  4. Der "ultimative" ioBroker Lovelace Leitfaden/Dokumentation
lovelacedokumentationleitfadenhilfeanleitung
194 Beiträge 30 Kommentatoren 68.2k Aufrufe 37 Beobachtet
  • GarfonsoG Garfonso
    @chrisham
    hm.. nicht so richtig... gab es Fehlermeldungen in der Browser-Konsole? Ist das entity ein accuweather-Wetter-Entity?
    Chrisham
    @garfonso Danke für die Rückmeldung. Ja, genau es ist die accuweather-card:
    https://github.com/algar42/IoB.lovelace.accuweather-card#entity-settings
    Und tatsächlich, da kommen Fehlermeldungen in der Browser-Console:
    vertical-stack-in-cardVersion: 0.4.4
    slider-entity-row.js:82 SLIDER-ENTITY-ROW 17.3.0 IS INSTALLED
    card-mod.js:5 CARD-MOD 3.2.2 IS INSTALLED
    card-mod.js:5 You may not be getting optimal performance out of card-mod.
    See https://github.com/thomasloven/lovelace-card-mod#performance-improvements
    browser_mod.js:373 BROWSER_MOD 2.1.3 IS INSTALLED BrowserID: da00c8a3-9f0a8b54
    2259387565.js:1 Unable to find icon for domain weather
    m @ 59387565.js:1
    ha-icon-button-arrow-next.ts:8 Uncaught TypeError: Cannot read properties of undefined (reading 'url_path')
    at Object.callback (ha-icon-button-arrow-next.ts:8:1)
    at core.e11368e8.js:1:7301
    at Array.forEach (<anonymous>)
    at WebSocket.handleMessage (core.e11368e8.js:1:7225)
    accuweather-card.js:107 undefined
    accuweather-card.js:109 Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'attributes')
    at WeatherCard.render (accuweather-card.js:109:43)
    at WeatherCard.update (styles.ts:371:1)
    at WeatherCard.performUpdate (styles.ts:371:1)
    at WeatherCard.scheduleUpdate (styles.ts:371:1)
    at WeatherCard.
    $EC (styles.ts:371:1)
    default_view?edit=1:1 Autofocus processing was blocked because a document already has a focused element.
    at WeatherCard._$EC (styles.ts:371:1)
    accuweather-card.js:107 Objectattributes: {friendly_name: 'Tamm [Tamm;Deutschland]', forecast: Array(7), temperature: 26, state_desc: 'Während der ersten Hälfte des Tages Sonne tendenziell in der zweiten Hälfte des Tages Bedeckt'}context: {id: 'daswetter.0.NextDays.Location_1', type: 'weather', room: 'any', func: 'Wetter', ids: Array(23), …}entity_id: "weather.Tamm_Tamm_Deutschland
    "last_changed: "2023-10-01T09:30:06.539Z"last_updated: "2023-10-03T21:45:06.471Z"state: "/adapter/daswetter/icons/tiempo-weather/galeria1/5.png"[[Prototype]]: Object
    manifest.json:1 Manifest: Line: 1, column: 1, Syntax error.
    Kannst du damit was anfangen?
      @chrisham
      Chrisham
      @garfonso Achso, sorry, hatte deine Frage nicht richtig gelesen: deine Frage war, ob die Entity eine spezielle accuweather-Entity ist (also nicht: ob es sich um die accuweather-card handelt).
      Hmm, das kann ich nicht sagen bzw. war mir nicht bewusst, dass ich da eine spezifische accuweather entity anlegen muss oder wie würde ich überhaupt eine spezielle accu-weather entity erzeugen...?
        @centurytt-0 said in Der "ultimative" ioBroker Lovelace Leitfaden/Dokumentation:
        @garfonso said in Der "ultimative" ioBroker Lovelace Leitfaden/Dokumentation:
        level.mode.airconditioner
        Hi und danke für deine Rückmeldung (entschuldige bitte meine späte Rückmeldung). Also der Smartthings Adapter legt jeden verfügbaren DP der Klimaanlage wie folgt an JSON anbei:
        smartthings.json
        Urgs.. was ein Chaos... ich empfehle stark mit dem Geräte-Tab ein Alias Gerät anzulegen. :-)
        Dabei sind unter "capabilities" die steuerbaren DP, dh alle Werte die ich dort setze werden an die Klima übertragen. Das mit dem ModeState hab ich nicht ganz verstanden. Ich hab zum Beispiel beim DP "thermostatCoolingSetpoint-setCoolingSetpoint" die Rolle "level.temperature" vergeben, da das ja die Soll Temp ist. Aber welche Rollen ich sonst vergeben soll schnall ich nicht ... :-) sorry.
