  4. update auf node.js 18.XX
86 Beiträge 8 Kommentatoren 12.6k Aufrufe 6 Beobachtet
  • KusselinK Kusselin
    Hallo Zusammen, wollte von 16.xx auf 18.xx wieder updaten....leider klappt das nicht....
    gebe an der Kommandoline das hier ein wie immer nur auf 18.x geändert
    curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
    dann warte ich 60 sek.
    dann das:
    TO AVOID THIS WAIT MIGRATE THE SCRIPT
    Continuing in 60 seconds (press Ctrl-C to abort) ...
    ## Installing the NodeSource Node.js 18.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 https://dl.yarnpkg.com/debian stable InRelease
    OK:2 https://deb.nodesource.com/node_18.x bionic InRelease
    OK:3 http://archive.ubuntu.com/ubuntu bionic InRelease
    OK:4 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
    OK:5 http://archive.ubuntu.com/ubuntu bionic-security InRelease
    ## Confirming "bionic" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_18.x/dists/bionic/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 18.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bionic main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x bionic main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    OK:1 https://deb.nodesource.com/node_18.x bionic InRelease
    OK:2 https://dl.yarnpkg.com/debian stable InRelease
    ## Run `sudo apt-get install -y nodejs` to install Node.js 18.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    dann sudo apt install -y nodejs eingegeben.... dann das hier:
    Einige Pakete konnten nicht installiert werden. Das kann bedeuten, dass
    Sie eine unmögliche Situation angefordert haben oder, wenn Sie die
    Unstable-Distribution verwenden, dass einige erforderliche Pakete noch
    nicht erstellt wurden oder Incoming noch nicht verlassen haben.
    Die folgenden Informationen helfen Ihnen vielleicht, die Situation zu lösen:
    Die folgenden Pakete haben unerfüllte Abhängigkeiten:
     nodejs : Hängt ab von: libc6 (>= 2.28) aber 2.27-3ubuntu1.6 soll installiert werden
    E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
    Könnt Ihr mir bitte mitteilen was ich hier noch installieren muss und in welcher Reihenfolge.
    Vielen herzlichen Dank.
    @kusselin
    Schau in meine Signatur, da gibt's ein Skript dafür.
    Und dein 5 Jahre altes Ubuntu ist tot. Da wird kein aktuelles nodejs drauf laufen. Aktualisieren.
    KusselinK 1 Antwort Letzte Antwort
      @kusselin
      KusselinK Offline
      KusselinK Offline
      Kusselin
      @thomas-braun o.k. danke Dir für die Info...das ist der fixer O.K.
      Nächste Frage wäre wie ich das bestehende Linux system auf ein aktuelles Update...da ich kein LinuxUser bin sag ichs ehrlich weiss ich es nicht..
      gibt es da ein HowtoDo?
      Danek und Gruss
        Danek und Gruss
        @kusselin sagte in update auf node.js 18.XX:
        Für Ubuntu gibt es ein hauseigenes Updateskript, wenn ich mich Recht entsinne. Musste Mal nach suchen.
          KusselinK Offline
          KusselinK Offline
          Kusselin
          schrieb am zuletzt editiert von Kusselin
          habe das hier gefunden....geht das mit dem /etc/apt/sources.list
          https://www.tuxedocomputers.com/de/Infos/Hilfe-Support/Anleitungen/Ubuntu-Upgrade-von-18-04-auf-20-04.tuxedo
          schau das steht bei mir in der SourceList drin:
          deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
          deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
          deb http://archive.ubuntu.com/ubuntu bionic-security main restricted universe multiverse
            @kusselin
            Das wirst du herausfinden müssen.
              @kusselin
              KusselinK Offline
              KusselinK Offline
              Kusselin
              @thomas-braun kannst du mir bitte mitteilen was ich da ändern muss..ich gehe davon aus das ich das bionic ändern muss aber in was...?
              Kannst du mir den Code bitte mitteilen...
