  4. IObroker stürzt immer ab...
6 Beiträge 3 Kommentatoren 499 Aufrufe 3 Beobachtet
  • ? Offline
    mein Iobroker mit der Version 9.0., NPM 9.8.1, Node 18.18.2, js-controller: 5.0.12 stürzt regelmäßig ab. Er schließt dann automatisch den Port.
    Das System läuft auf einer Synology Docker.
    Er lieft jetzt wieder 2 Tage und dann war das Problem. :-/
    Hier ein Auszug aus dem Log:
    2023-11-08 09:32:02.748 - error: shelly.0 (373) Error: Cannot find view "system"
    2023-11-08 09:32:02.751 - error: shelly.0 (373) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-11-08 09:32:02.752 - error: shelly.0 (373) unhandled promise rejection: DB closed
    2023-11-08 09:32:02.759 - error: shelly.0 (373) Error: DB closed
    at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:160:20)
    at Object.onceWrapper (node:events:632:26)
    at Socket.emit (node:events:517:28)
    at Socket.emit (node:domain:489:12)
    at TCP. (node:net:350:12)
    2023-11-08 09:32:02.760 - error: shelly.0 (373) DB closed
    2023-11-08 09:32:02.813 - info: shelly.0 (373) terminating
    2023-11-08 09:32:02.815 - warn: shelly.0 (373) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2023-11-08 09:32:02.818 - error: shelly.0 (373) Cannot find view "system" for search "device" : Connection is closed.
    2023-11-08 09:32:02.822 - error: shelly.0 (373) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2023-11-08 09:32:02.699 - error: javascript.0 (223) States database error: connect ECONNREFUSED 127.0.0.1:9000
    2023-11-08 09:32:02.884 - warn: javascript.0 (223) get state error: DB closed
    2023-11-08 09:32:02.885 - warn: javascript.0 (223) get state error: DB closed
    2023-11-08 09:32:02.886 - warn: javascript.0 (223) get state error: DB closed
    2023-11-08 09:32:02.931 - error: javascript.0 (223) script.js.POST.Playstation.CheckPS5On: setForeignState: Error: DB closed
    2023-11-08 09:32:02.932 - error: javascript.0 (223) script.js.POST.Aktie.aktie: setForeignState: Error: DB closed
    2023-11-08 09:32:02.933 - error: javascript.0 (223) script.js.POST.Aktie.aktie: setForeignState: Error: DB closed
    2023-11-08 09:32:06.869 - info: simple-api.0 (625) terminating http server on port 8087
    2023-11-08 09:32:06.894 - info: tado.0 (527) cleaned everything up...
    2023-11-08 09:32:06.893 - info: admin.1 (204) terminating http server on port 8090
    2023-11-08 09:32:06.902 - debug: web.0 (441) synochat.0 > Destroying extension for adapter instance 'synochat.0'!
    2023-11-08 09:32:06.930 - info: broadlink2.0 (561) Close all connections...
    2023-11-08 09:32:06.956 - info: yahka.0 (418) cleaning up ...
    2023-11-08 09:32:06.983 - info: admin.0 (197) terminating http server on port 8091
    2023-11-08 09:32:07.210 - info: backitup.0 (546) cleaned everything up...
    2023-11-08 09:32:07.222 - warn: synochat.0 (763) Got termination signal for SynoChat adapter instance! > Terminating instance...
    ? mcm1957M 2 Antworten Letzte Antwort
      @olli_m sagte in IObroker stürzt immer ab...:
      Moin,
      das ist leider nicht der korrekte Zeitpunkt, an dem das wahre Problem stattgefunden hat, das muss noch davor liegen.
      Bernd
      P.S.: Welche Version vom ioBroker Image, wie ist der Container konfiguriert, was nutzt Du DSM Container Manager, Protainer?
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @olli_m
        sicherheits halber ne Frage:
        Verwendest du den COMPACT MODE?
        (In 5.0.12 existiert(e) ein Problem mit dem compact mode)
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
          Moin,
          Bernd
          @dp20eic
          über DSM Container, Buanet-iobroker.9.0.0 , was möchtest du genau wissen noch? der Container nutzt das selbe host Netzwerk.
