  4. Echarts Presets verschwinden
    5.2k
51 Beiträge 4 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • B Bambulko
    ioBroker nodejs fixer 2023-09-20
    No recommendation for nodejs version found on your system. We recommend to install latest version from nodejs v18 tree.
    Your current setup is:
    /usr/bin/nodejs 	v10.19.0
    /usr/bin/node 		v10.19.0
    /usr/bin/npm 		6.14.4
    /usr/bin/npx 		6.14.4
    We found these nodejs versions available for installation:
    nodejs:
      Installed: 10.19.0~dfsg-3ubuntu1.1
      Candidate: 10.19.0~dfsg-3ubuntu1.1
      Version table:
     *** 10.19.0~dfsg-3ubuntu1.1 500
            500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
            500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    Nothing to do - Your installation is using the correct paths.
    You are running nodejs v10.19.0. Do you want to install recommended version v.18 ?
    Press <y> to continue or any other key to quit
    Trying to fix your installation now. Please be patient.
    find: '/run/user/1000/doc': Permission denied
    find: '/run/user/1000/gvfs': Permission denied
    rm: cannot remove '/var/lib/docker/overlay2/4f8b3a7f2e3d57afd657fc6acbbb6fdebf89b855621399d181d3222c414fc29b/diff/usr/share/keyrings/nodesource.gpg'$'\n''/var/lib/docker/overlay2/9b040315e5e2b23c9f7293e95a5435e2ccf7a47dd0bfbfebe945650f6ce108e0/merged/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg': No such file or directory
    Waiting for ioBroker to shut down - Give me a minute...
    *** These repos are active on your system:
    Hit:1 http://security.ubuntu.com/ubuntu focal-security InRelease
    Hit:2 https://phoscon.de/apt/deconz focal InRelease
    Hit:3 http://de.archive.ubuntu.com/ubuntu focal InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:5 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
    Reading package lists... Done
    N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://phoscon.de/apt/deconz focal InRelease' doesn't support architecture 'i386'
    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_18.x nodistro main
    Package: nodejs
    Pin: origin deb.nodesource.com
    Pin-Priority: 1001
    *** These repos are active after the adjustments:
    Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
    Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
    Hit:3 http://security.ubuntu.com/ubuntu focal-security InRelease
    Hit:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
    Get:5 https://deb.nodesource.com/node_18.x nodistro InRelease [12.1 kB]
    Hit:6 https://phoscon.de/apt/deconz focal InRelease
    Get:7 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages [5247 B]
    Fetched 17.4 kB in 3s (6650 B/s)
    N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://deb.nodesource.com/node_18.x nodistro InRelease' doesn't support architecture 'i386'
    Installing the recommended nodejs version now!
    Exact recommended version unknown, installing a fallback!
    Building dependency tree
    The following packages were automatically installed and are no longer required:
      gir1.2-goa-1.0 gyp javascript-common libc-ares2 libfwupdplugin1 libjs-inherits libjs-is-typedarray libjs-psl libjs-typedarray-to-buffer libpython2-stdlib libpython2.7-minimal
      libpython2.7-stdlib libssl-dev libunity-gtk2-parser0 libunity-gtk3-parser0 libuv1-dev libxmlb1 node-abbrev node-ajv node-ansi node-ansi-align node-ansi-regex node-ansi-styles
      node-ansistyles node-aproba node-archy node-are-we-there-yet node-asap node-asn1 node-assert-plus node-asynckit node-aws-sign2 node-aws4 node-balanced-match node-bcrypt-pbkdf
      node-bl node-bluebird node-boxen node-brace-expansion node-builtin-modules node-builtins node-cacache node-call-limit node-camelcase node-caseless node-chalk node-chownr
      node-ci-info node-cli-boxes node-cliui node-clone node-co node-color-convert node-color-name node-colors node-columnify node-combined-stream node-concat-map node-concat-stream
      node-config-chain node-configstore node-console-control-strings node-copy-concurrently node-core-util-is node-cross-spawn node-crypto-random-string node-cyclist node-dashdash
