  4. Kann man einem Datenpunkt eine flexible Werteliste zuweisen?
    5.3k
30 Beiträge 4 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • S schneidy76
    @mickym unglaublich, wie das immer hinzaubern tust...
    Vielen Dank, das bekomme ich jetzt hin!
    mickymM Offline
    mickymM Offline
    mickym
    @schneidy76 So hier nochmal mit trigger Node - die erst nach 10s das Kommando losschickt, wenn keine Eingabe mehr über VIS erfolgt:
    Und im unteren Teil wurden die 3 Change Nodes in einer ChangeNode zusammengefasst:
           "id": "3d2b5291773e6613",
           "type": "ioBroker in",
           "z": "7e6af0015415146d",
           "name": "",
           "topic": "0_userdata.0.Test.Räume.*",
           "payloadType": "value",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "fireOnStart": "false",
           "outFormat": "MQTT",
           "x": 190,
           "y": 3260,
           "wires": [
                   "ee5a3152d31c300a"
           "id": "ee5a3152d31c300a",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "from": ".*\\/(.*)$",
                   "fromt": "re",
                   "to": "$1",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 430,
           "y": 3260,
           "wires": [
                   "a5227d44b8b0b7de"
           "id": "a5227d44b8b0b7de",
           "type": "join",
           "name": "",
           "mode": "custom",
           "build": "object",
           "property": "payload",
           "propertyType": "msg",
           "key": "topic",
           "joiner": "\\n",
           "joinerType": "str",
           "accumulate": true,
           "timeout": "",
           "count": "1",
           "reduceRight": false,
           "reduceExp": "",
           "reduceInit": "",
           "reduceInitType": "",
           "reduceFixup": "",
           "x": 610,
           "y": 3260,
           "wires": [
                   "726d3392d952862d",
                   "304b596c37bc5c42"
           "id": "726d3392d952862d",
           "type": "debug",
           "name": "Objekt Räume",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 800,
           "y": 3200,
           "wires": []
           "id": "8ea80ed297a10f73",
           "type": "ioBroker out",
           "d": true,
           "name": "",
           "topic": "mihome-vacuum.0.control.X_send_command",
           "ack": "false",
           "autoCreate": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1230,
           "y": 3300,
           "wires": []
           "id": "46b3c4894b1c2958",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "\"app_segment_clean;\" & payload",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 830,
           "y": 3360,
           "wires": [
                   "8ea80ed297a10f73",
                   "18eec54d165e4241"
           "id": "810b21206fb366fb",
           "type": "debug",
           "name": "Kommando",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1250,
           "y": 3360,
           "wires": []
           "id": "304b596c37bc5c42",
           "type": "change",
           "name": "Nur zu reinigende Räume",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "$each(payload, function($v, $k) {$v ? $k})",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 810,
           "y": 3260,
           "wires": [
                   "803ce32f1e9acca9",
                   "c937041ba3fb937c"
           "id": "803ce32f1e9acca9",
           "type": "debug",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1090,
           "y": 3200,
           "wires": []
           "id": "c937041ba3fb937c",
           "type": "change",
           "name": "Übersetze in IDs",
           "rules": [
                   "t": "set",
                   "p": "roomIDs",
                   "pt": "msg",
                   "to": "[{\"Name\":\"Büro\",\"id\":18},{\"Name\":\"Wohnzimmer\",\"id\":12},{\"Name\":\"Diele\",\"id\":16},{\"Name\":\"Schlafzimmer\",\"id\":12},{\"Name\":\"Bad\",\"id\":15}]",
                   "tot": "json"
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "$.payload@$n.[roomIDs[Name=$n].id]",
                   "tot": "jsonata"
                   "t": "delete",
                   "p": "roomIDs",
                   "pt": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 620,
           "y": 3360,
           "wires": [
                   "46b3c4894b1c2958",
                   "598044f418769ebd"
           "id": "598044f418769ebd",
           "type": "debug",
           "name": "Array von zu reinigenden Räumen",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 860,
           "y": 3420,
           "wires": []
           "id": "9f5c65591f307250",
           "type": "change",
           "name": "Ändern in Kommando",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "roomIDs",
                   "pt": "msg",
                   "tot": "json"
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "jsonata"
                   "t": "delete",
                   "p": "roomIDs",
