  4. Iobroker Problem js controller stürtzt ab
55 Beiträge 4 Kommentatoren 8.1k Aufrufe 4 Beobachtet
  • F Fritzk
    @glasfaser
    Hat leider auch nicht geholfen
    ioBroker nodejs fixer 2023-10-03
    Recommended nodejs-version is: 18.18.0
    Checking your installation now. Please be patient!
    Your current setup is:
    /usr/bin/nodejs         v18.18.0
    /usr/bin/node           v18.18.0
    /usr/bin/npm            9.8.1
    /usr/bin/npx            9.8.1
    /usr/bin/corepack       0.19.0
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 18.18.0-1nodesource1
      Candidate: 18.18.0-1nodesource1
      Version table:
     *** 18.18.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0+dfsg1-1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
    Nothing to do - Your installation is using the correct paths.
    Nothing to do - Your version is the recommended one.
    You can now keep your whole system up-to-date using the usual 'sudo apt update && sudo apt full-upgrade' commands.
    Please DO NOT USE node version managers like 'nvm', 'n' and others in parallel. They will break your current installation!
    GlasfaserG Offline
    GlasfaserG Offline
    @fritzk
    curl -fsL https://iobroker.net/fix.sh | bash -
    F 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      @fritzk
      Fritzk
      @glasfaser
      .....hat sich leider auch nix geändert.....werde wahrscheinlich eine Neuinstallation machen müssen....
      proxio@Haupt-IoBroker:/opt/iobroker$ curl -fsL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2023-04-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      [sudo] password for proxio:
      Get:1 http://security.debian.org bookworm-security InRelease [48.0 kB]
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Get:5 http://security.debian.org bookworm-security/main amd64 Packages [78.6 kB]
      Get:6 http://security.debian.org bookworm-security/main Translation-en [45.3 kB]
      Fetched 172 kB in 0s (349 kB/s)
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/5)
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      proxio@Haupt-IoBroker:/opt/iobroker$ iobroker start
      proxio@Haupt-IoBroker:/opt/iobroker$ iobroker status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      • GlasfaserG Offline
        GlasfaserG Offline
        @fritzk
        Gerade noch ein Fragezeichen ...
        denn was ich nicht verstehe ... du schreibst
        Zitat : .... ich nutze den Befehl .... und dann läuft ioBroker
        und du zeigst auch danach
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        • F Fritzk
          @glasfaser
          library: loaded
          Installed gcc-c++
          Done.
          Autostart enabled!
          Objects type: jsonl
          States  type: jsonl
          @fritzk
          systemctl list-unit-files
          Achtung, sind mehrere Seiten.
            @fritzk
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Fritzk
            @glasfaser
            wenn ich das in Putty eingebe
            cd /opt/iobroker
            node node_modules/iobroker.js-controller/controller.js --logs
            dann startet er und läuft ganz normal
            Darf dann aber in putty nix mehr machen. sobald ich die Eingabetaste drücke oder die ssh Verbindung beende, stürtzt er wieder ab.
            Warum weshalb das so ist.....ist mir ein großes Rätsel.
            Das letzte was ich gemacht habe wo er noch in Ordnung war, ich hab mir Material Design Widget installiert für meine Vis und Tag darauf hab ich gemerkt das der Admin nicht mehr erreichbar ist und nixmehr funktioniert...