      node-debug node-decamelize node-decompress-response node-deep-extend node-defaults node-define-properties node-delayed-stream node-delegates node-detect-indent
      node-detect-newline node-dot-prop node-duplexer3 node-duplexify node-ecc-jsbn node-editor node-encoding node-end-of-stream node-err-code node-errno node-es6-promise
      node-escape-string-regexp node-execa node-extend node-extsprintf node-fast-deep-equal node-find-up node-flush-write-stream node-forever-agent node-form-data node-from2
      node-fs-vacuum node-fs-write-stream-atomic node-fs.realpath node-function-bind node-gauge node-genfun node-get-caller-file node-get-stream node-getpass node-glob node-got
      node-graceful-fs node-har-schema node-har-validator node-has-flag node-has-symbol-support-x node-has-to-string-tag-x node-has-unicode node-hosted-git-info node-http-signature
      node-iconv-lite node-iferr node-import-lazy node-imurmurhash node-inflight node-inherits node-ini node-invert-kv node-ip node-ip-regex node-is-npm node-is-obj node-is-object
      node-is-path-inside node-is-plain-obj node-is-retry-allowed node-is-stream node-is-typedarray node-isarray node-isexe node-isstream node-isurl node-jsbn
      node-json-parse-better-errors node-json-schema node-json-schema-traverse node-json-stable-stringify node-json-stringify-safe node-jsonify node-jsonparse node-jsonstream
      node-jsprim node-latest-version node-lazy-property node-lcid node-libnpx node-locate-path node-lockfile node-lodash node-lodash-packages node-lowercase-keys node-lru-cache
      node-make-dir node-mem node-mime node-mime-types node-mimic-fn node-mimic-response node-minimatch node-minimist node-mississippi node-mkdirp node-move-concurrently node-ms
      node-mute-stream node-nopt node-normalize-package-data node-npm-bundled node-npm-package-arg node-npm-run-path node-npmlog node-number-is-nan node-oauth-sign node-object-assign
      node-once node-opener node-os-locale node-os-tmpdir node-osenv node-p-cancelable node-p-finally node-p-is-promise node-p-limit node-p-locate node-p-timeout node-package-json
      node-parallel-transform node-path-exists node-path-is-absolute node-path-is-inside node-performance-now node-pify node-prepend-http node-process-nextick-args
      node-promise-inflight node-promise-retry node-promzard node-proto-list node-prr node-pseudomap node-psl node-pump node-pumpify node-punycode node-qs node-qw node-rc node-read
      node-read-package-json node-readable-stream node-registry-auth-token node-registry-url node-request node-require-directory node-require-main-filename node-resolve
      node-resolve-from node-retry node-rimraf node-run-queue node-safe-buffer node-semver node-semver-diff node-set-blocking node-sha node-shebang-command node-shebang-regex
      node-signal-exit node-slash node-slide node-sorted-object node-spdx-correct node-spdx-exceptions node-spdx-expression-parse node-spdx-license-ids node-sshpk node-ssri
      node-stream-each node-stream-iterate node-stream-shift node-strict-uri-encode node-string-decoder node-string-width node-strip-ansi node-strip-eof node-strip-json-comments
      node-supports-color node-tar node-term-size node-text-table node-through node-through2 node-timed-out node-tough-cookie node-tunnel-agent node-tweetnacl node-typedarray
      node-typedarray-to-buffer node-uid-number node-unique-filename node-unique-string node-unpipe node-uri-js node-url-parse-lax node-url-to-options node-util-deprecate node-uuid
      node-validate-npm-package-license node-validate-npm-package-name node-verror node-wcwidth.js node-which node-which-module node-wide-align node-widest-line node-wrap-ansi
      node-wrappy node-write-file-atomic node-xdg-basedir node-xtend node-y18n node-yallist node-yargs node-yargs-parser python-pkg-resources python2 python2-minimal python2.7
      python2.7-minimal unity-gtk-module-common
    Use 'sudo apt autoremove' to remove them.
    The following packages will be REMOVED:
      libnode-dev libnode64 node-gyp nodejs-doc npm
    The following packages will be upgraded:
      nodejs
    1 upgraded, 0 newly installed, 5 to remove and 1 not upgraded.
    Need to get 29.4 MB of archives.