                @kusselin
                Das steht doch in der Anleitung drin?
                  @kusselin
                  KusselinK Offline
                  KusselinK Offline
                  Kusselin
                  @thomas-braun o.k. sorry ...habdie source.list ..mit Befehl
                  sudo sed -i 's/bionic/focal/g' /etc/apt/sources.list
                  ändern können dann das ausgeführt:
                  sudo apt update && sudo apt -y dist-upgrade
                  bekomme aber immer noch einen Fehler nachdem ich
                  eingegeben habe..
                  Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                    gyp libc-ares2 libhttp-parser2.7.1 libjs-async libjs-inherits
                    libjs-node-uuid libjs-underscore libssl1.0-dev libuv1-dev node-abbrev
                    node-ansi node-ansi-color-table node-archy node-async node-balanced-match
                    node-block-stream node-brace-expansion node-builtin-modules
                    node-combined-stream node-concat-map node-cookie-jar node-delayed-stream
                    node-forever-agent node-form-data node-fs.realpath node-fstream
                    node-fstream-ignore node-github-url-from-git node-glob node-graceful-fs
                    node-gyp node-hosted-git-info node-inflight node-inherits node-ini
                    node-is-builtin-module node-isexe node-json-stringify-safe node-lockfile
                    node-lru-cache node-mime node-minimatch node-mkdirp node-mute-stream
                    node-node-uuid node-nopt node-normalize-package-data node-npmlog node-once
                    node-osenv node-path-is-absolute node-pseudomap node-qs node-read
                    node-read-package-json node-request node-retry node-rimraf node-semver
                    node-sha node-slide node-spdx-correct node-spdx-expression-parse
                    node-spdx-license-ids node-tar node-tunnel-agent node-underscore
                    node-validate-npm-package-license node-which node-wrappy node-yallist
                    python-chardet python-cliapp python-markdown python-pkg-resources
                    python-pygments python-ttystatus python-yaml
                  Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                  Die folgenden zusätzlichen Pakete werden installiert:
                    gcc-10-base libc-bin libc-dev-bin libc6 libc6-dev libcrypt-dev libcrypt1
                    libgcc-s1 libidn2-0 locales manpages-dev
                  Vorgeschlagene Pakete:
                    glibc-doc
                  Die folgenden NEUEN Pakete werden installiert:
                    gcc-10-base libcrypt-dev libcrypt1 libgcc-s1
                    libc-bin libc-dev-bin libc6 libc6-dev libidn2-0 locales manpages-dev nodejs
                  8 aktualisiert, 4 neu installiert, 0 zu entfernen und 581 nicht aktualisiert.
                  Es müssen noch 28,7 MB von 41,1 MB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 64,8 MB Plattenplatz zusätzlich benutzt.
                  Fehl:1 https://deb.nodesource.com/node_18.x bionic/main amd64 nodejs amd64 18.16.0-deb-1nodesource1
                    404  Not Found [IP: 104.22.5.26 443]
                  E: Fehlschlag beim Holen von https://deb.nodesource.com/node_18.x/pool/main/n/nodejs/nodejs_18.16.0-deb-1nodesource1_amd64.deb 404  Not Found [IP: 104.22.5.26 443]
                  E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get update« ausführen oder mit »--fix-missing« probieren?
                    dann das:
                    + apt-get update
                    + apt-get update
                    W Online
                    W Online
                    Wildbill
                    @kusselin Ubuntu macht doch automatisch Upgrades auf die nächste Version mittels
                    sudo do-release-upgrade
                    Gruss, Jürgen
                    • W Wildbill
                      Gruss, Jürgen
                      KusselinK Offline
                      KusselinK Offline
                      Kusselin
                      @wildbill sorry habe zwar schon eine weile iobroker aber ich bin da trotzdem nicht so im Geschäft wie ihr..bitte habt verständnis......
                        eingegeben habe..