                   "pt": "msg"
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 760,
           "y": 3540,
           "wires": [
                   "b8dedf1b1dd5667c"
           "id": "5aaa8a9f14d3827b",
           "name": "",
           "onlyack": "",
           "func": "all",
           "gap": "",
           "x": 150,
           "y": 3540,
           "wires": [
                   "b60aa4d9672068f1"
           "id": "b60aa4d9672068f1",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "change",
                   "p": "topic",
                   "pt": "msg",
                   "fromt": "re",
                   "to": "$1",
                   "tot": "str"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 390,
           "y": 3540,
           "wires": [
                   "dae3215ba6b5d35e"
           "id": "dae3215ba6b5d35e",
           "type": "join",
           "name": "",
           "mode": "custom",
           "build": "object",
           "key": "topic",
           "joiner": "\\n",
           "accumulate": true,
           "timeout": "",
           "count": "1",
           "reduceExp": "",
           "reduceInit": "",
           "reduceFixup": "",
           "x": 570,
           "y": 3540,
           "wires": [
                   "9f5c65591f307250"
           "id": "fd7b420bca79b9e2",
           "type": "debug",
           "name": "Kommando 2",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1190,
           "y": 3620,
           "wires": []
           "id": "9c3f0dc8f7443c47",
           "d": true,
           "name": "",
           "ack": "false",
           "stateName": "",
           "role": "",
           "payloadType": "",
           "readonly": "",
           "stateUnit": "",
           "stateMin": "",
           "stateMax": "",
           "x": 1250,
           "y": 3540,
           "wires": []
           "id": "18eec54d165e4241",
           "type": "trigger",
           "name": "",
           "op1": "",
           "op2": "",
           "op1type": "nul",
           "op2type": "payl",
           "duration": "10",
           "extend": true,
           "overrideDelay": false,
           "units": "s",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 1050,
           "y": 3360,
           "wires": [
                   "810b21206fb366fb"
           "id": "b8dedf1b1dd5667c",
           "type": "trigger",
           "name": "",
           "op1": "",
           "op2": "",
           "op1type": "nul",
           "op2type": "payl",
           "duration": "10",
           "extend": true,
           "units": "s",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 970,
           "y": 3540,
           "wires": [
                   "fd7b420bca79b9e2",
                   "9c3f0dc8f7443c47"
    • mickymM mickym
             "name": "",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 190,
             "y": 3260,
             "wires": [
                     "ee5a3152d31c300a"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "fromt": "re",
                     "to": "$1",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 430,
             "y": 3260,
             "wires": [
                     "a5227d44b8b0b7de"
             "type": "join",
             "name": "",
             "mode": "custom",
             "build": "object",
             "key": "topic",
             "joiner": "\\n",
             "accumulate": true,
             "timeout": "",
             "count": "1",
             "reduceExp": "",
             "reduceInit": "",
             "reduceFixup": "",
             "x": 610,
             "y": 3260,
             "wires": [
                     "726d3392d952862d",
                     "304b596c37bc5c42"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 800,
             "y": 3200,
             "wires": []
             "d": true,
             "name": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1230,
             "y": 3300,
             "wires": []
             "type": "change",
             "name": "",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 830,
             "y": 3360,
             "wires": [
                     "8ea80ed297a10f73",
                     "18eec54d165e4241"
             "type": "debug",
             "name": "Kommando",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1250,
             "y": 3360,
             "wires": []
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 810,
             "y": 3260,
             "wires": [
                     "803ce32f1e9acca9",
                     "c937041ba3fb937c"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1090,
             "y": 3200,
             "wires": []
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "roomIDs",
                     "pt": "msg",
                     "tot": "json"
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "delete",
                     "p": "roomIDs",
                     "pt": "msg"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 620,
             "y": 3360,