    After this operation, 153 MB of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_18.x nodistro/main amd64 nodejs amd64 18.17.0-1nodesource1 [29.4 MB]
    Fetched 29.4 MB in 4s (6746 kB/s)
    (Reading database ... 330244 files and directories currently installed.)
    Removing npm (6.14.4+ds-1ubuntu2) ...
    Removing node-gyp (6.1.0-3) ...
    Removing libnode-dev:amd64 (10.19.0~dfsg-3ubuntu1.1) ...
    Removing nodejs-doc (10.19.0~dfsg-3ubuntu1.1) ...
    dpkg: libnode64:amd64: dependency problems, but removing anyway as you requested:
     nodejs depends on libnode64 (= 10.19.0~dfsg-3ubuntu1.1).
    Removing libnode64:amd64 (10.19.0~dfsg-3ubuntu1.1) ...
    (Reading database ... 328802 files and directories currently installed.)
    Preparing to unpack .../nodejs_18.17.0-1nodesource1_amd64.deb ...
    Unpacking nodejs (18.17.0-1nodesource1) over (10.19.0~dfsg-3ubuntu1.1) ...
    Setting up nodejs (18.17.0-1nodesource1) ...
    Processing triggers for libc-bin (2.31-0ubuntu9.9) ...
    Processing triggers for man-db (2.9.1-1) ...
    Updating fallback to latest nodejs v18 release
    Calculating upgrade... Done
      nodejs ubuntu-advantage-tools
    2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 190 kB/29.7 MB of archives.
    After this operation, 920 kB of additional disk space will be used.
    Get:1 http://de.archive.ubuntu.com/ubuntu focal-updates/main amd64 ubuntu-advantage-tools amd64 29.4~20.04 [190 kB]
    Fetched 190 kB in 0s (920 kB/s)
    Preconfiguring packages ...
    (Reading database ... 334483 files and directories currently installed.)
    Preparing to unpack .../ubuntu-advantage-tools_29.4~20.04_amd64.deb ...
    Unpacking ubuntu-advantage-tools (29.4~20.04) over (28.1~20.04) ...
    Preparing to unpack .../nodejs_18.18.0-1nodesource1_amd64.deb ...
    Detected old npm client, removing...
    Unpacking nodejs (18.18.0-1nodesource1) over (18.17.0-1nodesource1) ...
    Setting up nodejs (18.18.0-1nodesource1) ...
    Setting up ubuntu-advantage-tools (29.4~20.04) ...
    Installing new version of config file /etc/ubuntu-advantage/help_data.yaml ...
    We tried our best to fix your nodejs. Please run iob diag again to verify.
    *** RESTARTING ioBroker NOW! ***
     Please refresh or restart your browser in a few moments.
    @bambulko sagte in Echarts Presets verschwinden:
    i386
    kein amd64?
    • B Bambulko
      /usr/bin/npm 		6.14.4
      /usr/bin/npx 		6.14.4
      nodejs:
        Version table:
      Package: nodejs
      Pin-Priority: 1001
        nodejs
      Bambulko
      @bambulko Ok Fortschritt:
      		     v.2023-06-20
         Static hostname: Nuc
               Icon name: computer-desktop
                 Chassis: desktop
              Machine ID: ad3458d0640e4781a50233d6b3388c72
                 Boot ID: 0f842b6f9206477d90dac70147d5fedf
        Operating System: Ubuntu 20.04.6 LTS
                  Kernel: Linux 5.15.0-84-generic
            Architecture: x86-64
      Installation: 		native
      Kernel: 		x86_64
      Userland: 		amd64
      Timezone: 		Europe/Berlin (CEST, +0200)
      User-ID: 		1000
      X-Server: 		true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Error: Object "system.config" not found
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.18.0
      			/usr/bin/node 		v18.18.0
      			/usr/bin/npm 		9.8.1
      			/usr/bin/npx 		9.8.1
      Recommended versions are nodejs 18.x.y and npm 9.x.y
      MEMORY:
      Mem:            15G        4.1G        5.6G        547M        5.4G         10G
      Swap:          2.0G          0B        2.0G
      Total:          17G        4.1G        7.6G
      Active iob-Instances: 	1
      List is empty
       Cannot read system.config: null (OK when migrating or restoring)
      ioBroker Core: 		js-controller 		4.0.24
      			admin 			6.3.5
      ioBroker Status: 	 Cannot read system.config: null (OK when migrating or restoring)
      Objects type: jsonl
      States  type: jsonl
      Objects: 		33
      States: 		26
      Size of iob-Database:
      36K	/opt/iobroker/iobroker-data/objects.jsonl
      92K	/opt/iobroker/iobroker-data/states.jsonl
      nodejs scheint jetzt zu laufen, aber 'Cannot read system.config: null (OK when migrating or restoring)' kommt immer noch.