        Ja, das klingt doch schon gut.
        Das da wird vermutlich der andere State sein, den du zwingend brauchst: smartthings.0.0b0d9dd1-e50b-91c0-0fb1-81c2180be92e.capabilities.airConditionerMode-setAirConditionerMode
        Kommt da wirklich ein String rein? Welches Strings können denn da rein? Oder kommen da Zahlen rein? Das wäre jedenfalls der Kandidat für level.mode.airconditioner. Vielleicht musst du den noch mit der Konverterfunktion im alias umrechnen... da kann ich gerne bei helfen, muss halt wissen, was da am Ende rein muss.
        Fan-Mode gibt es auch, das müsste ein airConditioner Gerät auch unterstützen, dafür gilt aber ähnliches, wie für den mode an sich.
        Centurytt 0C Offline
        Centurytt 0
        #66
        @garfonso
        ja Smartthings ist Chaos. Bei den steuerbaren DP sind es vorwiegend strings. Welche Werte man dort verwenden kann, ist unter -> "Status" zu sehen. Dort gibts dann die Folder-> supported...AC Mode z.B. Darunter findet man die Einstellungen die als string in die DP geschrieben werden können. Ich lege jetzt mal die Capabilities als Alias an und dann melde ich mich wieder.
          smartthings.json
          Centurytt 0
          #67
          @garfonso sagte in Der "ultimative" ioBroker Lovelace Leitfaden/Dokumentation:
          So, jetzt habe ich das ganze als Alias angelegt was prinzipiell ja klappt. Die Domain CLIMATE wird dann auch automatisch erzeugt. Wenn ich aber nun die Mini Climate Card oder aber die Thermostat Karte verwende, habe ich out of the Box nur "Heizen" oder "Aus" zur Verfügung. Die "Soll Temp" kann ich auch noch umstellen. Raumtemp wird auch angezeigt wie ich das sehe. Hier mal das Json der Alias mit den Rollen die ich zugewiesen habe:
          alias.0.Klimaanlage_Christian.json
          Danke derweil...
          • GarfonsoG Offline
            GarfonsoG Offline
            Garfonso
            #68
            @chrisham
            Fragen wir anders: Wie hast du denn das weather entity erzeugt?
            Die Fehlermeldung deutet irgendwie darauf hin, dass da was nicht passt... oder es gibt einen Bug in der Karte.
            Danke derweil...
            Wird das denn im Geräte-Adapter als Klimaanlage erkannt oder als Thermostat? Die states sehen nicht danach aus, dass du smartthings.0.0b0d9dd1-e50b-91c0-0fb1-81c2180be92e.capabilities.airConditionerMode-setAirConditionerMode bei MODE eingetragen hast beim Erstellen, sondern als zusätzlichen Zustand hinzugefügt hast, kann das sein? → der muss aber in Mode. Und dann braucht der "Zustände" und du musst die Strings in die Zustände / Nummern umwandeln in den Konverterfunktionen.
            Per Default unterstützt ioBroker diese Zustände: {0: 'OFF', 1: 'AUTO', 2: 'COOL', 3: 'HEAT', 4: 'ECO', 5: 'FAN_ONLY', 6: 'DRY'}. Das kann der Lovelace Adapter dann auch an Lovelace weiterreichen (und günstigerweise passen die ganz gut zu dem was Lovelace auch kann). :-)
            Wenn da ein String am Ende im State landen muss als Befehl bzw. beim Lesen ein String herauskommt (wenn es einen zweiten State gibt, in dem der Status steht, kannst du den im Geräte Adapter für MODE auch angeben → dann wird der Status in Lovelace auch aktualisiert, wenn du woanders schaltest, falls das bei der capability nicht passiert) musst du halt mit der Konverterfunktion arbeiten (fx steht da). Zum Schreiben musst du von Zahl auf String kommen → ich würde da die Strings als Array angeben und mit der Zahl darauf zugreifen, z.B. ['auto', 'cool', 'dry', 'heat', 'wind'][val] (die Strings halt anpassen, ich habe das aus deiner Ausführung versucht zu übernehmen, und die Reihenfolge ist aber dann wichtig und müssen mit den Zahlen der Zustände zusammen passen, die solltest du mit "Zustände anpassen" auch so machen, dass da die Befehle drinnen stehen, die du benötigst, wobei da der Name der States für den Lovelace Adapter schon passen muss → wenn "wind" nur der Ventilator ist, den da besser FAN_ONLY nennen usw.).