             "wires": [
                     "46b3c4894b1c2958",
                     "598044f418769ebd"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 860,
             "y": 3420,
             "wires": []
             "type": "change",
             "rules": [
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "set",
                     "p": "roomIDs",
                     "pt": "msg",
                     "tot": "json"
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
                     "t": "delete",
                     "p": "roomIDs",
                     "pt": "msg"
                     "t": "set",
                     "p": "payload",
                     "pt": "msg",
                     "tot": "jsonata"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 760,
             "y": 3540,
             "wires": [
                     "b8dedf1b1dd5667c"
             "name": "",
             "onlyack": "",
             "func": "all",
             "gap": "",
             "x": 150,
             "y": 3540,
             "wires": [
                     "b60aa4d9672068f1"
             "type": "change",
             "name": "",
             "rules": [
                     "t": "change",
                     "p": "topic",
                     "pt": "msg",
                     "fromt": "re",
                     "to": "$1",
                     "tot": "str"
             "action": "",
             "property": "",
             "from": "",
             "to": "",
             "reg": false,
             "x": 390,
             "y": 3540,
             "wires": [
                     "dae3215ba6b5d35e"
             "type": "join",
             "name": "",
             "mode": "custom",
             "build": "object",
             "key": "topic",
             "joiner": "\\n",
             "accumulate": true,
             "timeout": "",
             "count": "1",
             "reduceExp": "",
             "reduceInit": "",
             "reduceFixup": "",
             "x": 570,
             "y": 3540,
             "wires": [
                     "9f5c65591f307250"
             "type": "debug",
             "active": true,
             "tosidebar": true,
             "console": false,
             "tostatus": false,
             "statusVal": "",
             "x": 1190,
             "y": 3620,
             "wires": []
             "d": true,
             "name": "",
             "ack": "false",
             "stateName": "",
             "role": "",
             "payloadType": "",
             "readonly": "",
             "stateUnit": "",
             "stateMin": "",
             "stateMax": "",
             "x": 1250,
             "y": 3540,
             "wires": []
             "type": "trigger",
             "name": "",
             "op1": "",
             "op2": "",
             "op1type": "nul",
             "op2type": "payl",
             "duration": "10",
             "extend": true,
             "units": "s",
             "reset": "",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 1050,
             "y": 3360,
             "wires": [
                     "810b21206fb366fb"
             "type": "trigger",
             "name": "",
             "op1": "",
             "op2": "",
             "op1type": "nul",
             "op2type": "payl",
             "duration": "10",
             "extend": true,
             "units": "s",
             "reset": "",
             "bytopic": "all",
             "topic": "topic",
             "outputs": 1,
             "x": 970,
             "y": 3540,
             "wires": [
                     "fd7b420bca79b9e2",
                     "9c3f0dc8f7443c47"
      mickymM Offline
      mickymM Offline
      mickym
      Probiere halt mal den Datenpunkt aus, in dem Du das Kommando manuell in den Datenpunkt schreibst.
      • mickymM mickym
        schneidy76
        @mickym Mache ich. Vermutlich werde ich noch einen "Start" Button als Trigger hinzufügen.
        Dann kann ich das Reinigen definiert auslösen.
        Raspberry Matic (RP3), LIVE PV Monitoring mit Smartmeter, Poolsteuerung mit NodeRed, KNX Ausbau (ersetzt stückweise HM & klassische Installation), ioBroker Multihost (RP4 &RP2), Visu mit VIS
        • S schneidy76
          mickymM Offline
          mickymM Offline
          mickym
          @schneidy76 Dann würde ich es aber über die List Node und Arrays holen - ich modifiziere mal den Flow entsprechend - dann kann man sich die JOIN Node und die TRIGGER Node sparen.
          Wenn der Name richtig gepflegt ist kann man es direkt über den Namen anprechen - über die Id muss man halt wieder extrahieren.
          So hier nun einen Flow - mit definiertem Trigger:
          dann kann man zum Testen auch eine Inject Node nehmen.
          Wenn der Name des Datenpunktes den Raumnamen enthält (siehe obere Change Node), dann kann man auch direkt auf das common Objekt zugreifen:
          Ansonsten muss man es aus der _id extrahieren.
          da muss ich auch immer bissi tüfteln.