        i386
        kein amd64?
        Irgendwas ganz schräges.
        @Bambulko
        Lass das Skript nun noch mal laufen.
          @Bambulko
          Bambulko
          schrieb am zuletzt editiert von Bambulko
          • B Bambulko
            @bambulko
            Da müssen zwei Zeilen mit 'Nothing to do' kommen.
            Und schmeiß den ganzen anderen node-Krempel raus:
            sudo apt autoremove
              @bambulko
              sudo apt autoremove
              Bambulko
              @thomas-braun Ich bekomme immer das hier, egal wie oft ich das skript laufen lasse.
              You are running nodejs v18.18.0. Do you want to install recommended version v.18 ?
              Das Skript installiert immer 18.17 ueber 18.18, und dann 18.18 ueber 18.17.
              • B Bambulko
                @bambulko
                Ja, stimmt. Wenn keine recommended version im ioBroker gefunden werden kann dann kommt das so.
                cd /opt/iobroker/
                sudo -H -u iobroker npm install iobroker.js-controller
                  @bambulko
                  cd /opt/iobroker/
                  Bambulko
                  @thomas-braun said in Echarts Presets verschwinden:
                  cd /opt/iobroker/
                  up to date in 2s
                  49 packages are looking for funding
                    run `npm fund` for details
                  • B Bambulko
                    cd /opt/iobroker/
                    up to date in 2s
                    @bambulko
                    Bitte immer VOLLSTÄNDIGE Ein- wie Ausgaben posten.
                      @bambulko
                      Bambulko
                      Nuc:/opt/iobroker$ cd /opt/iobroker/
                      Nuc:/opt/iobroker$
                      Nuc:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                      up to date in 2s
                      • B Bambulko
                        Nuc:/opt/iobroker$
                        up to date in 2s
                        @bambulko
                        iob update
                        iob status
                          @bambulko
                          iob update
                          iob status
                          Bambulko
                          Nuc:/opt/iobroker$ iob update
                          Nuc:/opt/iobroker$ iob status
                          Objects type: jsonl
                          States  type: jsonl
                          • B Bambulko
                            Objects type: jsonl
                            States  type: jsonl
                            @bambulko Hast du die unnützen node-* Pakete rausgeworfen?
                              Bambulko
                              @thomas-braun Ja.
                              • B Bambulko
                                @thomas-braun Ja.
                                @bambulko
                                iob diag
                                in der langen Version.
