  4. iobroker geht nicht nach stromausfall
    5.2k
154 Beiträge 7 Kommentatoren 21.6k Aufrufe 5 Beobachtet
  • E Esmax666
    leider kein objekt mehr
    @esmax666
    iob update
    iob list adapters
    iob list instances
    E 1 Antwort Letzte Antwort
      @esmax666
      iob update
      iob list adapters
      iob list instances
      Esmax666
      schrieb am zuletzt editiert von Esmax666
      @thomas-braun said in iobroker geht nicht nach stromausfall:
      > iob list instances
      ubuntu@ubuntu:/opt/iobroker$ iob update
      Used repository: stable
      Adapter    "admin"        : 6.10.1   , installed 6.10.1
      Adapter    "alexa2"       : 3.25.2   , installed 3.25.2
      Adapter    "backitup"     : 2.6.23   , installed 2.6.23
      Adapter    "cloud"        : 4.4.1    , installed 4.4.1
      Adapter    "heatingcontrol": 2.11.1  , installed 2.11.1
      Adapter    "history"      : 2.2.6    , installed 2.2.6
      Adapter    "ical"         : 1.13.3   , installed 1.13.3
      Adapter    "iot"          : 1.14.5   , installed 1.14.5
      Adapter    "javascript"   : 7.1.4    , installed 7.1.4
      Controller "js-controller": 5.0.12   , installed 5.0.12
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "radar2"       : 2.0.7    , installed 2.0.7
      Adapter    "shuttercontrol": 1.6.1   , installed 1.6.1
      Adapter    "socketio"     : 6.5.5    , installed 6.5.5
      Adapter    "telegram"     : 1.16.0   , installed 1.16.0
      Adapter    "text2command" : 3.0.2    , installed 3.0.2
      Adapter    "web"          : 6.1.2    , installed 6.1.2
      Adapter    "ws"           : 2.5.5    , installed 2.5.5
      Adapter    "zwave2"       : 3.0.5    , installed 3.0.5
      ubuntu@ubuntu:/opt/iobroker$ ^C
      ubuntu@ubuntu:/opt/iobroker$ iobroker start
      ubuntu@ubuntu:/opt/iobroker$ iob list adapters
      system.adapter.admin                   : admin          - v6.10.1
      system.adapter.alexa2                  : alexa2         - v3.25.2
      system.adapter.backitup                : backitup       - v2.6.23
      system.adapter.cloud                   : cloud          - v4.4.1
      system.adapter.discovery               : discovery      - v3.1.0
      system.adapter.flot                    : flot           - v1.12.0
      system.adapter.heatingcontrol          : heatingcontrol - v2.11.1
      system.adapter.history                 : history        - v2.2.6
      system.adapter.ical                    : ical           - v1.13.3
      system.adapter.info                    : info           - v1.9.26
      system.adapter.iot                     : iot            - v1.14.5
      system.adapter.javascript              : javascript     - v7.1.4
      system.adapter.linkeddevices           : linkeddevices  - v1.5.5
      system.adapter.radar2                  : radar2         - v2.0.7
      system.adapter.rpi2                    : rpi2           - v1.3.2
      system.adapter.shuttercontrol          : shuttercontrol - v1.6.1
      system.adapter.simple-api              : simple-api     - v2.7.2
      system.adapter.socketio                : socketio       - v6.5.5
      system.adapter.telegram                : telegram       - v1.16.0
      system.adapter.text2command            : text2command   - v3.0.2
      system.adapter.tr-064                  : tr-064         - v4.2.18
      system.adapter.vis                     : vis            - v1.4.16
      system.adapter.vis-colorpicker         : vis-colorpicker - v2.0.3
      system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.4.0
      system.adapter.vis-metro               : vis-metro      - v1.2.0
      system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
      system.adapter.web                     : web            - v6.1.2
      system.adapter.zwave2                  : zwave2         - v3.0.5
      ubuntu@ubuntu:/opt/iobroker$ iob list instances
      + system.adapter.admin.0                  : admin                 : ubuntu                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : ubuntu                                   -  enabled
      + system.adapter.discovery.0              : discovery             : ubuntu                                   -  enabled
      + instance is alive
      • E Esmax666
        > iob list instances
        + instance is alive
        @esmax666
        Möglich, dass du die Instanzen manuell hinzufügen musst.
        ls -lAh /opt/iobroker/iobroker-data/backup-objects/
        sagt? Wann war der Stromausfall?
          @esmax666
          Esmax666
          Stomausfall war am 6 sept.
          ich kann nicht alles zeigen :
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:48 2023-09-19_05-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:48 2023-09-19_05-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:49 2023-09-19_05-49_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 05:49 2023-09-19_05-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:50 2023-09-19_05-50_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:50 2023-09-19_05-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:51 2023-09-19_05-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:51 2023-09-19_05-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:52 2023-09-19_05-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 05:52 2023-09-19_05-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:53 2023-09-19_05-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:53 2023-09-19_05-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:54 2023-09-19_05-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:54 2023-09-19_05-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:55 2023-09-19_05-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:55 2023-09-19_05-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:56 2023-09-19_05-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:56 2023-09-19_05-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:57 2023-09-19_05-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:57 2023-09-19_05-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:58 2023-09-19_05-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:58 2023-09-19_05-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:59 2023-09-19_05-59_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:59 2023-09-19_05-59_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:00 2023-09-19_06-00_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:00 2023-09-19_06-00_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:01 2023-09-19_06-01_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:01 2023-09-19_06-01_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:02 2023-09-19_06-02_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:02 2023-09-19_06-02_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:03 2023-09-19_06-03_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:03 2023-09-19_06-03_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:04 2023-09-19_06-04_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:04 2023-09-19_06-04_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:05 2023-09-19_06-05_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:05 2023-09-19_06-05_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:06 2023-09-19_06-06_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 06:06 2023-09-19_06-06_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:07 2023-09-19_06-07_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:07 2023-09-19_06-07_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:08 2023-09-19_06-08_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:08 2023-09-19_06-08_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:09 2023-09-19_06-09_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:09 2023-09-19_06-09_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:10 2023-09-19_06-10_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 06:10 2023-09-19_06-10_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:11 2023-09-19_06-11_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:11 2023-09-19_06-11_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:12 2023-09-19_06-12_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 06:12 2023-09-19_06-12_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:13 2023-09-19_06-13_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:13 2023-09-19_06-13_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:14 2023-09-19_06-14_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:14 2023-09-19_06-14_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:15 2023-09-19_06-15_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:15 2023-09-19_06-15_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:16 2023-09-19_06-16_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 06:16 2023-09-19_06-16_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:17 2023-09-19_06-17_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:17 2023-09-19_06-17_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:18 2023-09-19_06-18_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:18 2023-09-19_06-18_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:19 2023-09-19_06-19_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 06:19 2023-09-19_06-19_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:20 2023-09-19_06-20_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:20 2023-09-19_06-20_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:21 2023-09-19_06-21_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:21 2023-09-19_06-21_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:22 2023-09-19_06-22_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:22 2023-09-19_06-22_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:23 2023-09-19_06-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:23 2023-09-19_06-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:24 2023-09-19_06-24_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:24 2023-09-19_06-24_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:25 2023-09-19_06-25_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:25 2023-09-19_06-25_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:26 2023-09-19_06-26_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:26 2023-09-19_06-26_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:27 2023-09-19_06-27_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 06:27 2023-09-19_06-27_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:28 2023-09-19_06-28_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:28 2023-09-19_06-28_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:29 2023-09-19_06-29_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:29 2023-09-19_06-29_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:30 2023-09-19_06-30_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:30 2023-09-19_06-30_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:31 2023-09-19_06-31_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:31 2023-09-19_06-31_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:32 2023-09-19_06-32_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:32 2023-09-19_06-32_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:33 2023-09-19_06-33_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:33 2023-09-19_06-33_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:34 2023-09-19_06-34_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:34 2023-09-19_06-34_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:35 2023-09-19_06-35_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:35 2023-09-19_06-35_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:36 2023-09-19_06-36_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:36 2023-09-19_06-36_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:37 2023-09-19_06-37_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:37 2023-09-19_06-37_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:38 2023-09-19_06-38_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:38 2023-09-19_06-38_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:39 2023-09-19_06-39_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:39 2023-09-19_06-39_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:40 2023-09-19_06-40_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:40 2023-09-19_06-40_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:41 2023-09-19_06-41_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:41 2023-09-19_06-41_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:42 2023-09-19_06-42_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:42 2023-09-19_06-42_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:43 2023-09-19_06-43_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:43 2023-09-19_06-43_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:44 2023-09-19_06-44_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:44 2023-09-19_06-44_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:45 2023-09-19_06-45_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:45 2023-09-19_06-45_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:46 2023-09-19_06-46_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:46 2023-09-19_06-46_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:47 2023-09-19_06-47_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:47 2023-09-19_06-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:48 2023-09-19_06-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:48 2023-09-19_06-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:49 2023-09-19_06-49_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:49 2023-09-19_06-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:50 2023-09-19_06-50_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 06:50 2023-09-19_06-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:51 2023-09-19_06-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:51 2023-09-19_06-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:52 2023-09-19_06-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:52 2023-09-19_06-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:53 2023-09-19_06-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:53 2023-09-19_06-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:54 2023-09-19_06-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:54 2023-09-19_06-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:55 2023-09-19_06-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:55 2023-09-19_06-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:56 2023-09-19_06-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:56 2023-09-19_06-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:57 2023-09-19_06-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:57 2023-09-19_06-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:58 2023-09-19_06-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:58 2023-09-19_06-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:59 2023-09-19_06-59_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:59 2023-09-19_06-59_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:00 2023-09-19_07-00_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:00 2023-09-19_07-00_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:01 2023-09-19_07-01_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:01 2023-09-19_07-01_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:02 2023-09-19_07-02_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:02 2023-09-19_07-02_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:03 2023-09-19_07-03_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:03 2023-09-19_07-03_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:04 2023-09-19_07-04_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 07:04 2023-09-19_07-04_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:05 2023-09-19_07-05_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:05 2023-09-19_07-05_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:06 2023-09-19_07-06_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:06 2023-09-19_07-06_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:07 2023-09-19_07-07_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:07 2023-09-19_07-07_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:08 2023-09-19_07-08_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:08 2023-09-19_07-08_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:09 2023-09-19_07-09_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:09 2023-09-19_07-09_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:10 2023-09-19_07-10_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:10 2023-09-19_07-10_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:11 2023-09-19_07-11_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:11 2023-09-19_07-11_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:12 2023-09-19_07-12_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:12 2023-09-19_07-12_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:13 2023-09-19_07-13_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:13 2023-09-19_07-13_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:14 2023-09-19_07-14_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:14 2023-09-19_07-14_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:15 2023-09-19_07-15_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:15 2023-09-19_07-15_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:16 2023-09-19_07-16_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 07:16 2023-09-19_07-16_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:17 2023-09-19_07-17_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:17 2023-09-19_07-17_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:18 2023-09-19_07-18_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:18 2023-09-19_07-18_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:19 2023-09-19_07-19_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:19 2023-09-19_07-19_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:20 2023-09-19_07-20_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 07:20 2023-09-19_07-20_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:21 2023-09-19_07-21_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:21 2023-09-19_07-21_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:22 2023-09-19_07-22_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:22 2023-09-19_07-22_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:23 2023-09-19_07-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:23 2023-09-19_07-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:24 2023-09-19_07-24_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:24 2023-09-19_07-24_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:25 2023-09-19_07-25_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:25 2023-09-19_07-25_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:26 2023-09-19_07-26_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:26 2023-09-19_07-26_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:27 2023-09-19_07-27_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:27 2023-09-19_07-27_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:28 2023-09-19_07-28_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:28 2023-09-19_07-28_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:29 2023-09-19_07-29_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:29 2023-09-19_07-29_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:30 2023-09-19_07-30_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:30 2023-09-19_07-30_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:31 2023-09-19_07-31_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 07:31 2023-09-19_07-31_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:32 2023-09-19_07-32_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:32 2023-09-19_07-32_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:33 2023-09-19_07-33_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:33 2023-09-19_07-33_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:34 2023-09-19_07-34_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:34 2023-09-19_07-34_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:35 2023-09-19_07-35_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:35 2023-09-19_07-35_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:36 2023-09-19_07-36_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:36 2023-09-19_07-36_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:37 2023-09-19_07-37_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:37 2023-09-19_07-37_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:38 2023-09-19_07-38_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:38 2023-09-19_07-38_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:39 2023-09-19_07-39_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:39 2023-09-19_07-39_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:40 2023-09-19_07-40_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:40 2023-09-19_07-40_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:41 2023-09-19_07-41_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 07:41 2023-09-19_07-41_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:42 2023-09-19_07-42_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:42 2023-09-19_07-42_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:43 2023-09-19_07-43_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:43 2023-09-19_07-43_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:44 2023-09-19_07-44_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 07:44 2023-09-19_07-44_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:45 2023-09-19_07-45_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:45 2023-09-19_07-45_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:46 2023-09-19_07-46_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:46 2023-09-19_07-46_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:47 2023-09-19_07-47_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:47 2023-09-19_07-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:48 2023-09-19_07-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:48 2023-09-19_07-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:49 2023-09-19_07-49_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:49 2023-09-19_07-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:50 2023-09-19_07-50_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:50 2023-09-19_07-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:51 2023-09-19_07-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:51 2023-09-19_07-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:52 2023-09-19_07-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:52 2023-09-19_07-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:53 2023-09-19_07-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:53 2023-09-19_07-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:54 2023-09-19_07-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:54 2023-09-19_07-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:55 2023-09-19_07-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:55 2023-09-19_07-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:56 2023-09-19_07-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:56 2023-09-19_07-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:57 2023-09-19_07-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:57 2023-09-19_07-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:58 2023-09-19_07-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:58 2023-09-19_07-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:59 2023-09-19_07-59_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:59 2023-09-19_07-59_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:00 2023-09-19_08-00_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 08:00 2023-09-19_08-00_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:01 2023-09-19_08-01_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:01 2023-09-19_08-01_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:02 2023-09-19_08-02_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 08:02 2023-09-19_08-02_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:03 2023-09-19_08-03_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:03 2023-09-19_08-03_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:04 2023-09-19_08-04_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 08:04 2023-09-19_08-04_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:05 2023-09-19_08-05_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:05 2023-09-19_08-05_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:06 2023-09-19_08-06_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:06 2023-09-19_08-06_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:07 2023-09-19_08-07_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 08:07 2023-09-19_08-07_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:08 2023-09-19_08-08_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:08 2023-09-19_08-08_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:09 2023-09-19_08-09_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:09 2023-09-19_08-09_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:10 2023-09-19_08-10_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:10 2023-09-19_08-10_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:11 2023-09-19_08-11_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:11 2023-09-19_08-11_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:12 2023-09-19_08-12_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:12 2023-09-19_08-12_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:13 2023-09-19_08-13_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:13 2023-09-19_08-13_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:14 2023-09-19_08-14_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:14 2023-09-19_08-14_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:15 2023-09-19_08-15_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:15 2023-09-19_08-15_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:16 2023-09-19_08-16_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 08:16 2023-09-19_08-16_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:17 2023-09-19_08-17_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:17 2023-09-19_08-17_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:18 2023-09-19_08-18_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:18 2023-09-19_08-18_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:19 2023-09-19_08-19_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:19 2023-09-19_08-19_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:20 2023-09-19_08-20_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 08:20 2023-09-19_08-20_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:21 2023-09-19_08-21_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:21 2023-09-19_08-21_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:22 2023-09-19_08-22_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:22 2023-09-19_08-22_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:23 2023-09-19_08-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:23 2023-09-19_08-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:24 2023-09-19_08-24_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:24 2023-09-19_08-24_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:25 2023-09-19_08-25_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:25 2023-09-19_08-25_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:26 2023-09-19_08-26_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:26 2023-09-19_08-26_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:27 2023-09-19_08-27_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 08:27 2023-09-19_08-27_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:28 2023-09-19_08-28_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:28 2023-09-19_08-28_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:29 2023-09-19_08-29_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:29 2023-09-19_08-29_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:30 2023-09-19_08-30_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:30 2023-09-19_08-30_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:31 2023-09-19_08-31_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:31 2023-09-19_08-31_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:32 2023-09-19_08-32_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:32 2023-09-19_08-32_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:33 2023-09-19_08-33_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:33 2023-09-19_08-33_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:34 2023-09-19_08-34_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:34 2023-09-19_08-34_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:35 2023-09-19_08-35_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:35 2023-09-19_08-35_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:36 2023-09-19_08-36_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:36 2023-09-19_08-36_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:37 2023-09-19_08-37_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:37 2023-09-19_08-37_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:38 2023-09-19_08-38_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:38 2023-09-19_08-38_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:39 2023-09-19_08-39_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:39 2023-09-19_08-39_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:40 2023-09-19_08-40_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:40 2023-09-19_08-40_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:41 2023-09-19_08-41_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:41 2023-09-19_08-41_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:42 2023-09-19_08-42_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:42 2023-09-19_08-42_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:43 2023-09-19_08-43_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:43 2023-09-19_08-43_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:44 2023-09-19_08-44_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:44 2023-09-19_08-44_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:45 2023-09-19_08-45_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:45 2023-09-19_08-45_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:46 2023-09-19_08-46_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:46 2023-09-19_08-46_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:47 2023-09-19_08-47_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:47 2023-09-19_08-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:48 2023-09-19_08-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 08:48 2023-09-19_08-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:49 2023-09-19_08-49_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:49 2023-09-19_08-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:50 2023-09-19_08-50_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:50 2023-09-19_08-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:51 2023-09-19_08-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:51 2023-09-19_08-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:52 2023-09-19_08-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:52 2023-09-19_08-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:53 2023-09-19_08-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 08:53 2023-09-19_08-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:54 2023-09-19_08-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:54 2023-09-19_08-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:55 2023-09-19_08-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:55 2023-09-19_08-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:56 2023-09-19_08-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 08:56 2023-09-19_08-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:57 2023-09-19_08-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:57 2023-09-19_08-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:58 2023-09-19_08-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:58 2023-09-19_08-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:59 2023-09-19_08-59_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 08:59 2023-09-19_08-59_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:00 2023-09-19_09-00_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:00 2023-09-19_09-00_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:01 2023-09-19_09-01_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 09:01 2023-09-19_09-01_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:02 2023-09-19_09-02_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:02 2023-09-19_09-02_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:03 2023-09-19_09-03_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:03 2023-09-19_09-03_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:04 2023-09-19_09-04_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:04 2023-09-19_09-04_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:05 2023-09-19_09-05_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:05 2023-09-19_09-05_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:06 2023-09-19_09-06_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:06 2023-09-19_09-06_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:07 2023-09-19_09-07_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:07 2023-09-19_09-07_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:08 2023-09-19_09-08_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 09:08 2023-09-19_09-08_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:09 2023-09-19_09-09_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:09 2023-09-19_09-09_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:10 2023-09-19_09-10_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:10 2023-09-19_09-10_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:11 2023-09-19_09-11_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:11 2023-09-19_09-11_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:12 2023-09-19_09-12_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:12 2023-09-19_09-12_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:13 2023-09-19_09-13_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 09:13 2023-09-19_09-13_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:14 2023-09-19_09-14_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:14 2023-09-19_09-14_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:15 2023-09-19_09-15_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:15 2023-09-19_09-15_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:16 2023-09-19_09-16_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:16 2023-09-19_09-16_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:17 2023-09-19_09-17_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:17 2023-09-19_09-17_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:18 2023-09-19_09-18_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 09:18 2023-09-19_09-18_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:19 2023-09-19_09-19_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:19 2023-09-19_09-19_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:20 2023-09-19_09-20_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  487 Sep 19 09:20 2023-09-19_09-20_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:21 2023-09-19_09-21_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:21 2023-09-19_09-21_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:22 2023-09-19_09-22_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:22 2023-09-19_09-22_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:23 2023-09-19_09-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:23 2023-09-19_09-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:24 2023-09-19_09-24_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 09:24 2023-09-19_09-24_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:25 2023-09-19_09-25_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:25 2023-09-19_09-25_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:26 2023-09-19_09-26_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:26 2023-09-19_09-26_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:27 2023-09-19_09-27_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:27 2023-09-19_09-27_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:28 2023-09-19_09-28_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 09:28 2023-09-19_09-28_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:29 2023-09-19_09-29_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:29 2023-09-19_09-29_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:30 2023-09-19_09-30_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:30 2023-09-19_09-30_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:31 2023-09-19_09-31_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:31 2023-09-19_09-31_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:32 2023-09-19_09-32_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 09:32 2023-09-19_09-32_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:33 2023-09-19_09-33_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:33 2023-09-19_09-33_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:34 2023-09-19_09-34_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 09:34 2023-09-19_09-34_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:35 2023-09-19_09-35_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:35 2023-09-19_09-35_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:36 2023-09-19_09-36_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:36 2023-09-19_09-36_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:37 2023-09-19_09-37_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:37 2023-09-19_09-37_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:38 2023-09-19_09-38_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:38 2023-09-19_09-38_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:39 2023-09-19_09-39_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 09:39 2023-09-19_09-39_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:40 2023-09-19_09-40_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:40 2023-09-19_09-40_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:41 2023-09-19_09-41_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:41 2023-09-19_09-41_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:42 2023-09-19_09-42_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 09:42 2023-09-19_09-42_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:43 2023-09-19_09-43_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:43 2023-09-19_09-43_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:44 2023-09-19_09-44_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:44 2023-09-19_09-44_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:45 2023-09-19_09-45_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:45 2023-09-19_09-45_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:46 2023-09-19_09-46_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:46 2023-09-19_09-46_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:47 2023-09-19_09-47_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 09:47 2023-09-19_09-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:48 2023-09-19_09-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:48 2023-09-19_09-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:49 2023-09-19_09-49_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:49 2023-09-19_09-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:50 2023-09-19_09-50_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:50 2023-09-19_09-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:51 2023-09-19_09-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 09:51 2023-09-19_09-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:52 2023-09-19_09-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:52 2023-09-19_09-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:53 2023-09-19_09-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:53 2023-09-19_09-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:54 