    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
    michael_4358
    #3829
    19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
    19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
    19:48:00.005	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2869:9)
    19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
    19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
    19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
    19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
    19:48:00.012	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
    19:48:00.012	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
    19:48:00.012	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
    19:48:00.012	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
    19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
    19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
    19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
    19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
    19:48:00.013	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
    19:48:00.013	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
    19:48:00.013	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
    19:48:00.013	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
    19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
    ich erhalte nach dem update immer folgende Meldungen/warunungen,.,,
      TT-Tom
      #3830
      @michael_4358
      Welche updates hast du gemacht, Versionen bitte angeben.
      zusätzlich bitte die Config von
      mrIcon1ScreensaverEntity:
      mrIcon2ScreensaverEntity:
      zeigen.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      • T TT-Tom
        @michael_4358
        zeigen.
        michael_4358
        #3831
        @tt-tom said in SONOFF NSPanel mit Lovelace UI:
        TypeScript v4.3.1.3 zur Steuerung des SONOFF NSPanel mit dem ioBroker
                    ScreensaverEntity: NSPanel_Path + 'Relay.1',
                    ScreensaverEntityIconOn: 'lightbulb',
                    ScreensaverEntityIconOff: null,
                    ScreensaverEntityValue: null,
                    ScreensaverEntityValueDecimalPlace : 0,
                    ScreensaverEntityValueUnit: null,
                    ScreensaverEntityOnColor: On,
                    ScreensaverEntityOffColor: HMIOff
                    ScreensaverEntity: 'deconz.0.Sensors.5.open',
                    ScreensaverEntityIconOn: 'heat-wave',
                    ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                    ScreensaverEntityValueDecimalPlace : 1,
                    ScreensaverEntityValueUnit: '°',
                    ScreensaverEntityOnColor: MSRed,
                    ScreensaverEntityOffColor: Yellow
        • M michael_4358
          TT-Tom
          #3832
          @michael_4358
          hier steckt der Fehler, die Datenpunkte gibt's bei dir nicht. Es ist auch nur ein Beispiel.
          Gruß Tom
          Public Transport
          M 2 Antworten Letzte Antwort
          • T TT-Tom
            @michael_4358
            michael_4358
            #3833
            @michael_4358
            kann ich die einfach auskommentieren?
            • T TT-Tom
              @michael_4358
              michael_4358
              #3834
              @michael_4358
              habe die beiden mal auskommender nun sind noch
              20:11:51.959	warn	javascript.0 (540063) at script.js.NSPanel.pdf:3349:46
              20:11:51.959	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
              20:11:51.959	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
              20:11:51.959	warn	javascript.0 (540063) at fulfilled (script.js.NSPanel.pdf:5:58)
              • M michael_4358
                @MichaelF meinst du das tasmota update auf v.13❓
                MichaelFM Offline
                MichaelFM Offline
                MichaelF
                #3835
                @michael_4358
                Hi, nein die TFT Firmware
                • M michael_4358
                  @michael_4358
                  TT-Tom
                  #3836
                  @michael_4358
                  Wie aus kommentiert? Bitte zeigen komplett.
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @michael_4358
                    michael_4358
                    #3837
                    @tt-tom
                    Bin gerade nicht am pc..
                    Habe vor der Zeile mit den datenpunkten „//„ angefügt, mehr nicht
                      TT-Tom
                      #3838
                      @michael_4358
                      Ja so passt das nicht.
                                  ScreensaverEntity: NSPanel_Path + 'Relay.2',
                      ersetze mal bitte hier mit. Das funktioniert ohne Fehlermeldung und zeigt dir den Zustand der Relais.
                      Gruß Tom
                      Public Transport
                        manylopmy
                        #3839
                        Gute Abend zusammen 😊
                        Ich würde mich gerne daran geben, meine Sonos Boxen über das NSPanel
                        1. Ein und Auszuschalten
                        2. Lautstärke zu regulieren.
                        Da gibt es bestimmt schon einige Realisierungen.
                        Ich wäre froh wenn mir jemand eine kurze Beschreibung der Vorgehensweise (und welche Voraussetzungen ich erfüllt haben muss) mitteilen würde.
                        Stand derzeitig ist:
                        Der Sonos Adapter ist unter Objekte mit seinen Datenpunkten vorhanden. Ich habe bisher keinen zu SONOS gehörenden Alias eingerichtet.
