  3. Einsteigerfragen
  4. [gelöst]NPM ERR! missing node-ssh@^13.1.0, required by io
    5.5k
6 Beiträge 2 Kommentatoren 575 Aufrufe 1 Beobachtet
  • G Offline
    guergen
    Hallo, habe grade mal iob diag aufgerufen und bekomme einen Fehler (s.o)
    EDIT: Zeile 202-204
    Mit iob fix und iob node-update bekomme ich den auch nicht weg.
    Was ist zu tun?
    iob diag: (Langfassung)
    Skript v.2023-10-10
    *** BASE SYSTEM ***
     Static hostname: iob
           Icon name: computer-vm
             Chassis: vm 🖴
      Virtualization: kvm
              Kernel: Linux 6.1.0-13-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : amd64
    Systemuptime and Load:
     12:51:06 up 2 days, 20:54,  1 user,  load average: 0.37, 1.21, 1.45
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Fri 2023-11-03 12:51:06 CET
               Universal time: Fri 2023-11-03 11:51:06 UTC
                     RTC time: Fri 2023-11-03 11:51:06
                  NTP service: n/a
              RTC in local TZ: no
    *** User and Groups ***
    iob
    /home/iob
    iob cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            8.3G        481M        6.6G        540K        1.5G        7.8G
    Swap:           4.0G          0B        4.0G
    Total:           12G        481M         10G
             7940 M total memory
              459 M used memory
              719 M active memory
              568 M inactive memory
             6328 M free memory
              301 M buffer memory
             1162 M swap cache
             3813 M total swap
                0 M used swap
             3813 M free swap
    *** FAILED SERVICES ***
      UNIT             LOAD   ACTIVE SUB    DESCRIPTION
    * iobroker.service loaded failed failed ioBroker Server
    1 loaded units listed.
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  536K  794M   1% /run
    /dev/sda2      ext4       28G   16G   11G  60% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     785M     0  785M   0% /run/user/1000
    tmpfs          tmpfs     785M     0  785M   0% /run/user/0
    [Tue Oct 31 15:56:09 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
    [Tue Oct 31 15:56:10 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda2 ext4   rw,relatime,errors=remount-ro
    /var:
    2.5G    /var/
    2.0G    /var/log
    1.7G    /var/log/journal/2f4bc42be5da4a1da59ffeb8bb93ce6e
    364M    /var/cache
    Archived and active journals take up 127.0M in the file system.
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.7G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/files
    970M    /opt/iobroker/iobroker-data/files/vis-2-beta
    900M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
    898M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
    31M     /opt/iobroker/iobroker-data/objects.jsonl
    23M     /opt/iobroker/iobroker-data/objects.json.migrated
    23M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
    22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-busware.de_CUL868-if00
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.18.2
    /usr/bin/node           v18.18.2
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    nodejs:
      Installed: 18.18.2-1nodesource1
      Candidate: 18.18.2-1nodesource1
      Version table:
     *** 18.18.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://ftp.de.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    No problems detected
    Errors in npm tree:
    npm ERR! code ELSPROBLEMS
    npm ERR! missing: node-ssh@^13.1.0, required by iobroker.javascript@7.1.6
    npm ERR! A complete log of this run can be found in: /home/iob/.npm/_logs/2023-11-03T11_51_09_483Z-debug-0.log
    *** ioBroker-Installation ***
    ioBroker Status
    iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  5.0.16
    admin:          6.12.2
    javascript:     7.1.6
    Adapters from github:   5
    Adapter State
      system.adapter.admin.1                  : admin                 : iob                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : iob                                      -  enabled
      system.adapter.backitup.0               : backitup              : iob                                      -  enabled
      system.adapter.backitup.1               : backitup              : iob-slave                                -  enabled
      system.adapter.ble.0                    : ble                   : iob-slave                                - disabled
      system.adapter.broadlink2.0             : broadlink2            : iob                                      -  enabled
      system.adapter.deconz.0                 : deconz                : iob                                      -  enabled, port: 80
      system.adapter.device-reminder.0        : device-reminder       : iob                                      -  enabled
      system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iob                                      - disabled
      system.adapter.enigma2.0                : enigma2               : iob                                      -  enabled
      system.adapter.enocean.0                : enocean               : iob-slave                                -  enabled
      system.adapter.feiertage.0              : feiertage             : iob                                      -  enabled
      system.adapter.fullybrowser.0           : fullybrowser          : iob                                      -  enabled
