  4. Adapterwarnungen / web stürzt ab
    2.9k
    4.9k
    4.1k
63 Beiträge 6 Kommentatoren 8.7k Aufrufe 5 Beobachtet
  • MichaelFM Offline
    MichaelFM Offline
    MichaelF
    Hab Ihn glaube ich :
    Skript v.2023-10-10
    *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
      Operating System: Raspbian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.25-v8+
          Architecture: arm64
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : armhf
    Systemuptime and Load:
     21:20:34 up  1:35,  1 user,  load average: 1.59, 1.70, 1.99
    CPU threads: 4
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** Time and Time Zones ***
                   Local time: Wed 2023-11-08 21:20:34 CET
               Universal time: Wed 2023-11-08 20:20:34 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            7.8G        2.7G        3.6G        1.0M        1.5G        5.0G
    Swap:            99M          0B         99M
    Total:          7.9G        2.7G        3.7G
             7811 M total memory
             2692 M used memory
             2861 M active memory
              904 M inactive memory
             3618 M free memory
              275 M buffer memory
             1224 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    Raspberry only:
    oom events: 0
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** FILESYSTEM ***
    /dev/root      ext4      117G   17G   95G  15% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  876K  1.6G   1% /run
    /dev/sda1      vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
    [Wed Nov  8 19:45:02 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:9F:6B:93 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=247e04bb-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Wed Nov  8 19:45:04 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Wed Nov  8 19:45:04 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Wed Nov  8 19:45:06 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime,stripe=8191
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.4G    /var/
    3.6G    /var/log/journal/ce513f1a44ff4c9dbd382eb66e08c51e
    3.6G    /var/log
    574M    /var/cache
    Archived and active journals take up 3.5G in the file system.
    /opt/iobroker/backups:
    826M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.0G    /opt/iobroker/iobroker-data/
    1.1G    /opt/iobroker/iobroker-data/sqlite
    676M    /opt/iobroker/iobroker-data/files
    132M    /opt/iobroker/iobroker-data/backup-objects
    88M     /opt/iobroker/iobroker-data/files/echarts.admin
    1.1G    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    38M     /opt/iobroker/iobroker-data/states.jsonl
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.eb0afecd.js.map
    USB-Devices by-id:
    find: '/dev/serial/by-id/': No such file or directory
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.1-1nodesource1 500
         18.18.0-1nodesource1 500
         18.17.1-1nodesource1 500
         18.17.0-1nodesource1 500
         18.16.1-1nodesource1 500
         18.16.0-1nodesource1 500
         18.15.0-1nodesource1 500
         18.14.2-1nodesource1 500
         18.14.1-1nodesource1 500
         18.14.0-1nodesource1 500
         18.13.0-1nodesource1 500
         18.12.0-1nodesource1 500
         18.11.0-1nodesource1 500
         18.10.0-1nodesource1 500
         18.9.1-1nodesource1 500
         18.9.0-1nodesource1 500
         18.8.0-1nodesource1 500
         18.7.0-1nodesource1 500
         18.6.0-1nodesource1 500
         18.5.0-1nodesource1 500
         18.4.0-1nodesource1 500
         18.3.0-1nodesource1 500
         18.2.0-1nodesource1 500
         18.1.0-1nodesource1 500
         18.0.0-1nodesource1 500
         12.22.12~dfsg-1~deb11u4 500
    No problems detected
    Errors in npm tree:
    • MichaelFM MichaelF
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : armhf
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M          0B         99M
               7811 M total memory
               2692 M used memory
               3618 M free memory
                275 M buffer memory
               1224 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      4.4G    /var/
      3.6G    /var/log
      574M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
      Errors in npm tree:
      @michaelf
      Erstmal setzt du die 16 github-Installationen soweit wie möglich auf repo-gestützte Versionen.
      cd /opt/iobroker
      npm ls | grep github
      sagt?
      • MichaelFM Offline
        MichaelFM Offline
        MichaelF
        pi@iobroker:/opt/iobroker $ npm ls | grep github
        ├── iobroker.energiefluss-erweitert@0.0.2-alpha.20 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss-erweitert.git#07858bd9e4cbb8e005a3585cf5a480650fc47296)
        ├── iobroker.energiefluss@3.6.0 (git+ssh://git@github.com/SKB-CGN/ioBroker.energiefluss.git#bbd8b38c5885211a91ac3574399c32f22b3422fc)
        ├── iobroker.envertech-pv@1.0.2 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.envertech-pv.git#1397ecc1104c07c44cf49b03d214651e4ec9af62)
        ├── iobroker.fully-tablet-control@0.3.6-1 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#f7d8e7ac363adbe19b99c060d77895097228d7ca)
        ├── iobroker.midea@0.1.0 (git+ssh://git@github.com/TA2k/ioBroker.midea.git#262717eed55656f1c79056eccd8c209666015421)
        ├── iobroker.parcel@0.0.30 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#ace65142356e3f2abcce759beead0c580a6279b3)
        ├── iobroker.pid@0.0.8 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.pid.git#e9107393cd396a7abb2f0a07e762bb45c34332bb)
        ├── iobroker.pioneer_sc_vsx@0.1.0 (git+ssh://git@github.com/okeck1982/ioBroker.pioneer_sc_vsx.git#6902280218c6709de322058c19704839f241c069)
        ├── iobroker.sourceanalytix@0.4.15-alpha.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#af88beb902468eb03749e5b120f3e350e60256e1)
        ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#de8c1ad97edafedb16cbbb2c6dc14b032848df8e)
        ├── iobroker.vis-2-widgets-gauges@0.1.12 (git+ssh://git@github.com/ioBroker/ioBroker.vis-2-widgets-gauges.git#3c0e201b9912106fe9c76458ef91ee72aad49ea8)
        ├── iobroker.vis-lcars@1.1.1 (git+ssh://git@github.com/ioBroker/ioBroker.vis-lcars.git#29f478ee8176dc522d6b5a067f71fa0e449475ad)
        ├── iobroker.vis-material@0.1.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.vis-material.git#0384950a1e05ec2fa6b6c4bb774afa5e97a13b6c)
        ├── iobroker.vis-materialdesign@0.5.76 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#43f3a07d7b48f367612c19ef678935709f718aae)
        ├── iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
        ├── pioneer-avr@0.0.1 (git+ssh://git@github.com/EbSe/node-pioneer-avr.git#7affedc95c277a2c9b4ef102b9a96adab6948ba3)
          @michaelf
          Jetzt installierst du alle Adapter, die es auch in dieser Liste gibt neu:
          http://download.iobroker.net/list.html#sortCol=name&sortDir=0&filter=
          • MichaelFM Offline
            MichaelFM Offline
            MichaelF
            Im Iobroker über Adapter ? kann ich einfach trüber installieren oder müssen diese vorher gelöscht werden ?
              @michaelf
              Einfach drüber.
              • MichaelFM Offline
                MichaelFM Offline
                MichaelF
                Habe ich
                  Habe ich
                  @michaelf
                  cd /opt/iobroker
                  npm prune
                  npm ls
                  MichaelFM 1 Antwort Letzte Antwort
                    @michaelf
                    cd /opt/iobroker
                    npm prune
                    npm ls
                    MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    @thomas-braun said in Adapterwarnungen / web stürzt ab:
                    @michaelf
                    cd /opt/iobroker
                    npm prune
                    npm ls
                    Auch gemacht
                      @michaelf
                      cd /opt/iobroker
                      npm prune
                      npm ls
                      Auch gemacht
                      @michaelf sagte in Adapterwarnungen / web stürzt ab:
                      Auch gemacht
                      Zeig mal die Ausgabe von
                      npm ls
                      • MichaelFM Offline
                        MichaelFM Offline
                        MichaelF
                        iobroker.inst@3.0.0 /opt/iobroker
                        ├── @types/caseless@0.12.2 extraneous
                        ├── @types/request@2.48.8 extraneous
                        ├── @types/tough-cookie@4.0.2 extraneous
                        ├── coffeescript@1.12.7 extraneous
                        ├── iobroker.accuweather@1.3.1
                        ├── iobroker.admin@6.12.0
                        ├── iobroker.alexa2@3.25.5
                        ├── iobroker.backitup@2.8.7
                        ├── iobroker.bosesoundtouch@0.10.3
                        ├── iobroker.broadlink2@2.1.5
                        ├── iobroker.device-reminder@3.0.0
                        ├── iobroker.device-watcher@2.9.4
                        ├── iobroker.devices@1.1.5
                        ├── iobroker.discovery@3.1.0
                        ├── iobroker.dwd@2.8.5
                        ├── iobroker.echarts@1.5.1
                        ├── iobroker.evcc@0.0.10
                        ├── iobroker.eventlist@1.2.3
                        ├── iobroker.fb-checkpresence@1.2.2
                        ├── iobroker.fritzdect@2.3.1
                        ├── iobroker.ham@5.3.1
                        ├── iobroker.hekr@0.0.6
                        ├── iobroker.history@3.0.1
                        ├── iobroker.hm-rega@3.0.47
                        ├── iobroker.hm-rpc@1.15.19
                        ├── iobroker.ical@1.13.3
                        ├── iobroker.icons-material-png@0.1.0
                        ├── iobroker.icons-mfd-png@1.1.0
                        ├── iobroker.icons-mfd-svg@1.1.0
                        ├── iobroker.icons-open-icon-library-png@0.1.2
                        ├── iobroker.influxdb@3.2.0
                        ├── iobroker.info@2.0.0
                        ├── iobroker.iot@1.14.5
                        ├── iobroker.javascript@7.1.4
                        ├── iobroker.js-controller@5.0.12
                        ├── iobroker.logparser@2.2.0
                        ├── iobroker.luftdaten@3.1.0
                        ├── iobroker.mqtt-client@1.6.5
                        ├── iobroker.mqtt@4.1.1
                        ├── iobroker.nuki@1.6.0
                        ├── iobroker.nut@1.6.0
                        ├── iobroker.octoprint@5.1.0
                        ├── iobroker.parcel@0.0.27
                        ├── iobroker.pi-hole@1.3.6
                        ├── iobroker.psa@0.0.11
                        ├── iobroker.pvforecast@2.9.0
                        ├── iobroker.rpi2@1.3.2
                        ├── iobroker.s7@1.3.15
                        ├── iobroker.sainlogic@0.10.5
                        ├── iobroker.shelly@6.6.1
                        ├── iobroker.simple-api@2.7.2
                        ├── iobroker.socketio@6.5.5
                        ├── iobroker.sonoff@2.5.3
                        ├── iobroker.sql@2.2.0
                        ├── iobroker.synology@3.0.1
                        ├── iobroker.tankerkoenig@3.3.7
                        ├── iobroker.telegram@2.0.1
                        ├── iobroker.tr-064@4.2.18
                        ├── iobroker.trashschedule@2.3.0
                        ├── iobroker.tuya@3.14.2
                        ├── iobroker.upnp@1.0.21
                        ├── iobroker.vis-bars@0.1.4
                        ├── iobroker.vis-canvas-gauges@1.0.1
                        ├── iobroker.vis-colorpicker@2.0.3
                        ├── iobroker.vis-google-fonts@1.0.4
                        ├── iobroker.vis-history@1.0.0
                        ├── iobroker.vis-hqwidgets@1.4.0
                        ├── iobroker.vis-icontwo@0.96.0
                        ├── iobroker.vis-inventwo@3.3.3
                        ├── iobroker.vis-jqui-mfd@1.0.12
                        ├── iobroker.vis-justgage@1.0.2
                        ├── iobroker.vis-metro@1.2.0
                        ├── iobroker.vis-players@0.1.6
                        ├── iobroker.vis-rgraph@0.0.2
                        ├── iobroker.vis-timeandweather@1.2.2
                        ├── iobroker.vis@1.4.16
                        ├── iobroker.web@6.1.2
                        ├── iobroker.worx@2.3.4
                        ├── iobroker.ws@2.5.5
                        ├── node-inspect@2.0.0 extraneous
                        ├── typescript@5.1.6 extraneous
                        ├── virtual-tsc@0.6.2 extraneous
                        └── wake_on_lan@1.0.0 extraneous
                          @michaelf
                          Das sieht auf jeden Fall schon erheblich gesünder aus.