                                  @bambulko
                                  iob diag
                                  Bambulko
                                  Skript v.2023-06-20
                                  *** BASE SYSTEM ***
                                             Chassis: desktop
                                  model name	: Intel(R) Celeron(R) J4005 CPU @ 2.00GHz
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : x86_64
                                  Userland        : amd64
                                  Systemuptime and Load:
                                   22:30:18 up  2:12,  2 users,  load average: 3.77, 3.16, 2.50
                                  CPU threads: 2
                                  *** Time and Time Zones ***
                                                 Local time: Thu 2023-09-21 22:30:18 CEST
                                             Universal time: Thu 2023-09-21 20:30:18 UTC
                                                   RTC time: Thu 2023-09-21 20:30:18
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  user
                                  /home/user
                                  user adm dialout cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
                                  *** X-Server-Setup ***
                                  X-Server: 	true
                                  Desktop: 	mate
                                  Terminal: 	x11
                                  *** MEMORY ***
                                  Mem:            15G        4.3G        5.2G        577M        5.6G         10G
                                  Swap:          2.0G          0B        2.0G
                                  Total:          17G        4.3G        7.3G
                                          15133 M total memory
                                           4343 M used memory
                                           2232 M active memory
                                           5909 M inactive memory
                                           5234 M free memory
                                            936 M buffer memory
                                           4619 M swap cache
                                           2047 M total swap
                                              0 M used swap
                                           2047 M free swap
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  7.4G     0  7.4G   0% /dev
                                  tmpfs          tmpfs     1.5G  1.8M  1.5G   1% /run
                                  /dev/sda2      ext4      938G  144G  747G  17% /
                                  tmpfs          tmpfs     7.4G     0  7.4G   0% /dev/shm
                                  tmpfs          tmpfs     7.4G     0  7.4G   0% /sys/fs/cgroup
                                  /dev/loop0     squashfs  128K  128K     0 100% /snap/bare/5
                                  /dev/loop1     squashfs   56M   56M     0 100% /snap/core18/2785
                                  /dev/loop2     squashfs   64M   64M     0 100% /snap/core20/2015
                                  /dev/loop4     squashfs   64M   64M     0 100% /snap/core20/1974
                                  /dev/loop3     squashfs   74M   74M     0 100% /snap/core22/864
                                  /dev/loop6     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                                  /dev/loop8     squashfs  486M  486M     0 100% /snap/gnome-42-2204/120
                                  /dev/loop7     squashfs   82M   82M     0 100% /snap/gtk-common-themes/1534
                                  /dev/loop9     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/140
                                  /dev/loop5     squashfs   74M   74M     0 100% /snap/core22/858
                                  /dev/loop12    squashfs  486M  486M     0 100% /snap/gnome-42-2204/126
                                  /dev/loop13    squashfs   95M   95M     0 100% /snap/noson/579
                                  /dev/loop16    squashfs   41M   41M     0 100% /snap/snapd/20092
                                  /dev/loop15    squashfs   46M   46M     0 100% /snap/snap-store/638
                                  /dev/loop14    squashfs   13M   13M     0 100% /snap/snap-store/959
                                  /dev/loop10    squashfs   56M   56M     0 100% /snap/core18/2790
                                  /dev/loop11    squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                                  /dev/loop17    squashfs   41M   41M     0 100% /snap/snapd/19993
                                  /dev/sda1      vfat      511M  6.1M  505M   2% /boot/efi
                                  tmpfs          tmpfs     1.5G   56K  1.5G   1% /run/user/1000
                                  [Thu Sep 21 20:17:22 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                  [Thu Sep 21 20:17:23 2023] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                                  TARGET                         SOURCE      FSTYPE   OPTIONS
                                  /                              /dev/sda2   ext4     rw,relatime,errors=remount-ro
                                  |-/sys/kernel/tracing          tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
                                  |-/snap/bare/5                 /dev/loop0  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core18/2785            /dev/loop1  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core20/2015            /dev/loop2  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core20/1974            /dev/loop4  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core22/864             /dev/loop3  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/gtk-common-themes/1535 /dev/loop6  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/gnome-42-2204/120      /dev/loop8  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/gtk-common-themes/1534 /dev/loop7  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/gnome-3-38-2004/140    /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core22/858             /dev/loop5  squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/gnome-42-2204/126      /dev/loop12 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/noson/579              /dev/loop13 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/snapd/20092            /dev/loop16 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/snap-store/638         /dev/loop15 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/snap-store/959         /dev/loop14 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/core18/2790            /dev/loop10 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/gnome-3-38-2004/143    /dev/loop11 squashfs ro,nodev,relatime,errors=continue
                                  |-/snap/snapd/19993            /dev/loop17 squashfs ro,nodev,relatime,errors=continue
                                  `-/boot/efi                    /dev/sda1   vfat     rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
                                  /var:
                                  12G	/var/
                                  6.8G	/var/lib
                                  4.1G	/var/log/journal/ad3458d0640e4781a50233d6b3388c72
                                  4.1G	/var/log
                                  Archived and active journals take up 4.0G in the file system.