      system.adapter.heatingcontrol.0         : heatingcontrol        : iob                                      -  enabled
      system.adapter.ical.0                   : ical                  : iob                                      -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iob                                      - disabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iob                                      - disabled
      system.adapter.influxdb.0               : influxdb              : iob                                      -  enabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : iob                                      -  enabled, port: 8086
      system.adapter.iot.0                    : iot                   : iob                                      -  enabled
      system.adapter.javascript.0             : javascript            : iob                                      -  enabled
      system.adapter.life360.0                : life360               : iob                                      - disabled
      system.adapter.maxcul.0                 : maxcul                : iob                                      -  enabled
      system.adapter.meater.0                 : meater                : iob                                      - disabled
      system.adapter.mihome-vacuum.0          : mihome-vacuum         : iob                                      -  enabled, port: 54321
      system.adapter.modbus.0                 : modbus                : iob                                      -  enabled
      system.adapter.mqtt.0                   : mqtt                  : iob                                      -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nut.0                    : nut                   : iob                                      -  enabled
      system.adapter.octoprint.0              : octoprint             : iob                                      - disabled
      system.adapter.openweathermap.0         : openweathermap        : iob                                      -  enabled
      system.adapter.parcel.0                 : parcel                : iob                                      - disabled
      system.adapter.pi-hole.0                : pi-hole               : iob                                      -  enabled
      system.adapter.ping.0                   : ping                  : iob                                      -  enabled
      system.adapter.proxmox.0                : proxmox               : iob                                      -  enabled, port: 8006
      system.adapter.pvforecast.0             : pvforecast            : iob                                      - disabled
      system.adapter.renault.0                : renault               : iob                                      -  enabled
      system.adapter.scenes.0                 : scenes                : iob                                      -  enabled
      system.adapter.shelly.0                 : shelly                : iob                                      -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.smartmeter.0             : smartmeter            : iob                                      -  enabled
      system.adapter.snmp.0                   : snmp                  : iob                                      - disabled
      system.adapter.snmp.1                   : snmp                  : iob                                      - disabled
      system.adapter.snmp.2                   : snmp                  : iob                                      - disabled
      system.adapter.socketio.0               : socketio              : iob                                      -  enabled, port: 8084, bind: 192.168.1.201, run as: admin
      system.adapter.sonoff.0                 : sonoff                : iob                                      -  enabled, port: 11883, bind: 0.0.0.0
      system.adapter.sourceanalytix.0         : sourceanalytix        : iob                                      -  enabled
      system.adapter.synology.1               : synology              : iob                                      -  enabled, port: 5000
      system.adapter.synology.2               : synology              : iob                                      -  enabled, port: 5000
      system.adapter.tankerkoenig.0           : tankerkoenig          : iob                                      -  enabled
      system.adapter.telegram.0               : telegram              : iob                                      -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : iob                                      -  enabled
      system.adapter.tr-064.0                 : tr-064                : iob                                      -  enabled
      system.adapter.trashschedule.0          : trashschedule         : iob                                      -  enabled
      system.adapter.unifi.0                  : unifi                 : iob                                      -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iob                                      - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iob                                      - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iob                                      - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iob                                      - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iob                                      - disabled
