  3. Einsteigerfragen
  4. Webinterface nicht mehr aufrufbar
    5.5k
16 Beiträge 3 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • G GiB64
    leider ist auf einmal mein Webinterface nicht mehr aufrufbar. Der Vis Editor geht noch. Ich habe dann mal iobroker fix probiert und da kamen ein paar Fehler. Dann angeblich alles erfolgreich gefixt aber auf die Oberfläche komme ich immer noch nicht.
    pi@raspberry64:~ $ iobroker stop
    pi@raspberry64:~ $ iobroker fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2023-04-02
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
    Get:4 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
    Get:5 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
    Get:6 https://apt.grafana.com stable InRelease [5,983 B]
    Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
    Err:4 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Err:6 https://apt.grafana.com stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    Fetched 60.0 kB in 2s (37.0 kB/s)
    Reading package lists... Done
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://apt.grafana.com stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://apt.grafana.com/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/5)
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (5/5)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberry64:~ $ iobroker start
    pi@raspberry64:~ $
    War im Beta Kanal mit Vis 2 im gange und hatte zuletzt alle Updates durchlaufen lassen. Jemand eine Idee?
    pi@raspberry64:~ $ iobroker list instances
      system.adapter.adb.0                    : adb                   : raspberry64                              - disabled
      system.adapter.admin.0                  : admin                 : raspberry64                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : raspberry64                              -  enabled
    + system.adapter.backitup.0               : backitup              : raspberry64                              -  enabled
    + system.adapter.ble.0                    : ble                   : raspberry64                              -  enabled
      system.adapter.cameras.0                : cameras               : raspberry64                              - disabled, port: 8200, bind: 127.0.0.1
    + system.adapter.chromecast.0             : chromecast            : raspberry64                              -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : raspberry64                              -  enabled
      system.adapter.device-watcher.0         : device-watcher        : raspberry64                              - disabled
    + system.adapter.discovery.0              : discovery             : raspberry64                              -  enabled
    + system.adapter.echarts.0                : echarts               : raspberry64                              -  enabled
    + system.adapter.email.0                  : email                 : raspberry64                              -  enabled
      system.adapter.feiertage.0              : feiertage             : raspberry64                              -  enabled
      system.adapter.firetv.0                 : firetv                : raspberry64                              - disabled
      system.adapter.flot.0                   : flot                  : raspberry64                              - disabled
    + system.adapter.hiob.0                   : hiob                  : raspberry64                              -  enabled
    + system.adapter.history.0                : history               : raspberry64                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberry64                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberry64                              -  enabled, port: 12001
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberry64                              -  enabled, port: 12010
    + system.adapter.hue-extended.0           : hue-extended          : raspberry64                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberry64                              -  enabled, port: 443
    + system.adapter.hue.1                    : hue                   : raspberry64                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberry64                              - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : raspberry64                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberry64                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberry64                              - disabled
    + system.adapter.influxdb.0               : influxdb              : raspberry64                              -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : raspberry64                              -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberry64                              -  enabled
      system.adapter.openweathermap.0         : openweathermap        : raspberry64                              -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : raspberry64                              -  enabled
    + system.adapter.ping.0                   : ping                  : raspberry64                              -  enabled
    + system.adapter.radar2.0                 : radar2                : raspberry64                              -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberry64                              -  enabled
      system.adapter.schoolfree.0             : schoolfree            : raspberry64                              -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : raspberry64                              -  enabled
    + system.adapter.smartmeter.0             : smartmeter            : raspberry64                              -  enabled
    + system.adapter.smartthings.0            : smartthings           : raspberry64                              -  enabled
    + system.adapter.socketio.0               : socketio              : raspberry64                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberry64                              -  enabled
    + system.adapter.synology.0               : synology              : raspberry64                              -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberry64                              -  enabled
    + system.adapter.telegram.0               : telegram              : raspberry64                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : raspberry64                              -  enabled
    + system.adapter.vis-2-beta.0             : vis-2-beta            : raspberry64                              -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberry64                              -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberry64                              -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberry64                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberry64                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberry64                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberry64                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberry64                              - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberry64                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberry64                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberry64                              -  enabled
      system.adapter.vis-map.0                : vis-map               : raspberry64                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberry64                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberry64                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberry64                              -  enabled
    + system.adapter.web.0                    : web                   : raspberry64                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : raspberry64                              -  enabled
      system.adapter.ws.0                     : ws                    : raspberry64                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + instance is alive
    pi@raspberry64:~ $
    @gib64
    iob start admin
    Und System auf Stand halten, das sind die Repos für grafana und influxdb nicht gepflegt.