                          glibc-doc
                        @kusselin
                        Lösch die nodesource.list komplett und leg die nach dem Doppelsprung über Ubuntu 20.04 auf 22.04 dann frisch an. Deine jetzige Version der Datei ist eh noch im alten Format und müsste angepasst werden.
                          @kusselin
                          ändern können
                          Und warum machste es nicht nach der einfachen Anleitung und nimmst den Weg für erfahrene User?
                            @kusselin
                            KusselinK Offline
                            KusselinK Offline
                            Kusselin
                            @thomas-braun sagte in update auf node.js 18.XX:
                            @kusselin
                            wie mach ich das?
                              @kusselin
                              ändern können
                              KusselinK Offline
                              KusselinK Offline
                              Kusselin
                              @kusselin
                              ändern können
                              ?? sorry verstehe nur bahnhof
                                @kusselin
                                wie mach ich das?
                                @kusselin
                                sudo rm /etc/apt/sources.list.d/node*
                                  @kusselin
                                  KusselinK Offline
                                  KusselinK Offline
                                  Kusselin
                                  @kusselin
                                  das steht jetzt aktuell in dieser nodeliste drin
                                  ..und wenn ich die gelöscht habe...was muss ich da dann eintragen...umd das ich dann mit dem Befehlen
                                  die aktuelle Node.js version bekomme?
                                    @kusselin
                                    ändern können
                                    @kusselin
                                    Aus deiner Anleitung:
                                    Der Ubuntu-Weg
                                    Ubuntu hat seine eigene automatische Art des Upgrades zwischen den Versionen entwickelt. So können Sie alles vorbereiten und dann vom Rechner weggehen. Den Rest erledigt Ubuntu.
                                    Mach das doch danach. Da steht auch drin, das Herumgeschreibe in den .list-Files nur für erfahrenere User empfohlen wird...
                                      @kusselin
                                      @kusselin
                                      Lass die Finger von nodejs, solange da nicht Ubuntu 22.04 LTS drauf ist. Das schnallst du erst danach dann drauf..
                                      Ich würde das sogar temporär komplett rauswerfen.
                                      sudo apt remove nodejs
                                      Das verhindert, dass du dir die dfsg-Versiin von nodejs einhandelst.
                                        @kusselin
                                        Der Ubuntu-Weg
                                        KusselinK Offline
                                        KusselinK Offline
                                        Kusselin
                                        @kusselin
                                        Der Ubuntu-Weg
                                        bin das jetzt durchgegangen..
                                         iobroker stop
                                        root@iobroker-live:~# sudo apt install update-manager-core
                                        update-manager-core ist schon die neueste Version (1:20.04.10.11).
                                          gyp libc-ares2 libcups2 libhttp-parser2.7.1 libjansson4 libjs-async
                                          libjs-inherits libjs-node-uuid libjs-underscore libldb1 libssl1.0-dev
                                          libtdb1 libtevent0 libuv1-dev node-abbrev node-ansi node-ansi-color-table
                                          node-archy node-async node-balanced-match node-block-stream
                                          node-brace-expansion node-builtin-modules node-combined-stream
                                          node-concat-map node-cookie-jar node-delayed-stream node-forever-agent
                                          node-form-data node-fs.realpath node-fstream node-fstream-ignore
                                          node-github-url-from-git node-glob node-graceful-fs node-gyp
                                          python-chardet python-cliapp python-crypto python-ldb python-markdown
                                          python-pkg-resources python-pygments python-samba python-talloc python-tdb
                                          python-ttystatus python-yaml samba-common samba-common-bin samba-libs
                                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 255 nicht aktualisiert.
                                        root@iobroker-live:~# sudo apt autoremove
                                        Die folgenden Pakete werden ENTFERNT:
                                        0 aktualisiert, 0 neu installiert, 91 zu entfernen und 229 nicht aktualisiert.
                                        Nach dieser Operation werden 59,9 MB Plattenplatz freigegeben.
