  4. Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?
    5.3k
155 Beiträge 2 Kommentatoren 18.0k Aufrufe 1 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    #92
    So hier wie gesagt nochmal das mit der cron Node - und hier siehst Du auch wie man in der Node definierte events triggern kann:
    Die iobOut node musst halt aktivieren.
            "id": "adb1fab2e10dd6ac",
            "type": "cronplus",
            "z": "eb632aa6ea31f654",
            "name": "",
            "outputField": "payload",
            "timeZone": "",
            "persistDynamic": false,
            "commandResponseMsgOutput": "output1",
            "outputs": 1,
            "options": [
                    "name": "Sonnenaufgang",
                    "topic": "mqtt.0.SmartHome.Haus.Obergeschoss.Esszimmer.EZ_Rollo.cmnd.POWER1",
                    "payloadType": "str",
                    "payload": "ON",
                    "expressionType": "solar",
                    "expression": "0 * * * * * *",
                    "location": "50.05 9.10",
                    "offset": "0",
                    "solarType": "selected",
                    "solarEvents": "sunrise"
                    "name": "Sonnenuntergang",
                    "topic": "mqtt.0.SmartHome.Haus.Obergeschoss.Esszimmer.EZ_Rollo.cmnd.POWER2",
                    "payload": "ON",
                    "offset": "0",
                    "solarEvents": "sunset"
            "x": 480,
            "y": 460,
            "wires": [
                    "e758c9ada7c0988f",
                    "5d2aa9c5ad8ae144"
            "id": "e758c9ada7c0988f",
            "type": "ioBroker out",
            "d": true,
            "name": "",
            "topic": "",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 700,
            "y": 420,
            "wires": []
            "id": "5d2aa9c5ad8ae144",
            "type": "debug",
            "name": "Demo Test Solarevents",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "",
            "statusType": "auto",
            "x": 730,
            "y": 460,
            "wires": []
            "id": "c0202281d60c1a17",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "trigger",
            "payload": "Sonnenaufgang",
            "x": 240,
            "y": 440,
            "wires": [
                    "adb1fab2e10dd6ac"
            "id": "16237532e6d1ff7b",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "trigger",
            "payload": "Sonnenuntergang",
            "x": 250,
            "y": 480,
            "wires": [
                    "adb1fab2e10dd6ac"
    Die Konfiguration der cronplus Node siehst ja in dem Beitrag: https://forum.iobroker.net/post/1045427
    E 1 Antwort Letzte Antwort
    • E Einstein2002
      @mickym
      Gemacht.
      Hatte den Punkt schon gesucht und nicht gefunden.
      Ich möchte das auch gerne so gut beherrschen.
      mickymM Offline
      mickymM Offline
      mickym
      #93
      @einstein2002 sagte in Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?:
      @mickym
      Gemacht.
      Das wird schon - mit der Zeit kommt die Übung. Du bist immerhin einer der wenigen hier, der erkennt wieviel Funktionalität in NodeRed steckt und dass es in meinen Augen übersichtlicher und mächtiger als die Puzzleteilchen ist.
      • mickymM Offline
        mickymM Offline
        mickym
        #94
        Wie gesagt ich empfehle Dir aber, wenn Du mit mosquitto kommunizierst, das direkt aus NodeRed zu tun - Du bekommst ja trotzdem im iobroker über den Adapter nach wie vor den Status angezeigt. Es vermindert halt eine Fehlerquelle (wie eben das mit der mqtt Konfiguration). Anders ist es, wenn Du über andere Adapter Geräte steuerst.
        • mickymM mickym
                  "type": "cronplus",
                  "name": "",
                  "timeZone": "",
                  "outputs": 1,
                  "options": [
                          "payload": "ON",
                          "offset": "0",
                          "payload": "ON",
                          "offset": "0",
                  "x": 480,
                  "y": 460,
                  "wires": [
                          "e758c9ada7c0988f",
                          "5d2aa9c5ad8ae144"
                  "d": true,
                  "name": "",
                  "topic": "",
                  "ack": "false",
                  "stateName": "",
                  "role": "",
                  "payloadType": "",
                  "readonly": "",
                  "stateUnit": "",
                  "stateMin": "",
                  "stateMax": "",
                  "x": 700,
                  "y": 420,
                  "wires": []
                  "type": "debug",
                  "active": true,
                  "tosidebar": true,
                  "console": false,
                  "tostatus": false,
                  "statusVal": "",
                  "x": 730,
                  "y": 460,
                  "wires": []
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                          "p": "topic",
                          "vt": "str"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "trigger",
                  "x": 240,
                  "y": 440,
                  "wires": [
                          "adb1fab2e10dd6ac"
                  "type": "inject",
                  "name": "",
                  "props": [
                          "p": "payload"
                          "p": "topic",
                          "vt": "str"
                  "repeat": "",
                  "crontab": "",
                  "once": false,
                  "onceDelay": 0.1,
                  "topic": "trigger",
                  "x": 250,
                  "y": 480,
                  "wires": [
                          "adb1fab2e10dd6ac"
          Einstein2002
          #95
          @mickym
          Hmm.. würde ich gerne machen nur will die nicht.