2023-09-19_09-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:54 2023-09-19_09-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:55 2023-09-19_09-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:55 2023-09-19_09-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:56 2023-09-19_09-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:56 2023-09-19_09-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:57 2023-09-19_09-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:57 2023-09-19_09-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:58 2023-09-19_09-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:58 2023-09-19_09-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:59 2023-09-19_09-59_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:59 2023-09-19_09-59_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:00 2023-09-19_10-00_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:00 2023-09-19_10-00_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:01 2023-09-19_10-01_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:01 2023-09-19_10-01_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:02 2023-09-19_10-02_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 10:02 2023-09-19_10-02_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:03 2023-09-19_10-03_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:03 2023-09-19_10-03_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:04 2023-09-19_10-04_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:04 2023-09-19_10-04_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:05 2023-09-19_10-05_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:05 2023-09-19_10-05_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:06 2023-09-19_10-06_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:06 2023-09-19_10-06_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:07 2023-09-19_10-07_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:07 2023-09-19_10-07_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:08 2023-09-19_10-08_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:08 2023-09-19_10-08_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:09 2023-09-19_10-09_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:09 2023-09-19_10-09_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:10 2023-09-19_10-10_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:10 2023-09-19_10-10_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:11 2023-09-19_10-11_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:11 2023-09-19_10-11_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:12 2023-09-19_10-12_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:12 2023-09-19_10-12_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:13 2023-09-19_10-13_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:13 2023-09-19_10-13_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:14 2023-09-19_10-14_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 10:14 2023-09-19_10-14_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:15 2023-09-19_10-15_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:15 2023-09-19_10-15_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:16 2023-09-19_10-16_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 10:16 2023-09-19_10-16_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:17 2023-09-19_10-17_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:17 2023-09-19_10-17_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:18 2023-09-19_10-18_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:18 2023-09-19_10-18_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:19 2023-09-19_10-19_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:19 2023-09-19_10-19_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:20 2023-09-19_10-20_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:20 2023-09-19_10-20_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:21 2023-09-19_10-21_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:21 2023-09-19_10-21_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:22 2023-09-19_10-22_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:22 2023-09-19_10-22_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:23 2023-09-19_10-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:23 2023-09-19_10-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:24 2023-09-19_10-24_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:24 2023-09-19_10-24_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:25 2023-09-19_10-25_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:25 2023-09-19_10-25_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:26 2023-09-19_10-26_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:26 2023-09-19_10-26_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:27 2023-09-19_10-27_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:27 2023-09-19_10-27_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:28 2023-09-19_10-28_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:28 2023-09-19_10-28_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:29 2023-09-19_10-29_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:29 2023-09-19_10-29_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:30 2023-09-19_10-30_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:30 2023-09-19_10-30_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:31 2023-09-19_10-31_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:31 2023-09-19_10-31_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:32 2023-09-19_10-32_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:32 2023-09-19_10-32_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:33 2023-09-19_10-33_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:33 2023-09-19_10-33_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:34 2023-09-19_10-34_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:34 2023-09-19_10-34_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:35 2023-09-19_10-35_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 10:35 2023-09-19_10-35_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:36 2023-09-19_10-36_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:36 2023-09-19_10-36_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:37 2023-09-19_10-37_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 10:37 2023-09-19_10-37_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:38 2023-09-19_10-38_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:38 2023-09-19_10-38_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:39 2023-09-19_10-39_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:39 2023-09-19_10-39_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:40 2023-09-19_10-40_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:40 2023-09-19_10-40_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:41 2023-09-19_10-41_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:41 2023-09-19_10-41_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:42 2023-09-19_10-42_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 10:42 2023-09-19_10-42_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:43 2023-09-19_10-43_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:43 2023-09-19_10-43_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:44 2023-09-19_10-44_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:44 2023-09-19_10-44_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:45 2023-09-19_10-45_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:45 2023-09-19_10-45_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:46 2023-09-19_10-46_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:46 2023-09-19_10-46_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:47 2023-09-19_10-47_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:47 2023-09-19_10-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:48 2023-09-19_10-48_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:48 2023-09-19_10-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:49 2023-09-19_10-49_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:49 2023-09-19_10-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:50 2023-09-19_10-50_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:50 2023-09-19_10-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:51 2023-09-19_10-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:51 2023-09-19_10-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:52 2023-09-19_10-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:52 2023-09-19_10-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:53 2023-09-19_10-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:53 2023-09-19_10-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:54 2023-09-19_10-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:54 2023-09-19_10-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:55 2023-09-19_10-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:55 2023-09-19_10-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:56 2023-09-19_10-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 10:56 2023-09-19_10-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:57 2023-09-19_10-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:57 2023-09-19_10-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:58 2023-09-19_10-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:58 2023-09-19_10-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:51 2023-09-19_11-51_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 11:51 2023-09-19_11-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:52 2023-09-19_11-52_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:52 2023-09-19_11-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:53 2023-09-19_11-53_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:53 2023-09-19_11-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:54 2023-09-19_11-54_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 11:54 2023-09-19_11-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:55 2023-09-19_11-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 11:55 2023-09-19_11-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:56 2023-09-19_11-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  440 Sep 19 11:56 2023-09-19_11-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:57 2023-09-19_11-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 11:57 2023-09-19_11-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:58 2023-09-19_11-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 11:58 2023-09-19_11-58_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:59 2023-09-19_11-59_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 11:59 2023-09-19_11-59_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:00 2023-09-19_12-00_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:00 2023-09-19_12-00_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:01 2023-09-19_12-01_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:01 2023-09-19_12-01_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:02 2023-09-19_12-02_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:02 2023-09-19_12-02_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:03 2023-09-19_12-03_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:03 2023-09-19_12-03_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:04 2023-09-19_12-04_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:04 2023-09-19_12-04_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:05 2023-09-19_12-05_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:05 2023-09-19_12-05_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:06 2023-09-19_12-06_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  433 Sep 19 12:06 2023-09-19_12-06_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:07 2023-09-19_12-07_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:07 2023-09-19_12-07_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:08 2023-09-19_12-08_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 12:08 2023-09-19_12-08_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:09 2023-09-19_12-09_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:09 2023-09-19_12-09_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:10 2023-09-19_12-10_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  446 Sep 19 12:10 2023-09-19_12-10_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:11 2023-09-19_12-11_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:11 2023-09-19_12-11_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:12 2023-09-19_12-12_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:12 2023-09-19_12-12_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:13 2023-09-19_12-13_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 12:13 2023-09-19_12-13_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:14 2023-09-19_12-14_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:14 2023-09-19_12-14_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:16 2023-09-19_12-16_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:16 2023-09-19_12-16_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:17 2023-09-19_12-17_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:17 2023-09-19_12-17_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:18 2023-09-19_12-18_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:18 2023-09-19_12-18_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:19 2023-09-19_12-19_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:19 2023-09-19_12-19_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:20 2023-09-19_12-20_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:20 2023-09-19_12-20_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:21 2023-09-19_12-21_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:21 2023-09-19_12-21_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:22 2023-09-19_12-22_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:22 2023-09-19_12-22_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:23 2023-09-19_12-23_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:23 2023-09-19_12-23_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:24 2023-09-19_12-24_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:24 2023-09-19_12-24_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:25 2023-09-19_12-25_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:25 2023-09-19_12-25_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:26 2023-09-19_12-26_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:26 2023-09-19_12-26_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:27 2023-09-19_12-27_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:27 2023-09-19_12-27_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:28 2023-09-19_12-28_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:28 2023-09-19_12-28_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:29 2023-09-19_12-29_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:29 2023-09-19_12-29_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:30 2023-09-19_12-30_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:30 2023-09-19_12-30_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:31 2023-09-19_12-31_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 12:31 2023-09-19_12-31_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:32 2023-09-19_12-32_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:32 2023-09-19_12-32_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:33 2023-09-19_12-33_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  442 Sep 19 12:33 2023-09-19_12-33_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:34 2023-09-19_12-34_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 12:34 2023-09-19_12-34_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:35 2023-09-19_12-35_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:35 2023-09-19_12-35_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:36 2023-09-19_12-36_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:36 2023-09-19_12-36_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:37 2023-09-19_12-37_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:37 2023-09-19_12-37_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:38 2023-09-19_12-38_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:38 2023-09-19_12-38_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:39 2023-09-19_12-39_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:39 2023-09-19_12-39_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:41 2023-09-19_12-41_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 12:41 2023-09-19_12-41_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:42 2023-09-19_12-42_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  450 Sep 19 12:42 2023-09-19_12-42_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:43 2023-09-19_12-43_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:43 2023-09-19_12-43_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:44 2023-09-19_12-44_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:44 2023-09-19_12-44_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:45 2023-09-19_12-45_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:46 2023-09-19_12-46_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:47 2023-09-19_12-47_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:48 2023-09-19_12-48_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:49 2023-09-19_12-49_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:50 2023-09-19_12-50_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:51 2023-09-19_12-51_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:52 2023-09-19_12-52_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:53 2023-09-19_12-53_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:54 2023-09-19_12-54_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:55 2023-09-19_12-55_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:55 2023-09-19_12-55_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:56 2023-09-19_12-56_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:56 2023-09-19_12-56_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:57 2023-09-19_12-57_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:57 2023-09-19_12-57_states.json.gz
          -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:58 2023-09-19_12-58_objects.json.gz
          -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:58 2023-09-19_12-58_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 12:59 2023-09-19_12-59_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 12:59 2023-09-19_12-59_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:00 2023-09-19_13-00_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 13:00 2023-09-19_13-00_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:01 2023-09-19_13-01_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:01 2023-09-19_13-01_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:02 2023-09-19_13-02_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:02 2023-09-19_13-02_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:03 2023-09-19_13-03_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:03 2023-09-19_13-03_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:04 2023-09-19_13-04_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:04 2023-09-19_13-04_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:05 2023-09-19_13-05_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:05 2023-09-19_13-05_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:06 2023-09-19_13-06_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:06 2023-09-19_13-06_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:07 2023-09-19_13-07_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:07 2023-09-19_13-07_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:08 2023-09-19_13-08_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:08 2023-09-19_13-08_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:09 2023-09-19_13-09_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:09 2023-09-19_13-09_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:10 2023-09-19_13-10_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:10 2023-09-19_13-10_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:11 2023-09-19_13-11_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:11 2023-09-19_13-11_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:12 2023-09-19_13-12_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:12 2023-09-19_13-12_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:13 2023-09-19_13-13_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:13 2023-09-19_13-13_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:14 2023-09-19_13-14_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:14 2023-09-19_13-14_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:15 2023-09-19_13-15_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:15 2023-09-19_13-15_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:16 2023-09-19_13-16_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 13:16 2023-09-19_13-16_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:17 2023-09-19_13-17_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:17 2023-09-19_13-17_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:18 2023-09-19_13-18_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:18 2023-09-19_13-18_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:19 2023-09-19_13-19_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  433 Sep 19 13:19 2023-09-19_13-19_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:20 2023-09-19_13-20_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:20 2023-09-19_13-20_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 2.4K Sep 19 13:21 2023-09-19_13-21_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:21 2023-09-19_13-21_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 2.9K Sep 19 13:22 2023-09-19_13-22_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:22 2023-09-19_13-22_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 3.7K Sep 19 13:23 2023-09-19_13-23_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:23 2023-09-19_13-23_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.3K Sep 19 13:24 2023-09-19_13-24_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:24 2023-09-19_13-24_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.4K Sep 19 13:25 2023-09-19_13-25_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:25 2023-09-19_13-25_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:26 2023-09-19_13-26_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:26 2023-09-19_13-26_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:27 2023-09-19_13-27_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:27 2023-09-19_13-27_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:28 2023-09-19_13-28_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:28 2023-09-19_13-28_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:29 2023-09-19_13-29_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:29 2023-09-19_13-29_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:30 2023-09-19_13-30_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:30 2023-09-19_13-30_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:31 2023-09-19_13-31_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:31 2023-09-19_13-31_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:32 2023-09-19_13-32_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  443 Sep 19 13:32 2023-09-19_13-32_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:33 2023-09-19_13-33_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 13:33 2023-09-19_13-33_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:34 2023-09-19_13-34_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 13:34 2023-09-19_13-34_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:35 2023-09-19_13-35_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:35 2023-09-19_13-35_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:36 2023-09-19_13-36_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:36 2023-09-19_13-36_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:37 2023-09-19_13-37_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:37 2023-09-19_13-37_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:38 2023-09-19_13-38_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  474 Sep 19 13:38 2023-09-19_13-38_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:39 2023-09-19_13-39_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:39 2023-09-19_13-39_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:40 2023-09-19_13-40_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 13:40 2023-09-19_13-40_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:41 2023-09-19_13-41_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:41 2023-09-19_13-41_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:42 2023-09-19_13-42_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 13:42 2023-09-19_13-42_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:43 2023-09-19_13-43_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  475 Sep 19 13:43 2023-09-19_13-43_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:44 2023-09-19_13-44_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:44 2023-09-19_13-44_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:45 2023-09-19_13-45_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:45 2023-09-19_13-45_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:46 2023-09-19_13-46_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:46 2023-09-19_13-46_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:47 2023-09-19_13-47_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:47 2023-09-19_13-47_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:48 2023-09-19_13-48_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:48 2023-09-19_13-48_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:49 2023-09-19_13-49_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:49 2023-09-19_13-49_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:50 2023-09-19_13-50_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  466 Sep 19 13:50 2023-09-19_13-50_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:51 2023-09-19_13-51_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:51 2023-09-19_13-51_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:52 2023-09-19_13-52_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 13:52 2023-09-19_13-52_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:53 2023-09-19_13-53_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:53 2023-09-19_13-53_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:54 2023-09-19_13-54_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:54 2023-09-19_13-54_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:55 2023-09-19_13-55_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  468 Sep 19 13:55 2023-09-19_13-55_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:56 2023-09-19_13-56_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:56 2023-09-19_13-56_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:57 2023-09-19_13-57_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:57 2023-09-19_13-57_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:58 2023-09-19_13-58_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:58 2023-09-19_13-58_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:59 2023-09-19_13-59_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:59 2023-09-19_13-59_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:00 2023-09-19_14-00_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:00 2023-09-19_14-00_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:01 2023-09-19_14-01_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:01 2023-09-19_14-01_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:02 2023-09-19_14-02_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:02 2023-09-19_14-02_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:03 2023-09-19_14-03_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:03 2023-09-19_14-03_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:04 2023-09-19_14-04_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:04 2023-09-19_14-04_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:05 2023-09-19_14-05_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:05 2023-09-19_14-05_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:06 2023-09-19_14-06_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:06 2023-09-19_14-06_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:07 2023-09-19_14-07_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:07 2023-09-19_14-07_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:08 2023-09-19_14-08_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:08 2023-09-19_14-08_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:09 2023-09-19_14-09_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:09 2023-09-19_14-09_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:10 2023-09-19_14-10_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:10 2023-09-19_14-10_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:11 2023-09-19_14-11_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:11 2023-09-19_14-11_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:12 2023-09-19_14-12_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:12 2023-09-19_14-12_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:13 2023-09-19_14-13_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 14:13 2023-09-19_14-13_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:14 2023-09-19_14-14_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:14 2023-09-19_14-14_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:15 2023-09-19_14-15_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:15 2023-09-19_14-15_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:16 2023-09-19_14-16_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:16 2023-09-19_14-16_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:17 2023-09-19_14-17_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 14:17 2023-09-19_14-17_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:18 2023-09-19_14-18_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:18 2023-09-19_14-18_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:19 2023-09-19_14-19_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:19 2023-09-19_14-19_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:20 2023-09-19_14-20_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:20 2023-09-19_14-20_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:21 2023-09-19_14-21_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:21 2023-09-19_14-21_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:22 2023-09-19_14-22_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:22 2023-09-19_14-22_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:23 2023-09-19_14-23_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:23 2023-09-19_14-23_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:24 2023-09-19_14-24_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  440 Sep 19 14:24 2023-09-19_14-24_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:25 2023-09-19_14-25_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:25 2023-09-19_14-25_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:26 2023-09-19_14-26_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:26 2023-09-19_14-26_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:27 2023-09-19_14-27_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:27 2023-09-19_14-27_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:28 2023-09-19_14-28_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:28 2023-09-19_14-28_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:29 2023-09-19_14-29_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:29 2023-09-19_14-29_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:30 2023-09-19_14-30_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 14:30 2023-09-19_14-30_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:31 2023-09-19_14-31_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:31 2023-09-19_14-31_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:32 2023-09-19_14-32_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:32 2023-09-19_14-32_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:33 2023-09-19_14-33_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  438 Sep 19 14:33 2023-09-19_14-33_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:34 2023-09-19_14-34_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:34 2023-09-19_14-34_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:35 2023-09-19_14-35_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:35 2023-09-19_14-35_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:36 2023-09-19_14-36_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:36 2023-09-19_14-36_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:37 2023-09-19_14-37_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:37 2023-09-19_14-37_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:38 2023-09-19_14-38_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:38 2023-09-19_14-38_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:39 2023-09-19_14-39_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:39 2023-09-19_14-39_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:40 2023-09-19_14-40_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:40 2023-09-19_14-40_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:41 2023-09-19_14-41_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:41 2023-09-19_14-41_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:42 2023-09-19_14-42_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:42 2023-09-19_14-42_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:43 2023-09-19_14-43_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 14:43 2023-09-19_14-43_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:44 2023-09-19_14-44_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:44 2023-09-19_14-44_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:45 2023-09-19_14-45_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:45 2023-09-19_14-45_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:46 2023-09-19_14-46_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:46 2023-09-19_14-46_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:47 2023-09-19_14-47_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  442 Sep 19 14:47 2023-09-19_14-47_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:48 2023-09-19_14-48_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:48 2023-09-19_14-48_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:49 2023-09-19_14-49_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:49 2023-09-19_14-49_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:50 2023-09-19_14-50_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 14:50 2023-09-19_14-50_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:51 2023-09-19_14-51_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:51 2023-09-19_14-51_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:52 2023-09-19_14-52_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:52 2023-09-19_14-52_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:53 2023-09-19_14-53_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:53 2023-09-19_14-53_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:54 2023-09-19_14-54_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:54 2023-09-19_14-54_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:55 2023-09-19_14-55_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:55 2023-09-19_14-55_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:56 2023-09-19_14-56_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:56 2023-09-19_14-56_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:57 2023-09-19_14-57_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:57 2023-09-19_14-57_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:58 2023-09-19_14-58_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:58 2023-09-19_14-58_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:59 2023-09-19_14-59_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:59 2023-09-19_14-59_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:00 2023-09-19_15-00_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  465 Sep 19 15:00 2023-09-19_15-00_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:01 2023-09-19_15-01_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 15:01 2023-09-19_15-01_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:02 2023-09-19_15-02_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:02 2023-09-19_15-02_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:03 2023-09-19_15-03_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:03 2023-09-19_15-03_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:04 2023-09-19_15-04_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 15:04 2023-09-19_15-04_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:05 2023-09-19_15-05_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:05 2023-09-19_15-05_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:06 2023-09-19_15-06_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:06 2023-09-19_15-06_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:07 2023-09-19_15-07_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:07 2023-09-19_15-07_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:08 2023-09-19_15-08_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 15:08 2023-09-19_15-08_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:09 2023-09-19_15-09_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:09 2023-09-19_15-09_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:10 2023-09-19_15-10_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 15:10 2023-09-19_15-10_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:11 2023-09-19_15-11_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:11 2023-09-19_15-11_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:12 2023-09-19_15-12_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 15:12 2023-09-19_15-12_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:13 2023-09-19_15-13_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:13 2023-09-19_15-13_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:14 2023-09-19_15-14_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:14 2023-09-19_15-14_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:15 2023-09-19_15-15_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:15 2023-09-19_15-15_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:16 2023-09-19_15-16_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:16 2023-09-19_15-16_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:17 2023-09-19_15-17_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:17 2023-09-19_15-17_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:18 2023-09-19_15-18_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:18 2023-09-19_15-18_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:19 2023-09-19_15-19_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 15:19 2023-09-19_15-19_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:20 2023-09-19_15-20_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 15:20 2023-09-19_15-20_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:21 2023-09-19_15-21_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 15:21 2023-09-19_15-21_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:22 2023-09-19_15-22_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:22 2023-09-19_15-22_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:23 2023-09-19_15-23_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:23 2023-09-19_15-23_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:24 2023-09-19_15-24_objects.json.gz
          -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 15:24 2023-09-19_15-24_states.json.gz
          -rw-rw-r--+ 1 iobroker iobroker 6.1K Sep 19 15:25 2023-09-19_15-25_states.json.gz
          ubuntu@ubuntu:/opt/iobroker$
          E Thomas BraunT 2 Antworten Letzte Antwort
          • E Esmax666
            @thomas-braun said in iobroker geht nicht nach stromausfall:
            ls -lAh /opt/iobroker/iobroker-data/backup-objects/
            Stomausfall war am 6 sept.