            Wenn du auch den Status lesen willst, wäre da der Konverter so ca.: ['auto', 'cool', 'dry', 'heat', 'wind'].indexOf(val) → damit wird von String nach Nummer konvertiert. Wobei hier dann Groß-/Kleinschreibung noch relevant ist.
            Ich hoffe, es ist halbwegs klar, was ich meine. :-)
            Erst mit dem MODE State weiß der Lovelace Adapter, wie die Klimaanlage gesteuert wird und nur mit deren common.states ("Zustände" im Geräte-Tab) weiß er, welche Funktionen die Klimaanlage unterstützt.
            Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
            Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
            Centurytt 0C C 2 Antworten Letzte Antwort
              @chrisham
              Danke derweil...
              Centurytt 0
              #69
              @garfonso wird als Thermostat erkannt
              so sieht das aus. Ich erstelle den Alias mit der automatik Funktion. Mache ich da was falsch ?
              GarfonsoG 1 Antwort Letzte Antwort
              • Centurytt 0C Centurytt 0
                GarfonsoG Offline
                GarfonsoG Offline
                Garfonso
                #70
                Ja, weil Mode nicht ausgefüllt ist. :-)
                Was zur Hölle ist die "Automatik Funktion". Kenne ich ehrlich gesagt nicht. ;-)
                Aber im Grunde ändert das alles nichts an meinen Ausführungen oben, auf dem Screenshot siehst du auch MODE, relativ weit unten. Da muss die ID rein, mit der du den Betriebsmodus der Klimaanlage steuerst und ioBroker möchte da Zahlen reinschreiben, weshalb du die Zahlen zu Strings konvertieren musst. :-/
                Centurytt 0C 1 Antwort Letzte Antwort
                  @chrisham
                  Danke derweil...
                  Chrisham
                  #71
                  @garfonso Die Entity habe ich automatisch erzeugen lassen:
                  -> basierend auf DasWetter Adapter
                  -> in Objekte-Liste auf oberster Ebene (bei Location_1) Rolle, Raum und Funktion angegeben
                  -> dann hat Geräte-Adapter die Entität erzeugt
                  Ich habe jetzt mal noch getestet über anderen Wetter-Service (openweathermap) eine andere Entität zu erzeugen:
                  1.) Beobachtung: obwohl ich die gleiche custom-Card (eben accuweather) verwende ist nun bei dieser aus anderem Wetter-Service erzeugten Entität auch die Darstellung anders, d.h. andere Icons
                  2.) Beobachtung: nach wie vor scheinen nicht die Icons wie in der Beispiel-Darstellung von accuweather-Card verwendet werden.
                  Anbei screenshot mit 3 Kombinationen:
                  a) Entität: DasWetter, Card: Standard-Wetter-Karte von lovelace
                  b) Entität: DasWetter, Card: accuweather
                  c) Entität: openweathermap, Card: accuweather
                  Alles nicht so ganz verständlich für mich.
                  C GarfonsoG 2 Antworten Letzte Antwort
                  • C Chrisham
                    Chrisham
                    #72
                    @chrisham @Garfonso . Noch ne weitere Beobachtung:
                    Irgendwie scheint der Geräteadapter nicht alle Objekte in das erzeugte Gerät/Entität zu übernehmen:
                    So ist Sonnenuntergang, -aufgang als Objekt zwar vorhanden in der Objekteliste, allerdings nicht in der Zuständeliste des erzeugten Geräts. Demzufolge zeigt die Karte dann auch "invalid" an.
                      Centurytt 0
                      #73
                      @garfonso wie konvertieren ich das ? Gibt's da eine Anleitung?
                      • C Chrisham
                        GarfonsoG Offline
                        GarfonsoG Offline
                        Garfonso
                        schrieb am zuletzt editiert von Garfonso
                        #74
                        @chrisham
                        Ich glaube das liegt tatsächlich daran, dass das Wetter nicht vom accuweather Adapter kommt. Versuch das mal.
                        Hintergrund: für den ioBroker ist der wichtigste State tatsächlich die URL auf das Icon für das Wetter (ICON). Eine textliche Beschreibung für das Wetter ist nur optional und schon gar nicht standardisiert.