              @fritzk
              Fritzk
              Okay hier alles komplett
              proxio@Haupt-IoBroker:/opt/iobroker$ systemctl list-unit-files
              UNIT FILE                              STATE           PRESET
              proc-sys-fs-binfmt_misc.automount      static          -
              dev-hugepages.mount                    static          -
              dev-mqueue.mount                       static          -
              proc-fs-nfsd.mount                     static          -
              proc-sys-fs-binfmt_misc.mount          disabled        disabled
              run-rpc_pipefs.mount                   generated       -
              sys-fs-fuse-connections.mount          static          -
              sys-kernel-config.mount                masked          enabled
              sys-kernel-debug.mount                 masked          enabled
              sys-kernel-tracing.mount               static          -
              var-lib-nfs-rpc_pipefs.mount           static          -
              postfix-resolvconf.path                enabled         enabled
              systemd-ask-password-console.path      static          -
              systemd-ask-password-wall.path         static          -
              session-188.scope                      transient       -
              apt-daily-upgrade.service              static          -
              apt-daily.service                      static          -
              auth-rpcgss-module.service             static          -
              autovt@.service                        alias           -
              console-getty.service                  enabled-runtime disabled
              container-getty@.service               indirect        enabled
              cron.service                           enabled         enabled
              cryptdisks-early.service               masked          enabled
              cryptdisks.service                     masked          enabled
              dbus-org.freedesktop.hostname1.service alias           -
              dbus-org.freedesktop.locale1.service   alias           -
              dbus-org.freedesktop.login1.service    alias           -
              dbus-org.freedesktop.timedate1.service alias           -
              dbus-org.freedesktop.timesync1.service alias           -
              dbus.service                           static          -
              debug-shell.service                    disabled        disabled
              dpkg-db-backup.service                 static          -
              e2scrub@.service                       static          -
              e2scrub_all.service                    static          -
              e2scrub_fail@.service                  static          -
              e2scrub_reap.service                   enabled         enabled
              emergency.service                      static          -
              fstrim.service                         static          -
              getty-static.service                   static          -
              getty@.service                         disabled        enabled
              hwclock.service                        masked          enabled
              ifup@.service                          static          -
              ifupdown-pre.service                   static          -
              ifupdown-wait-online.service           enabled         enabled
              initrd-cleanup.service                 static          -
              initrd-parse-etc.service               static          -
              initrd-switch-root.service             static          -
              initrd-udevadm-cleanup-db.service      static          -
              iobroker.service                       enabled         enabled
              kmod-static-nodes.service              static          -
              kmod.service                           alias           -
              logrotate.service                      static          -
              man-db.service                         static          -
              modprobe@.service                      static          -
              networking.service                     enabled         enabled
              nfs-common.service                     masked          enabled
              nfs-idmapd.service                     static          -
              nfs-utils.service                      static          -
              nftables.service                       enabled         enabled
              pam_namespace.service                  static          -
              portmap.service                        alias           -
              postfix-resolvconf.service             enabled         enabled
              postfix.service                        enabled         enabled
              postfix@.service                       indirect        enabled
              procps.service                         alias           -
              quotaon.service                        static          -
              rc-local.service                       static          -
              rc.service                             masked          enabled
              rcS.service                            masked          enabled
              rescue.service                         static          -
              rpc-gssd.service                       static          -
              rpc-statd-notify.service               static          -
              rpc-statd.service                      static          -
              rpc-svcgssd.service                    static          -
              rpcbind.service                        enabled         enabled
              serial-getty@.service                  disabled        enabled
              ssh.service                            enabled         enabled
              sshd.service                           alias           -
              sudo.service                           masked          enabled
              system-update-cleanup.service          static          -
              systemd-ask-password-console.service   static          -
              systemd-ask-password-wall.service      static          -
              systemd-backlight@.service             static          -
              systemd-binfmt.service                 static          -
              systemd-boot-check-no-failures.service disabled        disabled
              systemd-exit.service                   static          -
              systemd-firstboot.service              static          -
              systemd-fsck-root.service              static          -
              systemd-fsck@.service                  static          -
              systemd-fsckd.service                  static          -
              systemd-halt.service                   static          -
              systemd-hibernate-resume@.service      static          -
              systemd-hibernate.service              static          -
              systemd-hostnamed.service              static          -
              systemd-hybrid-sleep.service           static          -
              systemd-initctl.service                static          -
              systemd-journal-flush.service          static          -
              systemd-journald.service               static          -
              systemd-journald@.service              static          -
              systemd-kexec.service                  static          -
              systemd-localed.service                static          -
              systemd-logind.service                 static          -
              systemd-machine-id-commit.service      static          -
              systemd-modules-load.service           static          -
              systemd-network-generator.service      enabled         enabled
              systemd-networkd-wait-online.service   disabled        disabled
              systemd-networkd-wait-online@.service  disabled        enabled
              systemd-networkd.service               disabled        disabled
              systemd-pcrphase-initrd.service        static          -
              systemd-pcrphase-sysinit.service       static          -
              systemd-pcrphase.service               static          -
              systemd-poweroff.service               static          -
              systemd-pstore.service                 enabled         enabled
              systemd-quotacheck.service             static          -
              systemd-random-seed.service            static          -
              systemd-reboot.service                 static          -
              systemd-remount-fs.service             enabled-runtime enabled
              systemd-repart.service                 static          -
              systemd-rfkill.service                 static          -
              systemd-suspend-then-hibernate.service static          -