            ich kann nicht alles zeigen :
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:48 2023-09-19_05-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:48 2023-09-19_05-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:49 2023-09-19_05-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 05:49 2023-09-19_05-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:50 2023-09-19_05-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:50 2023-09-19_05-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:51 2023-09-19_05-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:51 2023-09-19_05-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:52 2023-09-19_05-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 05:52 2023-09-19_05-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:53 2023-09-19_05-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:53 2023-09-19_05-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:54 2023-09-19_05-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:54 2023-09-19_05-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:55 2023-09-19_05-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:55 2023-09-19_05-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:56 2023-09-19_05-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:56 2023-09-19_05-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:57 2023-09-19_05-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:57 2023-09-19_05-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:58 2023-09-19_05-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:58 2023-09-19_05-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:59 2023-09-19_05-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:59 2023-09-19_05-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:00 2023-09-19_06-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:00 2023-09-19_06-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:01 2023-09-19_06-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:01 2023-09-19_06-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:02 2023-09-19_06-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:02 2023-09-19_06-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:03 2023-09-19_06-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:03 2023-09-19_06-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:04 2023-09-19_06-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:04 2023-09-19_06-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:05 2023-09-19_06-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:05 2023-09-19_06-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:06 2023-09-19_06-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 06:06 2023-09-19_06-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:07 2023-09-19_06-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:07 2023-09-19_06-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:08 2023-09-19_06-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:08 2023-09-19_06-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:09 2023-09-19_06-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:09 2023-09-19_06-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:10 2023-09-19_06-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 06:10 2023-09-19_06-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:11 2023-09-19_06-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:11 2023-09-19_06-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:12 2023-09-19_06-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 06:12 2023-09-19_06-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:13 2023-09-19_06-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:13 2023-09-19_06-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:14 2023-09-19_06-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:14 2023-09-19_06-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:15 2023-09-19_06-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:15 2023-09-19_06-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:16 2023-09-19_06-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 06:16 2023-09-19_06-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:17 2023-09-19_06-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:17 2023-09-19_06-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:18 2023-09-19_06-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:18 2023-09-19_06-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:19 2023-09-19_06-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 06:19 2023-09-19_06-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:20 2023-09-19_06-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:20 2023-09-19_06-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:21 2023-09-19_06-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:21 2023-09-19_06-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:22 2023-09-19_06-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:22 2023-09-19_06-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:23 2023-09-19_06-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:23 2023-09-19_06-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:24 2023-09-19_06-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:24 2023-09-19_06-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:25 2023-09-19_06-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:25 2023-09-19_06-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:26 2023-09-19_06-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:26 2023-09-19_06-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:27 2023-09-19_06-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 06:27 2023-09-19_06-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:28 2023-09-19_06-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:28 2023-09-19_06-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:29 2023-09-19_06-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:29 2023-09-19_06-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:30 2023-09-19_06-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:30 2023-09-19_06-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:31 2023-09-19_06-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:31 2023-09-19_06-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:32 2023-09-19_06-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:32 2023-09-19_06-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:33 2023-09-19_06-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:33 2023-09-19_06-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:34 2023-09-19_06-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:34 2023-09-19_06-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:35 2023-09-19_06-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:35 2023-09-19_06-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:36 2023-09-19_06-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:36 2023-09-19_06-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:37 2023-09-19_06-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:37 2023-09-19_06-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:38 2023-09-19_06-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:38 2023-09-19_06-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:39 2023-09-19_06-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:39 2023-09-19_06-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:40 2023-09-19_06-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:40 2023-09-19_06-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:41 2023-09-19_06-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:41 2023-09-19_06-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:42 2023-09-19_06-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:42 2023-09-19_06-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:43 2023-09-19_06-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:43 2023-09-19_06-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:44 2023-09-19_06-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:44 2023-09-19_06-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:45 2023-09-19_06-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:45 2023-09-19_06-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:46 2023-09-19_06-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:46 2023-09-19_06-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:47 2023-09-19_06-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:47 2023-09-19_06-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:48 2023-09-19_06-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:48 2023-09-19_06-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:49 2023-09-19_06-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:49 2023-09-19_06-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:50 2023-09-19_06-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 06:50 2023-09-19_06-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:51 2023-09-19_06-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:51 2023-09-19_06-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:52 2023-09-19_06-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:52 2023-09-19_06-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:53 2023-09-19_06-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:53 2023-09-19_06-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:54 2023-09-19_06-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:54 2023-09-19_06-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:55 2023-09-19_06-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:55 2023-09-19_06-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:56 2023-09-19_06-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:56 2023-09-19_06-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:57 2023-09-19_06-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:57 2023-09-19_06-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:58 2023-09-19_06-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:58 2023-09-19_06-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:59 2023-09-19_06-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:59 2023-09-19_06-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:00 2023-09-19_07-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:00 2023-09-19_07-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:01 2023-09-19_07-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:01 2023-09-19_07-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:02 2023-09-19_07-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:02 2023-09-19_07-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:03 2023-09-19_07-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:03 2023-09-19_07-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:04 2023-09-19_07-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 07:04 2023-09-19_07-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:05 2023-09-19_07-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:05 2023-09-19_07-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:06 2023-09-19_07-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:06 2023-09-19_07-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:07 2023-09-19_07-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:07 2023-09-19_07-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:08 2023-09-19_07-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:08 2023-09-19_07-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:09 2023-09-19_07-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:09 2023-09-19_07-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:10 2023-09-19_07-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:10 2023-09-19_07-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:11 2023-09-19_07-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:11 2023-09-19_07-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:12 2023-09-19_07-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:12 2023-09-19_07-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:13 2023-09-19_07-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:13 2023-09-19_07-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:14 2023-09-19_07-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:14 2023-09-19_07-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:15 2023-09-19_07-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:15 2023-09-19_07-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:16 2023-09-19_07-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 07:16 2023-09-19_07-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:17 2023-09-19_07-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:17 2023-09-19_07-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:18 2023-09-19_07-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:18 2023-09-19_07-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:19 2023-09-19_07-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:19 2023-09-19_07-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:20 2023-09-19_07-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 07:20 2023-09-19_07-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:21 2023-09-19_07-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:21 2023-09-19_07-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:22 2023-09-19_07-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:22 2023-09-19_07-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:23 2023-09-19_07-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:23 2023-09-19_07-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:24 2023-09-19_07-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:24 2023-09-19_07-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:25 2023-09-19_07-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:25 2023-09-19_07-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:26 2023-09-19_07-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:26 2023-09-19_07-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:27 2023-09-19_07-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:27 2023-09-19_07-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:28 2023-09-19_07-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:28 2023-09-19_07-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:29 2023-09-19_07-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:29 2023-09-19_07-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:30 2023-09-19_07-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:30 2023-09-19_07-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:31 2023-09-19_07-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 07:31 2023-09-19_07-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:32 2023-09-19_07-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:32 2023-09-19_07-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:33 2023-09-19_07-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:33 2023-09-19_07-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:34 2023-09-19_07-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:34 2023-09-19_07-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:35 2023-09-19_07-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:35 2023-09-19_07-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:36 2023-09-19_07-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:36 2023-09-19_07-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:37 2023-09-19_07-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:37 2023-09-19_07-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:38 2023-09-19_07-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:38 2023-09-19_07-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:39 2023-09-19_07-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:39 2023-09-19_07-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:40 2023-09-19_07-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:40 2023-09-19_07-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:41 2023-09-19_07-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 07:41 2023-09-19_07-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:42 2023-09-19_07-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:42 2023-09-19_07-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:43 2023-09-19_07-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:43 2023-09-19_07-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:44 2023-09-19_07-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 07:44 2023-09-19_07-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:45 2023-09-19_07-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:45 2023-09-19_07-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:46 2023-09-19_07-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:46 2023-09-19_07-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:47 2023-09-19_07-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:47 2023-09-19_07-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:48 2023-09-19_07-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:48 2023-09-19_07-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:49 2023-09-19_07-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:49 2023-09-19_07-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:50 2023-09-19_07-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:50 2023-09-19_07-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:51 2023-09-19_07-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:51 2023-09-19_07-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:52 2023-09-19_07-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:52 2023-09-19_07-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:53 2023-09-19_07-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:53 2023-09-19_07-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:54 2023-09-19_07-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:54 2023-09-19_07-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:55 2023-09-19_07-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:55 2023-09-19_07-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:56 2023-09-19_07-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:56 2023-09-19_07-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:57 2023-09-19_07-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:57 2023-09-19_07-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:58 2023-09-19_07-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:58 2023-09-19_07-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:59 2023-09-19_07-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:59 2023-09-19_07-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:00 2023-09-19_08-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 08:00 2023-09-19_08-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:01 2023-09-19_08-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:01 2023-09-19_08-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:02 2023-09-19_08-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 08:02 2023-09-19_08-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:03 2023-09-19_08-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:03 2023-09-19_08-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:04 2023-09-19_08-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 08:04 2023-09-19_08-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:05 2023-09-19_08-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:05 2023-09-19_08-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:06 2023-09-19_08-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:06 2023-09-19_08-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:07 2023-09-19_08-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 08:07 2023-09-19_08-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:08 2023-09-19_08-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:08 2023-09-19_08-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:09 2023-09-19_08-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:09 2023-09-19_08-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:10 2023-09-19_08-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:10 2023-09-19_08-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:11 2023-09-19_08-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:11 2023-09-19_08-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:12 2023-09-19_08-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:12 2023-09-19_08-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:13 2023-09-19_08-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:13 2023-09-19_08-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:14 2023-09-19_08-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:14 2023-09-19_08-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:15 2023-09-19_08-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:15 2023-09-19_08-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:16 2023-09-19_08-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 08:16 2023-09-19_08-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:17 2023-09-19_08-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:17 2023-09-19_08-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:18 2023-09-19_08-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:18 2023-09-19_08-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:19 2023-09-19_08-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:19 2023-09-19_08-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:20 2023-09-19_08-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 08:20 2023-09-19_08-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:21 2023-09-19_08-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:21 2023-09-19_08-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:22 2023-09-19_08-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:22 2023-09-19_08-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:23 2023-09-19_08-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:23 2023-09-19_08-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:24 2023-09-19_08-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:24 2023-09-19_08-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:25 2023-09-19_08-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:25 2023-09-19_08-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:26 2023-09-19_08-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:26 2023-09-19_08-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:27 2023-09-19_08-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 08:27 2023-09-19_08-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:28 2023-09-19_08-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:28 2023-09-19_08-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:29 2023-09-19_08-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:29 2023-09-19_08-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:30 2023-09-19_08-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:30 2023-09-19_08-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:31 2023-09-19_08-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:31 2023-09-19_08-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:32 2023-09-19_08-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:32 2023-09-19_08-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:33 2023-09-19_08-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:33 2023-09-19_08-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:34 2023-09-19_08-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:34 2023-09-19_08-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:35 2023-09-19_08-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:35 2023-09-19_08-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:36 2023-09-19_08-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:36 2023-09-19_08-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:37 2023-09-19_08-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:37 2023-09-19_08-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:38 2023-09-19_08-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:38 2023-09-19_08-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:39 2023-09-19_08-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:39 2023-09-19_08-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:40 2023-09-19_08-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:40 2023-09-19_08-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:41 2023-09-19_08-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:41 2023-09-19_08-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:42 2023-09-19_08-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:42 2023-09-19_08-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:43 2023-09-19_08-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:43 2023-09-19_08-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:44 2023-09-19_08-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:44 2023-09-19_08-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:45 2023-09-19_08-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:45 2023-09-19_08-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:46 2023-09-19_08-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:46 2023-09-19_08-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:47 2023-09-19_08-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:47 2023-09-19_08-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:48 2023-09-19_08-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 08:48 2023-09-19_08-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:49 2023-09-19_08-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:49 2023-09-19_08-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:50 2023-09-19_08-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:50 2023-09-19_08-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:51 2023-09-19_08-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:51 2023-09-19_08-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:52 2023-09-19_08-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:52 2023-09-19_08-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:53 2023-09-19_08-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 08:53 2023-09-19_08-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:54 2023-09-19_08-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:54 2023-09-19_08-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:55 2023-09-19_08-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:55 2023-09-19_08-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:56 2023-09-19_08-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 08:56 2023-09-19_08-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:57 2023-09-19_08-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:57 2023-09-19_08-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:58 2023-09-19_08-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:58 2023-09-19_08-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:59 2023-09-19_08-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 08:59 2023-09-19_08-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:00 2023-09-19_09-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:00 2023-09-19_09-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:01 2023-09-19_09-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 09:01 2023-09-19_09-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:02 2023-09-19_09-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:02 2023-09-19_09-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:03 2023-09-19_09-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:03 2023-09-19_09-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:04 2023-09-19_09-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:04 2023-09-19_09-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:05 2023-09-19_09-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:05 2023-09-19_09-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:06 2023-09-19_09-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:06 2023-09-19_09-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:07 2023-09-19_09-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:07 2023-09-19_09-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:08 2023-09-19_09-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 09:08 2023-09-19_09-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:09 2023-09-19_09-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:09 2023-09-19_09-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:10 2023-09-19_09-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:10 2023-09-19_09-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:11 2023-09-19_09-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:11 2023-09-19_09-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:12 2023-09-19_09-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:12 2023-09-19_09-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:13 2023-09-19_09-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 09:13 2023-09-19_09-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:14 2023-09-19_09-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:14 2023-09-19_09-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:15 2023-09-19_09-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:15 2023-09-19_09-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:16 2023-09-19_09-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:16 2023-09-19_09-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:17 2023-09-19_09-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:17 2023-09-19_09-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:18 2023-09-19_09-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 09:18 2023-09-19_09-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:19 2023-09-19_09-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:19 2023-09-19_09-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:20 2023-09-19_09-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  487 Sep 19 09:20 2023-09-19_09-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:21 2023-09-19_09-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:21 2023-09-19_09-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:22 2023-09-19_09-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:22 2023-09-19_09-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:23 2023-09-19_09-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:23 2023-09-19_09-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:24 2023-09-19_09-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 09:24 2023-09-19_09-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:25 2023-09-19_09-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:25 2023-09-19_09-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:26 2023-09-19_09-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:26 2023-09-19_09-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:27 2023-09-19_09-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:27 2023-09-19_09-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:28 2023-09-19_09-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 09:28 2023-09-19_09-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:29 2023-09-19_09-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:29 2023-09-19_09-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:30 2023-09-19_09-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:30 2023-09-19_09-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:31 2023-09-19_09-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:31 2023-09-19_09-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:32 2023-09-19_09-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 09:32 2023-09-19_09-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:33 2023-09-19_09-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:33 2023-09-19_09-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:34 2023-09-19_09-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 09:34 2023-09-19_09-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:35 2023-09-19_09-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:35 2023-09-19_09-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:36 2023-09-19_09-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:36 2023-09-19_09-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:37 2023-09-19_09-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:37 2023-09-19_09-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:38 2023-09-19_09-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:38 2023-09-19_09-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:39 2023-09-19_09-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 09:39 2023-09-19_09-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:40 2023-09-19_09-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:40 2023-09-19_09-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:41 2023-09-19_09-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:41 2023-09-19_09-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:42 2023-09-19_09-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 09:42 2023-09-19_09-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:43 2023-09-19_09-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:43 2023-09-19_09-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:44 2023-09-19_09-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:44 2023-09-19_09-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:45 2023-09-19_09-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:45 2023-09-19_09-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:46 2023-09-19_09-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:46 2023-09-19_09-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:47 2023-09-19_09-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 09:47 2023-09-19_09-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:48 2023-09-19_09-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:48 2023-09-19_09-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:49 2023-09-19_09-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:49 2023-09-19_09-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:50 2023-09-19_09-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:50 2023-09-19_09-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:51 2023-09-19_09-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 09:51 2023-09-19_09-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:52 2023-09-19_09-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:52 2023-09-19_09-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:53 2023-09-19_09-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:53 2023-09-19_09-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:54 2023-09-19_09-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:54 2023-09-19_09-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:55 2023-09-19_09-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:55 2023-09-19_09-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:56 2023-09-19_09-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:56 2023-09-19_09-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:57 2023-09-19_09-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:57 2023-09-19_09-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:58 2023-09-19_09-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:58 2023-09-19_09-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:59 2023-09-19_09-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:59 2023-09-19_09-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:00 2023-09-19_10-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:00 2023-09-19_10-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:01 2023-09-19_10-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:01 2023-09-19_10-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:02 2023-09-19_10-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 10:02 2023-09-19_10-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:03 2023-09-19_10-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:03 2023-09-19_10-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:04 2023-09-19_10-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:04 2023-09-19_10-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:05 2023-09-19_10-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:05 2023-09-19_10-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:06 2023-09-19_10-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:06 2023-09-19_10-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:07 2023-09-19_10-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:07 2023-09-19_10-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:08 2023-09-19_10-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:08 2023-09-19_10-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:09 2023-09-19_10-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:09 2023-09-19_10-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:10 