                                        Möchten Sie fortfahren? [J/n] J
                                        (Lese Datenbank ... 37958 Dateien und Verzeichnisse sind derzeit installiert.)
                                        Entfernen von node-gyp (3.6.2-1ubuntu1) ...
                                        Entfernen von gyp (0.1+20150913git1f374df9-1ubuntu1) ...
                                        Entfernen von libc-ares2:amd64 (1.15.0-1ubuntu0.4) ...
                                        Entfernen von samba-common-bin (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                        Entfernen von python-samba (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                        Entfernen von samba-libs:amd64 (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                        Entfernen von libcups2:amd64 (2.2.7-1ubuntu2.10) ...
                                        Entfernen von libhttp-parser2.7.1:amd64 (2.7.1-2ubuntu0.1) ...
                                        Entfernen von libjansson4:amd64 (2.12-1build1) ...
                                        Entfernen von node-request (2.26.1-1) ...
                                        Entfernen von node-form-data (0.1.0-1) ...
                                        Entfernen von node-async (0.8.0-3) ...
                                        Entfernen von libjs-async (0.8.0-3) ...
                                        Entfernen von node-tar (2.2.1-1) ...
                                        Entfernen von node-read-package-json (1.2.4-1) ...
                                        Entfernen von node-node-uuid (1.4.7-5) ...
                                        Entfernen von libjs-node-uuid (1.4.7-5) ...
                                        Entfernen von node-underscore (1.9.1~dfsg-1ubuntu0.20.04.1) ...
                                        Entfernen von libjs-underscore (1.9.1~dfsg-1ubuntu0.20.04.1) ...
                                        Entfernen von python-ldb:amd64 (2:1.2.3-1ubuntu0.2) ...
                                        Entfernen von libldb1:amd64 (2:1.2.3-1ubuntu0.2) ...
                                        Entfernen von libssl1.0-dev:amd64 (1.0.2n-1ubuntu5.13) ...
                                        Entfernen von python-tdb (1.3.15-2) ...
                                        Entfernen von libtdb1:amd64 (1.3.15-2) ...
                                        Entfernen von libtevent0:amd64 (0.9.34-1) ...
                                        Entfernen von libuv1-dev:amd64 (1.34.2-1ubuntu1.3) ...
                                        Entfernen von node-nopt (3.0.6-4) ...
                                        Entfernen von node-abbrev (1.1.1-2) ...
                                        Entfernen von node-ansi-color-table (1.0.0-1) ...
                                        Entfernen von node-npmlog (0.0.4-1) ...
                                        Entfernen von node-ansi (0.3.1-1) ...
                                        Entfernen von node-archy (1.0.0-3) ...
                                        Entfernen von node-fstream-ignore (0.0.6-2) ...
                                        Entfernen von node-block-stream (0.0.9-1ubuntu1) ...
                                        Entfernen von node-normalize-package-data (2.3.5-2) ...
                                        Entfernen von node-is-builtin-module (2.0.0-1) ...
                                        Entfernen von node-builtin-modules (3.1.0-1) ...
                                        Entfernen von node-combined-stream (1.0.8-1) ...
                                        Entfernen von node-cookie-jar (0.3.1-1) ...
                                        Entfernen von node-delayed-stream (1.0.0-4) ...
                                        Entfernen von node-forever-agent (0.6.1-2) ...
                                        Entfernen von node-fstream (1.0.12-2) ...
                                        Entfernen von node-github-url-from-git (1.5.0-1) ...
                                        Entfernen von node-sha (3.0.0-1) ...
                                        Entfernen von node-graceful-fs (4.2.3-2) ...
                                        Entfernen von node-hosted-git-info (2.8.5-1) ...
                                        Entfernen von node-ini (1.3.5-1) ...
                                        Entfernen von node-which (2.0.2-1) ...
                                        Entfernen von node-isexe (2.0.0-4) ...
                                        Entfernen von node-json-stringify-safe (5.0.1+repack-2) ...