                        In Homeassistant ist das aber anders, da wird als wichtigstes Element eine Beschreibung des Wetters in einem Wort verlangt (also z.B. "cloudy" oder "sunny" oder so) und danach sucht der sich dann das passende Icon raus. Diese standardisierte Beschreibung gibt es im ioBroker einfach nicht.
                        Das führt dazu, dass ich die Standardwetterkarte "hacke" und sie dazu bringe, das icon, was der Wetteradapter liefert anzuzeigen. Deshalb gehen auch alle anderen Custom-Wetterkarten nicht.
                        Wenn ich es richtig im Kopf habe, hat der Entwickler vom accuweather-Adapter und der accuweather-Karte aber eine ähnliche Beschreibung des Wetters in einem Wort hinzugefügt und die erkennt type-detector als "STATE" und die nutzt die Karte, wenn sie vorhanden ist. Die anderen Wetter-Adapter liefern das (vermutlich) nicht oder etwas, was die Karte nicht versteht (da ioBroker da keinen Standard festlegt / erzwingt),
                        @chrisham said in Der "ultimative" ioBroker Lovelace Leitfaden/Dokumentation:
                        Ja, die Rollen stimmen nicht. Erwartet wird da: time.sunrise bzw. time.sunset (siehe Gerätedefinition). Hm.. wobei ich da einen Fehler im type-detector / Gerätedefinition sehen würde. Eigentlich nutzt ioBroker da eher "date" und es gibt auch die Rollen date.sunrise und date.sunset in der Rollenliste, die mit time aber nicht. Urgs.. ich glaub da mache ich mal pullrequests. Seufz
                          GarfonsoG Offline
                          GarfonsoG Offline
                          Garfonso
                          #75
                          @centurytt-0
                          Das hab ich versucht hier zu erklären. So unverständlich? ;-)
                          Im Grunde musst du die ID smartthings.0.0b0d9dd1-e50b-91c0-0fb1-81c2180be92e.capabilities.airConditionerMode-setAirConditionerMode bei MODE eintragen und dann hinten auf den fx-Knopf drücken. Da kannst du dann für lesen und schreiben Konvertierungsfunktionen definieren. "val" ist dabei das, was reinkommt und das Ergebnis von deinem Ausdruck kommt dann in den State (beim Lesen den Aliasstate beim Schreiben in den Zielstate).
                          Ich hoffe, der Rest ist oben damit verständlicher. Wenn nicht, bitte konkrete Fragen. :-)
                            @centurytt-0
                            Centurytt 0
                            #76
                            @garfonso ok ich hab das in Mode eingetragen :-) ich bin echt manchaml schwer von Begriff. Aber trotzdem folgende Frage:
                            Wie muss ich das in den Konvertierungsfunktionen hinterlegen ?
                            Das kapier ich nicht ganz. Da hab ich nur lesen und schreiben ... wie muss ich das hier eintragen ? .
                              @chrisham
                              Chrisham
                              #77
                              @chrisham
                              Perfekt, damit funktioniert es nun einwandfrei:
                              Vielen Dank!
                                GarfonsoG Offline
                                GarfonsoG Offline
                                Garfonso
                                #78
                                @centurytt-0
                                Das da bei "Schreiben": ['auto', 'cool', 'dry', 'heat', 'wind'].indexOf(val).
                                Das da bei "Lesen": ['auto', 'cool', 'dry', 'heat', 'wind'][val]
                                Dann Zustände bearbeiten, da dann die Tabelle befüllen mit:
                                0 auto
                                1 cool
                                2 dry
                                3 heat
                                4 fan_only
                                (falls die Funktionen so stimmen).
                                So sollte es mit dem steuern dann schonmal gehen.
                                Bezüglich Lesen gibt es halt noch die Frage, ob der state aktualisiert wird, wenn du "von Außen" (also z.B. mit dem Handy und der Smartthings app) was einstellst. Falls nicht, kannst du halt für "lesen" auch einen anderen State angeben und musst ggf. die Konverterfunktion anpassen.
                                Centurytt 0C 2 Antworten Letzte Antwort
                                  @centurytt-0
                                  0 auto
                                  1 cool
                                  2 dry
                                  3 heat
                                  4 fan_only
                                  Centurytt 0
                                  #79
                                  @garfonso ohhhja .... das teste ich heute gleich mal. Danke schonmal !