                                  /opt/iobroker/backups:
                                  du: cannot access '/opt/iobroker/backups/': No such file or directory
                                  /opt/iobroker/iobroker-data:
                                  15M	/opt/iobroker/iobroker-data/files
                                  13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                  6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                  2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                  1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                  652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
                                  384K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js
                                  *** NodeJS-Installation ***
                                  /usr/bin/npm 		9.8.1
                                  /usr/bin/npx 		9.8.1
                                  nodejs:
                                    Installed: 18.18.0-1nodesource1
                                    Candidate: 18.18.0-1nodesource1
                                    Version table:
                                   *** 18.18.0-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  No problems detected
                                  Errors in npm tree: 0
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  No configuration change needed.
                                  Multihost discovery server: disabled
                                  Discovery authentication:   enabled
                                  Persistent activation:      disabled
                                  Objects:                    jsonl on 127.0.0.1
                                  States:                     jsonl on 127.0.0.1
                                  Core adapters versions
                                  js-controller: 	4.0.24
                                  admin: 		6.3.5
                                  javascript: 	"javascript" not found
                                  Adapters from github: 	0
                                  Adapter State
                                  + instance is alive
                                  ioBroker-Repositories
                                  List is empty
                                  Installed ioBroker-Instances
                                  Objects and States
                                  Objects: 	33
                                  States: 	26
                                  Hit:2 http://de.archive.ubuntu.com/ubuntu focal InRelease
                                  Hit:3 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
                                  Hit:5 https://phoscon.de/apt/deconz focal InRelease
                                  Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       57763      3637/deCONZ
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      130        37850      903/influxd
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          38201      931/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          19537      1/init
                                  tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          38914      743/cupsd
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      0          44737      2094/docker-proxy
                                  tcp        0      0 127.0.0.1:39365         0.0.0.0:*               LISTEN      0          39021      912/containerd
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       752286     111136/iobroker.js-
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       753258     111136/iobroker.js-
                                  tcp        0      0 0.0.0.0:8091            0.0.0.0:*               LISTEN      0          43886      1978/docker-proxy
                                  tcp        0      0 0.0.0.0:8082            0.0.0.0:*               LISTEN      0          43977      2027/docker-proxy
                                  tcp        0      0 0.0.0.0:8083            0.0.0.0:*               LISTEN      0          43927      2000/docker-proxy
                                  tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       57617      3637/deCONZ
                                  tcp        0      0 0.0.0.0:8081            0.0.0.0:*               LISTEN      0          43999      2048/docker-proxy
                                  tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        31177      641/systemd-resolve
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          38212      931/sshd: /usr/sbin
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          19541      1/init
                                  tcp6       0      0 :::631                  :::*                    LISTEN      0          38915      743/cupsd
                                  tcp6       0      0 :::1882                 :::*                    LISTEN      0          44740      2100/docker-proxy
                                  tcp6       0      0 :::8091                 :::*                    LISTEN      0          43892      1983/docker-proxy
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      0          43982      2033/docker-proxy
                                  tcp6       0      0 :::8083                 :::*                    LISTEN      0          44654      2011/docker-proxy
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      0          44004      2055/docker-proxy
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      130        43023      903/influxd
                                  udp        0      0 0.0.0.0:60140           0.0.0.0:*                           115        36343      738/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        36341      738/avahi-daemon: r
                                  udp        0      0 0.0.0.0:8081            0.0.0.0:*                           0          45073      2071/docker-proxy
                                  udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        31176      641/systemd-resolve
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          19538      1/init
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          38957      902/cups-browsed
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       57796      3637/deCONZ
                                  udp6       0      0 :::5353                 :::*                                115        36342      738/avahi-daemon: r