    • G Offline
      GiB64
      @thomas-braun Danke aber ganz blöde Frage, wie mache ich das? Hatte gedacht das es mit
      sudo apt update && sudo apt upgrade
      erledigt ist aber leider nicht. Auch die Hilfe bei Influx hat mir nicht wirklich weiter geholfen...
      • G GiB64
        @gib64
        Aus dem August:
        https://forum.iobroker.net/topic/67822/grafana-repo-braucht-neuen-schlüssel
        Aus dem Januar:
        https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
        Solange hängt das also schon schief bei dir...
        G 1 Antwort Letzte Antwort
          @gib64
          Aus dem August:
          Aus dem Januar:
          GiB64
          @thomas-braun Mag sein, mir fehlt noch ein wenig der Überblich als Windowsuser... Ich hatte es so wie von Dir beschrieben gemacht und
          apt-key list | grep -i grafana | wc -l
          ergab die gewünschte 0:
          pi@raspberry64:~ $ apt-key list | grep -i grafana | wc -l
          Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
          pi@raspberry64:~ $ sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
          pi@raspberry64:~ $ echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
          pi@raspberry64:~ $ sudo apt update
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
          Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
          Get:5 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
          Err:5 https://repos.influxdata.com/debian bullseye InRelease
          Get:8 https://apt.grafana.com stable/main arm64 Packages [112 kB]
          Get:9 https://apt.grafana.com stable/main armhf Packages [96.5 kB]
          Fetched 220 kB in 2s (113 kB/s)
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          da das update dann immer noch Fehler zeigte wollte ich dann den Key löschen und neu anlegen. Leider habe ich dann den falschen gelöscht.
          Wie kann ich diesen denn wieder herstellen oder ist der nicht wichtig?: 😰
          /etc/apt/trusted.gpg.d/raspberrypi-archive-stable.gpg
          pub   rsa2048 2012-06-17 [SC]
                CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
          uid           [ unknown] Raspberry Pi Archive Signing Key
          sub   rsa2048 2012-06-17 [E]
          • G GiB64
            @gib64
            sagt?
            €dit: Grafana ist doch okay nun. Da ist aber noch die zweite Baustelle bei influxdb. Dazu steht im Thread aus dem Januar aber was drin.
              @gib64
              sagt?
              GiB64
              @thomas-braun Der ausversehen gelöscht Raspberrypi-Key scheint doch wichtig zu sein. Nachdem ich den Influx Key erneuert habe kommt:
              Hit:6 http://archive.raspberrypi.org/debian bullseye InRelease
              Err:6 http://archive.raspberrypi.org/debian bullseye InRelease
                The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
              Fetched 11.6 kB in 1s (7,993 B/s)
              All packages are up to date.
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.org/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
              W: Failed to fetch http://archive.raspberrypi.org/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 82B129927FA3303E
              • G GiB64
                @gib64 sagte in Webinterface nicht mehr aufrufbar:
                82B129927FA3303E
                wget http://archive.raspberrypi.org/debian/raspberrypi.gpg.key
                sudo apt-key add raspberrypi.gpg.key
                rm raspberrypi.gpg.key
                  82B129927FA3303E
                  GiB64
                  schrieb am zuletzt editiert von GiB64
                  @thomas-braun Danke lief fehlerfrei durch aber ich bekomme immer noch Influx angemeckert obwohl ich den Key erneuert hatte:
                  Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                  Hit:4 http://security.debian.org/debian-security bullseye-security InRelease
                  Get:6 https://repos.influxdata.com/debian bullseye InRelease [7,040 B]
                  Err:6 https://repos.influxdata.com/debian bullseye InRelease
                  Fetched 11.6 kB in 2s (7,264 B/s)
                  pi@raspberry64:~ $
                  Edit: kann es sein das beim Import was schief gelaufen ist?:
                  /etc/apt/trusted.gpg.d/debian-archive-bookworm-automatic.gpg
                  pub   rsa4096 2023-01-21 [SC] [expires: 2031-01-19]
                        B8B8 0B5B 623E AB6A D877  5C45 B7C5 D7D6 3509 47F8
                  uid           [ unknown] Debian Archive Automatic Signing Key (12/bookworm) <ftpmaster@debian.org>