                                    @centurytt-0
                                    0 auto
                                    1 cool
                                    2 dry
                                    3 heat
                                    4 fan_only
                                    Centurytt 0
                                    schrieb am zuletzt editiert von Centurytt 0
                                    #80
                                    DU BIST MEIN HELD. Das scheint soweit zu klappen. Aber dennoch eine Frage. Es gibt ja diesen "fanOscillationMode-setFanOscillationMode" bei dem die Art des Lüfters angegeben wird, also Oszillierend oder vertikal usw. Wie bringe ich diese Auswahl in die Karte ? Die Zustände sind definiert, dass hat er beim Erstellen des Alias alles mitgenommen, aber in der Karte wird das so nicht erkannt.
                                    Danke dir für deine Geduld mit mir.
                                    Kurzes Update.... im Gerätemanager wird die Klima als solche nun erkannt. Jetzt habe ich noch 2 zusätzliche Zustände mit "Swing" ?
                                    Update: ich habe alles soweit geschafft und erledigt. Funzt auch. ABER... beim Smartthings in den DP gibt es jeweils einen DP für ein/aus der Klima. Das Problem ist jetzt, dass wenn die Klima eingeschalten wird, die beiden DP wie folgt stehen müssen: DP off auf false und DP on auf true. Wenn die Analage ausgeschalten wird eben umgekehrt. Da aber das Gerät nur einen Zustand für ON hat .... meine Frage wie ich das bewerkstelligen soll ? Danke
                                    • David G.D David G.
                                      @chrisham
                                      Ich mache sehr viel mit der picture-elements.
                                      Hier siehst du, was man da tb alles mit der card_mod machen kann.
                                      https://community.home-assistant.io/t/styling-elements-in-picture-elements-card-a-small-tutorial/315252
                                      Chrisham
                                      #81
                                      @david-g Ich wollte jetzt eine "custom: button-card" anlegen, das hat soweit auch gut funktioniert mit Formatierung usw. Allerdings funktioniert einfach die Umschaltung über "tap_action" (toggle) nicht. Der Code ist ja simpel, aber beim Klicken ändert sich einfach der Zustand nicht:
                                                - type: custom:button-card
                                                  entity: switch.Scene_WoZi_Gemuetlich
                                                  icon: mdi:brightness-7
                                                  tap_action:
                                                    action: toggle
                                                  color: rgb(223, 255, 97)
                                                  styles:
                                                    card:
                                                      - font-size: 12px
                                                    img_cell:
                                                      - align-items: center
                                                      - justify-content: center
                                                  state:
                                                    - value: 'on'
                                                      styles:
                                                        icon:
                                                          - color: rgb(223, 255, 97)
                                                    - value: 'off'
                                                      styles:
                                                        icon:
                                                          - color: rgb(100, 100, 100)
                                      Wenn ich einen Button über entities Karte anlege, kann ich den zustand umschalten und die Farbe des Icons in der custom: button-card ändert sich auch entsprechend, was kann da die Ursache sein?
                                      • C Chrisham
                                                    tap_action:
                                                      action: toggle
                                                    styles:
                                                      card:
                                                        - font-size: 12px
                                                      img_cell:
                                                    state:
                                                      - value: 'on'
                                                        styles:
                                                          icon:
                                                      - value: 'off'
                                                        styles:
                                                          icon:
                                        Chrisham
                                        #82
                                        @chrisham @M1R0O evtl. kannst du auch helfen, fand diesen Beitrag von dir:
                                        https://forum.iobroker.net/topic/34775/test-adapter-lovelace-v1-2-x/1368
                                        Ich bekomme die custom: button-card nicht dazu, dass sie auf die Click-Action reagiert. Evtl. ist der Datenpunkt, der hinter der Entität liegt auch nicht korrekt angelegt, aber hab schon alles ausprobiert:
                                        Das ist der Datenpunkt (unter "Eigene-Datenpunkte" angelegt):
                                        Merkwürdig ist auch: sobald ich "show_state: true" einfüge, kommt Fehlermeldung:
                                        Hat jemand eine Idee....?
                                        • C Chrisham
                                                      tap_action:
                                                        action: toggle
                                                      styles:
                                                        card:
                                                          - font-size: 12px
                                                        img_cell:
                                                      state:
                                                        - value: 'on'
                                                          styles:
                                                            icon:
                                                        - value: 'off'
                                                          styles:
                                                            icon:
                                          Chrisham
                                          #83
                                          @chrisham @Garfonso : du kennst dich doch auch sehr gut aus, hast du evtl. eine Idee, warum die action (toggle) bei der custom: button_card nicht funktioniert bei mir?