                                  udp6       0      0 :::55503                :::*                                115        36344      738/avahi-daemon: r
                                  udp6       0      0 :::8081                 :::*                                0          44733      2077/docker-proxy
                                  udp6       0      0 :::111                  :::*                                0          19544      1/init
                                  2023-09-21 22:14:39.108  - error: host.Nuc Cannot find view "system" for search "instance"
                                  2023-09-21 22:14:39.110  - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system"
                                  2023-09-21 22:14:39.111  - error: host.Nuc  _design/system missing - call node iobroker.js setup
                                  2023-09-21 22:14:39.111  - info: host.Nuc  no instances found
                                  2023-09-21 22:14:39.112  - info: host.Nuc no instances found
                                  2023-09-21 22:27:26.562  - info: host.Nuc received SIGTERM
                                  2023-09-21 22:27:26.577  - info: host.Nuc terminated
                                  2023-09-21 22:30:14.056  - info: host.Nuc iobroker.js-controller version 4.0.24 js-controller starting
                                  2023-09-21 22:30:14.059  - info: host.Nuc Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                                  2023-09-21 22:30:14.060  - info: host.Nuc hostname: Nuc, node: v18.18.0
                                  2023-09-21 22:30:14.060  - info: host.Nuc ip addresses: 192.168.179.52 fe80::b7b5:ce0f:92af:db16 172.18.0.1 fe80::42:ccff:fe35:673b fe80::5c18:58ff:fe12:6738
                                  2023-09-21 22:30:14.191  - error: host.Nuc Cannot read system.config: null (OK when migrating or restoring)
                                  2023-09-21 22:30:14.242  - error: host.Nuc Cannot find view "system" for search "host"
                                  2023-09-21 22:30:14.432  - info: host.Nuc connected to Objects and States
                                  2023-09-21 22:30:14.464  - info: host.Nuc added notifications configuration of host
                                  2023-09-21 22:30:14.511  - error: host.Nuc Cannot find view "system" for search "instance"
                                  2023-09-21 22:30:14.512  - error: host.Nuc Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
                                  2023-09-21 22:30:14.581  - info: host.Nuc Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                  2023-09-21 22:30:14.595  - error: host.Nuc Cannot find view "system" for search "host"
                                  2023-09-21 22:30:14.630  - error: host.Nuc Cannot find view "system" for search "state"
                                  2023-09-21 22:30:14.631  - error: host.Nuc Cannot find view "system" for search "instance"
                                  2023-09-21 22:30:14.632  - error: host.Nuc Could not collect system.host.Nuc states to check for obsolete states: Error: Cannot find view "system"
                                  2023-09-21 22:30:14.632  - error: host.Nuc  _design/system missing - call node iobroker.js setup
                                  2023-09-21 22:30:14.637  - info: host.Nuc  no instances found
                                  • B Bambulko
                                    Skript v.2023-06-20
                                    *** BASE SYSTEM ***
                                               Chassis: desktop
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : amd64
                                    CPU threads: 2
                                                  NTP service: active
                                              RTC in local TZ: no
                                    user
                                    /home/user
                                    X-Server: 	true
                                    Desktop: 	mate
                                    Terminal: 	x11
                                    *** MEMORY ***
                                    Swap:          2.0G          0B        2.0G
                                             4343 M used memory
                                             5234 M free memory
                                              936 M buffer memory
                                             4619 M swap cache
                                             2047 M total swap
                                                0 M used swap
                                             2047 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    12G	/var/
                                    6.8G	/var/lib
                                    4.1G	/var/log
                                    /usr/bin/npm 		9.8.1
                                    /usr/bin/npx 		9.8.1
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin: 		6.3.5
                                    Adapter State
                                    + instance is alive
                                    List is empty
                                    Objects and States
                                    Objects: 	33
                                    States: 	26
                                    Pending Updates: 0
                                    > X-Server: 	true
                                    > Desktop: 	mate
                                    > Terminal: 	x11
                                    schalt den Desktop-Quark und alles was damit zusammen angeschleppt wird aus. Server immer ohne GUI.
                                    sudo systemctl set-default multi-user.target
                                    sudo systemctl isolate multi-user.target
                                    Dann lass den
                                    iob fix
                                    laufen.
                                      > X-Server: 	true
                                      > Desktop: 	mate
                                      > Terminal: 	x11
                                      Dann lass den
                                      iob fix
                                      laufen.
                                      Bambulko
                                      @thomas-braun Vielen Dank erst einmal bis hierher. Ich muss morgen leider frueh raus und jetzt erst mal ins Bett. Keine Ahnung was ich da so verbockt habe, dass nicht einmal die Installation klappt.