          Ja ich weiß meist sitzt das Problem vor dem Bildschirm.. 😀
          Proxmox, VM`s Windows, IoBroker im unprivilegiert LXC, Openmediavault; LXC `s Tasmota, PiHole, , InfluxDB, Motioneye, WireguardVPN, UniFi:
          Smarthome...Sonoff, Alexa, Wled, raspberrymatic,...
          • E Einstein2002
            @mickym
            mickymM Offline
            mickymM Offline
            mickym
            #96
            @einstein2002 Die Node aufmachen und auf den Button klicken:
            • mickymM mickym
              Einstein2002
              #97
              @mickym
              prinzipiell gebe ich dir da voll recht, auch sehe ich keinen Nachteil damit.
              Dann bauen wir das mal um. Oder keine Lust mehr? Du hast ja schon mehr gemacht als ich je hätte erwarten können.
              • mickymM mickym
                Einstein2002
                #98
                @mickym sagte in Wie mit MQTT Daten in der IOBroker VIS justgage anzeigen?:
                Soweit runter hatte ich nicht geschaut.
                Hab oben gesucht.
                • E Einstein2002
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #99
                  @einstein2002 Ich bin fit wie ein Turnschuh - kann mal sein, dass es bissi länger dauert, wenn ich mir zwischenzeitlich was zwischen die Kiemen schiebe. ;)
                  • mickymM mickym
                    Einstein2002
                    schrieb am zuletzt editiert von Einstein2002
                    #100
                    @mickym
                    Okay dann los gehts.
                    Ich hab die anderen Flows mal deaktiviert.
                    • E Einstein2002
                      @mickym
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #101
                      @mickym
                      Gut Du sagst was du willst - ich stehe bereit ....
                      Ich werde Dir vielleicht nicht mehr den ganzen Flow vorgeben, damit Du immer mehr selbstständig Laufen kannst in NodeRed.
                      • mickymM mickym
                        @mickym
                        Einstein2002
                        #102
                        @mickym
                        Bleiben wir doch bei dem Rollo. Die anderen kann ich ja nachbauen.
                        Dann wäre es der eine Rollo, den kann ich ja dann später noch erweitern mit einer geschalteten Steckdose.
                        Da fällt mir noch genug ein. Ich brauche nur ein Grundgerüst auf das ich immer zurückgreifen kann.
                        Aber machen wir das an diesem Rollo fest.
                        • E Einstein2002
                          @mickym
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #103
                          @einstein2002 Gut was willst Du machen - das mit dem Hoch- Runterfahren mit Sonnenevents haben wir doch gemacht.
                          E 2 Antworten Letzte Antwort
                          • mickymM mickym
                            Einstein2002
                            #104
                            @mickym
                            doch gehen wir ja noch den Weg über den IOB?
                            Dachte jetzt steuern wir direkt über MQTT Explorer
                            Und wieder stehe ich auf dem Schlauch.
                            Hatten wir nicht MQTT in und out ins spiel bringen wollen?
                            • mickymM mickym
                              Einstein2002
                              #105
                              @mickym
                              • E Einstein2002
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #106
                                @einstein2002 Ach so na in diesem Fall wenn Du ohne den iobroker arbeiten willst, dann schmeiß oben die iobroker Out Node weg und konfigurieren in der mqtt Node erst mal Dein mosquitto.
                                • mickymM mickym
                                  Einstein2002
                                  #107
                                  @mickym
                                  • E Einstein2002
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #108
                                    @einstein2002 Ja und unter Sicherheit ggf. falls Du im mosquitto einen Benutzernamen und Passwort hast, mit dem Du Dich bei mosquitto anmeldest
                                    • mickymM mickym
                                      Einstein2002
                                      #109
                                      @mickym Was wäre da sinnvoll zu ändern? Nachrichten beim Verbindungsaufbau?
                                      • mickymM mickym
                                        Einstein2002
                                        #110
                                        @mickym
                                        das hab ich eingetragen, wollte es nicht zeigen.
                                        • E Einstein2002
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #111
                                          @einstein2002 OK - alles andere kannst Du leer lassen. Eine Client-ID kannst noch eintragen - dann siehst im mosquitto Log wer sich da verbindet.