          Der Rest bleibt gleich - hier der Import:
                 "id": "1196504985c5fb01",
                 "name": "",
                 "topic": "0_userdata.0.Test.boolean",
                 "onlyack": "",
                 "func": "all",
                 "gap": "",
                 "x": 190,
                 "y": 3820,
                 "wires": [
                         "8d6e4906189268ed"
                 "id": "8d6e4906189268ed",
                 "type": "ioBroker list",
                 "name": "",
                 "objType": "state",
                 "regex": "",
                 "asArray": "true",
                 "onlyIDs": "false",
                 "withValues": "true",
                 "x": 460,
                 "y": 3820,
                 "wires": [
                         "4ebc0b43e8dbfce7",
                         "e0ea39dbf512239f",
                         "54930b2003e7dede"
                 "id": "a17efaa7e3e9890a",
                 "type": "inject",
                 "name": "Trigger",
                 "props": [
                         "p": "payload"
                 "repeat": "",
                 "crontab": "",
                 "once": false,
                 "onceDelay": 0.1,
                 "topic": "",
                 "payload": "true",
                 "payloadType": "bool",
                 "x": 230,
                 "y": 3880,
                 "wires": [
                         "8d6e4906189268ed"
                 "id": "4ebc0b43e8dbfce7",
                 "type": "debug",
                 "name": "Array aller Datenpunkte",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 750,
                 "y": 3780,
                 "wires": []
                 "id": "e0ea39dbf512239f",
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload[val].common.name",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 750,
                 "y": 3820,
                 "wires": [
                         "d5098e9ac9d1ceec"
                 "id": "d5098e9ac9d1ceec",
                 "type": "debug",
                 "name": "Array mit zu reinigenden Datenpunkten über Namen",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1100,
                 "y": 3820,
                 "wires": []
                 "id": "54930b2003e7dede",
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "to": "payload[val].(_id ~> /.*\\.(.*)$/).groups[0]",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 750,
                 "y": 3860,
                 "wires": [
                         "3b8e94117f9bb7b3",
                         "d97052c98b8b1318"
                 "id": "3b8e94117f9bb7b3",
                 "type": "debug",
                 "name": "Array mit zu reinigenden Datenpunkten über ID",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1080,
                 "y": 3860,
                 "wires": []
                 "id": "d97052c98b8b1318",
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "roomIDs",
                         "pt": "msg",
                         "tot": "json"
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                         "t": "delete",
                         "p": "roomIDs",
                         "pt": "msg"
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 980,
                 "y": 3920,
                 "wires": [
                         "94bff5ad30ded90c",
                         "b8c3b3fbcc0306a6"
                 "id": "b8c3b3fbcc0306a6",
                 "type": "debug",
                 "name": "Kommando 3",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 1170,
                 "y": 3960,
                 "wires": []
                 "id": "94bff5ad30ded90c",
                 "d": true,
                 "name": "",
                 "ack": "false",
                 "stateName": "",
                 "role": "",
                 "payloadType": "",
                 "readonly": "",
                 "stateUnit": "",
                 "stateMin": "",
                 "stateMax": "",
                 "x": 1270,
                 "y": 3920,
                 "wires": []
          • mickymM Offline
            mickymM Offline
            mickym
            Ich habe noch eine Ergänzung.
            In der Doku steht ein Array für die Indizes:
            Wenn Du nur 1 Raum selektierst, dann wird daraus in dem Flow ein skalarer Wert:
            Wenn also in jedem Fall ein Array entstehen soll auch mit EINEM Element dann musst Du in der Change Node noch folgendes ergänzen:
            also noch den Teil hinten ergänzen, dann kommt immer ein Array raus:
            ~>$append([])
            also vollständig:
            $.payload@$n.[roomIDs[Name=$n].id]~>$append([])
            • mickymM mickym
              ~>$append([])
              also vollständig:
              schneidy76
              schrieb am zuletzt editiert von schneidy76
              @mickym Hi, irgendwas habe ich kräftig vermasselt. Der Aufruf über den Trigger hat gerade ioBroker lahm gelegt...😄
              Was ich versucht habe den ersten Flow mit dem Trigger zu kombinieren...
                      "type": "change",
                      "z": "db97e840ec20025f",
                      "name": "",
                      "rules": [
                              "t": "change",
                              "p": "topic",
                              "pt": "msg",
                              "fromt": "re",
                              "to": "$1",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 390,
                      "y": 100,
                      "wires": [
                              "a5227d44b8b0b7de"
                      "type": "join",
                      "name": "",
                      "mode": "custom",
                      "build": "object",
                      "key": "topic",
                      "joiner": "\\n",
                      "accumulate": true,
                      "timeout": "",
                      "count": "1",
                      "reduceExp": "",
                      "reduceInit": "",
                      "reduceFixup": "",
                      "x": 570,
                      "y": 100,
                      "wires": [
                              "726d3392d952862d",
                              "304b596c37bc5c42"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 760,
                      "y": 40,
                      "wires": []