                            @michaelf
                            And again...
                            iob diag
                              @michaelf
                              And again...
                              iob diag
                              MichaelFM Offline
                              MichaelFM Offline
                              MichaelF
                              @michaelf
                              And again...
                              iob diag
                              Kommt sofort, wie passiert sowas ? habe Iobroker ja schon länger im Einsatz und eigentlich nie irgendwelche Probleme gehabt
                                @michaelf
                                And again...
                                iob diag
                                Durch übermäßigen Einsatz von Adaptern direkt aus dem Github.
                                • MichaelFM Offline
                                  MichaelFM Offline
                                  MichaelF
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : armhf
                                   21:56:14 up  2:11,  1 user,  load average: 1.59, 1.63, 1.82
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Wed 2023-11-08 21:56:15 CET
                                             Universal time: Wed 2023-11-08 20:56:15 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            7.8G        2.9G        3.3G        1.0M        1.6G        4.7G
                                  Swap:            99M          0B         99M
                                  Total:          7.9G        2.9G        3.4G
                                           7811 M total memory
                                           2933 M used memory
                                           3096 M active memory
                                            963 M inactive memory
                                           3317 M free memory
                                            302 M buffer memory
                                           1258 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /var:
                                  4.4G    /var/
                                  3.6G    /var/log
                                  574M    /var/cache
                                  671M    /opt/iobroker/iobroker-data/files
                                  26M     /opt/iobroker/iobroker-data/states.jsonl
                                  USB-Devices by-id:
                                  /usr/bin/npm            9.8.1
                                  /usr/bin/npx            9.8.1
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  Errors in npm tree:
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                  npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                  npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                                  npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                  npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                  npm ERR! extraneous: typescript@5.1.6 /opt/iobroker/node_modules/typescript
                                  npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                  npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                  npm ERR! extraneous: form-data@2.5.1 /opt/iobroker/node_modules/@types/request/node_modules/form-data
                                  npm ERR! missing: homebridge-midea-air@^1.7.3, required by iobroker.ham@5.3.1
                                  npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
                                  npm ERR! extraneous: @aashutoshrathi/word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@aashutoshrathi/word-wrap
                                  npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak
                                  npm ERR! extraneous: @alcalzone/release-script-core@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-core
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-changelog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-changelog
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-exec@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-exec
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-git@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-git
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-license
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-package@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-package
                                  npm ERR! extraneous: @alcalzone/release-script-plugin-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-version
                                  npm ERR! extraneous: @alcalzone/release-script@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script
                                  npm ERR! extraneous: @eslint-community/eslint-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/eslint-utils
                                  npm ERR! extraneous: @eslint-community/regexpp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint-community/regexpp
                                  npm ERR! extraneous: @eslint/eslintrc@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/eslintrc
                                  npm ERR! extraneous: @eslint/js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@eslint/js
                                  npm ERR! extraneous: @humanwhocodes/config-array@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/config-array
                                  npm ERR! extraneous: @humanwhocodes/module-importer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/module-importer
                                  npm ERR! extraneous: @humanwhocodes/object-schema@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@humanwhocodes/object-schema
                                  npm ERR! extraneous: @iobroker/dev-server@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server
                                  npm ERR! extraneous: @iobroker/testing@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/testing
                                  npm ERR! extraneous: @nodelib/fs.scandir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.scandir
                                  npm ERR! extraneous: @nodelib/fs.stat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.stat
                                  npm ERR! extraneous: @nodelib/fs.walk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@nodelib/fs.walk
                                  npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/commons
                                  npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers
                                  npm ERR! extraneous: @sinonjs/samsam@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/samsam
                                  npm ERR! extraneous: @sinonjs/text-encoding@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/text-encoding
                                  npm ERR! extraneous: @socket.io/component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@socket.io/component-emitter
                                  npm ERR! extraneous: @types/cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cookie
                                  npm ERR! extraneous: @types/cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/cors
                                  npm ERR! extraneous: @types/expect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/expect
                                  npm ERR! extraneous: @types/http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/http-proxy
                                  npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/iobroker
                                  npm ERR! extraneous: @types/vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/vinyl
                                  npm ERR! extraneous: abbrev@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/abbrev
                                  npm ERR! extraneous: accepts@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/accepts
                                  npm ERR! extraneous: acorn-globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals
                                  npm ERR! extraneous: acorn-jsx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-jsx
                                  npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn
                                  npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/alcalzone-shared
                                  npm ERR! extraneous: ansi-align@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-align
                                  npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-colors
                                  npm ERR! extraneous: ansi-gray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-gray
                                  npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-regex
                                  npm ERR! extraneous: ansi-styles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-styles
                                  npm ERR! extraneous: ansi-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ansi-wrap
                                  npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/anymatch
                                  npm ERR! extraneous: append-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/append-buffer
                                  npm ERR! extraneous: archy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/archy
                                  npm ERR! extraneous: argparse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/argparse
                                  npm ERR! extraneous: arr-diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-diff
                                  npm ERR! extraneous: arr-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-filter
                                  npm ERR! extraneous: arr-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-flatten
                                  npm ERR! extraneous: arr-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-map
                                  npm ERR! extraneous: arr-union@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/arr-union
                                  npm ERR! extraneous: array-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-each
                                  npm ERR! extraneous: array-flatten@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-flatten
                                  npm ERR! extraneous: array-initial@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial
                                  npm ERR! extraneous: array-last@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last
                                  npm ERR! extraneous: array-slice@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-slice
                                  npm ERR! extraneous: array-sort@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-sort
                                  npm ERR! extraneous: array-unique@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-unique
                                  npm ERR! extraneous: assertion-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assertion-error
                                  npm ERR! extraneous: assign-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/assign-symbols
                                  npm ERR! extraneous: astral-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/astral-regex
                                  npm ERR! extraneous: async-done@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-done
                                  npm ERR! extraneous: async-each-series@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each-series
                                  npm ERR! extraneous: async-each@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-each
                                  npm ERR! extraneous: async-settle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async-settle
                                  npm ERR! extraneous: async@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/async
                                  npm ERR! extraneous: atob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/atob
                                  npm ERR! extraneous: bach@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bach
                                  npm ERR! extraneous: balanced-match@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
                                  npm ERR! extraneous: base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base
                                  npm ERR! extraneous: base64id@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base64id
                                  npm ERR! extraneous: batch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/batch
                                  npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binary-extensions
                                  npm ERR! extraneous: binaryextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/binaryextensions
                                  npm ERR! extraneous: bindings@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bindings
                                  npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser
                                  npm ERR! extraneous: boxen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/boxen
                                  npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
                                  npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/braces
                                  npm ERR! extraneous: browser-request@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-request
                                  npm ERR! extraneous: browser-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-stdout
                                  npm ERR! extraneous: browser-sync-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-client
                                  npm ERR! extraneous: browser-sync-ui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync-ui
                                  npm ERR! extraneous: browser-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync
                                  npm ERR! extraneous: bs-html-injector@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector
                                  npm ERR! extraneous: bs-recipes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-recipes
                                  npm ERR! extraneous: buffer-equal@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-equal
                                  npm ERR! extraneous: buffer-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/buffer-from
                                  npm ERR! extraneous: bytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bytes
                                  npm ERR! extraneous: cache-base@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cache-base
                                  npm ERR! extraneous: call-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/call-bind
                                  npm ERR! extraneous: callsites@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/callsites
                                  npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/camelcase
                                  npm ERR! extraneous: chai-as-promised@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai-as-promised
                                  npm ERR! extraneous: chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chai
                                  npm ERR! extraneous: chalk@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chalk
                                  npm ERR! extraneous: check-error@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/check-error
                                  npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/chokidar
                                  npm ERR! extraneous: class-utils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils
                                  npm ERR! extraneous: cli-boxes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cli-boxes
                                  npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cliui
                                  npm ERR! extraneous: clone-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-buffer
                                  npm ERR! extraneous: clone-stats@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone-stats
                                  npm ERR! extraneous: clone@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/clone
                                  npm ERR! extraneous: cloneable-readable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cloneable-readable
                                  npm ERR! extraneous: code-point-at@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/code-point-at
                                  npm ERR! extraneous: collection-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-map
                                  npm ERR! extraneous: collection-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/collection-visit
                                  npm ERR! extraneous: color-convert@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-convert
                                  npm ERR! extraneous: color-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-name
                                  npm ERR! extraneous: color-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/color-support
                                  npm ERR! extraneous: colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/colors
                                  npm ERR! extraneous: commander@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/commander
                                  npm ERR! extraneous: component-emitter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/component-emitter
                                  npm ERR! extraneous: concat-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
                                  npm ERR! extraneous: concat-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-stream
                                  npm ERR! extraneous: connect-history-api-fallback@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect-history-api-fallback
                                  npm ERR! extraneous: connect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect
                                  npm ERR! extraneous: content-disposition@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-disposition
                                  npm ERR! extraneous: content-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/content-type
                                  npm ERR! extraneous: convert-source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/convert-source-map
                                  npm ERR! extraneous: cookie-signature@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie-signature
                                  npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cookie
                                  npm ERR! extraneous: copy-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-descriptor
                                  npm ERR! extraneous: copy-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/copy-props
                                  npm ERR! extraneous: cors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cors
                                  npm ERR! extraneous: cross-spawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cross-spawn
                                  npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssom
                                  npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/cssstyle
                                  npm ERR! extraneous: d@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/d
                                  npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decamelize
                                  npm ERR! extraneous: decode-uri-component@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/decode-uri-component
                                  npm ERR! extraneous: deep-eql@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-eql
                                  npm ERR! extraneous: deep-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/deep-is
                                  npm ERR! extraneous: default-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-compare
                                  npm ERR! extraneous: default-resolution@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/default-resolution
                                  npm ERR! extraneous: define-data-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-data-property
                                  npm ERR! extraneous: define-properties@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-properties
                                  npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/define-property
                                  npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/depd
                                  npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/destroy
                                  npm ERR! extraneous: detect-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/detect-file
                                  npm ERR! extraneous: dev-ip@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dev-ip
                                  npm ERR! extraneous: diff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/diff
                                  npm ERR! extraneous: doctrine@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/doctrine
                                  npm ERR! extraneous: dom-compare-temp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-compare-temp
                                  npm ERR! extraneous: dom-serializer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer
                                  npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domelementtype
                                  npm ERR! extraneous: domhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domhandler
                                  npm ERR! extraneous: domutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/domutils
                                  npm ERR! extraneous: duplexer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexer
                                  npm ERR! extraneous: duplexify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/duplexify
                                  npm ERR! extraneous: each-props@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props
                                  npm ERR! extraneous: easy-extender@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/easy-extender
                                  npm ERR! extraneous: eazy-logger@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eazy-logger
                                  npm ERR! extraneous: ee-first@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ee-first
                                  npm ERR! extraneous: emoji-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/emoji-regex
                                  npm ERR! extraneous: encodeurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/encodeurl
                                  npm ERR! extraneous: end-of-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/end-of-stream
                                  npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client
                                  npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-parser
                                  npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io
                                  npm ERR! extraneous: enquirer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/enquirer
                                  npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/entities
                                  npm ERR! extraneous: error-ex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/error-ex
                                  npm ERR! extraneous: es5-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es5-ext
                                  npm ERR! extraneous: es6-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-iterator
                                  npm ERR! extraneous: es6-symbol@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-symbol
                                  npm ERR! extraneous: es6-weak-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/es6-weak-map
                                  npm ERR! extraneous: escalade@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escalade
                                  npm ERR! extraneous: escape-html@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-html
                                  npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escape-string-regexp
                                  npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen
                                  npm ERR! extraneous: eslint-scope@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-scope
                                  npm ERR! extraneous: eslint-visitor-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint-visitor-keys
                                  npm ERR! extraneous: eslint@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint
                                  npm ERR! extraneous: espree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/espree
                                  npm ERR! extraneous: esprima@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esprima
                                  npm ERR! extraneous: esquery@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esquery
                                  npm ERR! extraneous: esrecurse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esrecurse
                                  npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/estraverse
                                  npm ERR! extraneous: esutils@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/esutils
                                  npm ERR! extraneous: etag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/etag
                                  npm ERR! extraneous: event-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/event-stream
                                  npm ERR! extraneous: eventemitter3@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eventemitter3
                                  npm ERR! extraneous: execa@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/execa
                                  npm ERR! extraneous: expand-brackets@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets
                                  npm ERR! extraneous: expand-tilde@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-tilde
                                  npm ERR! extraneous: express@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express
                                  npm ERR! extraneous: ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext
                                  npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extend-shallow
                                  npm ERR! extraneous: extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob
                                  npm ERR! extraneous: fancy-log@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fancy-log
                                  npm ERR! extraneous: fast-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-glob
                                  npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fast-levenshtein
                                  npm ERR! extraneous: fastq@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fastq
                                  npm ERR! extraneous: file-entry-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-entry-cache
                                  npm ERR! extraneous: file-uri-to-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/file-uri-to-path
                                  npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fill-range
                                  npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler
                                  npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/find-up
                                  npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync
                                  npm ERR! extraneous: fined@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined
                                  npm ERR! extraneous: flagged-respawn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flagged-respawn
                                  npm ERR! extraneous: flat-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat-cache
                                  npm ERR! extraneous: flat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flat
                                  npm ERR! extraneous: flatted@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flatted
                                  npm ERR! extraneous: flush-write-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/flush-write-stream
                                  npm ERR! extraneous: for-in@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-in
                                  npm ERR! extraneous: for-own@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/for-own
                                  npm ERR! extraneous: forwarded@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/forwarded
                                  npm ERR! extraneous: fragment-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fragment-cache
                                  npm ERR! extraneous: fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fresh
                                  npm ERR! extraneous: from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/from
                                  npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-extra
                                  npm ERR! extraneous: fs-mkdirp-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs-mkdirp-stream
                                  npm ERR! extraneous: fs.realpath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fs.realpath
                                  npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fsevents
                                  npm ERR! extraneous: function-bind@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/function-bind
                                  npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-caller-file
                                  npm ERR! extraneous: get-func-name@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-func-name
                                  npm ERR! extraneous: get-intrinsic@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-intrinsic
                                  npm ERR! extraneous: get-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-stream
                                  npm ERR! extraneous: get-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/get-value
                                  npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-parent
                                  npm ERR! extraneous: glob-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream
                                  npm ERR! extraneous: glob-watcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher
                                  npm ERR! extraneous: glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
                                  npm ERR! extraneous: global-modules@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-modules
                                  npm ERR! extraneous: global-prefix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix
                                  npm ERR! extraneous: globals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globals
                                  npm ERR! extraneous: globalyzer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globalyzer
                                  npm ERR! extraneous: globrex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/globrex
                                  npm ERR! extraneous: glogg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glogg
                                  npm ERR! extraneous: gopd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gopd
                                  npm ERR! extraneous: graceful-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graceful-fs
                                  npm ERR! extraneous: graphemer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/graphemer
                                  npm ERR! extraneous: gulp-cli@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli
                                  npm ERR! extraneous: gulp-rename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-rename
                                  npm ERR! extraneous: gulp-replace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-replace
                                  npm ERR! extraneous: gulp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp
                                  npm ERR! extraneous: gulplog@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulplog
                                  npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-flag
                                  npm ERR! extraneous: has-property-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-property-descriptors
                                  npm ERR! extraneous: has-proto@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-proto
                                  npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-symbols
                                  npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-value
                                  npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values
                                  npm ERR! extraneous: has@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has
                                  npm ERR! extraneous: he@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/he
                                  npm ERR! extraneous: homedir-polyfill@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/homedir-polyfill
                                  npm ERR! extraneous: hosted-git-info@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/hosted-git-info
                                  npm ERR! extraneous: htmlparser2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2
                                  npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-errors
                                  npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy-middleware
                                  • MichaelFM Offline
                                    MichaelFM Offline
                                    MichaelF
                                    npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
                                    npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
                                    npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
                                    npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
                                    npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
                                    npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
                                    npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
                                    npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
                                    npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
                                    npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
                                    npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
                                    npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
                                    npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
                                    npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
                                    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
                                    npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
                                    npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
                                    npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
                                    npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
                                    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
                                    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
                                    npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
                                    npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
                                    npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
                                    npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
                                    npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
                                    npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
                                    npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
                                    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
                                    npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
                                    npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
                                    npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
                                    npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
                                    npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
                                    npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
                                    npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
                                    npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
                                    npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
                                    npm ERR! extraneous: istextorbinary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
                                    npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
                                    npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom
                                    npm ERR! extraneous: json-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
                                    npm ERR! extraneous: json-stable-stringify-without-jsonify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
                                    npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
                                    npm ERR! extraneous: just-debounce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
                                    npm ERR! extraneous: just-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-extend
                                    npm ERR! extraneous: keyv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
                                    npm ERR! extraneous: last-run@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
                                    npm ERR! extraneous: lazystream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
                                    npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
                                    npm ERR! extraneous: lead@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
                                    npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
                                    npm ERR! extraneous: liftoff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
                                    npm ERR! extraneous: limiter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/limiter
                                    npm ERR! extraneous: load-json-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
                                    npm ERR! extraneous: localtunnel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel
                                    npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
                                    npm ERR! extraneous: lodash.get@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.get
                                    npm ERR! extraneous: lodash.isfinite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.isfinite
                                    npm ERR! extraneous: lodash.merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
                                    npm ERR! extraneous: lodash.truncate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.truncate
                                    npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash
                                    npm ERR! extraneous: log-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
                                    npm ERR! extraneous: loupe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
                                    npm ERR! extraneous: make-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
                                    npm ERR! extraneous: map-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
                                    npm ERR! extraneous: map-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-stream
                                    npm ERR! extraneous: map-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
                                    npm ERR! extraneous: matchdep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
                                    npm ERR! extraneous: media-typer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/media-typer
                                    npm ERR! extraneous: merge-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-descriptors
                                    npm ERR! extraneous: merge-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
                                    npm ERR! extraneous: merge2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
                                    npm ERR! extraneous: methods@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/methods
                                    npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
                                    npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime
                                    npm ERR! extraneous: mimic-fn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
                                    npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
                                    npm ERR! extraneous: mitt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mitt
                                    npm ERR! extraneous: mixin-deep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
                                    npm ERR! extraneous: mocha@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
                                    npm ERR! extraneous: mute-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
                                    npm ERR! extraneous: nanoid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
                                    npm ERR! extraneous: nanomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
                                    npm ERR! extraneous: natural-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
                                    npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/negotiator
                                    npm ERR! extraneous: next-tick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
                                    npm ERR! extraneous: nise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise
                                    npm ERR! extraneous: nodemon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon
                                    npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nopt
                                    npm ERR! extraneous: normalize-package-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
                                    npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
                                    npm ERR! extraneous: now-and-later@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
                                    npm ERR! extraneous: npm-run-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
                                    npm ERR! extraneous: number-is-nan@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
                                    npm ERR! extraneous: nwmatcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nwmatcher
                                    npm ERR! extraneous: object-assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
                                    npm ERR! extraneous: object-copy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
                                    npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
                                    npm ERR! extraneous: object-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
                                    npm ERR! extraneous: object-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
                                    npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
                                    npm ERR! extraneous: object.defaults@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
                                    npm ERR! extraneous: object.map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
                                    npm ERR! extraneous: object.pick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
                                    npm ERR! extraneous: object.reduce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
                                    npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/on-finished
                                    npm ERR! extraneous: once@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
                                    npm ERR! extraneous: onetime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
                                    npm ERR! extraneous: openurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/openurl
                                    npm ERR! extraneous: opn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/opn
                                    npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
                                    npm ERR! extraneous: ordered-read-streams@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
                                    npm ERR! extraneous: os-locale@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
                                    npm ERR! extraneous: p-limit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
                                    npm ERR! extraneous: p-locate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
                                    npm ERR! extraneous: parent-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
                                    npm ERR! extraneous: parse-filepath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
                                    npm ERR! extraneous: parse-json@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
                                    npm ERR! extraneous: parse-node-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
                                    npm ERR! extraneous: parse-passwd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
                                    npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5
                                    npm ERR! extraneous: parseurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parseurl
                                    npm ERR! extraneous: pascalcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
                                    npm ERR! extraneous: path-dirname@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
                                    npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
                                    npm ERR! extraneous: path-is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
                                    npm ERR! extraneous: path-key@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
                                    npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
                                    npm ERR! extraneous: path-root-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
                                    npm ERR! extraneous: path-root@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
                                    npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-to-regexp
                                    npm ERR! extraneous: path-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
                                    npm ERR! extraneous: pathval@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
                                    npm ERR! extraneous: pause-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pause-stream
                                    npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
                                    npm ERR! extraneous: pify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
                                    npm ERR! extraneous: pinkie-promise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
                                    npm ERR! extraneous: pinkie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
                                    npm ERR! extraneous: portscanner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/portscanner
                                    npm ERR! extraneous: posix-character-classes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
                                    npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
                                    npm ERR! extraneous: pretty-hrtime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
                                    npm ERR! extraneous: proxy-addr@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-addr
                                    npm ERR! extraneous: ps-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ps-tree
                                    npm ERR! extraneous: pstree.remy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pstree.remy
                                    npm ERR! extraneous: pump@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
                                    npm ERR! extraneous: pumpify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