2023-09-19_10-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:10 2023-09-19_10-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:11 2023-09-19_10-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:11 2023-09-19_10-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:12 2023-09-19_10-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:12 2023-09-19_10-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:13 2023-09-19_10-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:13 2023-09-19_10-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:14 2023-09-19_10-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 10:14 2023-09-19_10-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:15 2023-09-19_10-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:15 2023-09-19_10-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:16 2023-09-19_10-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 10:16 2023-09-19_10-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:17 2023-09-19_10-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:17 2023-09-19_10-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:18 2023-09-19_10-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:18 2023-09-19_10-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:19 2023-09-19_10-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:19 2023-09-19_10-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:20 2023-09-19_10-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:20 2023-09-19_10-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:21 2023-09-19_10-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:21 2023-09-19_10-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:22 2023-09-19_10-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:22 2023-09-19_10-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:23 2023-09-19_10-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:23 2023-09-19_10-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:24 2023-09-19_10-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:24 2023-09-19_10-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:25 2023-09-19_10-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:25 2023-09-19_10-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:26 2023-09-19_10-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:26 2023-09-19_10-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:27 2023-09-19_10-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:27 2023-09-19_10-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:28 2023-09-19_10-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:28 2023-09-19_10-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:29 2023-09-19_10-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:29 2023-09-19_10-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:30 2023-09-19_10-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:30 2023-09-19_10-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:31 2023-09-19_10-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:31 2023-09-19_10-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:32 2023-09-19_10-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:32 2023-09-19_10-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:33 2023-09-19_10-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:33 2023-09-19_10-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:34 2023-09-19_10-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:34 2023-09-19_10-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:35 2023-09-19_10-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 10:35 2023-09-19_10-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:36 2023-09-19_10-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:36 2023-09-19_10-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:37 2023-09-19_10-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 10:37 2023-09-19_10-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:38 2023-09-19_10-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:38 2023-09-19_10-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:39 2023-09-19_10-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:39 2023-09-19_10-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:40 2023-09-19_10-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:40 2023-09-19_10-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:41 2023-09-19_10-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:41 2023-09-19_10-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:42 2023-09-19_10-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 10:42 2023-09-19_10-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:43 2023-09-19_10-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:43 2023-09-19_10-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:44 2023-09-19_10-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:44 2023-09-19_10-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:45 2023-09-19_10-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:45 2023-09-19_10-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:46 2023-09-19_10-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:46 2023-09-19_10-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:47 2023-09-19_10-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:47 2023-09-19_10-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:48 2023-09-19_10-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:48 2023-09-19_10-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:49 2023-09-19_10-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:49 2023-09-19_10-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:50 2023-09-19_10-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:50 2023-09-19_10-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:51 2023-09-19_10-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:51 2023-09-19_10-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:52 2023-09-19_10-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:52 2023-09-19_10-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:53 2023-09-19_10-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:53 2023-09-19_10-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:54 2023-09-19_10-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:54 2023-09-19_10-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:55 2023-09-19_10-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:55 2023-09-19_10-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:56 2023-09-19_10-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 10:56 2023-09-19_10-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:57 2023-09-19_10-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:57 2023-09-19_10-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:58 2023-09-19_10-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:58 2023-09-19_10-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:51 2023-09-19_11-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 11:51 2023-09-19_11-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:52 2023-09-19_11-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:52 2023-09-19_11-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:53 2023-09-19_11-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:53 2023-09-19_11-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:54 2023-09-19_11-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 11:54 2023-09-19_11-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:55 2023-09-19_11-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 11:55 2023-09-19_11-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:56 2023-09-19_11-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  440 Sep 19 11:56 2023-09-19_11-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:57 2023-09-19_11-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 11:57 2023-09-19_11-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:58 2023-09-19_11-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 11:58 2023-09-19_11-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:59 2023-09-19_11-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 11:59 2023-09-19_11-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:00 2023-09-19_12-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:00 2023-09-19_12-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:01 2023-09-19_12-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:01 2023-09-19_12-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:02 2023-09-19_12-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:02 2023-09-19_12-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:03 2023-09-19_12-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:03 2023-09-19_12-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:04 2023-09-19_12-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:04 2023-09-19_12-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:05 2023-09-19_12-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:05 2023-09-19_12-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:06 2023-09-19_12-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  433 Sep 19 12:06 2023-09-19_12-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:07 2023-09-19_12-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:07 2023-09-19_12-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:08 2023-09-19_12-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 12:08 2023-09-19_12-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:09 2023-09-19_12-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:09 2023-09-19_12-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:10 2023-09-19_12-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  446 Sep 19 12:10 2023-09-19_12-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:11 2023-09-19_12-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:11 2023-09-19_12-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:12 2023-09-19_12-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:12 2023-09-19_12-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:13 2023-09-19_12-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 12:13 2023-09-19_12-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:14 2023-09-19_12-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:14 2023-09-19_12-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:16 2023-09-19_12-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:16 2023-09-19_12-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:17 2023-09-19_12-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:17 2023-09-19_12-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:18 2023-09-19_12-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:18 2023-09-19_12-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:19 2023-09-19_12-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:19 2023-09-19_12-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:20 2023-09-19_12-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:20 2023-09-19_12-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:21 2023-09-19_12-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:21 2023-09-19_12-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:22 2023-09-19_12-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:22 2023-09-19_12-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:23 2023-09-19_12-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:23 2023-09-19_12-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:24 2023-09-19_12-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:24 2023-09-19_12-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:25 2023-09-19_12-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:25 2023-09-19_12-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:26 2023-09-19_12-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:26 2023-09-19_12-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:27 2023-09-19_12-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:27 2023-09-19_12-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:28 2023-09-19_12-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:28 2023-09-19_12-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:29 2023-09-19_12-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:29 2023-09-19_12-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:30 2023-09-19_12-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:30 2023-09-19_12-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:31 2023-09-19_12-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 12:31 2023-09-19_12-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:32 2023-09-19_12-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:32 2023-09-19_12-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:33 2023-09-19_12-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  442 Sep 19 12:33 2023-09-19_12-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:34 2023-09-19_12-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 12:34 2023-09-19_12-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:35 2023-09-19_12-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:35 2023-09-19_12-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:36 2023-09-19_12-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:36 2023-09-19_12-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:37 2023-09-19_12-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:37 2023-09-19_12-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:38 2023-09-19_12-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:38 2023-09-19_12-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:39 2023-09-19_12-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:39 2023-09-19_12-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:41 2023-09-19_12-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 12:41 2023-09-19_12-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:42 2023-09-19_12-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  450 Sep 19 12:42 2023-09-19_12-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:43 2023-09-19_12-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:43 2023-09-19_12-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:44 2023-09-19_12-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:44 2023-09-19_12-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:45 2023-09-19_12-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:46 2023-09-19_12-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:47 2023-09-19_12-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:48 2023-09-19_12-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:49 2023-09-19_12-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:50 2023-09-19_12-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:51 2023-09-19_12-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:52 2023-09-19_12-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:53 2023-09-19_12-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:54 2023-09-19_12-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:55 2023-09-19_12-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:55 2023-09-19_12-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:56 2023-09-19_12-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:56 2023-09-19_12-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:57 2023-09-19_12-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:57 2023-09-19_12-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:58 2023-09-19_12-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:58 2023-09-19_12-58_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 12:59 2023-09-19_12-59_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 12:59 2023-09-19_12-59_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:00 2023-09-19_13-00_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 13:00 2023-09-19_13-00_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:01 2023-09-19_13-01_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:01 2023-09-19_13-01_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:02 2023-09-19_13-02_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:02 2023-09-19_13-02_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:03 2023-09-19_13-03_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:03 2023-09-19_13-03_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:04 2023-09-19_13-04_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:04 2023-09-19_13-04_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:05 2023-09-19_13-05_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:05 2023-09-19_13-05_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:06 2023-09-19_13-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:06 2023-09-19_13-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:07 2023-09-19_13-07_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:07 2023-09-19_13-07_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:08 2023-09-19_13-08_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:08 2023-09-19_13-08_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:09 2023-09-19_13-09_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:09 2023-09-19_13-09_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:10 2023-09-19_13-10_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:10 2023-09-19_13-10_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:11 2023-09-19_13-11_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:11 2023-09-19_13-11_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:12 2023-09-19_13-12_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:12 2023-09-19_13-12_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:13 2023-09-19_13-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:13 2023-09-19_13-13_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:14 2023-09-19_13-14_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:14 2023-09-19_13-14_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:15 2023-09-19_13-15_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:15 2023-09-19_13-15_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:16 2023-09-19_13-16_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 13:16 2023-09-19_13-16_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:17 2023-09-19_13-17_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:17 2023-09-19_13-17_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:18 2023-09-19_13-18_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:18 2023-09-19_13-18_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:19 2023-09-19_13-19_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  433 Sep 19 13:19 2023-09-19_13-19_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:20 2023-09-19_13-20_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:20 2023-09-19_13-20_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 2.4K Sep 19 13:21 2023-09-19_13-21_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:21 2023-09-19_13-21_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 2.9K Sep 19 13:22 2023-09-19_13-22_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:22 2023-09-19_13-22_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 3.7K Sep 19 13:23 2023-09-19_13-23_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:23 2023-09-19_13-23_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.3K Sep 19 13:24 2023-09-19_13-24_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:24 2023-09-19_13-24_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.4K Sep 19 13:25 2023-09-19_13-25_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:25 2023-09-19_13-25_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:26 2023-09-19_13-26_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:26 2023-09-19_13-26_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:27 2023-09-19_13-27_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:27 2023-09-19_13-27_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:28 2023-09-19_13-28_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:28 2023-09-19_13-28_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:29 2023-09-19_13-29_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:29 2023-09-19_13-29_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:30 2023-09-19_13-30_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:30 2023-09-19_13-30_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:31 2023-09-19_13-31_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:31 2023-09-19_13-31_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:32 2023-09-19_13-32_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  443 Sep 19 13:32 2023-09-19_13-32_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:33 2023-09-19_13-33_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 13:33 2023-09-19_13-33_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:34 2023-09-19_13-34_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 13:34 2023-09-19_13-34_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:35 2023-09-19_13-35_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:35 2023-09-19_13-35_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:36 2023-09-19_13-36_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:36 2023-09-19_13-36_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:37 2023-09-19_13-37_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:37 2023-09-19_13-37_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:38 2023-09-19_13-38_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  474 Sep 19 13:38 2023-09-19_13-38_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:39 2023-09-19_13-39_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:39 2023-09-19_13-39_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:40 2023-09-19_13-40_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 13:40 2023-09-19_13-40_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:41 2023-09-19_13-41_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:41 2023-09-19_13-41_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:42 2023-09-19_13-42_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 13:42 2023-09-19_13-42_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:43 2023-09-19_13-43_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  475 Sep 19 13:43 2023-09-19_13-43_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:44 2023-09-19_13-44_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:44 2023-09-19_13-44_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:45 2023-09-19_13-45_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:45 2023-09-19_13-45_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:46 2023-09-19_13-46_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:46 2023-09-19_13-46_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:47 2023-09-19_13-47_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:47 2023-09-19_13-47_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:48 2023-09-19_13-48_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:48 2023-09-19_13-48_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:49 2023-09-19_13-49_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:49 2023-09-19_13-49_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:50 2023-09-19_13-50_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  466 Sep 19 13:50 2023-09-19_13-50_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:51 2023-09-19_13-51_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:51 2023-09-19_13-51_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:52 2023-09-19_13-52_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 13:52 2023-09-19_13-52_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:53 2023-09-19_13-53_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:53 2023-09-19_13-53_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:54 2023-09-19_13-54_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:54 2023-09-19_13-54_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:55 2023-09-19_13-55_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  468 Sep 19 13:55 2023-09-19_13-55_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:56 2023-09-19_13-56_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:56 2023-09-19_13-56_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:57 2023-09-19_13-57_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:57 2023-09-19_13-57_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:58 2023-09-19_13-58_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:58 2023-09-19_13-58_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:59 2023-09-19_13-59_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:59 2023-09-19_13-59_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:00 2023-09-19_14-00_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:00 2023-09-19_14-00_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:01 2023-09-19_14-01_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:01 2023-09-19_14-01_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:02 2023-09-19_14-02_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:02 2023-09-19_14-02_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:03 2023-09-19_14-03_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:03 2023-09-19_14-03_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:04 2023-09-19_14-04_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:04 2023-09-19_14-04_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:05 2023-09-19_14-05_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:05 2023-09-19_14-05_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:06 2023-09-19_14-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:06 2023-09-19_14-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:07 2023-09-19_14-07_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:07 2023-09-19_14-07_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:08 2023-09-19_14-08_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:08 2023-09-19_14-08_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:09 2023-09-19_14-09_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:09 2023-09-19_14-09_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:10 2023-09-19_14-10_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:10 2023-09-19_14-10_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:11 2023-09-19_14-11_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:11 2023-09-19_14-11_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:12 2023-09-19_14-12_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:12 2023-09-19_14-12_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:13 2023-09-19_14-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 14:13 2023-09-19_14-13_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:14 2023-09-19_14-14_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:14 2023-09-19_14-14_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:15 2023-09-19_14-15_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:15 2023-09-19_14-15_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:16 2023-09-19_14-16_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:16 2023-09-19_14-16_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:17 2023-09-19_14-17_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 14:17 2023-09-19_14-17_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:18 2023-09-19_14-18_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:18 2023-09-19_14-18_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:19 2023-09-19_14-19_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:19 2023-09-19_14-19_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:20 2023-09-19_14-20_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:20 2023-09-19_14-20_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:21 2023-09-19_14-21_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:21 2023-09-19_14-21_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:22 2023-09-19_14-22_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:22 2023-09-19_14-22_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:23 2023-09-19_14-23_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:23 2023-09-19_14-23_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:24 2023-09-19_14-24_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  440 Sep 19 14:24 2023-09-19_14-24_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:25 2023-09-19_14-25_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:25 2023-09-19_14-25_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:26 2023-09-19_14-26_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:26 2023-09-19_14-26_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:27 2023-09-19_14-27_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:27 2023-09-19_14-27_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:28 2023-09-19_14-28_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:28 2023-09-19_14-28_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:29 2023-09-19_14-29_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:29 2023-09-19_14-29_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:30 2023-09-19_14-30_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 14:30 2023-09-19_14-30_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:31 2023-09-19_14-31_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:31 2023-09-19_14-31_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:32 2023-09-19_14-32_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:32 2023-09-19_14-32_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:33 2023-09-19_14-33_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  438 Sep 19 14:33 2023-09-19_14-33_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:34 2023-09-19_14-34_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:34 2023-09-19_14-34_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:35 2023-09-19_14-35_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:35 2023-09-19_14-35_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:36 2023-09-19_14-36_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:36 2023-09-19_14-36_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:37 2023-09-19_14-37_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:37 2023-09-19_14-37_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:38 2023-09-19_14-38_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:38 2023-09-19_14-38_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:39 2023-09-19_14-39_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:39 2023-09-19_14-39_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:40 2023-09-19_14-40_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:40 2023-09-19_14-40_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:41 2023-09-19_14-41_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:41 2023-09-19_14-41_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:42 2023-09-19_14-42_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:42 2023-09-19_14-42_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:43 2023-09-19_14-43_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 14:43 2023-09-19_14-43_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:44 2023-09-19_14-44_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:44 2023-09-19_14-44_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:45 2023-09-19_14-45_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:45 2023-09-19_14-45_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:46 2023-09-19_14-46_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:46 2023-09-19_14-46_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:47 2023-09-19_14-47_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  442 Sep 19 14:47 2023-09-19_14-47_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:48 2023-09-19_14-48_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:48 2023-09-19_14-48_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:49 2023-09-19_14-49_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:49 2023-09-19_14-49_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:50 2023-09-19_14-50_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 14:50 2023-09-19_14-50_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:51 2023-09-19_14-51_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:51 2023-09-19_14-51_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:52 2023-09-19_14-52_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:52 2023-09-19_14-52_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:53 2023-09-19_14-53_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:53 2023-09-19_14-53_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:54 2023-09-19_14-54_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:54 2023-09-19_14-54_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:55 2023-09-19_14-55_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:55 2023-09-19_14-55_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:56 2023-09-19_14-56_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:56 2023-09-19_14-56_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:57 2023-09-19_14-57_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:57 2023-09-19_14-57_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:58 2023-09-19_14-58_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:58 2023-09-19_14-58_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:59 2023-09-19_14-59_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:59 2023-09-19_14-59_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:00 2023-09-19_15-00_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  465 Sep 19 15:00 2023-09-19_15-00_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:01 2023-09-19_15-01_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 15:01 2023-09-19_15-01_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:02 2023-09-19_15-02_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:02 2023-09-19_15-02_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:03 2023-09-19_15-03_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:03 2023-09-19_15-03_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:04 2023-09-19_15-04_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 15:04 2023-09-19_15-04_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:05 2023-09-19_15-05_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:05 2023-09-19_15-05_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:06 2023-09-19_15-06_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:06 2023-09-19_15-06_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:07 2023-09-19_15-07_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:07 2023-09-19_15-07_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:08 2023-09-19_15-08_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 15:08 2023-09-19_15-08_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:09 2023-09-19_15-09_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:09 2023-09-19_15-09_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:10 2023-09-19_15-10_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 15:10 2023-09-19_15-10_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:11 2023-09-19_15-11_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:11 2023-09-19_15-11_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:12 2023-09-19_15-12_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 15:12 2023-09-19_15-12_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:13 2023-09-19_15-13_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:13 2023-09-19_15-13_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:14 2023-09-19_15-14_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:14 2023-09-19_15-14_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:15 2023-09-19_15-15_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:15 2023-09-19_15-15_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:16 2023-09-19_15-16_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:16 2023-09-19_15-16_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:17 2023-09-19_15-17_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:17 2023-09-19_15-17_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:18 2023-09-19_15-18_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:18 2023-09-19_15-18_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:19 2023-09-19_15-19_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 15:19 2023-09-19_15-19_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:20 2023-09-19_15-20_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 15:20 2023-09-19_15-20_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:21 2023-09-19_15-21_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 15:21 2023-09-19_15-21_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:22 2023-09-19_15-22_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:22 2023-09-19_15-22_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:23 2023-09-19_15-23_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:23 2023-09-19_15-23_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:24 2023-09-19_15-24_objects.json.gz
