    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • A australien
    @kuckuckmann
    alles klar, schade aber.
    Ich dachte das schon gesehen zu haben.
    TT-Tom
    #3827
    @australien es gibt in den Icons eins, was aussieht wie ein Radio. Eventuell hast du das gesehen.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
      michael_4358
      schrieb am zuletzt editiert von michael_4358
      #3828
      @MichaelF meinst du das tasmota update auf v.13❓
      MichaelFM 1 Antwort Letzte Antwort
        michael_4358
        #3829
        19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
        19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
        19:48:00.005	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2869:9)
        19:48:00.005	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
        19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8739:25)
        19:48:00.012	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
        19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
        19:48:00.012	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
        19:48:00.012	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
        19:48:00.012	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
        19:48:00.012	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
        19:48:00.012	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
        19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverStatusIcons (script.js.NSPanel.pdf:8766:30)
        19:48:00.013	warn	javascript.0 (540063) at HandleScreensaverUpdate (script.js.NSPanel.pdf:8619:13)
        19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2932:17)
        19:48:00.013	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
        19:48:00.013	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
        19:48:00.013	warn	javascript.0 (540063) at script.js.NSPanel.pdf:8:71
        19:48:00.013	warn	javascript.0 (540063) at __awaiter (script.js.NSPanel.pdf:4:12)
        19:48:00.013	warn	javascript.0 (540063) at Object.<anonymous> (script.js.NSPanel.pdf:2928:12)
        ich erhalte nach dem update immer folgende Meldungen/warunungen,.,,
          TT-Tom
          #3830
          @michael_4358
          Welche updates hast du gemacht, Versionen bitte angeben.
          zusätzlich bitte die Config von
          mrIcon1ScreensaverEntity:
          mrIcon2ScreensaverEntity:
          zeigen.
          Gruß Tom
          Public Transport
          • T TT-Tom
            @michael_4358
            zeigen.
            michael_4358
            #3831
            @tt-tom said in SONOFF NSPanel mit Lovelace UI:
            TypeScript v4.3.1.3 zur Steuerung des SONOFF NSPanel mit dem ioBroker
                        ScreensaverEntity: NSPanel_Path + 'Relay.1',
                        ScreensaverEntityIconOn: 'lightbulb',
                        ScreensaverEntityIconOff: null,
                        ScreensaverEntityValue: null,
                        ScreensaverEntityValueDecimalPlace : 0,
                        ScreensaverEntityValueUnit: null,
                        ScreensaverEntityOnColor: On,
                        ScreensaverEntityOffColor: HMIOff
                        ScreensaverEntity: 'deconz.0.Sensors.5.open',
                        ScreensaverEntityIconOn: 'heat-wave',
                        ScreensaverEntityValue: 'deconz.0.Sensors.65.temperature',
                        ScreensaverEntityValueDecimalPlace : 1,
                        ScreensaverEntityValueUnit: '°',
                        ScreensaverEntityOnColor: MSRed,
                        ScreensaverEntityOffColor: Yellow
            • M michael_4358
              TT-Tom
              #3832
              @michael_4358
              hier steckt der Fehler, die Datenpunkte gibt's bei dir nicht. Es ist auch nur ein Beispiel.
              Gruß Tom
              Public Transport
              M 2 Antworten Letzte Antwort
              • T TT-Tom
                @michael_4358
                michael_4358
                #3833
                @michael_4358
                kann ich die einfach auskommentieren?
                • T TT-Tom
                  @michael_4358
                  michael_4358
                  #3834
                  @michael_4358
                  habe die beiden mal auskommender nun sind noch
                  20:11:51.959	warn	javascript.0 (540063) at script.js.NSPanel.pdf:3349:46
                  20:11:51.959	warn	javascript.0 (540063) at step (script.js.NSPanel.pdf:33:23)
                  20:11:51.959	warn	javascript.0 (540063) at Object.next (script.js.NSPanel.pdf:14:53)
                  20:11:51.959	warn	javascript.0 (540063) at fulfilled (script.js.NSPanel.pdf:5:58)
                  • M michael_4358
                    MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    #3835
                    @michael_4358
                    Hi, nein die TFT Firmware
                    • M michael_4358
                      @michael_4358
                      TT-Tom
                      #3836
                      @michael_4358
                      Wie aus kommentiert? Bitte zeigen komplett.
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        @michael_4358
                        michael_4358
                        #3837
                        @tt-tom
                        Bin gerade nicht am pc..
                        Habe vor der Zeile mit den datenpunkten „//„ angefügt, mehr nicht
                          TT-Tom
                          #3838
                          @michael_4358
                          Ja so passt das nicht.
                                      ScreensaverEntity: NSPanel_Path + 'Relay.2',
                          ersetze mal bitte hier mit. Das funktioniert ohne Fehlermeldung und zeigt dir den Zustand der Relais.