                      "name": "send command",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1000,
                      "y": 160,
                      "wires": []
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 790,
                      "y": 200,
                      "wires": [
                              "810b21206fb366fb",
                              "8ea80ed297a10f73"
                      "type": "debug",
                      "name": "Kommando",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 990,
                      "y": 200,
                      "wires": []
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "jsonata"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 770,
                      "y": 100,
                      "wires": [
                              "803ce32f1e9acca9",
                              "c937041ba3fb937c"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 1050,
                      "y": 40,
                      "wires": []
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "roomIDs",
                              "pt": "msg",
                              "to": "[{\"Name\":\"Wohnzimmer\",\"id\":16},{\"Name\":\"Esszimmer\",\"id\":18},{\"Name\":\"Küche\",\"id\":17},{\"Name\":\"Gang\",\"id\":22},{\"Name\":\"Bad\",\"id\":21},{\"Name\":\"Schlafzimmer\",\"id\":19},{\"Name\":\"Büro\",\"id\":20},{\"Name\":\"Treppenhaus\",\"id\":23},{\"Name\":\"Speiß\",\"id\":24}]",
                              "tot": "json"
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "jsonata"
                              "t": "delete",
                              "p": "roomIDs",
                              "pt": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 520,
                      "y": 200,
                      "wires": [
                              "46b3c4894b1c2958",
                              "598044f418769ebd"
                      "type": "debug",
                      "active": true,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "statusVal": "",
                      "x": 820,
                      "y": 260,
                      "wires": []
                      "id": "edd702cba8f8c6b9",
                      "name": "Start Multiroom",
                      "topic": "0_userdata.0.Räume.control.Start_Multiroom",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 100,
                      "y": 60,
                      "wires": [
                              "8d6e4906189268ed"
                      "name": "",
                      "topic": "0_userdata.0.Räume.*",
                      "objType": "state",
                      "regex": "",
                      "asArray": "true",
                      "onlyIDs": "false",
                      "x": 180,
                      "y": 100,
                      "wires": [
                              "ee5a3152d31c300a"
              Debug:
              26.9.2023, 17:45:36node: Objekt Räume
              Start_Multiroom : msg.payload : Object
              { Start_Multiroom: array[10] }
              26.9.2023, 17:45:37node: Nur zu reinigende Räume
              Start_Multiroom : msg.payload : string[15]
              "Start_Multiroom"
              26.9.2023, 17:45:38node: Array von zu reinigenden Räumen
              Start_Multiroom : msg.payload : undefined
              undefined
              26.9.2023, 17:45:39node: Kommando
              Start_Multiroom : msg.payload : string[18]
              "app_segment_clean;"
              26.9.2023, 17:45:39node: Objekt Räume
              26.9.2023, 17:45:39node: Nur zu reinigende Räume
              "Start_Multiroom"
              26.9.2023, 17:45:39node: Array von zu reinigenden Räumen
              undefined
              "Start_Multiroom"
              undefined
              26.9.2023, 17:46:06node: Objekt Räume
              26.9.2023, 17:46:07node: Nur zu reinigende Räume
              "Start_Multiroom"
              26.9.2023, 17:46:08node: Array von zu reinigenden Räumen
              undefined
              26.9.2023, 17:46:08node: Kommando
              26.9.2023, 17:46:08node: Objekt Räume
              26.9.2023, 17:46:08node: Nur zu reinigende Räume
              "Start_Multiroom"
              undefined
              "Start_Multiroom"
              undefined
              • S schneidy76
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "change",
                                "p": "topic",
                                "pt": "msg",
                                "fromt": "re",
                                "to": "$1",
                                "tot": "str"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 390,
                        "y": 100,
                        "wires": [
                                "a5227d44b8b0b7de"
                        "type": "join",
                        "name": "",
                        "mode": "custom",
                        "build": "object",
                        "key": "topic",
                        "joiner": "\\n",
                        "accumulate": true,
                        "timeout": "",
                        "count": "1",
                        "reduceExp": "",
                        "reduceInit": "",
                        "reduceFixup": "",
                        "x": 570,
                        "y": 100,
                        "wires": [
                                "726d3392d952862d",
                                "304b596c37bc5c42"
                        "type": "debug",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 760,
                        "y": 40,
                        "wires": []
                        "ack": "false",
                        "stateName": "",
                        "role": "",
                        "payloadType": "",
                        "readonly": "",
                        "stateUnit": "",
                        "stateMin": "",
                        "stateMax": "",
                        "x": 1000,
                        "y": 160,
                        "wires": []
                        "type": "change",
                        "name": "",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 790,
                        "y": 200,
                        "wires": [
                                "810b21206fb366fb",
                                "8ea80ed297a10f73"
                        "type": "debug",
