badsnoopy667
                Kannst du machen. Die Ausgangsbasis ist jetzt sauber?
                  badsnoopy667
                  Ich denke schon! Vielen Dank nochmal für Deine Hilfe!
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                             Chassis: vm
                      Virtualization: kvm
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : amd64
                   15:19:38 up  3:17,  1 user,  load average: 0.13, 0.24, 0.26
                  CPU threads: 16
                                 Local time: Wed 2023-11-22 15:19:38 CET
                             Universal time: Wed 2023-11-22 14:19:38 UTC
                                   RTC time: Wed 2023-11-22 14:19:39
                                NTP service: active
                            RTC in local TZ: no
                  iobroker
                  /home/iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            3.8G        2.9G        376M        0.0K        498M        638M
                  Swap:           974M        3.0M        971M
                  Total:          4.8G        3.0G        1.3G
                           3821 M total memory
                           2947 M used memory
                            233 M active memory
                           2950 M inactive memory
                            375 M free memory
                             77 M buffer memory
                            421 M swap cache
                            974 M total swap
                              3 M used swap
                            971 M free swap
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     383M  488K  382M   1% /run
                  /dev/sda1      ext4       47G  7.0G   37G  17% /
                  /var:
                  1.5G    /var/
                  1.1G    /var/log
                  250M    /var/cache
                  988M    /opt/iobroker/iobroker-data/
                  552M    /opt/iobroker/iobroker-data/history
                  35M     /opt/iobroker/iobroker-data/objects.jsonl
                  17M     /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            9.8.1
                  /usr/bin/npx            9.8.1
                  nodejs:
                    Version table:
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.4
                  Adapter State
                  + instance is alive
                  Adapter    "eusec"        : 1.2.1    , installed 1.2.1
                  Adapter    "fullybrowser" : 3.0.6    , installed 3.0.6
                  Controller "js-controller": 5.0.16   , installed 5.0.16
                  Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
                  Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
                  Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
                  Objects and States
                  Objects:        26482
                  States:         21176
                  Pending Updates: 0
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       43927      6334/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       49903      6334/iobroker.js-co
                  tcp        0      0 192.168.0.47:2001       0.0.0.0:*               LISTEN      1000       67114      6507/io.hm-rpc.0
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       65717      6436/node-red
                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       57050      6633/io.sonoff.1
                  tcp        0      0 192.168.0.47:2010       0.0.0.0:*               LISTEN      1000       49978      6522/io.hm-rpc.1
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       56977      6582/io.mqtt.1
                  tcp        0      0 127.0.0.1:36421         0.0.0.0:*               LISTEN      1000       70740      6898/io.yahka.0
                  tcp6       0      0 :::8554                 :::*                    LISTEN      1000       68061      6960/go2rtc
                  tcp6       0      0 :::8555                 :::*                    LISTEN      1000       68065      6960/go2rtc
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       46924      6352/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       68038      6881/io.web.0
                  tcp6       0      0 :::43987                :::*                    LISTEN      1000       59113      6898/io.yahka.0
                  tcp6       0      0 :::3000                 :::*                    LISTEN      1000       102368     7883/io.fullybrowse
                  tcp6       0      0 :::1984                 :::*                    LISTEN      1000       59131      6960/go2rtc
                  udp        0      0 0.0.0.0:52130           0.0.0.0:*                           1000       71959      6930/io.eusec.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       59114      6898/io.yahka.0
                  udp        0      0 192.168.0.47:5353       0.0.0.0:*                           1000       65855      6648/io.tr-064.0
                  udp        0      0 0.0.0.0:34354           0.0.0.0:*                           1000       68647      6693/io.broadlink2.
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       57020      6616/io.shelly.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       50108      6789/io.nanoleaf-li
                  udp        0      0 0.0.0.0:51253           0.0.0.0:*                           1000       69661      6693/io.broadlink2.
                  udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1000       65826      6567/io.mihome-vacu
                  udp        0      0 0.0.0.0:45380           0.0.0.0:*                           1000       71954      6930/io.eusec.0
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       69657      6693/io.broadlink2.