            -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 15:24 2023-09-19_15-24_states.json.gz
            -rw-rw-r--+ 1 iobroker iobroker 6.1K Sep 19 15:25 2023-09-19_15-25_states.json.gz
            ubuntu@ubuntu:/opt/iobroker$
            Esmax666
            @esmax666 teil 2
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:16 2023-09-18_21-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:17 2023-09-18_21-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:17 2023-09-18_21-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:18 2023-09-18_21-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 21:18 2023-09-18_21-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:19 2023-09-18_21-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 21:19 2023-09-18_21-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:20 2023-09-18_21-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  447 Sep 18 21:20 2023-09-18_21-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:21 2023-09-18_21-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 21:21 2023-09-18_21-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:22 2023-09-18_21-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 21:22 2023-09-18_21-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:23 2023-09-18_21-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:23 2023-09-18_21-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:24 2023-09-18_21-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 18 21:24 2023-09-18_21-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:25 2023-09-18_21-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 18 21:25 2023-09-18_21-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:26 2023-09-18_21-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 21:26 2023-09-18_21-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:27 2023-09-18_21-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 21:27 2023-09-18_21-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:28 2023-09-18_21-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:28 2023-09-18_21-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:29 2023-09-18_21-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 18 21:29 2023-09-18_21-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:30 2023-09-18_21-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 18 21:30 2023-09-18_21-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:31 2023-09-18_21-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 21:31 2023-09-18_21-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:32 2023-09-18_21-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 18 21:32 2023-09-18_21-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:33 2023-09-18_21-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:33 2023-09-18_21-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:34 2023-09-18_21-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 21:34 2023-09-18_21-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:35 2023-09-18_21-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 21:35 2023-09-18_21-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:36 2023-09-18_21-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 21:36 2023-09-18_21-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:37 2023-09-18_21-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 21:37 2023-09-18_21-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:38 2023-09-18_21-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 21:38 2023-09-18_21-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:39 2023-09-18_21-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 21:39 2023-09-18_21-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:40 2023-09-18_21-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 21:40 2023-09-18_21-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:41 2023-09-18_21-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 18 21:41 2023-09-18_21-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:42 2023-09-18_21-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:42 2023-09-18_21-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:43 2023-09-18_21-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 21:43 2023-09-18_21-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:44 2023-09-18_21-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 21:44 2023-09-18_21-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:45 2023-09-18_21-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 21:45 2023-09-18_21-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:46 2023-09-18_21-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 21:46 2023-09-18_21-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:47 2023-09-18_21-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 21:47 2023-09-18_21-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:48 2023-09-18_21-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 21:48 2023-09-18_21-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:49 2023-09-18_21-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 21:49 2023-09-18_21-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:50 2023-09-18_21-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 21:50 2023-09-18_21-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:51 2023-09-18_21-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 21:51 2023-09-18_21-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:52 2023-09-18_21-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 21:52 2023-09-18_21-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:53 2023-09-18_21-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 18 21:53 2023-09-18_21-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:54 2023-09-18_21-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 18 21:54 2023-09-18_21-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:55 2023-09-18_21-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 21:55 2023-09-18_21-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:56 2023-09-18_21-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 18 21:56 2023-09-18_21-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:57 2023-09-18_21-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 21:57 2023-09-18_21-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:58 2023-09-18_21-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 18 21:58 2023-09-18_21-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 21:59 2023-09-18_21-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 21:59 2023-09-18_21-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:00 2023-09-18_22-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:00 2023-09-18_22-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:01 2023-09-18_22-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:01 2023-09-18_22-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:02 2023-09-18_22-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:02 2023-09-18_22-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:03 2023-09-18_22-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:03 2023-09-18_22-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:04 2023-09-18_22-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 18 22:04 2023-09-18_22-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:05 2023-09-18_22-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 18 22:05 2023-09-18_22-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:06 2023-09-18_22-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 22:06 2023-09-18_22-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:07 2023-09-18_22-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:07 2023-09-18_22-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:08 2023-09-18_22-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:08 2023-09-18_22-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:09 2023-09-18_22-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:09 2023-09-18_22-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:10 2023-09-18_22-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:10 2023-09-18_22-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:11 2023-09-18_22-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:11 2023-09-18_22-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:12 2023-09-18_22-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 22:12 2023-09-18_22-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:13 2023-09-18_22-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:13 2023-09-18_22-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:14 2023-09-18_22-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 22:14 2023-09-18_22-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:15 2023-09-18_22-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 18 22:15 2023-09-18_22-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:16 2023-09-18_22-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:16 2023-09-18_22-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:17 2023-09-18_22-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 22:17 2023-09-18_22-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:18 2023-09-18_22-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:18 2023-09-18_22-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:19 2023-09-18_22-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:19 2023-09-18_22-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:20 2023-09-18_22-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 18 22:20 2023-09-18_22-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:21 2023-09-18_22-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:21 2023-09-18_22-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:22 2023-09-18_22-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:22 2023-09-18_22-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:23 2023-09-18_22-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:23 2023-09-18_22-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:24 2023-09-18_22-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 22:24 2023-09-18_22-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:25 2023-09-18_22-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:25 2023-09-18_22-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:26 2023-09-18_22-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 18 22:26 2023-09-18_22-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:27 2023-09-18_22-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:27 2023-09-18_22-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:28 2023-09-18_22-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:28 2023-09-18_22-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:29 2023-09-18_22-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 22:29 2023-09-18_22-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:30 2023-09-18_22-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:30 2023-09-18_22-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:31 2023-09-18_22-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:31 2023-09-18_22-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:32 2023-09-18_22-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:32 2023-09-18_22-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:33 2023-09-18_22-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 22:33 2023-09-18_22-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:34 2023-09-18_22-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 22:34 2023-09-18_22-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:35 2023-09-18_22-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:35 2023-09-18_22-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:36 2023-09-18_22-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:36 2023-09-18_22-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:37 2023-09-18_22-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:37 2023-09-18_22-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:38 2023-09-18_22-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 22:38 2023-09-18_22-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:39 2023-09-18_22-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:39 2023-09-18_22-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:40 2023-09-18_22-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 18 22:40 2023-09-18_22-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:41 2023-09-18_22-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:41 2023-09-18_22-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:42 2023-09-18_22-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 22:42 2023-09-18_22-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:43 2023-09-18_22-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 18 22:43 2023-09-18_22-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:44 2023-09-18_22-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 22:44 2023-09-18_22-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:45 2023-09-18_22-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 18 22:45 2023-09-18_22-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:46 2023-09-18_22-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 22:46 2023-09-18_22-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:47 2023-09-18_22-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:47 2023-09-18_22-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:48 2023-09-18_22-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  485 Sep 18 22:48 2023-09-18_22-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:49 2023-09-18_22-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 22:49 2023-09-18_22-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:50 2023-09-18_22-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:50 2023-09-18_22-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:51 2023-09-18_22-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 22:51 2023-09-18_22-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:52 2023-09-18_22-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 22:52 2023-09-18_22-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:53 2023-09-18_22-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 22:53 2023-09-18_22-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:54 2023-09-18_22-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 22:54 2023-09-18_22-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:55 2023-09-18_22-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 18 22:55 2023-09-18_22-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:56 2023-09-18_22-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:56 2023-09-18_22-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:57 2023-09-18_22-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 22:57 2023-09-18_22-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:58 2023-09-18_22-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 18 22:58 2023-09-18_22-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 22:59 2023-09-18_22-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 22:59 2023-09-18_22-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:00 2023-09-18_23-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 23:00 2023-09-18_23-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:01 2023-09-18_23-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 18 23:01 2023-09-18_23-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:02 2023-09-18_23-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 18 23:02 2023-09-18_23-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:03 2023-09-18_23-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:03 2023-09-18_23-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:04 2023-09-18_23-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:04 2023-09-18_23-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:05 2023-09-18_23-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 23:05 2023-09-18_23-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:06 2023-09-18_23-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 23:06 2023-09-18_23-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:07 2023-09-18_23-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:07 2023-09-18_23-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:08 2023-09-18_23-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:08 2023-09-18_23-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:09 2023-09-18_23-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:09 2023-09-18_23-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:10 2023-09-18_23-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:10 2023-09-18_23-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:11 2023-09-18_23-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 18 23:11 2023-09-18_23-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:12 2023-09-18_23-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:12 2023-09-18_23-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:13 2023-09-18_23-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 18 23:13 2023-09-18_23-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:14 2023-09-18_23-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 18 23:14 2023-09-18_23-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:15 2023-09-18_23-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:15 2023-09-18_23-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:16 2023-09-18_23-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:16 2023-09-18_23-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:17 2023-09-18_23-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:17 2023-09-18_23-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:18 2023-09-18_23-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 23:18 2023-09-18_23-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:19 2023-09-18_23-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 18 23:19 2023-09-18_23-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:20 2023-09-18_23-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 23:20 2023-09-18_23-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:21 2023-09-18_23-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 23:21 2023-09-18_23-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:22 2023-09-18_23-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 18 23:22 2023-09-18_23-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:23 2023-09-18_23-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:23 2023-09-18_23-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:24 2023-09-18_23-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 18 23:24 2023-09-18_23-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:25 2023-09-18_23-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 18 23:25 2023-09-18_23-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:26 2023-09-18_23-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:26 2023-09-18_23-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:27 2023-09-18_23-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 18 23:27 2023-09-18_23-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:28 2023-09-18_23-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  450 Sep 18 23:28 2023-09-18_23-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:29 2023-09-18_23-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:29 2023-09-18_23-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:30 2023-09-18_23-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:30 2023-09-18_23-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:31 2023-09-18_23-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 23:31 2023-09-18_23-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:32 2023-09-18_23-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 23:32 2023-09-18_23-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:33 2023-09-18_23-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 18 23:33 2023-09-18_23-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:34 2023-09-18_23-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 23:34 2023-09-18_23-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:35 2023-09-18_23-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:35 2023-09-18_23-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:36 2023-09-18_23-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 18 23:36 2023-09-18_23-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:37 2023-09-18_23-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:37 2023-09-18_23-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:38 2023-09-18_23-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:38 2023-09-18_23-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:39 2023-09-18_23-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 23:39 2023-09-18_23-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:40 2023-09-18_23-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:40 2023-09-18_23-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:41 2023-09-18_23-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:41 2023-09-18_23-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:42 2023-09-18_23-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:42 2023-09-18_23-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:43 2023-09-18_23-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 18 23:43 2023-09-18_23-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:44 2023-09-18_23-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:44 2023-09-18_23-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:45 2023-09-18_23-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 18 23:45 2023-09-18_23-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:46 2023-09-18_23-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:46 2023-09-18_23-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:47 2023-09-18_23-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:47 2023-09-18_23-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:48 2023-09-18_23-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 18 23:48 2023-09-18_23-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:49 2023-09-18_23-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:49 2023-09-18_23-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:50 2023-09-18_23-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 18 23:50 2023-09-18_23-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:51 2023-09-18_23-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 18 23:51 2023-09-18_23-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:52 2023-09-18_23-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 18 23:52 2023-09-18_23-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:53 2023-09-18_23-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 18 23:53 2023-09-18_23-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:54 2023-09-18_23-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:54 2023-09-18_23-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:55 2023-09-18_23-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 18 23:55 2023-09-18_23-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:56 2023-09-18_23-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 18 23:56 2023-09-18_23-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:57 2023-09-18_23-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 18 23:57 2023-09-18_23-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:58 2023-09-18_23-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 18 23:58 2023-09-18_23-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 18 23:59 2023-09-18_23-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 18 23:59 2023-09-18_23-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:00 2023-09-19_00-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 00:00 2023-09-19_00-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:01 2023-09-19_00-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:01 2023-09-19_00-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:02 2023-09-19_00-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:02 2023-09-19_00-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:03 2023-09-19_00-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:03 2023-09-19_00-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:04 2023-09-19_00-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:04 2023-09-19_00-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:05 2023-09-19_00-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 00:05 2023-09-19_00-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:06 2023-09-19_00-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:06 2023-09-19_00-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:07 2023-09-19_00-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:07 2023-09-19_00-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:08 2023-09-19_00-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:08 2023-09-19_00-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:09 2023-09-19_00-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:09 2023-09-19_00-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:10 2023-09-19_00-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 00:10 2023-09-19_00-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:11 2023-09-19_00-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 00:11 2023-09-19_00-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:12 2023-09-19_00-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 00:12 2023-09-19_00-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:13 2023-09-19_00-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:13 2023-09-19_00-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:14 2023-09-19_00-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 00:14 2023-09-19_00-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:15 2023-09-19_00-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 00:15 2023-09-19_00-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:16 2023-09-19_00-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 00:16 2023-09-19_00-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:17 2023-09-19_00-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 00:17 2023-09-19_00-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:18 2023-09-19_00-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:18 2023-09-19_00-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:19 2023-09-19_00-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 00:19 2023-09-19_00-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:20 2023-09-19_00-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 00:20 2023-09-19_00-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:21 2023-09-19_00-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 00:21 2023-09-19_00-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:22 2023-09-19_00-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:22 2023-09-19_00-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:23 2023-09-19_00-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 00:23 2023-09-19_00-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:24 2023-09-19_00-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:24 2023-09-19_00-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:25 2023-09-19_00-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 00:25 2023-09-19_00-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:26 2023-09-19_00-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:26 2023-09-19_00-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:27 2023-09-19_00-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:27 2023-09-19_00-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:28 2023-09-19_00-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:28 2023-09-19_00-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:29 2023-09-19_00-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 00:29 2023-09-19_00-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:30 2023-09-19_00-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:30 2023-09-19_00-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:31 2023-09-19_00-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 00:31 2023-09-19_00-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:32 2023-09-19_00-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 00:32 2023-09-19_00-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:33 2023-09-19_00-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 00:33 2023-09-19_00-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:34 2023-09-19_00-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 00:34 2023-09-19_00-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:35 2023-09-19_00-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 00:35 2023-09-19_00-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:36 2023-09-19_00-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:36 2023-09-19_00-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:37 2023-09-19_00-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 00:37 2023-09-19_00-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:38 2023-09-19_00-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 00:38 2023-09-19_00-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:39 2023-09-19_00-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 00:39 2023-09-19_00-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:40 2023-09-19_00-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 00:40 2023-09-19_00-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:41 2023-09-19_00-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 00:41 2023-09-19_00-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:42 2023-09-19_00-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 00:42 2023-09-19_00-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:43 2023-09-19_00-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 00:43 2023-09-19_00-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:44 2023-09-19_00-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:44 2023-09-19_00-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:45 2023-09-19_00-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:45 2023-09-19_00-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:46 2023-09-19_00-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 00:46 2023-09-19_00-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:47 2023-09-19_00-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 00:47 2023-09-19_00-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:48 2023-09-19_00-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 00:48 2023-09-19_00-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:49 2023-09-19_00-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:49 2023-09-19_00-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:50 2023-09-19_00-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 00:50 2023-09-19_00-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:51 2023-09-19_00-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 00:51 2023-09-19_00-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:52 2023-09-19_00-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 00:52 2023-09-19_00-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:53 2023-09-19_00-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 00:53 2023-09-19_00-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:54 2023-09-19_00-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 00:54 2023-09-19_00-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:55 2023-09-19_00-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 00:55 2023-09-19_00-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:56 2023-09-19_00-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 00:56 2023-09-19_00-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:57 2023-09-19_00-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 00:57 2023-09-19_00-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:58 2023-09-19_00-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 00:58 2023-09-19_00-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 00:59 2023-09-19_00-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 00:59 2023-09-19_00-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:00 2023-09-19_01-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 01:00 2023-09-19_01-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:01 2023-09-19_01-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:01 2023-09-19_01-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:02 2023-09-19_01-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:02 2023-09-19_01-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:03 2023-09-19_01-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 01:03 2023-09-19_01-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:04 2023-09-19_01-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 01:04 2023-09-19_01-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:05 2023-09-19_01-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:05 2023-09-19_01-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:06 2023-09-19_01-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 01:06 2023-09-19_01-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:07 2023-09-19_01-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:07 2023-09-19_01-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:08 2023-09-19_01-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 01:08 2023-09-19_01-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:09 2023-09-19_01-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:09 2023-09-19_01-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:10 2023-09-19_01-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:10 2023-09-19_01-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:11 2023-09-19_01-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:11 2023-09-19_01-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:12 2023-09-19_01-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 01:12 2023-09-19_01-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:13 2023-09-19_01-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 01:13 2023-09-19_01-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:14 2023-09-19_01-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 01:14 2023-09-19_01-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:15 2023-09-19_01-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:15 2023-09-19_01-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:16 2023-09-19_01-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 01:16 2023-09-19_01-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:17 2023-09-19_01-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 01:17 2023-09-19_01-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:18 2023-09-19_01-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:18 2023-09-19_01-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:19 2023-09-19_01-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:19 2023-09-19_01-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:20 2023-09-19_01-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:20 2023-09-19_01-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:21 2023-09-19_01-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:21 2023-09-19_01-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:22 2023-09-19_01-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:22 2023-09-19_01-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:23 2023-09-19_01-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:23 2023-09-19_01-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:24 2023-09-19_01-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 01:24 2023-09-19_01-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:25 2023-09-19_01-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:25 2023-09-19_01-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:26 2023-09-19_01-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:26 2023-09-19_01-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:27 2023-09-19_01-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:27 2023-09-19_01-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:28 2023-09-19_01-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:28 2023-09-19_01-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:29 2023-09-19_01-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:29 2023-09-19_01-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:30 2023-09-19_01-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 01:30 2023-09-19_01-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:31 2023-09-19_01-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:31 2023-09-19_01-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:32 2023-09-19_01-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 