                        Vielen Dank
                        Manfred
                        • M manylopmy
                          Vielen Dank
                          Manfred
                          TT-Tom
                          #3840
                          @manylopmy schon mal im Wiki auf github gelesen. Siehe Signatur
                          Gruß Tom
                          Public Transport
                          • T TT-Tom
                            @australien es gibt in den Icons eins, was aussieht wie ein Radio. Eventuell hast du das gesehen.
                            australien
                            #3841
                            @tt-tom
                            ja, das kenne ich.
                            Wollte eigene Bilder (locale Logos) anstatt des Radio-Icons.
                            Ist es möglich eigene Bilder anstatt des Icons einzusetzen? Ev. via die icon_mapping.ts
                            • A australien
                              @tt-tom
                              ja, das kenne ich.
                              Kuckuckmann
                              #3842
                              @australien
                              Hey,
                              das icon_mapping.ts enhält ja letztlich die Icons von der Seite, die ich Dir gegeben habe. Es bleibt dabei, neue Icons bitte über das Git einkippen :-)
                              Wir haben keine Möglichkeit derzeit, da einfach mal ein JPG oder PNG einzuladen. Das Nextiondisplay ist da etwas "speziell".
                              LG
                              NSPanel Dokumentation im GitHub Wiki:
                              • K Kuckuckmann
                                @australien
                                Hey,
                                LG
                                australien
                                #3843
                                @Kuckuckmann
                                Ok. Danke. Verstehe.
                                • T TT-Tom
                                  manylopmy
                                  schrieb am zuletzt editiert von manylopmy
                                  #3844
                                  @tt-tom
                                  Ich habe in der Zwischenzeit gelesen und gemacht. 😊
                                  Mit mittlerem Erfolg. Ich habe verstanden, dass ich einen Player benötige (logisch) und mir verschiedene zur Auswahl stehen. Spotify, Volumio und Sonos.
                                  Habe mit Sonos und Spotify versucht. Ich bekomme auch eine Page und habe ein wenig Zugriff auf mein Sonos. Derzeit habe ich folgenden Eintrag im ts:
                                  let Sonos = <PageMedia>
                                      'type': 'cardMedia',
                                      'heading': 'Sonos',
                                      'useColor': true,
                                      'items': [<PageItem>{
                                                  adapterPlayerInstance: 'alias.0.NSPanel.1.Media.Sonos_1',
                                                  mediaDevice: '192_168_178_86',
                                                  speakerList: ['Wohnzimmer'],
                                                  colorMediaIcon: colorRadio,
                                                  colorMediaArtist: Yellow,
                                                  colorMediaTitle: Yellow,
                                                  autoCreateALias : true
                                  Nun erscheint eine Page in der der Sender, der Titel und ich glaube das Album angezeigt werden. Weiterhin kann ich Next und Prev nutzen. Dazwischen steht auch das Pause-Symbol. das klappt auch, wechselt aber dann nicht in Play-Symbol und läßt auch keinen Start mehr zu.
                                  Seltsam finde ich selber, dass die ID als auch die PlayerInstance identisch sind. Aber ich finde keine wirkliche Alternative.
                                  Kann mir an der Stelle jemand auf die Sprünge helfen?
                                  Zum Schluß hätte ich gerne eine Anzeige, in der auch z.B. Playlist stehen in denen ich Titel aussuchen kann. Aber, - das ist next Step. Zuerst wäre es schön, die Steuerung richtig hinzubekommen.
                                  So sieht die Page aktuell aus.
                                  Gruß Manfred
                                  M T ArmilarA 3 Antworten Letzte Antwort
                                  • M manylopmy
                                    @tt-tom
                                        'heading': 'Sonos',
                                        'useColor': true,
                                    Gruß Manfred
                                    michael_4358
                                    #3845
                                    Hallo
                                    ich habe das problem das ich nun das display nicht ganz mittig habe... kann man die Ansicht zentrieren?
                                    • M manylopmy
                                      @tt-tom
                                          'heading': 'Sonos',
                                          'useColor': true,
                                      Gruß Manfred
                                      TT-Tom
                                      #3846
                                      @manylopmy
                                      Weiter kann ich dir da nicht helfen. Nutze keine Media Page und auch keinen der Adapter.
                                      Gruß Tom
                                      Public Transport
                                      • M michael_4358
                                        Hallo
                                        TT-Tom
                                        #3847
                                        @michael_4358 kann deine Aussage nicht nachvollziehen, worauf beziehst du dich? Die Positionen sind auf dem Panel festgeschrieben und lassen sich nicht ändern.