      system.adapter.vis-material.0           : vis-material          : iob                                      - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iob                                      -  enabled
      system.adapter.vis-metro.0              : vis-metro             : iob                                      - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iob                                      - disabled
      system.adapter.vis.0                    : vis                   : iob                                      -  enabled
      system.adapter.web.0                    : web                   : iob                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iob                                      - disabled
      system.adapter.wiffi-wz.0               : wiffi-wz              : iob                                      -  enabled
      system.adapter.wled.0                   : wled                  : iob-slave                                -  enabled
      system.adapter.zigbee.0                 : zigbee                : iob-slave                                -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e61ee51d512ec11a2f121c7bd930c07-if00-port0
    + instance is alive
    ioBroker-Repositories
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Stable (default): http://download.iobroker.net/sources-dist.json
    Active repo(s): Beta (latest)
    Installed ioBroker-Instances
    Used repository: Beta (latest)
    Adapter    "admin"        : 6.12.2   , installed 6.12.2
    Adapter    "alexa2"       : 3.25.5   , installed 3.25.5
    Adapter    "backitup"     : 2.9.1    , installed 2.9.1
    Adapter    "ble"          : 0.13.4   , installed 0.13.4
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "deconz"       : 1.3.22   , installed 1.3.22
    Adapter    "device-reminder": 3.0.0  , installed 3.0.0
    Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
    Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
    Adapter    "fullybrowser" : 3.0.2    , installed 3.0.2
    Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
    Adapter    "ical"         : 1.13.3   , installed 1.13.3
    Adapter    "iot"          : 2.0.11   , installed 2.0.11
    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
    Controller "js-controller": 5.0.16   , installed 5.0.16
    Adapter    "maxcul"       : 1.3.1    , installed 1.3.1
    Adapter    "meater"       : 1.0.2    , installed 1.0.2
    Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
    Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
    Adapter    "openweathermap": 0.4.5   , installed 0.4.5
    Adapter    "parcel"       : 0.1.6    , installed 0.1.6
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "proxmox"      : 2.2.1    , installed 2.2.1
    Adapter    "pvforecast"   : 2.9.0    , installed 2.9.0
    Adapter    "renault"      : 0.0.21   , installed 0.0.21
    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "snmp"         : 3.1.0    , installed 3.1.0
    Adapter    "socketio"     : 6.6.0    , installed 6.6.0
    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
    Adapter    "synology"     : 3.0.1    , installed 3.0.1
    Adapter    "telegram"     : 2.0.1    , installed 2.0.1
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "trashschedule": 2.3.0    , installed 2.3.0
    Adapter    "unifi"        : 0.6.6    , installed 0.6.6
    Adapter    "vis-justgage" : 2.0.0    , installed 2.0.0
    Adapter    "vis-material" : 0.1.3    , installed 0.1.3
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "web"          : 6.1.10   , installed 6.1.10
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
    Adapter    "ws"           : 2.5.8    , installed 2.5.8
    Objects and States
    Objects:        38316
    States:         42925
    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
    Hit:2 http://ftp.de.debian.org/debian bookworm InRelease
    Hit:3 http://ftp.de.debian.org/debian bookworm-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1527       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16976      474/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          13493      1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          16978      474/sshd: /usr/sbin
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12786      1/init
    udp        0      0 192.168.1.201:123       0.0.0.0:*                           0          16996      483/ntpd
    udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          16994      483/ntpd
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          16990      483/ntpd
    udp6       0      0 :::111                  :::*                                0          12787      1/init
    udp6       0      0 2a00:6020:a5b5:bb56:123 :::*                                109        17080      483/ntpd
    udp6       0      0 fe80::dc29:faff:fe1:123 :::*                                109        17030      483/ntpd
    udp6       0      0 ::1:123                 :::*                                0          16998      483/ntpd
    udp6       0      0 :::123                  :::*                                0          16987      483/ntpd
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:632:26)
        at Socket.emit (node:events:517:28)
        at TCP.<anonymous> (node:net:350:12)
    2023-11-03 12:48:32.634  - error: enigma2.0 (615007) DB closed
    2023-11-03 12:48:32.583  - warn: sonoff.0 (614747) get state error: Connection is closed.
    2023-11-03 12:48:32.613  - warn: sonoff.0 (614747) get state error: Connection is closed.