01:32 2023-09-19_01-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:33 2023-09-19_01-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 01:33 2023-09-19_01-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:34 2023-09-19_01-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 01:34 2023-09-19_01-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:35 2023-09-19_01-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 01:35 2023-09-19_01-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:36 2023-09-19_01-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:36 2023-09-19_01-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:37 2023-09-19_01-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 01:37 2023-09-19_01-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:38 2023-09-19_01-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:38 2023-09-19_01-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:39 2023-09-19_01-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 01:39 2023-09-19_01-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:40 2023-09-19_01-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:40 2023-09-19_01-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:41 2023-09-19_01-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:41 2023-09-19_01-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:42 2023-09-19_01-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 01:42 2023-09-19_01-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:43 2023-09-19_01-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 01:43 2023-09-19_01-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:44 2023-09-19_01-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:44 2023-09-19_01-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:45 2023-09-19_01-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 01:45 2023-09-19_01-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:46 2023-09-19_01-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:46 2023-09-19_01-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:47 2023-09-19_01-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:47 2023-09-19_01-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:48 2023-09-19_01-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 01:48 2023-09-19_01-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:49 2023-09-19_01-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 01:49 2023-09-19_01-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:50 2023-09-19_01-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 01:50 2023-09-19_01-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:51 2023-09-19_01-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 01:51 2023-09-19_01-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:52 2023-09-19_01-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 01:52 2023-09-19_01-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:53 2023-09-19_01-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 01:53 2023-09-19_01-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:54 2023-09-19_01-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 01:54 2023-09-19_01-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:55 2023-09-19_01-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 01:55 2023-09-19_01-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:56 2023-09-19_01-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 01:56 2023-09-19_01-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:57 2023-09-19_01-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 01:57 2023-09-19_01-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:58 2023-09-19_01-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 01:58 2023-09-19_01-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 01:59 2023-09-19_01-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 01:59 2023-09-19_01-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:00 2023-09-19_02-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:00 2023-09-19_02-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:01 2023-09-19_02-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 02:01 2023-09-19_02-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:02 2023-09-19_02-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:02 2023-09-19_02-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:03 2023-09-19_02-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 02:03 2023-09-19_02-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:04 2023-09-19_02-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 02:04 2023-09-19_02-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:05 2023-09-19_02-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 02:05 2023-09-19_02-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:06 2023-09-19_02-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 02:06 2023-09-19_02-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:07 2023-09-19_02-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:07 2023-09-19_02-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:08 2023-09-19_02-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 02:08 2023-09-19_02-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:09 2023-09-19_02-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:09 2023-09-19_02-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:10 2023-09-19_02-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 02:10 2023-09-19_02-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:11 2023-09-19_02-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:11 2023-09-19_02-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:12 2023-09-19_02-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 02:12 2023-09-19_02-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:13 2023-09-19_02-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 02:13 2023-09-19_02-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:14 2023-09-19_02-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 02:14 2023-09-19_02-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:15 2023-09-19_02-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 02:15 2023-09-19_02-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:16 2023-09-19_02-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:16 2023-09-19_02-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:17 2023-09-19_02-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:17 2023-09-19_02-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:18 2023-09-19_02-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:18 2023-09-19_02-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:19 2023-09-19_02-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 02:19 2023-09-19_02-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:20 2023-09-19_02-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:20 2023-09-19_02-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:21 2023-09-19_02-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 02:21 2023-09-19_02-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:22 2023-09-19_02-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 02:22 2023-09-19_02-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:23 2023-09-19_02-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 02:23 2023-09-19_02-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:24 2023-09-19_02-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 02:24 2023-09-19_02-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:25 2023-09-19_02-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 02:25 2023-09-19_02-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:26 2023-09-19_02-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:26 2023-09-19_02-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:27 2023-09-19_02-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  489 Sep 19 02:27 2023-09-19_02-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:28 2023-09-19_02-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:28 2023-09-19_02-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:29 2023-09-19_02-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:29 2023-09-19_02-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:30 2023-09-19_02-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 02:30 2023-09-19_02-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:31 2023-09-19_02-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 02:31 2023-09-19_02-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:32 2023-09-19_02-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 02:32 2023-09-19_02-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:33 2023-09-19_02-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 02:33 2023-09-19_02-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:34 2023-09-19_02-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 02:34 2023-09-19_02-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:35 2023-09-19_02-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 02:35 2023-09-19_02-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:36 2023-09-19_02-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:36 2023-09-19_02-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:37 2023-09-19_02-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 02:37 2023-09-19_02-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:38 2023-09-19_02-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:38 2023-09-19_02-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:39 2023-09-19_02-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 02:39 2023-09-19_02-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:40 2023-09-19_02-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:40 2023-09-19_02-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:41 2023-09-19_02-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 02:41 2023-09-19_02-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:42 2023-09-19_02-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:42 2023-09-19_02-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:43 2023-09-19_02-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:43 2023-09-19_02-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:44 2023-09-19_02-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 02:44 2023-09-19_02-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:45 2023-09-19_02-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 02:45 2023-09-19_02-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:46 2023-09-19_02-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 02:46 2023-09-19_02-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:47 2023-09-19_02-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:47 2023-09-19_02-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:48 2023-09-19_02-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 02:48 2023-09-19_02-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:49 2023-09-19_02-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 02:49 2023-09-19_02-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:50 2023-09-19_02-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 02:50 2023-09-19_02-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:51 2023-09-19_02-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:51 2023-09-19_02-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:52 2023-09-19_02-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:52 2023-09-19_02-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:53 2023-09-19_02-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 02:53 2023-09-19_02-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:54 2023-09-19_02-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 02:54 2023-09-19_02-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:55 2023-09-19_02-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 02:55 2023-09-19_02-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:56 2023-09-19_02-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 02:56 2023-09-19_02-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:57 2023-09-19_02-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 02:57 2023-09-19_02-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:58 2023-09-19_02-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 02:58 2023-09-19_02-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 02:59 2023-09-19_02-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 02:59 2023-09-19_02-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:00 2023-09-19_03-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  486 Sep 19 03:00 2023-09-19_03-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:01 2023-09-19_03-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:01 2023-09-19_03-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:02 2023-09-19_03-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 03:02 2023-09-19_03-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:03 2023-09-19_03-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 03:03 2023-09-19_03-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:04 2023-09-19_03-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 03:04 2023-09-19_03-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:05 2023-09-19_03-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 03:05 2023-09-19_03-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:06 2023-09-19_03-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:06 2023-09-19_03-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:07 2023-09-19_03-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 03:07 2023-09-19_03-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:08 2023-09-19_03-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 03:08 2023-09-19_03-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:09 2023-09-19_03-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:09 2023-09-19_03-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:10 2023-09-19_03-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 03:10 2023-09-19_03-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:11 2023-09-19_03-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 03:11 2023-09-19_03-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:12 2023-09-19_03-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:12 2023-09-19_03-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:13 2023-09-19_03-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 03:13 2023-09-19_03-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:14 2023-09-19_03-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 03:14 2023-09-19_03-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:15 2023-09-19_03-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 03:15 2023-09-19_03-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:16 2023-09-19_03-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 03:16 2023-09-19_03-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:17 2023-09-19_03-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 03:17 2023-09-19_03-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:18 2023-09-19_03-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 03:18 2023-09-19_03-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:19 2023-09-19_03-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 03:19 2023-09-19_03-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:20 2023-09-19_03-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:20 2023-09-19_03-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:21 2023-09-19_03-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:21 2023-09-19_03-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:22 2023-09-19_03-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 03:22 2023-09-19_03-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:23 2023-09-19_03-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:23 2023-09-19_03-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:24 2023-09-19_03-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:24 2023-09-19_03-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:25 2023-09-19_03-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:25 2023-09-19_03-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:26 2023-09-19_03-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:26 2023-09-19_03-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:27 2023-09-19_03-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 03:27 2023-09-19_03-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:28 2023-09-19_03-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 03:28 2023-09-19_03-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:29 2023-09-19_03-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:29 2023-09-19_03-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:30 2023-09-19_03-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:30 2023-09-19_03-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:31 2023-09-19_03-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 03:31 2023-09-19_03-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:32 2023-09-19_03-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 03:32 2023-09-19_03-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:33 2023-09-19_03-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 03:33 2023-09-19_03-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:34 2023-09-19_03-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:34 2023-09-19_03-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:35 2023-09-19_03-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 03:35 2023-09-19_03-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:36 2023-09-19_03-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 03:36 2023-09-19_03-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:37 2023-09-19_03-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:37 2023-09-19_03-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:38 2023-09-19_03-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 03:38 2023-09-19_03-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:39 2023-09-19_03-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 03:39 2023-09-19_03-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:40 2023-09-19_03-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 03:40 2023-09-19_03-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:41 2023-09-19_03-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 03:41 2023-09-19_03-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:42 2023-09-19_03-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 03:42 2023-09-19_03-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:43 2023-09-19_03-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:43 2023-09-19_03-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:44 2023-09-19_03-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 03:44 2023-09-19_03-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:45 2023-09-19_03-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 03:45 2023-09-19_03-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:46 2023-09-19_03-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 03:46 2023-09-19_03-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:47 2023-09-19_03-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 03:47 2023-09-19_03-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:48 2023-09-19_03-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:48 2023-09-19_03-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:49 2023-09-19_03-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 03:49 2023-09-19_03-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:50 2023-09-19_03-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 03:50 2023-09-19_03-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:51 2023-09-19_03-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 03:51 2023-09-19_03-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:52 2023-09-19_03-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:52 2023-09-19_03-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:53 2023-09-19_03-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 03:53 2023-09-19_03-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:54 2023-09-19_03-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 03:54 2023-09-19_03-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:55 2023-09-19_03-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 03:55 2023-09-19_03-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:56 2023-09-19_03-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 03:56 2023-09-19_03-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:57 2023-09-19_03-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 03:57 2023-09-19_03-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:58 2023-09-19_03-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 03:58 2023-09-19_03-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 03:59 2023-09-19_03-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 03:59 2023-09-19_03-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:00 2023-09-19_04-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 04:00 2023-09-19_04-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:01 2023-09-19_04-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:01 2023-09-19_04-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:02 2023-09-19_04-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 04:02 2023-09-19_04-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:03 2023-09-19_04-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 04:03 2023-09-19_04-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:04 2023-09-19_04-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 04:04 2023-09-19_04-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:05 2023-09-19_04-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 04:05 2023-09-19_04-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:06 2023-09-19_04-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:06 2023-09-19_04-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:07 2023-09-19_04-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 04:07 2023-09-19_04-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:08 2023-09-19_04-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:08 2023-09-19_04-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:09 2023-09-19_04-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:09 2023-09-19_04-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:10 2023-09-19_04-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 04:10 2023-09-19_04-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:11 2023-09-19_04-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:11 2023-09-19_04-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:12 2023-09-19_04-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:12 2023-09-19_04-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:13 2023-09-19_04-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 04:13 2023-09-19_04-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:14 2023-09-19_04-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:14 2023-09-19_04-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:15 2023-09-19_04-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 04:15 2023-09-19_04-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:16 2023-09-19_04-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:16 2023-09-19_04-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:17 2023-09-19_04-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 04:17 2023-09-19_04-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:18 2023-09-19_04-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:18 2023-09-19_04-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:19 2023-09-19_04-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 04:19 2023-09-19_04-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:20 2023-09-19_04-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 04:20 2023-09-19_04-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:21 2023-09-19_04-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:21 2023-09-19_04-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:22 2023-09-19_04-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 04:22 2023-09-19_04-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:23 2023-09-19_04-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 04:23 2023-09-19_04-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:24 2023-09-19_04-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:24 2023-09-19_04-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:25 2023-09-19_04-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 04:25 2023-09-19_04-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:26 2023-09-19_04-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 04:26 2023-09-19_04-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:27 2023-09-19_04-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:27 2023-09-19_04-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:28 2023-09-19_04-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 04:28 2023-09-19_04-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:29 2023-09-19_04-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 04:29 2023-09-19_04-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:30 2023-09-19_04-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 04:30 2023-09-19_04-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:31 2023-09-19_04-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:31 2023-09-19_04-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:32 2023-09-19_04-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:32 2023-09-19_04-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:33 2023-09-19_04-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 04:33 2023-09-19_04-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:34 2023-09-19_04-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 04:34 2023-09-19_04-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:35 2023-09-19_04-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:35 2023-09-19_04-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:36 2023-09-19_04-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 04:36 2023-09-19_04-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:37 2023-09-19_04-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 04:37 2023-09-19_04-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:38 2023-09-19_04-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:38 2023-09-19_04-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:39 2023-09-19_04-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 04:39 2023-09-19_04-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:40 2023-09-19_04-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 04:40 2023-09-19_04-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:41 2023-09-19_04-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 04:41 2023-09-19_04-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:42 2023-09-19_04-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 04:42 2023-09-19_04-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:43 2023-09-19_04-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 04:43 2023-09-19_04-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:44 2023-09-19_04-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 04:44 2023-09-19_04-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:45 2023-09-19_04-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 04:45 2023-09-19_04-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:46 2023-09-19_04-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 04:46 2023-09-19_04-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:47 2023-09-19_04-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 04:47 2023-09-19_04-47_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:48 2023-09-19_04-48_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 04:48 2023-09-19_04-48_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:49 2023-09-19_04-49_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 04:49 2023-09-19_04-49_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:50 2023-09-19_04-50_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 04:50 2023-09-19_04-50_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:51 2023-09-19_04-51_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 04:51 2023-09-19_04-51_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:52 2023-09-19_04-52_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 04:52 2023-09-19_04-52_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:53 2023-09-19_04-53_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 04:53 2023-09-19_04-53_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:54 2023-09-19_04-54_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 04:54 2023-09-19_04-54_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:55 2023-09-19_04-55_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 04:55 2023-09-19_04-55_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:56 2023-09-19_04-56_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 04:56 2023-09-19_04-56_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:57 2023-09-19_04-57_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 04:57 2023-09-19_04-57_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:58 2023-09-19_04-58_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 04:58 2023-09-19_04-58_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 04:59 2023-09-19_04-59_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 04:59 2023-09-19_04-59_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:00 2023-09-19_05-00_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:00 2023-09-19_05-00_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:01 2023-09-19_05-01_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:01 2023-09-19_05-01_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:02 2023-09-19_05-02_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 05:02 2023-09-19_05-02_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:03 2023-09-19_05-03_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:03 2023-09-19_05-03_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:04 2023-09-19_05-04_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 05:04 2023-09-19_05-04_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:05 2023-09-19_05-05_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:05 2023-09-19_05-05_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:06 2023-09-19_05-06_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:06 2023-09-19_05-06_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:07 2023-09-19_05-07_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 05:07 2023-09-19_05-07_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:08 2023-09-19_05-08_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:08 2023-09-19_05-08_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:09 2023-09-19_05-09_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:09 2023-09-19_05-09_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:10 2023-09-19_05-10_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:10 2023-09-19_05-10_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:11 2023-09-19_05-11_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:11 2023-09-19_05-11_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:12 2023-09-19_05-12_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:12 2023-09-19_05-12_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:13 2023-09-19_05-13_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:13 2023-09-19_05-13_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:14 2023-09-19_05-14_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:14 2023-09-19_05-14_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:15 2023-09-19_05-15_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 05:15 2023-09-19_05-15_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:16 2023-09-19_05-16_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:16 2023-09-19_05-16_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:17 2023-09-19_05-17_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:17 2023-09-19_05-17_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:18 2023-09-19_05-18_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:18 2023-09-19_05-18_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:19 2023-09-19_05-19_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 05:19 2023-09-19_05-19_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:20 2023-09-19_05-20_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 05:20 2023-09-19_05-20_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:21 2023-09-19_05-21_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:21 2023-09-19_05-21_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:22 2023-09-19_05-22_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 05:22 2023-09-19_05-22_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:23 2023-09-19_05-23_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:23 2023-09-19_05-23_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:24 2023-09-19_05-24_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:24 2023-09-19_05-24_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:25 2023-09-19_05-25_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:25 2023-09-19_05-25_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:26 2023-09-19_05-26_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:26 2023-09-19_05-26_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:27 2023-09-19_05-27_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:27 2023-09-19_05-27_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:28 2023-09-19_05-28_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:28 2023-09-19_05-28_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:29 2023-09-19_05-29_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 05:29 2023-09-19_05-29_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:30 2023-09-19_05-30_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:30 2023-09-19_05-30_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:31 2023-09-19_05-31_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 05:31 2023-09-19_05-31_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:32 2023-09-19_05-32_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 05:32 2023-09-19_05-32_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:33 2023-09-19_05-33_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 05:33 2023-09-19_05-33_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:34 2023-09-19_05-34_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:34 2023-09-19_05-34_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:35 2023-09-19_05-35_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:35 2023-09-19_05-35_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:36 2023-09-19_05-36_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:36 2023-09-19_05-36_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:37 2023-09-19_05-37_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 05:37 2023-09-19_05-37_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:38 2023-09-19_05-38_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 05:38 2023-09-19_05-38_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:39 2023-09-19_05-39_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:39 2023-09-19_05-39_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:40 2023-09-19_05-40_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 05:40 2023-09-19_05-40_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:41 2023-09-19_05-41_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 05:41 2023-09-19_05-41_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:42 2023-09-19_05-42_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 05:42 2023-09-19_05-42_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:43 2023-09-19_05-43_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 05:43 2023-09-19_05-43_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:44 2023-09-19_05-44_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:44 2023-09-19_05-44_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:45 2023-09-19_05-45_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 05:45 2023-09-19_05-45_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:46 2023-09-19_05-46_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 05:46 2023-09-19_05-46_states.json.gz
            -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:47 2023-09-19_05-47_objects.json.gz
            -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 05:47 2023-09-19_05-47_states.json.gz
            • E Esmax666
              @thomas-braun said in iobroker geht nicht nach stromausfall:
              ls -lAh /opt/iobroker/iobroker-data/backup-objects/
              Stomausfall war am 6 sept.