                                    npm ERR! extraneous: qs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
                                    npm ERR! extraneous: queue-microtask@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
                                    npm ERR! extraneous: randombytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
                                    npm ERR! extraneous: range-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/range-parser
                                    npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-body
                                    npm ERR! extraneous: read-pkg-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
                                    npm ERR! extraneous: read-pkg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
                                    npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
                                    npm ERR! extraneous: rechoir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
                                    npm ERR! extraneous: regex-not@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
                                    npm ERR! extraneous: remove-bom-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
                                    npm ERR! extraneous: remove-bom-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
                                    npm ERR! extraneous: remove-trailing-separator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
                                    npm ERR! extraneous: repeat-element@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
                                    npm ERR! extraneous: repeat-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
                                    npm ERR! extraneous: replace-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
                                    npm ERR! extraneous: replace-homedir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
                                    npm ERR! extraneous: replacestream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
                                    npm ERR! extraneous: require-directory@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
                                    npm ERR! extraneous: require-from-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-from-string
                                    npm ERR! extraneous: require-main-filename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
                                    npm ERR! extraneous: requires-port@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/requires-port
                                    npm ERR! extraneous: resolve-dir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
                                    npm ERR! extraneous: resolve-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
                                    npm ERR! extraneous: resolve-options@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
                                    npm ERR! extraneous: resolve-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
                                    npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
                                    npm ERR! extraneous: resp-modifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier
                                    npm ERR! extraneous: ret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
                                    npm ERR! extraneous: reusify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
                                    npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
                                    npm ERR! extraneous: run-parallel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
                                    npm ERR! extraneous: rx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rx
                                    npm ERR! extraneous: safe-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
                                    npm ERR! extraneous: semver-greatest-satisfied-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
                                    npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send
                                    npm ERR! extraneous: serialize-javascript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
                                    npm ERR! extraneous: serve-index@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index
                                    npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-static
                                    npm ERR! extraneous: server-destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/server-destroy
                                    npm ERR! extraneous: set-blocking@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
                                    npm ERR! extraneous: set-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
                                    npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/setprototypeof
                                    npm ERR! extraneous: shebang-command@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
                                    npm ERR! extraneous: shebang-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
                                    npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
                                    npm ERR! extraneous: signal-exit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
                                    npm ERR! extraneous: simple-update-notifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier
                                    npm ERR! extraneous: sinon-chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon-chai
                                    npm ERR! extraneous: sinon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon
                                    npm ERR! extraneous: slice-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/slice-ansi
                                    npm ERR! extraneous: snapdragon-node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
                                    npm ERR! extraneous: snapdragon-util@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
                                    npm ERR! extraneous: snapdragon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
                                    npm ERR! extraneous: socket.io-adapter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter
                                    npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-client
                                    npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-parser
                                    npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io
                                    npm ERR! extraneous: source-map-resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
                                    npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
                                    npm ERR! extraneous: source-map-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
                                    npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map
                                    npm ERR! extraneous: sparkles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
                                    npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
                                    npm ERR! extraneous: spdx-exceptions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
                                    npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
                                    npm ERR! extraneous: spdx-license-ids@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
                                    npm ERR! extraneous: split-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
                                    npm ERR! extraneous: split@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split
                                    npm ERR! extraneous: stack-trace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
                                    npm ERR! extraneous: static-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
                                    npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/statuses
                                    npm ERR! extraneous: stream-combiner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
                                    npm ERR! extraneous: stream-exhaust@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
                                    npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
                                    npm ERR! extraneous: stream-throttle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-throttle
                                    npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
                                    npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
                                    npm ERR! extraneous: strip-bom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
                                    npm ERR! extraneous: strip-final-newline@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
                                    npm ERR! extraneous: strip-json-comments@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
                                    npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
                                    npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
                                    npm ERR! extraneous: sver-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
                                    npm ERR! extraneous: symbol-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/symbol-tree
                                    npm ERR! extraneous: table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table
                                    npm ERR! extraneous: text-table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
                                    npm ERR! extraneous: textextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
                                    npm ERR! extraneous: through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
                                    npm ERR! extraneous: through2-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
                                    npm ERR! extraneous: through2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
                                    npm ERR! extraneous: time-stamp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
                                    npm ERR! extraneous: timekeeper@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
                                    npm ERR! extraneous: tiny-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
                                    npm ERR! extraneous: to-absolute-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
                                    npm ERR! extraneous: to-object-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
                                    npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
                                    npm ERR! extraneous: to-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
                                    npm ERR! extraneous: to-through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
                                    npm ERR! extraneous: toidentifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/toidentifier
                                    npm ERR! extraneous: touch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/touch
                                    npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
                                    npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
                                    npm ERR! extraneous: type-detect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
                                    npm ERR! extraneous: type-fest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
                                    npm ERR! extraneous: type-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-is
                                    npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
                                    npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
                                    npm ERR! extraneous: ua-parser-js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ua-parser-js
                                    npm ERR! extraneous: unc-path-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
                                    npm ERR! extraneous: undefsafe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undefsafe
                                    npm ERR! extraneous: undertaker-registry@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
                                    npm ERR! extraneous: undertaker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
                                    npm ERR! extraneous: union-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
                                    npm ERR! extraneous: unique-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
                                    npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
                                    npm ERR! extraneous: unpipe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unpipe
                                    npm ERR! extraneous: unset-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
                                    npm ERR! extraneous: upath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
                                    npm ERR! extraneous: urix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
                                    npm ERR! extraneous: use@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
                                    npm ERR! extraneous: utils-merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/utils-merge
                                    npm ERR! extraneous: v8flags@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
                                    npm ERR! extraneous: validate-npm-package-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
                                    npm ERR! extraneous: value-or-function@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
                                    npm ERR! extraneous: vary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vary
                                    npm ERR! extraneous: vinyl-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
                                    npm ERR! extraneous: vinyl-sourcemap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
                                    npm ERR! extraneous: vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
                                    npm ERR! extraneous: whatwg-url-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url-compat
                                    npm ERR! extraneous: which-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
                                    npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
                                    npm ERR! extraneous: widest-line@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/widest-line
                                    npm ERR! extraneous: word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/word-wrap
                                    npm ERR! extraneous: workerpool@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
                                    npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
                                    npm ERR! extraneous: wrappy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
                                    npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ws
                                    npm ERR! extraneous: xml-name-validator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml-name-validator
                                    npm ERR! extraneous: xmldom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmldom
                                    npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest-ssl
                                    npm ERR! extraneous: xmlhttprequest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest
                                    npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
                                    npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
                                    npm ERR! extraneous: yargs-unparser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
                                    npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
                                    npm ERR! extraneous: yocto-queue@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
                                    npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                                    npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                                    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/axios
                                    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios
                                    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script/node_modules/axios
                                    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/axios
                                    npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
                                    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals/node_modules/acorn
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/debug
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/ms
                                    npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/raw-body
                                    npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/fs-extra
                                    npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/jsonfile
                                    npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/universalify
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/debug
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/ms
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/define-property
                                    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor
                                    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor
                                    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-descriptor
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/debug
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/ms
                                    npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/domelementtype
                                    npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/entities
                                    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
                                    npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client/node_modules/ws
                                    npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/cookie
                                    npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/ws
                                    npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/estraverse
                                    npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/levn
                                    npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/optionator
                                    npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/prelude-ls
                                    npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/source-map
                                    npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/type-check
                                    npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint/node_modules/glob-parent
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/define-property
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/extend-shallow
                                    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor
                                    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor
                                    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-descriptor
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-extendable
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/debug
                                    npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/finalhandler
                                    npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/mime
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/ms
                                    npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send
                                    npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/serve-static
                                    npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext/node_modules/type
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/extend-shallow
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-extendable
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/debug
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/ms
                                    npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/on-finished
                                    npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/statuses
                                    npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces
                                    npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
                                    npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
                                    npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/to-regex-range
                                    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
                                    npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
                                    npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
                                    npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch
                                    npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/binary-extensions
                                    npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces
                                    npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/chokidar
                                    npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range
                                    npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fsevents
                                    npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent
                                    npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-binary-path
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-extendable
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-number
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/kind-of
                                    npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch
                                    npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/readdirp
                                    npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/to-regex-range
                                    npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
                                    npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
                                    npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
                                    npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
                                    npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
                                    npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
                                    npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
                                    npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
                                    npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
                                    npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
                                    npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
                                    npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
                                    npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
                                    npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
                                    npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/node_modules/readable-stream
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable/node_modules/is-plain-object
                                    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom/node_modules/acorn
                                    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
                                    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/axios
                                    npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/cliui