                          Gruß Tom
                          Public Transport
                            manylopmy
                            #3839
                            Gute Abend zusammen 😊
                            Ich würde mich gerne daran geben, meine Sonos Boxen über das NSPanel
                            1. Ein und Auszuschalten
                            2. Lautstärke zu regulieren.
                            Da gibt es bestimmt schon einige Realisierungen.
                            Ich wäre froh wenn mir jemand eine kurze Beschreibung der Vorgehensweise (und welche Voraussetzungen ich erfüllt haben muss) mitteilen würde.
                            Stand derzeitig ist:
                            Der Sonos Adapter ist unter Objekte mit seinen Datenpunkten vorhanden. Ich habe bisher keinen zu SONOS gehörenden Alias eingerichtet.
                            Vielen Dank
                            Manfred
                            • M manylopmy
                              Vielen Dank
                              Manfred
                              TT-Tom
                              #3840
                              @manylopmy schon mal im Wiki auf github gelesen. Siehe Signatur
                              Gruß Tom
                              Public Transport
                              • T TT-Tom
                                australien
                                #3841
                                @tt-tom
                                ja, das kenne ich.
                                Wollte eigene Bilder (locale Logos) anstatt des Radio-Icons.
                                Ist es möglich eigene Bilder anstatt des Icons einzusetzen? Ev. via die icon_mapping.ts
                                • A australien
                                  @tt-tom
                                  ja, das kenne ich.
                                  Kuckuckmann
                                  #3842
                                  @australien
                                  Hey,
                                  das icon_mapping.ts enhält ja letztlich die Icons von der Seite, die ich Dir gegeben habe. Es bleibt dabei, neue Icons bitte über das Git einkippen :-)
                                  Wir haben keine Möglichkeit derzeit, da einfach mal ein JPG oder PNG einzuladen. Das Nextiondisplay ist da etwas "speziell".
                                  LG
                                  NSPanel Dokumentation im GitHub Wiki:
                                  • K Kuckuckmann
                                    @australien
                                    Hey,
                                    LG
                                    australien
                                    #3843
                                    @Kuckuckmann
                                    Ok. Danke. Verstehe.
                                    • T TT-Tom
                                      manylopmy
                                      schrieb am zuletzt editiert von manylopmy
                                      #3844
                                      @tt-tom
                                      Ich habe in der Zwischenzeit gelesen und gemacht. 😊
                                      Mit mittlerem Erfolg. Ich habe verstanden, dass ich einen Player benötige (logisch) und mir verschiedene zur Auswahl stehen. Spotify, Volumio und Sonos.
                                      Habe mit Sonos und Spotify versucht. Ich bekomme auch eine Page und habe ein wenig Zugriff auf mein Sonos. Derzeit habe ich folgenden Eintrag im ts:
                                      let Sonos = <PageMedia>
                                          'type': 'cardMedia',
                                          'heading': 'Sonos',
                                          'useColor': true,
                                          'items': [<PageItem>{
                                                      adapterPlayerInstance: 'alias.0.NSPanel.1.Media.Sonos_1',
                                                      mediaDevice: '192_168_178_86',
                                                      speakerList: ['Wohnzimmer'],
                                                      colorMediaIcon: colorRadio,
                                                      colorMediaArtist: Yellow,
                                                      colorMediaTitle: Yellow,
                                                      autoCreateALias : true
                                      Nun erscheint eine Page in der der Sender, der Titel und ich glaube das Album angezeigt werden. Weiterhin kann ich Next und Prev nutzen. Dazwischen steht auch das Pause-Symbol. das klappt auch, wechselt aber dann nicht in Play-Symbol und läßt auch keinen Start mehr zu.
                                      Seltsam finde ich selber, dass die ID als auch die PlayerInstance identisch sind. Aber ich finde keine wirkliche Alternative.
                                      Kann mir an der Stelle jemand auf die Sprünge helfen?
                                      Zum Schluß hätte ich gerne eine Anzeige, in der auch z.B. Playlist stehen in denen ich Titel aussuchen kann. Aber, - das ist next Step. Zuerst wäre es schön, die Steuerung richtig hinzubekommen.
                                      So sieht die Page aktuell aus.
                                      Gruß Manfred
                                      M T ArmilarA 3 Antworten Letzte Antwort
                                      • M manylopmy
                                        @tt-tom
                                            'heading': 'Sonos',
                                            'useColor': true,
                                        Gruß Manfred
                                        michael_4358
                                        #3845
                                        Hallo
                                        ich habe das problem das ich nun das display nicht ganz mittig habe... kann man die Ansicht zentrieren?
                                        • M manylopmy
                                          @tt-tom
                                              'heading': 'Sonos',
                                              'useColor': true,
                                          Gruß Manfred
                                          TT-Tom
                                          #3846
                                          @manylopmy
                                          Weiter kann ich dir da nicht helfen. Nutze keine Media Page und auch keinen der Adapter.
                                          Gruß Tom
                                          Public Transport