                        "name": "Kommando",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 990,
                        "y": 200,
                        "wires": []
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 770,
                        "y": 100,
                        "wires": [
                                "803ce32f1e9acca9",
                                "c937041ba3fb937c"
                        "type": "debug",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 1050,
                        "y": 40,
                        "wires": []
                        "type": "change",
                        "rules": [
                                "t": "set",
                                "p": "roomIDs",
                                "pt": "msg",
                                "tot": "json"
                                "t": "set",
                                "p": "payload",
                                "pt": "msg",
                                "tot": "jsonata"
                                "t": "delete",
                                "p": "roomIDs",
                                "pt": "msg"
                        "action": "",
                        "property": "",
                        "from": "",
                        "to": "",
                        "reg": false,
                        "x": 520,
                        "y": 200,
                        "wires": [
                                "46b3c4894b1c2958",
                                "598044f418769ebd"
                        "type": "debug",
                        "active": true,
                        "tosidebar": true,
                        "console": false,
                        "tostatus": false,
                        "statusVal": "",
                        "x": 820,
                        "y": 260,
                        "wires": []
                        "onlyack": "",
                        "func": "all",
                        "gap": "",
                        "x": 100,
                        "y": 60,
                        "wires": [
                                "8d6e4906189268ed"
                        "name": "",
                        "objType": "state",
                        "regex": "",
                        "asArray": "true",
                        "onlyIDs": "false",
                        "x": 180,
                        "y": 100,
                        "wires": [
                                "ee5a3152d31c300a"
                Debug:
                "Start_Multiroom"
                undefined
                "Start_Multiroom"
                undefined
                "Start_Multiroom"
                undefined
                "Start_Multiroom"
                undefined
                "Start_Multiroom"
                undefined
                "Start_Multiroom"
                undefined
                mickymM Offline
                mickymM Offline
                mickym
                @schneidy76 Nun dann deaktiviere halt mal die iobroker -out Node und prüge die Ausgabe bzw. poste alle Ausgaben aus den Denug nodes. Wenn das Array aus den zu reinigen Räumen undefinded ist, dann stimmt da ja schon was nicht. Du musst halt step für step vorgehen
                • mickymM mickym
                  schneidy76
                  @mickym habe den Fehler, mit der IN Node geht es. Nehme ich die IN Node als Trigger in Verbindung mit der GET Objects Node, schmiert es mir ab.
                  Also bleibt das hier, aber wo kann ich die Namen pflegen?
                  Wenn der Name richtig gepflegt ist kann man es direkt über den Namen anprechen - über die Id muss man halt wieder extrahieren. ```
                  • S schneidy76
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @schneidy76 sagte in Kann man einem Datenpunkt eine flexible Werteliste zuweisen?:
                    • mickymM mickym
                      schneidy76
                      @mickym super, jetzt passt es. Nehme den 2. Weg über die IDs. Die Debug Ausgabe passt jetzt.
                      Habe noch eine Verzögerung rein (1msg/2sek) falls der Daumen nervös ist.
                      Bastel mir nun noch ne Lösung, dass alle Räume wieder auf false gesetzt werden, wenn der Robi zurückfährt. Geht ja wahrscheinlich auch über eine Out Node ins Räume Verzeichnis.
                      Dann fehlt mir noch ein Popup, in der Vis, in der ich für jeden Raum den Reinigungsmodus definieren kann. Der Anfang ist geschafft!!! 💪
                      Danke für Deine Geduld! 😁
                      • mickymM mickym
                        Ich glaube das wirst Du Pech haben - man kann nicht mal mit Javascript die enums modifizieren. Dieses Raum, Funktionskonzept ist meines Erachtens eh nicht durchdacht, da dieses komplett ausserhalb der Objekte steht. Ich würde den Adapterentwickler eher bitten, eine andere Möglichkeit zum Beispiel durch Arrays oder Objekte zu finden.
                        T Nicht stören
                        T Nicht stören
                        ticaki
                        @mickym sagte in Kann man einem Datenpunkt eine flexible Werteliste zuweisen?:
                        Vielleicht verstehe ich dich falsch jedoch mit dieser Funktion:
                        async function addToEnum(enumName, newStateId) {
                            if (!await existsObjectAsync(newStateId)) {
                                log(newStateId + ' not exist!', 'warn')
                                return false;
                            let myEnum = await getObjectAsync(enumName);
                            if (myEnum) {
                                let pos = myEnum.common.members.indexOf(newStateId);
                                if (pos === -1) {
                                    try {
                                        myEnum.common.members.push(newStateId);
                                        myEnum.from = "system.adapter." + "0";
                                        myEnum.ts = new Date().getTime();
                                        await setObjectAsync(enumName, myEnum);
                                        return true;
                                    } catch (e) {log(e + ' add id: ' + newStateId,'error')}
                            return false;
                        kannst du einem enum ein neues Mitglied verpassen.
                        Spenden