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/debug
                                    npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs-parser
                                    npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
                                    npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces
                                    npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range
                                    npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
                                    npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
                                    npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
                                    npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
                                    npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/to-regex-range
                                    npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
                                    npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/brace-expansion
                                    npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
                                    npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
                                    npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
                                    npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
                                    npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
                                    npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers
                                    npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/isarray
                                    npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/path-to-regexp
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/debug
                                    npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/has-flag
                                    npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/semver
                                    npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/supports-color
                                    npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/define-property
                                    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-accessor-descriptor
                                    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-data-descriptor
                                    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
                                    npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
                                    npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
                                    npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/debug
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/ms
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/debug
                                    npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/depd
                                    npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/destroy
                                    npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/http-errors
                                    npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/inherits
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/ms
                                    npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/on-finished
                                    npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/setprototypeof
                                    npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/statuses
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/debug
                                    npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/depd
                                    npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/http-errors
                                    npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/inherits
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/ms
                                    npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/setprototypeof
                                    npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/statuses
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/extend-shallow
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-extendable
                                    npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
                                    npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier/node_modules/semver
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
                                    npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/define-property
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/extend-shallow
                                    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor
                                    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor
                                    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-descriptor
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-extendable
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
                                    npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/source-map
                                    npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter/node_modules/ws
                                    npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
                                    npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/define-property
                                    npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor
                                    npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor
                                    npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-descriptor
                                    npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/ajv
                                    npm ERR! extraneous: json-schema-traverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/json-schema-traverse
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
                                    npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
                                    npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value/node_modules/is-extendable
                                    npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
                                    npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
                                    npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
                                    npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser/node_modules/is-plain-obj
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send/node_modules/ms
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces/node_modules/extend-shallow
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range/node_modules/extend-shallow
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number/node_modules/kind-of
                                    npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch/node_modules/normalize-path
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces/node_modules/extend-shallow
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range/node_modules/extend-shallow
                                    npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent/node_modules/is-glob
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number/node_modules/kind-of
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces/node_modules/extend-shallow
                                    npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range/node_modules/extend-shallow
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number/node_modules/kind-of
                                    npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
                                    npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
                                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T20_56_24_842Z-debug-0.log
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    js-controller:  5.0.12
                                    admin:          6.12.0
                                    javascript:     7.1.4
                                    Adapters from github:   9
                                    Adapter State
                                    + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                      system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
                                    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                                    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                      system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                                    + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
                                    + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                    + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
                                    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
                                    + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                      system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
                                      system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
                                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
                                    + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
                                    + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
                                    + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
                                    + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                                    + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                                    + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
                                    + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
                                    + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                    + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                    + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
                                    + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                    + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
                                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
                                    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
                                    + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
                                    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                                    + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
                                    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                                      system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                                      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                                      system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                                      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): stable
                                    Installed ioBroker-Instances
                                    Used repository: stable
                                    Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
                                    Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                    Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
                                    Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                    Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                                    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                                    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                                    Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                                    Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                    Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                    Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
                                    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                                    Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                                    Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                    Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                    Adapter    "hekr"         : 0.0.6    , installed 0.0.6
                                    Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                                    Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                    Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                    Adapter    "info"         : 2.0.0    , installed 2.0.0
                                    Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                    Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                    Controller "js-controller": 5.0.12   , installed 5.0.12
                                    Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                                    Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
                                    Adapter    "midea"        : 0.0.7    , installed 0.1.0
                                    Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                    Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
                                    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                    Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                                    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                    Adapter    "psa"          : 0.0.11   , installed 0.0.11
                                    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                                    Adapter    "s7"           : 1.3.15   , installed 1.3.15
                                    Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                                    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                    Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                    Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                    Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                                    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                    Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                    Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                    Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
                                    Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                    Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                    Objects and States
                                    Objects:        28839
                                    States:         24330
                                    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
                                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
                                    tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
                                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
                                    tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
                                    tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
                                    tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
                                    tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
                                    tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
                                    tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
                                    tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
                                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
                                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
                                    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
                                    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
                                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
                                    tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
                                    udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
                                    udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
                                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
                                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
                                    udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
                                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
                                    udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
                                    udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
                                    2023-11-08 21:52:08.090  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                    2023-11-08 21:53:00.347  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                    2023-11-08 21:53:00.888  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476780888_7107
                                    2023-11-08 21:53:58.129  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                    2023-11-08 21:54:00.072  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 3554
                                    2023-11-08 21:54:01.670  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476841669_4609
                                    2023-11-08 21:54:07.965  - info: luftdaten.0 (3554) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-08 21:54:08.604  - info: luftdaten.0 (3554) Terminated (NO_ERROR): Without reason
                                    2023-11-08 21:54:09.169  - warn: luftdaten.0 (3554) get state error: Connection is closed.
                                    2023-11-08 21:54:09.400  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                    2023-11-08 21:54:32.528  - info: fritzdect.0 (18158) DECT ID: 087610101442 identified for command (state) : false
                                    2023-11-08 21:54:59.917  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                    2023-11-08 21:55:00.201  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3669
                                    2023-11-08 21:55:02.467  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476902467_6802
                                    2023-11-08 21:55:07.827  - info: dwd.0 (3669) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-08 21:55:09.345  - info: dwd.0 (3669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-11-08 21:55:09.893  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2023-11-08 21:56:00.181  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 4091
                                    2023-11-08 21:56:00.710  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                    2023-11-08 21:56:01.245  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476961244_1751
                                    2023-11-08 21:56:07.469  - info: luftdaten.0 (4091) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                                    2023-11-08 21:56:08.624  - info: luftdaten.0 (4091) Terminated (NO_ERROR): Without reason
                                    2023-11-08 21:56:09.211  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                    2023-11-08 21:56:59.486  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                    2023-11-08 21:57:02.037  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699477022036_8863
                                    • MichaelFM MichaelF
                                      npm ERR! extraneous: http-proxy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/http-proxy
                                      npm ERR! extraneous: human-signals@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/human-signals
                                      npm ERR! extraneous: iconv-lite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
                                      npm ERR! extraneous: ignore-by-default@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore-by-default
                                      npm ERR! extraneous: ignore@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ignore
                                      npm ERR! extraneous: immutable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/immutable
                                      npm ERR! extraneous: import-fresh@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/import-fresh
                                      npm ERR! extraneous: imurmurhash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/imurmurhash
                                      npm ERR! extraneous: inflight@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
                                      npm ERR! extraneous: ini@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ini
                                      npm ERR! extraneous: interpret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/interpret
                                      npm ERR! extraneous: invert-kv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/invert-kv
                                      npm ERR! extraneous: ipaddr.js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ipaddr.js
                                      npm ERR! extraneous: is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-absolute
                                      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor
                                      npm ERR! extraneous: is-arrayish@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-arrayish
                                      npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-binary-path
                                      npm ERR! extraneous: is-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-buffer
                                      npm ERR! extraneous: is-core-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-core-module
                                      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor
                                      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable
                                      npm ERR! extraneous: is-extglob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extglob
                                      npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-fullwidth-code-point
                                      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-glob
                                      npm ERR! extraneous: is-negated-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-negated-glob
                                      npm ERR! extraneous: is-number-like@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number-like
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-number
                                      npm ERR! extraneous: is-path-inside@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-path-inside
                                      npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-obj
                                      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-plain-object
                                      npm ERR! extraneous: is-relative@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-relative
                                      npm ERR! extraneous: is-unc-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unc-path
                                      npm ERR! extraneous: is-unicode-supported@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-unicode-supported
                                      npm ERR! extraneous: is-utf8@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-utf8
                                      npm ERR! extraneous: is-valid-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-valid-glob
                                      npm ERR! extraneous: is-windows@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-windows
                                      npm ERR! extraneous: is-wsl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-wsl
                                      npm ERR! extraneous: isexe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isexe
                                      npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/isobject