          Ab hier gingen die Probleme los, davor war noch alles im grünen Bereich:
          2023-11-08 09:30:00.081 - info: javascript.0 (223) script.js.common.Astro: Astro: Gültige Zeiten: [aktueller Tag: 8] | [nächster Tag: 6] | [Aktualisiert: 0] | Aktuelle Tageszeit: später Vormittag | Kommende Tageszeit: Mittag
          2023-11-08 09:30:00.252 - info: javascript.0 (223) script.js.POST.Aktie.aktie: Ferrari
          2023-11-08 09:30:15.258 - info: ham.0 (334) stateChange ham.0.Wifi-Thermometer.Wifi-Thermometer-History.S2R1 {"val":"wj8JAAAAAADVPvIqAgECAgLgA8APAAAAAAAAAAABAQ==","ack":true,"ts":1699432215257,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1699432215257}
          2023-11-08 09:30:32.178 - error: mielecloudservice.0 (384) States database error: read ECONNRESET
          2023-11-08 09:30:32.209 - error: synology.0 (327) States database error: read ECONNRESET
          2023-11-08 09:30:37.183 - error: mielecloudservice.0 (384) States database error: connect ECONNREFUSED 127.0.0.1:9000
          2023-11-08 09:30:37.193 - error: mielecloudservice.0 (384) Objects database error: connect ECONNREFUSED 127.0.0.1:9001
          2023-11-08 09:32:03.088 - error: shelly.0 (373) Error: Cannot find view "system"
          at ObjectsInRedisClient._getObjectView (/opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:4328:59)
          at processTicksAndRejections (node:internal/process/task_queues:95:5)
          at runNextTicks (node:internal/process/task_queues:64:3)
          at processImmediate (node:internal/timers:447:9)
          2023-11-08 09:32:03.088 - error: shelly.0 (373) Cannot find view "system"
          2023-11-08 09:32:03.094 - error: shelly.0 (373) uncaught exception: write EPIPE
          2023-11-08 09:32:03.094 - error: shelly.0 (373) Error: write EPIPE
          at afterWriteDispatched (node:internal/stream_base_commons:160:15)
          at writeGeneric (node:internal/stream_base_commons:151:3)
          at Socket._writeGeneric (node:net:962:11)
          at Socket._write (node:net:974:8)
          at writeOrBuffer (node:internal/streams/writable:392:12)
          at _write (node:internal/streams/writable:333:10)
          at Socket.Writable.write (node:internal/streams/writable:337:10)
          at console.value (node:internal/console/constructor:305:16)
          at console.warn (node:internal/console/constructor:385:26)
          at /opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/integrations/onunhandledrejection.ts:97:17
          2023-11-08 09:32:03.094 - error: shelly.0 (373) Exception-Code: EPIPE: write EPIPE
          2023-11-08 09:32:03.126 - error: shelly.0 (373) uncaught exception: write EPIPE
          2023-11-08 09:32:03.126 - error: shelly.0 (373) Error: write EPIPE
          at console.error (/opt/iobroker/node_modules/@iobroker/plugin-sentry/node_modules/@sentry/src/integrations/console.ts:51:29)
          2023-11-08 09:32:03.127 - error: shelly.0 (373) Exception-Code: EPIPE: write EPIPE
          2023-11-08 09:32:03.182 - info: hue.0 (281) terminating
          2023-11-08 09:32:02.779 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.780 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.780 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.783 - info: lgtv.0 (501) terminating
          2023-11-08 09:32:02.784 - warn: lgtv.0 (501) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2023-11-08 09:32:02.785 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.785 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.785 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.786 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.786 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.787 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.787 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.787 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.790 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.790 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.790 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.790 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.791 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.791 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.792 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.792 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.793 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.793 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.793 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.793 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.794 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.797 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.797 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.798 - error: lgtv.0 (501) DB closed
          2023-11-08 09:32:02.800 - error: lgtv.0 (501) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2023-11-08 09:32:02.800 - error: lgtv.0 (501) unhandled promise rejection: DB closed
          2023-11-08 09:32:02.800 - error: lgtv.0 (501) Error: DB closed
          2023-11-08 09:32:02.801 - error: lgtv.0 (501) DB closed
          also dauernd ein DB Fehler der kommt....das iobroker Docker image läuft dann noch aber er schließt dann den Port.
          • mcm1957M mcm1957
            @olli_m
            @mcm57
            welchen Compact Mode meinst du denn? das sagt mir ja gar nichts gerade :-(
              @dp20eic
              Moin,
              es gibt zwei Logs, Du hast jetzt das Log gezeigt, welches der ioBroker schreibt, im Docker ist es aber so, glaube ich, dass das ioBroker Log auch ins Docker Log geschrieben wird, das Docker Log enthält dann auch alles was außerhalb des ioBrokers noch so passiert.
              Beispiel:
              Bernd
              82.9k
