  4. Adapter Updates sehr langsam, viele Warnmeldungen
5 Beiträge 3 Kommentatoren 420 Aufrufe 1 Beobachtet
  • L Offline
    loverz
    Jemand eine Idee, wie ich diese Meldungen wegbekomme?
    (Sie erscheinen bei jedem Apdaterupdate. Die Updates sind dadurch furchtbar langsam und dauern teilweise 5-10 Minuten)
    Hardware: Raspberry Pi 4 4GB (genug RAM frei)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated topo@3.0.3: This module has moved and is now available at @hapi/topo. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated babel@6.23.0: In 6.x, the babel package has been deprecated in favor of babel-cli. Check https://opencollective.com/babel to support the Babel maintainers
    npm WARN deprecated string-similarity@4.0.4: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated hoek@6.1.3: This module has moved and is now available at @hapi/hoek. Please update your dependencies as this version is no longer maintained an may contain bugs and security issues.
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated circular-json@0.5.9: CircularJSON is in maintenance only, flatted is its successor.
    npm WARN deprecated xmldom@0.1.31: Deprecated due to CVE-2021-21366 resolved in 0.5.0
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated joi@14.3.1: This module has moved and is now available at @hapi/joi. Please update your dependencies
    haselchenH Thomas BraunT 2 Antworten Letzte Antwort
    • L loverz
      haselchenH Offline
      haselchenH Offline
      haselchen
      @loverz
      ohne
      iob diag
      kriegen wir die Kuh nicht vom Eis ;)
      • L loverz
        @loverz sagte in Adapter Updates sehr langsam, viele Warnmeldungen:
        Gar nicht. Muss im entsprechenden Adapter angegangen werden.
        Das bremst aber die Installation nicht aus, sind nur Hinweise.
        L 1 Antwort Letzte Antwort
          loverz
          @thomas-braun das kommt aber bei jedem Adapter Update.
          Hab 3 ioBroker Installationen, nur bei dieser einen kommen diese Meldungen und das langsame Verhalten.
          Auch wenn 3x derselbe Adapter auf allen 3 Rechnern upgedatet wird.
          • L loverz
            Natürlich, weil diese Hinweise jedesmal kommen, wenn npm durch deine Installation schaut und diese Dinger entdeckt.
            82.9k