              systemd-suspend.service                static          -
              systemd-sysctl.service                 static          -
              systemd-sysext.service                 enabled         enabled
              systemd-sysusers.service               static          -
              systemd-time-wait-sync.service         disabled        disabled
              systemd-timedated.service              static          -
              systemd-timesyncd.service              enabled         enabled
              systemd-tmpfiles-clean.service         static          -
              systemd-tmpfiles-setup-dev.service     static          -
              systemd-tmpfiles-setup.service         static          -
              systemd-udev-settle.service            static          -
              systemd-udev-trigger.service           static          -
              systemd-udevd.service                  static          -
              systemd-update-utmp-runlevel.service   static          -
              systemd-update-utmp.service            static          -
              systemd-user-sessions.service          static          -
              systemd-volatile-root.service          static          -
              udev.service                           alias           -
              urandom.service                        generated       -
              user-runtime-dir@.service              static          -
              user@.service                          static          -
              x11-common.service                     masked          enabled
              machine.slice                          static          -
              system-systemd\x2dcryptsetup.slice     static          -
              user.slice                             static          -
              dbus.socket                            static          -
              rpcbind.socket                         enabled         enabled
              ssh.socket                             enabled         enabled
              syslog.socket                          static          -
              systemd-fsckd.socket                   static          -
              systemd-initctl.socket                 static          -
              systemd-journald-audit.socket          masked          enabled
              systemd-journald-dev-log.socket        static          -
              systemd-journald-varlink@.socket       static          -
              systemd-journald.socket                static          -
              systemd-journald@.socket               static          -
              systemd-networkd.socket                enabled         enabled
              systemd-rfkill.socket                  static          -
              systemd-udevd-control.socket           static          -
              systemd-udevd-kernel.socket            static          -
              basic.target                           static          -
              blockdev@.target                       static          -
              bluetooth.target                       static          -
              boot-complete.target                   static          -
              cryptsetup-pre.target                  static          -
              cryptsetup.target                      static          -
              ctrl-alt-del.target                    alias           -
              default.target                         alias           -
              emergency.target                       static          -
              exit.target                            disabled        disabled
              factory-reset.target                   static          -
              final.target                           static          -
              first-boot-complete.target             static          -
              getty-pre.target                       static          -
              getty.target                           static          -
              graphical.target                       static          -
              halt.target                            disabled        disabled
              hibernate.target                       static          -
              hybrid-sleep.target                    static          -
              initrd-fs.target                       static          -
              initrd-root-device.target              static          -
              initrd-root-fs.target                  static          -
              initrd-switch-root.target              static          -
              initrd-usr-fs.target                   static          -
              initrd.target                          static          -
              integritysetup-pre.target              static          -
              integritysetup.target                  static          -
              kexec.target                           disabled        disabled
              local-fs-pre.target                    static          -
              local-fs.target                        static          -
              multi-user.target                      static          -
              network-online.target                  static          -
              network-pre.target                     static          -
              network.target                         static          -
              nfs-client.target                      enabled         enabled
              nss-lookup.target                      static          -
              nss-user-lookup.target                 static          -
              paths.target                           static          -
              poweroff.target                        disabled        disabled
              printer.target                         static          -
              reboot.target                          enabled         enabled
              remote-cryptsetup.target               enabled         enabled
              remote-fs-pre.target                   static          -
              remote-fs.target                       enabled         enabled
              remote-veritysetup.target              enabled         enabled
              rescue-ssh.target                      static          -
              rescue.target                          static          -
              rpc_pipefs.target                      generated       -
              rpcbind.target                         static          -
              runlevel0.target                       alias           -
              runlevel1.target                       alias           -
              runlevel2.target                       alias           -
              runlevel3.target                       alias           -
              runlevel4.target                       alias           -
              runlevel5.target                       alias           -
              runlevel6.target                       alias           -
              shutdown.target                        static          -
              sigpwr.target                          static          -
              slices.target                          static          -
              smartcard.target                       static          -
              sockets.target                         static          -
              sound.target                           static          -
              suspend-then-hibernate.target          static          -
              suspend.target                         static          -
              swap.target                            static          -
              sysinit.target                         static          -
              system-update-pre.target               static          -
              system-update.target                   static          -
              time-set.target                        static          -
              time-sync.target                       static          -
              timers.target                          static          -
              umount.target                          static          -
              usb-gadget.target                      static          -
              veritysetup-pre.target                 static          -
              veritysetup.target                     static          -
              apt-daily-upgrade.timer                enabled         enabled
              apt-daily.timer                        enabled         enabled
              dpkg-db-backup.timer                   enabled         enabled
              e2scrub_all.timer                      enabled         enabled
              fstrim.timer                           enabled         enabled
              logrotate.timer                        enabled         enabled
              man-db.timer                           enabled         enabled
              systemd-tmpfiles-clean.timer           static          -
              244 unit files listed.