                                      npm ERR! extraneous: istextorbinary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/istextorbinary
                                      npm ERR! extraneous: js-yaml@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/js-yaml
                                      npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom
                                      npm ERR! extraneous: json-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-buffer
                                      npm ERR! extraneous: json-stable-stringify-without-jsonify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/json-stable-stringify-without-jsonify
                                      npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsonfile
                                      npm ERR! extraneous: just-debounce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-debounce
                                      npm ERR! extraneous: just-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/just-extend
                                      npm ERR! extraneous: keyv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/keyv
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/kind-of
                                      npm ERR! extraneous: last-run@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/last-run
                                      npm ERR! extraneous: lazystream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lazystream
                                      npm ERR! extraneous: lcid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lcid
                                      npm ERR! extraneous: lead@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lead
                                      npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/levn
                                      npm ERR! extraneous: liftoff@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff
                                      npm ERR! extraneous: limiter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/limiter
                                      npm ERR! extraneous: load-json-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/load-json-file
                                      npm ERR! extraneous: localtunnel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel
                                      npm ERR! extraneous: locate-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/locate-path
                                      npm ERR! extraneous: lodash.get@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.get
                                      npm ERR! extraneous: lodash.isfinite@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.isfinite
                                      npm ERR! extraneous: lodash.merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.merge
                                      npm ERR! extraneous: lodash.truncate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash.truncate
                                      npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/lodash
                                      npm ERR! extraneous: log-symbols@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/log-symbols
                                      npm ERR! extraneous: loupe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/loupe
                                      npm ERR! extraneous: make-iterator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator
                                      npm ERR! extraneous: map-cache@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-cache
                                      npm ERR! extraneous: map-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-stream
                                      npm ERR! extraneous: map-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/map-visit
                                      npm ERR! extraneous: matchdep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep
                                      npm ERR! extraneous: media-typer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/media-typer
                                      npm ERR! extraneous: merge-descriptors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-descriptors
                                      npm ERR! extraneous: merge-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge-stream
                                      npm ERR! extraneous: merge2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/merge2
                                      npm ERR! extraneous: methods@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/methods
                                      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/micromatch
                                      npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mime
                                      npm ERR! extraneous: mimic-fn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mimic-fn
                                      npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
                                      npm ERR! extraneous: mitt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mitt
                                      npm ERR! extraneous: mixin-deep@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mixin-deep
                                      npm ERR! extraneous: mocha@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha
                                      npm ERR! extraneous: mute-stdout@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mute-stdout
                                      npm ERR! extraneous: nanoid@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanoid
                                      npm ERR! extraneous: nanomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch
                                      npm ERR! extraneous: natural-compare@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/natural-compare
                                      npm ERR! extraneous: negotiator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/negotiator
                                      npm ERR! extraneous: next-tick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/next-tick
                                      npm ERR! extraneous: nise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise
                                      npm ERR! extraneous: nodemon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon
                                      npm ERR! extraneous: nopt@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nopt
                                      npm ERR! extraneous: normalize-package-data@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data
                                      npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-path
                                      npm ERR! extraneous: now-and-later@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/now-and-later
                                      npm ERR! extraneous: npm-run-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/npm-run-path
                                      npm ERR! extraneous: number-is-nan@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/number-is-nan
                                      npm ERR! extraneous: nwmatcher@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nwmatcher
                                      npm ERR! extraneous: object-assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-assign
                                      npm ERR! extraneous: object-copy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy
                                      npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-inspect
                                      npm ERR! extraneous: object-keys@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-keys
                                      npm ERR! extraneous: object-visit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-visit
                                      npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.assign
                                      npm ERR! extraneous: object.defaults@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.defaults
                                      npm ERR! extraneous: object.map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.map
                                      npm ERR! extraneous: object.pick@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.pick
                                      npm ERR! extraneous: object.reduce@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object.reduce
                                      npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/on-finished
                                      npm ERR! extraneous: once@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
                                      npm ERR! extraneous: onetime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/onetime
                                      npm ERR! extraneous: openurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/openurl
                                      npm ERR! extraneous: opn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/opn
                                      npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/optionator
                                      npm ERR! extraneous: ordered-read-streams@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ordered-read-streams
                                      npm ERR! extraneous: os-locale@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/os-locale
                                      npm ERR! extraneous: p-limit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-limit
                                      npm ERR! extraneous: p-locate@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/p-locate
                                      npm ERR! extraneous: parent-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parent-module
                                      npm ERR! extraneous: parse-filepath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-filepath
                                      npm ERR! extraneous: parse-json@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-json
                                      npm ERR! extraneous: parse-node-version@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-node-version
                                      npm ERR! extraneous: parse-passwd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse-passwd
                                      npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parse5
                                      npm ERR! extraneous: parseurl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/parseurl
                                      npm ERR! extraneous: pascalcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pascalcase
                                      npm ERR! extraneous: path-dirname@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-dirname
                                      npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-exists
                                      npm ERR! extraneous: path-is-absolute@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
                                      npm ERR! extraneous: path-key@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-key
                                      npm ERR! extraneous: path-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-parse
                                      npm ERR! extraneous: path-root-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root-regex
                                      npm ERR! extraneous: path-root@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-root
                                      npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-to-regexp
                                      npm ERR! extraneous: path-type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-type
                                      npm ERR! extraneous: pathval@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pathval
                                      npm ERR! extraneous: pause-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pause-stream
                                      npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/picomatch
                                      npm ERR! extraneous: pify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pify
                                      npm ERR! extraneous: pinkie-promise@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie-promise
                                      npm ERR! extraneous: pinkie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pinkie
                                      npm ERR! extraneous: portscanner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/portscanner
                                      npm ERR! extraneous: posix-character-classes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/posix-character-classes
                                      npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/prelude-ls
                                      npm ERR! extraneous: pretty-hrtime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pretty-hrtime
                                      npm ERR! extraneous: proxy-addr@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/proxy-addr
                                      npm ERR! extraneous: ps-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ps-tree
                                      npm ERR! extraneous: pstree.remy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pstree.remy
                                      npm ERR! extraneous: pump@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pump
                                      npm ERR! extraneous: pumpify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/pumpify
                                      npm ERR! extraneous: qs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/qs
                                      npm ERR! extraneous: queue-microtask@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/queue-microtask
                                      npm ERR! extraneous: randombytes@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/randombytes
                                      npm ERR! extraneous: range-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/range-parser
                                      npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/raw-body
                                      npm ERR! extraneous: read-pkg-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up
                                      npm ERR! extraneous: read-pkg@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg
                                      npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/readdirp
                                      npm ERR! extraneous: rechoir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rechoir
                                      npm ERR! extraneous: regex-not@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/regex-not
                                      npm ERR! extraneous: remove-bom-buffer@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-buffer
                                      npm ERR! extraneous: remove-bom-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-bom-stream
                                      npm ERR! extraneous: remove-trailing-separator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/remove-trailing-separator
                                      npm ERR! extraneous: repeat-element@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-element
                                      npm ERR! extraneous: repeat-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/repeat-string
                                      npm ERR! extraneous: replace-ext@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-ext
                                      npm ERR! extraneous: replace-homedir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replace-homedir
                                      npm ERR! extraneous: replacestream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream
                                      npm ERR! extraneous: require-directory@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-directory
                                      npm ERR! extraneous: require-from-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-from-string
                                      npm ERR! extraneous: require-main-filename@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/require-main-filename
                                      npm ERR! extraneous: requires-port@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/requires-port
                                      npm ERR! extraneous: resolve-dir@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-dir
                                      npm ERR! extraneous: resolve-from@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-from
                                      npm ERR! extraneous: resolve-options@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-options
                                      npm ERR! extraneous: resolve-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve-url
                                      npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resolve
                                      npm ERR! extraneous: resp-modifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier
                                      npm ERR! extraneous: ret@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ret
                                      npm ERR! extraneous: reusify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/reusify
                                      npm ERR! extraneous: rimraf@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
                                      npm ERR! extraneous: run-parallel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/run-parallel
                                      npm ERR! extraneous: rx@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/rx
                                      npm ERR! extraneous: safe-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-regex
                                      npm ERR! extraneous: semver-greatest-satisfied-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/semver-greatest-satisfied-range
                                      npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send
                                      npm ERR! extraneous: serialize-javascript@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serialize-javascript
                                      npm ERR! extraneous: serve-index@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index
                                      npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-static
                                      npm ERR! extraneous: server-destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/server-destroy
                                      npm ERR! extraneous: set-blocking@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-blocking
                                      npm ERR! extraneous: set-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value
                                      npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/setprototypeof
                                      npm ERR! extraneous: shebang-command@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-command
                                      npm ERR! extraneous: shebang-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/shebang-regex
                                      npm ERR! extraneous: side-channel@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/side-channel
                                      npm ERR! extraneous: signal-exit@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/signal-exit
                                      npm ERR! extraneous: simple-update-notifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier
                                      npm ERR! extraneous: sinon-chai@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon-chai
                                      npm ERR! extraneous: sinon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sinon
                                      npm ERR! extraneous: slice-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/slice-ansi
                                      npm ERR! extraneous: snapdragon-node@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node
                                      npm ERR! extraneous: snapdragon-util@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util
                                      npm ERR! extraneous: snapdragon@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon
                                      npm ERR! extraneous: socket.io-adapter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter
                                      npm ERR! extraneous: socket.io-client@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-client
                                      npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-parser
                                      npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io
                                      npm ERR! extraneous: source-map-resolve@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-resolve
                                      npm ERR! extraneous: source-map-support@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support
                                      npm ERR! extraneous: source-map-url@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-url
                                      npm ERR! extraneous: sparkles@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sparkles
                                      npm ERR! extraneous: spdx-correct@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-correct
                                      npm ERR! extraneous: spdx-exceptions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-exceptions
                                      npm ERR! extraneous: spdx-expression-parse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-expression-parse
                                      npm ERR! extraneous: spdx-license-ids@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/spdx-license-ids
                                      npm ERR! extraneous: split-string@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split-string
                                      npm ERR! extraneous: split@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/split
                                      npm ERR! extraneous: stack-trace@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stack-trace
                                      npm ERR! extraneous: static-extend@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend
                                      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/statuses
                                      npm ERR! extraneous: stream-combiner@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-combiner
                                      npm ERR! extraneous: stream-exhaust@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-exhaust
                                      npm ERR! extraneous: stream-shift@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-shift
                                      npm ERR! extraneous: stream-throttle@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/stream-throttle
                                      npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/string-width
                                      npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-ansi
                                      npm ERR! extraneous: strip-bom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-bom
                                      npm ERR! extraneous: strip-final-newline@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-final-newline
                                      npm ERR! extraneous: strip-json-comments@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/strip-json-comments
                                      npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-color
                                      npm ERR! extraneous: supports-preserve-symlinks-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/supports-preserve-symlinks-flag
                                      npm ERR! extraneous: sver-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/sver-compat
                                      npm ERR! extraneous: symbol-tree@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/symbol-tree
                                      npm ERR! extraneous: table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table
                                      npm ERR! extraneous: text-table@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/text-table
                                      npm ERR! extraneous: textextensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/textextensions
                                      npm ERR! extraneous: through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through
                                      npm ERR! extraneous: through2-filter@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2-filter
                                      npm ERR! extraneous: through2@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/through2