              ich kann nicht alles zeigen :
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:48 2023-09-19_05-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:48 2023-09-19_05-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:49 2023-09-19_05-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 05:49 2023-09-19_05-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:50 2023-09-19_05-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:50 2023-09-19_05-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:51 2023-09-19_05-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:51 2023-09-19_05-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:52 2023-09-19_05-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 05:52 2023-09-19_05-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:53 2023-09-19_05-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:53 2023-09-19_05-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:54 2023-09-19_05-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 05:54 2023-09-19_05-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:55 2023-09-19_05-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 05:55 2023-09-19_05-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:56 2023-09-19_05-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 05:56 2023-09-19_05-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:57 2023-09-19_05-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 05:57 2023-09-19_05-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:58 2023-09-19_05-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 05:58 2023-09-19_05-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 05:59 2023-09-19_05-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 05:59 2023-09-19_05-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:00 2023-09-19_06-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:00 2023-09-19_06-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:01 2023-09-19_06-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:01 2023-09-19_06-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:02 2023-09-19_06-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:02 2023-09-19_06-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:03 2023-09-19_06-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:03 2023-09-19_06-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:04 2023-09-19_06-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:04 2023-09-19_06-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:05 2023-09-19_06-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:05 2023-09-19_06-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:06 2023-09-19_06-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 06:06 2023-09-19_06-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:07 2023-09-19_06-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:07 2023-09-19_06-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:08 2023-09-19_06-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:08 2023-09-19_06-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:09 2023-09-19_06-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:09 2023-09-19_06-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:10 2023-09-19_06-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 06:10 2023-09-19_06-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:11 2023-09-19_06-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:11 2023-09-19_06-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:12 2023-09-19_06-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 06:12 2023-09-19_06-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:13 2023-09-19_06-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:13 2023-09-19_06-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:14 2023-09-19_06-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:14 2023-09-19_06-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:15 2023-09-19_06-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:15 2023-09-19_06-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:16 2023-09-19_06-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 06:16 2023-09-19_06-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:17 2023-09-19_06-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:17 2023-09-19_06-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:18 2023-09-19_06-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:18 2023-09-19_06-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:19 2023-09-19_06-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 06:19 2023-09-19_06-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:20 2023-09-19_06-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:20 2023-09-19_06-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:21 2023-09-19_06-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:21 2023-09-19_06-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:22 2023-09-19_06-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:22 2023-09-19_06-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:23 2023-09-19_06-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:23 2023-09-19_06-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:24 2023-09-19_06-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:24 2023-09-19_06-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:25 2023-09-19_06-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:25 2023-09-19_06-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:26 2023-09-19_06-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 06:26 2023-09-19_06-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:27 2023-09-19_06-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 06:27 2023-09-19_06-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:28 2023-09-19_06-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 06:28 2023-09-19_06-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:29 2023-09-19_06-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:29 2023-09-19_06-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:30 2023-09-19_06-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:30 2023-09-19_06-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:31 2023-09-19_06-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:31 2023-09-19_06-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:32 2023-09-19_06-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:32 2023-09-19_06-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:33 2023-09-19_06-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:33 2023-09-19_06-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:34 2023-09-19_06-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 06:34 2023-09-19_06-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:35 2023-09-19_06-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:35 2023-09-19_06-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:36 2023-09-19_06-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:36 2023-09-19_06-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:37 2023-09-19_06-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:37 2023-09-19_06-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:38 2023-09-19_06-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 06:38 2023-09-19_06-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:39 2023-09-19_06-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:39 2023-09-19_06-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:40 2023-09-19_06-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:40 2023-09-19_06-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:41 2023-09-19_06-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:41 2023-09-19_06-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:42 2023-09-19_06-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 06:42 2023-09-19_06-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:43 2023-09-19_06-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:43 2023-09-19_06-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:44 2023-09-19_06-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 06:44 2023-09-19_06-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:45 2023-09-19_06-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 06:45 2023-09-19_06-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:46 2023-09-19_06-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:46 2023-09-19_06-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:47 2023-09-19_06-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 06:47 2023-09-19_06-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:48 2023-09-19_06-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 06:48 2023-09-19_06-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:49 2023-09-19_06-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 06:49 2023-09-19_06-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:50 2023-09-19_06-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 06:50 2023-09-19_06-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:51 2023-09-19_06-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 06:51 2023-09-19_06-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:52 2023-09-19_06-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 06:52 2023-09-19_06-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:53 2023-09-19_06-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:53 2023-09-19_06-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:54 2023-09-19_06-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:54 2023-09-19_06-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:55 2023-09-19_06-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:55 2023-09-19_06-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:56 2023-09-19_06-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 06:56 2023-09-19_06-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:57 2023-09-19_06-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 06:57 2023-09-19_06-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:58 2023-09-19_06-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 06:58 2023-09-19_06-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 06:59 2023-09-19_06-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 06:59 2023-09-19_06-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:00 2023-09-19_07-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:00 2023-09-19_07-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:01 2023-09-19_07-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:01 2023-09-19_07-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:02 2023-09-19_07-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:02 2023-09-19_07-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:03 2023-09-19_07-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:03 2023-09-19_07-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:04 2023-09-19_07-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 07:04 2023-09-19_07-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:05 2023-09-19_07-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:05 2023-09-19_07-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:06 2023-09-19_07-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:06 2023-09-19_07-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:07 2023-09-19_07-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:07 2023-09-19_07-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:08 2023-09-19_07-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:08 2023-09-19_07-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:09 2023-09-19_07-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:09 2023-09-19_07-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:10 2023-09-19_07-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:10 2023-09-19_07-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:11 2023-09-19_07-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:11 2023-09-19_07-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:12 2023-09-19_07-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:12 2023-09-19_07-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:13 2023-09-19_07-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:13 2023-09-19_07-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:14 2023-09-19_07-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:14 2023-09-19_07-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:15 2023-09-19_07-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:15 2023-09-19_07-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:16 2023-09-19_07-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 07:16 2023-09-19_07-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:17 2023-09-19_07-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:17 2023-09-19_07-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:18 2023-09-19_07-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:18 2023-09-19_07-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:19 2023-09-19_07-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 07:19 2023-09-19_07-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:20 2023-09-19_07-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 07:20 2023-09-19_07-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:21 2023-09-19_07-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 07:21 2023-09-19_07-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:22 2023-09-19_07-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:22 2023-09-19_07-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:23 2023-09-19_07-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:23 2023-09-19_07-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:24 2023-09-19_07-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:24 2023-09-19_07-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:25 2023-09-19_07-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:25 2023-09-19_07-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:26 2023-09-19_07-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:26 2023-09-19_07-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:27 2023-09-19_07-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 07:27 2023-09-19_07-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:28 2023-09-19_07-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:28 2023-09-19_07-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:29 2023-09-19_07-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 07:29 2023-09-19_07-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:30 2023-09-19_07-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 07:30 2023-09-19_07-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:31 2023-09-19_07-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 07:31 2023-09-19_07-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:32 2023-09-19_07-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:32 2023-09-19_07-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:33 2023-09-19_07-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:33 2023-09-19_07-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:34 2023-09-19_07-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 07:34 2023-09-19_07-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:35 2023-09-19_07-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:35 2023-09-19_07-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:36 2023-09-19_07-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:36 2023-09-19_07-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:37 2023-09-19_07-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:37 2023-09-19_07-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:38 2023-09-19_07-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:38 2023-09-19_07-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:39 2023-09-19_07-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:39 2023-09-19_07-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:40 2023-09-19_07-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 07:40 2023-09-19_07-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:41 2023-09-19_07-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 07:41 2023-09-19_07-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:42 2023-09-19_07-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 07:42 2023-09-19_07-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:43 2023-09-19_07-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 07:43 2023-09-19_07-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:44 2023-09-19_07-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 07:44 2023-09-19_07-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:45 2023-09-19_07-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 07:45 2023-09-19_07-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:46 2023-09-19_07-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:46 2023-09-19_07-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:47 2023-09-19_07-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:47 2023-09-19_07-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:48 2023-09-19_07-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 07:48 2023-09-19_07-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:49 2023-09-19_07-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 07:49 2023-09-19_07-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:50 2023-09-19_07-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:50 2023-09-19_07-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:51 2023-09-19_07-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 07:51 2023-09-19_07-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:52 2023-09-19_07-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 07:52 2023-09-19_07-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:53 2023-09-19_07-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:53 2023-09-19_07-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:54 2023-09-19_07-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:54 2023-09-19_07-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:55 2023-09-19_07-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 07:55 2023-09-19_07-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:56 2023-09-19_07-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 07:56 2023-09-19_07-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:57 2023-09-19_07-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:57 2023-09-19_07-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:58 2023-09-19_07-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 07:58 2023-09-19_07-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 07:59 2023-09-19_07-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 07:59 2023-09-19_07-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:00 2023-09-19_08-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 08:00 2023-09-19_08-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:01 2023-09-19_08-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:01 2023-09-19_08-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:02 2023-09-19_08-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 08:02 2023-09-19_08-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:03 2023-09-19_08-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:03 2023-09-19_08-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:04 2023-09-19_08-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 08:04 2023-09-19_08-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:05 2023-09-19_08-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:05 2023-09-19_08-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:06 2023-09-19_08-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:06 2023-09-19_08-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:07 2023-09-19_08-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 08:07 2023-09-19_08-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:08 2023-09-19_08-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:08 2023-09-19_08-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:09 2023-09-19_08-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:09 2023-09-19_08-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:10 2023-09-19_08-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:10 2023-09-19_08-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:11 2023-09-19_08-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:11 2023-09-19_08-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:12 2023-09-19_08-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:12 2023-09-19_08-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:13 2023-09-19_08-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  475 Sep 19 08:13 2023-09-19_08-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:14 2023-09-19_08-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:14 2023-09-19_08-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:15 2023-09-19_08-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:15 2023-09-19_08-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:16 2023-09-19_08-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 08:16 2023-09-19_08-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:17 2023-09-19_08-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:17 2023-09-19_08-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:18 2023-09-19_08-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 08:18 2023-09-19_08-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:19 2023-09-19_08-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:19 2023-09-19_08-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:20 2023-09-19_08-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 08:20 2023-09-19_08-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:21 2023-09-19_08-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 08:21 2023-09-19_08-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:22 2023-09-19_08-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:22 2023-09-19_08-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:23 2023-09-19_08-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:23 2023-09-19_08-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:24 2023-09-19_08-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:24 2023-09-19_08-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:25 2023-09-19_08-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:25 2023-09-19_08-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:26 2023-09-19_08-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:26 2023-09-19_08-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:27 2023-09-19_08-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 08:27 2023-09-19_08-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:28 2023-09-19_08-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:28 2023-09-19_08-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:29 2023-09-19_08-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:29 2023-09-19_08-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:30 2023-09-19_08-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:30 2023-09-19_08-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:31 2023-09-19_08-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:31 2023-09-19_08-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:32 2023-09-19_08-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 08:32 2023-09-19_08-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:33 2023-09-19_08-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:33 2023-09-19_08-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:34 2023-09-19_08-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:34 2023-09-19_08-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:35 2023-09-19_08-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:35 2023-09-19_08-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:36 2023-09-19_08-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:36 2023-09-19_08-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:37 2023-09-19_08-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:37 2023-09-19_08-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:38 2023-09-19_08-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:38 2023-09-19_08-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:39 2023-09-19_08-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:39 2023-09-19_08-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:40 2023-09-19_08-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:40 2023-09-19_08-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:41 2023-09-19_08-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:41 2023-09-19_08-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:42 2023-09-19_08-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 08:42 2023-09-19_08-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:43 2023-09-19_08-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:43 2023-09-19_08-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:44 2023-09-19_08-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 08:44 2023-09-19_08-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:45 2023-09-19_08-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 08:45 2023-09-19_08-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:46 2023-09-19_08-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 08:46 2023-09-19_08-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:47 2023-09-19_08-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:47 2023-09-19_08-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:48 2023-09-19_08-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 08:48 2023-09-19_08-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:49 2023-09-19_08-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:49 2023-09-19_08-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:50 2023-09-19_08-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 08:50 2023-09-19_08-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:51 2023-09-19_08-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 08:51 2023-09-19_08-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:52 2023-09-19_08-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 08:52 2023-09-19_08-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:53 2023-09-19_08-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 08:53 2023-09-19_08-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:54 2023-09-19_08-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 08:54 2023-09-19_08-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:55 2023-09-19_08-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 08:55 2023-09-19_08-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:56 2023-09-19_08-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  457 Sep 19 08:56 2023-09-19_08-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:57 2023-09-19_08-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 08:57 2023-09-19_08-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:58 2023-09-19_08-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 08:58 2023-09-19_08-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 08:59 2023-09-19_08-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 08:59 2023-09-19_08-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:00 2023-09-19_09-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:00 2023-09-19_09-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:01 2023-09-19_09-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 09:01 2023-09-19_09-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:02 2023-09-19_09-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:02 2023-09-19_09-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:03 2023-09-19_09-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:03 2023-09-19_09-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:04 2023-09-19_09-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:04 2023-09-19_09-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:05 2023-09-19_09-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:05 2023-09-19_09-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:06 2023-09-19_09-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:06 2023-09-19_09-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:07 2023-09-19_09-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:07 2023-09-19_09-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:08 2023-09-19_09-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  484 Sep 19 09:08 2023-09-19_09-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:09 2023-09-19_09-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:09 2023-09-19_09-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:10 2023-09-19_09-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:10 2023-09-19_09-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:11 2023-09-19_09-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:11 2023-09-19_09-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:12 2023-09-19_09-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:12 2023-09-19_09-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:13 2023-09-19_09-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 09:13 2023-09-19_09-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:14 2023-09-19_09-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:14 2023-09-19_09-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:15 2023-09-19_09-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:15 2023-09-19_09-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:16 2023-09-19_09-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:16 2023-09-19_09-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:17 2023-09-19_09-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 09:17 2023-09-19_09-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:18 2023-09-19_09-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 09:18 2023-09-19_09-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:19 2023-09-19_09-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:19 2023-09-19_09-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:20 2023-09-19_09-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  487 Sep 19 09:20 2023-09-19_09-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:21 2023-09-19_09-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:21 2023-09-19_09-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:22 2023-09-19_09-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 09:22 2023-09-19_09-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:23 2023-09-19_09-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:23 2023-09-19_09-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:24 2023-09-19_09-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 09:24 2023-09-19_09-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:25 2023-09-19_09-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:25 2023-09-19_09-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:26 2023-09-19_09-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:26 2023-09-19_09-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:27 2023-09-19_09-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:27 2023-09-19_09-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:28 2023-09-19_09-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  462 Sep 19 09:28 2023-09-19_09-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:29 2023-09-19_09-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:29 2023-09-19_09-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:30 2023-09-19_09-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:30 2023-09-19_09-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:31 2023-09-19_09-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:31 2023-09-19_09-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:32 2023-09-19_09-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 09:32 2023-09-19_09-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:33 2023-09-19_09-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:33 2023-09-19_09-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:34 2023-09-19_09-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 09:34 2023-09-19_09-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:35 2023-09-19_09-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:35 2023-09-19_09-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:36 2023-09-19_09-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:36 2023-09-19_09-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:37 2023-09-19_09-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:37 2023-09-19_09-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:38 2023-09-19_09-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 09:38 2023-09-19_09-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:39 2023-09-19_09-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  481 Sep 19 09:39 2023-09-19_09-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:40 2023-09-19_09-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 09:40 2023-09-19_09-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:41 2023-09-19_09-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:41 2023-09-19_09-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:42 2023-09-19_09-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 09:42 2023-09-19_09-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:43 2023-09-19_09-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 09:43 2023-09-19_09-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:44 2023-09-19_09-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 09:44 2023-09-19_09-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:45 2023-09-19_09-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:45 2023-09-19_09-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:46 2023-09-19_09-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 09:46 2023-09-19_09-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:47 2023-09-19_09-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 09:47 2023-09-19_09-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:48 2023-09-19_09-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:48 2023-09-19_09-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:49 2023-09-19_09-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 09:49 2023-09-19_09-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:50 2023-09-19_09-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 09:50 2023-09-19_09-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:51 2023-09-19_09-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 09:51 2023-09-19_09-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:52 2023-09-19_09-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 09:52 2023-09-19_09-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:53 2023-09-19_09-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:53 2023-09-19_09-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:54 2023-09-19_09-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:54 2023-09-19_09-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:55 2023-09-19_09-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 09:55 2023-09-19_09-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:56 2023-09-19_09-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 09:56 2023-09-19_09-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:57 2023-09-19_09-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  479 Sep 19 09:57 2023-09-19_09-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:58 2023-09-19_09-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 09:58 2023-09-19_09-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 09:59 2023-09-19_09-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 09:59 2023-09-19_09-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:00 2023-09-19_10-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:00 2023-09-19_10-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:01 2023-09-19_10-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:01 2023-09-19_10-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:02 2023-09-19_10-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  463 Sep 19 10:02 2023-09-19_10-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:03 2023-09-19_10-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:03 2023-09-19_10-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:04 2023-09-19_10-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:04 2023-09-19_10-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:05 2023-09-19_10-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:05 2023-09-19_10-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:06 2023-09-19_10-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:06 2023-09-19_10-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:07 2023-09-19_10-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:07 2023-09-19_10-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:08 2023-09-19_10-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:08 2023-09-19_10-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:09 2023-09-19_10-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:09 2023-09-19_10-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:10 2023-09-19_10-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:10 2023-09-19_10-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:11 2023-09-19_10-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:11 2023-09-19_10-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:12 2023-09-19_10-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:12 2023-09-19_10-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:13 2023-09-19_10-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 10:13 2023-09-19_10-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:14 2023-09-19_10-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  483 Sep 19 10:14 2023-09-19_10-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:15 2023-09-19_10-15_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:15 2023-09-19_10-15_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:16 2023-09-19_10-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  480 Sep 19 10:16 2023-09-19_10-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:17 2023-09-19_10-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:17 2023-09-19_10-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:18 2023-09-19_10-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:18 2023-09-19_10-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:19 2023-09-19_10-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:19 2023-09-19_10-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:20 2023-09-19_10-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:20 2023-09-19_10-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:21 2023-09-19_10-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:21 2023-09-19_10-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:22 2023-09-19_10-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:22 2023-09-19_10-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:23 2023-09-19_10-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:23 2023-09-19_10-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:24 2023-09-19_10-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:24 2023-09-19_10-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:25 2023-09-19_10-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:25 2023-09-19_10-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:26 2023-09-19_10-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:26 2023-09-19_10-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:27 2023-09-19_10-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  478 Sep 19 10:27 2023-09-19_10-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:28 2023-09-19_10-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 10:28 2023-09-19_10-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:29 2023-09-19_10-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:29 2023-09-19_10-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:30 2023-09-19_10-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 10:30 2023-09-19_10-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:31 2023-09-19_10-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:31 2023-09-19_10-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:32 2023-09-19_10-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:32 2023-09-19_10-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:33 2023-09-19_10-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:33 2023-09-19_10-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:34 2023-09-19_10-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:34 2023-09-19_10-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:35 2023-09-19_10-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  477 Sep 19 10:35 2023-09-19_10-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:36 2023-09-19_10-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:36 2023-09-19_10-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:37 2023-09-19_10-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  482 Sep 19 10:37 2023-09-19_10-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:38 2023-09-19_10-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  476 Sep 19 10:38 2023-09-19_10-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:39 2023-09-19_10-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:39 2023-09-19_10-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:40 2023-09-19_10-40_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  471 Sep 19 10:40 2023-09-19_10-40_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:41 2023-09-19_10-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:41 2023-09-19_10-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:42 2023-09-19_10-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 10:42 2023-09-19_10-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:43 2023-09-19_10-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  472 Sep 19 10:43 2023-09-19_10-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:44 2023-09-19_10-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  466 Sep 19 10:44 2023-09-19_10-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:45 