  4. Iobroker Absturz - Ursache?
    5.1k
56 Beiträge 6 Kommentatoren 5.9k Aufrufe 4 Beobachtet
  • B brokeling
    @thomas-braun said in Iobroker Absturz - Ursache?:
    @brokeling sagte in Iobroker Absturz - Ursache?:
    Ich hatte den aber schon abgenommen...
    Computergrundwissen: Macht man nicht.
    im abgeschalteten modus.
    brokeling
    pi@raspi:~ $  cat /etc/fstab
    proc            /proc           proc    defaults          0       0
    PARTUUID=6c586e13-01  /boot           vfat    defaults,flush    0       2
    PARTUUID=6c586e13-02  /               ext4    defaults,noatime  0       1
    # a swapfile is not a swap partition, no line here
    #   use  dphys-swapfile swap[on|off]  for that
    # PARTUUID=85032a97-01 /backup          ext4    defaults,noatime,nofail 0 2
    PARTUUID=85032a97-01 /backup          ext4    defaults,ro,noatime,nofail 0 2
    • B brokeling
      @brokeling
      mount | sort
        @brokeling
        mount | sort
        brokeling
        mount | sort
        pi@raspi:~ $ mount | sort
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        /dev/sda1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro)
        /dev/sda2 on / type ext4 (rw,noatime,stripe=8191)
        /dev/sdb1 on /backup type ext4 (rw,noatime)
        devtmpfs on /dev type devtmpfs (rw,relatime,size=1773668k,nr_inodes=84274,mode=755)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        none on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        proc on /proc type proc (rw,relatime)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,size=775416k,nr_inodes=819200,mode=755)
        tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=387704k,nr_inodes=96926,mode=700,uid=1000,gid=1000)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        • B brokeling
          mount | sort
          brokeling
          diesen Schritt habe ich noch nicht gemacht:
          sudo mount -o remount /backup
          soll ich?
            @brokeling dann kommst duvaber icht mehr an dein(e) Backup(s) ran
            brokeling
            @homoran said in Iobroker Absturz - Ursache?:
            Eigentlich hoff(t)e ich sie nicht mehr zu brauchen.
            Gleich mit einem neuen USB stick - diesmal nehme ich einen SSD - ein backup machen...
            • B brokeling
              soll ich?
              @brokeling
              Da ist das Ding doch noch:
              mit rw-Option.
              Mach den remount und dann schaust du nochmal mit
              mount | sort
              ob das dann ro drin ist.
                @brokeling
                mit rw-Option.
                mount | sort
                brokeling
                schrieb am zuletzt editiert von brokeling
                /dev/sdb1 on /backup type ext4 (ro,noatime)
                sollte jetzt passen.
                • B brokeling
                  @brokeling
                  Ja, jetzt ist es ro und es kann da nicht mehr schreibend drauf zugegriffen werden. Jetzt kannst du versuchen die Datein dort rauszukratzen und das auf ein drittes, funktionierende Medium zu schreiben.
                  (Am Rande: Deswegen legt man auch nie nur ein Backup an, sondern schiebt das nach Möglichkeit auch physisch noch woanders hin.)
                    @brokeling
                    brokeling
                    ok, vielen Dank. Ich muss aber erst noch einen neuen Datenträger besorgen, dann versuche ich das. Wie man backups automatisiert noch wo anders hin kopiert - das sollten wir noch genauer beleuchten. Aber dann müsste ja noch ein weiterer (3.) USB Datenträger ran...
                    Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                    • B brokeling
                      Der Backitup-Adapter hat doch 'zig' Möglichkeiten dafür. Und mit 'woanders' meinte ich auch wirklich örtlich 'woanders'. Ein Backup auf einem Datenträger in deinem Haus nutzt dir ja nix, wenn die Bude (Gott verhüte) abbrennt.
                      Mein Backup wird z. B. lokal auf ein NAS geschrieben und dann bei GoogleDrive hochgeladen.
                      • B brokeling
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        quatsch, schieb die Sicherung auf ein NAS oder Dropbox, Google Drive, usw.
                        Nutzt Du denn nicht den Backitup Adapter ?
                        Lehrling seit 1975 !!!
                        • DJMarc75D DJMarc75
                          brokeling
                          doch doch, alles gut, den benutze ich ja schon längst 14 Tage rückläufig.
                          Danke für die kleine Gedankenauffrischung.
                          Ich hatte jetzt nur noch den raspibackup im Kopf...
                          • B brokeling
                            brokeling
                            Ich habe raspiBackup auch auf dem iobroker installiert, nachdem ich es bei nextcloud anwende.
                            Aber mit dem iobroker-eigenen Backitup wahrscheinlich gar nicht notwendig!?!