                                        Entfernen von node-lockfile (0.4.1-1) ...
                                        Entfernen von node-lru-cache (5.1.1-5) ...
                                        Entfernen von node-mime (2.4.4+dfsg-1) ...
                                        Entfernen von node-mkdirp (0.5.1-2) ...
                                        Entfernen von node-read (1.0.7-2) ...
                                        Entfernen von node-mute-stream (0.0.8-2) ...
                                        Entfernen von node-osenv (0.1.5-1) ...
                                        Entfernen von node-pseudomap (1.0.2-1) ...
                                        Entfernen von node-qs (6.9.1+ds-1) ...
                                        Entfernen von node-retry (0.12.0-1) ...
                                        Entfernen von node-rimraf (2.6.3-1) ...
                                        Entfernen von node-semver (5.4.1-1) ...
                                        Entfernen von node-slide (1.1.6-2) ...
                                        Entfernen von node-validate-npm-package-license (3.0.4-1) ...
                                        Entfernen von node-spdx-correct (1.0.2-1) ...
                                        Entfernen von node-spdx-expression-parse (1.0.4-1) ...
                                        Entfernen von node-spdx-license-ids (3.0.5-1) ...
                                        Entfernen von node-tunnel-agent (0.3.1-1) ...
                                        Entfernen von node-yallist (4.0.0-1) ...
                                        Entfernen von python-chardet (3.0.4-1) ...
                                        Entfernen von python-cliapp (1.20170827-1) ...
                                        Entfernen von python-crypto (2.6.1-8ubuntu2) ...
                                        Entfernen von python-markdown (2.6.9-1) ...
                                        Entfernen von python-pkg-resources (39.0.1-2ubuntu0.1) ...
                                        Entfernen von python-pygments (2.2.0+dfsg-1ubuntu0.2) ...
                                        Entfernen von python-talloc (2.1.10-2ubuntu1) ...
                                        Entfernen von python-ttystatus (0.38-1) ...
                                        Entfernen von python-yaml (3.12-1build2) ...
                                        Entfernen von samba-common (2:4.7.6+dfsg~ubuntu-0ubuntu2.29) ...
                                        Entfernen von node-glob (7.1.6-1) ...
                                        Entfernen von node-inherits (2.0.4-1) ...
                                        Entfernen von libjs-inherits (2.0.4-1) ...
                                        Entfernen von node-minimatch (3.0.4-4ubuntu0.1) ...
                                        Entfernen von node-brace-expansion (1.1.11-1) ...
                                        Entfernen von node-balanced-match (1.0.0-1) ...
                                        Entfernen von node-concat-map (0.0.1-2) ...
                                        Entfernen von node-fs.realpath (1.0.0-1) ...
                                        Entfernen von node-inflight (1.0.6-1) ...
                                        Entfernen von node-once (1.4.0-3) ...
                                        Entfernen von node-path-is-absolute (2.0.0-1) ...
                                        Entfernen von node-wrappy (1.0.2-1) ...
                                        Trigger für man-db (2.8.3-2ubuntu0.1) werden verarbeitet ...
                                        Trigger für libc-bin (2.27-3ubuntu1.6) werden verarbeitet ...
                                        root@iobroker-live:~# sudo do-release-upgrade
                                        Checking for a new Ubuntu release
                                        Please install all available updates for your release before upgrading.
                                        root@iobroker-live:~# sudo do-release-upgrade -d
                                        There is no development version of an LTS available.
                                        To upgrade to the latest non-LTS development release
                                        set Prompt=normal in /etc/update-manager/release-upgrades.
                                        und jetzt....?
                                          @kusselin
                                          Der Ubuntu-Weg
                                           iobroker stop
                                          und jetzt....?
                                          root@iobroker-live
                                          Ist schon komplett falsch. Nie, nie, nie als root. Gerade nicht auf einem Ubuntu.
                                          Als Standarduser mit sudo-Recht anmelden, dann upgraden.