                                      npm ERR! extraneous: time-stamp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/time-stamp
                                      npm ERR! extraneous: timekeeper@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/timekeeper
                                      npm ERR! extraneous: tiny-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tiny-glob
                                      npm ERR! extraneous: to-absolute-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-absolute-glob
                                      npm ERR! extraneous: to-object-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path
                                      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex-range
                                      npm ERR! extraneous: to-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-regex
                                      npm ERR! extraneous: to-through@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-through
                                      npm ERR! extraneous: toidentifier@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/toidentifier
                                      npm ERR! extraneous: touch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/touch
                                      npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/tr46
                                      npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-check
                                      npm ERR! extraneous: type-detect@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-detect
                                      npm ERR! extraneous: type-fest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-fest
                                      npm ERR! extraneous: type-is@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type-is
                                      npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/type
                                      npm ERR! extraneous: typedarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/typedarray
                                      npm ERR! extraneous: ua-parser-js@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ua-parser-js
                                      npm ERR! extraneous: unc-path-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unc-path-regex
                                      npm ERR! extraneous: undefsafe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undefsafe
                                      npm ERR! extraneous: undertaker-registry@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker-registry
                                      npm ERR! extraneous: undertaker@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker
                                      npm ERR! extraneous: union-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value
                                      npm ERR! extraneous: unique-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unique-stream
                                      npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/universalify
                                      npm ERR! extraneous: unpipe@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unpipe
                                      npm ERR! extraneous: unset-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value
                                      npm ERR! extraneous: upath@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/upath
                                      npm ERR! extraneous: urix@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/urix
                                      npm ERR! extraneous: use@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/use
                                      npm ERR! extraneous: utils-merge@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/utils-merge
                                      npm ERR! extraneous: v8flags@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/v8flags
                                      npm ERR! extraneous: validate-npm-package-license@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/validate-npm-package-license
                                      npm ERR! extraneous: value-or-function@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/value-or-function
                                      npm ERR! extraneous: vary@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vary
                                      npm ERR! extraneous: vinyl-fs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-fs
                                      npm ERR! extraneous: vinyl-sourcemap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap
                                      npm ERR! extraneous: vinyl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl
                                      npm ERR! extraneous: whatwg-url-compat@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/whatwg-url-compat
                                      npm ERR! extraneous: which-module@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which-module
                                      npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/which
                                      npm ERR! extraneous: widest-line@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/widest-line
                                      npm ERR! extraneous: word-wrap@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/word-wrap
                                      npm ERR! extraneous: workerpool@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/workerpool
                                      npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrap-ansi
                                      npm ERR! extraneous: wrappy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
                                      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ws
                                      npm ERR! extraneous: xml-name-validator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml-name-validator
                                      npm ERR! extraneous: xmldom@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmldom
                                      npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest-ssl
                                      npm ERR! extraneous: xmlhttprequest@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/xmlhttprequest
                                      npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/y18n
                                      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-parser
                                      npm ERR! extraneous: yargs-unparser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser
                                      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs
                                      npm ERR! extraneous: yocto-queue@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yocto-queue
                                      npm ERR! extraneous: debug@4.3.4 /opt/iobroker/node_modules/virtual-tsc/node_modules/debug
                                      npm ERR! extraneous: ms@2.1.2 /opt/iobroker/node_modules/virtual-tsc/node_modules/ms
                                      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/pak/node_modules/axios
                                      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script-plugin-iobroker/node_modules/axios
                                      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@alcalzone/release-script/node_modules/axios
                                      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@iobroker/dev-server/node_modules/axios
                                      npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
                                      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/acorn-globals/node_modules/acorn
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-initial/node_modules/is-number
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/array-last/node_modules/is-number
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/base/node_modules/define-property
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/debug
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/ms
                                      npm ERR! extraneous: raw-body@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/body-parser/node_modules/raw-body
                                      npm ERR! extraneous: fs-extra@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/fs-extra
                                      npm ERR! extraneous: jsonfile@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/jsonfile
                                      npm ERR! extraneous: universalify@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/browser-sync/node_modules/universalify
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/debug
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/bs-html-injector/node_modules/ms
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/define-property
                                      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor
                                      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor
                                      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-descriptor
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/debug
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/connect/node_modules/ms
                                      npm ERR! extraneous: domelementtype@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/domelementtype
                                      npm ERR! extraneous: entities@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/dom-serializer/node_modules/entities
                                      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/each-props/node_modules/is-plain-object
                                      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io-client/node_modules/ws
                                      npm ERR! extraneous: cookie@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/cookie
                                      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/engine.io/node_modules/ws
                                      npm ERR! extraneous: estraverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/estraverse
                                      npm ERR! extraneous: levn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/levn
                                      npm ERR! extraneous: optionator@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/optionator
                                      npm ERR! extraneous: prelude-ls@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/prelude-ls
                                      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/source-map
                                      npm ERR! extraneous: type-check@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/escodegen/node_modules/type-check
                                      npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/eslint/node_modules/glob-parent
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/debug
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/define-property
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/extend-shallow
                                      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor
                                      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor
                                      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-descriptor
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-extendable
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/ms
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/debug
                                      npm ERR! extraneous: finalhandler@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/finalhandler
                                      npm ERR! extraneous: mime@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/mime
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/ms
                                      npm ERR! extraneous: send@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send
                                      npm ERR! extraneous: serve-static@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/serve-static
                                      npm ERR! extraneous: type@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/ext/node_modules/type
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/define-property
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/extend-shallow
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/extglob/node_modules/is-extendable
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/debug
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/ms
                                      npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/on-finished
                                      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/finalhandler/node_modules/statuses
                                      npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces
                                      npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-extendable
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/kind-of
                                      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/micromatch
                                      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/to-regex-range
                                      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/fined/node_modules/is-plain-object
                                      npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/glob-parent
                                      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-stream/node_modules/is-glob
                                      npm ERR! extraneous: anymatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch
                                      npm ERR! extraneous: binary-extensions@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/binary-extensions
                                      npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces
                                      npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/chokidar
                                      npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range
                                      npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fsevents
                                      npm ERR! extraneous: glob-parent@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent
                                      npm ERR! extraneous: is-binary-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-binary-path
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-extendable
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/is-number
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/kind-of
                                      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch
                                      npm ERR! extraneous: readdirp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/readdirp
                                      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/to-regex-range
                                      npm ERR! extraneous: which@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/global-prefix/node_modules/which
                                      npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-colors
                                      npm ERR! extraneous: ansi-regex@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/ansi-regex
                                      npm ERR! extraneous: camelcase@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/camelcase
                                      npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/cliui
                                      npm ERR! extraneous: decamelize@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/decamelize
                                      npm ERR! extraneous: get-caller-file@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/get-caller-file
                                      npm ERR! extraneous: is-fullwidth-code-point@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/is-fullwidth-code-point
                                      npm ERR! extraneous: string-width@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/string-width
                                      npm ERR! extraneous: strip-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/strip-ansi
                                      npm ERR! extraneous: wrap-ansi@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/wrap-ansi
                                      npm ERR! extraneous: y18n@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/y18n
                                      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs-parser
                                      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/gulp-cli/node_modules/yargs
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/kind-of
                                      npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/htmlparser2/node_modules/readable-stream
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-accessor-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-data-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/is-extendable/node_modules/is-plain-object
                                      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/jsdom/node_modules/acorn
                                      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/liftoff/node_modules/is-plain-object
                                      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/axios
                                      npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/cliui
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/debug
                                      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs-parser
                                      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/localtunnel/node_modules/yargs
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/make-iterator/node_modules/kind-of
                                      npm ERR! extraneous: braces@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces
                                      npm ERR! extraneous: fill-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range
                                      npm ERR! extraneous: findup-sync@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/findup-sync
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-extendable
                                      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-glob
                                      npm ERR! extraneous: is-number@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/kind-of
                                      npm ERR! extraneous: micromatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/micromatch
                                      npm ERR! extraneous: to-regex-range@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/to-regex-range
                                      npm ERR! extraneous: ansi-colors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ansi-colors
                                      npm ERR! extraneous: brace-expansion@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/brace-expansion
                                      npm ERR! extraneous: cliui@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/cliui
                                      npm ERR! extraneous: minimatch@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/minimatch
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/ms
                                      npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/supports-color
                                      npm ERR! extraneous: yargs-parser@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs-parser
                                      npm ERR! extraneous: yargs@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/mocha/node_modules/yargs
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nanomatch/node_modules/kind-of
                                      npm ERR! extraneous: @sinonjs/fake-timers@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers
                                      npm ERR! extraneous: isarray@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/isarray
                                      npm ERR! extraneous: path-to-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/path-to-regexp
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/debug
                                      npm ERR! extraneous: has-flag@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/has-flag
                                      npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/semver
                                      npm ERR! extraneous: supports-color@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nodemon/node_modules/supports-color
                                      npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/normalize-package-data/node_modules/semver
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/define-property
                                      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-accessor-descriptor
                                      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-data-descriptor
                                      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/kind-of
                                      npm ERR! extraneous: find-up@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/find-up
                                      npm ERR! extraneous: path-exists@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/read-pkg-up/node_modules/path-exists
                                      npm ERR! extraneous: escape-string-regexp@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/replacestream/node_modules/escape-string-regexp
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/debug
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/resp-modifier/node_modules/ms
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/debug
                                      npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/depd
                                      npm ERR! extraneous: destroy@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/destroy
                                      npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/http-errors
                                      npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/inherits
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/ms
                                      npm ERR! extraneous: on-finished@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/on-finished
                                      npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/setprototypeof
                                      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/send/node_modules/statuses
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/debug
                                      npm ERR! extraneous: depd@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/depd
                                      npm ERR! extraneous: http-errors@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/http-errors
                                      npm ERR! extraneous: inherits@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/inherits
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/ms
                                      npm ERR! extraneous: setprototypeof@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/setprototypeof
                                      npm ERR! extraneous: statuses@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/serve-index/node_modules/statuses
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/extend-shallow
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-extendable
                                      npm ERR! extraneous: is-plain-object@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/set-value/node_modules/is-plain-object
                                      npm ERR! extraneous: semver@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/simple-update-notifier/node_modules/semver
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-node/node_modules/define-property
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon-util/node_modules/kind-of
                                      npm ERR! extraneous: debug@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/debug
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/define-property
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/extend-shallow
                                      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor
                                      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor
                                      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-descriptor
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-extendable
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/ms
                                      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/source-map