                  sub   rsa4096 2023-01-21 [S] [expires: 2031-01-19]
                  /etc/apt/trusted.gpg.d/debian-archive-bookworm-security-automatic.gpg
                        05AB 9034 0C0C 5E79 7F44  A8C8 254C F3B5 AEC0 A8F0
                  uid           [ unknown] Debian Security Archive Automatic Signing Key (12/bookworm) <ftpmaster@debian.org>
                  /etc/apt/trusted.gpg.d/debian-archive-bookworm-stable.gpg
                  pub   ed25519 2023-01-23 [SC] [expires: 2031-01-21]
                        4D64 FEC1 19C2 0290 67D6  E791 F8D2 585B 8783 D481
                  uid           [ unknown] Debian Stable Release Key (12/bookworm) <debian-release@lists.debian.org>
                  /etc/apt/trusted.gpg.d/debian-archive-bullseye-automatic.gpg
                  pub   rsa4096 2021-01-17 [SC] [expires: 2029-01-15]
                        1F89 983E 0081 FDE0 18F3  CC96 73A4 F27B 8DD4 7936
                  uid           [ unknown] Debian Archive Automatic Signing Key (11/bullseye) <ftpmaster@debian.org>
                  sub   rsa4096 2021-01-17 [S] [expires: 2029-01-15]
                  /etc/apt/trusted.gpg.d/debian-archive-bullseye-security-automatic.gpg
                        AC53 0D52 0F2F 3269 F5E9  8313 A484 4904 4AAD 5C5D
                  uid           [ unknown] Debian Security Archive Automatic Signing Key (11/bullseye) <ftpmaster@debian.org>
                  /etc/apt/trusted.gpg.d/debian-archive-bullseye-stable.gpg
                  pub   rsa4096 2021-02-13 [SC] [expires: 2029-02-11]
                        A428 5295 FC7B 1A81 6000  62A9 605C 66F0 0D6C 9793
                  uid           [ unknown] Debian Stable Release Key (11/bullseye) <debian-release@lists.debian.org>
                  /etc/apt/trusted.gpg.d/debian-archive-buster-automatic.gpg
                  pub   rsa4096 2019-04-14 [SC] [expires: 2027-04-12]
                        80D1 5823 B7FD 1561 F9F7  BCDD DC30 D7C2 3CBB ABEE
                  uid           [ unknown] Debian Archive Automatic Signing Key (10/buster) <ftpmaster@debian.org>
                  sub   rsa4096 2019-04-14 [S] [expires: 2027-04-12]
                  /etc/apt/trusted.gpg.d/debian-archive-buster-security-automatic.gpg
                        5E61 B217 265D A980 7A23  C5FF 4DFA B270 CAA9 6DFA
                  uid           [ unknown] Debian Security Archive Automatic Signing Key (10/buster) <ftpmaster@debian.org>
                  /etc/apt/trusted.gpg.d/debian-archive-buster-stable.gpg
                  pub   rsa4096 2019-02-05 [SC] [expires: 2027-02-03]
                        6D33 866E DD8F FA41 C014  3AED DCC9 EFBF 77E1 1517
                  uid           [ unknown] Debian Stable Release Key (10/buster) <debian-release@lists.debian.org>
                  pi@raspberry64:~ $
                  • G GiB64
                    pi@raspberry64:~ $
                    pi@raspberry64:~ $
                    Nein, die Pakete sind mehrfach signiert.
                    Zu influx:
                    ls -lAh /etc/apt/sources.list.d/
                    sagt? Ich vermute da liegen zwei Dateien mit Bezug zu influx drin.
                      Zu influx:
                      GiB64
                      @thomas-braun said in Webinterface nicht mehr aufrufbar:
                      pi@raspberry64:~ $ ls -lAh /etc/apt/sources.list.d/
                      total 12K
                      -rw-r--r-- 1 root root   0 Oct  5 15:19 grafana.list
                      -rw-r--r-- 1 root root 101 Oct  5 15:27 influxdb.list
                      -rw-r--r-- 1 root root 208 Dec  1  2022 nodesource.list
                      -rw-r--r-- 1 root root 191 Sep 22  2022 raspi.list
                      pi@raspberry64:~ $
                      • G GiB64
                        total 12K
                        pi@raspberry64:~ $
                        @gib64
                        sudo rm /etc/apt/sources.list.d/influxdb.list
                        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
                        echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                        rm influxdata-archive_compat.key
                        Dann nochmal
                        sudo apt update
                        • G Offline
                          GiB64
                          @thomas-braun Vielen Dank! Jetzt ist alles auf Stand ohne Fehler. Aber mal ehrlich, wie hätte ich da als Windows User drauf kommen sollen?
                          • G GiB64
                            Lesen bildet. Linux und Debian ist sehr gut dokumentiert.