    2023-11-03 12:48:34.207  - error: host.iob Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]: Error: DB closed
    2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at Object.onceWrapper (node:events:632:26)
    2023-11-03 12:48:34.210  - error: host.iob Caught by controller[0]:     at Socket.emit (node:events:517:28)
    2023-11-03 12:48:34.211  - error: host.iob Caught by controller[0]:     at Socket.emit (node:domain:489:12)
    2023-11-03 12:48:34.211  - error: host.iob Caught by controller[0]:     at TCP.<anonymous> (node:net:350:12)
    2023-11-03 12:48:36.149  - warn: host.iob instance system.adapter.ping.0 terminated due to SIGTERM
    2023-11-03 12:48:36.196  - warn: host.iob instance system.adapter.javascript.0 terminated due to SIGTERM
    2023-11-03 12:48:36.240  - warn: host.iob instance system.adapter.sonoff.0 terminated due to SIGTERM
    2023-11-03 12:48:36.288  - warn: host.iob instance system.adapter.enigma2.0 terminated due to SIGTERM
    2023-11-03 12:48:36.304  - warn: host.iob instance system.adapter.heatingcontrol.0 terminated due to SIGTERM
    2023-11-03 12:48:36.364  - warn: host.iob instance system.adapter.maxcul.0 terminated due to SIGTERM
    2023-11-03 12:48:36.499  - warn: host.iob instance system.adapter.web.0 terminated due to SIGTERM
    2023-11-03 12:48:36.555  - warn: host.iob instance system.adapter.telegram.0 terminated due to SIGTERM
    2023-11-03 12:48:36.659  - warn: host.iob instance system.adapter.synology.2 terminated due to SIGTERM
    2023-11-03 12:48:36.660  - warn: host.iob instance system.adapter.mihome-vacuum.0 terminated due to SIGTERM
    Hier dieSummary:
                            v.2023-10-10
             Chassis: vm 🖴
      Virtualization: kvm
    Installation:           kvm
    Kernel:                 x86_64
    Userland:               amd64
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.18.2
                            /usr/bin/npm            9.8.1
                            /usr/bin/npx            9.8.1
    Recommended versions are nodejs 18.18.2 and npm 9.8.1
    MEMORY:
    Mem:            8.3G        484M        6.6G        548K        1.5G        7.8G
    Swap:           4.0G          0B        4.0G
    Total:           12G        484M         10G
    Active iob-Instances:   1
    ioBroker Core:          js-controller           5.0.16
                            admin                   6.12.2
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Objects:                38316
    States:                 42925
    Size of iob-Database:
    19M     /opt/iobroker/iobroker-data/objects.json.old
    9.9M    /opt/iobroker/iobroker-data/states.jsonl
    7.8M    /opt/iobroker/iobroker-data/states.json.migrated
    7.8M    /opt/iobroker/iobroker-data/states.json.bak.migrated
    2.5M    /opt/iobroker/iobroker-data/states.json.old
    0       /opt/iobroker/iobroker-data/states.json.broken
    Hier das Log aus Zeile 206:
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@9.8.1
    2 info using node@v18.18.2
    3 timing npm:load:whichnode Completed in 2ms
    4 timing config:load:defaults Completed in 3ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
    6 timing config:load:builtin Completed in 2ms
    7 timing config:load:cli Completed in 6ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 3ms
    10 timing config:load:project Completed in 8ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
    12 timing config:load:user Completed in 0ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 0ms
    15 timing config:load:setEnvs Completed in 1ms
    16 timing config:load Completed in 22ms
    17 timing npm:load:configload Completed in 22ms
    18 timing config:load:flatten Completed in 4ms
    19 timing npm:load:mkdirpcache Completed in 1ms
    20 timing npm:load:mkdirplogs Completed in 0ms
    21 verbose title npm x @iobroker/jsonltool@latest /opt/iobroker/iobroker-data
    22 verbose argv "x" "--yes" "@iobroker/jsonltool@latest" "/opt/iobroker/iobroker-data"
    23 timing npm:load:setTitle Completed in 1ms
    24 timing npm:load:display Completed in 1ms
    25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2023-11-03T11_49_31_141Z-