              • F Fritzk
                @glasfaser
                cd /opt/iobroker
                @fritzk sagte in Iobroker Problem js controller stürtzt ab:
                Das ist so, weil der Prozess abgebrochen wird, wenn der entsprechende user sich ausloggt.
                Deswegen wird sowas auch "anders" gestartet, mittlerweile per systemd. Das ist aber bei dir 'kaputt'.
                • F Fritzk
                  user.slice                             static          -
                  @fritzk
                  systemctl list-units --failed --no-pager
                    @fritzk
                    Fritzk
                    proxio@Haupt-IoBroker:/opt/iobroker$ systemctl list-units --failed --no-pager
                      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                    * networking.service   loaded failed failed Raise network interfaces
                    2 loaded units listed.
                    • F Fritzk
                      networking
                      Starte das mal neu
                      sudo systemctl restart networking.service
                        networking
                        Starte das mal neu
                        Fritzk
                        proxio@Haupt-IoBroker:/opt/iobroker$ sudo systemctl restart networking.service
                        Job for networking.service failed because the control process exited with error code.
                        See "systemctl status networking.service" and "journalctl -xeu networking.service" for details.
                        • F Fritzk
                            Fritzk
                            proxio@Haupt-IoBroker:/opt/iobroker$ systemctl status networking.service
                            x networking.service - Raise network interfaces
                                 Loaded: loaded (/lib/systemd/system/networking.service; enabled; preset: enabled)
                                 Active: failed (Result: exit-code) since Fri 2023-10-06 21:58:16 CEST; 3min 40s ago
                                   Docs: man:interfaces(5)
                                Process: 5671 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
                                Process: 5698 ExecStopPost=/usr/bin/touch /run/network/restart-hotplug (code=exited, status=0/SUCCESS)
                               Main PID: 5671 (code=exited, status=1/FAILURE)
                                    CPU: 46ms
                            • F Fritzk
                                      CPU: 46ms
                              @fritzk
                              Meiner Meinung nach sollte der Service laufen. Aber mit Proxmox kenn ich mich nicht aus.
                              Verabschiede mich dann aus dem Thread.
                                @fritzk
                                Fritzk
                                Okay ich danke dir für deine Hilfe. Werde jetzt dann auch mal aufgeben. Ich probier morgen mal eine komplette Neuinstallation. vielleicht och ohne Proxmox
                                • O Offline
                                  O Offline
                                  oxident
                                  schrieb am zuletzt editiert von oxident
                                  Möchte mich hier auch mal reinhängen. Prinzipiell läuft meine Installation als Proxmox-Container stressfrei, jedoch wird auch bei mir minütlich (!) das syslog mit folgender Meldung geflutet:
                                  Nov 15 17:49:01 iobroker bash[768020]: URIError: URI malformed
                                  Nov 15 17:49:01 iobroker bash[768020]:     at decodeURI (<anonymous>)
                                  Nov 15 17:49:01 iobroker bash[768020]:     at /opt/iobroker/node_modules/iobroker.web/main.js:1637:31
                                  Nov 15 17:49:01 iobroker bash[768020]:     at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                                  Nov 15 17:49:01 iobroker bash[768020]:     at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
                                  Nov 15 17:49:01 iobroker bash[768020]:     at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
                                  Nov 15 17:49:01 iobroker bash[768020]:     at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                                  Nov 15 17:49:01 iobroker bash[768020]:     at next (/opt/iobroker/node_modules/express/lib/router/index.js:280:10)
                                  Nov 15 17:49:01 iobroker bash[768020]:     at getSocketIoFile (/opt/iobroker/node_modules/iobroker.web/main.js:1010:9)
                                  Nov 15 17:49:01 iobroker bash[768020]:     at /opt/iobroker/node_modules/iobroker.web/main.js:1154:44
                                  Im ioBroker sind aber keinerlei Fehlermeldungen zu finden. Wenn ich das richtig interpretiere, dann versucht der Web-Adapter eine URL aufzurufen?