2023-09-19_10-45_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 10:45 2023-09-19_10-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:46 2023-09-19_10-46_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:46 2023-09-19_10-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:47 2023-09-19_10-47_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:47 2023-09-19_10-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:48 2023-09-19_10-48_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:48 2023-09-19_10-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:49 2023-09-19_10-49_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:49 2023-09-19_10-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:50 2023-09-19_10-50_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  473 Sep 19 10:50 2023-09-19_10-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:51 2023-09-19_10-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  469 Sep 19 10:51 2023-09-19_10-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:52 2023-09-19_10-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:52 2023-09-19_10-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:53 2023-09-19_10-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  474 Sep 19 10:53 2023-09-19_10-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:54 2023-09-19_10-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  468 Sep 19 10:54 2023-09-19_10-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:55 2023-09-19_10-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  470 Sep 19 10:55 2023-09-19_10-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:56 2023-09-19_10-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  465 Sep 19 10:56 2023-09-19_10-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:57 2023-09-19_10-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  464 Sep 19 10:57 2023-09-19_10-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 10:58 2023-09-19_10-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  467 Sep 19 10:58 2023-09-19_10-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:51 2023-09-19_11-51_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 11:51 2023-09-19_11-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:52 2023-09-19_11-52_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:52 2023-09-19_11-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:53 2023-09-19_11-53_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 11:53 2023-09-19_11-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:54 2023-09-19_11-54_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  461 Sep 19 11:54 2023-09-19_11-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:55 2023-09-19_11-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 11:55 2023-09-19_11-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:56 2023-09-19_11-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  440 Sep 19 11:56 2023-09-19_11-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:57 2023-09-19_11-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 11:57 2023-09-19_11-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:58 2023-09-19_11-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 11:58 2023-09-19_11-58_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 11:59 2023-09-19_11-59_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  460 Sep 19 11:59 2023-09-19_11-59_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:00 2023-09-19_12-00_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:00 2023-09-19_12-00_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:01 2023-09-19_12-01_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:01 2023-09-19_12-01_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:02 2023-09-19_12-02_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:02 2023-09-19_12-02_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:03 2023-09-19_12-03_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:03 2023-09-19_12-03_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:04 2023-09-19_12-04_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:04 2023-09-19_12-04_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:05 2023-09-19_12-05_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:05 2023-09-19_12-05_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:06 2023-09-19_12-06_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  433 Sep 19 12:06 2023-09-19_12-06_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:07 2023-09-19_12-07_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:07 2023-09-19_12-07_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:08 2023-09-19_12-08_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  454 Sep 19 12:08 2023-09-19_12-08_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:09 2023-09-19_12-09_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:09 2023-09-19_12-09_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:10 2023-09-19_12-10_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  446 Sep 19 12:10 2023-09-19_12-10_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:11 2023-09-19_12-11_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:11 2023-09-19_12-11_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:12 2023-09-19_12-12_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:12 2023-09-19_12-12_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:13 2023-09-19_12-13_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  459 Sep 19 12:13 2023-09-19_12-13_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:14 2023-09-19_12-14_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:14 2023-09-19_12-14_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:16 2023-09-19_12-16_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  441 Sep 19 12:16 2023-09-19_12-16_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:17 2023-09-19_12-17_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:17 2023-09-19_12-17_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:18 2023-09-19_12-18_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:18 2023-09-19_12-18_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:19 2023-09-19_12-19_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:19 2023-09-19_12-19_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:20 2023-09-19_12-20_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:20 2023-09-19_12-20_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:21 2023-09-19_12-21_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:21 2023-09-19_12-21_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:22 2023-09-19_12-22_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:22 2023-09-19_12-22_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:23 2023-09-19_12-23_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:23 2023-09-19_12-23_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:24 2023-09-19_12-24_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  455 Sep 19 12:24 2023-09-19_12-24_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:25 2023-09-19_12-25_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:25 2023-09-19_12-25_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:26 2023-09-19_12-26_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:26 2023-09-19_12-26_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:27 2023-09-19_12-27_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  447 Sep 19 12:27 2023-09-19_12-27_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:28 2023-09-19_12-28_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:28 2023-09-19_12-28_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:29 2023-09-19_12-29_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:29 2023-09-19_12-29_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:30 2023-09-19_12-30_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:30 2023-09-19_12-30_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:31 2023-09-19_12-31_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  452 Sep 19 12:31 2023-09-19_12-31_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:32 2023-09-19_12-32_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  445 Sep 19 12:32 2023-09-19_12-32_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:33 2023-09-19_12-33_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  442 Sep 19 12:33 2023-09-19_12-33_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:34 2023-09-19_12-34_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  458 Sep 19 12:34 2023-09-19_12-34_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:35 2023-09-19_12-35_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:35 2023-09-19_12-35_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:36 2023-09-19_12-36_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  443 Sep 19 12:36 2023-09-19_12-36_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:37 2023-09-19_12-37_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:37 2023-09-19_12-37_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:38 2023-09-19_12-38_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  448 Sep 19 12:38 2023-09-19_12-38_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:39 2023-09-19_12-39_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  451 Sep 19 12:39 2023-09-19_12-39_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:41 2023-09-19_12-41_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  436 Sep 19 12:41 2023-09-19_12-41_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:42 2023-09-19_12-42_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  450 Sep 19 12:42 2023-09-19_12-42_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:43 2023-09-19_12-43_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:43 2023-09-19_12-43_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:44 2023-09-19_12-44_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:44 2023-09-19_12-44_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:45 2023-09-19_12-45_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:46 2023-09-19_12-46_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:47 2023-09-19_12-47_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:48 2023-09-19_12-48_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:49 2023-09-19_12-49_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:50 2023-09-19_12-50_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:51 2023-09-19_12-51_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:52 2023-09-19_12-52_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:53 2023-09-19_12-53_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:54 2023-09-19_12-54_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:55 2023-09-19_12-55_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  444 Sep 19 12:55 2023-09-19_12-55_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:56 2023-09-19_12-56_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  453 Sep 19 12:56 2023-09-19_12-56_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:57 2023-09-19_12-57_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  449 Sep 19 12:57 2023-09-19_12-57_states.json.gz
              -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 19 12:58 2023-09-19_12-58_objects.json.gz
              -rw-rwxr--+ 1 iobroker iobroker  456 Sep 19 12:58 2023-09-19_12-58_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 12:59 2023-09-19_12-59_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 12:59 2023-09-19_12-59_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:00 2023-09-19_13-00_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 13:00 2023-09-19_13-00_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:01 2023-09-19_13-01_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:01 2023-09-19_13-01_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:02 2023-09-19_13-02_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:02 2023-09-19_13-02_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:03 2023-09-19_13-03_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:03 2023-09-19_13-03_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:04 2023-09-19_13-04_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:04 2023-09-19_13-04_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:05 2023-09-19_13-05_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:05 2023-09-19_13-05_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:06 2023-09-19_13-06_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:06 2023-09-19_13-06_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:07 2023-09-19_13-07_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:07 2023-09-19_13-07_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:08 2023-09-19_13-08_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:08 2023-09-19_13-08_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:09 2023-09-19_13-09_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:09 2023-09-19_13-09_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:10 2023-09-19_13-10_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:10 2023-09-19_13-10_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:11 2023-09-19_13-11_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:11 2023-09-19_13-11_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:12 2023-09-19_13-12_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:12 2023-09-19_13-12_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:13 2023-09-19_13-13_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:13 2023-09-19_13-13_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:14 2023-09-19_13-14_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:14 2023-09-19_13-14_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:15 2023-09-19_13-15_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 13:15 2023-09-19_13-15_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:16 2023-09-19_13-16_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 13:16 2023-09-19_13-16_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:17 2023-09-19_13-17_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:17 2023-09-19_13-17_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:18 2023-09-19_13-18_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:18 2023-09-19_13-18_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:19 2023-09-19_13-19_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  433 Sep 19 13:19 2023-09-19_13-19_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Sep 19 13:20 2023-09-19_13-20_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:20 2023-09-19_13-20_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 2.4K Sep 19 13:21 2023-09-19_13-21_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:21 2023-09-19_13-21_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 2.9K Sep 19 13:22 2023-09-19_13-22_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:22 2023-09-19_13-22_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 3.7K Sep 19 13:23 2023-09-19_13-23_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 13:23 2023-09-19_13-23_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.3K Sep 19 13:24 2023-09-19_13-24_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:24 2023-09-19_13-24_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.4K Sep 19 13:25 2023-09-19_13-25_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 13:25 2023-09-19_13-25_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:26 2023-09-19_13-26_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:26 2023-09-19_13-26_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:27 2023-09-19_13-27_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:27 2023-09-19_13-27_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:28 2023-09-19_13-28_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 13:28 2023-09-19_13-28_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:29 2023-09-19_13-29_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 13:29 2023-09-19_13-29_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:30 2023-09-19_13-30_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:30 2023-09-19_13-30_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:31 2023-09-19_13-31_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:31 2023-09-19_13-31_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:32 2023-09-19_13-32_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  443 Sep 19 13:32 2023-09-19_13-32_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:33 2023-09-19_13-33_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 13:33 2023-09-19_13-33_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:34 2023-09-19_13-34_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 13:34 2023-09-19_13-34_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 4.5K Sep 19 13:35 2023-09-19_13-35_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:35 2023-09-19_13-35_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:36 2023-09-19_13-36_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  441 Sep 19 13:36 2023-09-19_13-36_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:37 2023-09-19_13-37_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:37 2023-09-19_13-37_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:38 2023-09-19_13-38_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  474 Sep 19 13:38 2023-09-19_13-38_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:39 2023-09-19_13-39_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 13:39 2023-09-19_13-39_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:40 2023-09-19_13-40_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 13:40 2023-09-19_13-40_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:41 2023-09-19_13-41_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:41 2023-09-19_13-41_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:42 2023-09-19_13-42_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 13:42 2023-09-19_13-42_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:43 2023-09-19_13-43_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  475 Sep 19 13:43 2023-09-19_13-43_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:44 2023-09-19_13-44_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:44 2023-09-19_13-44_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:45 2023-09-19_13-45_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 13:45 2023-09-19_13-45_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:46 2023-09-19_13-46_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:46 2023-09-19_13-46_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:47 2023-09-19_13-47_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:47 2023-09-19_13-47_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:48 2023-09-19_13-48_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:48 2023-09-19_13-48_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:49 2023-09-19_13-49_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:49 2023-09-19_13-49_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:50 2023-09-19_13-50_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  466 Sep 19 13:50 2023-09-19_13-50_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:51 2023-09-19_13-51_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:51 2023-09-19_13-51_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:52 2023-09-19_13-52_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 13:52 2023-09-19_13-52_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:53 2023-09-19_13-53_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 13:53 2023-09-19_13-53_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:54 2023-09-19_13-54_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 13:54 2023-09-19_13-54_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:55 2023-09-19_13-55_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  468 Sep 19 13:55 2023-09-19_13-55_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:56 2023-09-19_13-56_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 13:56 2023-09-19_13-56_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:57 2023-09-19_13-57_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 13:57 2023-09-19_13-57_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:58 2023-09-19_13-58_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 13:58 2023-09-19_13-58_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 13:59 2023-09-19_13-59_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 13:59 2023-09-19_13-59_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:00 2023-09-19_14-00_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:00 2023-09-19_14-00_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:01 2023-09-19_14-01_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:01 2023-09-19_14-01_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:02 2023-09-19_14-02_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:02 2023-09-19_14-02_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:03 2023-09-19_14-03_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:03 2023-09-19_14-03_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:04 2023-09-19_14-04_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:04 2023-09-19_14-04_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:05 2023-09-19_14-05_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:05 2023-09-19_14-05_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:06 2023-09-19_14-06_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:06 2023-09-19_14-06_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:07 2023-09-19_14-07_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:07 2023-09-19_14-07_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:08 2023-09-19_14-08_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:08 2023-09-19_14-08_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:09 2023-09-19_14-09_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:09 2023-09-19_14-09_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:10 2023-09-19_14-10_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:10 2023-09-19_14-10_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:11 2023-09-19_14-11_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:11 2023-09-19_14-11_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:12 2023-09-19_14-12_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:12 2023-09-19_14-12_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:13 2023-09-19_14-13_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  450 Sep 19 14:13 2023-09-19_14-13_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:14 2023-09-19_14-14_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:14 2023-09-19_14-14_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:15 2023-09-19_14-15_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:15 2023-09-19_14-15_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:16 2023-09-19_14-16_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:16 2023-09-19_14-16_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:17 2023-09-19_14-17_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 14:17 2023-09-19_14-17_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:18 2023-09-19_14-18_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:18 2023-09-19_14-18_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:19 2023-09-19_14-19_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 14:19 2023-09-19_14-19_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:20 2023-09-19_14-20_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:20 2023-09-19_14-20_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:21 2023-09-19_14-21_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 14:21 2023-09-19_14-21_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:22 2023-09-19_14-22_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:22 2023-09-19_14-22_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:23 2023-09-19_14-23_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 14:23 2023-09-19_14-23_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:24 2023-09-19_14-24_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  440 Sep 19 14:24 2023-09-19_14-24_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:25 2023-09-19_14-25_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:25 2023-09-19_14-25_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:26 2023-09-19_14-26_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:26 2023-09-19_14-26_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:27 2023-09-19_14-27_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:27 2023-09-19_14-27_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:28 2023-09-19_14-28_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  455 Sep 19 14:28 2023-09-19_14-28_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:29 2023-09-19_14-29_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:29 2023-09-19_14-29_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:30 2023-09-19_14-30_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  462 Sep 19 14:30 2023-09-19_14-30_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:31 2023-09-19_14-31_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:31 2023-09-19_14-31_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:32 2023-09-19_14-32_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:32 2023-09-19_14-32_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:33 2023-09-19_14-33_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  438 Sep 19 14:33 2023-09-19_14-33_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:34 2023-09-19_14-34_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:34 2023-09-19_14-34_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:35 2023-09-19_14-35_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:35 2023-09-19_14-35_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:36 2023-09-19_14-36_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:36 2023-09-19_14-36_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:37 2023-09-19_14-37_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:37 2023-09-19_14-37_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:38 2023-09-19_14-38_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:38 2023-09-19_14-38_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:39 2023-09-19_14-39_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:39 2023-09-19_14-39_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:40 2023-09-19_14-40_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  471 Sep 19 14:40 2023-09-19_14-40_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:41 2023-09-19_14-41_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:41 2023-09-19_14-41_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:42 2023-09-19_14-42_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 14:42 2023-09-19_14-42_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:43 2023-09-19_14-43_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 14:43 2023-09-19_14-43_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:44 2023-09-19_14-44_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:44 2023-09-19_14-44_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:45 2023-09-19_14-45_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 14:45 2023-09-19_14-45_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:46 2023-09-19_14-46_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:46 2023-09-19_14-46_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:47 2023-09-19_14-47_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  442 Sep 19 14:47 2023-09-19_14-47_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:48 2023-09-19_14-48_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  449 Sep 19 14:48 2023-09-19_14-48_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:49 2023-09-19_14-49_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  459 Sep 19 14:49 2023-09-19_14-49_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:50 2023-09-19_14-50_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 14:50 2023-09-19_14-50_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:51 2023-09-19_14-51_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:51 2023-09-19_14-51_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:52 2023-09-19_14-52_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 14:52 2023-09-19_14-52_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:53 2023-09-19_14-53_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  445 Sep 19 14:53 2023-09-19_14-53_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:54 2023-09-19_14-54_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 14:54 2023-09-19_14-54_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:55 2023-09-19_14-55_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:55 2023-09-19_14-55_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:56 2023-09-19_14-56_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  458 Sep 19 14:56 2023-09-19_14-56_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:57 2023-09-19_14-57_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 14:57 2023-09-19_14-57_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:58 2023-09-19_14-58_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 14:58 2023-09-19_14-58_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 14:59 2023-09-19_14-59_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 14:59 2023-09-19_14-59_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:00 2023-09-19_15-00_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  465 Sep 19 15:00 2023-09-19_15-00_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:01 2023-09-19_15-01_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  444 Sep 19 15:01 2023-09-19_15-01_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:02 2023-09-19_15-02_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:02 2023-09-19_15-02_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:03 2023-09-19_15-03_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:03 2023-09-19_15-03_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:04 2023-09-19_15-04_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  467 Sep 19 15:04 2023-09-19_15-04_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:05 2023-09-19_15-05_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:05 2023-09-19_15-05_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:06 2023-09-19_15-06_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:06 2023-09-19_15-06_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:07 2023-09-19_15-07_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:07 2023-09-19_15-07_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:08 2023-09-19_15-08_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  461 Sep 19 15:08 2023-09-19_15-08_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:09 2023-09-19_15-09_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  463 Sep 19 15:09 2023-09-19_15-09_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:10 2023-09-19_15-10_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  456 Sep 19 15:10 2023-09-19_15-10_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:11 2023-09-19_15-11_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  460 Sep 19 15:11 2023-09-19_15-11_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:12 2023-09-19_15-12_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  451 Sep 19 15:12 2023-09-19_15-12_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:13 2023-09-19_15-13_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:13 2023-09-19_15-13_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:14 2023-09-19_15-14_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:14 2023-09-19_15-14_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:15 2023-09-19_15-15_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  447 Sep 19 15:15 2023-09-19_15-15_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:16 2023-09-19_15-16_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:16 2023-09-19_15-16_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:17 2023-09-19_15-17_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:17 2023-09-19_15-17_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:18 2023-09-19_15-18_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  454 Sep 19 15:18 2023-09-19_15-18_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:19 2023-09-19_15-19_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  453 Sep 19 15:19 2023-09-19_15-19_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:20 2023-09-19_15-20_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  452 Sep 19 15:20 2023-09-19_15-20_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:21 2023-09-19_15-21_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  457 Sep 19 15:21 2023-09-19_15-21_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:22 2023-09-19_15-22_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:22 2023-09-19_15-22_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:23 2023-09-19_15-23_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  464 Sep 19 15:23 2023-09-19_15-23_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.2M Sep 19 15:24 2023-09-19_15-24_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker  448 Sep 19 15:24 2023-09-19_15-24_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 6.1K Sep 19 15:25 2023-09-19_15-25_states.json.gz
              ubuntu@ubuntu:/opt/iobroker$
              @esmax666 sagte in iobroker geht nicht nach stromausfall:
              ich kann nicht alles zeigen :
              Warum nicht?
              Scheinen aber keine Daten mehr von vor dem Crash vorhanden zu sein. Dann haste vermutlich Pech gehabt.
              Hast du wenigstens ein ordentliches Backup?
              E 1 Antwort Letzte Antwort
                Warum nicht?
                Esmax666
                putty consolle zeig mir nur das, vielleicht war da zu viel text, und er könnte nicht alles zeigen…
                • E Esmax666
                  Nein, im Terminal Buffer ist Platz 'ohne Ende'.
                    Esmax666
                    Also hier oben bin ich blokiert, mein verlauf / line command sind weg
                    • E Esmax666
                      @esmax666
                      Man kann mit der Maus z.B. nach oben scrollen. In gescheiten Terminalprogrammen jedenfalls. Bei puTTY weiß ich es nicht...
                        @esmax666
                        Esmax666
                        @thomas-braun said in iobroker geht nicht nach stromausfall:
                        genau und dann bin ich geblockt
                        weiss für ein Terminalprogram soll ich nehmen ?
                        Thomas BraunT OliverIOO 3 Antworten Letzte Antwort
                        • E Esmax666
                          @esmax666
                          Ich verwende die PowerShell.
                          • E Esmax666
                            @esmax666
                            Du kannst das auch in einen Pager wie 'less' rüberwerfen. Der kann definitiv große Ausgaben seitenweise anzeigen.
                            ls -lAh /opt/iobroker/iobroker-data/backup-objects/ | less
                              @esmax666
                              Esmax666
                              PowerShell
                              da bin ich auch limitiert
                              • E Esmax666
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                Configure the scrollback buffer
                                The scrollback buffer is the amount of text that PuTTY's SSH terminal keeps in memory and allows you to scroll back and review. By default, PuTTY sets the scrollback buffer to 200 lines, which may not be enough for some tasks or situations. To increase or decrease the scrollback buffer, open PuTTY and go to the Window category on the left pane. Then, enter the number of lines that you want in the Lines of scrollback box. You can also check the box that says Unlimited scrollback if you want PuTTY to keep all the text that you see on the terminal.
                                bevor noch mehr verwirrung auch von neuen tools entsteht in die man sich erst reinfuchsen muss
                                Meine Adapter und Widgets
                                Links im Profil
                                • OliverIOO OliverIO
                                  Ah.
                                  PowerShell hier:
                                    Ah.
                                    PowerShell hier:
                                    @thomas-braun sagte in iobroker geht nicht nach stromausfall:
                                    Ah.
                                    PowerShell hier:
                                    nee, 9001 ist der Port für iob
                                      @esmax666
                                      Esmax666
                                      Mit less fängt das an mit
                                      total 150M
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:53 2023-09-17_19-53_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  472 Sep 17 19:53 2023-09-17_19-53_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:54 2023-09-17_19-54_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  465 Sep 17 19:54 2023-09-17_19-54_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:55 2023-09-17_19-55_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  463 Sep 17 19:55 2023-09-17_19-55_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:56 2023-09-17_19-56_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  460 Sep 17 19:56 2023-09-17_19-56_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:57 2023-09-17_19-57_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  447 Sep 17 19:57 2023-09-17_19-57_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:58 2023-09-17_19-58_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  457 Sep 17 19:58 2023-09-17_19-58_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 19:59 2023-09-17_19-59_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  455 Sep 17 19:59 2023-09-17_19-59_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:00 2023-09-17_20-00_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  468 Sep 17 20:00 2023-09-17_20-00_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:01 2023-09-17_20-01_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  467 Sep 17 20:01 2023-09-17_20-01_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:02 2023-09-17_20-02_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  470 Sep 17 20:02 2023-09-17_20-02_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:03 2023-09-17_20-03_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  470 Sep 17 20:03 2023-09-17_20-03_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:04 2023-09-17_20-04_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  457 Sep 17 20:04 2023-09-17_20-04_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:05 2023-09-17_20-05_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  468 Sep 17 20:05 2023-09-17_20-05_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:06 2023-09-17_20-06_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  461 Sep 17 20:06 2023-09-17_20-06_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:07 2023-09-17_20-07_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  463 Sep 17 20:07 2023-09-17_20-07_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:08 2023-09-17_20-08_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  477 Sep 17 20:08 2023-09-17_20-08_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:09 2023-09-17_20-09_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  467 Sep 17 20:09 2023-09-17_20-09_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:10 2023-09-17_20-10_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  465 Sep 17 20:10 2023-09-17_20-10_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:11 2023-09-17_20-11_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  461 Sep 17 20:11 2023-09-17_20-11_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:12 2023-09-17_20-12_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  466 Sep 17 20:12 2023-09-17_20-12_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:13 2023-09-17_20-13_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  476 Sep 17 20:13 2023-09-17_20-13_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:14 2023-09-17_20-14_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  467 Sep 17 20:14 2023-09-17_20-14_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:15 2023-09-17_20-15_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  457 Sep 17 20:15 2023-09-17_20-15_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:16 2023-09-17_20-16_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  468 Sep 17 20:16 2023-09-17_20-16_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:17 2023-09-17_20-17_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  469 Sep 17 20:17 2023-09-17_20-17_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:18 2023-09-17_20-18_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  469 Sep 17 20:18 2023-09-17_20-18_states.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker 1.1K Sep 17 20:19 2023-09-17_20-19_objects.json.gz
                                      -rw-rwxr--+ 1 iobroker iobroker  466 Sep 17 20:19 2023-09-17_20-19_states.json.gz
                                      die Datei die man braucht wäre eher
                                      2023-09-06_10-19_states.json.gz
                                      das wäre perfekt
                                      • E Esmax666
                                        total 150M
                                        das wäre perfekt
                                        das wäre perfekt
                                        Die hast du aber nicht mehr. Kein anderweitiges, richtiges Backup?
                                          das wäre perfekt
                                          Esmax666
                                          @thomas-braun ich hab gerade ein backupiobroker.tar backup gefunden
                                          ich wollte die Datei probieren aber ich bekomme