    26 verbose logfile /home/iobroker/.npm/_logs/2023-11-03T11_49_31_141Z-debug-0.log
    27 timing npm:load:logFile Completed in 12ms
    28 timing npm:load:timers Completed in 0ms
    29 timing npm:load:configScope Completed in 1ms
    30 timing npm:load Completed in 66ms
    31 silly logfile start cleaning logs, removing 2 files
    32 timing arborist:ctor Completed in 1ms
    33 silly logfile done cleaning log files
    34 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.admin
    35 http fetch GET 200 https://registry.npmjs.org/@iobroker%2fjsonltool 376ms (cache revalidated)
    36 timing arborist:ctor Completed in 0ms
    37 timing arborist:ctor Completed in 0ms
    38 timing arborist:ctor Completed in 1ms
    39 timing command:x Completed in 6680ms
    40 verbose exit 0
    41 timing npm Completed in 7030ms
    42 info ok
    • G guergen
      EDIT: Zeile 202-204
      Was ist zu tun?
      Skript v.2023-10-10
      *** BASE SYSTEM ***
               Chassis: vm 🖴
        Virtualization: kvm
      Docker          : false
      Kernel          : x86_64
      Userland        : amd64
      CPU threads: 8
                    NTP service: n/a
                RTC in local TZ: no
      iob
      /home/iob
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           4.0G          0B        4.0G
      Total:           12G        481M         10G
               7940 M total memory
                459 M used memory
                719 M active memory
               6328 M free memory
                301 M buffer memory
               1162 M swap cache
               3813 M total swap
                  0 M used swap
               3813 M free swap
      *** FILESYSTEM ***
      /var:
      2.5G    /var/
      2.0G    /var/log
      364M    /var/cache
      USB-Devices by-id:
      /usr/bin/npm            9.8.1
      /usr/bin/npx            9.8.1
      nodejs:
        Version table:
           18.13.0+dfsg1-1 500
      Errors in npm tree:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.12.2
      javascript:     7.1.6
      Adapter State
      + instance is alive
      Objects and States
      Objects:        38316
      States:         42925
      Pending Updates: 0
      Hier dieSummary:
                              v.2023-10-10
               Chassis: vm 🖴
        Virtualization: kvm
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               amd64
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.8.1
                              /usr/bin/npx            9.8.1
      MEMORY:
      Swap:           4.0G          0B        4.0G
      Total:           12G        484M         10G
                              admin                   6.12.2
      Objects type: jsonl
      States  type: jsonl
      Objects:                38316
      States:                 42925
      40 verbose exit 0
      42 info ok
      haselchenH Offline
      haselchenH Offline
      haselchen
      @guergen
      Ich würde ins Blaue tippen und node-ssh im Javascript Adapter eintragen. Siehe unten.
      Und dann den Adapter neu starten, wenn er es nicht schon alleine macht.
      G 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @guergen
        guergen
        @haselchen Steht und stand drin:
        • haselchenH Offline
          haselchenH Offline
          haselchen
          @guergen
          dann schreib doch mal
          node-ssh@13.1.0
          rein
            @guergen
            node-ssh@13.1.0
            rein
            guergen
            @haselchen sagte in NPM ERR! missing node-ssh@^13.1.0, required by iobroker:
            node-ssh@13.1.0
            Habe jetzt mal node-ssh@13.1.0 eingetragen und iob diag nochmal ausgeführt, dann passte es.
            Aus Neugier wieder den alten Eintrag gemacht (ohne die Versionsnummer):
            Passt immer noch...
            Wer weiss was es war ;-)
            Danke!
            • G guergen
              node-ssh@13.1.0
              Passt immer noch...
              Danke!
              haselchenH Offline
              haselchenH Offline
              haselchen
              @guergen
              Gern geschehen 😝