                  udp6       0      0 :::8555                 :::*                                1000       68066      6960/go2rtc
                  2023-11-22 15:18:30.022  - warn: javascript.0 (6394)     at listOnTimeout (node:internal/timers:571:11)
                  2023-11-22 15:18:30.022  - warn: javascript.0 (6394)     at processTimers (node:internal/timers:512:7)
                  2023-11-22 15:18:30.064  - info: javascript.0 (6394) State value to set for "fullybrowser.0.LenovoTabletFlur.Commands.setAudioVolume" has to be type "number" but received type "string"
                  2023-11-22 15:18:30.069  - debug: fullybrowser.0 (7883) state fullybrowser.0.LenovoTabletFlur.Commands.setAudioVolume changed: 80 (ack = false)
                  2023-11-22 15:18:30.130  - debug: fullybrowser.0 (7883) [REST] 192.168.0.21: Sending command setAudioVolume response.data: {"statustext":"Audio volume set to 80% for stream 3","status":"OK"}
                  2023-11-22 15:18:30.130  - debug: fullybrowser.0 (7883) [REST] 192.168.0.21: Sending command setAudioVolume successful: - Status = "OK", Message = "Audio volume set to 80% for stream 3"
                  2023-11-22 15:18:30.130  - info: fullybrowser.0 (7883) 🗸 192.168.0.21: Command setAudioVolume successfully set to 80
                  2023-11-22 15:18:30.131  - info: fullybrowser.0 (7883) State value to set for "fullybrowser.0.LenovoTabletFlur.Commands.setAudioVolume" has to be type "number" but received type "string"
                  2023-11-22 15:18:33.009  - info: web.0 (6881) <== Disconnect system.user.admin from ::ffff:192.168.0.21 flot
                  2023-11-22 15:18:33.022  - info: web.0 (6881) <== Disconnect system.user.admin from ::ffff:192.168.0.21 flot
                  2023-11-22 15:18:33.035  - info: web.0 (6881) <== Disconnect system.user.admin from ::ffff:192.168.0.21 flot
                  2023-11-22 15:18:33.060  - info: web.0 (6881) <== Disconnect system.user.admin from ::ffff:192.168.0.21 vis.0
                  2023-11-22 15:18:37.065  - info: web.0 (6881) ==> Connected system.user.admin from ::ffff:192.168.0.21
                  2023-11-22 15:18:43.496  - info: web.0 (6881) ==> Connected system.user.admin from ::ffff:192.168.0.21
                  2023-11-22 15:19:03.326  - info: javascript.0 (6394) script.js.Eigene_Scripte.Licht.BM_Badezimmer_neu: Licht im Badezimmer auf volle Helligkeit!
                  2023-11-22 15:19:37.586  - info: javascript.0 (6394) script.js.Eigene_Scripte.Licht.BM_Badezimmer_neu: Licht im Badezimmer auf volle Helligkeit!
                  2023-11-22 15:19:37.586  - warn: javascript.0 (6394) State "fullybrowser.0.192_168_0_21.Commands.stopDaydream" not found
                  2023-11-22 15:19:37.587  - warn: javascript.0 (6394)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1740:20)
                  2023-11-22 15:19:37.587  - warn: javascript.0 (6394)     at Object.<anonymous> (script.js.Eigene_Scripte.Licht.Bewegungsmelder_Wohnungsflur:9:5)
                  2023-11-22 15:19:37.587  - warn: javascript.0 (6394)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
                  2023-11-22 15:19:37.587  - warn: javascript.0 (6394)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
                  2023-11-22 15:19:37.587  - warn: javascript.0 (6394)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11220:62)
                  2023-11-22 15:19:37.587  - warn: javascript.0 (6394)     at processImmediate (node:internal/timers:476:21)
                  2023-11-22 15:19:43.116  - info: javascript.0 (6394) script.js.Eigene_Scripte.Licht.BM_Badezimmer_neu: Licht im Badezimmer auf volle Helligkeit!
                  2023-11-22 15:20:12.588  - info: javascript.0 (6394) script.js.Eigene_Scripte.Licht.BM_Badezimmer_neu: Licht im Badezimmer auf volle Helligkeit!
                  • B badsnoopy667
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: vm
                        Virtualization: kvm
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                    CPU threads: 16
                                  NTP service: active
                              RTC in local TZ: no
                    iobroker
                    /home/iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                             3821 M total memory
                             2947 M used memory
                              233 M active memory
                              375 M free memory
                               77 M buffer memory
                              421 M swap cache
                              974 M total swap
                                3 M used swap
                              971 M free swap
                    *** FILESYSTEM ***
                    /var:
                    1.5G    /var/
                    1.1G    /var/log
                    250M    /var/cache
                    USB-Devices by-id:
                    /usr/bin/npm            9.8.1
                    /usr/bin/npx            9.8.1
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        26482
                    States:         21176
                    Pending Updates: 0
                    @badsnoopy667
                    Kleinigkeit noch:
                    sudo systemctl set-default multi-user
                    Und den fullybrowser würde ich vom debug-LogLevel heruntersetzen.
                    Das Upgrade auf Bookworm würde ich danach versuchen:
                    https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                      @badsnoopy667
                      Kleinigkeit noch:
                      badsnoopy667
                      Super, das Update auf Bookwork Debian 12 hat einwandfrei geklappt!