                                      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/socket.io-adapter/node_modules/ws
                                      npm ERR! extraneous: source-map@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/source-map-support/node_modules/source-map
                                      npm ERR! extraneous: define-property@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/define-property
                                      npm ERR! extraneous: is-accessor-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor
                                      npm ERR! extraneous: is-data-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor
                                      npm ERR! extraneous: is-descriptor@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-descriptor
                                      npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/ajv
                                      npm ERR! extraneous: json-schema-traverse@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/table/node_modules/json-schema-traverse
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/to-object-path/node_modules/kind-of
                                      npm ERR! extraneous: fast-levenshtein@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/undertaker/node_modules/fast-levenshtein
                                      npm ERR! extraneous: is-extendable@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/union-value/node_modules/is-extendable
                                      npm ERR! extraneous: has-value@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value
                                      npm ERR! extraneous: has-values@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-values
                                      npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/vinyl-sourcemap/node_modules/normalize-path
                                      npm ERR! extraneous: is-plain-obj@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/yargs-unparser/node_modules/is-plain-obj
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-accessor-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/class-utils/node_modules/is-data-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-accessor-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/expand-brackets/node_modules/is-data-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: ms@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/express/node_modules/send/node_modules/ms
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/braces/node_modules/extend-shallow
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/fill-range/node_modules/extend-shallow
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/findup-sync/node_modules/is-number/node_modules/kind-of
                                      npm ERR! extraneous: normalize-path@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/anymatch/node_modules/normalize-path
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/braces/node_modules/extend-shallow
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/fill-range/node_modules/extend-shallow
                                      npm ERR! extraneous: is-glob@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/glob-parent/node_modules/is-glob
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob-watcher/node_modules/micromatch/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/has-values/node_modules/is-number/node_modules/kind-of
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/braces/node_modules/extend-shallow
                                      npm ERR! extraneous: extend-shallow@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/fill-range/node_modules/extend-shallow
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/matchdep/node_modules/is-number/node_modules/kind-of
                                      npm ERR! extraneous: @sinonjs/commons@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/nise/node_modules/@sinonjs/fake-timers/node_modules/@sinonjs/commons
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-accessor-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/snapdragon/node_modules/is-data-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: kind-of@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
                                      npm ERR! extraneous: isobject@ /opt/iobroker/node_modules/iobroker.javascript/node_modules/unset-value/node_modules/has-value/node_modules/isobject
                                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2023-11-08T20_56_24_842Z-debug-0.log
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Core adapters versions
                                      js-controller:  5.0.12
                                      admin:          6.12.0
                                      javascript:     7.1.4
                                      Adapters from github:   9
                                      Adapter State
                                      + system.adapter.accuweather.0            : accuweather           : IoBroker64Bit                            -  enabled
                                      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                        system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 - disabled
                                      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                                      + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                                      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                                      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                                      + system.adapter.envertech-pv.0           : envertech-pv          : iobroker                                 -  enabled
                                      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 -  enabled
                                      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                      + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
                                      + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
                                      + system.adapter.hekr.0                   : hekr                  : IoBroker64Bit                            -  enabled
                                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                                      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
                                      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                      + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                                        system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
                                        system.adapter.midea.0                  : midea                 : IoBroker64Bit                            - disabled
                                      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker64Bit                            -  enabled, port: 54321
                                      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.69
                                      + system.adapter.nuki.0                   : nuki                  : IoBroker64Bit                            -  enabled
                                      + system.adapter.nuki.1                   : nuki                  : IoBroker64Bit                            -  enabled
                                      + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                                      + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
                                      + system.adapter.octoprint.1              : octoprint             : iobroker                                 -  enabled
                                      + system.adapter.parcel.0                 : parcel                : iobroker                                 -  enabled
                                      + system.adapter.pi-hole.0                : pi-hole               : iobroker                                 -  enabled
                                      + system.adapter.pioneer_sc_vsx.0         : pioneer_sc_vsx        : iobroker                                 -  enabled, port: 23
                                      + system.adapter.psa.0                    : psa                   : iobroker                                 -  enabled
                                      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                                      + system.adapter.pvforecast.1             : pvforecast            : iobroker                                 -  enabled
                                      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                      + system.adapter.rpi2.1                   : rpi2                  : IoBroker64Bit                            -  enabled
                                      + system.adapter.s7.0                     : s7                    : iobroker                                 -  enabled
                                      + system.adapter.sainlogic.0              : sainlogic             : iobroker                                 -  enabled, port: 45000, bind: 192.168.178.69
                                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
                                      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.69
                                      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
                                      + system.adapter.switchbot-hub.0          : switchbot-hub         : IoBroker64Bit                            -  enabled
                                      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                                      + system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
                                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.tr-064.0                 : tr-064                : IoBroker64Bit                            -  enabled
                                      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                                      + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                                        system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                                      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                                        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                                        system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                                        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
                                        system.adapter.vis-players.0            : vis-players           : iobroker                                 -  enabled
                                        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                      + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                                      + instance is alive
                                      ioBroker-Repositories
                                      Active repo(s): stable
                                      Installed ioBroker-Instances
                                      Used repository: stable
                                      Adapter    "accuweather"  : 1.3.1    , installed 1.3.1
                                      Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                      Adapter    "alexa2"       : 3.25.2   , installed 3.25.5
                                      Adapter    "backitup"     : 2.8.7    , installed 2.8.7
                                      Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                                      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                                      Adapter    "device-reminder": 3.0.0  , installed 3.0.0
                                      Adapter    "device-watcher": 2.9.4   , installed 2.9.4
                                      Adapter    "devices"      : 1.1.5    , installed 1.1.5
                                      Adapter    "echarts"      : 1.5.1    , installed 1.5.1
                                      Adapter    "envertech-pv" : 1.0.2    , installed 1.0.2
                                      Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                                      Adapter    "eventlist"    : 1.2.3    , installed 1.2.3
                                      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                      Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                      Adapter    "ham"          : 5.3.1    , installed 5.3.1
                                      Adapter    "hekr"         : 0.0.6    , installed 0.0.6
                                      Adapter    "hm-rega"      : 3.0.47   , installed 3.0.47
                                      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                      Adapter    "ical"         : 1.13.3   , installed 1.13.3
                                      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                      Adapter    "info"         : 2.0.0    , installed 2.0.0
                                      Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
                                      Controller "js-controller": 5.0.12   , installed 5.0.12
                                      Adapter    "logparser"    : 2.2.0    , installed 2.2.0
                                      Adapter    "luftdaten"    : 3.1.0    , installed 3.1.0
                                      Adapter    "midea"        : 0.0.7    , installed 0.1.0
                                      Adapter    "mqtt"         : 4.1.1    , installed 4.1.1
                                      Adapter    "mqtt-client"  : 1.6.5    , installed 1.6.5
                                      Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                      Adapter    "nut"          : 1.6.0    , installed 1.6.0
                                      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                                      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
                                      Adapter    "psa"          : 0.0.11   , installed 0.0.11
                                      Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
                                      Adapter    "s7"           : 1.3.15   , installed 1.3.15
                                      Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
                                      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
                                      Adapter    "sonoff"       : 2.5.3    , installed 2.5.3
                                      Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                      Adapter    "telegram"     : 2.0.1    , installed 2.0.1
                                      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                      Adapter    "tuya"         : 3.14.2   , installed 3.14.2
                                      Adapter    "upnp"         : 1.0.21   , installed 1.0.21
                                      Adapter    "vis-icontwo"  : 0.96.0   , installed 0.96.0
                                      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                                      Adapter    "web"          : 6.1.4    , installed 6.1.2  [Updatable]
                                      Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                      Adapter    "ws"           : 2.5.5    , installed 2.5.5
                                      Objects and States
                                      Objects:        28839
                                      States:         24330
                                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                                      Reading package lists...
                                      Pending Updates: 0
                                      *** Listening Ports ***
                                      tcp        0      0 192.168.178.69:45000    0.0.0.0:*               LISTEN      1001       150559     18465/io.sainlogic.
                                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16499      531/cupsd
                                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13823      917/exim4
                                      tcp        0      0 192.168.178.69:8701     0.0.0.0:*               LISTEN      1001       138031     17482/io.hm-rpc.0
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       140028     17700/io.mqtt.1
                                      tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       143721     17847/io.shelly.1
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       140027     17700/io.mqtt.1
                                      tcp        0      0 192.168.178.69:2010     0.0.0.0:*               LISTEN      1001       140025     17692/io.hm-rpc.3
                                      tcp        0      0 192.168.178.69:2001     0.0.0.0:*               LISTEN      1001       141320     17505/io.hm-rpc.1
                                      tcp        0      0 192.168.178.69:2000     0.0.0.0:*               LISTEN      1001       136160     17568/io.hm-rpc.2
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15217      611/sshd: /usr/sbin
                                      tcp        0      0 192.168.178.69:1887     0.0.0.0:*               LISTEN      1001       140070     17813/io.mqtt.3
                                      tcp        0      0 192.168.178.69:1886     0.0.0.0:*               LISTEN      1001       140069     17813/io.mqtt.3
                                      tcp        0      0 192.168.178.69:1882     0.0.0.0:*               LISTEN      1001       141739     17790/io.sonoff.0
                                      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       138417     17273/iobroker.js-c
                                      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       138410     17273/iobroker.js-c
                                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       148037     18544/io.simple-api
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       137827     17298/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       158639     20102/io.web.0
                                      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       168901     18256/io.upnp.0
                                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13824      917/exim4
                                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16498      531/cupsd
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15219      611/sshd: /usr/sbin
                                      tcp6       0      0 :::80                   :::*                    LISTEN      0          15245      658/apache2
                                      udp        0      0 0.0.0.0:51507           0.0.0.0:*                           1001       146871     18210/io.broadlink2
                                      udp        0      0 0.0.0.0:59804           0.0.0.0:*                           1001       146875     18210/io.broadlink2
                                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       141936     17828/io.tuya.0
                                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       141937     17828/io.tuya.0
                                      udp        0      0 0.0.0.0:55830           0.0.0.0:*                           108        14770      396/avahi-daemon: r
                                      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       146867     18210/io.broadlink2
                                      udp        0      0 0.0.0.0:36315           0.0.0.0:*                           1001       146874     18210/io.broadlink2
                                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16646      459/dhcpcd
                                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13758      596/cups-browsed
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14768      396/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141737     17779/io.shelly.0
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       147689     18256/io.upnp.0
                                      udp6       0      0 :::45149                :::*                                108        14771      396/avahi-daemon: r
                                      udp6       0      0 :::546                  :::*                                0          16667      459/dhcpcd
                                      udp6       0      0 :::5353                 :::*                                108        14769      396/avahi-daemon: r
                                      2023-11-08 21:52:08.090  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                      2023-11-08 21:53:00.347  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                      2023-11-08 21:53:00.888  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476780888_7107
                                      2023-11-08 21:53:58.129  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                      2023-11-08 21:54:00.072  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 3554
                                      2023-11-08 21:54:01.670  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476841669_4609
                                      2023-11-08 21:54:07.965  - info: luftdaten.0 (3554) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                                      2023-11-08 21:54:08.604  - info: luftdaten.0 (3554) Terminated (NO_ERROR): Without reason
                                      2023-11-08 21:54:09.169  - warn: luftdaten.0 (3554) get state error: Connection is closed.
                                      2023-11-08 21:54:09.400  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                      2023-11-08 21:54:32.528  - info: fritzdect.0 (18158) DECT ID: 087610101442 identified for command (state) : false
                                      2023-11-08 21:54:59.917  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                      2023-11-08 21:55:00.201  - info: host.iobroker instance system.adapter.dwd.0 started with pid 3669
                                      2023-11-08 21:55:02.467  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476902467_6802
                                      2023-11-08 21:55:07.827  - info: dwd.0 (3669) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.18.2, js-controller: 5.0.12
                                      2023-11-08 21:55:09.345  - info: dwd.0 (3669) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2023-11-08 21:55:09.893  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2023-11-08 21:56:00.181  - info: host.iobroker instance system.adapter.luftdaten.0 started with pid 4091
                                      2023-11-08 21:56:00.710  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                      2023-11-08 21:56:01.245  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699476961244_1751
                                      2023-11-08 21:56:07.469  - info: luftdaten.0 (4091) starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.luftdaten, node: v18.18.2, js-controller: 5.0.12
                                      2023-11-08 21:56:08.624  - info: luftdaten.0 (4091) Terminated (NO_ERROR): Without reason
                                      2023-11-08 21:56:09.211  - info: host.iobroker instance system.adapter.luftdaten.0 terminated with code 0 (NO_ERROR)
                                      2023-11-08 21:56:59.486  - info: mqtt.1 (17700) Client [Solaranzeige] connection closed: disconnected
                                      2023-11-08 21:57:02.037  - info: mqtt.1 (17700) Client [Solaranzeige] connected with secret 1699477022036_8863
                                      @michaelf
                                      Räum das auf:
                                      npm ERR! missing: homebridge-midea-air@^1.7.3, required by iobroker.ham@5.3.1
                                      npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
                                      MichaelFM 1 Antwort Letzte Antwort
                                        @michaelf
                                        Räum das auf:
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        schrieb am zuletzt editiert von MichaelF
                                        @thomas-braun said in Adapterwarnungen / web stürzt ab:
                                        @michaelf
                                        Räum das auf:
                                        Aufräumen ?
                                        Das müsste das hier sein ?
                                        • MichaelFM MichaelF
                                          @michaelf
                                          Räum das auf:
                                          Aufräumen ?
                                          @michaelf
                                          Die fehlen aus Sicht von npm.
                                          Ich weiß aber nicht wie der ham-Adapter das handhabt.