                                        Gruß Tom
                                        Public Transport
                                        • T TT-Tom
                                          michael_4358
                                          #3848
                                          @tt-tom habe das tat neu geflasht nun passt es. wird sich wohl verschluckt haben.
                                          ich hatte bei meinen (sehr) alten script folgende screensaver einstellungen:
                                              panelRecvTopic: 'mqtt.0.NSPanel.tele.NsPanel.RESULT',       // anpassen
                                              panelSendTopic: 'mqtt.0.NSPanel.cmnd.NsPanel.CustomSend',   // anpassen
                                              firstScreensaverEntity: { ScreensaverEntity: 'modbus.0.holdingRegisters.1068_soc', ScreensaverEntityIcon: 'battery', ScreensaverEntityText: 'Speicher', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
                                              secondScreensaverEntity: { ScreensaverEntity: 'kostal-piko-ba.0.Power.DC1Power', ScreensaverEntityIcon: 'sun-wireless', ScreensaverEntityText: "Garten", ScreensaverEntityUnitText: 'W', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
                                              thirdScreensaverEntity: { ScreensaverEntity: 'kostal-piko-ba.0.Power.DC2Power', ScreensaverEntityIcon: 'sun-wireless', ScreensaverEntityText: 'Strasse', ScreensaverEntityUnitText: 'W', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 9} },
                                              fourthScreensaverEntity: { ScreensaverEntity: 'kostal-piko-ba.0.Statistics_Daily.Yield', ScreensaverEntityIcon: 'power-plug-outline', ScreensaverEntityText: 'Gesamt/Tag', ScreensaverEntityUnitText: 'W', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
                                              alternativeScreensaverLayout: false,
                                              autoWeatherColorScreensaverLayout: false,
                                              mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.NSPanel.stat.NsPanel.POWER1', ScreensaverEntityIcon: 'light-switch', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
                                              mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.NSPanel.stat.NsPanel.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
                                              timeoutScreensaver: 10,
                                              dimmode: 90,
                                          sind das in der aktuellen version die folgenden❓
                                              bottomScreensaverEntity :
                                                      // bottomScreensaverEntity 1
                                                          ScreensaverEntity: 'accuweather.0.Daily.Day1.Sunrise',
                                                          ScreensaverEntityFactor: 1,
                                                          ScreensaverEntityDecimalPlaces: 0,
                                                          ScreensaverEntityDateFormat: 'hh:mm',   // like DD.MM or DD.MM.YY or YYYY/MM/DD or hh:mm
                                                          ScreensaverEntityIconOn: 'weather-sunset-up',
                                                          ScreensaverEntityText: 'Sonne',
                                                          ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100}
                                                      // bottomScreensaverEntity 2
                                                          ScreensaverEntity: 'accuweather.0.Current.WindSpeed',
                                                          ScreensaverEntityFactor: (1000/3600),
                                                          ScreensaverEntityDecimalPlaces: 1,
                                                          ScreensaverEntityIconOn: 'weather-windy',
                                                          ScreensaverEntityText: "Wind",
                                                          ScreensaverEntityUnitText: 'm/s',
                                                          ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 120 }
                                                      // bottomScreensaverEntity 3
                                                          ScreensaverEntity: 'accuweather.0.Current.WindGust',
                                                          ScreensaverEntityIconOn: 'weather-tornado',
                                                          ScreensaverEntityText: 'Böen',
                                                      // bottomScreensaverEntity 4
                                                          ScreensaverEntity: 'accuweather.0.Current.WindDirection',
                                                          ScreensaverEntityIconOn: 'windsock',
                                                          ScreensaverEntityText: 'Windr.',
                                                          ScreensaverEntityUnitText: '°',
                                                          ScreensaverEntityIconColor: White
                                                      // bottomScreensaverEntity 5 (for Alternative and Advanced Screensaver)
                                                          ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity',
                                                          ScreensaverEntityIconOn: 'water-percent',
                                                          ScreensaverEntityText: 'Feuchte',
                                                      // bottomScreensaverEntity 6 (only Advanced Screensaver)
                                                          ScreensaverEntity: 'accuweather.0.Current.UVIndex',
                                                          ScreensaverEntityIconOn: 'solar-power',
                                                          ScreensaverEntityText: 'UV',
                                                          ScreensaverEntityUnitText: '',
                                          würde dort gerne wieder meine pv Daten abbilden :)
